>make -i kicad Scanning dependencies of target polygon [ 0%] Building CXX object polygon/CMakeFiles/polygon.dir/math_for_graphics.cpp.o [ 0%] Building CXX object polygon/CMakeFiles/polygon.dir/polygon_test_point_inside.cpp.o [ 0%] Building CXX object polygon/CMakeFiles/polygon.dir/clipper.cpp.o [ 0%] Linking CXX static library libpolygon.a [ 0%] Built target polygon Scanning dependencies of target bitmaps [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/folder.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinorient_right.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinorient_left.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinorient_up.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinorient_down.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_normal.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_invert.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_clock_normal.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_clock_invert.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_active_low_input.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_clock_active_low.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_active_low_output.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_clock_fall.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pinshape_nonlogic.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_input.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_output.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_bidi.cpp.o [ 0%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_3states.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_passive.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_notspecif.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_powerinput.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_poweroutput.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_opencoll.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_openemit.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/pintype_noconnect.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/refresh.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/small_down.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/small_edit.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/small_library.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/small_plus.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/small_up.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/trash.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/tree_nosel.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/tree_sel.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_16/www.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/about.cpp.o [ 2%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_arc.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_board.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_bus2bus.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_bus.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_circle.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_component.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_corner.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_dashed_line.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_dimension.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_document.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_gerber.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_glabel.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_graphical_segments.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_graphical_polygon.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_hierarchical_label.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_hierar_pin.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_hierarchical_subsheet.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_junction.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_keepout_area.cpp.o [ 5%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_library.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_line2bus.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_line_label.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_line.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_pcb_target.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_polygon.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_power.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_rectangle.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_tracks.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_via.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_zone_cutout.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/add_zone.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/align_items.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/align_items_left.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/align_items_right.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/align_items_top.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/align_items_bottom.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/align_items_center.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/align_items_middle.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/anchor.cpp.o [ 7%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/annotate_down_right.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/annotate_right_down.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/annotate.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/apply_pad_settings.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/array.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/auto_associe.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/auto_delete_track.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/auto_track_width.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/autoplace_fields.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/axis3d_back.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/axis3d_bottom.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/axis3d_front.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/axis3d_left.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/axis3d_right.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/axis3d_top.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/axis3d.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/bitmap2component.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/bom.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/book.cpp.o [ 10%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/break_bus.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/break_line.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/browse_files.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/calculator.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/cancel.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/change_entry_orient.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/contrast_mode.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/create_cmp_file.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/checked_ok.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/color_materials.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/component_select_unit.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/component_select_alternate_shape.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/config.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/copy.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/copy_pad_settings.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/copper_layers_setup.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/cursor_shape.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/cursor.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/custom_pad_to_primitives.cpp.o [ 12%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/cut.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/cvpcb.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/dashline.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/datasheet.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_association.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_bus.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_circle.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_connection.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_dimension.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_field.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_gerber.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_glabel.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_line.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_module.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_net.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_node.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_pad.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_polygon.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_rectangle.cpp.o [ 15%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_sheet.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete_track.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/delete.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/directory.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/directory_browser.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/display_options.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/distribute_horizontal.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/distribute_vertical.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/down.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/drag.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/drag_outline_segment.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/drag_pad.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/drag_segment_withslope.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/drc_off.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/drc.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/duplicate.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/edges_sketch.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/edit_comp_footprint.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/edit_comp_ref.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/edit_comp_value.cpp.o [ 17%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/edit_module.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/editor.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/edit_cmp_symb_links.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/edit_text.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/edit.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/eeschema.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/enter_sheet.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ercerr.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/erc_green.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ercwarn.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/erc.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/exit.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/exchange.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/export3d.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/export_dsn.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/export_idf.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/export_footprint_names.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/export_module.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/export_part.cpp.o [ 20%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/export_step.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/export.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/fabrication.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/file_footprint.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/fill_zone.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/find.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/find_replace.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/flag.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/flip_board.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/fonts.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/footprint_text.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gbr_select_mode0.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gbr_select_mode1.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gbr_select_mode2.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gerber_file.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gerber_job_file.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gerbview_show_negative_objects.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gerbview_drill_file.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gerbview_clear_layers.cpp.o [ 22%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/general_deletions.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/general_ratsnest.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/glabel2label.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/glabel2text.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/gl_change.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/go_down.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/go_up.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/green.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/grid_select.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/grid_select_axis.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/grid.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/hammer.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/help.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/hidden_pin.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/hierarchy_nav.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/highlight_remove.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/hotkeys.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/hotkeys_import.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/hotkeys_export.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/html.cpp.o [ 25%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/icon.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/icon_cvpcb_small.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/icon_gerbview_small.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import3d.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/image.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import_brd_file.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import_document.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import_footprint_names.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import_hierarchical_label.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import_module.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import_part.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import_project.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import_setup.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/import.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/info.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/insert_module_board.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/invisible_text.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/kicad_icon_small.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/label2glabel.cpp.o [ 27%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/label2text.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/label.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_ca.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_bg.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_cs.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_def.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_de.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_en.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_es.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_fr.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_fi.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_gr.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_hu.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_it.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_jp.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_ko.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_nl.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_pl.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_pt.cpp.o [ 30%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_ru.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_sk.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_sl.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_lt.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lang_zh.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/language.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/layers_manager.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/leave_sheet.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/left.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/libedit.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lib_next.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lib_previous.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/library_browse.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/library_archive.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/library_archive_as.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/library.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/library_table.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lines90.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/list_nets.cpp.o [ 32%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/load_gerber.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/load_module_board.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/load_module_lib.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/local_ratsnest.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/lock_unlock.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/locked.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/measurement.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/minus.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pcb_target.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mirror_h.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mirror_v.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mode_module.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mode_track.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/modratsnest.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_check.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_editor.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_wizard.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_filtered_list.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_full_list.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_options.cpp.o [ 35%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_pin_filtered_list.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_library_list.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_name_filtered_list.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module_ratsnest.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/module.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/modview_icon.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/morgan1.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/morgan2.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move_glabel.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move_exactly.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move_pad.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move_polygon.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move_rectangle.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move_sheet.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move_target.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/move_relative.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mw_add_gap.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mw_add_line.cpp.o [ 37%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mw_add_shape.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mw_add_stub_arc.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mw_add_stub.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/mw_toolbar.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/net_highlight.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/net_highlight_schematic.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/netlist.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/net_locked.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/net_unlocked.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_board.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_component.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_cvpcb.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_document.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_footprint.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_library.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_generic.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_page_layout.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_project.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/new_project_with_template.cpp.o [ 40%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/noconn.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/normal.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/online_help.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/open_brd_file.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/open_library.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/open_page_layout.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/open_project.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/open_document.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_3drender.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_all_tracks_and_vias.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_all_tracks.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_all_vias.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_arc.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_board.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_circle.