18:00:05$ fm DL1FX-0 to APRX29-0 via DB0FDA-0 UI PID=F0 !4944.13NI00834.57E& BC1 Raspberry RX/TX APRX iGate QTH: Haehnlein JN49GR OP: Peter 18:00:05$ fm DB0AIS-0 to APGW1K-0 via DB0FDA-0,WIDE2-2 UIv PID=F0 !4959.31N/00835.51Er438.387MHz C4FM/WiresX+FM 67Hz 13.7V 18:00:07$ fm DB0AIS-0 to APGW1K-0 via DB0GIS-10,WIDE1-0,DB0FDA-0 UIv PID=F0 !4959.31N/00835.51Er438.387MHz C4FM/WiresX+FM 67Hz 13.7V 18:00:13$ fm DB0ASF-0 to APGE01-0 via DB0GIS-10,DB0FDA-0 UI PID=F0 }DL7FCG>APGE01,TCPIP,DB0ASF*:>!5008.29N/00901.97E-3(5) with OLED Display 256 x 64 Pixel 18:00:30$ fm DL1JU-9 to TY5YR1-0 via DB0FDA-0,WIDE2-1 UIv PID=F0 `~._l .j/]"4s}439.325MHz 73 RALF= 18:01:23$ fm DF0HR-0 to APRS-0 via DB0FDA-0 UI^ PID=F0 >anyfrog + TH-D7E 18:01:39$ fm DB0RHB-0 to APNU19-0 via DB0MYK-0,DB0GIS-10,DB0FDA-0 UI^ PID=F0 !5034.63N/00656.80E#APRS-DIGI Todenfeld/Rheinbach 400m NN 18:01:39$ fm DF0HR-0 to APRS-0 via DB0GIS-10,DB0FDA-0 UI^ PID=F0 >anyfrog + TH-D7E 18:01:40$ fm DB0HU-0 to APU25N-0 via DB0MI-0,WIDE1-0,DB0GIS-10,DB0FDA-0 UI^ PID=F0 APRS,TCPIP,DB0ASF*:>=5007.54N/00909.21E>320/012/A=000892 GPS Accuracy: 3m 18:01:52$ fm DG3FDW-9 to APAVT5-0 via DB0BOS-0,DB0FDA-0 UI PID=F0 =4940.16N/00900.66Ev054/000/A=000763 Ralf on Bulli K 4.07V X 18:02:00$ fm DB0FDA-0 to APRS-0 via WIDE2-2 UI^ PID=F0 !4952.05N/00838.28E#MultimodeRelais DA 438.587MHz www.f42.info 18:02:30$ fm DL1JU-9 to TY5YR0-0 via DB0IDS-0,DB0FDA-0 UIv PID=F0 `~._l .j/]"4p}439.325MHz 73 RALF= 18:02:30$ fm DG1YHR-9 to EIFPQ7-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 `~]!pq$v/`"5.}_$ 18:02:43$ fm DB0FBH-13 to APGW1K-0 via WIDE1-1,WIDE2-2 UIv PID=F0 =4936.19N/00744.74E_000/000g000t078r000p000h01b09668FELSBERGERHOF WX 13.9V 18:02:44$ fm DB0ASF-0 to APGE01-0 via DB0GIS-10,DB0FDA-0 UI PID=F0 }DB0FAT>APLM01,TCPIP,DB0ASF*:>!5008.29N/00901.99E#/A=000525 Bodo at Home 18:02:44$ fm DB0REI-10 to APMI0A-0 via DB0GIS-10,WIDE1-0,DB0FDA-0 UI PID=F0 !5037.42N/00854.09ErAPRS DB0REI U=12.0V Digi Sysop DB4ZZ/DL9GX 18:02:54$ fm DB0FBH-13 to APGW1K-0 via DL1FX-0,WIDE1-0,DB0FDA-0 UIv PID=F0 =4936.19N/00744.74E_000/000g000t078r000p000h01b09668FELSBERGERHOF WX 13.9V 18:04:40$ fm DB0DIG-0 to APX204-0 via DB0RO-0,DB0FDA-0 UI PID=F0 =/5Y`cPG*A&{1CDB0DIG, Pirmasens 18:05:14$ fm F5RCT-9 to TX3YV7-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 `}Lm}D>/]"5o}= 18:05:22$ fm DG1YHR-9 to EIEYY2-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 `~_ oS$v/`"51}_$ 18:05:23$ fm DM3HJW-3 to TYPQT5-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 '~1nl ._/]TM-D710.Ultimeter2100.= 18:06:01$ fm DB0ASF-0 to APGE01-0 via DB0GIS-10,DB0FDA-0 UI PID=F0 }DB0HU>APU25N,TCPIP,DB0ASF*:>=5007.19N/00857.25ErCAMPERTRACK EL-NODE:951011 432,800Mhz T00 18:06:01$ fm DB0KT-0 to APNU18-0 via DB0GIS-10,WIDE1-0,DB0FDA-0 UI^ PID=F0 > www.aprs-frankfurt.de 18:06:02$ fm DB0AIS-0 to APGW1K-0 via DB0FDA-0,WIDE2-2 UIv PID=F0 !4959.31N/00835.51Er438.387MHz C4FM/WiresX+FM 67Hz 13.8V 18:07:08$ fm DB0FDA-0 to APRS-0 via DL1FX-0,WIDE3-2 UI^ PID=F0 !4952.05N/00838.28E#DMR Relais BrandMeister DA 438.500MHz 18:08:37$ fm DL1JU-9 to TY5YR1-0 via DB0IDS-0,DB0FDA-0 UIv PID=F0 `~._l .j/]"4y}439.325MHz 73 RALF= 18:08:37$ fm DB0ASF-0 to APGE01-0 via DB0GIS-10,DB0FDA-0 UI PID=F0 }DG7NFG-11>APRX28,TCPIP,DB0ASF*:>!4958.63NR00916.76E&Rx-only iGate on Raspberry Pi 18:08:53$ fm DB0REI-10 to APMI0A-0 via DB0GIS-10,WIDE1-0,DB0FDA-0 UI PID=F0 T#150,164,000,000,000,000,00000000 18:08:54$ fm DK3RW-9 to U0SXW2-0 via DB0REI-10,DB0GIS-10,DB0FDA-0 UI PID=F0 `~Wks|>>/"7Q} 18:09:02$ fm DB0ASF-0 to APGE01-0 via DB0GIS-10,DB0FDA-0 UI PID=F0 }DB3FAT-6>APGE01,TCPIP,DB0ASF*:>!5008.29N/00901.97E_.../...g...t...r...p...h36b..... 18:09:10$ fm DK3RW-9 to U0SXV2-0 via DB0REI-10,DB0GIS-10,DB0FDA-0 UI PID=F0 `~WCo,`>/"7<}Ralf.F07 18:09:15$ fm DK3RW-9 to U0SXV6-0 via DB0GIS-10,WIDE1-0,DB0FDA-0 UI PID=F0 `~W@nf8>/"7:} 18:09:15$ fm DB0TFM-1 to AP4R10-0 via DB0FDA-0 UIv PID=F0 ;EL-374241*111111z4845.42NE00824.47E0439.225MHz 1750 R50k DB0TFM-R 18:09:16$ fm DB0TFM-6 to AP4R10-0 via DB0FDA-0 UIv PID=F0 =4845.42N/00824.47E_.../...g...t...r...p...P...h..b..... 18:09:26$ fm DK3RW-9 to U0SXV6-0 via DB0GIS-10,WIDE1-0,DB0FDA-0 UI PID=F0 `~WJmqL>/"7<}
