*PADS-LOGIC-V9.0* DESIGN EXPORT FILE FROM PADS LOGIC V9.4 *SCH* GENERAL PARAMETERS OF THE SCHEMATIC DESIGN" CUR SHEET 0 Current Active Sheet USERGRID 100 10 Design and Label/Text grid settings LINEWIDTH 10 Width items will be created with CONNWIDTH 10 Width used to plot connections BUSWIDTH 25 Width used to plot buses BUSANGLE 25 Angle used when plotting buses NNVISPWRGND 4 Pwr/Gnd netname visibility default flag PCBFLAGS 10399 PCB Netlist and ECO options PINNAMESIZE 100 10 Height and LineWidth used by pin names TEXTSIZE 139 10 Height and LineWidth text will be created width JOBTIME 0 Amount of time spent on this LOGIC design DOTGRID 100 Space in thous/inch between graphic dots BACKUPTIME 5 Number of minutes between database backups TIEDOTSIZE 25 Diameter of tiedot point REFNAMESIZE 100 10 Height and LineWidth used by part ref. names PARTNAMESIZE 100 10 Height and LineWidth used by part type names PINNOSIZE 100 10 Height and LineWidth used by pin numbers NETNAMESIZE 100 10 Height and LineWidth used by net names REAL WIDTH 20 Widths greater then this are displayed real size SHEET SIZE B UNITS 0 Rules units type JOBNAME WCU_Kilobot_Schematic.sch NTXCOL 11 9 HIRCOL 14 LINCOL 14 TXTCOL 11 9 CONCOL 13 BUSCOL 13 PTXCOL 11 9 COMCOL 11 NMCOL 11 9 PNMCOL 11 9 PINCOL 11 9 NETCOL 11 9 FBGCOL 15 0 OFFREFVIEW 0 Offsheet references visibility default flag OFFREFNUM 0 Offsheet references per line SHEETNUMSEP [] Sheet Number separators FONT MODE System DEFAULT FONT "Regular Verdana" BORDER NAME SIZEB FIELDCOL 10 2 *CAM* PLOTTER SETTINGS *MISC* MISCELLANEOUS PARAMETERS *REMARK* PARENT_KEYWORD PARENT_VALUE *REMARK* [ { *REMARK* CHILD_KEYWORD CHILD_VALUE *REMARK* [ CHILD_KEYWORD CHILD_VALUE *REMARK* [ { *REMARK* GRAND_CHILD_KEYWORD GRAND_CHILD_VALUE [...] *REMARK* } ]] *REMARK* } ] LAYER MILS { LAYER 0 { LAYER_THICKNESS 0 DIELECTRIC 3.300000 } LAYER 1 { LAYER_NAME Top LAYER_TYPE ROUTING PLANE NONE ROUTING_DIRECTION HORIZONTAL ASSOCIATED_SILK_SCREEN Silkscreen Top ASSOCIATED_PASTE_MASK Paste Mask Top ASSOCIATED_SOLDER_MASK Solder Mask Top ASSOCIATED_ASSEMBLY Assembly Drawing Top COMPONENT Y ROUTABLE Y VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 10 COPPER_THICKNESS 1.35 DIELECTRIC 4.300000 COST 0 } LAYER 2 { LAYER_NAME Bottom LAYER_TYPE ROUTING PLANE NONE ROUTING_DIRECTION VERTICAL ASSOCIATED_SILK_SCREEN Silkscreen Bottom ASSOCIATED_PASTE_MASK Paste Mask Bottom ASSOCIATED_SOLDER_MASK Solder Mask Bottom ASSOCIATED_ASSEMBLY Assembly Drawing Bottom COMPONENT Y ROUTABLE Y VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 1.35 DIELECTRIC 3.300000 COST 0 } LAYER 3 { LAYER_NAME Layer_3 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 4 { LAYER_NAME Layer_4 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 5 { LAYER_NAME Layer_5 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 6 { LAYER_NAME Layer_6 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 7 { LAYER_NAME Layer_7 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 8 { LAYER_NAME Layer_8 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 9 { LAYER_NAME Layer_9 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 10 { LAYER_NAME Layer_10 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 11 { LAYER_NAME Layer_11 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 12 { LAYER_NAME Layer_12 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 13 { LAYER_NAME Layer_13 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 14 { LAYER_NAME Layer_14 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 15 { LAYER_NAME Layer_15 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 16 { LAYER_NAME Layer_16 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 17 { LAYER_NAME Layer_17 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 18 { LAYER_NAME Layer_18 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 19 { LAYER_NAME Layer_19 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 20 { LAYER_NAME Layer_20 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 21 { LAYER_NAME Solder Mask Top LAYER_TYPE SOLDER_MASK PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 22 { LAYER_NAME Paste Mask Bottom LAYER_TYPE PASTE_MASK PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 23 { LAYER_NAME Paste Mask Top LAYER_TYPE PASTE_MASK PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 24 { LAYER_NAME Drill Drawing LAYER_TYPE DRILL PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 25 { LAYER_NAME Layer_25 LAYER_TYPE UNASSIGNED PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 26 { LAYER_NAME Silkscreen Top LAYER_TYPE SILK_SCREEN PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 27 { LAYER_NAME Assembly Drawing Top LAYER_TYPE ASSEMBLY PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 28 { LAYER_NAME Solder Mask Bottom LAYER_TYPE SOLDER_MASK PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 29 { LAYER_NAME Silkscreen Bottom LAYER_TYPE SILK_SCREEN PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } LAYER 30 { LAYER_NAME Assembly Drawing Bottom LAYER_TYPE ASSEMBLY PLANE NONE ROUTING_DIRECTION NO_PREFERENCE VISIBLE Y SELECTABLE Y ENABLED Y LAYER_THICKNESS 0 COPPER_THICKNESS 0 DIELECTRIC 0.000000 COST 0 } } *REMARK* PARENT_KEYWORD PARENT_VALUE *REMARK* [ { *REMARK* CHILD_KEYWORD CHILD_VALUE *REMARK* [ CHILD_KEYWORD CHILD_VALUE *REMARK* [ { *REMARK* GRAND_CHILD_KEYWORD GRAND_CHILD_VALUE [...] *REMARK* } ]] *REMARK* } ] RULES_SECTION MILS { NET_CLASS DATA DESIGN RULES { RULE_SET (1) { FOR : { DEFAULT : } AGAINST : { DEFAULT : } LAYER 0 CLEARANCE_RULE : { TRACK_TO_TRACK 6 VIA_TO_TRACK 6 VIA_TO_VIA 6 PAD_TO_TRACK 6 PAD_TO_VIA 6 PAD_TO_PAD 6 SMD_TO_TRACK 6 SMD_TO_VIA 6 SMD_TO_PAD 6 SMD_TO_SMD 6 COPPER_TO_TRACK 6 COPPER_TO_VIA 6 COPPER_TO_PAD 6 COPPER_TO_SMD 6 COPPER_TO_COPPER 6 TEXT_TO_TRACK 6 TEXT_TO_VIA 6 TEXT_TO_PAD 6 TEXT_TO_SMD 6 OUTLINE_TO_TRACK 6 OUTLINE_TO_VIA 6 OUTLINE_TO_PAD 6 OUTLINE_TO_SMD 6 OUTLINE_TO_COPPER 6 DRILL_TO_TRACK 6 DRILL_TO_VIA 6 DRILL_TO_PAD 6 DRILL_TO_SMD 6 DRILL_TO_COPPER 6 SAME_NET_SMD_TO_VIA 6 SAME_NET_SMD_TO_CRN 6 SAME_NET_VIA_TO_VIA 6 SAME_NET_PAD_TO_CRN 6 MIN_TRACK_WIDTH 6 REC_TRACK_WIDTH 6 MAX_TRACK_WIDTH 6 DRILL_TO_DRILL 6 BODY_TO_BODY 6 SAME_NET_TRACK_TO_CRN 6 } } RULE_SET (2) { FOR : { DEFAULT : } AGAINST : { DEFAULT : } LAYER 0 ROUTE_RULE : { LENGTH_MINIMIZATION_TYPE 1 TRACE_SHARE Y VIA_SHARE Y AUTO_ROUTE Y RIPUP Y SHOVE Y ROUTE_PRIORITY 3 MAX_NUMBER_OF_VIAS -1 VALID_LAYER 1 VALID_LAYER 2 VALID_VIA_TYPE *USE_CURRENT* } } RULE_SET (3) { FOR : { DEFAULT : } AGAINST : { DEFAULT : } LAYER 0 HIGH_SPEED_RULE : { MIN_LENGTH 0 MAX_LENGTH 50000 STUB_LENGTH 0 PARALLEL_LENGTH 1000 PARALLEL_GAP 200 TANDEM_LENGTH 1000 TANDEM_GAP 200 MIN_DELAY 0.000000 MAX_DELAY 10.000000 MIN_CAPACITANCE 0.000000 MAX_CAPACITANCE 10.000000 MIN_IMPEDANCE 50.000000 MAX_IMPEDANCE 150.000000 SHIELD_NET * SHIELD_GAP 200 MATCH_LENGTH_TOLERANCE 200 } } } } *FIELDS* USER FIELDS "Drawn By" NATHAN THOMAS "Checked By" NATHAN THOMAS "QC By" "Released By" "Drawn Date" 1-26-16 "Checked Date" 2-8-16 "QC Date" "Release Date" "Company Name" WESTERN CAROLINA UNIVERSITY "Title" KILOBOT "Code" "Drawing Number" 1 "Revision" 1.0 "Scale" *SHT* 1 POWER,MOTOR,RX -1 $$$NONE *CAE* GENERAL PARAMETERS FOR THE SHEET" SCALE 4.140 Scale of window expansion WINDOWCENTER 3929 2779 Point defining the center of the window BITCS0 0 system status bits BITCS1 0 system status bits BITCS2 0 system status bits *TEXT* FREE TEXT 1760 8750 0 0 139 10 0 "Default Font" Power 3140 8730 0 0 139 10 0 "Default Font" Debug 1530 7460 0 0 139 10 0 "Default Font" LEG 1 1560 6940 0 0 139 10 0 "Default Font" LEG 2 1560 6450 0 0 139 10 0 "Default Font" LEG 3 2700 4600 0 0 139 10 0 "Default Font" Infared RX 11300 8800 0 0 139 10 0 "Default Font" Motor Controls 24950 33600 0 0 97 10 0 "Default Font" SHEET NAME: 25680 33630 0 8 153 10 1 "Default Font" Sheet Name 26650 32600 0 0 97 10 0 "Default Font" SHEET NAME: 27380 32630 0 8 153 10 1 "Default Font" Sheet Name 27240 30900 0 0 100 10 0 "Default Font" TITLE: 19140 17800 0 0 100 10 0 "Default Font" TITLE: 19340 16100 0 0 100 10 0 "Default Font" TITLE: 11730 590 0 0 97 10 1 "Default Font" Sheet Name 28400 31800 0 0 100 10 0 "Default Font" SIZE: 11060 610 0 0 97 10 0 "Default Font" SHEET NAME: 3660 7650 0 0 139 10 0 "Default Font" Charging Circuit 8160 9650 0 0 139 10 0 "Default Font" 3V Regulators *LINES* LINES ITEMS SIZEB LINES 16000 1700 34 40 OPEN 2 10 255 0 0 -5010 0 OPEN 2 10 255 -500 0 -500 -950 OPEN 2 10 255 -1800 -950 -1800 -1200 OPEN 2 10 255 -3100 0 -3100 -950 OPEN 2 10 255 -3800 0 -3800 -950 OPEN 2 10 255 0 -950 -5000 -950 OPEN 2 10 255 -5000 1290 -5000 -1200 OPEN 2 10 255 0 800 -5000 800 OPEN 2 10 255 -5000 -400 -7500 -400 CLOSED 7 10 255 0 -1200 0 1290 -5000 1290 -5000 400 -7500 400 -7500 -1200 0 -1200 OPEN 2 10 255 -5010 0 -7500 0 OPEN 2 10 255 -5000 -800 -7500 -800 OPEN 2 10 255 -6000 400 -6000 -1200 OPEN 2 10 255 502 1150 2 1150 OPEN 2 10 255 500 3550 0 3550 OPEN 2 10 255 500 5900 0 5900 OPEN 2 10 255 -2864 8100 -2864 7100 OPEN 2 10 255 -464 8100 -464 7100 OPEN 2 10 255 -1364 8100 -1364 7100 OPEN 2 10 255 -2800 8800 -2800 8300 OPEN 2 10 255 -5300 8800 -5300 8300 OPEN 2 10 255 -7800 8800 -7800 8300 OPEN 2 10 255 -10300 8800 -10300 8300 OPEN 2 10 255 -12800 8800 -12800 8300 OPEN 2 10 255 -15000 5900 -15500 5900 OPEN 2 10 255 -15000 1150 -15500 1150 OPEN 2 10 255 -15000 3550 -15500 3550 OPEN 5 10 255 0 -1200 0 8300 -15000 8300 -15000 -1200 0 -1200 OPEN 2 10 255 -3450 8100 0 8100 OPEN 2 10 255 -3450 7900 0 7900 OPEN 2 10 255 -3450 7500 0 7500 OPEN 2 10 255 -3450 7300 0 7300 CLOSED 5 10 255 0 8300 -3450 8300 -3450 7100 0 7100 0 8300 OPEN 2 10 255 -3450 7700 0 7700 -6000 -250 0 8 153 10 1 "Default Font" Checked Date -2000 -600 0 12 306 10 1 "Default Font" Drawing Number -300 -600 0 12 306 10 1 "Default Font" Revision -6000 150 0 8 153 10 1 "Default Font" Drawn Date -6300 -250 0 9 153 10 1 "Default Font" Checked By -6300 150 0 9 153 10 1 "Default Font" Drawn By -2300 400 0 12 250 10 1 "Default Font" Title -2500 1050 0 12 250 10 1 "Default Font" Company Name -3450 -600 0 12 300 10 1 "Default Font" Sheet Size -1350 -1050 0 8 150 10 1 "Default Font" Sheet Number -900 -1050 0 8 150 10 1 "Default Font" Number of Sheets -400 -200 0 0 100 10 0 "Default Font" REV: -3600 -200 0 0 100 10 0 "Default Font" SIZE: -7460 250 0 0 100 10 0 "Default Font" DRAWN: -5960 250 0 0 100 10 0 "Default Font" DATED: -5960 -150 0 0 100 10 0 "Default Font" DATED: -7460 -150 0 0 100 10 0 "Default Font" CHECKED: -4960 1100 0 0 100 10 0 "Default Font" COMPANY: -4960 600 0 0 100 10 0 "Default Font" TITLE: -2150 -200 0 0 100 10 0 "Default Font" DRAWING NO: -1750 -1100 0 0 100 10 0 "Default Font" SHEET: OF -2200 8150 0 0 100 10 0 "Default Font" REVISION RECORD -1200 7950 0 0 100 10 0 "Default Font" APPROVED: -2350 7950 0 0 100 10 0 "Default Font" ECO NO: 100 -50 0 0 250 25 0 "Default Font" A 100 2350 0 0 250 25 0 "Default Font" B 100 7100 0 0 250 25 0 "Default Font" D -414 7950 0 0 100 10 0 "Default Font" DATE: -1550 8400 0 0 250 25 0 "Default Font" 1 -4050 8400 0 0 250 25 0 "Default Font" 2 -6550 8400 0 0 250 25 0 "Default Font" 3 -9050 8400 0 0 250 25 0 "Default Font" 4 -11550 8400 0 0 250 25 0 "Default Font" 5 -13900 8400 0 0 250 25 0 "Default Font" 6 -15250 7100 0 0 250 25 0 "Default Font" D -15250 4700 0 0 250 25 0 "Default Font" C -15250 -50 0 0 250 25 0 "Default Font" A -15250 2350 0 0 250 25 0 "Default Font" B 100 4700 0 0 250 25 0 "Default Font" C -3250 7950 0 0 100 10 0 "Default Font" LTR *CAEDECAL* ITEMS PIN 34000 34000 100 10 100 10 4 1 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 140 20 0 1 100 10 "Default Font" REF-DES 230 0 0 8 100 10 "Default Font" PART-TYPE -520 0 0 1 100 10 "Default Font" * -80 0 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 200 0 PINB 34000 34000 100 10 100 10 4 2 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 230 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 140 0 CIRCLE 2 10 255 140 0 190 0 PCLK 33500 33180 100 10 100 10 4 2 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 280 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 200 0 OPEN 3 10 255 200 30 260 0 200 -30 PCLKB 33500 33180 100 10 100 10 4 3 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 280 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 3 10 255 200 30 260 0 200 -30 OPEN 2 10 255 0 0 140 0 CIRCLE 2 10 255 190 0 140 0 PINIEB 34000 34000 100 10 100 10 4 1 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 220 