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_generic.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_module.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_pad.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_pinsheet.cpp.o [ 42%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_pin.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_rectangle.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_segment.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_tracks.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_track.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/options_vias.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/opt_show_polygon.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/orient.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ortho.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pad_sketch.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pad.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pad_dimensions.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pad_enumerate.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pads_mask_layers.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/path.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pagelayout_load.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pagelayout_normal_view_mode.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pagelayout_special_view_mode.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/palette.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/part_properties.cpp.o [ 45%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/paste.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pcbnew.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pcbcalculator.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pcb_offset.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pin2pin.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pin_name_to.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pin_number_to.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pin_size_to.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pin_show_etype.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pin_table.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pin_to.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/pin.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/plot.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/plot_dxf.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/plot_hpg.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/plot_pdf.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/plot_ps.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/plot_svg.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/plus.cpp.o [ 47%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/polar_coord.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/post_compo.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/post_drill.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/post_module.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/preference.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/primitives_to_custom_pad.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/print_button.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ps_router.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ps_diff_pair.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ps_diff_pair_gap.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ps_diff_pair_tune_length.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ps_diff_pair_tune_phase.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ps_diff_pair_via_gap.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ps_tune_length.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/push_pad_settings.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/py_script.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/ratsnest.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/read_setup.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/recent.cpp.o [ 50%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/redo.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/red.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/reload2.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/reload.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/render_mode.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/reset_text.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/resize_sheet.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rescue.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/right.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/router_len_tuner.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/router_len_tuner_setup.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/router_len_tuner_amplitude_decr.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/router_len_tuner_amplitude_incr.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/router_len_tuner_dist_decr.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/router_len_tuner_dist_incr.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rotate_ccw.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rotate_cw.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rotate_neg_x.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rotate_pos_x.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rotate_neg_y.cpp.o [ 52%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rotate_pos_y.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rotate_neg_z.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/rotate_pos_z.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/save_as.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/save_fp_to_board.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/save_gerber.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/save_library.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/save_project.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/save_setup.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/save.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/select_grid.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/select_layer_pair.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/select_w_layer.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/select_same_sheet.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/shape_3d.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/sheetset.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/simulator.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/sim_run.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/sim_stop.cpp.o [ 55%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/sim_tune.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/sim_probe.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/sim_add_signal.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/sim_settings.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/search_tree.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/setcolor_3d_bg.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/setcolor_silkscreen.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/setcolor_soldermask.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/setcolor_solderpaste.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/setcolor_copper.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/setcolor_board_body.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_dcodenumber.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_footprint.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_mod_edge.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/showtrack.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_zone.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_zone_disable.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_zone_outline_only.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_all_layers.cpp.o [ 57%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_no_layers.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_no_copper_layers.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/show_all_copper_layers.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/spreadsheet.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/svg_file.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/swap_layer.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/text.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/text_sketch.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/three_d.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/tool_ratsnest.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/tools.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/track_locked.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/track_sketch.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/track_unlocked.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/transistor.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/undelete.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/undo.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/unit_inch.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/unit_mm.cpp.o [ 60%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/unknown.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/unlocked.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/unzip.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/up.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/update_fields.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/update_module_board.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/update_pcb_from_sch.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/use_3D_copper_thickness.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/via.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/via_buried.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/via_microvia.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/via_sketch.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/warning.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/web_support.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/width_net.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/width_segment.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/width_track_via.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/width_track.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/width_vias.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/wizard_add_fplib_small.cpp.o [ 62%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zip_tool.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zip.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zone_duplicate.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zone_unfill.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zoom.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zoom_area.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zoom_fit_in_page.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zoom_center_on_screen.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zoom_in.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zoom_out.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zoom_redraw.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_26/zoom_selection.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/dialog_warning.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_3d.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_cvpcb.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_eeschema.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_gerbview.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_kicad.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_libedit.cpp.o [ 65%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_modedit.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_pcbnew.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_bitmap2component.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_pcbcalculator.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/viewlibs_icon.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/icon_pagelayout_editor.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_48/wizard_add_fplib_icon.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_other/tune_diff_pair_length_legend.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_other/tune_diff_pair_skew_legend.cpp.o [ 67%] Building CXX object bitmaps_png/CMakeFiles/bitmaps.dir/cpp_other/tune_single_track_length_legend.cpp.o [ 67%] Linking CXX static library libbitmaps.a [ 67%] Built target bitmaps Scanning dependencies of target version_header [ 67%] Generating version string header -- Using Git to determine build version string. -- Found Git: /usr/bin/git (found version "2.13.7") -- Writing xxxxxx/kicad-source-mirror-master-20190222/build/kicad_build_version.h file with version: 5.1.0-rc1-unknown [ 67%] Built target version_header Scanning dependencies of target page_layout_lexer_source_files [ 67%] TokenList2DsnLexer.cmake creating: xxxxxx/kicad-source-mirror-master-20190222/include/page_layout_reader_lexer.h and xxxxxx/kicad-source-mirror-master-20190222/common/page_layout/page_layout_reader_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/common/page_layout/page_layout_reader.keywords [ 67%] Built target page_layout_lexer_source_files Scanning dependencies of target lib_table_lexer_source_files [ 67%] TokenList2DsnLexer.cmake creating: xxxxxx/kicad-source-mirror-master-20190222/include/lib_table_lexer.h and xxxxxx/kicad-source-mirror-master-20190222/common/lib_table_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/common/lib_table.keywords [ 67%] Built target lib_table_lexer_source_files Scanning dependencies of target gal [ 67%] Building CXX object common/CMakeFiles/gal.dir/basic_gal.cpp.o [ 67%] Building CXX object common/CMakeFiles/gal.dir/draw_panel_gal.cpp.o [ 67%] Building CXX object common/CMakeFiles/gal.dir/gl_context_mgr.cpp.o [ 67%] Building CXX object common/CMakeFiles/gal.dir/newstroke_font.cpp.o [ 67%] Building CXX object common/CMakeFiles/gal.dir/origin_viewitem.cpp.o [ 67%] Building CXX object common/CMakeFiles/gal.dir/painter.cpp.o [ 67%] Building CXX object common/CMakeFiles/gal.dir/text_utils.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/worksheet_viewitem.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/color4d.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/gal_display_options.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/graphics_abstraction_layer.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/hidpi_gl_canvas.cpp.o xxxxxx/kicad-source-mirror-master-20190222/common/gal/hidpi_gl_canvas.cpp: In constructor ‘HIDPI_GL_CANVAS::HIDPI_GL_CANVAS(wxWindow*, wxWindowID, const int*, const wxPoint&, const wxSize&, long int, const wxString&, const wxPalette&)’: xxxxxx/kicad-source-mirror-master-20190222/common/gal/hidpi_gl_canvas.cpp:41:5: error: ‘SetViewWantsBestResolution’ was not declared in this scope SetViewWantsBestResolution( true ); ^~~~~~~~~~~~~~~~~~~~~~~~~~ xxxxxx/kicad-source-mirror-master-20190222/common/gal/hidpi_gl_canvas.cpp: In member function ‘virtual float HIDPI_GL_CANVAS::GetBackingScaleFactor() const’: xxxxxx/kicad-source-mirror-master-20190222/common/gal/hidpi_gl_canvas.cpp:64:81: error: ‘class wxGLCanvas’ has no member named ‘GetBackingScaleFactor’; did you mean ‘GetContentScaleFactor’? return static_cast< wxGLCanvas* >( const_cast< HIDPI_GL_CANVAS* >( this ))->GetBackingScaleFactor(); ^~~~~~~~~~~~~~~~~~~~~ GetContentScaleFactor [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/stroke_font.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/geometry/hetriang.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/view/view_controls.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/view/view_overlay.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/view/wx_view_controls.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/view/zoom_controller.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/opengl_gal.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/gl_resources.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/gl_builtin_shaders.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/shader.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/vertex_item.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/vertex_container.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/cached_container.cpp.o [ 70%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/cached_container_gpu.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/cached_container_ram.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/noncached_container.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/vertex_manager.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/gpu_manager.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/antialiasing.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/opengl_compositor.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/opengl/utils.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/cairo/cairo_gal.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/cairo/cairo_compositor.cpp.o [ 72%] Building CXX object common/CMakeFiles/gal.dir/gal/cairo/cairo_print.cpp.o [ 72%] Linking CXX static library libgal.a /usr/bin/ar: CMakeFiles/gal.dir/gal/hidpi_gl_canvas.cpp.o: Datei oder Verzeichnis nicht gefunden [ 72%] Built target gal Scanning dependencies of target netlist_lexer_source_files [ 72%] TokenList2DsnLexer.cmake creating: xxxxxx/kicad-source-mirror-master-20190222/include/netlist_lexer.h and xxxxxx/kicad-source-mirror-master-20190222/common/netlist_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/common/netlist.keywords [ 72%] Built target netlist_lexer_source_files Scanning dependencies of target common [ 72%] Building CXX object common/CMakeFiles/common.dir/colors.cpp.o [ 72%] Building CXX object common/CMakeFiles/common.dir/dlist.cpp.o [ 72%] Building CXX object common/CMakeFiles/common.dir/string.cpp.o [ 72%] Building CXX object common/CMakeFiles/common.dir/dialog_about/AboutDialog_main.cpp.o [ 72%] Building CXX object common/CMakeFiles/common.dir/dialog_about/dialog_about.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialog_about/dialog_about_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_color_picker.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_color_picker_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_configure_paths.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_configure_paths_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_display_info_HTML_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_edit_library_tables.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_exit_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_file_dir_picker.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_global_lib_table_config.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_global_lib_table_config_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_hotkey_list.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_image_editor.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_image_editor_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_list_selector_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_page_settings_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_text_entry_base.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_print_generic.cpp.o [ 75%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_print_generic_base.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/dialogs/dialog_text_entry.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/dialogs/panel_common_settings.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/dialogs/panel_common_settings_base.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/dialogs/panel_hotkeys_editor.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/dialogs/wx_html_report_panel.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/dialogs/wx_html_report_panel_base.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/button_row_panel.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/color_swatch.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/footprint_choice.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/footprint_preview_widget.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/footprint_select_widget.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/gal_options_panel.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/grid_combobox.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/grid_icon_text_helpers.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/grid_text_button_helpers.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/indicator_icon.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/layer_box_selector.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/lib_tree.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/mathplot.cpp.o [ 77%] Building CXX object common/CMakeFiles/common.dir/widgets/paged_dialog.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/progress_reporter.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/stepped_slider.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/text_ctrl_eval.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/two_column_tree_list.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/ui_common.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/unit_binder.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/widget_save_restore.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/widget_hotkey_list.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/widgets/wx_grid.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/page_layout/title_block_shapes.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/page_layout/worksheet_dataitem.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/page_layout/worksheet_layout.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/page_layout/page_layout_default_description.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/page_layout/page_layout_graphic_items.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/page_layout/page_layout_reader_keywords.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/page_layout/page_layout_reader.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/preview_items/arc_assistant.