/* UDP syntax: signals: DS18B20 1wire sensor packet: rail1 1w 2864fc3008082 25.44 DS2438 1wire sensor packet: rail1 1w 2612c3102004f 25.44 1.23 0.12 digital input state: rail1 di1 1 analog input state: rail1 ai1 250 commands: relay on command: rail1 do12 on relay off command: rail1 do5 off high side switch on command: rail1 ho2 on high side switch off command: rail1 ho4 off low side switch on command: rail1 lo1 on low side switch off command: rail1 lo2 off analog output command: rail1 ao1 180 status command: rail1 stat10 reset command: rail1 rst default scan cycles: 1wire cycle: 30000 ms analog input cycle: 10000 ms heart beat cycle(only RS485): 60000 ms MODBUS TCP commands: FC1 - FC16 MODBUS RTU commands: FC3, FC6, FC16 MODBUS register map (1 register = 2 bytes = 16 bits) register number description 0 relay outputs 1-8 1 relay outputs 9-12 2 digital outputs HSS 1-4, LSS 1-4 3 analog output 1 4 analog output 2 5 digital inputs 1-8 6 digital inputs 9-16 7 digital inputs 17-24 8 analog input 1 0-256 9 analog input 2 0-256 10 service - reset (bit 0) 11 1st DS2438 Temp (value multiplied by 100) 12 1st DS2438 Vad (value multiplied by 100) 13 1st DS2438 Vsens (value multiplied by 100) - 39 DS2438 values (up to 10 sensors) 40-50 DS18B20 Temperature (up to 10 sensors) (value multiplied by 100) Combination of 1wire sensors must be up to 10pcs maximum (DS18B20 or DS2438) using RS485 the UDP syntax must have \n symbol at the end of the command line */ //#define dbg(x) Serial.print(x); #define dbg(x) Serial.println(x); //#define dbgln(x) Serial.println(x); #define dbgln(x) ; #define ver 3 #include #include #include #include #include #include byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0}; unsigned int listenPort = 44444; unsigned int sendPort = 55555; unsigned int remPort = 55556; IPAddress listenIpAddress; IPAddress sendIpAddress(255, 255, 255, 255); #define relOut1Byte 0 #define relOut2Byte 1 #define hssLssByte 2 #define anaOut1Byte 3 #define anaOut2Byte 4 #define digInp1Byte 5 #define digInp2Byte 6 #define digInp3Byte 7 #define anaInp1Byte 8 #define anaInp2Byte 9 #define serviceByte 10 #define oneWireTempByte 11 #define oneWireVadByte 12 #define oneWireVsensByte 13 #define oneWireDS18B20Byte 40 #define inputPacketBufferSize UDP_TX_PACKET_MAX_SIZE char inputPacketBuffer[UDP_TX_PACKET_MAX_SIZE]; #define outputPacketBufferSize 100 char outputPacketBuffer[outputPacketBufferSize]; EthernetUDP udpRecv; EthernetUDP udpSend; #define oneWireCycle 5000 #define oneWireSubCycle 5000 #define anaInputCycle 10000 #define heartBeatCycle 60000 #define statusLedTimeOn 50 #define statusLedTimeOff 990 #define commLedTimeOn 50 #define commLedTimeOff 50 #define debouncingTime 5 #define Serial1TxControl 16 #define numOfRelays 14 int relayPins[numOfRelays] = {43, 44, 45, 46, 47, 48, 49, 2, 3, 4, 5, 40, 41, 42}; #define numOfHSSwitches 0 int HSSwitchPins[numOfHSSwitches] = {}; #define numOfLSSwitches 0 int LSSwitchPins[numOfLSSwitches] = {}; #define numOfAnaOuts 8 int anaOutPins[numOfAnaOuts] = {9,8 ,7 ,6 ,13 ,12 ,11 ,10}; #define numOfAnaInputs 8 int analogPins[numOfAnaInputs] = {57, 56 ,55 ,54 ,61 ,60 ,59 ,58}; float analogStatus[numOfAnaInputs]; #define numOfDigInputs 16 int inputPins[numOfDigInputs] = {22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37}; int inputStatus[numOfDigInputs]; int