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 4 10 255 0 0 200 0 140 30 140 0 PINORB 34000 34000 100 10 100 10 4 2 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 300 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 180 0 CIRCLE 2 10 255 230 0 180 0 PINSHORT 34000 34000 100 10 100 10 4 1 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 60 10 0 1 100 10 "Default Font" REF-DES 140 10 0 8 100 10 "Default Font" PART-TYPE -530 10 0 1 100 10 "Default Font" * -70 10 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 100 0 PINVRTS 34000 34000 100 10 100 10 4 1 0 0 3 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 20 -80 0 0 100 10 "Default Font" REF-DES -20 -40 0 9 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 2 10 255 0 -100 0 0 CONIN 32000 32000 100 10 100 10 4 3 0 1 30 0 TIMESTAMP 2016.02.26.18.06.05 "Default Font" "Default Font" -400 -30 0 4 100 10 "Default Font" REF-DES -790 -110 0 6 100 10 "Default Font" PART-TYPE -850 100 0 6 100 10 "Default Font" * -850 0 0 6 100 10 "Default Font" * OPEN 2 10 255 -600 100 -600 -100 OPEN 2 10 255 -200 100 -200 -100 OPEN 2 10 255 -200 0 0 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 192 CONOUT 32000 32000 100 10 100 10 4 3 0 1 30 0 TIMESTAMP 2016.02.26.18.06.05 "Default Font" "Default Font" 400 -30 0 4 100 10 "Default Font" REF-DES 780 -110 0 6 100 10 "Default Font" PART-TYPE 840 80 0 6 100 10 "Default Font" * 840 -20 0 6 100 10 "Default Font" * OPEN 2 10 255 200 100 200 -100 OPEN 2 10 255 600 100 600 -100 OPEN 2 10 255 200 0 0 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 192 CONIN1 32000 32000 100 10 100 10 4 2 0 1 30 0 TIMESTAMP 2016.02.26.18.06.05 "Default Font" "Default Font" -540 -30 0 4 100 10 "Default Font" REF-DES -540 -200 0 6 100 10 "Default Font" PART-TYPE -530 -300 0 6 100 10 "Default Font" * -530 -400 0 6 100 10 "Default Font" * OPEN 2 10 255 -200 0 0 0 CLOSED 5 10 255 -300 100 900 -1800 -400 -100 -200 100 -300 -100 -800 -100 2700 -1800 -900 -100 -700 100 -800 100 -300 100 T0 0 0 0 90 -30 0 0 0 0 0 8 P10 200 0 0 0 0 0 0 192 CONOUT1 32000 32000 100 10 100 10 4 2 0 1 30 0 TIMESTAMP 2016.02.26.18.06.05 "Default Font" "Default Font" 550 -30 0 4 100 10 "Default Font" REF-DES 550 -200 0 6 100 10 "Default Font" PART-TYPE 550 -310 0 6 100 10 "Default Font" * 550 -420 0 6 100 10 "Default Font" * OPEN 2 10 255 200 0 0 0 CLOSED 5 10 255 300 100 900 1800 200 -100 400 100 300 -100 800 -100 2700 1800 700 -100 900 100 800 100 300 100 T0 0 0 0 0 0 0 0 0 0 0 8 P-90 200 0 0 0 0 0 0 192 CON_IO 32000 32000 100 10 100 10 4 2 0 1 30 0 TIMESTAMP 2016.02.26.18.06.05 "Default Font" "Default Font" -500 -40 0 4 100 10 "Default Font" REF-DES -500 -190 0 6 100 10 "Default Font" PART-TYPE -500 -300 0 6 100 10 "Default Font" * -500 -400 0 6 100 10 "Default Font" * OPEN 2 10 255 -200 0 0 0 CLOSED 7 10 255 -200 0 -300 -100 -700 -100 -800 0 -700 100 -300 100 -200 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 192 GND 33500 33180 100 10 100 10 4 4 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 100 -50 0 0 100 10 "Default Font" REF-DES 0 200 0 0 100 10 "Default Font" PART-TYPE 0 100 0 0 100 10 "Default Font" * 0 0 0 0 100 10 "Default Font" * OPEN 2 5 255 0 0 0 -100 OPEN 2 5 255 -100 -100 100 -100 OPEN 2 5 255 -60 -160 60 -160 OPEN 2 5 255 -20 -220 20 -220 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 AGND 33500 33180 100 10 100 10 4 1 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 260 0 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 6 5 255 0 0 0 -50 -100 -50 0 -200 100 -50 0 -50 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 CHGND 33500 33180 100 10 100 10 4 5 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 264 -40 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 5 255 0 0 0 -100 OPEN 2 5 255 -100 -100 100 -100 OPEN 2 5 255 -100 -100 -150 -200 OPEN 2 5 255 0 -100 -50 -200 OPEN 2 5 255 100 -100 50 -200 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 REFIN 33500 33180 100 10 100 10 4 1 0 1 24 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" -360 0 0 1 100 10 "Default Font" REF-DES -360 -20 0 3 100 10 "Default Font" PART-TYPE 0 100 0 0 100 10 "Default Font" * 0 0 0 0 100 10 "Default Font" * OPEN 7 5 255 0 0 -100 0 -150 -50 -300 -50 -300 50 -150 50 -100 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 REFOUT 33500 33180 100 10 100 10 4 1 0 1 24 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 350 10 0 0 100 10 "Default Font" REF-DES 350 -10 0 2 100 10 "Default Font" PART-TYPE 0 100 0 0 100 10 "Default Font" * 0 0 0 0 100 10 "Default Font" * OPEN 8 5 255 0 0 100 0 100 50 250 50 300 0 250 -50 100 -50 100 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 1025-7 32000 32000 97 10 97 10 2 2 0 2 0 0 TIMESTAMP 2016.02.26.19.16.46 "Default Font" "Default Font" 160 320 0 4 97 10 "Default Font" REF-DES 240 -110 0 6 97 10 "Default Font" PART-TYPE OPEN 2 10 255 -200 100 200 100 OPEN 2 10 255 -100 0 100 0 T0 300 90 2 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T0 -200 90 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 +5V 33500 33180 97 10 97 10 4 2 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 0 250 0 4 100 10 "Default Font" REF-DES 0 200 0 0 100 10 "Default Font" PART-TYPE 0 100 0 0 100 10 "Default Font" * 0 0 0 0 100 10 "Default Font" * OPEN 2 5 255 0 0 0 200 COPCLS 4 5 255 0 200 -50 100 50 100 0 200 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 BUBBLE 33500 33180 97 10 97 10 4 2 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 0 300 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 10 255 0 0 0 100 CIRCLE 2 10 255 0 100 0 200 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 Y 33500 33180 97 10 97 10 4 2 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 0 300 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 3 10 255 0 0 0 100 -100 200 OPEN 2 10 255 0 100 100 200 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 +12V 33500 33274 97 10 97 10 4 2 1 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 4 484 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 5 255 0 0 0 300 COPCLS 4 5 255 0 300 -50 150 50 150 0 300 -108 356 0 0 100 10 +12V T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 -5V 33500 33274 97 10 97 10 4 2 1 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 16 -520 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 5 255 0 0 0 -300 COPCLS 4 5 255 0 -300 50 -150 -50 -150 0 -300 -80 -388 0 0 100 10 -5V T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 -12V 33500 33274 97 10 97 10 4 2 1 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 8 -560 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 5 255 0 0 0 -300 COPCLS 4 5 255 0 -300 50 -150 -50 -150 0 -300 -116 -412 0 0 100 10 -12V T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 +5VA 33500 33274 97 10 97 10 4 2 1 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 8 468 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 10 255 0 0 0 300 COPCLS 4 10 255 0 300 -50 150 50 150 0 300 -108 336 0 0 100 10 +5VA T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 LM3658SD-A/NOPB 32000 32000 97 10 97 10 2 1 0 10 0 0 TIMESTAMP 2016.02.26.18.05.33 "Default Font" "Default Font" -420 330 0 4 97 10 "Default Font" REF-DES -110 -430 0 6 97 10 "Default Font" PART-TYPE CLOSED 5 10 255 -500 -400 -500 300 400 300 400 -400 -500 -400 T-700 200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-700 100 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-700 0 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-700 -200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-700 -300 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 200 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 -100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 -200 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 -300 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 CAP 33800 33180 97 10 97 10 4 4 0 2 26 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 150 -210 0 0 100 10 "Default Font" REF-DES 210 -40 0 2 100 10 "Default Font" PART-TYPE 150 -240 0 2 100 10 "Default Font" VALUE 150 -340 0 2 100 10 "Default Font" * OPEN 2 10 255 0 -200 0 -50 OPEN 2 1 255 -100 -200 100 -200 OPEN 2 1 255 -100 -300 100 -300 OPEN 2 10 255 0 -300 0 -500 T0 0 0 0 20 -90 0 0 -20 -40 0 9 PINVRTS P-110 -140 0 1 0 0 0 0 128 T0 -500 0 2 20 -80 0 0 -20 -40 0 9 PINVRTS P-110 -130 0 1 0 0 0 0 128 CAPA 33930 33180 97 10 97 10 4 4 0 2 26 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 180 -210 0 0 100 10 "Default Font" REF-DES 240 -30 0 2 100 10 "Default Font" PART-TYPE 180 -250 0 2 100 10 "Default Font" VALUE 180 -360 0 2 100 10 "Default Font" * OPEN 2 10 255 0 -200 0 -50 OPEN 2 1 255 -100 -200 100 -200 OPEN 2 1 255 -100 -300 1333 -866 -140 -550 140 -260 100 -300 OPEN 2 10 255 0 -260 0 -500 T0 0 0 0 20 -80 0 0 -20 -40 0 9 PINVRTS P-76 -112 0 1 0 0 0 0 128 T0 -500 0 2 20 -80 0 0 -20 -40 0 9 PINVRTS P-72 -136 0 1 0 0 0 0 128 CAPH 33300 33180 97 10 97 10 4 4 0 2 26 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 250 150 0 4 100 10 "Default Font" REF-DES 250 250 0 4 100 10 "Default Font" PART-TYPE 260 -140 0 6 100 10 "Default Font" VALUE 260 -250 0 6 100 10 "Default Font" * OPEN 2 10 255 100 0 200 0 OPEN 2 10 255 300 0 400 0 OPEN 2 10 255 200 100 200 -100 OPEN 2 10 255 300 100 300 -100 T0 0 0 0 80 20 0 1 170 -30 0 8 PINSHORT P-40 -110 0 1 0 0 0 0 128 T500 0 0 1 80 20 0 1 170 -30 0 8 PINSHORT P-40 -120 0 1 0 0 0 0 128 CAPAH 33100 33280 97 10 97 10 4 4 0 2 26 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 250 150 0 4 100 10 "Default Font" REF-DES 250 250 0 4 100 10 "Default Font" PART-TYPE 250 -150 0 6 100 10 "Default Font" VALUE 250 -250 0 6 100 10 "Default Font" * OPEN 2 10 255 200 100 200 -100 OPEN 2 10 255 300 100 1272 1056 250 -120 500 120 300 -100 OPEN 2 10 255 200 0 100 0 OPEN 2 10 255 250 0 400 0 T0 0 0 0 30 20 0 1 170 -30 0 8 PINSHORT P-28 -104 0 1 0 0 0 0 128 T500 0 0 1 30 20 0 1 170 -30 0 8 PINSHORT P-28 -104 0 1 0 0 0 0 128 RESZ-H 33200 33180 97 10 97 10 4 1 0 2 2 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 300 100 0 4 100 10 "Default Font" REF-DES 310 200 0 4 100 10 "Default Font" PART-TYPE 300 -100 0 6 100 10 "Default Font" VALUE 300 -200 0 6 100 10 "Default Font" * OPEN 10 10 255 100 0 120 0 150 60 210 -60 270 60 330 -60 390 60 450 -60 470 0 500 0 T0 0 0 0 34 16 0 0 170 -30 0 8 PINSHORT P-80 -30 0 1 0 0 0 0 128 T600 0 0 1 0 20 0 0 170 -30 0 8 PINSHORT P-90 -20 0 1 0 0 0 0 128 RESZ-V 33500 33480 97 10 97 10 4 1 0 2 2 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 100 -280 0 0 100 10 "Default Font" REF-DES 100 -180 0 0 100 10 "Default Font" PART-TYPE 100 -320 0 2 100 10 "Default Font" VALUE 100 -420 0 2 100 10 "Default Font" * OPEN 10 10 255 0 -500 0 -480 -60 -450 60 -390 -60 -330 60 -270 -60 -210 60 -150 0 -130 0 -100 T0 0 0 0 20 -80 0 0 -20 -40 0 9 PINVRTS P840 80 0 1 0 0 0 0 128 T0 -600 0 2 20 -80 0 0 -20 -40 0 9 PINVRTS P840 40 0 1 0 0 0 0 128 RESB-H 33200 33180 97 10 97 10 4 2 0 2 2 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 300 80 0 4 100 10 "Default Font" REF-DES 300 180 0 4 100 10 "Default Font" PART-TYPE 310 -120 0 12 100 10 "Default Font" VALUE 300 -80 0 6 100 10 "Default Font" * OPEN 7 10 255 100 0 150 0 150 50 450 50 450 -50 150 -50 150 0 OPEN 2 10 255 450 0 500 0 T0 0 0 0 34 16 0 0 170 -30 0 8 PINSHORT P-160 0 0 1 0 0 0 0 128 T600 0 0 1 34 16 0 0 170 -30 0 8 PINSHORT P-160 0 0 1 0 0 0 0 128 RESB-V 33500 32630 97 10 97 10 4 2 0 2 2 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 140 -260 0 0 100 10 "Default Font" REF-DES 210 -80 0 2 100 10 "Default Font" PART-TYPE 140 -290 0 2 100 10 "Default Font" VALUE 180 -400 0 2 100 10 "Default Font" * OPEN 7 10 255 0 -460 0 -410 -50 -410 -50 -110 50 -110 50 -410 0 -410 OPEN 2 10 255 0 -110 0 -60 T0 0 90 2 90 -30 90 2 170 -30 0 8 PINSHORT P-10 -190 90 2 0 0 0 0 128 T0 -500 90 0 80 -30 90 2 170 -30 0 8 PINSHORT P-10 -160 90 2 0 0 0 0 128 SCH_DIO-H 32000 32000 97 10 97 10 4 6 0 2 26 0 TIMESTAMP 2016.02.26.19.21.34 "Default Font" "Default Font" 250 150 0 4 100 10 "Default Font" REF-DES 250 250 0 4 100 10 "Default Font" PART-TYPE 250 -150 0 6 100 10 "Default Font" * 250 -250 0 6 100 10 "Default Font" * COPCLS 4 15 255 180 80 180 -80 340 0 180 80 OPEN 2 10 255 180 0 100 0 OPEN 2 15 255 340 80 340 -80 OPEN 2 10 255 400 0 340 0 OPEN 3 10 255 340 80 310 80 310 60 OPEN 3 10 255 340 -80 370 -80 370 -60 T500 0 0 1 70 20 0 1 170 -30 0 8 PINSHORT P-500 10 0 1 -70 10 0 1 0 T0 0 0 0 70 20 0 1 170 -30 0 8 