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/preview_items/arc_geom_manager.cpp.o [ 80%] Building CXX object common/CMakeFiles/common.dir/preview_items/bright_box.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/preview_items/centreline_rect_item.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/preview_items/polygon_geom_manager.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/preview_items/polygon_item.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/preview_items/preview_utils.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/preview_items/ruler_item.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/preview_items/selection_area.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/preview_items/simple_overlay_item.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/plotters/plotter.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/plotters/DXF_plotter.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/plotters/GERBER_plotter.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/plotters/HPGL_plotter.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/plotters/PDF_plotter.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/plotters/PS_plotter.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/plotters/SVG_plotter.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/plotters/common_plot_functions.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/advanced_config.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/array_options.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/base_struct.cpp.o [ 82%] Building CXX object common/CMakeFiles/common.dir/bezier_curves.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/bin_mod.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/bitmap.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/bitmap_base.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/board_printout.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/build_version.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/colors_design_settings.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/commit.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/common.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/config_params.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/confirm.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/convert_basic_shapes_to_polygon.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/dialog_shim.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/displlst.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/draw_graphic_text.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/dsnlexer.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/eagle_parser.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/eda_base_frame.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/eda_dde.cpp.o [ 85%] Building CXX object common/CMakeFiles/common.dir/eda_doc.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/eda_dockart.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/eda_pattern_match.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/eda_size_ctrl.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/env_paths.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/env_vars.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/exceptions.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/executable_names.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/filename_resolver.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/filter_reader.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/footprint_filter.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/footprint_info.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/gbr_metadata.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/gestfich.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/getrunningmicrosecs.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/gr_basic.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/grid_tricks.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/hash_eda.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/hotkey_store.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/hotkeys_basic.cpp.o [ 87%] Building CXX object common/CMakeFiles/common.dir/html_messagebox.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/incremental_text_ctrl.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/kiface_i.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/kiway.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/kiway_express.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/kiway_holder.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/kiway_player.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/lib_id.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/lib_table_base.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/lib_table_keywords.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/lib_tree_model.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/lib_tree_model_adapter.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/lockfile.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/marker_base.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/md5_hash.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/msgpanel.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/netlist_keywords.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/observable.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/prependpath.cpp.o [ 90%] Building CXX object common/CMakeFiles/common.dir/printout.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/project.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/properties.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/ptree.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/refdes_utils.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/reporter.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/richio.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/search_stack.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/searchhelpfilefullpath.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/selcolor.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/settings.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/status_popup.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/systemdirsappend.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/trace_helpers.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/undo_redo_container.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/utf8.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/validators.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/wildcards_and_files_ext.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/worksheet.cpp.o [ 92%] Building CXX object common/CMakeFiles/common.dir/wxdataviewctrl_helpers.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/xnode.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/pgm_base.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/kicad_curl/kicad_curl.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/kicad_curl/kicad_curl_easy.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/system/libcontext.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/view/view.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/view/view_item.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/view/view_group.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/math/math_util.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/action_manager.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/actions.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/common_tools.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/conditional_menu.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/context_menu.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/grid_menu.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/selection_conditions.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/tool_action.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/tool_base.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/tool_dispatcher.cpp.o [ 95%] Building CXX object common/CMakeFiles/common.dir/tool/tool_event.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/tool/tool_interactive.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/tool/tool_manager.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/tool/tool_menu.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/tool/zoom_menu.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/tool/zoom_tool.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/convex_hull.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/geometry_utils.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/seg.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/shape.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/shape_collisions.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/shape_arc.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/shape_file_io.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/shape_line_chain.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/shape_poly_set.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/geometry/trigo.cpp.o [ 97%] Building CXX object common/CMakeFiles/common.dir/libeval/numeric_evaluator.cpp.o [ 97%] Linking CXX static library libcommon.a [ 97%] Built target common Scanning dependencies of target kicad [ 97%] Building CXX object kicad/CMakeFiles/kicad.dir/commandframe.cpp.o [ 97%] Building CXX object kicad/CMakeFiles/kicad.dir/dialogs/dialog_template_selector_base.cpp.o [ 97%] Building CXX object kicad/CMakeFiles/kicad.dir/dialogs/dialog_template_selector.cpp.o [ 97%] Building CXX object kicad/CMakeFiles/kicad.dir/files-io.cpp.o [ 97%] Building CXX object kicad/CMakeFiles/kicad.dir/import_project.cpp.o [ 97%] Building CXX object kicad/CMakeFiles/kicad.dir/kicad.cpp.o [100%] Building CXX object kicad/CMakeFiles/kicad.dir/mainframe.cpp.o [100%] Building CXX object kicad/CMakeFiles/kicad.dir/menubar.cpp.o [100%] Building CXX object kicad/CMakeFiles/kicad.dir/prjconfig.cpp.o [100%] Building CXX object kicad/CMakeFiles/kicad.dir/project_template.cpp.o [100%] Building CXX object kicad/CMakeFiles/kicad.dir/tree_project_frame.cpp.o [100%] Building CXX object kicad/CMakeFiles/kicad.dir/treeprojectfiles.cpp.o [100%] Building CXX object kicad/CMakeFiles/kicad.dir/treeproject_item.cpp.o make[3]: *** No rule to make target 'common/libgal.a', needed by 'kicad/kicad'. Schluss. [100%] Built target kicad >find . -name kicad ./kicad ../common/gal/hidpi_gl_canvas.cpp modified cpp File ( uncomment all RETINA_OPENGL_PATCH occurence ) disable #ifdef RETINA_OPENGL_PATCH switch /* #ifdef RETINA_OPENGL_PATCH SetViewWantsBestResolution( true ); #endif */ /* #ifdef RETINA_OPENGL_PATCH const float scaleFactor = GetBackingScaleFactor(); size.x *= scaleFactor; size.y *= scaleFactor; #endif */ //#ifdef RETINA_OPENGL_PATCH // this is ugly, but original method isn't marked const although it doesn't modify anything // => clean up when it officially has arrived in wxWidgets // return static_cast< wxGLCanvas* >( const_cast< HIDPI_GL_CANVAS* >( this ))->GetBackingScaleFactor(); //#else return 1.0f; //#endif >make -i kicad [ 0%] Built target polygon [ 67%] Built target bitmaps [ 67%] Generating version string header -- Using Git to determine build version string. -- Found Git: /usr/bin/git (found version "2.13.7") -- Not updating xxxxxx/kicad-source-mirror-master-20190222/build/kicad_build_version.h [ 67%] Built target version_header [ 67%] Built target page_layout_lexer_source_files [ 67%] Built target lib_table_lexer_source_files Scanning dependencies of target gal [ 67%] Building CXX object common/CMakeFiles/gal.dir/gal/hidpi_gl_canvas.cpp.o [ 67%] Linking CXX static library libgal.a [ 72%] Built target gal [ 72%] Built target netlist_lexer_source_files [ 97%] Built target common [ 97%] Linking CXX executable kicad [100%] Built target kicad >find . -name kicad ./kicad ./kicad/kicad >make -i -j8 all Scanning dependencies of target pcb_plot_lexer_source_files Scanning dependencies of target pcb_lexer_source_files [ 0%] Built target page_layout_lexer_source_files [ 0%] TokenList2DsnLexer.cmake creating: [ 0%] TokenList2DsnLexer.cmake creating: [ 0%] Generating version string header [ 0%] Built target netlist_lexer_source_files [ 0%] Built target lib_table_lexer_source_files xxxxxx/kicad-source-mirror-master-20190222/include/pcb_lexer.h and [ 0%] Built target polygon -- Using Git to determine build version string. xxxxxx/kicad-source-mirror-master-20190222/include/pcb_plot_params_lexer.h and Scanning dependencies of target kicad_3dsg Scanning dependencies of target field_template_lexer_source_files Scanning dependencies of target cmp_library_lexer_source_files xxxxxx/kicad-source-mirror-master-20190222/common/pcb_keywords.cpp from -- Found Git: /usr/bin/git (found version "2.13.7") -- Not updating xxxxxx/kicad-source-mirror-master-20190222/build/kicad_build_version.h Scanning dependencies of target dialog_bom_cfg_lexer_source_files xxxxxx/kicad-source-mirror-master-20190222/common/pcb_plot_params_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/common/pcb.keywords [ 0%] Built target version_header [ 0%] TokenList2DsnLexer.cmake creating: [ 0%] TokenList2DsnLexer.cmake creating: xxxxxx/kicad-source-mirror-master-20190222/common/pcb_plot_params.keywords [ 0%] TokenList2DsnLexer.cmake creating: xxxxxx/kicad-source-mirror-master-20190222/eeschema/template_fieldnames_lexer.h and xxxxxx/kicad-source-mirror-master-20190222/eeschema/cmp_library_lexer.h and Scanning dependencies of target lib_dxf xxxxxx/kicad-source-mirror-master-20190222/eeschema/dialogs/dialog_bom_cfg_lexer.h and xxxxxx/kicad-source-mirror-master-20190222/eeschema/template_fieldnames_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/eeschema/cmp_library_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/eeschema/dialogs/dialog_bom_cfg_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/eeschema/template_fieldnames.keywords xxxxxx/kicad-source-mirror-master-20190222/eeschema/cmp_library.keywords xxxxxx/kicad-source-mirror-master-20190222/eeschema/dialogs/dialog_bom_cfg.keywords [ 0%] Building CXX object dxflib_qcad/CMakeFiles/lib_dxf.dir/dl_dxf.cpp.o [ 0%] Built target pcb_plot_lexer_source_files [ 0%] Built target dialog_bom_cfg_lexer_source_files [ 0%] Building CXX object dxflib_qcad/CMakeFiles/lib_dxf.dir/dl_writer_ascii.cpp.o [ 0%] Built target field_template_lexer_source_files [ 1%] Building C object dxflib_qcad/CMakeFiles/lib_dxf.dir/tinyspline_lib/tinyspline.c.o [ 1%] Built target cmp_library_lexer_source_files Scanning dependencies of target specctra_lexer_source_files Scanning dependencies of target idf3 [ 1%] TokenList2DsnLexer.cmake creating: xxxxxx/kicad-source-mirror-master-20190222/pcbnew/specctra_import_export/specctra_lexer.h and xxxxxx/kicad-source-mirror-master-20190222/pcbnew/specctra_import_export/specctra_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/pcbnew/specctra_import_export/specctra.keywords [ 28%] Built target bitmaps [ 28%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_base.cpp.o Scanning dependencies of target potrace [ 28%] Built target pcb_lexer_source_files [ 28%] Building CXX object dxflib_qcad/CMakeFiles/lib_dxf.dir/tinyspline_lib/tinysplinecpp.cpp.o [ 28%] Building CXX object potrace/CMakeFiles/potrace.dir/bitmap_io.cpp.o [ 28%] Building CXX object utils/idftools/CMakeFiles/idf3.dir/idf_helpers.cpp.o Scanning dependencies of target pcb_calculator_lexer_source_files [ 28%] TokenList2DsnLexer.cmake creating: [ 28%] Built target specctra_lexer_source_files xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/pcb_calculator_datafile_lexer.h and [ 28%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_node.cpp.o xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/pcb_calculator_datafile_keywords.cpp from xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/pcb_calculator_datafile.keywords [ 28%] Building CXX object potrace/CMakeFiles/potrace.dir/curve.cpp.o [ 28%] Built target pcb_calculator_lexer_source_files Scanning dependencies of target idfcyl [ 28%] Building CXX object utils/idftools/CMakeFiles/idfcyl.dir/idf_cylinder.cpp.o [ 28%] Building CXX object potrace/CMakeFiles/potrace.dir/decompose.cpp.o [ 28%] Building CXX object potrace/CMakeFiles/potrace.dir/greymap.cpp.o Scanning dependencies of target idfrect [ 28%] Building CXX object utils/idftools/CMakeFiles/idfrect.dir/idf_rect.cpp.o Scanning dependencies of target kicad2step [ 28%] Building CXX object potrace/CMakeFiles/potrace.dir/potracelib.cpp.o [ 29%] Building CXX object potrace/CMakeFiles/potrace.dir/render.cpp.o [ 29%] Building CXX object potrace/CMakeFiles/potrace.dir/trace.cpp.o [ 29%] Linking CXX executable idfcyl [ 29%] Built target idfcyl [ 29%] Building CXX object utils/idftools/CMakeFiles/idf3.dir/idf_common.cpp.o [ 29%] Linking CXX executable idfrect [ 29%] Linking CXX static library libpotrace.a [ 29%] Built target potrace Scanning dependencies of target unit_test_utils [ 29%] Built target idfrect [ 29%] Building CXX object qa/unit_test_utils/CMakeFiles/unit_test_utils.dir/unit_test_utils.cpp.o [ 29%] Building CXX object utils/idftools/CMakeFiles/idf3.dir/idf_outlines.cpp.o [ 29%] Linking CXX static library libunit_test_utils.a [ 29%] Built target unit_test_utils Scanning dependencies of target legacy_gal [ 29%] Building CXX object common/CMakeFiles/legacy_gal.dir/legacy_gal/block.cpp.o Scanning dependencies of target legacy_wx [ 29%] Building CXX object common/CMakeFiles/legacy_wx.dir/legacy_wx/block.cpp.o [ 29%] Linking CXX static library liblib_dxf.a [ 29%] Built target lib_dxf [ 29%] Building CXX object common/CMakeFiles/legacy_wx.dir/legacy_wx/eda_draw_frame.cpp.o [ 29%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/kicad2step.cpp.o [ 29%] Building CXX object common/CMakeFiles/legacy_wx.dir/legacy_wx/eda_draw_panel.cpp.o [ 29%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_helpers.cpp.o [ 29%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/scenegraph.cpp.o [ 29%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/pcb/3d_resolver.cpp.o [ 29%] Building CXX object common/CMakeFiles/legacy_gal.dir/legacy_gal/eda_draw_frame.cpp.o [ 29%] Building CXX object utils/idftools/CMakeFiles/idf3.dir/idf_parser.cpp.o [ 29%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/pcb/base.cpp.o [ 29%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/pcb/kicadmodel.cpp.o [ 29%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_appearance.cpp.o [ 29%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_faceset.cpp.o [ 29%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_shape.cpp.o [ 29%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_colors.cpp.o [ 29%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/pcb/kicadmodule.cpp.o [ 29%] Building CXX object common/CMakeFiles/legacy_wx.dir/legacy_wx/other.cpp.o [ 31%] Built target gal [ 31%] Building CXX object common/CMakeFiles/legacy_gal.dir/legacy_gal/other.cpp.o [ 31%] Building CXX object utils/idftools/CMakeFiles/idf3.dir/vrml_layer.cpp.o [ 31%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_coords.cpp.o [ 31%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/pcb/kicadpad.cpp.o [ 42%] Built target common [ 42%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/pcb/kicadpcb.cpp.o Scanning dependencies of target pcbcommon Scanning dependencies of target connectivity [ 42%] Building CXX object pcbnew/connectivity/CMakeFiles/connectivity.dir/connectivity_algo.cpp.o [ 42%] Building CXX object pcbnew/connectivity/CMakeFiles/connectivity.dir/connectivity_data.cpp.o [ 42%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_normals.cpp.o [ 42%] Building CXX object common/CMakeFiles/pcbcommon.dir/base_screen.cpp.o [ 42%] Linking CXX static library liblegacy_wx.a [ 42%] Built target legacy_wx [ 42%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_index.cpp.o [ 42%] Linking CXX static library libidf3.a [ 42%] Linking CXX static library liblegacy_gal.a [ 42%] Built target idf3 [ 42%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/sg_coordindex.cpp.o [ 42%] Built target legacy_gal [ 42%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_node.cpp.o [ 42%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/pcb/kicadcurve.cpp.o [ 42%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/pcb/oce_utils.cpp.o [ 42%] Building CXX object common/CMakeFiles/pcbcommon.dir/eda_text.cpp.o [ 42%] Building CXX object common/CMakeFiles/pcbcommon.dir/fp_lib_table.cpp.o Scanning dependencies of target bitmap2component [ 42%] Building CXX object bitmap2component/CMakeFiles/bitmap2component.dir/__/common/single_top.cpp.o [ 42%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_transform.cpp.o [ 42%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/sexpr/sexpr.cpp.o [ 42%] Building CXX object common/CMakeFiles/pcbcommon.dir/lset.cpp.o [ 42%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_appearance.cpp.o [ 43%] Building CXX object utils/kicad2step/CMakeFiles/kicad2step.dir/sexpr/sexpr_parser.cpp.o [ 43%] Building CXX object bitmap2component/CMakeFiles/bitmap2component.dir/bitmap2component.cpp.o [ 43%] creating xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/attenuators/splitter_formula.h from xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/attenuators/splitter_formula.html [ 43%] creating xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/attenuators/pi_formula.h from xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/attenuators/pi_formula.html [ 43%] creating xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/attenuators/tee_formula.h from xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/attenuators/tee_formula.html [ 43%] creating xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/attenuators/bridget_tee_formula.h from xxxxxx/kicad-source-mirror-master-20190222/pcb_calculator/attenuators/bridget_tee_formula.html Scanning dependencies of target pcb_calculator_kiface [ 43%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/pcb_calculator.cpp.o [ 43%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/attenuators.cpp.o [ 43%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_index.cpp.o [ 43%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/board_classes_values.cpp.o [ 43%] Linking CXX executable kicad2step [ 44%] Building CXX object pcbnew/connectivity/CMakeFiles/connectivity.dir/connectivity_items.cpp.o [ 44%] Building CXX object bitmap2component/CMakeFiles/bitmap2component.dir/bitmap2cmp_gui_base.cpp.o [ 44%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_coordindex.cpp.o [ 44%] Built target kicad2step [ 45%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_colors.cpp.o [ 45%] Building CXX object common/CMakeFiles/pcbcommon.dir/page_info.cpp.o [ 45%] Building CXX object bitmap2component/CMakeFiles/bitmap2component.dir/bitmap2cmp_gui.cpp.o [ 45%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_coords.cpp.o [ 45%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/colorcode.cpp.o [ 45%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/electrical_spacing_values.cpp.o [ 46%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/params_read_write.cpp.o [ 46%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/pcb_calculator_frame.cpp.o [ 46%] Building CXX object common/CMakeFiles/pcbcommon.dir/pcb_keywords.cpp.o [ 46%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_faceset.cpp.o [ 47%] Linking CXX executable bitmap2component [ 47%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_normals.cpp.o [ 47%] Linking CXX static library libconnectivity.a [ 47%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_shape.cpp.o [ 47%] Built target connectivity [ 47%] Building CXX object 3d-viewer/3d_cache/sg/CMakeFiles/kicad_3dsg.dir/ifsg_api.cpp.o [ 47%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/datafile_read_write.cpp.o [ 48%] Built target kicad [ 48%] Building CXX object common/CMakeFiles/pcbcommon.dir/pcb_plot_params_keywords.cpp.o Scanning dependencies of target dxf2idf [ 48%] Building CXX object utils/idftools/CMakeFiles/dxf2idf.dir/dxf2idfmain.cpp.o Scanning dependencies of target idf2vrml [ 48%] Building CXX object utils/idftools/CMakeFiles/idf2vrml.dir/idf2vrml.cpp.o [ 48%] Built target bitmap2component [ 48%] Building CXX object utils/idftools/CMakeFiles/dxf2idf.dir/dxf2idf.cpp.o [ 48%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_base_frame.cpp.o [ 48%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/board_commit.cpp.o Scanning dependencies of target kicad-ogltest [ 48%] Building CXX object utils/kicad-ogltest/CMakeFiles/kicad-ogltest.dir/kicad-ogltest.cpp.o [ 48%] Linking CXX executable dxf2idf [ 48%] Built target dxf2idf [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/regulators_funct.cpp.o [ 48%] Linking CXX shared library libkicad_3dsg.so [ 48%] Built target kicad_3dsg [ 48%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/board_connected_item.