inputStatusNew[numOfDigInputs]; int inputChangeTimestamp[numOfDigInputs]; #define numOfDipSwitchPins 5 int dipSwitchPins[numOfDipSwitchPins] = {66, 65, 64, 63, 67}; #define numOfLedPins 2 int ledPins[numOfLedPins] = {69, 68}; int boardAddress = 0; int ethOn = 0; int rtuOn = 0; long baudRate = 115200; int Serial1TxDelay = 10; int Serial1TimeOut = 20; bool ticTac = 0; String boardAddressStr; String boardAddressRailStr; String railStr = "rail"; String digInputStr = "di"; String anaInputStr = "ai"; String relayStr = "ro"; String HSSwitchStr = "ho"; String LSSwitchStr = "lo"; String anaOutStr = "ao"; String digStatStr = "stat"; String rstStr = "rst"; String heartBeatStr = "hb"; String relayOnCommands[numOfRelays]; String relayOffCommands[numOfRelays]; String HSSwitchOnCommands[numOfHSSwitches]; String HSSwitchOffCommands[numOfHSSwitches]; String LSSwitchOnCommands[numOfLSSwitches]; String LSSwitchOffCommands[numOfLSSwitches]; String digStatCommand[numOfDigInputs]; String anaOutCommand[numOfAnaOuts]; class Timer { private: unsigned long timestampLastHitMs; unsigned long sleepTimeMs; public: boolean isOver(); void sleep(unsigned long sleepTimeMs); }; boolean Timer::isOver() { if (millis() - timestampLastHitMs < sleepTimeMs) { return false; } timestampLastHitMs = millis(); return true; } void Timer::sleep(unsigned long sleepTimeMs) { this->sleepTimeMs = sleepTimeMs; timestampLastHitMs = millis(); } Timer statusLedTimerOn; Timer statusLedTimerOff; Timer oneWireTimer; Timer oneWireSubTimer; Timer analogTimer; Timer heartBeatTimer; MgsModbus Mb; OneWire ds(38); byte oneWireData[12]; byte oneWireAddr[8]; #define maxSensors 10 byte readstage = 0, resolution = 11; byte sensors[maxSensors][8], DS2438count, DS18B20count; byte sensors2438[maxSensors][8], sensors18B20[maxSensors][8]; DS2438 ds2438(&ds); void setup() { Serial.begin(9600); dbg("Railduino firmware version: "); dbgln(ver); for (int i = 0; i < numOfDigInputs; i++) { pinMode(inputPins[i], INPUT); inputStatus[i] = 1; inputStatusNew[i] = 0; digStatCommand[i] = digStatStr + String(i + 1, DEC); } for (int i = 0; i < numOfRelays; i++) { pinMode(relayPins[i], OUTPUT); relayOnCommands[i] = relayStr + String(i + 1, DEC) + " on"; relayOffCommands[i] = relayStr + String(i + 1, DEC) + " off"; setRelay(i, 0); } for (int i = 0; i < numOfHSSwitches; i++) { pinMode(HSSwitchPins[i], OUTPUT); HSSwitchOnCommands[i] = HSSwitchStr + String(i + 1, DEC) + " on"; HSSwitchOffCommands[i] = HSSwitchStr + String(i + 1, DEC) + " off"; setHSSwitch(i, 0); } for (int i = 0; i < numOfLSSwitches; i++) { pinMode(LSSwitchPins[i], OUTPUT); LSSwitchOnCommands[i] = LSSwitchStr + String(i + 1, DEC) + " on"; LSSwitchOffCommands[i] = LSSwitchStr + String(i + 1, DEC) + " off"; setLSSwitch(i, 0); } for (int i = 0; i < numOfAnaOuts; i++) { pinMode(anaOutPins[i], OUTPUT); anaOutCommand[i] = anaOutStr + String(i + 1, DEC); setAnaOut(i, 0); } for (int i = 0; i < numOfAnaInputs; i++) { pinMode(analogPins[i], INPUT); } for (int i = 0; i < numOfLedPins; i++) { pinMode(ledPins[i], OUTPUT); } analogTimer.sleep(anaInputCycle); statusLedTimerOn.sleep(statusLedTimeOn); statusLedTimerOff.sleep(statusLedTimeOff); heartBeatTimer.sleep(heartBeatCycle); for (int i = 0; i < 4; i++) { pinMode(dipSwitchPins[i], INPUT); if (!digitalRead(dipSwitchPins[i])) { boardAddress |= (1 << i); } } Ethernet.init(53); // Most Arduino shields pinMode(dipSwitchPins[4], INPUT); if (!digitalRead(dipSwitchPins[4])) { ethOn = 1; dbgln("Ethernet ON");} else { ethOn = 0; dbgln("Ethernet OFF");} pinMode(dipSwitchPins[4], INPUT); if (!digitalRead(dipSwitchPins[4])) { rtuOn = 0; dbgln("485 RTU ON ");} else { rtuOn = 1; dbgln("485 RTU OFF");} dbg(baudRate); dbg(" Bd, Tx Delay: "); dbg(Serial1TxDelay); dbg(" ms, Timeout: "); dbg(Serial1TimeOut); dbgln(" ms"); boardAddressStr = String(boardAddress); boardAddressRailStr = railStr + String(boardAddress); if (ethOn) { mac[5] = (0xED + boardAddress); listenIpAddress = IPAddress(192, 168, 178, 150 + boardAddress); if (Ethernet.begin(mac) == 0) { dbgln("Failed to configure Ethernet using DHCP, using Static Mode"); Ethernet.begin(mac, listenIpAddress); } udpRecv.begin(listenPort); udpSend.begin(sendPort); dbg("IP: "); printIPAddress(); dbgln(); } memset(Mb.MbData, 0, sizeof(Mb.MbData)); if (rtuOn) { modbus_configure(&Serial1, baudRate, SERIAL_8N1, boardAddress, Serial1TxControl, sizeof(Mb.MbData), Mb.MbData); } Serial1.begin(baudRate); Serial1.setTimeout(Serial1TimeOut); pinMode(Serial1TxControl, OUTPUT); digitalWrite(Serial1TxControl, 0); dbg("Address: "); dbgln(boardAddressStr); lookUpSensors(); } void loop() { readDigInputs(); readAnaInputs(); processCommands(); processOnewire(); statusLed(); if (ethOn) {Mb.MbsRun();} else {heartBeat();} if (rtuOn) {modbus_update();} } void (* resetFunc) (void) = 0; void printIPAddress() { for (byte thisByte = 0; thisByte < 4; thisByte++) { dbg(Ethernet.localIP()[thisByte]); dbg("."); } } void heartBeat() { if (!heartBeatTimer.isOver()) { return; } heartBeatTimer.sleep(heartBeatCycle); if (ticTac) { sendMsg(heartBeatStr + " 1"); ticTac = 0; } else { sendMsg(heartBeatStr + " 0"); ticTac = 1; } } void statusLed() { if (statusLedTimerOff.isOver()) { statusLedTimerOn.sleep(statusLedTimeOn); statusLedTimerOff.sleep(statusLedTimeOff); digitalWrite(ledPins[0],HIGH); } if (statusLedTimerOn.isOver()) { digitalWrite(ledPins[0],LOW); } } String oneWireAddressToString(byte addr[]) { String s = ""; for (int i = 0; i < 8; i++) { s += String(addr[i], HEX); } return s; } void lookUpSensors(){ byte j=0, k=0, l=0, m=0; while ((j <= maxSensors) && (ds.search(sensors[j]))){ if (!OneWire::crc8(sensors[j], 7) != sensors[j][7]){ if (sensors[j][0] == 38){ for (l=0;l<8;l++){ sensors2438[k][l]=sensors[j][l]; } k++; } else { for (l=0;l<8;l++){ sensors18B20[m][l]=sensors[j][l]; } m++; dssetresolution(ds,sensors[j],resolution); } } j++; } DS2438count = k; DS18B20count = m; dbg("1-wire sensors found: "); dbgln(k+m); } void dssetresolution(OneWire ow, byte addr[8], byte resolution) { byte resbyte = 0x1F; if (resolution == 12){ resbyte = 0x7F; } else if (resolution == 11) { resbyte = 0x5F; } else if (resolution == 10) { resbyte = 0x3F; } ow.reset(); ow.select(addr); ow.write(0x4E); ow.write(0); ow.write(0); ow.write(resbyte); ow.write(0x48); } void dsconvertcommand(OneWire ow, byte addr[8]){ ow.reset(); ow.select(addr); ow.write(0x44,1); } float dsreadtemp(OneWire ow, byte addr[8]) { int i; byte data[12]; float celsius; ow.reset(); ow.select(addr); ow.write(0xBE); for ( i = 0; i < 9; i++) { data[i] = ow.read(); } int16_t TReading = (data[1] << 8) | data[0]; celsius = 0.0625 * TReading; return celsius; } void processOnewire() { static byte