PINSHORT P-500 10 0 1 -70 10 0 1 0 SCH_DIO-V 32000 32000 97 10 97 10 4 6 0 2 26 0 TIMESTAMP 2016.02.26.19.21.34 "Default Font" "Default Font" 150 -220 0 0 100 10 "Default Font" REF-DES 150 -130 0 0 100 10 "Default Font" PART-TYPE 150 -240 0 2 100 10 "Default Font" * 150 -330 0 2 100 10 "Default Font" * OPEN 2 15 255 -80 -160 80 -160 OPEN 2 10 255 0 -100 0 -160 COPCLS 4 15 255 -80 -320 80 -320 0 -160 -80 -320 OPEN 2 10 255 0 -320 0 -400 OPEN 3 10 255 -80 -160 -80 -190 -60 -190 OPEN 3 10 255 80 -160 80 -130 60 -130 T0 0 0 1 20 -80 0 0 -20 -40 0 9 PINVRTS P-500 10 0 1 -30 14 0 1 0 T0 -500 0 3 20 -80 0 0 -20 -40 0 9 PINVRTS P-500 10 0 1 -30 14 0 1 0 XC6210B302MR-G 32000 32000 97 10 97 10 2 1 0 5 0 0 TIMESTAMP 2016.02.26.17.51.53 "Default Font" "Default Font" -310 320 0 4 97 10 "Default Font" REF-DES -170 -350 0 6 97 10 "Default Font" PART-TYPE CLOSED 5 10 255 -400 -300 -400 300 400 300 400 -300 -400 -300 T-600 200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-600 0 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-600 -200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 -100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 MOTOR 32000 32000 97 10 97 10 2 3 2 2 0 0 TIMESTAMP 2016.02.26.19.22.31 "Default Font" "Default Font" 210 110 0 4 97 10 "Default Font" REF-DES 360 -120 0 6 97 10 "Default Font" PART-TYPE CIRCLE 2 10 255 0 -100 0 100 COPCLS 5 10 255 100 100 100 200 -100 200 -100 100 100 100 COPCLS 5 10 255 100 -200 100 -100 -100 -100 -100 -200 100 -200 -10 -90 0 0 69 10 - -20 40 0 0 69 10 + T0 -400 90 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T0 400 90 3 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 NPN-V 32000 32000 100 10 100 10 4 6 0 3 0 0 TIMESTAMP 2016.02.26.19.17.50 "Default Font" "Default Font" 590 60 0 0 100 10 "Default Font" REF-DES 640 180 0 0 100 10 "Default Font" PART-TYPE 590 20 0 2 100 10 "Default Font" PART NUMBER 590 -100 0 2 100 10 "Default Font" * CIRCLE 2 20 255 100 0 532 0 OPEN 2 10 255 200 50 400 200 OPEN 2 25 255 200 100 200 -100 OPEN 2 10 255 200 0 100 0 OPEN 2 10 255 200 -50 400 -200 COPCLS 4 10 255 260 -134 302 -90 324 -144 260 -134 T400 -300 0 3 -20 -80 0 1 -20 -40 0 9 PINVRTS P1030 100 0 1 0 0 0 0 128 T0 0 0 0 70 20 0 1 170 -30 0 8 PINSHORT P-10 -110 0 1 0 0 0 0 128 T400 300 0 1 -20 -80 0 1 -20 -40 0 9 PINVRTS P200 0 0 0 0 0 0 0 128 NPN-VA 32000 32000 100 10 100 10 4 6 0 3 0 0 TIMESTAMP 2016.02.26.19.17.50 "Default Font" "Default Font" -660 90 0 1 100 10 "Default Font" REF-DES -900 200 0 0 100 10 "Default Font" PART-TYPE -660 40 0 3 100 10 "Default Font" PART NUMBER -950 -80 0 2 100 10 "Default Font" * CIRCLE 2 20 255 -600 0 -150 0 OPEN 2 10 255 -500 -200 -300 -50 OPEN 2 25 255 -300 100 -300 -100 OPEN 2 10 255 -200 0 -300 0 OPEN 2 10 255 -500 200 -300 50 COPCLS 4 10 255 -360 -134 -402 -90 -424 -144 -360 -134 T-500 -300 0 3 140 -90 0 1 -20 -40 0 9 PINVRTS P-310 10 0 1 0 0 0 0 128 T-500 300 0 1 140 -80 0 1 -20 -40 0 9 PINVRTS P-1140 20 0 0 0 0 0 0 128 T0 0 0 1 88 40 0 1 230 0 0 8 PIN P-500 10 0 1 0 0 0 0 128 NPN-H 32000 32000 100 10 100 10 4 6 0 3 0 0 TIMESTAMP 2016.02.26.19.17.50 "Default Font" "Default Font" -530 160 0 0 100 10 "Default Font" REF-DES 270 290 0 0 100 10 "Default Font" PART-TYPE -530 40 0 0 100 10 "Default Font" PART NUMBER 250 230 0 2 100 10 "Default Font" * OPEN 2 10 255 0 200 0 100 OPEN 2 10 255 50 200 200 400 OPEN 2 25 255 -100 200 100 200 COPCLS 4 10 255 134 260 90 302 144 324 134 260 OPEN 2 10 255 -50 200 -200 400 CIRCLE 2 20 255 0 100 0 532 T300 400 0 1 80 16 0 1 170 -30 0 8 PINSHORT P-30 -110 0 1 0 0 0 0 128 T0 0 0 2 20 -80 0 0 -20 -40 0 9 PINVRTS P-10 30 0 1 0 0 0 0 128 T-300 400 0 0 70 16 0 1 170 -30 0 8 PINSHORT P30 -120 0 1 0 0 0 0 128 NPN-HA 32000 32000 100 10 100 10 4 6 0 3 0 0 TIMESTAMP 2016.02.26.19.17.50 "Default Font" "Default Font" -270 -160 0 1 100 10 "Default Font" REF-DES 300 -180 0 0 100 10 "Default Font" PART-TYPE -430 -240 0 12 100 10 "Default Font" PART NUMBER 300 -230 0 2 100 10 "Default Font" * OPEN 2 25 255 100 -200 -100 -200 OPEN 2 10 255 0 -200 0 -100 OPEN 2 10 255 50 -200 200 -400 OPEN 2 10 255 -50 -200 -200 -400 COPCLS 4 10 255 -134 -260 -90 -302 -144 -324 -134 -260 CIRCLE 2 20 255 0 -100 0 -532 T-300 -400 0 2 80 14 0 1 170 -30 0 8 PINSHORT P60 120 0 1 0 0 0 0 128 T0 0 0 1 20 -80 0 0 -20 -40 0 9 PINVRTS P60 120 0 1 0 0 0 0 128 T300 -400 0 3 80 14 0 1 170 -30 0 8 PINSHORT P90 160 0 1 0 0 0 0 128 OPAMP 32000 32000 97 10 97 10 4 1 2 3 0 0 TIMESTAMP 2016.02.26.19.21.13 "Default Font" "Default Font" 366 -132 0 4 100 10 "Default Font" REF-DES 700 -200 0 6 100 10 "Default Font" PART-TYPE 700 -300 0 6 100 10 "Default Font" * 700 -400 0 6 100 10 "Default Font" * CLOSED 4 10 255 200 102 200 -298 600 -98 200 102 220 -30 0 0 100 10 - 220 -232 0 0 100 10 + T0 0 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 0 0 0 0 128 T0 -200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 0 0 0 0 128 T800 -100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 0 0 0 0 128 IR_RX 32000 32000 100 10 100 10 2 8 0 2 0 0 TIMESTAMP 2016.02.26.19.22.55 "Default Font" "Default Font" 100 200 0 4 100 10 "Default Font" REF-DES 250 -150 0 6 100 10 "Default Font" PART-TYPE OPEN 2 10 255 90 0 390 0 OPEN 2 10 255 340 90 340 -90 COPCLS 4 10 255 190 0 190 -90 340 0 190 0 COPCLS 4 10 255 190 0 190 90 340 0 190 0 OPEN 2 10 255 250 150 350 250 COPCLS 5 10 255 250 150 270 210 310 180 320 170 250 150 OPEN 2 10 255 350 150 450 250 COPCLS 5 10 255 340 140 360 200 400 170 410 160 340 140 T500 0 0 1 130 14 0 1 170 -30 0 8 PINSHORT P-500 10 0 1 -70 10 0 1 0 T0 0 0 0 130 14 0 1 170 -30 0 8 PINSHORT P-500 10 0 1 -70 10 0 1 0 XC6221B302MR-G 32000 32000 97 10 97 10 2 1 0 5 0 0 TIMESTAMP 2016.02.26.18.04.35 "Default Font" "Default Font" -310 320 0 4 97 10 "Default Font" REF-DES -170 -350 0 6 97 10 "Default Font" PART-TYPE CLOSED 5 10 255 -400 -300 -400 300 400 300 400 -300 -400 -300 T-600 200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-600 0 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-600 -200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T600 -100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 *PARTTYPE* ITEMS HEADER02 CON 0 0 1 0 TIMESTAMP 1999.03.30.22.52.06 CONN 5 2 CONIN S CONOUT L CONIN1 S CONOUT1 L CON_IO Z 1 0 U 2 0 U $GND_SYMS UND 0 0 2 0 TIMESTAMP 1999.03.30.22.52.06 GND 3 GND G GND AGND G AGND CHGND G CHGND $OSR_SYMS UND 0 0 2 0 TIMESTAMP 1999.03.30.22.52.06 OFF 2 REFIN S REFOUT L 1025-7 UND 1 0 0 0 TIMESTAMP 2016.02.26.19.16.46 GATE 1 2 0 1025-7 1 0 U 2 0 U $PWR_SYMS UND 0 0 2 0 TIMESTAMP 1999.03.30.22.52.06 PWR 7 +5V P +5V BUBBLE P +5V Y P +5V +12V P +12V -5V P -5V -12V P -12V +5VA P +5VA LM3658SD-A/NOPB UND 1 1 0 0 TIMESTAMP 2016.02.26.18.05.33 GATE 1 10 0 LM3658SD-A/NOPB 1 0 U CHG_IN 4 0 U USB_SEL 2 0 U USBPWR 3 0 U GND 5 0 U EN_B 10 0 U BATT 7 0 U STAT1 9 0 U TS 8 0 U ISET 6 0 U STAT2 SIGPIN 11 GND HEADER01 CON 0 0 1 0 TIMESTAMP 2016.02.26.18.06.05 CONN 5 1 CONIN S CONOUT L CONIN1 S CONOUT1 L CON_IO Z 1 0 U CAP-CC05 CAP 1 0 0 0 TIMESTAMP 2004.12.22.19.44.43 GATE 4 2 0 CAP CAPA CAPH CAPAH 1 1 U 2 1 U RES-1/8W RES 1 0 0 0 TIMESTAMP 2004.12.22.19.44.43 GATE 4 2 1 RESZ-H RESZ-V RESB-H RESB-V 1 1 U 2 1 U SCHOTTKY_DIODE DIO 1 0 0 2 TIMESTAMP 2016.02.26.19.21.34 GATE 2 2 1 SCH_DIO-H SCH_DIO-V K 0 U A 0 U K A XC6210B302MR-G UND 1 0 0 0 TIMESTAMP 2016.02.26.17.51.53 GATE 1 5 0 XC6210B302MR-G 1 0 U VIN 3 0 U CE 2 0 U GND 5 0 U VOUT 4 0 U CB MOTOR UND 1 0 0 0 TIMESTAMP 2016.02.26.19.22.31 GATE 1 2 0 MOTOR 2 0 U 1 0 U MMBT6428 TRX 1 0 0 3 TIMESTAMP 2016.02.26.19.17.47 GATE 4 3 1 NPN-V NPN-VA NPN-H NPN-HA E 0 U B 0 U C 0 U B E C OPA4376AIPWR ANA 4 2 0 0 TIMESTAMP 2016.02.26.19.21.13 GATE 1 3 1 OPAMP 2 0 L 3 0 L 1 0 S GATE 1 3 1 OPAMP 6 0 L 5 0 L 7 0 S GATE 1 3 1 OPAMP 9 0 L 10 0 L 8 0 S GATE 1 3 1 OPAMP 13 0 L 12 0 L 14 0 S SIGPIN 4 VCC SIGPIN 11 GND TEMD7100X01 DIO 1 0 0 0 TIMESTAMP 2016.02.26.19.22.55 GATE 1 2 0 IR_RX 2 0 U 1 0 U XC6221B302MR-G UND 1 0 0 0 TIMESTAMP 2016.02.26.18.04.33 GATE 1 5 0 XC6221B302MR-G 1 0 U VIN 3 0 U CE 2 0 U GND 5 0 U VOUT 4 0 U CB *PART* ITEMS J1-1 HEADER02 2400 8600 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" TWO PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-2P 0 0 0 0 0 J1-2 HEADER02 2400 8500 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" TWO PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-2P 0 0 0 0 0 J2-1 HEADER02 3800 8600 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" TWO PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-2P 0 0 0 0 0 J2-2 HEADER02 3800 8500 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" TWO PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-2P 0 0 0 0 0 BATT 1025-7 2500 8900 0 0 97 10 97 10 2 6 2 0 0 0 "Default Font" "Default Font" 160 320 0 4 97 10 0 "Default Font" REF-DES 240 -110 0 6 97 10 0 "Default Font" PART-TYPE "PCB DECAL" 1025-7 "Description" Coin Cell Battery Holder "Manufactuer #" 1025-7 "Distributor" Mouser "Distributor #" 534-1025-7 "Designator" BATT 0 140 20 0 1 1 140 20 0 1 U6 LM3658SD-A/NOPB 4500 7100 0 0 97 10 97 10 2 6 10 0 0 0 "Default Font" "Default Font" -420 330 0 4 97 10 0 "Default Font" REF-DES -110 -430 0 6 97 10 0 "Default Font" PART-TYPE "PCB DECAL" 10WSON "Description" IC CHARGER LI-ION USB/AC 10WSON "Distributor" Digikey "Distributor #" LM3658SD-A/NOPBCT-ND "Manufactuer #" LM3658SD-A/NOPB "Designator" U6 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 3 140 20 0 1 4 140 20 0 1 5 140 20 0 1 6 140 20 0 1 7 140 20 0 1 8 140 20 0 1 9 140 20 0 1 J3-1 HEADER01 2100 7300 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" TWO PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" CONN 0 0 0 0 0 J4-1 HEADER01 2100 6800 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" TWO PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" CONN 0 0 0 0 0 J5-1 HEADER01 2100 6300 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" TWO PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" CONN 0 0 0 0 0 C17 CAP-CC05 2900 7200 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 2.2UF 6.3V Y5V 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C17 "Distributor" Digikey "Distributor #" 490-1587-1-ND "Manufactuer #" GRM188F50J225ZE01D 0 20 -90 0 0 1 20 -80 0 0 C19 CAP-CC05 7000 6000 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 2.2UF 6.3V Y5V 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C19 "Distributor" Digikey "Distributor #" 490-1587-1-ND "Manufactuer #" GRM188F50J225ZE01D 0 20 -90 0 0 1 20 -80 0 0 R37 RES-1/8W 5800 7300 90 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 10K OHM 1% 1/10W 0603 "Value" 10K "PCB DECAL" 0603_NOSILK "Designator" R37 "Distributor" Digikey "Distributor #" P10.0KHCT-ND "Manufactuer #" ERJ-3EKF1002V 0 34 16 0 0 1 0 20 0 0 R34 RES-1/8W 5400 7000 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 180 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 400 180 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 10K OHM 1% 1/10W 0603 "Value" 10K "PCB DECAL" 0603_NOSILK "Designator" R34 "Distributor" Digikey "Distributor #" P10.0KHCT-ND "Manufactuer #" ERJ-3EKF1002V 0 34 16 0 0 1 0 20 0 0 R33 RES-1/8W 8000 5200 90 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 10K OHM 1% 1/10W 0603 "Value" 10K "PCB DECAL" 0603_NOSILK "Designator" R33 "Distributor" Digikey "Distributor #" P10.0KHCT-ND "Manufactuer #" ERJ-3EKF1002V 0 34 16 0 0 1 0 20 0 0 R36 RES-1/8W 5400 6700 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 190 110 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 400 180 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 25.5K OHM 1% 1/10W 0603 "Value" 25.5k "PCB DECAL" 0603_NOSILK "Designator" R36 "Distributor" Digikey "Distributor #" P25.5KHCT-ND "Manufactuer #" ERJ-3EKF2552V 0 34 16 0 0 1 0 20 0 0 C18 CAP-CC05 7800 9100 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 2.2UF 6.3V Y5V 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C18 "Distributor" Digikey "Distributor #" 490-1587-1-ND "Manufactuer #" GRM188F50J225ZE01D 0 20 -90 0 0 1 20 -80 0 0 C16 CAP-CC05 7700 7600 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 2.2UF 6.3V Y5V 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Manufactuer #" GRM188F50J225ZE01D "Designator" C16 "Distributor" Digikey "Distributor #" 490-1587-1-ND 0 20 -90 0 0 1 20 -80 0 0 D1 SCHOTTKY_DIODE 2300 7300 0 0 97 10 97 10 4 9 2 0 0 26 "Default Font" "Default Font" 250 150 0 4 100 10 0 "Default Font" REF-DES 250 250 0 4 100 10 0 "Default Font" PART-TYPE 250 -150 0 6 100 10 0 "Default Font" * 250 -250 0 6 100 10 0 "Default Font" * "Description" DIODE SCHOTTKY 30V 100MA 0603 "Sim.Analog.Prefix" D "Sim.Analog.Order" Model$ "Sim.Analog.Model" d1n914 "PCB DECAL" 0603_NOSILK "Designator" D1 "Distributor" Digikey "Distributor #" 641-1282-1-ND "Manufactuer #" CDBU0130L 0 70 20 0 1 1 70 20 0 1 M1 MOTOR 13300 7000 0 0 97 10 97 10 2 5 2 0 0 0 "Default Font" "Default Font" 210 110 0 4 97 10 0 "Default Font" REF-DES 360 -120 0 6 97 10 0 "Default Font" PART-TYPE "PCB DECAL" MOTOR "Description" Vibration Motor "Designator" M1 "Distributor" Pololu "Distributor #" 1638 0 140 20 0 1 1 140 20 0 1 M2 MOTOR 13300 4500 0 0 97 10 97 10 2 5 2 0 0 0 "Default Font" "Default Font" 210 110 0 4 97 10 0 "Default Font" REF-DES 360 -120 0 6 97 10 0 "Default Font" PART-TYPE "PCB DECAL" MOTOR "Description" Vibration Motor "Designator" M1 "Distributor" Pololu "Distributor #" 1638 0 140 20 0 1 1 140 20 0 1 C10 CAP-CC05 10700 8400 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 2.2UF 6.3V Y5V 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C18 "Distributor" Digikey "Distributor #" 490-1587-1-ND "Manufactuer #" GRM188F50J225ZE01D 0 20 -90 0 0 1 20 -80 0 0 C14 CAP-CC05 10700 6000 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 2.2UF 6.3V Y5V 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C18 "Distributor" Digikey "Distributor #" 490-1587-1-ND "Manufactuer #" GRM188F50J225ZE01D 0 20 -90 0 0 1 20 -80 0 0 C7 CAP-CC05 11300 8400 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 10% X7R 0603 "Value" 0.01uf "PCB DECAL" 0603_NOSILK "Designator" C7 "Distributor" Digikey "Distributor #" 490-1520-1-ND "Manufactuer #" GRM188R71E103KA01D 0 20 -90 0 0 1 20 -80 0 0 C13 CAP-CC05 11300 6000 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 10% X7R 0603 "Value" 0.01uf "PCB DECAL" 0603_NOSILK "Designator" C13 "Distributor" Digikey "Distributor #" 490-1520-1-ND "Manufactuer #" GRM188R71E103KA01D 0 20 -90 0 0 1 20 -80 0 0 R17 RES-1/8W 12200 7800 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 200 OHM 1% 1/10W 0603 "Value" 200 "PCB DECAL" 0603_NOSILK "Designator" R17 "Distributor" Digikey "Distributor #" P200HCT-ND "Manufactuer #" ERJ-3EKF2000V 0 34 16 0 0 1 0 20 0 0 R24 RES-1/8W 12200 5300 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 200 OHM 1% 1/10W 0603 "Value" 200 "PCB DECAL" 0603_NOSILK "Designator" R24 "Distributor" Digikey "Distributor #" P200HCT-ND "Manufactuer #" ERJ-3EKF2000V 0 34 16 0 0 1 0 20 0 0 T5 MMBT6428 12900 7800 0 0 100 10 100 10 4 10 3 0 0 2 "Default Font" "Default Font" 590 60 0 0 100 10 0 "Default Font" REF-DES 640 180 0 0 100 10 0 "Default Font" PART-TYPE 590 20 0 2 100 10 3 "Default Font" Part Number 590 -100 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" q2n4030 "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" Q "Description" TRANS NPN 50V 0.5A SOT-23 "Part Number" MMBT6428 "PCB DECAL" SOT23 "Designator" T5 "Distributor" Digikey "Distributor #" MMBT6428CT-ND "Manufactuer #" MMBT6428CT 0 -20 -80 0 1 1 70 20 0 1 2 -20 -80 0 1 T6 MMBT6428 12900 5300 0 0 100 10 100 10 4 10 3 0 0 2 "Default Font" "Default Font" 590 60 0 0 100 10 0 "Default Font" REF-DES 640 180 0 0 100 10 0 "Default Font" PART-TYPE 590 20 0 2 100 10 3 "Default Font" Part Number 590 -100 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" q2n4030 "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" Q "Description" TRANS NPN 50V 0.5A SOT-23 "Part Number" MMBT6428 "PCB DECAL" SOT23 "Designator" T5 "Distributor" Digikey "Distributor #" MMBT6428CT-ND "Manufactuer #" MMBT6428CT 0 -20 -80 0 1 1 70 20 0 1 2 -20 -80 0 1 U2-B OPA4376AIPWR 5600 1900 0 2 97 10 97 10 4 6 3 0 0 0 "Default Font" "Default Font" 366 -132 0 4 100 10 0 "Default Font" REF-DES 700 -200 0 6 100 10 0 "Default Font" PART-TYPE 700 -300 0 6 100 10 0 "Default Font" * 700 -400 0 6 100 10 0 "Default Font" * "Description" IC OPAMP GP 5.5MHZ RRO 14TSSOP "PCB DECAL" TSSOP14 "Designator" U2 "Distributor" Digikey "Distributor #" 296-22565-1-ND "Manufactuer #" OPA4376AIPWR 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 U2-A OPA4376AIPWR 5600 3600 0 2 97 10 97 10 4 6 3 0 0 0 "Default Font" "Default Font" 366 -132 0 4 100 10 0 "Default Font" REF-DES 700 -200 0 6 100 10 0 "Default Font" PART-TYPE 700 -300 0 6 100 10 0 "Default Font" * 700 -400 0 6 100 10 0 "Default Font" * "Description" IC OPAMP GP 5.5MHZ RRO 14TSSOP "PCB DECAL" TSSOP14 "Designator" U2 "Distributor" Digikey "Distributor #" 296-22565-1-ND "Manufactuer #" OPA4376AIPWR 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 U2-C OPA4376AIPWR 2700 1900 0 0 97 10 97 10 4 6 3 0 0 0 "Default Font" "Default Font" 366 -132 0 4 100 10 0 "Default Font" REF-DES 700 -200 0 6 100 10 0 "Default Font" PART-TYPE 700 -300 0 6 100 10 0 "Default Font" * 700 -400 0 6 100 10 0 "Default Font" * "Description" IC OPAMP GP 5.5MHZ RRO 14TSSOP "PCB DECAL" TSSOP14 "Designator" U2 "Distributor" Digikey "Distributor #" 296-22565-1-ND "Manufactuer #" OPA4376AIPWR 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 U2-D OPA4376AIPWR 2700 3900 0 0 97 10 97 10 4 6 3 0 0 0 "Default Font" "Default Font" 366 -132 0 4 100 10 0 "Default Font" REF-DES 700 -200 0 6 100 10 0 "Default Font" PART-TYPE 700 -300 0 6 100 10 0 "Default Font" * 700 -400 0 6 100 10 0 "Default Font" * "Description" IC OPAMP GP 5.5MHZ RRO 14TSSOP "PCB DECAL" TSSOP14 "Designator" U2 "Distributor" Digikey "Distributor #" 296-22565-1-ND "Manufactuer #" OPA4376AIPWR 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 R4 RES-1/8W 2200 3000 90 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 280 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 270 -90 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 549K OHM 1% 1/10W 0603 "Value" 549k "PCB DECAL" 0603_NOSILK "Designator" R4 "Distributor" Digikey "Distributor #" P549KHCT-ND "Manufactuer #" ERJ-3EKF5493V 0 34 16 0 0 1 0 20 0 0 R2 RES-1/8W 4500 3100 90 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 280 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 270 -90 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 5.62K OHM 1% 1/10W 0603 "Value" 5.62k "PCB DECAL" 0603_NOSILK "Designator" R2 "Distributor" Digikey "Distributor #" P5.62KHCT-ND "Manufactuer #" ERJ-3EKF5621V 0 34 16 0 0 1 0 20 0 0 R5 RES-1/8W 5700 3300 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 190 110 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 420 180 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 25.5K OHM 1% 1/10W 0603 "Value" 25.5k "PCB DECAL" 0603_NOSILK "Designator" R5 "Distributor" Digikey "Distributor #" P25.5KHCT-ND "Manufactuer #" ERJ-3EKF2552V 0 34 16 0 0 1 0 20 0 0 R6 RES-1/8W 5500 2500 90 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 420 170 90 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 130 220 90 5 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 2.26K OHM 1% 1/10W 0603 "Value" 2.26k "PCB DECAL" 0603_NOSILK "Designator" R6 "Distributor" Digikey "Distributor #" P2.26KHCT-ND "Manufactuer #" ERJ-3EKF2261V 0 34 16 0 0 1 0 20 0 0 C1 CAP-CC05 4100 1800 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 2.2UF 6.3V Y5V 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C1 "Distributor" Digikey "Distributor #" 490-1587-1-ND "Manufactuer #" GRM188F50J225ZE01D 0 20 -90 0 0 1 20 -80 0 0 C3 CAP-CC05 4600 1800 0 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 10% X7R 0603 "Value" 0.01uf "PCB DECAL" 0603_NOSILK "Designator" C3 "Distributor" Digikey "Distributor #" 490-1520-1-ND "Manufactuer #" GRM188R71E103KA01D 0 20 -90 0 0 1 20 -80 0 0 C2 CAP-CC05 3800 3800 90 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" 230 -300 90 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE -210 -310 90 1 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 1000PF 50V 5% NP0 0603 "Value" 1nf "PCB DECAL" 0603_NOSILK "Designator" C2 "Distributor" Digikey "Distributor #" 490-1451-1-ND "Manufactuer #" GRM1885C1H102JA01D 0 20 -90 0 0 1 20 -80 0 0 C6 CAP-CC05 5900 1400 90 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" -80 -150 90 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE -200 -420 90 1 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 68PF 50V 5% C0G 0603 "Value" 68pf "PCB DECAL" 0603_NOSILK "Designator" C6 "Distributor" Digikey "Distributor #" 445-1279-1-ND "Manufactuer #" C1608C0G1H680J080AA 0 20 -90 0 0 1 20 -80 0 0 C5 CAP-CC05 5700 3100 90 0 97 10 97 10 4 10 2 0 0 26 "Default Font" "Default Font" -120 -120 90 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE -200 -350 90 1 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 68PF 50V 5% C0G 0603 "Value" 68pf "PCB DECAL" 0603_NOSILK "Designator" C5 "Distributor" Digikey "Distributor #" 445-1279-1-ND "Manufactuer #" C1608C0G1H680J080AA 0 20 -90 0 0 1 20 -80 0 0 R10 RES-1/8W 2200 1800 90 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 280 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 270 -90 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 25.5K OHM 1% 1/10W 0603 "Value" 25.5k "PCB DECAL" 0603_NOSILK "Designator" R10 "Distributor" Digikey "Distributor #" P25.5KHCT-ND "Manufactuer #" ERJ-3EKF2552V 0 34 16 0 0 1 0 20 0 0 R8 RES-1/8W 2200 1000 90 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 280 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 270 -90 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 25.5K OHM 1% 1/10W 0603 "Value" 25.5k "PCB DECAL" 0603_NOSILK "Designator" R8 "Distributor" Digikey "Distributor #" P25.5KHCT-ND "Manufactuer #" ERJ-3EKF2552V 0 34 16 0 0 1 0 20 0 0 R9 RES-1/8W 5900 1600 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 180 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 400 190 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 280K OHM 1% 1/10W 0603 "Value" 280k "PCB DECAL" 0603_NOSILK "Designator" R9 "Distributor" Digikey "Distributor #" P280KHCT-ND "Manufactuer #" ERJ-3EKF2803V 0 34 16 0 0 1 0 20 0 0 R7 RES-1/8W 5500 900 90 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 280 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 270 -90 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 499 OHM 1% 1/10W 0603 "Value" 499 "PCB DECAL" 0603_NOSILK "Designator" R7 "Distributor" Digikey "Distributor #" P499HCT-ND "Manufactuer #" ERJ-3EKF4990V 0 34 16 0 0 1 0 20 0 0 RX1 TEMD7100X01 2200 4100 90 0 100 10 100 10 2 8 2 0 0 0 "Default Font" "Default Font" 100 200 0 4 100 10 0 "Default Font" REF-DES 250 -150 0 6 100 10 0 "Default Font" PART-TYPE "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" RX "Description" Photodiodes 60V 215mW 60Deg "PCB DECAL" 0805_NOSILK "Designator" RX1 "Distributor" Mouser "Distributor #" 782-TEMD7100X01 0 130 14 0 1 1 130 14 0 1 U5 XC6210B302MR-G 9000 5900 0 0 97 10 97 10 2 6 5 0 0 0 "Default Font" "Default Font" -310 320 0 4 97 10 0 "Default Font" REF-DES -170 -350 0 6 97 10 0 "Default Font" PART-TYPE "Description" IC REG LDO 3V 0.7A SOT25 "Designator" U4 "Distributor" Digikey "Distributor #" 893-1074-1-ND "Manufactuer #" XC6210B302MR-G "PCB DECAL" SOT25 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 3 140 20 0 1 4 140 20 0 1 U4 XC6210B302MR-G 9000 7500 0 0 97 10 97 10 2 6 5 0 0 0 "Default Font" "Default Font" -310 320 0 4 97 10 0 "Default Font" REF-DES -170 -350 0 6 97 10 0 "Default Font" PART-TYPE "Description" IC REG LDO 3V 0.7A SOT25 "Designator" U4 "Distributor" Digikey "Distributor #" 893-1074-1-ND "Manufactuer #" XC6210B302MR-G "PCB DECAL" SOT25 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 3 140 20 0 1 4 140 20 0 1 U3 XC6221B302MR-G 9000 9000 0 0 97 10 97 10 2 6 5 0 0 0 "Default Font" "Default Font" -310 320 0 4 97 10 0 "Default Font" REF-DES -170 -350 0 6 97 10 0 "Default Font" PART-TYPE "PCB DECAL" SOT25 "Distributor #" 893-1100-1-ND "Description" IC REG LDO 3V 0.2A SOT25 "Designator" U3 "Distributor" Digikey "Manufactuer #" XC6221B302MR-G 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 3 140 20 0 1 4 140 20 0 1 *BUSSES* *OFFPAGE REFS* @@@O0 GND $GND_SYMS 2500 8300 0 0 0 @@@O1 GND $GND_SYMS 3900 8300 0 0 0 @@@O2 DEBUG $OSR_SYMS 3900 8600 0 1 0 @@@O3 VBATT $PWR_SYMS 2500 9400 0 0 0 @@@O4 GND $GND_SYMS 2900 6700 0 0 0 @@@O5 GND $GND_SYMS 3700 6700 0 0 0 @@@O6 VBATT $PWR_SYMS 5200 7500 0 0 0 @@@O7 PD0 $OSR_SYMS 6000 7200 0 1 0 @@@O8 VCC1 $PWR_SYMS 5800 7900 0 0 0 @@@O9 GND $GND_SYMS 6100 6600 0 0 0 @@@O10 CE $OSR_SYMS 7900 5900 0 0 0 @@@O11 GND $GND_SYMS 8000 5200 0 0 0 @@@O12 GND $GND_SYMS 8300 5300 0 0 0 @@@O13 VBATT $PWR_SYMS 7000 6200 0 0 0 @@@O14 GND $GND_SYMS 7000 5400 0 0 0 @@@O15 VCC $PWR_SYMS 9700 6200 0 0 0 @@@O16 VBATT $PWR_SYMS 7800 9300 0 0 0 @@@O17 GND $GND_SYMS 8300 8700 0 0 0 @@@O18 GND $GND_SYMS 7800 8600 0 0 0 @@@O19 VCC1 $PWR_SYMS 9700 9300 0 0 0 @@@O20 CE $OSR_SYMS 8400 7500 0 0 0 @@@O21 VBATT $PWR_SYMS 7700 7800 0 0 0 @@@O22 GND $GND_SYMS 7700 7100 0 0 0 @@@O23 GND $GND_SYMS 8300 7200 0 0 0 @@@O24 VCC2 $PWR_SYMS 9700 7800 0 0 0 @@@O25 VCC2 $PWR_SYMS 10700 8700 0 0 0 @@@O26 VCC2 $PWR_SYMS 10700 6300 0 0 0 @@@O27 GND $GND_SYMS 10700 7700 0 0 0 @@@O28 GND $GND_SYMS 10700 5300 0 0 0 @@@O29 MOSI $OSR_SYMS 12200 7800 0 0 0 @@@O30 GND $GND_SYMS 13300 6600 0 0 0 @@@O31 PD3 $OSR_SYMS 12200 5300 0 0 0 @@@O32 GND $GND_SYMS 13300 4000 0 0 0 @@@O33 GND $GND_SYMS 2200 3000 0 0 0 @@@O34 VCC $PWR_SYMS 2200 4800 0 0 0 @@@O35 GND $GND_SYMS 4500 3100 0 0 0 @@@O36 GND $GND_SYMS 4400 1300 0 0 0 @@@O37 VCC $PWR_SYMS 4400 1800 0 0 0 @@@O38 GND $GND_SYMS 5500 2500 0 0 0 @@@O39 GND $GND_SYMS 5500 900 0 0 0 @@@O40 GND $GND_SYMS 2200 1000 0 0 0 @@@O41 VCC $PWR_SYMS 2200 2400 0 0 0 @@@O42 AMP1_OUT $OSR_SYMS 6600 3700 0 1 0 @@@O43 AMP2_OUT $OSR_SYMS 6600 2000 0 1 0 *TIEDOTS* @@@D0 2200 6800 @@@D1 3700 7300 @@@D2 2900 7300 @@@D3 3700 6800 @@@D4 5800 7200 @@@D5 6100 6700 @@@D6 8000 5900 @@@D7 7000 6100 @@@D8 8300 9200 @@@D9 7800 9200 @@@D10 7700 7700 @@@D11 2200 7300 @@@D12 10700 8500 @@@D13 10700 6100 @@@D14 10700 7800 @@@D15 10700 5400 @@@D16 11300 8500 @@@D17 11300 6100 @@@D18 2200 3700 @@@D19 3600 3800 @@@D20 4400 1300 @@@D21 4400 1800 @@@D22 5700 3100 @@@D23 5500 3100 @@@D24 4500 3800 @@@D25 4900 3800 @@@D26 5900 1600 @@@D27 6500 1600 @@@D28 6300 3100 @@@D29 5500 1600 @@@D30 2200 1700 @@@D31 6500 3700 @@@D32 6600 2000 *CONNECTION* *SIGNAL* GND 2 0 J1.2 @@@O0 3 0 2400 8500 2500 8500 2500 8300 J2.2 @@@O1 3 0 3800 8500 3900 8500 3900 8300 C17.2 @@@O4 2 0 2900 6700 2900 6700 U6.3 @@@D3 3 0 3800 6900 3700 6900 3700 6800 @@@D3 U6.5 2 0 3700 6800 3800 6800 @@@D3 @@@O5 2 0 3700 6800 3700 6700 R34.2 @@@D5 3 0 6000 7000 6100 7000 6100 6700 @@@D5 R36.2 2 0 6100 6700 6000 6700 @@@D5 @@@O9 2 0 6100 6700 6100 6600 R33.1 @@@O11 2 0 8000 5200 8000 5200 U5.2 @@@O12 3 0 8400 5700 8300 5700 8300 5300 C19.2 @@@O14 2 0 7000 5500 7000 5400 U3.2 @@@O17 3 0 8400 8800 8300 8800 8300 8700 C18.2 @@@O18 2 0 7800 8600 7800 8600 C16.2 @@@O22 2 0 7700 7100 7700 7100 U4.2 @@@O23 3 0 8400 7300 8300 7300 8300 7200 C10.2 @@@D14 2 0 10700 7900 10700 7800 C13.2 @@@D15 3 0 11300 5500 11300 5400 10700 5400 @@@D14 C7.2 3 0 10700 7800 11300 7800 11300 7900 @@@D14 @@@O27 2 0 10700 7800 10700 7700 @@@D15 C14.2 2 0 10700 5400 10700 5500 @@@D15 @@@O28 2 0 10700 5400 10700 5300 M1.2 @@@O30 2 0 13300 6600 13300 6600 M2.2 @@@O32 2 0 13300 4100 13300 4000 R4.1 @@@O33 2 0 2200 3000 2200 3000 R2.1 @@@O35 2 0 4500 3100 4500 3100 C1.2 @@@D20 2 0 4100 1300 4400 1300 @@@D20 C3.2 2 0 4400 1300 4600 1300 @@@D20 @@@O36 2 0 4400 1300 4400 1300 R6.1 @@@O38 2 0 5500 2500 5500 2500 R7.1 @@@O39 2 0 5500 900 5500 900 R8.1 @@@O40 2 0 2200 1000 2200 1000 *SIGNAL* $$$15684 64 0 J1.1 BATT.2 3 0 2400 8600 2500 8600 2500 8700 *SIGNAL* DEBUG 0 0 J2.1 @@@O2 2 0 3800 8600 3900 8600 *SIGNAL* VBATT 0 0 BATT.1 @@@O3 2 0 2500 9200 2500 9400 U6.10 @@@O6 3 0 5100 7300 5200 7300 5200 7500 U5.1 @@@D7 2 0 8400 6100 7000 6100 @@@D7 C19.1 2 0 7000 6100 7000 6000 @@@D7 @@@O13 2 0 7000 6100 7000 6200 U3.3 @@@D8 3 0 8400 9000 8300 9000 8300 9200 C18.1 @@@D9 2 0 7800 9100 7800 9200 @@@D8 U3.1 2 0 8300 9200 8400 9200 @@@D9 @@@D8 2 0 7800 9200 8300 9200 @@@D9 @@@O16 2 0 7800 9200 7800 9300 U4.1 @@@D10 2 0 8400 7700 7700 7700 @@@D10 C16.1 2 0 7700 7700 7700 7600 @@@D10 @@@O21 2 0 7700 7700 7700 7800 *SIGNAL* $$$18202 64 0 J3.1 @@@D11 2 0 2100 7300 2200 7300 J5.1 @@@D0 3 0 2100 6300 2200 6300 2200 6800 @@@D0 J4.1 2 0 2200 6800 2100 6800 D1.A @@@D11 2 0 2300 7300 2200 7300 @@@D11 @@@D0 2 0 2200 7300 2200 6800 *SIGNAL* PD0 0 0 R37.1 @@@D4 2 0 5800 7300 5800 7200 @@@D4 U6.7 2 0 5800 7200 5100 7200 @@@D4 @@@O7 2 0 5800 7200 6000 7200 *SIGNAL* $$$18269 64 0 D1.K @@@D2 2 0 2800 7300 2900 7300 U6.4 @@@D1 3 0 3800 7200 3700 7200 3700 7300 @@@D1 U6.1 2 0 3700 7300 3800 7300 @@@D1 @@@D2 2 0 3700 7300 2900 7300 @@@D2 C17.1 2 0 2900 7300 2900 7200 *SIGNAL* VCC1 0 0 R37.2 @@@O8 2 0 5800 7900 5800 7900 U3.5 @@@O19 3 0 9600 9100 9700 9100 9700 9300 *SIGNAL* $$$18465 64 0 U6.9 R34.1 2 0 5100 7000 5400 7000 *SIGNAL* $$$18470 64 0 U6.8 R36.1 4 0 5100 6900 5300 6900 5300 6700 5400 6700 *SIGNAL* $$$3513 64 0 T5.B R17.2 2 0 12900 7800 12800 7800 *SIGNAL* CE 0 0 U5.3 @@@D6 2 0 8400 5900 8000 5900 @@@D6 R33.2 2 0 8000 5900 8000 5800 @@@D6 @@@O10 2 0 8000 5900 7900 5900 U4.3 @@@O20 2 0 8400 7500 8400 7500 *SIGNAL* VCC 2 0 U5.5 @@@O15 3 0 9600 6000 9700 6000 9700 6200 RX1.2 @@@O34 2 0 2200 4600 2200 4800 C1.1 @@@D21 2 0 4100 1800 4400 1800 @@@D21 C3.1 2 0 4400 1800 4600 1800 @@@D21 @@@O37 2 0 4400 1800 4400 1800 R10.2 @@@O41 2 0 2200 2400 2200 2400 *SIGNAL* VCC2 0 0 U4.5 @@@O24 3 0 9600 7600 9700 7600 9700 7800 C10.1 @@@D12 2 0 10700 8400 10700 8500 @@@D12 @@@D16 2 0 10700 8500 11300 8500 @@@D12 @@@O25 2 0 10700 8500 10700 8700 C14.1 @@@D13 2 0 10700 6000 10700 6100 @@@D13 @@@D17 2 0 10700 6100 11300 6100 @@@D13 @@@O26 2 0 10700 6100 10700 6300 @@@D16 C7.1 2 0 11300 8500 11300 8400 @@@D16 T5.C 3 0 11300 8500 13300 8500 13300 8100 @@@D17 C13.1 2 0 11300 6100 11300 6000 @@@D17 T6.C 3 0 11300 6100 13300 6100 13300 5600 *SIGNAL* $$$3571 64 0 M1.1 T5.E 2 0 13300 7400 13300 7500 *SIGNAL* $$$3620 64 0 R24.2 T6.B 2 0 12800 5300 12900 5300 *SIGNAL* PD3 0 0 R24.1 @@@O31 2 0 12200 5300 12200 5300 *SIGNAL* $$$3648 64 0 M2.1 T6.E 2 0 13300 4900 13300 5000 *SIGNAL* $$$8019 64 0 U2-D.13 @@@D19 5 0 2700 3900 2600 3900 2600 4200 3600 4200 3600 3800 @@@D19 U2-D.14 2 0 3600 3800 3500 3800 @@@D19 C2.1 2 0 3600 3800 3800 3800 *SIGNAL* $$$8027 64 0 U2-D.12 @@@D18 2 0 2700 3700 2200 3700 @@@D18 R4.2 2 0 2200 3700 2200 3600 @@@D18 RX1.1 2 0 2200 3700 2200 4100 *SIGNAL* AMP1_OUT 0 0 R5.2 @@@D28 2 0 6300 3300 6300 3100 @@@D28 C5.2 2 0 6300 3100 6200 3100 @@@D28 @@@D31 3 0 6300 3100 6500 3100 6500 3700 @@@D31 U2-A.1 2 0 6500 3700 6400 3700 @@@D31 @@@O42 2 0 6500 3700 6600 3700 *SIGNAL* $$$8283 64 0 C2.2 @@@D24 2 0 4300 3800 4500 3800 @@@D24 R2.2 2 0 4500 3800 4500 3700 @@@D24 @@@D25 2 0 4500 3800 4900 3800 U2-B.5 @@@D25 3 0 5600 2100 4900 2100 4900 3800 @@@D25 U2-A.3 2 0 4900 3800 5600 3800 *SIGNAL* $$$8489 64 0 R5.1 @@@D22 2 0 5700 3300 5700 3100 @@@D22 C5.1 2 0 5700 3100 5700 3100 @@@D22 @@@D23 2 0 5700 3100 5500 3100 U2-A.2 @@@D23 3 0 5600 3600 5500 3600 5500 3100 @@@D23 R6.2 2 0 5500 3100 5500 3100 *SIGNAL* $$$8890 64 0 C6.1 @@@D26 2 0 5900 1400 5900 1600 U2-B.6 @@@D29 3 0 5600 1900 5500 1900 5500 1600 @@@D26 R9.1 2 0 5900 1600 5900 1600 R7.2 @@@D29 2 0 5500 1500 5500 1600 @@@D29 @@@D26 2 0 5500 1600 5900 1600 *SIGNAL* AMP2_OUT 0 0 C6.2 @@@D27 3 0 6400 1400 6500 1400 6500 1600 @@@D27 R9.2 2 0 6500 1600 6500 1600 @@@D27 @@@D32 3 0 6500 1600 6600 1600 6600 2000 @@@D32 U2-B.7 2 0 6600 2000 6400 2000 @@@D32 @@@O43 2 0 6600 2000 6600 2000 *SIGNAL* $$$9017 64 0 U2-C.10 @@@D30 2 0 2700 1700 2200 1700 R10.1 @@@D30 2 0 2200 1800 2200 1700 @@@D30 R8.2 2 0 2200 1700 2200 1600 *SIGNAL* $$$9049 64 0 U2-C.9 U2-C.8 6 0 2700 1900 2600 1900 2600 2200 3600 2200 3600 1800 3500 1800 *SIGNAL* MOSI 0 0 R17.1 @@@O29 2 0 12200 7800 12200 7800 *NETNAMES* DEBUG @@@O2 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" VBATT @@@O3 -280 100 0 4 0 0 0 0 -1 10 100 "Default Font" VBATT @@@O6 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" PD0 @@@O7 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" VCC1 @@@O8 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" CE @@@O10 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" VBATT @@@O13 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC @@@O15 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VBATT @@@O16 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC1 @@@O19 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" CE @@@O20 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" VBATT @@@O21 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC2 @@@O24 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC2 @@@O25 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC2 @@@O26 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" MOSI @@@O29 -360 0 0 1 0 0 0 3 -1 10 97 "Default Font" PD3 @@@O31 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" VCC @@@O34 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC @@@O37 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC @@@O41 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" AMP1_OUT @@@O42 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" AMP2_OUT @@@O43 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" *SHT* 2 MPU -1 $$$NONE *CAE* GENERAL PARAMETERS FOR THE SHEET" SCALE 3.766 Scale of window expansion WINDOWCENTER 4251 2751 Point defining the center of the window BITCS0 0 system status bits BITCS1 0 system status bits BITCS2 0 system status bits *TEXT* FREE TEXT 12900 4200 0 0 139 10 0 "Default Font" Program 9100 5000 0 0 139 10 0 "Default Font" Ambient Light Sensor 5700 4600 0 0 139 10 0 "Default Font" Infared TX 7200 8900 0 0 139 10 0 "Default Font" MPU 12800 6700 0 0 139 10 0 "Default Font" RGB LED INDICATOR *LINES* LINES ITEMS SIZEB LINES 16000 1700 34 42 OPEN 2 10 255 0 0 -5010 0 OPEN 2 10 255 -500 0 -500 -950 OPEN 2 10 255 -1800 -950 -1800 -1200 OPEN 2 10 255 -3100 0 -3100 -950 OPEN 2 10 255 -3800 0 -3800 -950 OPEN 2 10 255 0 -950 -5000 -950 OPEN 2 10 255 -5000 1290 -5000 -1200 OPEN 2 10 255 0 800 -5000 800 OPEN 2 10 255 -5000 -400 -7500 -400 CLOSED 7 10 255 0 -1200 0 1290 -5000 1290 -5000 400 -7500 400 -7500 -1200 0 -1200 OPEN 2 10 255 -5010 0 -7500 0 OPEN 2 10 255 -5000 -800 -7500 -800 OPEN 2 10 255 -6000 400 -6000 -1200 OPEN 2 10 255 502 1150 2 1150 OPEN 2 10 255 500 3550 0 3550 OPEN 2 10 255 500 5900 0 5900 OPEN 2 10 255 -2864 8100 -2864 7100 OPEN 2 10 255 -464 8100 -464 7100 OPEN 2 10 255 -1364 8100 -1364 7100 OPEN 2 10 255 -2800 8800 -2800 8300 OPEN 2 10 255 -5300 8800 -5300 8300 OPEN 2 10 255 -7800 8800 -7800 8300 OPEN 2 10 255 -10300 8800 -10300 8300 OPEN 2 10 255 -12800 8800 -12800 8300 OPEN 2 10 255 -15000 5900 -15500 5900 OPEN 2 10 255 -15000 1150 -15500 1150 OPEN 2 10 255 -15000 3550 -15500 3550 OPEN 5 10 255 0 -1200 0 8300 -15000 8300 -15000 -1200 0 -1200 OPEN 2 10 255 -3450 8100 0 8100 OPEN 2 10 255 -3450 7900 0 7900 OPEN 2 10 255 -3450 7500 0 7500 OPEN 2 10 255 -3450 7300 0 7300 CLOSED 5 10 255 0 8300 -3450 8300 -3450 7100 0 7100 0 8300 OPEN 2 10 255 -3450 7700 0 7700 -300 -600 0 12 306 10 1 "Default Font" Revision -1720 -1090 0 0 100 10 0 "Default Font" SHEET: OF -4220 -1070 0 8 153 10 1 "Default Font" Sheet Name -4950 -1100 0 0 97 10 0 "Default Font" SHEET NAME: -6300 150 0 9 150 10 1 "Default Font" Drawn By -6300 -250 0 9 150 10 1 "Default Font" Checked By -6000 150 0 8 150 10 1 "Default Font" Drawn Date -6000 -250 0 8 150 10 1 "Default Font" Checked Date -2500 1050 0 12 250 10 1 "Default Font" Company Name -2300 400 0 12 250 10 1 "Default Font" Title -3450 -600 0 12 300 10 1 "Default Font" Sheet Size -2000 -600 0 12 300 10 1 "Default Font" Drawing Number -1350 -1050 0 8 150 10 1 "Default Font" Sheet Number -900 -1050 0 8 150 10 1 "Default Font" Number of Sheets -400 -200 0 0 100 10 0 "Default Font" REV: -3600 -200 0 0 100 10 0 "Default Font" SIZE: -7460 250 0 0 100 10 0 "Default Font" DRAWN: -5960 250 0 0 100 10 0 "Default Font" DATED: -5960 -150 0 0 100 10 0 "Default Font" DATED: -7460 -150 0 0 100 10 0 "Default Font" CHECKED: -4960 1100 0 0 100 10 0 "Default Font" COMPANY: -4960 600 0 0 100 10 0 "Default Font" TITLE: -2150 -200 0 0 100 10 0 "Default Font" DRAWING NO: -2200 8150 0 0 100 10 0 "Default Font" REVISION RECORD -1200 7950 0 0 100 10 0 "Default Font" APPROVED: -2350 7950 0 0 100 10 0 "Default Font" ECO NO: 100 -50 0 0 250 25 0 "Default Font" A 100 2350 0 0 250 25 0 "Default Font" B 100 7100 0 0 250 25 0 "Default Font" D -414 7950 0 0 100 10 0 "Default Font" DATE: -1550 8400 0 0 250 25 0 "Default Font" 1 -4050 8400 0 0 250 25 0 "Default Font" 2 -6550 8400 0 0 250 25 0 "Default Font" 3 -9050 8400 0 0 250 25 0 "Default Font" 4 -11550 8400 0 0 250 25 0 "Default Font" 5 -13900 8400 0 0 250 25 0 "Default Font" 6 -15250 7100 0 0 250 25 0 "Default Font" D -15250 4700 0 0 250 25 0 "Default Font" C -15250 -50 0 0 250 25 0 "Default Font" A -15250 2350 0 0 250 25 0 "Default Font" B 100 4700 0 0 250 25 0 "Default Font" C -3250 7950 0 0 100 10 0 "Default Font" LTR *CAEDECAL* ITEMS