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/tracks_width_versus_current.cpp.o Scanning dependencies of target qa_utils [ 48%] Building CXX object qa/qa_utils/CMakeFiles/qa_utils.dir/stdstream_line_reader.cpp.o [ 48%] Linking CXX executable idf2vrml [ 48%] Linking CXX executable kicad-ogltest [ 48%] Built target idf2vrml [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline_ident.cpp.o [ 48%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/board_design_settings.cpp.o [ 48%] Building CXX object qa/qa_utils/CMakeFiles/qa_utils.dir/utility_program.cpp.o [ 48%] creating xxxxxx/kicad-source-mirror-master-20190222/eeschema/dialogs/dialog_bom_help_html.h from xxxxxx/kicad-source-mirror-master-20190222/eeschema/dialogs/dialog_bom_help.html Scanning dependencies of target eeschema_kiface [ 48%] Building CXX object qa/qa_utils/CMakeFiles/qa_utils.dir/geometry/line_chain_construction.cpp.o [ 48%] Built target kicad-ogltest [ 48%] Building CXX object qa/qa_utils/CMakeFiles/qa_utils.dir/geometry/poly_set_construction.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/UnitSelector.cpp.o [ 48%] Building CXX object qa/qa_utils/CMakeFiles/qa_utils.dir/geometry/seg_construction.cpp.o Scanning dependencies of target gerbview_kiface Scanning dependencies of target pl_editor_kiface Scanning dependencies of target s3d_plugin_idf [ 48%] Building CXX object plugins/3d/idf/CMakeFiles/s3d_plugin_idf.dir/s3d_plugin_idf.cpp.o [ 48%] Linking CXX static library libqa_utils.a [ 48%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/pl_editor.cpp.o [ 48%] Built target qa_utils [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/pcb_calculator_datafile_keywords.cpp.o [ 48%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/board_items_to_polygon_shape_transform.cpp.o Scanning dependencies of target s3d_plugin_vrml [ 48%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerbview.cpp.o [ 48%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/__/__/__/common/richio.cpp.o [ 48%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/__/__/__/common/exceptions.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline/transline.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline/c_microstrip.cpp.o [ 48%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_annotate.cpp.o [ 48%] Building CXX object plugins/3d/idf/CMakeFiles/s3d_plugin_idf.dir/__/__/__/utils/idftools/vrml_layer.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline/microstrip.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline/coplanar.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline/coax.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline/rectwaveguide.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline/stripline.cpp.o [ 48%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/vrml.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline/twistedpair.cpp.o [ 48%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/transline_dlg_funct.cpp.o [ 48%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/dialogs/properties_frame_base.cpp.o [ 48%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/dialogs/dialogs_for_printing.cpp.o [ 48%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/block.cpp.o [ 49%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_board.cpp.o [ 49%] Linking CXX shared module libs3d_plugin_idf.so [ 49%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/am_param.cpp.o [ 49%] Built target s3d_plugin_idf [ 49%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/am_primitive.cpp.o [ 49%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/x3d.cpp.o [ 49%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/attenuators/attenuator_classes.cpp.o [ 49%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_annotate_base.cpp.o [ 49%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/dialogs/pcb_calculator_frame_base.cpp.o [ 49%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/wrlproc.cpp.o [ 49%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/dialogs/dialog_new_dataitem_base.cpp.o [ 49%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_bom.cpp.o [ 49%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_bom_base.cpp.o [ 49%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/DCodeSelectionbox.cpp.o [ 50%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gbr_screen.cpp.o [ 50%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/wrlfacet.cpp.o [ 50%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/dialogs/dialog_new_dataitem.cpp.o [ 51%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator_kiface.dir/dialogs/dialog_regulator_data_base.cpp.o [ 51%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gbr_layout.cpp.o [ 51%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_bom_cfg_keywords.cpp.o [ 52%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_node.cpp.o [ 52%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_board_item.cpp.o [ 52%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_dimension.cpp.o Scanning dependencies of target s3d_plugin_oce [ 52%] Building CXX object plugins/3d/oce/CMakeFiles/s3d_plugin_oce.dir/oce.cpp.o [ 52%] Linking CXX shared module _pcb_calculator.kiface [ 52%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_fields_editor_global.cpp.o [ 52%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/pl_editor_screen.cpp.o [ 52%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_base.cpp.o [ 52%] Building CXX object plugins/3d/oce/CMakeFiles/s3d_plugin_oce.dir/loadmodel.cpp.o [ 52%] Built target pcb_calculator_kiface [ 52%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_transform.cpp.o [ 52%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerber_file_image.cpp.o [ 52%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerber_file_image_list.cpp.o [ 52%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_drawsegment.cpp.o [ 52%] Linking CXX shared module libs3d_plugin_oce.so [ 52%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/pl_editor_layout.cpp.o [ 52%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_fields_editor_global_base.cpp.o [ 52%] Built target s3d_plugin_oce [ 53%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_choose_component.cpp.o [ 53%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_shape.cpp.o [ 53%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/design_tree_frame.cpp.o Scanning dependencies of target qa_pcbnew_utils [ 53%] Building CXX object qa/pcbnew_utils/CMakeFiles/qa_pcbnew_utils.dir/board_construction_utils.cpp.o [ 53%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/events_functions.cpp.o [ 53%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerber_draw_item.cpp.o [ 53%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_appearance.cpp.o [ 53%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_material.cpp.o [ 53%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_edge_mod.cpp.o [ 53%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_component_in_lib.cpp.o [ 53%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_marker_pcb.cpp.o [ 54%] Building CXX object qa/pcbnew_utils/CMakeFiles/qa_pcbnew_utils.dir/board_file_utils.cpp.o Scanning dependencies of target qa_common_gerbview [ 54%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_faceset.cpp.o [ 54%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/common_mocks.cpp.o [ 54%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/controle.cpp.o [ 54%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerbview_layer_widget.cpp.o [ 54%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_module.cpp.o [ 54%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerbview_printout.cpp.o [ 54%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_lineset.cpp.o [ 54%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_module.cpp.o [ 54%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/__/__/common/eda_text.cpp.o [ 54%] Linking CXX static library libqa_pcbnew_utils.a [ 54%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_component_in_lib_base.cpp.o [ 54%] Built target qa_pcbnew_utils [ 54%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_component_in_schematic.cpp.o [ 54%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/files.cpp.o [ 54%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_pointset.cpp.o [ 54%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/onleftclick.cpp.o [ 55%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/__/__/common/base_units.cpp.o [ 55%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gbr_layer_box_selector.cpp.o [ 55%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/X2_gerber_attributes.cpp.o [ 55%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/clear_gbr_drawlayers.cpp.o [ 55%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_coords.cpp.o [ 55%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/netclass.cpp.o [ 55%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/__/__/common/colors.cpp.o [ 55%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/controle.cpp.o [ 55%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_component_in_schematic_base.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/onrightclick.cpp.o [ 56%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/netinfo_item.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_norms.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/__/__/common/observable.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_array_options.cpp.o [ 56%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_components_libid.cpp.o [ 56%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_components_libid_base.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_color.cpp.o [ 56%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/dcode.cpp.o [ 56%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/draw_gerber_screen.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/page_layout_writer.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_color4d.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_box.cpp.o [ 56%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/netinfo_list.cpp.o [ 56%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_pad.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/pl_editor_config.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/pl_editor_frame.cpp.o [ 56%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_label.cpp.o [ 56%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/evaluate.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_switch.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_coroutine.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_format_units.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_hotkey_store.cpp.o [ 56%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/events_called_functions.cpp.o [ 56%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_pcb_target.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/pl_editor_undo_redo.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v2/vrml2_inline.cpp.o [ 56%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_label_base.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_node.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_base.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_lib_table.cpp.o [ 56%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/excellon_read_drill_file.cpp.o [ 56%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_line_style.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/properties_frame.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/hotkeys.cpp.o [ 56%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_pcb_text.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/menubar.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_group.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_kicad_string.cpp.o [ 56%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/export_to_pcbnew.cpp.o [ 56%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_line_style_base.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_refdes_utils.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_title_block.cpp.o [ 56%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_separator.cpp.o [ 56%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/toolbars_pl_editor.cpp.o [ 56%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_text_mod.cpp.o [ 56%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_track.cpp.o [ 56%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_edit_one_field.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_utf8.cpp.o [ 56%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/test_wildcards_and_files_ext.cpp.o [ 57%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_material.cpp.o [ 57%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/files.cpp.o [ 57%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_matbinding.cpp.o [ 57%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/block.cpp.o [ 57%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_erc.cpp.o [ 57%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/libeval/test_numeric_evaluator.cpp.o [ 57%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/class_zone.cpp.o [ 57%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerbview_config.cpp.o Scanning dependencies of target qa_common_eeschema [ 57%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_coords.cpp.o [ 57%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/common_mocks.cpp.o [ 57%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/__/common/base_screen.cpp.o [ 57%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_module.cpp.o [ 57%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/__/common/base_units.cpp.o [ 57%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_switch.cpp.o [ 57%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/__/__/common/eda_text.cpp.o [ 57%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/geometry/test_fillet.cpp.o [ 58%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerbview_frame.cpp.o [ 58%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_erc_base.cpp.o [ 58%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/collectors.cpp.o [ 58%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/geometry/test_segment.cpp.o [ 58%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/__/common/eda_text.cpp.o [ 58%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/__/common/dialogs/dialog_page_settings.cpp.o [ 58%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_faceset.cpp.o [ 58%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/__/__/common/base_units.cpp.o [ 58%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/geometry/test_shape_arc.cpp.o [ 58%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_global_sym_lib_table_config.cpp.o [ 58%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_edit_draw_item.cpp.o [ 58%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/__/__/common/colors.cpp.o [ 58%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_transform.cpp.o [ 58%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/connectivity/connectivity_algo.cpp.o [ 58%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor_kiface.dir/__/common/page_info.cpp.o [ 58%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/hotkeys.cpp.o [ 58%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/geometry/test_shape_poly_set_collision.cpp.o [ 58%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/__/__/common/observable.cpp.o [ 58%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_array_options.cpp.o [ 58%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/v1/vrml1_shapehints.cpp.o [ 58%] Linking CXX shared module _pl_editor.kiface [ 58%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/x3d/x3d_appearance.cpp.o [ 58%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_edit_draw_item_base.cpp.o [ 58%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/geometry/test_shape_poly_set_distance.cpp.o [ 58%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/json11.cpp.o [ 58%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/job_file_reader.cpp.o [ 58%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/x3d/x3d_base.cpp.o [ 59%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/geometry/test_shape_poly_set_iterator.cpp.o [ 59%] Building CXX object qa/common/CMakeFiles/qa_common_gerbview.dir/view/test_zoom_controller.cpp.o [ 59%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_edit_pin.cpp.o [ 59%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_color4d.cpp.o [ 59%] Built target pl_editor_kiface [ 59%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_edit_pin_base.cpp.o [ 59%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/connectivity/connectivity_items.cpp.o [ 59%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/x3d/x3d_coords.cpp.o [ 59%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/x3d/x3d_ifaceset.cpp.o [ 59%] Linking CXX executable qa_common_gerbview [ 59%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_coroutine.cpp.o [ 59%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/locate.cpp.o [ 59%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/x3d/x3d_ops.cpp.o [ 59%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/menubar.cpp.o [ 59%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/x3d/x3d_shape.cpp.o [ 60%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_edit_pin_table.cpp.o [ 60%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/onleftclick.cpp.o [ 60%] Built target qa_common_gerbview [ 60%] Building CXX object plugins/3d/vrml/CMakeFiles/s3d_plugin_vrml.dir/x3d/x3d_transform.cpp.o [ 60%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_format_units.cpp.o [ 60%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/onrightclick.cpp.o [ 61%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/connectivity/connectivity_data.cpp.o [ 61%] Linking CXX shared module libs3d_plugin_vrml.so [ 61%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/convert_drawsegment_list_to_polygon.cpp.o [ 61%] Built target s3d_plugin_vrml [ 61%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/drc_item.cpp.o [ 61%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/eagle_plugin.cpp.o [ 61%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_edit_pin_table_base.cpp.o [ 61%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_edit_text.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_hotkey_store.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/readgerb.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/rs274_read_XY_and_IJ_coordinates.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/rs274d.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/rs274x.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_edit_text_base.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_lib_table.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/select_layers_to_pcb.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/gpcb_plugin.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/io_mgr.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_kicad_string.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_refdes_utils.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_title_block.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_new_component.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/toolbars_gerber.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/kicad_clipboard.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/kicad_netlist_reader.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/kicad_plugin.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_utf8.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerbview_draw_panel_gal.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_lib_new_component_base.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_netlist.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/test_wildcards_and_files_ext.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/libeval/test_numeric_evaluator.