oneWireState = 0; static byte oneWireCnt = 0; switch(oneWireState) { case 0: if (!oneWireTimer.isOver()) { return; } oneWireTimer.sleep(oneWireCycle); oneWireSubTimer.sleep(oneWireSubCycle); oneWireCnt = 0; oneWireState++; break; case 1: if (!oneWireSubTimer.isOver()) { return; } if ((oneWireCnt < DS2438count)){ ds2438.begin(); ds2438.update(sensors2438[oneWireCnt]); if (!ds2438.isError()) { if (rtuOn) { Mb.MbData[oneWireTempByte + (oneWireCnt*3)] = ds2438.getTemperature()*100; Mb.MbData[oneWireVadByte + (oneWireCnt*3)] = ds2438.getVoltage(DS2438_CHA)*100; Mb.MbData[oneWireVsensByte + (oneWireCnt*3)] = ds2438.getVoltage(DS2438_CHB)*100; } else { sendMsg("1w " + oneWireAddressToString(sensors2438[oneWireCnt]) + " " + String(ds2438.getTemperature(), 2) + " " + String(ds2438.getVoltage(DS2438_CHA), 2) + " " + String(ds2438.getVoltage(DS2438_CHB), 2)); } } oneWireCnt++; } else { oneWireCnt = 0; oneWireState++; } break; case 2: if (!oneWireSubTimer.isOver()) { return; } if ((oneWireCnt < DS18B20count)){ dsconvertcommand(ds,sensors18B20[oneWireCnt]); oneWireCnt++; } else { oneWireCnt = 0; oneWireState++; } break; case 3: if (!oneWireSubTimer.isOver()) { return; } if ((oneWireCnt < DS18B20count)){ if (rtuOn) { Mb.MbData[oneWireDS18B20Byte + oneWireCnt] = dsreadtemp(ds,sensors18B20[oneWireCnt])*100; } else { sendMsg("1w " + oneWireAddressToString(sensors18B20[oneWireCnt]) + " " + String(dsreadtemp(ds,sensors18B20[oneWireCnt]), 2)); } oneWireCnt++; } else { oneWireState = 0; } break; } } void readDigInputs() { int timestamp = millis(); for (int i = 0; i < numOfDigInputs; i++) { int oldValue = inputStatus[i]; int newValue = inputStatusNew[i]; int curValue = digitalRead(inputPins[i]); int byteNo = i/8; int bitPos = i - (byteNo*8); if (oldValue != newValue) { if(newValue != curValue) { inputStatusNew[i] = curValue; } else if(timestamp - inputChangeTimestamp[i] > debouncingTime) { inputStatus[i] = newValue; if(!newValue) { bitWrite(Mb.MbData[byteNo+5], bitPos, 1); sendInputOn(i + 1); } else { bitWrite(Mb.MbData[byteNo+5], bitPos, 0); sendInputOff(i + 1); } } } else { if(oldValue != curValue) { inputStatusNew[i] = curValue; inputChangeTimestamp[i] = timestamp; } } } } void readAnaInputs() { if (!analogTimer.isOver()) { return; } analogTimer.sleep(anaInputCycle); for (int i = 0; i < numOfAnaInputs; i++) { int pin = analogPins[i]; float value = analogRead(pin) * (255 / 1023.0); float oldValue = analogStatus[i]; analogStatus[i] = value; if (value != oldValue) { Mb.MbData[i+8] = (byte) value; sendAnaInput(i+1,Mb.MbData[i+8]); } } } void sendInputOn(int input) { sendMsg(digInputStr + String(input, DEC) + " 1"); } void sendInputOff(int input) { sendMsg(digInputStr + String(input, DEC) + " 0"); } void sendAnaInput(int input, float value) { sendMsg(anaInputStr + String(input, DEC) + " " + String(value, 2)); } void sendMsg(String message) { message = railStr + boardAddressStr + " " + message; message.toCharArray(outputPacketBuffer, outputPacketBufferSize); digitalWrite(ledPins[1],HIGH); if (ethOn) { udpSend.beginPacket(sendIpAddress, remPort); udpSend.write(outputPacketBuffer, message.length()); udpSend.endPacket(); } if (!rtuOn) { digitalWrite(Serial1TxControl, HIGH); Serial1.print(message + "\n"); delay(Serial1TxDelay); digitalWrite(Serial1TxControl, LOW); } digitalWrite(ledPins[1],LOW); dbg("Sending