>gdb /usr/local/bin/kicad GNU gdb (GDB; openSUSE Leap 42.3) 8.2 Copyright (C) 2018 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-suse-linux". Type "show configuration" for configuration details. For bug reporting instructions, please see: . Find the GDB manual and other documentation resources online at: . For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from /usr/local/bin/kicad...(no debugging symbols found)...done. (gdb) run Starting program: /usr/local/bin/kicad Missing separate debuginfos, use: zypper install glibc-debuginfo-2.22-22.1.x86_64 [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib64/libthread_db.so.1". [New Thread 0x7fffe7043700 (LWP 8414)] [New Thread 0x7fffe6842700 (LWP 8415)] [New Thread 0x7fffe6041700 (LWP 8416)] [New Thread 0x7fffd31e5700 (LWP 8418)] Fatal Error: Mismatch between the program and library build versions detected. The library used 3.0 (wchar_t,compiler with C++ ABI 1011,wx containers,compatible with 2.8), and wxNet used 3.0 (wchar_t,compiler with C++ ABI 1002,STL containers,compatible with 2.8). Thread 1 "kicad" received signal SIGABRT, Aborted. 0x00007ffff3862f67 in raise () from /lib64/libc.so.6 Missing separate debuginfos, use: zypper install Mesa-libEGL1-debuginfo-17.0.5-176.1.x86_64 Mesa-libGL1-debuginfo-17.0.5-176.1.x86_64 Mesa-libglapi0-debuginfo-17.0.5-176.1.x86_64 fontconfig-debuginfo-2.11.1-4.3.x86_64 glibc-locale-debuginfo-2.22-22.1.x86_64 gtk2-theming-engine-adwaita-debuginfo-3.20.2-3.3.x86_64 gvfs-debuginfo-1.28.3-5.3.1.x86_64 krb5-debuginfo-1.12.5-22.1.x86_64 libFLAC8-debuginfo-1.3.2-2.3.1.x86_64 libGLEW1_13-debuginfo-1.13.0-4.4.x86_64 libGLU1-debuginfo-9.0.0-18.4.x86_64 libSM6-debuginfo-1.2.2-8.3.x86_64 libX11-6-debuginfo-1.6.3-10.3.1.x86_64 libX11-xcb1-debuginfo-1.6.3-10.3.1.x86_64 libXcomposite1-debuginfo-0.4.4-13.3.x86_64 libXcursor1-debuginfo-1.1.14-10.6.1.x86_64 libXdamage1-debuginfo-1.1.4-12.3.x86_64 libXext6-debuginfo-1.3.3-6.3.x86_64 libXfixes3-debuginfo-5.0.1-10.3.x86_64 libXi6-debuginfo-1.7.5-8.1.x86_64 libXinerama1-debuginfo-1.1.3-8.3.x86_64 libXrandr2-debuginfo-1.5.0-9.1.x86_64 libXrender1-debuginfo-0.9.9-6.3.x86_64 libXxf86vm1-debuginfo-1.1.4-4.3.x86_64 libasound2-debuginfo-1.1.4.1-1.1.x86_64 libatk-1_0-0-debuginfo-2.20.0-3.4.x86_64 libbz2-1-debuginfo-1.0.6-34.15.x86_64 libcairo2-debuginfo-1.15.2-8.3.1.x86_64 libcanberra-gtk0-debuginfo-0.30-14.3.x86_64 libcanberra-gtk2-module-debuginfo-0.30-14.3.x86_64 libcap2-debuginfo-2.22-18.16.x86_64 libcurl4-debuginfo-7.37.0-45.1.x86_64 libdatrie1-debuginfo-0.2.4-22.3.x86_64 libdbus-1-3-debuginfo-1.8.22-5.1.x86_64 libexpat1-debuginfo-2.1.0-24.1.x86_64 libffi4-debuginfo-5.3.1+r233831-10.1.x86_64 