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/geometry/test_fillet.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_netlist_base.cpp.o Scanning dependencies of target qa_common_pcbnew [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerbview_painter.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/common_mocks.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_module.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/legacy_netlist_reader.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/legacy_plugin.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/netlist_reader.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/geometry/test_segment.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/__/__/common/eda_text.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_plot_schematic.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/__/__/common/base_units.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/tools/gerbview_actions.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/geometry/test_shape_arc.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/geometry/test_shape_poly_set_collision.cpp.o Scanning dependencies of target qa_common_tools [ 62%] Building CXX object qa/common_tools/CMakeFiles/qa_common_tools.dir/__/__/common/colors.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/__/__/common/colors.cpp.o [ 62%] Building CXX object qa/common_tools/CMakeFiles/qa_common_tools.dir/__/__/common/observable.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pad_custom_shape_functions.cpp.o [ 62%] Building CXX object qa/common_tools/CMakeFiles/qa_common_tools.dir/main.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_plot_schematic_base.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_print_using_printer.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/geometry/test_shape_poly_set_distance.cpp.o [ 62%] Building CXX object qa/common_tools/CMakeFiles/qa_common_tools.dir/tools/coroutines/coroutines.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/__/__/common/observable.cpp.o [ 62%] Building CXX object qa/common_tools/CMakeFiles/qa_common_tools.dir/tools/io_benchmark/io_benchmark.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_array_options.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/tools/selection_tool.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/geometry/test_shape_poly_set_iterator.cpp.o [ 62%] Building CXX object qa/common/CMakeFiles/qa_common_eeschema.dir/view/test_zoom_controller.cpp.o [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/tools/gerbview_control.cpp.o [ 62%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pad_draw_functions.cpp.o [ 62%] Linking CXX executable qa_common_tools [ 62%] Built target qa_common_tools [ 62%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/gerber_collectors.cpp.o [ 62%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_print_using_printer_base.cpp.o [ 63%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/dialogs/panel_gerbview_display_options.cpp.o [ 63%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_color4d.cpp.o [ 63%] Linking CXX executable qa_common_eeschema [ 63%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_rescue_each.cpp.o Scanning dependencies of target pl_editor [ 63%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor.dir/__/common/single_top.cpp.o Scanning dependencies of target pcb_calculator [ 63%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator.dir/__/common/single_top.cpp.o [ 63%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_display_options.cpp.o [ 63%] Built target qa_common_eeschema [ 63%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_draw_panel_gal.cpp.o [ 63%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_rescue_each_base.cpp.o [ 63%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_coroutine.cpp.o [ 63%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/dialogs/panel_gerbview_display_options_base.cpp.o [ 63%] Building CXX object pagelayout_editor/CMakeFiles/pl_editor.dir/__/common/pgm_base.cpp.o [ 63%] Building CXX object pcb_calculator/CMakeFiles/pcb_calculator.dir/__/common/pgm_base.cpp.o [ 63%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/dialogs/panel_gerbview_settings.cpp.o [ 63%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/dialogs/panel_gerbview_settings_base.cpp.o [ 63%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_sch_edit_sheet_pin.cpp.o [ 63%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/dialogs/dialog_layers_select_to_pcb_base.cpp.o [ 63%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_format_units.cpp.o [ 63%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_hotkey_store.cpp.o [ 63%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_sch_edit_sheet_pin_base.cpp.o [ 63%] Linking CXX executable pl_editor [ 63%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_general_settings.cpp.o [ 63%] Linking CXX executable pcb_calculator [ 63%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/dialogs/dialog_print_gerbview.cpp.o [ 63%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_lib_table.cpp.o [ 63%] Built target pl_editor [ 63%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_sch_sheet_props.cpp.o [ 63%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_sch_sheet_props_base.cpp.o [ 63%] Built target pcb_calculator [ 63%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_schematic_find.cpp.o [ 63%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/dialogs/dialog_select_one_pcb_layer.cpp.o [ 63%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/__/common/base_screen.cpp.o [ 63%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_netlist.cpp.o [ 64%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_schematic_find_base.cpp.o [ 64%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_kicad_string.cpp.o [ 64%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/__/common/base_units.cpp.o [ 64%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_set_grid.cpp.o [ 64%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/__/common/eda_text.cpp.o [ 64%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_refdes_utils.cpp.o [ 64%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_title_block.cpp.o [ 64%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/__/common/widgets/layer_box_selector.cpp.o [ 64%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/__/common/lset.cpp.o [ 64%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_painter.cpp.o [ 64%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_set_grid_base.cpp.o [ 64%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_symbol_remap.cpp.o [ 64%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_utf8.cpp.o [ 64%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_parser.cpp.o [ 65%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/test_wildcards_and_files_ext.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_plot_params.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_screen.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/pcb_view.cpp.o [ 67%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/__/common/settings.cpp.o [ 67%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/libeval/test_numeric_evaluator.cpp.o [ 67%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/geometry/test_fillet.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_symbol_remap_base.cpp.o [ 67%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/geometry/test_segment.cpp.o [ 67%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/geometry/test_shape_arc.cpp.o [ 67%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/__/pcbnew/layer_widget.cpp.o [ 67%] Building CXX object gerbview/CMakeFiles/gerbview_kiface.dir/__/common/page_info.cpp.o [ 67%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/geometry/test_shape_poly_set_collision.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/plugin.cpp.o [ 67%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/geometry/test_shape_poly_set_distance.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_update_fields.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/ratsnest_data.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/ratsnest_viewitem.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/sel_layer.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/__/pcbnew/zone_settings.cpp.o [ 67%] Linking CXX shared module _gerbview.kiface [ 67%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/geometry/test_shape_poly_set_iterator.cpp.o [ 67%] Building CXX object common/CMakeFiles/pcbcommon.dir/widgets/net_selector.cpp.o [ 67%] Building CXX object qa/common/CMakeFiles/qa_common_pcbnew.dir/view/test_zoom_controller.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_update_fields_base.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_eeschema_template_fieldnames.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_eeschema_template_fieldnames_base.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_eeschema_display_options.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_eeschema_display_options_base.cpp.o [ 67%] Linking CXX executable qa_common_pcbnew [ 67%] Linking CXX static library libpcbcommon.a [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_eeschema_settings.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_eeschema_settings_base.cpp.o [ 67%] Built target gerbview_kiface [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_libedit_display_options.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_libedit_settings.cpp.o [ 67%] Built target qa_common_pcbnew Scanning dependencies of target gerbview [ 67%] Built target pcbcommon [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_libedit_settings_base.cpp.o [ 67%] Building CXX object gerbview/CMakeFiles/gerbview.dir/__/common/single_top.cpp.o [ 67%] Building CXX object gerbview/CMakeFiles/gerbview.dir/__/common/pgm_base.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_sym_lib_table.cpp.o [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/panel_sym_lib_table_base.cpp.o Scanning dependencies of target 3d-viewer Scanning dependencies of target pcad2kicadpcb [ 67%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/widgets/pin_shape_combobox.cpp.o [ 68%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/widgets/pin_type_combobox.cpp.o [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcad2kicad_common.cpp.o [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/__/plugins/ldr/pluginldr.cpp.o [ 68%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/widgets/symbol_preview_widget.cpp.o [ 68%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/widgets/symbol_tree_pane.cpp.o [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/__/plugins/ldr/3d/pluginldr3D.cpp.o [ 68%] Linking CXX executable gerbview [ 68%] Built target gerbview [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_cache/3d_cache_wrapper.cpp.o [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcad_plugin.cpp.o [ 68%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/widgets/widget_eeschema_color_config.cpp.o [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_cache/3d_cache.cpp.o [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb.cpp.o [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_arc.cpp.o [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_component.cpp.o [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_copper_pour.cpp.o [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_cutout.cpp.o [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_cache/3d_plugin_manager.cpp.o [ 68%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/block_libedit.cpp.o [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_cache/dialogs/3d_cache_dialogs.cpp.o [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_cache/dialogs/dlg_select_3dmodel.cpp.o [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_cache/dialogs/panel_prev_3d_base.cpp.o Scanning dependencies of target github_plugin [ 68%] Building CXX object pcbnew/github/CMakeFiles/github_plugin.dir/github_plugin.cpp.o [ 68%] Building CXX object pcbnew/github/CMakeFiles/github_plugin.dir/github_getliblist.cpp.o [ 68%] Building CXX object pcbnew/github/CMakeFiles/github_plugin.dir/html_link_parser.cpp.o [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_keepout.cpp.o [ 68%] Generating pcbnew_wrap.cxx, pcbnew.py [ 68%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/controller.cpp.o xxxxxx/kicad-source-mirror-master-20190222/pcbnew/../include/common.h:383: Warning 317: Specialization of non-template 'less'. [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_cache/dialogs/panel_prev_model.cpp.o xxxxxx/kicad-source-mirror-master-20190222/pcbnew/../include/eda_text.h:45: Warning 401: Nothing known about base class 'std::mutex'. Ignored. [ 68%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_line.cpp.o class_board.h:51: Warning 315: Nothing known about 'std::unique_ptr'. [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_canvas/cinfo3d_visu.cpp.o [ 68%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_canvas/create_layer_items.cpp.o [ 68%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/libedit.cpp.o [ 69%] Linking CXX static library libgithub_plugin.a [ 69%] Built target github_plugin [ 69%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_module.cpp.o [ 69%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_canvas/create_3Dgraphic_brd_items.cpp.o [ 69%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/libedit_onleftclick.cpp.o [ 69%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/libedit_onrightclick.cpp.o [ 69%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/libedit_plot_component.cpp.o [ 69%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/libedit_undo_redo.cpp.o [ 69%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_net.cpp.o [ 69%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_pad.cpp.o [ 69%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_pad_shape.cpp.o [ 69%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_canvas/create_layer_poly.cpp.o [ 69%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_canvas/eda_3d_canvas.cpp.o [ 70%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_plane.cpp.o [ 70%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/lib_edit_frame.cpp.o [ 70%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_polygon.cpp.o [ 70%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_canvas/eda_3d_canvas_pivot.cpp.o [ 70%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_model_viewer/c3d_model_viewer.cpp.o [ 70%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_ogl_legacy/c_ogl_3dmodel.cpp.o [ 70%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_text.cpp.o [ 70%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_via.cpp.o [ 70%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_ogl_legacy/ogl_legacy_utils.cpp.o [ 70%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/libfield.cpp.o [ 70%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_ogl_legacy/c3d_render_createscene_ogl_legacy.cpp.o [ 71%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_ogl_legacy/c3d_render_ogl_legacy.cpp.o [ 71%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/menubar_libedit.cpp.o [ 71%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_ogl_legacy/clayer_triangles.cpp.o [ 71%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/pcb_via_shape.cpp.o [ 71%] Building CXX object pcbnew/pcad2kicadpcb_plugin/CMakeFiles/pcad2kicadpcb.dir/s_expr_loader.cpp.o [ 71%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/pinedit.cpp.o [ 71%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/accelerators/caccelerator.cpp.o [ 71%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/accelerators/cbvh_packet_traversal.cpp.o [ 71%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/accelerators/cbvh_pbrt.cpp.o [ 71%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/symbdraw.cpp.o [ 71%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/symbedit.cpp.o [ 71%] Linking CXX static library libpcad2kicadpcb.a [ 71%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/tool_lib.cpp.o [ 71%] Built target pcad2kicadpcb [ 71%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/lib_export.cpp.o [ 71%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libedit/lib_manager.cpp.o [ 72%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/bom_plugins.cpp.o [ 72%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/accelerators/ccontainer.cpp.o Scanning dependencies of target pnsrouter [ 72%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/accelerators/ccontainer2d.cpp.o swig_import_helper fixed for xxxxxx/kicad-source-mirror-master-20190222/build/pcbnew/pcbnew.py Scanning dependencies of target pcbnew_kiface_objects [ 72%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_view.cpp.o [ 72%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/time_limit.cpp.o [ 72%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/PerlinNoise.cpp.o [ 72%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_kicad_iface.cpp.o [ 72%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/c3d_render_createscene.cpp.o [ 72%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/c3d_render_raytracing.cpp.o [ 72%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_painter.cpp.o [ 72%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_algo_base.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_diff_pair.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_diff_pair_placer.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_dp_meander_placer.cpp.o [ 73%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/annotate.cpp.o [ 73%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/autoplace_fields.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/cfrustum.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/cmaterial.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/mortoncodes.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_dragger.cpp.o [ 73%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/backanno.cpp.o [ 73%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/block.cpp.o [ 73%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/bus-wire-junction.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/ray.cpp.o [ 73%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcbnew.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/raypacket.cpp.o [ 73%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/microwave/microwave_inductor.cpp.o [ 73%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_block_options.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_item.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/cbbox2d.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/cfilledcircle2d.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/citemlayercsg2d.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_itemset.cpp.o [ 73%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/busentry.cpp.o [ 73%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/cobject2d.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_line.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_line_placer.cpp.o [ 73%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_block_options_base.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_logger.cpp.o [ 73%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_meander.cpp.o [ 73%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/class_libentry.cpp.o [ 74%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/cpolygon2d.cpp.o [ 75%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_board_setup.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/class_library.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/cmp_library_keywords.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/cmp_library_lexer.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/component_references_lister.cpp.o [ 75%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_meander_placer.cpp.o [ 75%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/cpolygon4pts2d.cpp.o [ 75%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/cring2d.cpp.o [ 75%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_meander_placer_base.cpp.o [ 75%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_choose_footprint.cpp.o [ 75%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/croundsegment2d.cpp.o [ 75%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_meander_skew_placer.cpp.o [ 75%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_node.cpp.o [ 75%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_optimizer.cpp.o [ 75%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes2D/ctriangle2d.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/controle.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/cross-probing.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/drc_erc_item.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/edit_bitmap.cpp.o [ 75%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_cleaning_options.cpp.o [ 75%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_cleaning_options_base.cpp.o [ 75%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/cbbox.cpp.o [ 75%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/cbbox_ray.cpp.o [ 75%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/ccylinder.cpp.o [ 75%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_router.cpp.o [ 75%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_copper_zones.cpp.o [ 75%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_copper_zones_base.cpp.o [ 75%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_create_array.cpp.o [ 75%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/edit_component_in_schematic.cpp.o [ 76%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/edit_label.cpp.o [ 76%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/eeredraw.cpp.o [ 76%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/cdummyblock.cpp.o [ 76%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/eeschema.cpp.o [ 76%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_routing_settings.cpp.o [ 76%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/clayeritem.cpp.o [ 76%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_create_array_base.cpp.o [ 76%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_shove.cpp.o [ 76%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_sizes_settings.cpp.o [ 76%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_solid.cpp.o [ 77%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_tool_base.cpp.o [ 77%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/eeschema_config.