PIN 34000 34000 97 10 97 10 4 1 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 140 20 0 1 100 10 "Default Font" REF-DES 230 0 0 8 100 10 "Default Font" PART-TYPE -520 0 0 1 100 10 "Default Font" * -80 0 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 200 0 PINB 34000 34000 97 10 97 10 4 2 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 230 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 140 0 CIRCLE 2 10 255 140 0 190 0 PCLK 33500 33180 97 10 97 10 4 2 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 280 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 200 0 OPEN 3 10 255 200 30 260 0 200 -30 PCLKB 33500 33180 97 10 97 10 4 3 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 280 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 3 10 255 200 30 260 0 200 -30 OPEN 2 10 255 0 0 140 0 CIRCLE 2 10 255 190 0 140 0 PINIEB 34000 34000 97 10 97 10 4 1 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 220 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 4 10 255 0 0 200 0 140 30 140 0 PINORB 34000 34000 97 10 97 10 4 2 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 130 14 0 1 100 10 "Default Font" REF-DES 300 0 0 8 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 180 0 CIRCLE 2 10 255 230 0 180 0 PINSHORT 34000 34000 97 10 97 10 4 1 0 0 0 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 60 10 0 1 100 10 "Default Font" REF-DES 140 10 0 8 100 10 "Default Font" PART-TYPE -530 10 0 1 100 10 "Default Font" * -70 10 0 1 100 10 "Default Font" * OPEN 2 10 255 0 0 100 0 PINVRTS 34000 34000 97 10 97 10 4 1 0 0 3 1 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 20 -80 0 0 100 10 "Default Font" REF-DES -20 -40 0 9 100 10 "Default Font" PART-TYPE -500 10 0 1 100 10 "Default Font" * -30 14 0 1 100 10 "Default Font" * OPEN 2 10 255 0 -100 0 0 ATMEGA328P-MU 32000 32000 97 10 97 10 2 1 0 33 0 0 TIMESTAMP 2016.02.26.19.20.49 "Default Font" "Default Font" -500 1230 0 4 97 10 "Default Font" REF-DES 480 1290 0 6 97 10 "Default Font" PART-TYPE CLOSED 5 10 255 -600 1200 -600 -1400 700 -1400 700 1200 -600 1200 T-800 700 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 600 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -300 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -400 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 0 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 300 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 400 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 500 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -600 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -500 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -100 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -1200 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -1100 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -900 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 -1000 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 800 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 -900 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 -1000 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 -1100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 -100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 -200 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 1000 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T-800 900 0 0 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 300 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 200 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 100 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 0 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 700 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 800 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 900 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 1000 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 T900 -1200 0 1 140 20 0 1 230 0 0 8 PIN P-520 0 0 1 -80 0 0 1 0 GND 33500 33180 97 10 97 10 4 4 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 100 -50 0 0 100 10 "Default Font" REF-DES 0 200 0 0 100 10 "Default Font" PART-TYPE 0 100 0 0 100 10 "Default Font" * 0 0 0 0 100 10 "Default Font" * OPEN 2 5 255 0 0 0 -100 OPEN 2 5 255 -100 -100 100 -100 OPEN 2 5 255 -60 -160 60 -160 OPEN 2 5 255 -20 -220 20 -220 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 AGND 33500 33180 97 10 97 10 4 1 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 260 0 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 6 5 255 0 0 0 -50 -100 -50 0 -200 100 -50 0 -50 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 CHGND 33500 33180 97 10 97 10 4 5 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 264 -40 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 5 255 0 0 0 -100 OPEN 2 5 255 -100 -100 100 -100 OPEN 2 5 255 -100 -100 -150 -200 OPEN 2 5 255 0 -100 -50 -200 OPEN 2 5 255 100 -100 50 -200 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 RESZ-H 33200 33180 100 10 100 10 4 1 0 2 2 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 300 100 0 4 100 10 "Default Font" REF-DES 310 200 0 4 100 10 "Default Font" PART-TYPE 300 -100 0 6 100 10 "Default Font" VALUE 300 -200 0 6 100 10 "Default Font" * OPEN 10 10 255 100 0 120 0 150 60 210 -60 270 60 330 -60 390 60 450 -60 470 0 500 0 T0 0 0 0 34 16 0 0 170 -30 0 8 PINSHORT P-80 -30 0 1 0 0 0 0 128 T600 0 0 1 0 20 0 0 170 -30 0 8 PINSHORT P-90 -20 0 1 0 0 0 0 128 RESZ-V 33500 33480 100 10 100 10 4 1 0 2 2 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 100 -280 0 0 100 10 "Default Font" REF-DES 100 -180 0 0 100 10 "Default Font" PART-TYPE 100 -320 0 2 100 10 "Default Font" VALUE 100 -420 0 2 100 10 "Default Font" * OPEN 10 10 255 0 -500 0 -480 -60 -450 60 -390 -60 -330 60 -270 -60 -210 60 -150 0 -130 0 -100 T0 0 0 0 20 -80 0 0 -20 -40 0 9 PINVRTS P840 80 0 1 0 0 0 0 128 T0 -600 0 2 20 -80 0 0 -20 -40 0 9 PINVRTS P840 40 0 1 0 0 0 0 128 RESB-H 33200 33180 100 10 100 10 4 2 0 2 2 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 300 80 0 4 100 10 "Default Font" REF-DES 300 180 0 4 100 10 "Default Font" PART-TYPE 310 -120 0 12 100 10 "Default Font" VALUE 300 -80 0 6 100 10 "Default Font" * OPEN 7 10 255 100 0 150 0 150 50 450 50 450 -50 150 -50 150 0 OPEN 2 10 255 450 0 500 0 T0 0 0 0 34 16 0 0 170 -30 0 8 PINSHORT P-160 0 0 1 0 0 0 0 128 T600 0 0 1 34 16 0 0 170 -30 0 8 PINSHORT P-160 0 0 1 0 0 0 0 128 RESB-V 33500 32630 100 10 100 10 4 2 0 2 2 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 140 -260 0 0 100 10 "Default Font" REF-DES 210 -80 0 2 100 10 "Default Font" PART-TYPE 140 -290 0 2 100 10 "Default Font" VALUE 180 -400 0 2 100 10 "Default Font" * OPEN 7 10 255 0 -460 0 -410 -50 -410 -50 -110 50 -110 50 -410 0 -410 OPEN 2 10 255 0 -110 0 -60 T0 0 90 2 90 -30 90 2 170 -30 0 8 PINSHORT P-10 -190 90 2 0 0 0 0 128 T0 -500 90 0 80 -30 90 2 170 -30 0 8 PINSHORT P-10 -160 90 2 0 0 0 0 128 CAP 33800 33180 100 10 100 10 4 4 0 2 26 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 150 -210 0 0 100 10 "Default Font" REF-DES 210 -40 0 2 100 10 "Default Font" PART-TYPE 150 -240 0 2 100 10 "Default Font" VALUE 150 -340 0 2 100 10 "Default Font" * OPEN 2 10 255 0 -200 0 -50 OPEN 2 1 255 -100 -200 100 -200 OPEN 2 1 255 -100 -300 100 -300 OPEN 2 10 255 0 -300 0 -500 T0 0 0 0 20 -90 0 0 -20 -40 0 9 PINVRTS P-110 -140 0 1 0 0 0 0 128 T0 -500 0 2 20 -80 0 0 -20 -40 0 9 PINVRTS P-110 -130 0 1 0 0 0 0 128 CAPA 33930 33180 100 10 100 10 4 4 0 2 26 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 180 -210 0 0 100 10 "Default Font" REF-DES 240 -30 0 2 100 10 "Default Font" PART-TYPE 180 -250 0 2 100 10 "Default Font" VALUE 180 -360 0 2 100 10 "Default Font" * OPEN 2 10 255 0 -200 0 -50 OPEN 2 1 255 -100 -200 100 -200 OPEN 2 1 255 -100 -300 1333 -866 -140 -550 140 -260 100 -300 OPEN 2 10 255 0 -260 0 -500 T0 0 0 0 20 -80 0 0 -20 -40 0 9 PINVRTS P-76 -112 0 1 0 0 0 0 128 T0 -500 0 2 20 -80 0 0 -20 -40 0 9 PINVRTS P-72 -136 0 1 0 0 0 0 128 CAPH 33300 33180 100 10 100 10 4 4 0 2 26 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 250 150 0 4 100 10 "Default Font" REF-DES 250 250 0 4 100 10 "Default Font" PART-TYPE 260 -140 0 6 100 10 "Default Font" VALUE 260 -250 0 6 100 10 "Default Font" * OPEN 2 10 255 100 0 200 0 OPEN 2 10 255 300 0 400 0 OPEN 2 10 255 200 100 200 -100 OPEN 2 10 255 300 100 300 -100 T0 0 0 0 80 20 0 1 170 -30 0 8 PINSHORT P-40 -110 0 1 0 0 0 0 128 T500 0 0 1 80 20 0 1 170 -30 0 8 PINSHORT P-40 -120 0 1 0 0 0 0 128 CAPAH 33100 33280 100 10 100 10 4 4 0 2 26 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 250 150 0 4 100 10 "Default Font" REF-DES 250 250 0 4 100 10 "Default Font" PART-TYPE 250 -150 0 6 100 10 "Default Font" VALUE 250 -250 0 6 100 10 "Default Font" * OPEN 2 10 255 200 100 200 -100 OPEN 2 10 255 300 100 1272 1056 250 -120 500 120 300 -100 OPEN 2 10 255 200 0 100 0 OPEN 2 10 255 250 0 400 0 T0 0 0 0 30 20 0 1 170 -30 0 8 PINSHORT P-28 -104 0 1 0 0 0 0 128 T500 0 0 1 30 20 0 1 170 -30 0 8 PINSHORT P-28 -104 0 1 0 0 0 0 128 NPN-V 32000 32000 100 10 100 10 4 6 0 3 0 0 TIMESTAMP 2016.02.26.19.18.03 "Default Font" "Default Font" 590 60 0 0 100 10 "Default Font" REF-DES 640 180 0 0 100 10 "Default Font" PART-TYPE 590 20 0 2 100 10 "Default Font" PART NUMBER 590 -100 0 2 100 10 "Default Font" * CIRCLE 2 20 255 100 0 532 0 OPEN 2 10 255 200 50 400 200 OPEN 2 25 255 200 100 200 -100 OPEN 2 10 255 200 0 100 0 OPEN 2 10 255 200 -50 400 -200 COPCLS 4 10 255 260 -134 302 -90 324 -144 260 -134 T400 -300 0 3 -20 -80 0 1 -20 -40 0 9 PINVRTS P1030 100 0 1 0 0 0 0 128 T0 0 0 0 70 20 0 1 170 -30 0 8 PINSHORT P-10 -110 0 1 0 0 0 0 128 T400 300 0 1 -20 -80 0 1 -20 -40 0 9 PINVRTS P200 0 0 0 0 0 0 0 128 NPN-VA 32000 32000 100 10 100 10 4 6 0 3 0 0 TIMESTAMP 2016.02.26.19.18.03 "Default Font" "Default Font" -660 90 0 1 100 10 "Default Font" REF-DES -900 200 0 0 100 10 "Default Font" PART-TYPE -660 40 0 3 100 10 "Default Font" PART NUMBER -950 -80 0 2 100 10 "Default Font" * CIRCLE 2 20 255 -600 0 -150 0 OPEN 2 10 255 -500 -200 -300 -50 OPEN 2 25 255 -300 100 -300 -100 OPEN 2 10 255 -200 0 -300 0 OPEN 2 10 255 -500 200 -300 50 COPCLS 4 10 255 -360 -134 -402 -90 -424 -144 -360 -134 T-500 -300 0 3 140 -90 0 1 -20 -40 0 9 PINVRTS P-310 10 0 1 0 0 0 0 128 T-500 300 0 1 140 -80 0 1 -20 -40 0 9 PINVRTS P-1140 20 0 0 0 0 0 0 128 T0 0 0 1 88 40 0 1 230 0 0 8 PIN P-500 10 0 1 0 0 0 0 128 NPN-H 32000 32000 100 10 100 10 4 6 0 3 0 0 TIMESTAMP 2016.02.26.19.18.03 "Default Font" "Default Font" -530 160 0 0 100 10 "Default Font" REF-DES 270 290 0 0 100 10 "Default Font" PART-TYPE -530 40 0 0 100 10 "Default Font" PART NUMBER 250 230 0 2 100 10 "Default Font" * OPEN 2 10 255 0 200 0 100 OPEN 2 10 255 50 200 200 400 OPEN 2 25 255 -100 200 100 200 COPCLS 4 10 255 134 260 90 302 144 324 134 260 OPEN 2 10 255 -50 200 -200 400 CIRCLE 2 20 255 0 100 0 532 T300 400 0 1 80 16 0 1 170 -30 0 8 PINSHORT P-30 -110 0 1 0 0 0 0 128 T0 0 0 2 20 -80 0 0 -20 -40 0 9 PINVRTS P-10 30 0 1 0 0 0 0 128 T-300 400 0 0 70 16 0 1 170 -30 0 8 PINSHORT P30 -120 0 1 0 0 0 0 128 NPN-HA 32000 32000 100 10 100 10 4 6 0 3 0 0 TIMESTAMP 2016.02.26.19.18.03 "Default Font" "Default Font" -270 -160 0 1 100 10 "Default Font" REF-DES 300 -180 0 0 100 10 "Default Font" PART-TYPE -430 -240 0 12 100 10 "Default Font" PART NUMBER 300 -230 0 2 100 10 "Default Font" * OPEN 2 25 255 100 -200 -100 -200 OPEN 2 10 255 0 -200 0 -100 OPEN 2 10 255 50 -200 200 -400 OPEN 2 10 255 -50 -200 -200 -400 COPCLS 4 10 255 -134 -260 -90 -302 -144 -324 -134 -260 CIRCLE 2 20 255 0 -100 0 -532 T-300 -400 0 2 80 14 0 1 170 -30 0 8 PINSHORT P60 120 0 1 0 0 0 0 128 T0 0 0 1 20 -80 0 0 -20 -40 0 9 PINVRTS P60 120 0 1 0 0 0 0 128 T300 -400 0 3 80 14 0 1 170 -30 0 8 PINSHORT P90 160 0 1 0 0 0 0 128 LED 32000 32000 100 10 100 10 4 8 0 2 0 0 TIMESTAMP 2016.02.26.19.23.28 "Default Font" "Default Font" 100 200 0 4 100 10 "Default Font" REF-DES 250 -150 0 6 100 10 "Default Font" PART-TYPE 250 -250 0 6 100 10 "Default Font" * 250 -350 0 6 100 10 "Default Font" * OPEN 2 10 255 90 0 390 0 OPEN 2 10 255 340 90 340 -90 COPCLS 4 10 255 190 0 190 -90 340 0 190 0 COPCLS 4 10 255 190 0 190 90 340 0 190 0 OPEN 2 10 255 250 150 350 250 COPCLS 5 10 255 350 250 290 230 320 190 330 180 350 250 OPEN 2 10 255 350 150 450 250 COPCLS 5 10 255 460 260 400 240 430 200 440 190 460 260 T500 0 0 1 130 14 0 1 170 -30 0 8 PINSHORT P-500 10 0 1 -70 10 0 1 0 T0 0 0 0 130 14 0 1 170 -30 0 8 PINSHORT P-500 10 0 1 -70 10 0 1 0 LED-V 32000 