libfreetype6-debuginfo-2.6.3-5.3.1.x86_64 libgcc_s1-debuginfo-8.2.1+r264010-2.3.x86_64 libgcrypt20-debuginfo-1.6.1-48.1.x86_64 libgdk_pixbuf-2_0-0-debuginfo-2.34.0-19.1.x86_64 libgio-2_0-0-debuginfo-2.48.2-3.4.x86_64 libglib-2_0-0-debuginfo-2.48.2-3.4.x86_64 libgmodule-2_0-0-debuginfo-2.48.2-3.4.x86_64 libgobject-2_0-0-debuginfo-2.48.2-3.4.x86_64 libgpg-error0-debuginfo-1.27-1.3.x86_64 libgraphite2-3-debuginfo-1.3.1-7.3.1.x86_64 libgthread-2_0-0-debuginfo-2.48.2-3.4.x86_64 libgtk-2_0-0-debuginfo-2.24.31-15.3.1.x86_64 libharfbuzz0-debuginfo-1.4.5-6.1.x86_64 libidn11-debuginfo-1.28-9.3.1.x86_64 libjpeg62-debuginfo-62.2.0-42.1.x86_64 libjpeg8-debuginfo-8.1.2-42.1.x86_64 libjson-c2-debuginfo-0.12-7.3.x86_64 libkeyutils1-debuginfo-1.5.9-7.13.x86_64 liblzma5-debuginfo-5.2.2-3.15.x86_64 libnotify4-debuginfo-0.7.6-8.3.x86_64 libogg0-debuginfo-1.3.0-6.3.x86_64 libopenssl1_0_0-debuginfo-1.0.2j-32.1.x86_64 libpango-1_0-0-debuginfo-1.40.1-3.4.x86_64 libpcre1-debuginfo-8.39-11.1.x86_64 libpixman-1-0-debuginfo-0.34.0-4.3.x86_64 libpng16-16-debuginfo-1.6.8-11.3.x86_64 libpulse0-debuginfo-9.0-8.1.x86_64 libpython2_7-1_0-debuginfo-2.7.13-27.9.1.x86_64 libselinux1-debuginfo-2.5-4.17.x86_64 libspeex1-debuginfo-1.2-1.1.x86_64 libssh2-1-debuginfo-1.4.3-18.3.x86_64 libstdc++6-debuginfo-8.2.1+r264010-2.3.x86_64 libsystemd0-debuginfo-228-65.1.x86_64 libthai0-debuginfo-0.1.25-3.3.x86_64 libuuid1-debuginfo-2.29.2-8.1.x86_64 libvorbisenc2-debuginfo-1.3.3-17.1.x86_64 libwayland-client0-debuginfo-1.13.0-2.3.x86_64 libwx_baseu-suse1-debuginfo-3.0.2-11.1.x86_64 libwx_gtk2u_adv-suse1-debuginfo-3.0.2-11.1.x86_64 libxcb-dri2-0-debuginfo-1.11.1-9.1.x86_64 libxcb-dri3-0-debuginfo-1.11.1-9.1.x86_64 libxcb-glx0-debuginfo-1.11.1-9.1.x86_64 libxcb-present0-debuginfo-1.11.1-9.1.x86_64 libxcb-render0-debuginfo-1.11.1-9.1.x86_64 libxcb-shm0-debuginfo-1.11.1-9.1.x86_64 libxcb-sync1-debuginfo-1.11.1-9.1.x86_64 libxcb-xfixes0-debuginfo-1.11.1-9.1.x86_64 libxcb1-debuginfo-1.11.1-9.1.x86_64 libxshmfence1-debuginfo-1.2-8.3.x86_64 libz1-debuginfo-1.2.8-14.3.1.x86_64 (gdb) bt #0 0x00007ffff3862f67 in raise () at /lib64/libc.so.6 #1 0x00007ffff386433a in abort () at /lib64/libc.so.6 #2 0x00007ffff63d7a19 in () at /usr/local/lib64/libwx_baseu-3.0.so.0 #3 0x00007ffff64794d1 in wxLog::OnLog(unsigned long, wxString const&, wxLogRecordInfo const&) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #4 0x00007ffff63df007 in wxLogger::DoLog(wchar_t const*, ...) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #5 0x00007ffff63db29b in wxAppConsoleBase::CheckBuildOptions(char const*, char const*) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #6 0x00007fffc740a6fd in () at /usr/lib64/libwx_baseu_net-suse.so.1 #7 0x00007ffff7dea1ea in call_init.part () at /lib64/ld-linux-x86-64.so.2 #8 0x00007ffff7dea2d3 in _dl_init () at /lib64/ld-linux-x86-64.so.2 #9 0x00007ffff7dee718 in dl_open_worker () at /lib64/ld-linux-x86-64.so.2 #10 0x00007ffff7dea0a4 in _dl_catch_error () at /lib64/ld-linux-x86-64.so.2 #11 0x00007ffff7dede7b in _dl_open () at /lib64/ld-linux-x86-64.so.2 #12 0x00007ffff0248eeb in dlopen_doit () at /lib64/libdl.so.2 #13 0x00007ffff7dea0a4 in _dl_catch_error () at /lib64/ld-linux-x86-64.so.2 #14 0x00007ffff024949d in _dlerror_run () at /lib64/libdl.so.2 #15 0x00007ffff0248f81 in dlopen@@GLIBC_2.2.5 () at /lib64/libdl.so.2 #16 0x00007fffd087fabb in _PyImport_GetDynLoadFunc () at /usr/lib64/libpython2.7.so.1.0 #17 0x00007fffd087c7ff in _PyImport_LoadDynamicModule () at /usr/lib64/libpython2.7.so.1.0 #18 0x00007fffd0836fa4 in () at /usr/lib64/libpython2.7.so.1.0 #19 0x00007fffd08374c7 in PyImport_ImportModuleLevel () at /usr/lib64/libpython2.7.so.1.0 #20 0x00007fffd0816bdb in () at /usr/lib64/libpython2.7.so.1.0 #21 0x00007fffd07ae986 in PyObject_Call () at /usr/lib64/libpython2.7.so.1.0 #22 0x00007fffd08173a6 in PyEval_CallObjectWithKeywords () at /usr/lib64/libpython2.7.so.1.0 #23 0x00007fffd081aaac in PyEval_EvalFrameEx () at /usr/lib64/libpython2.7.so.1.0 #24 0x00007fffd0822604 in PyEval_EvalCodeEx () at /usr/lib64/libpython2.7.so.1.0 --Type for more, q to quit, c to continue without paging-- #25 0x00007fffd0877642 in PyEval_EvalCode () at /usr/lib64/libpython2.7.so.1.0 #26 0x00007fffd087bd40 in PyImport_ExecCodeModuleEx () at /usr/lib64/libpython2.7.so.1.0 #27 0x00007fffd087bf5c in () at /usr/lib64/libpython2.7.so.1.0 #28 0x00007fffd0836fa4 in () at /usr/lib64/libpython2.7.so.1.0 #29 0x00007fffd08375d7 in PyImport_ImportModuleLevel () at /usr/lib64/libpython2.7.so.1.0 #30 0x00007fffd0816bdb in () at /usr/lib64/libpython2.7.so.1.0 #31 0x00007fffd07ae986 in PyObject_Call () at /usr/lib64/libpython2.7.so.1.0 #32 0x00007fffd08173a6 in PyEval_CallObjectWithKeywords () at /usr/lib64/libpython2.7.so.1.0 #33 0x00007fffd081aaac in PyEval_EvalFrameEx () at /usr/lib64/libpython2.7.so.1.0 #34 0x00007fffd0822604 in PyEval_EvalCodeEx () at /usr/lib64/libpython2.7.so.1.0 #35 0x00007fffd0877642 in PyEval_EvalCode () at /usr/lib64/libpython2.7.so.1.0 #36 0x00007fffd087bd40 in PyImport_ExecCodeModuleEx () at /usr/lib64/libpython2.7.so.1.0 #37 0x00007fffd087bf5c in () at /usr/lib64/libpython2.7.so.1.0 #38 0x00007fffd0796249 in () at /usr/lib64/libpython2.7.so.1.0 #39 0x00007fffd087c5d3 in () at /usr/lib64/libpython2.7.so.1.0 #40 0x00007fffd0836de2 in () at /usr/lib64/libpython2.7.so.1.0 #41 0x00007fffd08374c7 in