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/cobject.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/cplane.cpp.o [ 77%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_drc.cpp.o [ 77%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/erc.cpp.o [ 77%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/events_called_functions_for_edit.cpp.o [ 77%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/fields_grid_table.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/croundseg.cpp.o [ 77%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_drc_base.cpp.o [ 77%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_edit_footprint_for_BoardEditor.cpp.o [ 77%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_topology.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/3d_render_raytracing/shapes3D/ctriangle.cpp.o [ 77%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_tune_status_popup.cpp.o [ 77%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_utils.cpp.o [ 77%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_via.cpp.o [ 77%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/files-io.cpp.o [ 77%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/find.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/buffers_debug.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/c3d_render_base.cpp.o [ 77%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/generate_alias_info.cpp.o [ 77%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/pns_walkaround.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/ccamera.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/ccolorrgb.cpp.o [ 77%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/getpart.cpp.o [ 77%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_edit_footprint_for_BoardEditor_base.cpp.o [ 77%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/router_preview_item.cpp.o [ 77%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/router_tool.cpp.o [ 77%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/cimage.cpp.o [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/cpostshader.cpp.o [ 78%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/hierarch.cpp.o [ 78%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/highlight_connection.cpp.o [ 78%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/hotkeys.cpp.o [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/cpostshader_ssao.cpp.o [ 78%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_edit_footprint_for_fp_editor.cpp.o [ 78%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_arc.cpp.o [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/ctrack_ball.cpp.o [ 78%] Building CXX object pcbnew/router/CMakeFiles/pnsrouter.dir/length_tuner_tool.cpp.o [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_viewer/3d_menubar.cpp.o [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_viewer/hotkeys.cpp.o [ 78%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_edit_footprint_for_fp_editor_base.cpp.o [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/test_cases.cpp.o [ 78%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_bezier.cpp.o [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_rendering/trackball.cpp.o [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_viewer/3d_toolbar.cpp.o [ 78%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_circle.cpp.o [ 78%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_collectors.cpp.o [ 78%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_draw_item.cpp.o [ 78%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_enum_pads.cpp.o [ 78%] Linking CXX static library libpnsrouter.a [ 78%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_enum_pads_base.cpp.o [ 78%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_exchange_footprints.cpp.o [ 78%] Built target pnsrouter [ 78%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_viewer/dialogs/dialog_3D_view_option.cpp.o [ 79%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_field.cpp.o [ 79%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_viewer/dialogs/dialog_3D_view_option_base.cpp.o [ 79%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_viewer/eda_3d_viewer.cpp.o [ 79%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_pin.cpp.o [ 79%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_exchange_footprints_base.cpp.o [ 79%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_polyline.cpp.o [ 79%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_rectangle.cpp.o [ 79%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_export_idf.cpp.o [ 79%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/lib_text.cpp.o [ 79%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/common_ogl/cogl_att_list.cpp.o [ 79%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/common_ogl/ogl_utils.cpp.o [ 79%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/libarch.cpp.o [ 79%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_fastmath.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_export_idf_base.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_export_step.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_export_step_base.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_export_svg.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_export_svg_base.cpp.o [ 80%] Building CXX object 3d-viewer/CMakeFiles/3d-viewer.dir/3d_math.cpp.o [ 80%] Linking CXX static library lib3d-viewer.a [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/menubar.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_export_vrml.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_generator.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_export_vrml_base.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_object_list.cpp.o [ 80%] Built target 3d-viewer [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_find.cpp.o Scanning dependencies of target cvpcb_kiface Scanning dependencies of target test_gal_pixel_alignment [ 80%] Building CXX object qa/gal/gal_pixel_alignment/CMakeFiles/test_gal_pixel_alignment.dir/test_gal_pixel_alignment.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/cvpcb.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/common/base_units.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_find_base.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_object.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_footprint_wizard_list.cpp.o [ 80%] Building CXX object qa/gal/gal_pixel_alignment/CMakeFiles/test_gal_pixel_alignment.dir/__/__/qa_utils/pcb_test_frame.cpp.o [ 80%] Building CXX object qa/gal/gal_pixel_alignment/CMakeFiles/test_gal_pixel_alignment.dir/__/__/qa_utils/mocks.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_footprint_wizard_list_base.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/pcbnew/board_items_to_polygon_shape_transform.cpp.o [ 80%] Building CXX object qa/gal/gal_pixel_alignment/CMakeFiles/test_gal_pixel_alignment.dir/__/__/__/common/base_units.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/pcbnew/pcb_general_settings.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/onleftclick.cpp.o [ 80%] Building CXX object qa/gal/gal_pixel_alignment/CMakeFiles/test_gal_pixel_alignment.dir/__/__/__/pcbnew/tools/pcb_tool.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/pcbnew/drc_item.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_fp_browser_display_options.cpp.o [ 80%] Building CXX object qa/gal/gal_pixel_alignment/CMakeFiles/test_gal_pixel_alignment.dir/__/__/__/pcbnew/tools/selection.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/pcbnew/tools/grid_helper.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_fp_browser_display_options_base.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_fp_plugin_options.cpp.o [ 80%] Building CXX object qa/gal/gal_pixel_alignment/CMakeFiles/test_gal_pixel_alignment.dir/__/__/__/pcbnew/tools/selection_tool.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/onrightclick.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/operations_on_items_lists.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/pin_number.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/auto_associate.cpp.o [ 80%] Building CXX object qa/gal/gal_pixel_alignment/CMakeFiles/test_gal_pixel_alignment.dir/__/__/__/pcbnew/tools/tool_event_utils.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/pin_shape.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/pin_type.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_fp_plugin_options_base.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/cfg.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_gen_footprint_position_file_base.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_gencad_export_options.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/plot_schematic_DXF.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/plot_schematic_HPGL.cpp.o [ 80%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/components_listbox.cpp.o [ 80%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/plot_schematic_PDF.cpp.o [ 80%] Linking CXX executable test_gal_pixel_alignment [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_gendrill.cpp.o [ 80%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_gendrill_base.cpp.o [ 81%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_get_footprint_by_name_base.cpp.o [ 81%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_global_deletion.cpp.o [ 81%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/plot_schematic_PS.cpp.o [ 81%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/display_footprints_frame.cpp.o [ 82%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/plot_schematic_SVG.cpp.o [ 82%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/footprints_listbox.cpp.o [ 82%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/library_listbox.cpp.o [ 82%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/cvpcb_mainframe.cpp.o [ 82%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_global_deletion_base.cpp.o [ 82%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_draw_panel.cpp.o [ 82%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/project_rescue.cpp.o [ 82%] Built target test_gal_pixel_alignment [ 82%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_base_frame.cpp.o [ 82%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_bitmap.cpp.o [ 82%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_global_edit_tracks_and_vias.cpp.o [ 82%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/listbox_base.cpp.o [ 82%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_bus_entry.cpp.o [ 82%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/menubar.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/readwrite_dlgs.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_collectors.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_global_edit_tracks_and_vias_base.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_component.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/toolbars_cvpcb.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_global_edit_text_and_graphics.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_eagle_plugin.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_global_edit_text_and_graphics_base.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_global_fp_lib_table_config.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_push_pad_properties.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_push_pad_properties_base.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/tools/cvpcb_actions.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/tools/cvpcb_control.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/tools/cvpcb_selection_tool.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/dialogs/fp_conflict_assignment_selector_base.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/dialogs/fp_conflict_assignment_selector.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/dialogs/dialog_display_options.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_graphic_item_properties.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_field.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_graphic_item_properties_base.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_import_settings.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_import_settings_base.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_io_mgr.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_keepout_area_properties.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/dialogs/dialog_display_options_base.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/dialogs/dialog_config_equfiles_base.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/dialogs/dialog_config_equfiles.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/pcbnew/dialogs/dialog_fp_plugin_options.cpp.o [ 83%] Building CXX object cvpcb/CMakeFiles/cvpcb_kiface.dir/__/pcbnew/dialogs/dialog_fp_plugin_options_base.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_keepout_area_properties_base.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_layer_selection_base.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_item_struct.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_junction.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_legacy_plugin.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_line.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_move_exact.cpp.o [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_move_exact_base.cpp.o [ 83%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_marker.cpp.o [ 83%] Linking CXX shared module _cvpcb.kiface [ 83%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_netlist.cpp.o [ 84%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_netlist_base.cpp.o [ 84%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_non_copper_zones_properties.cpp.o [ 84%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_non_copper_zones_properties_base.cpp.o [ 84%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pad_basicshapes_properties.cpp.o [ 84%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pad_properties.cpp.o [ 84%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_no_connect.cpp.o [ 84%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_plugin.cpp.o [ 84%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_preview_panel.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_screen.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pad_properties_base.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_plot.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_plot_base.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_sheet.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_sheet_path.cpp.o [ 85%] Built target cvpcb_kiface [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_sheet_pin.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_text.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_validators.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/schedit.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pns_diff_pair_dimensions.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/schematic_undo_redo.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pns_diff_pair_dimensions_base.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pns_length_tuning_settings.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pns_length_tuning_settings_base.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pns_settings.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sch_edit_frame.cpp.o [ 85%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/selpart.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_pns_settings_base.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_position_relative.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_position_relative_base.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_print_pcbnew.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_select_net_from_list.cpp.o [ 85%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_select_net_from_list_base.cpp.o [ 86%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_set_grid.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sheet.cpp.o [ 86%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_set_grid_base.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sheetlab.cpp.o [ 86%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_swap_layers.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/symbol_lib_table.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/symbol_tree_model_adapter.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/symbol_tree_synchronizing_adapter.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/template_fieldnames.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/template_fieldnames_keywords.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/tool_sch.cpp.o [ 86%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_swap_layers_base.cpp.o [ 86%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_target_properties_base.cpp.o [ 86%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_text_properties.cpp.o [ 86%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_text_properties_base.cpp.o [ 86%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_track_via_properties.cpp.o [ 86%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/tool_viewlib.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/transform.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/viewlib_frame.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/viewlibs.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_exporters/netlist_exporter.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_track_via_properties_base.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_track_via_size.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_exporters/netlist_exporter_cadstar.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_track_via_size_base.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_exporters/netlist_exporter_generic.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_exporters/netlist_exporter_kicad.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_update_pcb.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_update_pcb_base.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_exporters/netlist_exporter_orcadpcb2.cpp.o [ 87%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/netlist_exporters/netlist_exporter_pspice.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_fp_lib_table.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_fp_lib_table_base.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_modedit_defaults.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_modedit_defaults_base.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_modedit_display_options.cpp.o [ 87%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_modedit_settings.cpp.o [ 88%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_modedit_settings_base.cpp.o [ 88%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_pcbnew_display_options.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sim/netlist_exporter_pspice_sim.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sim/ngspice.cpp.o [ 88%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_pcbnew_display_options_base.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sim/sim_plot_frame.cpp.o [ 88%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_pcbnew_settings.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sim/sim_plot_frame_base.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sim/sim_plot_panel.cpp.o [ 88%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_pcbnew_settings_base.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sim/simulate.cpp.o [ 88%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_mask_and_paste.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sim/spice_simulator.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/sim/spice_value.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_signal_list.cpp.o [ 88%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_signal_list_base.cpp.o [ 88%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_mask_and_paste_base.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_sim_settings.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_sim_settings_base.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_feature_constraints.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_spice_model.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/dialogs/dialog_spice_model_base.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_feature_constraints_base.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/widgets/tuner_slider.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_layers.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/widgets/tuner_slider_base.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_layers_base.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_netclasses.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/__/common/dialogs/dialog_page_settings.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/__/common/base_screen.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/__/common/base_units.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_netclasses_base.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/__/common/eda_text.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_text_and_graphics.cpp.o [ 89%] Building CXX object eeschema/CMakeFiles/eeschema_kiface.dir/__/common/page_info.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_text_and_graphics_base.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_tracks_and_vias.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_setup_tracks_and_vias_base.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_wizard.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_wizard_frame.cpp.o [ 89%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_wizard_frame_functions.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/wizard_3DShape_Libs_downloader_base.