17:49:44$ fm DL1FX-0 to APRX29-0 via DB0FDA-0 UI PID=F0 !4944.13NI00834.57E& BC4 Raspberry RX/TX APRX iGate QTH: Haehnlein JN49GR OP: Peter 17:49:57$ fm DB0ASF-0 to APGE01-0 via DB0GIS-10,DB0FDA-0 UI PID=F0 }DB0ASF-4>APGE01,TCPIP,DB0ASF*:>!5004.67N/00906.55E_292/000g...t072r000p000h47b10199 17:50:26$ fm DB0ASF-0 to APGE01-0 via DB0FDA-0 UI PID=F0 }DG7NFG-11>APRX28,TCPIP,DB0ASF*:>!4958.63NR00916.76E&Rx-only iGate on Raspberry Pi 17:50:42$ fm DB0FDA-0 to APRS-0 via WIDE3-3 UI^ PID=F0 !4952.05N/00838.28E#DMR Relais BrandMeister DA 438.500MHz 17:51:02$ fm DF5KC-0 to TYUYW1-0 via DB0FDA-0,WIDE2-1 UIv PID=F0 `~?Ol ,-/`"5/}YAESU VX-8 the real ALL-in-ONE Tracker DF5KC 64546 Walldorf _ 17:51:26$ fm DB0ASF-0 to APGE01-0 via DB0GIS-10,DB0FDA-0 UI PID=F0 }DB0FAT>APLM01,TCPIP,DB0ASF*:>!5008.29N/00901.99E#/A=000525 Bodo at Home 17:51:36$ fm DB0TFM-6 to APOTC1-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 >Teufelsmuehle 900m NN, Ultimeter 2100 12.1V 21C 17:51:40$ fm DM3HJW-1 to TYPQT5-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 '~1nl ._/]TM-D710.Ultimeter2100.= 17:51:48$ fm DO3CN-7 to APRS-0 via DB0KT-0,DB0FDA-0 UI^ PID=F0 !5007.67N/00846.73E[Christoph 17:52:11$ fm DF8JE-9 to UQ0XW7-0 via DB0KX-2,DB0MYK-0,DB0FDA-0 UI PID=F0 `|Ofm?<>/ 17:52:12$ fm DB0GIS-10 to APMI04-0 via DB0FDA-0 UI PID=F0 @011913z5033.02N/00845.81E&WX3in1Mini U=13.4V Digi + Gateway Fernwald JO40JN Sysop DL6FBS 17:52:52$ fm DF4OR-0 to TYPXU4-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 '~)>l .-/]= 17:53:07$ fm DB0AIS-0 to APGW1K-0 via DB0FDA-0,WIDE2-2 UIv PID=F0 !4959.31N/00835.51Er438.387MHz C4FM/WiresX+FM 67Hz 13.9V 17:53:08$ fm DB0AIS-0 to APGW1K-0 via DB0BOS-0,DB0GIS-10,DB0FDA-0 UIv PID=F0 !4959.31N/00835.51Er438.387MHz C4FM/WiresX+FM 67Hz 13.9V 17:53:34$ fm DB0REI-10 to APMI0A-0 via DB0KT-0,DB0FDA-0 UI PID=F0 !5037.42N/00854.09E_022/000g000t071r000p000P...h49b09869APRS DB0REI Wetter 17:53:47$ fm PE4CE-0 to TX3QQ8-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 `}9` |Zv/]"5t}145.500MHz= 17:53:48$ fm DB0TFM-1 to AP4R10-0 via DB0FDA-0 UIv PID=F0 ;EL-374241*111111z4845.42NE00824.47E0439.225MHz 1750 R50k DB0TFM-R 17:54:28$ fm DB0LDK-0 to APMI06-0 via DB0GIS-10,DB0FDA-0 UI PID=F0 @011916z5032.28N/00831.77E-WX3in1Plus2.0 U=12.2V 17:54:28$ fm DO3CN-7 to APRS-0 via DB0KT-0,DB0FDA-0 UI^ PID=F0 !5007.67N/00846.73E[Christoph 17:54:50$ fm PE4CE-0 to TX3QQ0-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 `}8Z ,cv/]"6"}145.500MHz= 17:55:01$ fm DF0OH-2 to APZ1HW-0 via DB0TFM-1,DB0FDA-0 UIv PID=F0 T#851,48.9,122.7,63.3,121.6,000,00000000 17:56:53$ fm DF0HR-0 to APRS-0 via DB0GIS-10,DB0FDA-0 UI^ PID=F0 >anyfrog + TH-D7E 17:57:24$ fm PE4CE-0 to TX3RP8-0 via DB0SWS-1,DB0RO-0,DB0FDA-0 UIv PID=F0 `}6p "}v/]"6:}145.500MHz= 17:58:00$ fm DB0BOS-0 to APNU19-0 via DB0FDA-0,WIDE2-2 UI^ PID=F0 !4944.59N/00855.26E#APRS-Digi Boellstein 17:58:01$ fm DB0AIS-0 to APGW1K-0 via DB0FDA-0 UIv PID=F0 =4959.31N/00835.51E_000/000g000t097r000p000h19b09983DB0AIS indoor Temperature - 17:58:13$ fm DB0BOS-0 to APNU19-0 via DB0KT-0,DB0GIS-10,DB0FDA-0 UI^ PID=F0 !4944.59N/00855.26E#APRS-Digi Boellstein 17:58:14$ fm DB0REI-10 to APMI0A-0 via DB0KT-0,DB0FDA-0 UI PID=F0 !5037.42N/00854.09ErAPRS DB0REI U=12.0V Digi Sysop DB4ZZ/DL9GX 17:58:33$ fm DH6KW-6 to APOTC1-0 via DB0BOS-0,DB0FDA-0 UI PID=F0 !4954.34N/00851.26E_.../...g...t071OD1w 17:58:39$ fm DB0ASF-0 to APGE01-0 via DB0FDA-0 UI PID=F0 }DG7NFG-11>APRX28,TCPIP,DB0ASF*:>!4958.63NR00916.76E&Rx-only iGate on Raspberry Pi
