pc3bs:~/Software/KiCAD/kicad-source-mirror-master-20190222/build # >cmake -DKICAD_SCRIPTING_WXPYTHON=OFF -Wdev -DCMAKE_BUILD_TYPE=Debug ../ -- The C compiler identification is GNU 4.8.5 -- The CXX compiler identification is GNU 7.3.1 -- Check for working C compiler: /usr/bin/cc -- Check for working C compiler: /usr/bin/cc -- works -- Detecting C compiler ABI info -- Detecting C compiler ABI info - done -- Detecting C compile features -- Detecting C compile features - done -- Check for working CXX compiler: /usr/bin/c++ -- Check for working CXX compiler: /usr/bin/c++ -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- Detecting CXX compile features -- Detecting CXX compile features - done -- KiCad install dir: -- Looking for malloc.h -- Looking for malloc.h - found -- Looking for iso646.h -- Looking for iso646.h - found -- Looking for stdint.h -- Looking for stdint.h - found -- Looking for strcasecmp -- Looking for strcasecmp - found -- Looking for strncasecmp -- Looking for strncasecmp - found -- Looking for strtok_r -- Looking for strtok_r - found -- Looking for malloc -- Looking for malloc - found -- Looking for math.h -- Looking for math.h - found -- Looking for C++ include cmath -- Looking for C++ include cmath - found -- Looking for asinh -- Looking for asinh - found -- Looking for acosh -- Looking for acosh - found -- Looking for atanh -- Looking for atanh - found -- Performing Test HAVE_CMATH_ISINF -- Performing Test HAVE_CMATH_ISINF - Success -- Looking for clock_gettime in rt -- Looking for clock_gettime in rt - found -- Looking for gettimeofday -- Looking for gettimeofday - found -- Looking for getc_unlocked -- Looking for getc_unlocked - found -- Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE -- Performing Test COMPILER_SUPPORTS_WSUGGEST_OVERRIDE - Success -- Performing Test COMPILER_SUPPORTS_WVLA -- Performing Test COMPILER_SUPPORTS_WVLA - Success -- Performing Test COMPILER_SUPPORTS_WSHADOW -- Performing Test COMPILER_SUPPORTS_WSHADOW - Success -- Found OpenGL: /usr/lib64/libGL.so -- Found GLEW: /usr/include -- Check for installed GLEW -- found -- Found GLM: /usr/include (found suitable version "0.9.5.3", minimum required is "0.9.5.1") -- Found CURL: /usr/lib64/libcurl.so (found version "7.37.0") -- Found PkgConfig: /usr/bin/pkg-config (found version "0.28") -- Checking for module 'cairo' -- Found cairo, version 1.15.2 -- Found Cairo: /usr/lib64/libcairo.so (found suitable version "1.15.2", minimum required is "1.12") -- Checking for module 'pixman-1' -- Found pixman-1, version 0.34.0 -- Found Pixman: /usr/lib64/libpixman-1.so (found suitable version "0.34.0", minimum required is "0.30") -- Boost version: 1.61.0 -- Found ngspice: /usr/include -- Found SWIG: /usr/bin/swig (found suitable version "3.0.10", minimum required is "3.0") -- Found PythonInterp: /usr/bin/python2 (found suitable version "2.7.13", minimum required is "2.6") -- Check for installed Python Interpreter -- found -- Python module install path: lib/python2.7/site-packages -- Found PythonLibs: /usr/lib64/libpython2.7.so (found suitable version "2.7.13", minimum required is "2.6") -- Found wxWidgets: -L/usr/local/lib64;-pthread;;;-lwx_gtk2u_gl-3.0;-lwx_gtk2u_aui-3.0;-lwx_gtk2u_adv-3.0;-lwx_gtk2u_html-3.0;-lwx_gtk2u_core-3.0;-lwx_baseu_net-3.0;-lwx_baseu-3.0;-lwx_baseu_xml-3.0;-lwx_gtk2u_stc-3.0 (found suitable version "3.0.4", minimum required is "3.0.0") -- Found Doxygen: /usr/bin/doxygen (found version "1.8.11") -- Found OpenSSL: /usr/lib64/libssl.so;/usr/lib64/libcrypto.so (found version "1.0.2j") -- S3DSG version: 2.0.0 -- Boost version: 1.61.0 -- Found the following Boost libraries: -- unit_test_framework -- filesystem -- system -- Boost version: 1.61.0 -- Found the following Boost libraries: -- unit_test_framework -- Boost version: 1.61.0 -- Found the following Boost libraries: -- unit_test_framework -- Configuring done -- Generating done -- Build files have been written to: xxxxxx/kicad-source-mirror-master-20190222/build pc3bs:~/Software/KiCAD/kicad-source-mirror-master-20190222/build #