packet: "); dbgln(message); } void setRelay(int relay, int value) { if (relay > numOfRelays) { return; } dbgln("Writing to relay " + String(relay+1) + " value " + String(value)); digitalWrite(relayPins[relay], value); } void setHSSwitch(int hsswitch, int value) { if (hsswitch > numOfHSSwitches) { return; } dbgln("Writing to high side switch" + String(hsswitch+1) + " value " + String(value)); digitalWrite(HSSwitchPins[hsswitch], value); } void setLSSwitch(int lsswitch, int value) { if (lsswitch > numOfLSSwitches) { return; } dbgln("Writing to low side switch" + String(lsswitch+1) + " value " + String(value)); digitalWrite(LSSwitchPins[lsswitch], value); } void setAnaOut(int pwm, int value) { if (pwm > numOfAnaOuts) { return; } dbgln("Writing to analog output " + String(pwm+1) + " value " + String(value)); analogWrite(anaOutPins[pwm], value); } boolean receivePacket(String *cmd) { if (!rtuOn) { while (Serial1.available() > 0) { *cmd = Serial1.readStringUntil('\n'); if (cmd->startsWith(boardAddressRailStr)) { cmd->replace(boardAddressRailStr, ""); cmd->trim(); return true; } } } if (ethOn) { int packetSize = udpRecv.parsePacket(); if (packetSize) { memset(inputPacketBuffer, 0, sizeof(inputPacketBuffer)); udpRecv.read(inputPacketBuffer, inputPacketBufferSize); *cmd = String(inputPacketBuffer); if (cmd->startsWith(boardAddressRailStr)) { cmd->replace(boardAddressRailStr, ""); cmd->trim(); return true; } } } return false; } void processCommands() { String cmd; byte byteNo, curBitValue, bitPos; int curAnaVal; for (int i = 0; i < numOfRelays; i++) { if (i<8) { setRelay(i, bitRead(Mb.MbData[relOut1Byte],i)); } else { setRelay(i, bitRead(Mb.MbData[relOut2Byte],i-8)); } } for (int i = 0; i < numOfHSSwitches; i++) { setHSSwitch(i, bitRead(Mb.MbData[hssLssByte],i)); } for (int i = 0; i < numOfLSSwitches; i++) { setLSSwitch(i, bitRead(Mb.MbData[hssLssByte],i+numOfHSSwitches)); } for (int i = 0; i < numOfAnaOuts; i++) { setAnaOut(i, Mb.MbData[anaOut1Byte+i]); } if (bitRead(Mb.MbData[serviceByte],0)) { resetFunc(); } if (receivePacket(&cmd)) { dbg("Received packet: ") dbgln(cmd); digitalWrite(ledPins[1],HIGH); if (cmd.startsWith(relayStr)) { for (int i = 0; i < numOfRelays; i++) { if (i<8) {byteNo = relOut1Byte; bitPos = i;} else {byteNo = relOut2Byte; bitPos = i-8;} if (cmd == relayOnCommands[i]) { bitWrite(Mb.MbData[byteNo],bitPos,1); } else if (cmd == relayOffCommands[i]) { bitWrite(Mb.MbData[byteNo],bitPos,0); } } } else if (cmd.startsWith(HSSwitchStr)) { for (int i = 0; i < numOfHSSwitches; i++) { if (cmd == HSSwitchOnCommands[i]) { bitWrite(Mb.MbData[hssLssByte],i,1); } else if (cmd == HSSwitchOffCommands[i]) { bitWrite(Mb.MbData[hssLssByte],i,0); } } } else if (cmd.startsWith(LSSwitchStr)) { for (int i = 0; i < numOfLSSwitches; i++) { if (cmd == LSSwitchOnCommands[i]) { bitWrite(Mb.MbData[hssLssByte],i + numOfHSSwitches,1); } else if (cmd == LSSwitchOffCommands[i]) { bitWrite(Mb.MbData[hssLssByte],i + numOfHSSwitches,0); } } } else if (cmd.startsWith(anaOutStr)) { String anaOutValue = cmd.substring(anaOutStr.length() + 2); for (int i = 0; i < numOfAnaOuts; i++) { if (cmd.substring(0,anaOutStr.length()+1) == anaOutCommand[i]) { Mb.MbData[anaOut1Byte+i] = anaOutValue.toInt(); } } } else if (cmd.startsWith(rstStr)) { bitWrite(Mb.MbData[serviceByte],0,1); } digitalWrite(ledPins[1],LOW); } }