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/wizard_3DShape_Libs_downloader.cpp.o [ 90%] Linking CXX shared library _eeschema.kiface [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_pcbnew_action_plugins.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/panel_pcbnew_action_plugins_base.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/export_d356.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/export_footprint_associations.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/export_gencad.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/export_idf.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/export_vrml.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/gen_drill_report_files.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/gen_footprints_placefile.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/gendrill_Excellon_writer.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/gendrill_file_writer_base.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/gendrill_gerber_writer.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/exporters/gerber_jobfile_writer.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/dialog_import_gfx_base.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/dialog_import_gfx.cpp.o [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/graphics_import_mgr.cpp.o [ 90%] Built target eeschema_kiface [ 90%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/graphics_importer.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/graphics_importer_pcbnew.cpp.o Scanning dependencies of target eeschema [ 91%] Building CXX object eeschema/CMakeFiles/eeschema.dir/__/common/single_top.cpp.o [ 91%] Building CXX object eeschema/CMakeFiles/eeschema.dir/__/common/pgm_base.cpp.o Scanning dependencies of target qa_eagle_plugin [ 91%] Building CXX object qa/eeschema/CMakeFiles/qa_eagle_plugin.dir/test_module.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/graphics_importer_buffer.cpp.o [ 91%] Building CXX object qa/eeschema/CMakeFiles/qa_eagle_plugin.dir/test_basic.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/dxf_import_plugin.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/svg_import_plugin.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/import_gfx/nanosvg.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/drc/courtyard_overlap.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/drc/drc_marker_factory.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/drc/drc_provider.cpp.o [ 91%] Linking CXX executable eeschema [ 91%] Linking CXX executable qa_eagle_plugin [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/autorouter/rect_placement/rect_placement.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/autorouter/spread_footprints.cpp.o [ 91%] Built target qa_eagle_plugin [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/autorouter/ar_autoplacer.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/autorouter/ar_matrix.cpp.o [ 91%] Built target eeschema [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/autorouter/autoplacer_tool.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/action_plugin.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/append_board_to_current.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/array_creator.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/array_pad_name_provider.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/attribut.cpp.o [ 91%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/block.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/block_footprint_editor.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/board_netlist_updater.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/build_BOM_from_board.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/connect.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/controle.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/cross-probing.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/deltrack.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dimension.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dragsegm.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/drc.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/drc_clearance_test_functions.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/edgemod.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/edit.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/edit_pcb_text.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/edit_track_width.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/editedge.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/editrack-part2.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/editrack.cpp.o [ 92%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/edtxtmod.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/event_handlers_tracks_vias_sizes.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/files.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_info_impl.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_editor_utils.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_editor_onclick.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_editor_options.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/fp_tree_synchronizing_adapter.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_edit_frame.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_libraries_utils.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_viewer_frame.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/fp_tree_model_adapter.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/generate_footprint_info.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/grid_layer_box_helpers.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/highlight.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/hotkeys.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/hotkeys_board_editor.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/hotkeys_footprint_editor.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/initpcb.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/layer_widget.cpp.o [ 93%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/load_select_footprint.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/magnetic_tracks_functions.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/menubar_footprint_editor.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/menubar_pcb_editor.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/microwave.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/minimun_spanning_tree.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/move-drag_pads.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/move_or_drag_track.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/muwave_command.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/netlist.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/onleftclick.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/onrightclick.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pad_edit_functions.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pad_naming.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcb_base_edit_frame.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcb_footprint_edit_utils.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcb_layer_box_selector.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcb_layer_widget.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcb_edit_frame.cpp.o [ 94%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcbnew_config.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcbnew_printout.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcb_legacy_draw_utils.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcbplot.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/plot_board_layers.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/plot_brditems_plotter.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/ratsnest.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/specctra_import_export/specctra.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/specctra_import_export/specctra_export.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/specctra_import_export/specctra_import.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/specctra_import_export/specctra_keywords.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/target_edit.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/text_mod_grid_table.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tool_footprint_editor.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tool_footprint_viewer.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tool_onrightclick.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tool_pcb_editor.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/toolbars_update_user_interface.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tracks_cleaner.cpp.o [ 95%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/undo_redo.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/zone_filler.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/zones_by_polygon.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/zones_by_polygon_fill_functions.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/zones_functions_for_undo_redo.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/zones_test_and_combine_areas.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/drawing_tool.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/edit_constraints.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/edit_points.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/edit_tool.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/grid_helper.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/microwave_tool.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/footprint_editor_tools.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/pad_tool.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/pcb_actions.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/pcb_bright_box.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/pcb_editor_control.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/pcb_selection_conditions.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/pcb_tool.cpp.o [ 96%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/pcbnew_control.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/picker_tool.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/placement_tool.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/point_editor.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/position_relative_tool.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/selection.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/selection_tool.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/tool_event_utils.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/tools_common.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/zone_create_helper.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/tools/zone_filler_tool.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_preview_panel.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/footprint_tree_pane.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/__/common/dialogs/dialog_page_settings.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/__/common/base_units.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_scripting.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/dialogs/dialog_scripting_base.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/pcbnew_wrap.cxx.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/__/common/swig/wx_python_helpers.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/swig/pcbnew_action_plugins.cpp.o [ 97%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/swig/pcbnew_footprint_wizards.cpp.o [ 98%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/swig/pcbnew_scripting_helpers.cpp.o [ 98%] Building CXX object pcbnew/CMakeFiles/pcbnew_kiface_objects.dir/swig/python_scripting.cpp.o [ 98%] Built target pcbnew_kiface_objects Scanning dependencies of target pcbnew_python Scanning dependencies of target pcbnew_kiface Scanning dependencies of target qa_pcbnew Scanning dependencies of target qa_pcbnew_tools [ 98%] Linking CXX shared module _pcbnew.so [ 98%] Linking CXX shared module _pcbnew.kiface [ 98%] Building CXX object qa/pcbnew_tools/CMakeFiles/qa_pcbnew_tools.dir/pcbnew_tools.cpp.o [ 98%] Building CXX object qa/pcbnew_tools/CMakeFiles/qa_pcbnew_tools.dir/tools/drc_tool/drc_tool.cpp.o [ 98%] Building CXX object qa/pcbnew_tools/CMakeFiles/qa_pcbnew_tools.dir/tools/polygon_generator/polygon_generator.cpp.o [ 98%] Building CXX object qa/pcbnew_tools/CMakeFiles/qa_pcbnew_tools.dir/tools/pcb_parser/pcb_parser_tool.cpp.o [ 98%] Building CXX object qa/pcbnew_tools/CMakeFiles/qa_pcbnew_tools.dir/tools/polygon_triangulation/polygon_triangulation.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/__/__/common/eda_text.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/__/__/common/colors.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/__/__/common/observable.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/test_module.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/board_test_utils.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/drc/drc_test_utils.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/test_array_pad_name_provider.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/test_graphics_import_mgr.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/test_pad_naming.cpp.o [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/drc/test_drc_courtyard_invalid.cpp.o [100%] Linking CXX executable qa_pcbnew_tools [100%] Building CXX object qa/pcbnew/CMakeFiles/qa_pcbnew.dir/drc/test_drc_courtyard_overlap.cpp.o [100%] Linking CXX executable qa_pcbnew [100%] Built target pcbnew_python [100%] Built target pcbnew_kiface Scanning dependencies of target pcbnew_python_module Scanning dependencies of target pcbnew [100%] Creating python's pcbnew native module _pcbnew.so for command line use. [100%] Building CXX object pcbnew/CMakeFiles/pcbnew.dir/__/common/single_top.cpp.o [100%] Built target pcbnew_python_module [100%] Linking CXX executable pcbnew [100%] Built target pcbnew [100%] Built target qa_pcbnew_tools [100%] Built target qa_pcbnew >make -i install [ 27%] Built target bitmaps [ 27%] Built target pcb_plot_lexer_source_files [ 27%] Built target polygon [ 27%] Built target legacy_gal [ 27%] Built target legacy_wx [ 27%] Generating version string header -- Using Git to determine build version string. -- Found Git: /usr/bin/git (found version "2.13.7") -- Not updating xxxxxx/kicad-source-mirror-master-20190222/build/kicad_build_version.h [ 27%] Built target version_header [ 27%] Built target page_layout_lexer_source_files [ 27%] Built target lib_table_lexer_source_files [ 29%] Built target gal [ 29%] Built target netlist_lexer_source_files [ 40%] Built target common [ 40%] Built target pcb_lexer_source_files [ 43%] Built target pcbcommon [ 44%] Built target kicad_3dsg [ 47%] Built target 3d-viewer [ 48%] Built target pcad2kicadpcb [ 49%] Built target github_plugin [ 50%] Built target cvpcb_kiface [ 50%] Built target field_template_lexer_source_files [ 50%] Built target cmp_library_lexer_source_files [ 50%] Built target dialog_bom_cfg_lexer_source_files [ 61%] Built target eeschema_kiface [ 61%] Built target eeschema [ 64%] Built target gerbview_kiface [ 64%] Built target gerbview [ 65%] Built target lib_dxf [ 65%] Built target specctra_lexer_source_files [ 81%] Built target pcbnew_kiface_objects [ 81%] Built target idf3 [ 82%] Built target connectivity [ 84%] Built target pnsrouter [ 84%] Built target pcbnew_kiface [ 84%] Built target pcbnew [ 84%] Built target pcbnew_python [ 84%] Built target pcbnew_python_module [ 85%] Built target pl_editor_kiface [ 85%] Built target pl_editor [ 86%] Built target potrace [ 87%] Built target bitmap2component [ 87%] Built target pcb_calculator_lexer_source_files [ 89%] Built target pcb_calculator_kiface [ 89%] Built target pcb_calculator [ 89%] Built target s3d_plugin_idf [ 91%] Built target s3d_plugin_vrml [ 91%] Built target s3d_plugin_oce [ 92%] Built target kicad [ 92%] Built target idfcyl [ 92%] Built target idfrect [ 92%] Built target dxf2idf [ 92%] Built target idf2vrml [ 92%] Built target kicad-ogltest [ 93%] Built target kicad2step [ 93%] Built target qa_utils [ 94%] Built target qa_pcbnew_utils [ 94%] Built target unit_test_utils [ 96%] Built target qa_common_gerbview [ 97%] Built target qa_common_eeschema [ 98%] Built target qa_common_pcbnew [100%] Built target qa_pcbnew [100%] Built target qa_eagle_plugin [100%] Built target qa_common_tools [100%] Built target qa_pcbnew_tools [100%] Built target test_gal_pixel_alignment Install the project... -- Install configuration: "Debug" -- Up-to-date: /usr/local/share/doc/kicad/scripts -- Installing: /usr/local/share/doc/kicad/scripts/test_kicad_plugin.py -- Installing: /usr/local/share/doc/kicad/scripts/ddr3_length_match.py -- Installing: /usr/local/share/doc/kicad/scripts/test_plugin.py -- Installing: /usr/local/share/doc/kicad/scripts/lib_convert.py -- Up-to-date: /usr/local/share/icons -- Up-to-date: /usr/local/share/icons/hicolor -- Up-to-date: /usr/local/share/icons/hicolor/scalable -- Up-to-date: /usr/local/share/icons/hicolor/scalable/mimetypes -- Installing: /usr/local/share/icons/hicolor/scalable/mimetypes/application-x-kicad-pcb.svg -- Installing: /usr/local/share/icons/hicolor/scalable/mimetypes/application-x-kicad-project.svg -- Installing: /usr/local/share/icons/hicolor/scalable/mimetypes/application-x-kicad-schematic.svg -- Up-to-date: /usr/local/share/icons/hicolor/scalable/apps -- Installing: /usr/local/share/icons/hicolor/scalable/apps/pcbnew.svg -- Installing: /usr/local/share/icons/hicolor/scalable/apps/pcbcalculator.svg -- Installing: /usr/local/share/icons/hicolor/scalable/apps/bitmap2component.svg -- Installing: /usr/local/share/icons/hicolor/scalable/apps/gerbview.svg -- Installing: /usr/local/share/icons/hicolor/scalable/apps/kicad.svg -- Installing: /usr/local/share/icons/hicolor/scalable/apps/eeschema.svg -- Up-to-date: /usr/local/share/icons/hicolor/16x16 -- Up-to-date: /usr/local/share/icons/hicolor/16x16/mimetypes -- Installing: /usr/local/share/icons/hicolor/16x16/mimetypes/application-x-kicad-schematic.png -- Installing: /usr/local/share/icons/hicolor/16x16/mimetypes/application-x-kicad-pcb.png -- Installing: /usr/local/share/icons/hicolor/16x16/mimetypes/application-x-kicad-project.png -- Up-to-date: /usr/local/share/icons/hicolor/16x16/apps -- Installing: /usr/local/share/icons/hicolor/16x16/apps/pcbcalculator.png -- Installing: /usr/local/share/icons/hicolor/16x16/apps/pcbnew.png -- Installing: /usr/local/share/icons/hicolor/16x16/apps/kicad.png -- Installing: /usr/local/share/icons/hicolor/16x16/apps/bitmap2component.png -- Installing: /usr/local/share/icons/hicolor/16x16/apps/eeschema.png -- Installing: /usr/local/share/icons/hicolor/16x16/apps/gerbview.png -- Up-to-date: /usr/local/share/icons/hicolor/128x128 -- Up-to-date: /usr/local/share/icons/hicolor/128x128/mimetypes -- Installing: /usr/local/share/icons/hicolor/128x128/mimetypes/application-x-kicad-schematic.png -- Installing: /usr/local/share/icons/hicolor/128x128/mimetypes/application-x-kicad-pcb.png -- Installing: /usr/local/share/icons/hicolor/128x128/mimetypes/application-x-kicad-project.png -- Up-to-date: /usr/local/share/icons/hicolor/128x128/apps -- Installing: /usr/local/share/icons/hicolor/128x128/apps/pcbcalculator.png -- Installing: /usr/local/share/icons/hicolor/128x128/apps/pcbnew.png -- Installing: /usr/local/share/icons/hicolor/128x128/apps/kicad.png -- Installing: /usr/local/share/icons/hicolor/128x128/apps/bitmap2component.png -- Installing: /usr/local/share/icons/hicolor/128x128/apps/eeschema.png -- Installing: /usr/local/share/icons/hicolor/128x128/apps/gerbview.png -- Up-to-date: /usr/local/share/icons/hicolor/64x64 -- Up-to-date: /usr/local/share/icons/hicolor/64x64/mimetypes -- Installing: /usr/local/share/icons/hicolor/64x64/mimetypes/application-x-kicad-schematic.png -- Installing: /usr/local/share/icons/hicolor/64x64/mimetypes/application-x-kicad-pcb.png -- Installing: /usr/local/share/icons/hicolor/64x64/mimetypes/application-x-kicad-project.png -- Up-to-date: /usr/local/share/icons/hicolor/64x64/apps -- Installing: /usr/local/share/icons/hicolor/64x64/apps/pcbcalculator.png -- Installing: /usr/local/share/icons/hicolor/64x64/apps/pcbnew.png -- Installing: /usr/local/share/icons/hicolor/64x64/apps/kicad.png -- Installing: /usr/local/share/icons/hicolor/64x64/apps/bitmap2component.png -- Installing: /usr/local/share/icons/hicolor/64x64/apps/eeschema.png -- Installing: /usr/local/share/icons/hicolor/64x64/apps/gerbview.png -- Up-to-date: /usr/local/share/icons/hicolor/48x48 -- Up-to-date: /usr/local/share/icons/hicolor/48x48/mimetypes -- Installing: /usr/local/share/icons/hicolor/48x48/mimetypes/application-x-kicad-schematic.png -- Installing: /usr/local/share/icons/hicolor/48x48/mimetypes/application-x-kicad-pcb.png -- Installing: /usr/local/share/icons/hicolor/48x48/mimetypes/application-x-kicad-project.png -- Up-to-date: /usr/local/share/icons/hicolor/48x48/apps -- Installing: /usr/local/share/icons/hicolor/48x48/apps/pcbcalculator.png -- Installing: /usr/local/share/icons/hicolor/48x48/apps/pcbnew.png -- Installing: /usr/local/share/icons/hicolor/48x48/apps/kicad.png -- Installing: /usr/local/share/icons/hicolor/48x48/apps/bitmap2component.png -- Installing: /usr/local/share/icons/hicolor/48x48/apps/eeschema.png -- Installing: /usr/local/share/icons/hicolor/48x48/apps/gerbview.png -- Up-to-date: /usr/local/share/icons/hicolor/24x24 -- Up-to-date: /usr/local/share/icons/hicolor/24x24/mimetypes -- Installing: /usr/local/share/icons/hicolor/24x24/mimetypes/application-x-kicad-schematic.png -- Installing: /usr/local/share/icons/hicolor/24x24/mimetypes/application-x-kicad-pcb.png -- Installing: /usr/local/share/icons/hicolor/24x24/mimetypes/application-x-kicad-project.png -- Up-to-date: /usr/local/share/icons/hicolor/24x24/apps -- Installing: /usr/local/share/icons/hicolor/24x24/apps/pcbcalculator.png -- Installing: /usr/local/share/icons/hicolor/24x24/apps/pcbnew.png -- Installing: /usr/local/share/icons/hicolor/24x24/apps/kicad.png -- Installing: /usr/local/share/icons/hicolor/24x24/apps/bitmap2component.png -- Installing: /usr/local/share/icons/hicolor/24x24/apps/eeschema.png -- Installing: /usr/local/share/icons/hicolor/24x24/apps/gerbview.png -- Up-to-date: /usr/local/share/icons/hicolor/22x22 -- Up-to-date: /usr/local/share/icons/hicolor/22x22/mimetypes -- Installing: /usr/local/share/icons/hicolor/22x22/mimetypes/application-x-kicad-schematic.png -- Installing: /usr/local/share/icons/hicolor/22x22/mimetypes/application-x-kicad-pcb.png -- Installing: /usr/local/share/icons/hicolor/22x22/mimetypes/application-x-kicad-project.png -- Up-to-date: /usr/local/share/icons/hicolor/22x22/apps -- Installing: /usr/local/share/icons/hicolor/22x22/apps/pcbcalculator.png -- Installing: /usr/local/share/icons/hicolor/22x22/apps/pcbnew.png -- Installing: /usr/local/share/icons/hicolor/22x22/apps/kicad.png -- Installing: /usr/local/share/icons/hicolor/22x22/apps/bitmap2component.png -- Installing: /usr/local/share/icons/hicolor/22x22/apps/eeschema.png -- Installing: /usr/local/share/icons/hicolor/22x22/apps/gerbview.png -- Up-to-date: /usr/local/share/icons/hicolor/32x32 -- Up-to-date: /usr/local/share/icons/hicolor/32x32/mimetypes -- Installing: /usr/local/share/icons/hicolor/32x32/mimetypes/application-x-kicad-schematic.png -- Installing: /usr/local/share/icons/hicolor/32x32/mimetypes/application-x-kicad-pcb.png -- Installing: /usr/local/share/icons/hicolor/32x32/mimetypes/application-x-kicad-project.png -- Up-to-date: /usr/local/share/icons/hicolor/32x32/apps -- Installing: /usr/local/share/icons/hicolor/32x32/apps/pcbcalculator.png -- Installing: /usr/local/share/icons/hicolor/32x32/apps/pcbnew.png -- Installing: /usr/local/share/icons/hicolor/32x32/apps/kicad.png -- Installing: /usr/local/share/icons/hicolor/32x32/apps/bitmap2component.png -- Installing: /usr/local/share/icons/hicolor/32x32/apps/eeschema.png -- Installing: /usr/local/share/icons/hicolor/32x32/apps/gerbview.png -- Up-to-date: /usr/local/share/mime -- Up-to-date: /usr/local/share/mime/packages -- Installing: /usr/local/share/mime/packages/kicad-kicad.xml -- Installing: /usr/local/share/mime/packages/kicad-gerbers.xml -- Up-to-date: /usr/local/share/applications -- Installing: /usr/local/share/applications/pcbnew.desktop -- Installing: /usr/local/share/applications/eeschema.desktop -- Installing: /usr/local/share/applications/gerbview.desktop -- Installing: /usr/local/share/applications/kicad.desktop -- Installing: /usr/local/share/applications/pcbcalculator.desktop -- Installing: /usr/local/share/applications/bitmap2component.desktop -- Up-to-date: /usr/local/share/appdata -- Installing: /usr/local/share/appdata/kicad.appdata.xml -- Installing: /usr/local/lib64/libkicad_3dsg.so.2.0.0 -- Up-to-date: /usr/local/lib64/libkicad_3dsg.so -- Set runtime path of "/usr/local/lib64/libkicad_3dsg.so.2.0.0" to "" -- Installing: /usr/local/bin/_cvpcb.kiface -- Set runtime path of "/usr/local/bin/_cvpcb.kiface" to "" -- Installing: /usr/local/bin/eeschema -- Set runtime path of "/usr/local/bin/eeschema" to "" -- Installing: /usr/local/bin/_eeschema.kiface -- Set runtime path of "/usr/local/bin/_eeschema.kiface" to "" -- Installing: /usr/local/share/kicad/plugins/bom2csv.xsl -- Installing: /usr/local/share/kicad/plugins/bom2grouped_csv.xsl -- Installing: /usr/local/share/kicad/plugins/netlist_form_cadstar-RINF.xsl -- Installing: /usr/local/share/kicad/plugins/netlist_form_cadstar.xsl -- Installing: /usr/local/share/kicad/plugins/netlist_form_OrcadPcb2.xsl -- Installing: /usr/local/share/kicad/plugins/netlist_form_pads-pcb.asc.xsl -- Installing: /usr/local/share/kicad/plugins/bom_with_title_block_2_csv.xsl -- Installing: /usr/local/share/kicad/plugins/README-bom.txt -- Installing: /usr/local/share/kicad/plugins/kicad_netlist_reader.py -- Installing: /usr/local/share/kicad/plugins/bom_csv_grouped_by_value.py -- Installing: /usr/local/share/kicad/plugins/bom_csv_grouped_by_value_with_fp.py -- Installing: /usr/local/share/kicad/plugins/bom_csv_sorted_by_ref.py -- Installing: /usr/local/share/kicad/plugins/bom_html_grouped_by_value.py -- Installing: /usr/local/share/kicad/plugins/bom_html_with_advanced_grouping.py -- Installing: /usr/local/share/kicad/plugins/bom_sorted_by_ref.py -- Installing: /usr/local/bin/gerbview -- Set runtime path of "/usr/local/bin/gerbview" to "" -- Installing: /usr/local/bin/_gerbview.kiface -- Set runtime path of "/usr/local/bin/_gerbview.kiface" to "" -- Installing: /usr/local/bin/pcbnew -- Set runtime path of "/usr/local/bin/pcbnew" to "" -- Installing: /usr/local/bin/_pcbnew.kiface -- Set runtime path of "/usr/local/bin/_pcbnew.kiface" to "" -- Installing: /usr/local/lib/python2.7/site-packages/pcbnew.py -- Up-to-date: /usr/local/share/kicad/scripting/plugins -- Installing: /usr/local/share/kicad/scripting/plugins/FPC_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/bga_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/circular_pad_array_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/qfp_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/touch_slider_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/FootprintWizardBase.py -- Installing: /usr/local/share/kicad/scripting/plugins/qrcode_footprint_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/microMatch_connectors.py -- Installing: /usr/local/share/kicad/scripting/plugins/qfn_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/PadArray.py -- Installing: /usr/local/share/kicad/scripting/plugins/sdip_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/uss39_barcode.py -- Installing: /usr/local/share/kicad/scripting/plugins/zip_wizard.py -- Installing: /usr/local/share/kicad/scripting/plugins/__init__.py -- Installing: /usr/local/share/kicad/scripting/plugins/kicad_qrcode.py -- Installing: /usr/local/lib/python2.7/site-packages/_pcbnew.so -- Set runtime path of "/usr/local/lib/python2.7/site-packages/_pcbnew.so" to "" -- Installing: /usr/local/bin/pl_editor -- Set runtime path of "/usr/local/bin/pl_editor" to "" -- Installing: /usr/local/bin/_pl_editor.kiface -- Set runtime path of "/usr/local/bin/_pl_editor.kiface" to "" -- Installing: /usr/local/bin/bitmap2component -- Set runtime path of "/usr/local/bin/bitmap2component" to "" -- Installing: /usr/local/bin/pcb_calculator -- Set runtime path of "/usr/local/bin/pcb_calculator" to "" -- Installing: /usr/local/bin/_pcb_calculator.kiface -- Set runtime path of "/usr/local/bin/_pcb_calculator.kiface" to "" -- Installing: /usr/local/lib64/kicad/plugins/3d/libs3d_plugin_idf.so -- Set runtime path of "/usr/local/lib64/kicad/plugins/3d/libs3d_plugin_idf.so" to "" -- Installing: /usr/local/lib64/kicad/plugins/3d/libs3d_plugin_vrml.so -- Set runtime path of "/usr/local/lib64/kicad/plugins/3d/libs3d_plugin_vrml.so" to "" -- Installing: /usr/local/lib64/kicad/plugins/3d/libs3d_plugin_oce.so -- Set runtime path of "/usr/local/lib64/kicad/plugins/3d/libs3d_plugin_oce.so" to "" -- Installing: /usr/local/bin/kicad -- Set runtime path of "/usr/local/bin/kicad" to "" -- Installing: /usr/local/bin/idfcyl -- Installing: /usr/local/bin/idfrect -- Installing: /usr/local/bin/idf2vrml -- Set runtime path of "/usr/local/bin/idf2vrml" to "" -- Installing: /usr/local/bin/dxf2idf -- Set runtime path of "/usr/local/bin/dxf2idf" to "" -- Installing: /usr/local/bin/kicad-ogltest -- Set runtime path of "/usr/local/bin/kicad-ogltest" to "" -- Installing: /usr/local/bin/kicad2step -- Set runtime path of "/usr/local/bin/kicad2step" to "" -- Up-to-date: /usr/local/share/kicad/demos/complex_hierarchy -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/fp-lib-table -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/complex_hierarchy.sch -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/complex_hierarchy-cache.lib -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/ampli_ht.sch -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/complex_hierarchy.kicad_pcb -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/complex_hierarchy_schlib.lib -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/sym-lib-table -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/complex_hierarchy.net -- Installing: /usr/local/share/kicad/demos/complex_hierarchy/complex_hierarchy.pro -- Up-to-date: /usr/local/share/kicad/demos/custom_pads_test -- Installing: /usr/local/share/kicad/demos/custom_pads_test/custom_pads_test.net -- Installing: /usr/local/share/kicad/demos/custom_pads_test/custom_pads_test.sch -- Installing: /usr/local/share/kicad/demos/custom_pads_test/custom_pads_test.pro -- Installing: /usr/local/share/kicad/demos/custom_pads_test/custom_pads_test.kicad_pcb -- Installing: /usr/local/share/kicad/demos/custom_pads_test/custom_pads_schlib.lib -- Installing: /usr/local/share/kicad/demos/custom_pads_test/custom_pads_test.lib -- Installing: /usr/local/share/kicad/demos/custom_pads_test/sym-lib-table -- Installing: /usr/local/share/kicad/demos/custom_pads_test/custom_pads_test-cache.lib -- Installing: /usr/local/share/kicad/demos/custom_pads_test/custom_pads_schlib.dcm -- Up-to-date: /usr/local/share/kicad/demos/ecc83 -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp_v2.kicad_pcb -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83_schlib.lib -- Installing: /usr/local/share/kicad/demos/ecc83/fp-lib-table -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp.net -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp.sch -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp_v2-cache.lib -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83_schlib.dcm -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp.kicad_pcb -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp-cache.lib -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp_v2.net -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp.pro -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp_v2.pro -- Installing: /usr/local/share/kicad/demos/ecc83/sym-lib-table -- Installing: /usr/local/share/kicad/demos/ecc83/ecc83-pp_v2.sch -- Up-to-date: /usr/local/share/kicad/demos/electric -- Installing: /usr/local/share/kicad/demos/electric/electric.pro -- Installing: /usr/local/share/kicad/demos/electric/elec-unifil.dcm -- Installing: /usr/local/share/kicad/demos/electric/elec-unifil.lib -- Installing: /usr/local/share/kicad/demos/electric/sym-lib-table -- Installing: /usr/local/share/kicad/demos/electric/electric-cache.lib -- Installing: /usr/local/share/kicad/demos/electric/electric.sch -- Up-to-date: /usr/local/share/kicad/demos/flat_hierarchy -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/flat_hierarchy.pro -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/sym-lib-table -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/flat_hierarchy.kicad_pcb -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/flat_hierarchy_schlib.lib -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/flat_hierarchy.sch -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/flat_hierarchy-cache.lib -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/flat_hierarchy.net -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/pic_sockets.sch -- Installing: /usr/local/share/kicad/demos/flat_hierarchy/pic_programmer.sch -- Up-to-date: /usr/local/share/kicad/demos/interf_u -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u.kicad_pcb -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u.pro -- Installing: /usr/local/share/kicad/demos/interf_u/fp-lib-table -- Installing: /usr/local/share/kicad/demos/interf_u/tux.kicad_mod -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u.net -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u_schlib.lib -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u.sch -- Up-to-date: /usr/local/share/kicad/demos/interf_u/interf_u.pretty -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u.pretty/PGA120.kicad_mod -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u.pretty/BUS_PC.kicad_mod -- Installing: /usr/local/share/kicad/demos/interf_u/sym-lib-table -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u_schlib.dcm -- Installing: /usr/local/share/kicad/demos/interf_u/interf_u-cache.lib -- Installing: /usr/local/share/kicad/demos/interf_u/tux.bmp -- Installing: /usr/local/share/kicad/demos/interf_u/pagelayout_logo.kicad_wks -- Installing: /usr/local/share/kicad/demos/interf_u/tux.lib -- Up-to-date: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213 -- Up-to-date: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/prj.3dshapes -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/prj.3dshapes/db9_female_pin90deg.wrl -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/prj.3dshapes/Jack.wrl -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/prj.3dshapes/Device.switch_toggle_horizontal_right_angle_PC_terminal.wrl -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/prj.3dshapes/push_butt_4pads.wrl -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/prj.3dshapes/Device.switch_toggle_horizontal_right_angle_PC_terminal.wings -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/prj.3dshapes/Jack.wings -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/prj.3dshapes/push_butt_4pads.wings -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/in_out_conn.sch -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/fp-lib-table -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/kit-dev-coldfire-xilinx_5213-cache.lib -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/xilinx.sch -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/kit-dev-coldfire-xilinx_5213.net -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/kit-dev-coldfire-xilinx_5213.kicad_pcb -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/kit-dev-coldfire-xilinx_5213_schlib.dcm -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/sym-lib-table -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/kit-dev-coldfire-xilinx_5213.sch -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/kit-dev-coldfire-xilinx_5213_schlib.lib -- Installing: /usr/local/share/kicad/demos/kit-dev-coldfire-xilinx_5213/kit-dev-coldfire-xilinx_5213.pro -- Up-to-date: /usr/local/share/kicad/demos/microwave -- Installing: /usr/local/share/kicad/demos/microwave/shape1.txt -- Installing: /usr/local/share/kicad/demos/microwave/microwave.kicad_pcb -- Installing: /usr/local/share/kicad/demos/microwave/microwave.pro -- Up-to-date: /usr/local/share/kicad/demos/pic_programmer -- Installing: /usr/local/share/kicad/demos/pic_programmer/pic_programmer.net -- Installing: /usr/local/share/kicad/demos/pic_programmer/fp-lib-table -- Installing: /usr/local/share/kicad/demos/pic_programmer/pic_programmer.pro -- Installing: /usr/local/share/kicad/demos/pic_programmer/sym-lib-table -- Installing: /usr/local/share/kicad/demos/pic_programmer/pic_programmer.kicad_pcb -- Installing: /usr/local/share/kicad/demos/pic_programmer/pic_programmer-cache.lib -- Installing: /usr/local/share/kicad/demos/pic_programmer/pic_sockets.sch -- Installing: /usr/local/share/kicad/demos/pic_programmer/pic_programmer.sch -- Up-to-date: /usr/local/share/kicad/demos/pic_programmer/libs -- Installing: /usr/local/share/kicad/demos/pic_programmer/libs/pic_programmer_schlib.dcm -- Up-to-date: /usr/local/share/kicad/demos/pic_programmer/libs/pic_programmer_fp.pretty -- Installing: /usr/local/share/kicad/demos/pic_programmer/libs/pic_programmer_fp.pretty/40tex-Ell600.kicad_mod -- Installing: /usr/local/share/kicad/demos/pic_programmer/libs/pic_programmer_fp.pretty/TO-92_BC237_307.kicad_mod -- Installing: /usr/local/share/kicad/demos/pic_programmer/libs/pic_programmer_fp.pretty/RV2X4.kicad_mod -- Installing: /usr/local/share/kicad/demos/pic_programmer/libs/pic_programmer_schlib.lib -- Up-to-date: /usr/local/share/kicad/demos/python_scripts_examples -- Installing: /usr/local/share/kicad/demos/python_scripts_examples/gen_gerber_and_drill_files_board.py -- Installing: /usr/local/share/kicad/demos/python_scripts_examples/action_menu_text_by_date.py -- Installing: /usr/local/share/kicad/demos/python_scripts_examples/action_plugin_test_undoredo.py -- Installing: /usr/local/share/kicad/demos/python_scripts_examples/action_menu_add_automatic_border.py -- Installing: /usr/local/share/kicad/demos/python_scripts_examples/plot_board.py -- Up-to-date: /usr/local/share/kicad/demos/simulation -- Up-to-date: /usr/local/share/kicad/demos/simulation/rectifier -- Installing: /usr/local/share/kicad/demos/simulation/rectifier/rectifier.pro -- Installing: /usr/local/share/kicad/demos/simulation/rectifier/rectifier-cache.lib -- Installing: /usr/local/share/kicad/demos/simulation/rectifier/sym-lib-table -- Installing: /usr/local/share/kicad/demos/simulation/rectifier/rectifier_schlib.lib -- Installing: /usr/local/share/kicad/demos/simulation/rectifier/rectifier.sch -- Up-to-date: /usr/local/share/kicad/demos/simulation/pspice -- Installing: /usr/local/share/kicad/demos/simulation/pspice/pspice-cache.lib -- Installing: /usr/local/share/kicad/demos/simulation/pspice/pspice.pro -- Installing: /usr/local/share/kicad/demos/simulation/pspice/schematic_libspice.dcm -- Installing: /usr/local/share/kicad/demos/simulation/pspice/schematic_libspice.lib -- Installing: /usr/local/share/kicad/demos/simulation/pspice/sym-lib-table -- Installing: /usr/local/share/kicad/demos/simulation/pspice/pspice.sch -- Up-to-date: /usr/local/share/kicad/demos/simulation/laser_driver -- Installing: /usr/local/share/kicad/demos/simulation/laser_driver/laser_driver_schlib.lib -- Installing: /usr/local/share/kicad/demos/simulation/laser_driver/laser_driver.pro -- Installing: /usr/local/share/kicad/demos/simulation/laser_driver/ad8009.lib -- Installing: /usr/local/share/kicad/demos/simulation/laser_driver/laser_driver.sch -- Installing: /usr/local/share/kicad/demos/simulation/laser_driver/laser.lib -- Installing: /usr/local/share/kicad/demos/simulation/laser_driver/sym-lib-table -- Installing: /usr/local/share/kicad/demos/simulation/laser_driver/laser_driver-cache.lib -- Installing: /usr/local/share/kicad/demos/simulation/laser_driver/fzt1049a.lib -- Up-to-date: /usr/local/share/kicad/demos/simulation/sallen_key -- Installing: /usr/local/share/kicad/demos/simulation/sallen_key/sallen_key.sch -- Installing: /usr/local/share/kicad/demos/simulation/sallen_key/ad8051.lib -- Installing: /usr/local/share/kicad/demos/simulation/sallen_key/sym-lib-table -- Installing: /usr/local/share/kicad/demos/simulation/sallen_key/sallen_key_schlib.lib -- Installing: /usr/local/share/kicad/demos/simulation/sallen_key/sallen_key.pro -- Installing: /usr/local/share/kicad/demos/simulation/sallen_key/sallen_key-cache.lib -- Up-to-date: /usr/local/share/kicad/demos/sonde xilinx -- Installing: /usr/local/share/kicad/demos/sonde xilinx/sonde xilinx_schlib.lib -- Installing: /usr/local/share/kicad/demos/sonde xilinx/fp-lib-table -- Installing: /usr/local/share/kicad/demos/sonde xilinx/sonde xilinx.kicad_pcb -- Installing: /usr/local/share/kicad/demos/sonde xilinx/sonde xilinx.sch -- Installing: /usr/local/share/kicad/demos/sonde xilinx/sym-lib-table -- Installing: /usr/local/share/kicad/demos/sonde xilinx/sonde xilinx.net -- Installing: /usr/local/share/kicad/demos/sonde xilinx/sonde xilinx.pro -- Installing: /usr/local/share/kicad/demos/sonde xilinx/sonde xilinx-cache.lib -- Up-to-date: /usr/local/share/kicad/demos/test_pads_inside_pads -- Installing: /usr/local/share/kicad/demos/test_pads_inside_pads/test_pads_inside_pads_schlib.dcm -- Installing: /usr/local/share/kicad/demos/test_pads_inside_pads/test_pads_inside_pads.kicad_pcb -- Installing: /usr/local/share/kicad/demos/test_pads_inside_pads/test_pads_inside_pads.pro -- Installing: /usr/local/share/kicad/demos/test_pads_inside_pads/test_pads_inside_pads.sch -- Installing: /usr/local/share/kicad/demos/test_pads_inside_pads/test_pads_inside_pads_schlib.lib -- Installing: /usr/local/share/kicad/demos/test_pads_inside_pads/sym-lib-table -- Installing: /usr/local/share/kicad/demos/test_pads_inside_pads/test_pads_inside_pads.net -- Installing: /usr/local/share/kicad/demos/test_pads_inside_pads/test_pads_inside_pads-cache.lib -- Up-to-date: /usr/local/share/kicad/demos/test_xil_95108 -- Installing: /usr/local/share/kicad/demos/test_xil_95108/carte_test.net -- Installing: /usr/local/share/kicad/demos/test_xil_95108/carte_test-cache.lib -- Installing: /usr/local/share/kicad/demos/test_xil_95108/carte_test.sch -- Installing: /usr/local/share/kicad/demos/test_xil_95108/carte_test_schlib.dcm -- Installing: /usr/local/share/kicad/demos/test_xil_95108/fp-lib-table -- Installing: /usr/local/share/kicad/demos/test_xil_95108/carte_test.pro -- Installing: /usr/local/share/kicad/demos/test_xil_95108/carte_test_schlib.lib -- Installing: /usr/local/share/kicad/demos/test_xil_95108/sym-lib-table -- Installing: /usr/local/share/kicad/demos/test_xil_95108/carte_test.kicad_pcb -- Up-to-date: /usr/local/share/kicad/demos/video -- Installing: /usr/local/share/kicad/demos/video/pal-ntsc.sch -- Installing: /usr/local/share/kicad/demos/video/modul.sch -- Installing: /usr/local/share/kicad/demos/video/graphic.sch -- Installing: /usr/local/share/kicad/demos/video/fp-lib-table -- Installing: /usr/local/share/kicad/demos/video/bus_pci.sch -- Installing: /usr/local/share/kicad/demos/video/video.sch -- Installing: /usr/local/share/kicad/demos/video/video.kicad_pcb -- Installing: /usr/local/share/kicad/demos/video/rams.sch -- Installing: /usr/local/share/kicad/demos/video/muxdata.sch -- Installing: /usr/local/share/kicad/demos/video/sym-lib-table -- Installing: /usr/local/share/kicad/demos/video/video.pro -- Installing: /usr/local/share/kicad/demos/video/video-cache.lib -- Installing: /usr/local/share/kicad/demos/video/esvideo.sch -- Installing: /usr/local/share/kicad/demos/video/video.net -- Up-to-date: /usr/local/share/kicad/demos/video/libs -- Up-to-date: /usr/local/share/kicad/demos/video/libs/footprints.pretty -- Installing: /usr/local/share/kicad/demos/video/libs/footprints.pretty/PLCC68.kicad_mod -- Installing: /usr/local/share/kicad/demos/video/libs/footprints.pretty/PLCC84.kicad_mod -- Installing: /usr/local/share/kicad/demos/video/libs/footprints.pretty/sim72.kicad_mod -- Installing: /usr/local/share/kicad/demos/video/libs/footprints.pretty/LRTDK.kicad_mod -- Installing: /usr/local/share/kicad/demos/video/libs/video_schlib.lib -- Installing: /usr/local/share/kicad/template/kicad.pro >/usr/local/bin/kicad ./src/common/object.cpp(251): assert "classTable->Get(m_className) == NULL" failed in Register(): Class "wxAnyValueTypeGlobalsManager" already in RTTI table - have you used IMPLEMENT_DYNAMIC_CLASS() multiple times or linked some object file twice)? kicad-source-mirror-master-20190222/kicad-error-calling-pcb-layout-editor.jpg