PyImport_ImportModuleLevel () at /usr/lib64/libpython2.7.so.1.0 #42 0x00007fffd0816bdb in () at /usr/lib64/libpython2.7.so.1.0 #43 0x00007fffd07ae986 in PyObject_Call () at /usr/lib64/libpython2.7.so.1.0 #44 0x00007fffd08173a6 in PyEval_CallObjectWithKeywords () at /usr/lib64/libpython2.7.so.1.0 #45 0x00007fffd081aaac in PyEval_EvalFrameEx () at /usr/lib64/libpython2.7.so.1.0 #46 0x00007fffd0822604 in PyEval_EvalCodeEx () at /usr/lib64/libpython2.7.so.1.0 #47 0x00007fffd0877642 in PyEval_EvalCode () at /usr/lib64/libpython2.7.so.1.0 #48 0x00007fffd087bd40 in PyImport_ExecCodeModuleEx () at /usr/lib64/libpython2.7.so.1.0 #49 0x00007fffd087bf5c in () at /usr/lib64/libpython2.7.so.1.0 #50 0x00007fffd0796249 in () at /usr/lib64/libpython2.7.so.1.0 #51 0x00007fffd0836fa4 in () at /usr/lib64/libpython2.7.so.1.0 --Type for more, q to quit, c to continue without paging-- #52 0x00007fffd08374c7 in PyImport_ImportModuleLevel () at /usr/lib64/libpython2.7.so.1.0 #53 0x00007fffd0816bdb in () at /usr/lib64/libpython2.7.so.1.0 #54 0x00007fffd0817c61 in PyEval_EvalFrameEx () at /usr/lib64/libpython2.7.so.1.0 #55 0x00007fffd081ca54 in PyEval_EvalFrameEx () at /usr/lib64/libpython2.7.so.1.0 #56 0x00007fffd0822604 in PyEval_EvalCodeEx () at /usr/lib64/libpython2.7.so.1.0 #57 0x00007fffd081cd2b in PyEval_EvalFrameEx () at /usr/lib64/libpython2.7.so.1.0 #58 0x00007fffd0822604 in PyEval_EvalCodeEx () at /usr/lib64/libpython2.7.so.1.0 #59 0x00007fffd0877642 in PyEval_EvalCode () at /usr/lib64/libpython2.7.so.1.0 #60 0x00007fffd087d88b in () at /usr/lib64/libpython2.7.so.1.0 #61 0x00007fffd087da92 in PyRun_StringFlags () at /usr/lib64/libpython2.7.so.1.0 #62 0x00007fffd07987e9 in PyRun_SimpleStringFlags () at /usr/lib64/libpython2.7.so.1.0 #63 0x00007fffd13a3c2a in pcbnewInitPythonScripting(char const*) () at /usr/local/bin/_pcbnew.kiface #64 0x00007fffd0da83cf in PCB::IFACE::OnKifaceStart(PGM_BASE*, int) () at /usr/local/bin/_pcbnew.kiface #65 0x00000000004c2179 in () #66 0x00000000004c0d85 in () #67 0x0000000000464f3f in () #68 0x000000000046547a in () #69 0x00007ffff6554bba in wxEvtHandler::ProcessEventIfMatchesId(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #70 0x00007ffff6554cc3 in wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #71 0x00007ffff655508b in wxEvtHandler::TryHereOnly(wxEvent&) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #72 0x00000000004a6769 in () #73 0x00007ffff6554e83 in wxEvtHandler::DoTryChain(wxEvent&) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #74 0x00007ffff6555175 in wxEvtHandler::ProcessEvent(wxEvent&) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #75 0x00007ffff6ea33ab in wxWindowBase::TryAfter(wxEvent&) () at /usr/local/lib64/libwx_gtk2u_core-3.0.so.0 #76 0x00007ffff6ea33ab in wxWindowBase::TryAfter(wxEvent&) () at /usr/local/lib64/libwx_gtk2u_core-3.0.so.0 --Type for more, q to quit, c to continue without paging-- #77 0x00007ffff6554ed7 in wxEvtHandler::SafelyProcessEvent(wxEvent&) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #78 0x00007ffff6d25bc1 in wxgtk_button_clicked_callback () at /usr/local/lib64/libwx_gtk2u_core-3.0.so.0 #79 0x00007ffff1ec7b37 in () at /usr/lib64/libgobject-2.0.so.0 #80 0x00007ffff1ee0918 in g_signal_emit_valist () at /usr/lib64/libgobject-2.0.so.0 #81 0x00007ffff1ee1592 in g_signal_emit () at /usr/lib64/libgobject-2.0.so.0 #82 0x00007ffff328f9d5 in () at /usr/lib64/libgtk-x11-2.0.so.0 #83 0x00007ffff1ec7908 in g_closure_invoke () at /usr/lib64/libgobject-2.0.so.0 #84 0x00007ffff1ed8b37 in () at /usr/lib64/libgobject-2.0.so.0 #85 0x00007ffff1ee12a8 in g_signal_emit_valist () at /usr/lib64/libgobject-2.0.so.0 #86 0x00007ffff1ee1592 in g_signal_emit () at /usr/lib64/libgobject-2.0.so.0 #87 0x00007ffff328e8e9 in () at /usr/lib64/libgtk-x11-2.0.so.0 #88 0x00007ffff332fb75 in () at /usr/lib64/libgtk-x11-2.0.so.0 #89 0x00007ffff1ec7908 in g_closure_invoke () at /usr/lib64/libgobject-2.0.so.0 #90 0x00007ffff1ed90cb in () at /usr/lib64/libgobject-2.0.so.0 #91 0x00007ffff1ee0f78 in g_signal_emit_valist () at /usr/lib64/libgobject-2.0.so.0 #92 0x00007ffff1ee1592 in g_signal_emit () at /usr/lib64/libgobject-2.0.so.0 #93 0x00007ffff343f8d4 in () at /usr/lib64/libgtk-x11-2.0.so.0 #94 0x00007ffff332e324 in gtk_propagate_event () at /usr/lib64/libgtk-x11-2.0.so.0 #95 0x00007ffff332e6db in gtk_main_do_event () at /usr/lib64/libgtk-x11-2.0.so.0 #96 0x00007ffff2fa1bfc in () at /usr/lib64/libgdk-x11-2.0.so.0 #97 0x00007ffff1517134 in g_main_context_dispatch () at /usr/lib64/libglib-2.0.so.0 #98 0x00007ffff1517388 in () at /usr/lib64/libglib-2.0.so.0 #99 0x00007ffff151764a in g_main_loop_run () at /usr/lib64/libglib-2.0.so.0 #100 0x00007ffff332d7c7 in gtk_main () at /usr/lib64/libgtk-x11-2.0.so.0 #101 0x00007ffff6cc93e5 in wxGUIEventLoop::DoRun() () at /usr/local/lib64/libwx_gtk2u_core-3.0.so.0 #102 0x00007ffff6415e13 in wxEventLoopBase::Run() () at /usr/local/lib64/libwx_baseu-3.0.so.0 #103 0x00007ffff63dc546 in wxAppConsoleBase::MainLoop() () at /usr/local/lib64/libwx_baseu-3.0.so.0 --Type for more, q to quit, c to continue without paging-- #104 0x0000000000460e46 in () #105 0x00007ffff6465457 in wxEntry(int&, wchar_t**) () at /usr/local/lib64/libwx_baseu-3.0.so.0 #106 0x0000000000444638 in () #107 0x00007ffff384e725 in __libc_start_main () at /lib64/libc.so.6 #108 0x0000000000448499 in _start () (gdb)