32000 100 10 100 10 4 8 0 2 0 0 TIMESTAMP 2016.02.26.19.23.28 "Default Font" "Default Font" -300 350 0 4 100 10 "Default Font" REF-DES 350 250 0 6 100 10 "Default Font" PART-TYPE 350 150 0 6 100 10 "Default Font" COLOR 350 50 0 6 100 10 "Default Font" PART NUMBER OPEN 2 10 255 0 190 0 490 COPCLS 4 10 255 0 290 -90 290 0 440 0 290 COPCLS 4 10 255 0 290 90 290 0 440 0 290 OPEN 2 10 255 90 440 -90 440 OPEN 2 10 255 76 376 176 476 COPCLS 5 10 255 176 476 116 456 146 416 156 406 176 476 OPEN 2 10 255 176 376 276 476 COPCLS 5 10 255 286 486 226 466 256 426 266 416 286 486 T0 600 90 2 100 100 90 2 230 0 0 8 PIN P-180 470 90 2 0 0 0 0 128 T0 100 90 0 90 100 90 2 230 0 0 8 PIN P-160 360 90 2 0 0 0 0 128 INDUCTOR 33200 32874 100 10 100 10 4 3 0 2 0 0 TIMESTAMP 1999.09.02.14.33.15 "Default Font" "Default Font" 250 300 0 4 100 10 "Default Font" REF-DES 250 250 0 6 100 10 "Default Font" PART-TYPE 250 -100 0 6 100 10 "Default Font" VALUE 250 -200 0 6 100 10 "Default Font" SPIL PART# OPEN 2 10 255 100 0 1777 -1754 100 -52 200 48 200 0 OPEN 2 10 255 200 0 1777 -1754 200 -52 300 48 300 0 OPEN 2 10 255 300 0 1777 -1754 300 -52 400 48 400 0 T0 0 0 0 70 30 0 1 170 -30 0 8 PINSHORT P-500 10 0 1 0 0 0 0 128 T500 0 0 1 60 30 0 1 170 -30 0 8 PINSHORT P-500 10 0 1 0 0 0 0 128 +5V 33500 33180 100 10 100 10 4 2 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 0 250 0 4 100 10 "Default Font" REF-DES 0 200 0 0 100 10 "Default Font" PART-TYPE 0 100 0 0 100 10 "Default Font" * 0 0 0 0 100 10 "Default Font" * OPEN 2 5 255 0 0 0 200 COPCLS 4 5 255 0 200 -50 100 50 100 0 200 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 BUBBLE 33500 33180 100 10 100 10 4 2 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 0 300 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 10 255 0 0 0 100 CIRCLE 2 10 255 0 100 0 200 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 Y 33500 33180 100 10 100 10 4 2 0 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 0 300 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 3 10 255 0 0 0 100 -100 200 OPEN 2 10 255 0 100 100 200 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 +12V 33500 33274 100 10 100 10 4 2 1 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 4 484 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 5 255 0 0 0 300 COPCLS 4 5 255 0 300 -50 150 50 150 0 300 -108 356 0 0 100 10 +12V T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 -5V 33500 33274 100 10 100 10 4 2 1 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 16 -520 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 5 255 0 0 0 -300 COPCLS 4 5 255 0 -300 50 -150 -50 -150 0 -300 -80 -388 0 0 100 10 -5V T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 -12V 33500 33274 100 10 100 10 4 2 1 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 8 -560 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 5 255 0 0 0 -300 COPCLS 4 5 255 0 -300 50 -150 -50 -150 0 -300 -116 -412 0 0 100 10 -12V T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 +5VA 33500 33274 100 10 100 10 4 2 1 1 26 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 8 468 0 4 100 10 "Default Font" REF-DES 0 200 0 6 100 10 "Default Font" PART-TYPE 0 100 0 6 100 10 "Default Font" * 0 0 0 6 100 10 "Default Font" * OPEN 2 10 255 0 0 0 300 COPCLS 4 10 255 0 300 -50 150 50 150 0 300 -108 336 0 0 100 10 +5VA T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 REFIN 33500 33180 100 10 100 10 4 1 0 1 24 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" -360 0 0 1 100 10 "Default Font" REF-DES -360 -20 0 3 100 10 "Default Font" PART-TYPE 0 100 0 0 100 10 "Default Font" * 0 0 0 0 100 10 "Default Font" * OPEN 7 5 255 0 0 -100 0 -150 -50 -300 -50 -300 50 -150 50 -100 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 REFOUT 33500 33180 100 10 100 10 4 1 0 1 24 0 TIMESTAMP 1999.08.25.21.39.16 "Default Font" "Default Font" 350 10 0 0 100 10 "Default Font" REF-DES 350 -10 0 2 100 10 "Default Font" PART-TYPE 0 100 0 0 100 10 "Default Font" * 0 0 0 0 100 10 "Default Font" * OPEN 8 5 255 0 0 100 0 100 50 250 50 300 0 250 -50 100 -50 100 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 128 NPN-V_PHOTO 32000 32000 97 10 97 10 4 8 0 2 0 0 TIMESTAMP 2016.02.26.19.19.05 "Default Font" "Default Font" 590 60 0 0 97 10 "Default Font" REF-DES 640 180 0 0 97 10 "Default Font" PART-TYPE 590 20 0 2 97 10 "Default Font" PART NUMBER 590 -100 0 2 97 10 "Default Font" * OPEN 2 10 255 200 50 400 200 OPEN 2 25 255 200 100 200 -100 OPEN 2 10 255 200 -50 400 -200 COPCLS 4 10 255 260 -134 302 -90 324 -144 260 -134 COPCLS 4 10 255 60 66 102 110 124 56 60 66 COPCLS 4 10 255 60 -34 102 10 124 -44 60 -34 OPEN 3 10 255 82 -12 22 48 24 48 OPEN 3 10 255 84 90 24 150 26 150 T400 -300 0 3 -20 -80 0 1 -20 -40 0 9 PINVRTS P1030 100 0 1 -30 14 0 1 0 T400 300 0 1 -20 -80 0 1 -20 -40 0 9 PINVRTS P200 0 0 0 -30 14 0 1 0 CONIN 32000 32000 100 10 100 10 4 3 0 1 30 0 TIMESTAMP 2016.02.26.19.20.08 "Default Font" "Default Font" -400 -30 0 4 100 10 "Default Font" REF-DES -790 -110 0 6 100 10 "Default Font" PART-TYPE -850 100 0 6 100 10 "Default Font" * -850 0 0 6 100 10 "Default Font" * OPEN 2 10 255 -600 100 -600 -100 OPEN 2 10 255 -200 100 -200 -100 OPEN 2 10 255 -200 0 0 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 192 CONOUT 32000 32000 100 10 100 10 4 3 0 1 30 0 TIMESTAMP 2016.02.26.19.20.08 "Default Font" "Default Font" 400 -30 0 4 100 10 "Default Font" REF-DES 780 -110 0 6 100 10 "Default Font" PART-TYPE 840 80 0 6 100 10 "Default Font" * 840 -20 0 6 100 10 "Default Font" * OPEN 2 10 255 200 100 200 -100 OPEN 2 10 255 600 100 600 -100 OPEN 2 10 255 200 0 0 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 192 CONIN1 32000 32000 100 10 100 10 4 2 0 1 30 0 TIMESTAMP 2016.02.26.19.20.08 "Default Font" "Default Font" -540 -30 0 4 100 10 "Default Font" REF-DES -540 -200 0 6 100 10 "Default Font" PART-TYPE -530 -300 0 6 100 10 "Default Font" * -530 -400 0 6 100 10 "Default Font" * OPEN 2 10 255 -200 0 0 0 CLOSED 5 10 255 -300 100 900 -1800 -400 -100 -200 100 -300 -100 -800 -100 2700 -1800 -900 -100 -700 100 -800 100 -300 100 T0 0 0 0 90 -30 0 0 0 0 0 8 P10 200 0 0 0 0 0 0 192 CONOUT1 32000 32000 100 10 100 10 4 2 0 1 30 0 TIMESTAMP 2016.02.26.19.20.08 "Default Font" "Default Font" 550 -30 0 4 100 10 "Default Font" REF-DES 550 -200 0 6 100 10 "Default Font" PART-TYPE 550 -310 0 6 100 10 "Default Font" * 550 -420 0 6 100 10 "Default Font" * OPEN 2 10 255 200 0 0 0 CLOSED 5 10 255 300 100 900 1800 200 -100 400 100 300 -100 800 -100 2700 1800 700 -100 900 100 800 100 300 100 T0 0 0 0 0 0 0 0 0 0 0 8 P-90 200 0 0 0 0 0 0 192 CON_IO 32000 32000 100 10 100 10 4 2 0 1 30 0 TIMESTAMP 2016.02.26.19.20.08 "Default Font" "Default Font" -500 -40 0 4 100 10 "Default Font" REF-DES -500 -190 0 6 100 10 "Default Font" PART-TYPE -500 -300 0 6 100 10 "Default Font" * -500 -400 0 6 100 10 "Default Font" * OPEN 2 10 255 -200 0 0 0 CLOSED 7 10 255 -200 0 -300 -100 -700 -100 -800 0 -700 100 -300 100 -200 0 T0 0 0 0 0 0 0 0 0 0 0 8 P0 0 0 0 0 0 0 0 192 RGB_COMMON_ANODE 32000 32000 100 10 100 10 2 20 0 4 0 0 TIMESTAMP 2016.02.26.19.19.42 "Default Font" "Default Font" 100 200 0 4 100 10 "Default Font" REF-DES 310 -530 0 6 100 10 "Default Font" PART-TYPE OPEN 2 10 255 340 90 340 -90 COPCLS 4 10 255 190 0 190 -90 340 0 190 0 COPCLS 4 10 255 190 0 190 90 340 0 190 0 OPEN 2 10 255 250 150 350 250 COPCLS 5 10 255 350 250 290 230 320 190 330 180 350 250 OPEN 2 10 255 350 150 450 250 COPCLS 5 10 255 460 260 400 240 430 200 440 190 460 260 OPEN 2 10 255 340 -110 340 -290 COPCLS 4 10 255 190 -200 190 -110 340 -200 190 -200 COPCLS 4 10 255 190 -200 190 -290 340 -200 190 -200 OPEN 2 10 255 340 -310 340 -490 COPCLS 4 10 255 190 -400 190 -310 340 -400 190 -400 COPCLS 4 10 255 190 -400 190 -490 340 -400 190 -400 OPEN 2 10 255 100 -400 100 0 OPEN 2 10 255 400 -200 300 -200 OPEN 2 10 255 400 -400 300 -400 OPEN 2 10 255 400 0 300 0 OPEN 2 10 255 100 0 200 0 OPEN 2 10 255 100 -200 200 -200 OPEN 2 10 255 100 -400 200 -400 T500 -200 0 1 30 20 0 1 80 50 0 8 PINSHORT P-500 10 0 1 -70 10 0 1 0 T500 0 0 1 50 20 0 1 100 60 0 8 PINSHORT P-500 10 0 1 -70 10 0 1 0 T500 -400 0 1 60 20 0 1 90 60 0 8 PINSHORT P-530 10 0 1 -70 10 0 1 0 T0 -200 0 0 70 30 0 1 110 60 0 8 PINSHORT P-530 10 0 1 -70 10 0 1 0 *PARTTYPE* ITEMS ATMEGA328P UND 1 0 0 0 TIMESTAMP 2016.02.26.19.20.49 GATE 1 33 0 ATMEGA328P-MU 1 0 U PD3 2 0 U PD4 7 0 U PB6 8 0 U PB7 12 0 U PB0 11 0 U PD7 10 0 U PD6 9 0 U PD5 22 0 U ADC7 19 0 U ADC6 14 0 U PB2 13 0 U PB1 29 0 U RESET 17 0 U SCK 15 0 U MOSI 16 0 U MISO 32 0 U PD2 21 0 U GND2 5 0 U GND1 3 0 U GND 27 0 U PC4 28 0 U PC5 30 0 U PD0 31 0 U PD1 23 0 U PC0 24 0 U PC1 25 0 U PC2 26 0 U PC3 20 0 U AREF 18 0 U AVCC 6 0 U VCC1 4 0 U VCC 33 0 U PAD $GND_SYMS UND 0 0 2 0 TIMESTAMP 1999.03.30.22.52.06 GND 3 GND G GND AGND G AGND CHGND G CHGND RES-1/8W RES 1 0 0 0 TIMESTAMP 2004.12.22.19.44.43 GATE 4 2 1 RESZ-H RESZ-V RESB-H RESB-V 1 1 U 2 1 U CAP-CC05 CAP 1 0 0 0 TIMESTAMP 2004.12.22.19.44.43 GATE 4 2 0 CAP CAPA CAPH CAPAH 1 1 U 2 1 U MMBT6428 TRX 1 0 0 3 TIMESTAMP 2016.02.26.19.17.47 GATE 4 3 1 NPN-V NPN-VA NPN-H NPN-HA E 0 U B 0 U C 0 U B E C 2SD2114KT146W TRX 1 0 0 3 TIMESTAMP 2016.02.26.19.18.03 GATE 4 3 1 NPN-V NPN-VA NPN-H NPN-HA E 0 U B 0 U C 0 U B E C LED DIO 1 0 0 0 TIMESTAMP 2016.02.26.19.23.27 GATE 2 2 0 LED LED-V 2 0 U 1 0 U IND-MOLDED IND 1 0 0 0 TIMESTAMP 2004.12.22.19.56.40 GATE 1 2 0 INDUCTOR 1 0 U 2 0 U $PWR_SYMS UND 0 0 2 0 TIMESTAMP 1999.03.30.22.52.06 PWR 7 +5V P +5V BUBBLE P +5V Y P +5V +12V P +12V -5V P -5V -12V P -12V +5VA P +5VA $OSR_SYMS UND 0 0 2 0 TIMESTAMP 1999.03.30.22.52.06 OFF 2 REFIN S REFOUT L TEPT5700 TRX 1 0 0 0 TIMESTAMP 2016.02.26.19.19.05 GATE 1 2 1 NPN-V_PHOTO 2 0 U 1 0 U HEADER06 CON 0 0 1 0 TIMESTAMP 2016.02.26.19.20.08 CONN 5 6 CONIN L CONOUT S CONIN1 L CONOUT1 S CON_IO Z 1 0 U 2 0 U 3 0 U 4 0 U 5 0 U 6 0 U RGB_LED DIO 1 0 0 0 TIMESTAMP 2016.02.26.19.19.42 GATE 1 4 0 RGB_COMMON_ANODE 2 0 U G 1 0 U R 3 0 U B 4 0 U A *PART* ITEMS U1 ATMEGA328P 8200 7300 0 0 97 10 97 10 2 1 33 0 0 0 "Default Font" "Default Font" -500 1230 0 4 97 10 0 "Default Font" REF-DES 480 1290 0 6 97 10 0 "Default Font" PART-TYPE "PCB DECAL" MLF-32 0 140 20 0 1 1 140 20 0 1 2 140 20 0 1 3 140 20 0 1 4 140 20 0 1 5 140 20 0 1 6 140 20 0 1 7 140 20 0 1 8 140 20 0 1 9 140 20 0 1 10 140 20 0 1 11 140 20 0 1 12 140 20 0 1 13 140 20 0 1 14 140 20 0 1 15 140 20 0 1 16 140 20 0 1 17 140 20 0 1 18 140 20 0 1 19 140 20 0 1 20 140 20 0 1 21 140 20 0 1 22 140 20 0 1 23 140 20 0 1 24 140 20 0 1 25 140 20 0 1 26 140 20 0 1 27 140 20 0 1 28 140 20 0 1 29 140 20 0 1 30 140 20 0 1 31 140 20 0 1 32 140 20 0 1 R1 RES-1/8W 4100 6200 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 11K OHM 1% 1/10W 0603 "Value" 11k "PCB DECAL" 0603_NOSILK "Designator" R1 "Distributor" Digikey "Distributor #" P11.0KHCT-ND "Manufactuer #" ERJ-3EKF1102V 0 34 16 0 0 1 0 20 0 0 C4 CAP-CC05 5300 5900 0 0 100 10 100 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 100 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 5% C0G 0603 "Value" 0.01uf "PCB DECAL" 0603_NOSILK "Designator" C4 "Distributor" Digikey "Distributor #" 445-2664-1-ND "Manufactuer #" C1608C0G1E103J080AA 0 20 -90 0 0 1 20 -80 0 0 T1 MMBT6428 3700 5700 0 0 100 10 100 10 4 10 3 0 0 0 "Default Font" "Default Font" 590 60 0 0 100 10 0 "Default Font" REF-DES 640 180 0 0 100 10 0 "Default Font" PART-TYPE 590 20 0 2 100 10 3 "Default Font" Part Number 590 -100 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" q2n4030 "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" Q "Description" TRANS NPN 50V 0.5A SOT-23 "Designator" T5 "Distributor" Digikey "Distributor #" MMBT6428CT-ND "Manufactuer #" MMBT6428CT "PCB DECAL" SOT23 "Part Number" MMBT6428 0 -20 -80 0 1 1 70 20 0 1 2 -20 -80 0 1 C12 CAP-CC05 10800 8600 0 0 100 10 100 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 5% C0G 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C4 "Distributor" Digikey "Distributor #" 445-2664-1-ND "Manufactuer #" C1608C0G1E103J080AA 0 20 -90 0 0 1 20 -80 0 0 C11 CAP-CC05 11300 8600 0 0 100 10 100 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 10% X7R 0603 "Value" 0.01uf "PCB DECAL" 0603_NOSILK "Designator" C11 "Distributor" Digikey "Distributor #" 490-1520-1-ND "Manufactuer #" GRM188R71E103KA01D 0 20 -90 0 0 1 20 -80 0 0 C9 CAP-CC05 7300 4000 0 0 100 10 100 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 10% X7R 0603 "Value" 0.01uf "PCB DECAL" 0603_NOSILK "Designator" C9 "Distributor" Digikey "Distributor #" 490-1520-1-ND "Manufactuer #" GRM188R71E103KA01D 0 20 -90 0 0 1 20 -80 0 0 C8 CAP-CC05 6800 4000 0 0 100 10 100 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 5% C0G 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C4 "Distributor" Digikey "Distributor #" 445-2664-1-ND "Manufactuer #" C1608C0G1E103J080AA 0 20 -90 0 0 1 20 -80 0 0 C20 CAP-CC05 3300 6800 0 0 100 10 100 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 10000PF 25V 5% C0G 0603 "Value" 2.2uf "PCB DECAL" 0603_NOSILK "Designator" C20 "Distributor" Digikey "Distributor #" 445-2664-1-ND "Manufactuer #" C1608C0G1E103J080AA 0 20 -90 0 0 1 20 -80 0 0 T2 2SD2114KT146W 4000 3500 0 0 100 10 100 10 3 9 3 0 0 0 "Default Font" "Default Font" 590 60 0 0 100 10 0 "Default Font" REF-DES 640 180 0 0 100 10 0 "Default Font" PART-TYPE 590 -100 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" q2n4030 "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" T "Description" BJT NPN 20V 0.5A "Designator" T2 "Distributor" Mouser "Distributor #" 755-2SD2114KT146W "Manufactuer #" 2SD2114KT146W "PCB DECAL" SOT23 0 -20 -80 0 1 1 70 20 0 1 2 -20 -80 0 1 T3 2SD2114KT146W 5700 3100 0 0 100 10 100 10 3 9 3 0 0 0 "Default Font" "Default Font" 590 60 0 0 100 10 0 "Default Font" REF-DES 640 180 0 0 100 10 0 "Default Font" PART-TYPE 590 -100 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" q2n4030 "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" T "Description" BJT NPN 20V 0.5A "Designator" T2 "Distributor" Mouser "Distributor #" 755-2SD2114KT146W "Manufactuer #" 2SD2114KT146W "PCB DECAL" SOT23 0 -20 -80 0 1 1 70 20 0 1 2 -20 -80 0 1 R23 RES-1/8W 2700 5000 90 0 100 10 100 10 4 5 2 0 0 2 "Default Font" "Default Font" 300 120 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Value" NM "PCB DECAL" 0603_NOSILK 0 34 16 0 0 1 0 20 0 0 R3 RES-1/8W 4400 6100 0 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 1.62K OHM 1% 1/10W 0603 "Value" 1.62k "PCB DECAL" 0603_NOSILK "Designator" R3 "Distributor" Digikey "Distributor #" P1.62KHCT-ND "Manufactuer #" ERJ-3EKF1621V 0 34 16 0 0 1 0 20 0 0 R11 RES-1/8W 2300 4300 0 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 2.37K OHM 1% 1/10W 0603 "Value" 2.37k "PCB DECAL" 0603_NOSILK "Designator" R11 "Distributor" Digikey "Distributor #" P2.37KHCT-ND "Manufactuer #" ERJ-3EKF2371V 0 34 16 0 0 1 0 20 0 0 R20 RES-1/8W 2300 2700 0 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 4.87K OHM 1% 1/10W 0603 "Value" 4.87k "PCB DECAL" 0603_NOSILK "Designator" R20 "Distributor" Digikey "Distributor #" P4.87KHCT-ND "Manufactuer #" ERJ-3EKF4871V 0 34 16 0 0 1 0 20 0 0 R13 RES-1/8W 2300 3900 0 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 1.18K OHM 1% 1/10W 0603 "Value" 1.18k "PCB DECAL" 0603_NOSILK "Designator" R13 "Distributor" Digikey "Distributor #" P1.18KHCT-ND "Manufactuer #" ERJ-3EKF1181V 0 34 16 0 0 1 0 20 0 0 R14 RES-1/8W 2300 3500 0 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 154 OHM 1% 1/10W 0603 "Value" 154 "PCB DECAL" 0603_NOSILK "Designator" R14 "Distributor" Digikey "Distributor #" P154HCT-ND "Manufactuer #" ERJ-3EKF1540V 0 34 16 0 0 1 0 20 0 0 R18 RES-1/8W 2300 3100 0 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 9.76K OHM 1% 1/10W 0603 "Value" 9.76k "PCB DECAL" 0603_NOSILK "Designator" R18 "Distributor" Digikey "Distributor #" P9.76KHCT-ND "Manufactuer #" ERJ-3EKF9761V 0 34 16 0 0 1 0 20 0 0 R12 RES-1/8W 3500 3700 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 4.99K OHM 1% 1/10W 0603 "Value" 4.99k "PCB DECAL" 0603_NOSILK "Designator" R12 "Distributor" Digikey "Distributor #" P4.99KHCT-ND "Manufactuer #" ERJ-3EKF4991V 0 34 16 0 0 1 0 20 0 0 R15 RES-1/8W 3500 2700 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -110 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 301 OHM 1% 1/10W 0603 "Value" 301 "PCB DECAL" 0603_NOSILK "Designator" R15 "Distributor" Digikey "Distributor #" P301HCT-ND "Manufactuer #" ERJ-3EKF3010V 0 34 16 0 0 1 0 20 0 0 R16 RES-1/8W 4800 3100 0 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 10 OHM 1% 1/10W 0603 "Value" 10 "PCB DECAL" 0603_NOSILK "Designator" R16 "Distributor" Digikey "Distributor #" P10.0HCT-ND "Manufactuer #" ERJ-3EKF10R0V 0 34 16 0 0 1 0 20 0 0 R19 RES-1/8W 4400 2400 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 806 OHM 1% 1/10W 0603 "Value" 806 "PCB DECAL" 0603_NOSILK "Designator" R19 "Distributor" Digikey "Distributor #" P806HCT-ND "Manufactuer #" ERJ-3EKF8060V 0 34 16 0 0 1 0 20 0 0 R38 RES-1/8W 6100 2100 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 0.82 OHM 1% 1/10W 0603 "Value" 0.82 "PCB DECAL" 0603_NOSILK "Designator" R38 "Distributor" Digikey "Distributor #" P.82AJCT-ND "Manufactuer #" ERJ-3RQFR82V 0 34 16 0 0 1 0 20 0 0 R35 RES-1/8W 9700 3100 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 604K OHM 1% 1/10W 0603 "Value" 604k "PCB DECAL" 0603_NOSILK "Designator" R35 "Distributor" Digikey "Distributor #" P604KHCT-ND "Manufactuer #" ERJ-3EKF6043V 0 34 16 0 0 1 0 20 0 0 TX1 LED 6100 4300 90 2 100 10 100 10 4 9 2 0 0 0 "Default Font" "Default Font" 100 200 0 4 100 10 0 "Default Font" REF-DES 250 -150 0 6 100 10 0 "Default Font" PART-TYPE 250 -250 0 6 100 10 0 "Default Font" * 250 -350 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" D "Description" Infrared Emitters 5V 160mW 60Deg "PCB DECAL" 0805_NOSILK "Designator" TX1 "Distributor" Mouser "Manufactuer #" VSMB1940X01 "Distributor #" 782-VSMB1940X01 0 130 14 0 1 1 130 14 0 1 R21 RES-1/8W 5700 7700 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 20K OHM 1% 1/10W 0603 "Value" 20k "PCB DECAL" 0603_NOSILK "Designator" R21 "Distributor" Digikey "Distributor #" P20.0KHCT-ND "Manufactuer #" ERJ-3EKF2002V 0 34 16 0 0 1 0 20 0 0 R22 RES-1/8W 5700 6900 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 1.47K OHM 1% 1/10W 0603 "Value" 1.47k "PCB DECAL" 0603_NOSILK "Designator" R22 "Distributor" Digikey "Distributor #" P1.47KHCT-ND "Manufactuer #" ERJ-3EKF1471V 0 34 16 0 0 1 0 20 0 0 R31 RES-1/8W 5000 6900 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 2M OHM 5% 1/10W 0603 "Value" 2M "PCB DECAL" 0603_NOSILK "Designator" R31 "Distributor" Digikey "Distributor #" "Manufactuer #" 0 34 16 0 0 1 0 20 0 0 R32 RES-1/8W 5000 7700 90 0 100 10 100 10 4 10 2 0 0 2 "Default Font" "Default Font" 300 100 0 4 100 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 300 -100 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 2M OHM 5% 1/10W 0603 "Value" 2M "PCB DECAL" 0603_NOSILK "Designator" R32 "Distributor" Digikey "Distributor #" "Manufactuer #" 0 34 16 0 0 1 0 20 0 0 L1 IND-MOLDED 10600 8100 90 0 100 10 100 10 3 10 2 0 0 2 "Default Font" "Default Font" 310 180 90 4 100 10 0 "Default Font" REF-DES 250 250 0 6 100 10 0 "Default Font" PART-TYPE 130 220 90 5 97 10 3 "Default Font" Value "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" L "Description" FIXED IND 10UH 50MA 900 MOHM "Value" 10uH "PCB DECAL" 0603_NOSILK "Designator" L1 "Distributor" Digikey "Distributor #" 490-4025-1-ND "Manufactuer #" LQM18FN100M00D 0 70 30 0 1 1 60 30 0 1 C15 CAP-CC05 10600 7900 0 0 100 10 100 10 4 10 2 0 0 26 "Default Font" "Default Font" 150 -210 0 0 97 10 0 "Default Font" REF-DES 210 -40 0 2 100 10 0 "Default Font" PART-TYPE 150 -240 0 2 97 10 3 "Default Font" Value 150 -340 0 2 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" C "Description" CAP CER 0.1UF 16V 10% X7R 0603 "Value" 0.1uf "PCB DECAL" 0603_NOSILK "Designator" C15 "Distributor" Digikey "Distributor #" 478-1239-1-ND "Manufactuer #" 0603YC104KAT2A 0 20 -90 0 0 1 20 -80 0 0 T4 TEPT5700 9300 4200 0 0 97 10 97 10 3 9 2 0 0 0 "Default Font" "Default Font" 590 60 0 0 97 10 0 "Default Font" REF-DES 640 180 0 0 97 10 0 "Default Font" PART-TYPE 590 -100 0 2 97 10 0 "Default Font" * "Sim.Analog.Model" q2n4030 "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" Q "Description" AMBIENT LIGHT SENSOR 5MM 570NM "Designator" T4 "Distributor" Mouser "Distributor #" 782-TEPT5700 "Manufactuer #" TEPT5700 "PCB DECAL" PHOTO_TRAN 0 -20 -80 0 1 1 -20 -80 0 1 J6-1 HEADER06 13700 4000 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" SIX PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-3X2P 0 0 0 0 0 J6-2 HEADER06 12500 4000 0 1 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" SIX PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-3X2P 0 0 0 0 0 J6-3 HEADER06 13700 3900 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" SIX PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-3X2P 0 0 0 0 0 J6-4 HEADER06 12500 3900 0 1 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" SIX PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-3X2P 0 0 0 0 0 J6-5 HEADER06 13700 3800 0 0 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" SIX PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-3X2P 0 0 0 0 0 J6-6 HEADER06 12500 3800 0 1 100 10 100 10 4 5 1 0 0 30 "Default Font" "Default Font" -400 -30 0 4 100 10 0 "Default Font" REF-DES -790 -110 0 6 100 10 0 "Default Font" PART-TYPE -850 100 0 6 100 10 0 "Default Font" * -850 0 0 6 100 10 0 "Default Font" * "Description" SIX PIN INLINE HEADER; 100 MIL CENTERS "Part Number" "Manufacturer #1" "Cost" "PCB DECAL" SIP-3X2P 0 0 0 0 0 R29 RES-1/8W 13100 5300 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 190 110 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 400 180 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 1.6K OHM 5% 1/10W 0603 "Value" 1.6k "PCB DECAL" 0603_NOSILK "Designator" R25 "Distributor" Digikey "Distributor #" P1.6KGCT-ND "Manufactuer #" ERJ-3GEYJ162V 0 34 16 0 0 1 0 20 0 0 R30 RES-1/8W 13100 5200 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 180 -160 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 390 -90 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 820 OHM 5% 1/10W 0603 "Value" 820 "PCB DECAL" 0603_NOSILK "Designator" R26 "Distributor" Digikey "Distributor #" P820GCT-ND "Manufactuer #" ERJ-3GEYJ821V 0 34 16 0 0 1 0 20 0 0 R28 RES-1/8W 13100 5700 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 170 -150 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 410 -80 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 820 OHM 5% 1/10W 0603 "Value" 820 "PCB DECAL" 0603_NOSILK "Designator" R28 "Distributor" Digikey "Distributor #" P820GCT-ND "Manufactuer #" ERJ-3GEYJ821V 0 34 16 0 0 1 0 20 0 0 R26 RES-1/8W 13100 6200 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 210 -150 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 410 -80 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 820 OHM 5% 1/10W 0603 "Value" 820 "PCB DECAL" 0603_NOSILK "Designator" R30 "Distributor" Digikey "Distributor #" P820GCT-ND "Manufactuer #" ERJ-3GEYJ821V 0 34 16 0 0 1 0 20 0 0 R27 RES-1/8W 13100 5800 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 190 110 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 400 180 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 1.6K OHM 5% 1/10W 0603 "Value" 1.6k "PCB DECAL" 0603_NOSILK "Designator" R27 "Distributor" Digikey "Distributor #" P1.6KGCT-ND "Manufactuer #" ERJ-3GEYJ162V 0 34 16 0 0 1 0 20 0 0 R25 RES-1/8W 13100 6300 0 0 97 10 97 10 4 10 2 0 0 2 "Default Font" "Default Font" 190 110 0 4 97 10 0 "Default Font" REF-DES 310 200 0 4 100 10 0 "Default Font" PART-TYPE 400 180 0 6 97 10 3 "Default Font" Value 300 -200 0 6 100 10 0 "Default Font" * "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" R "Description" RES SMD 1.6K OHM 5% 1/10W 0603 "Value" 1.6k "PCB DECAL" 0603_NOSILK "Designator" R29 "Distributor" Digikey "Distributor #" P1.6KGCT-ND "Manufactuer #" ERJ-3GEYJ162V 0 34 16 0 0 1 0 20 0 0 LED1 RGB_LED 12100 5800 0 2 100 10 100 10 2 8 4 0 0 0 "Default Font" "Default Font" 100 200 0 4 100 10 0 "Default Font" REF-DES 310 -530 0 6 100 10 0 "Default Font" PART-TYPE "Sim.Analog.Model" "Sim.Analog.Order" Model$ "Sim.Analog.Prefix" D "Description" LIGHT EMITTING DIODE "Color" ??? "Part Number" "Manufacturer #1" "PCB DECAL" 4-PLCC 0 30 20 0 1 1 50 20 0 1 2 60 20 0 1 3 70 30 0 1 *BUSSES* *OFFPAGE REFS* @@@O0 GND $GND_SYMS 9200 5900 0 0 0 @@@O1 GND $GND_SYMS 10600 7400 0 0 0 @@@O2 GND $GND_SYMS 11300 7900 0 0 0 @@@O3 VCC1 $PWR_SYMS 11300 8800 0 0 0 @@@O4 AMP2_OUT $OSR_SYMS 9100 7600 0 1 0 @@@O5 AMP1_OUT $OSR_SYMS 9100 7500 0 1 0 @@@O6 GRN_820 $OSR_SYMS 9100 7400 0 1 0 @@@O7 GRN_1.6K $OSR_SYMS 9100 7300 0 1 0 @@@O8 BLUE_820 $OSR_SYMS 9100 7200 0 1 0 @@@O9 BLUE_1.6K $OSR_SYMS 9100 7100 0 1 0 @@@O10 PB0 $OSR_SYMS 7400 7300 0 0 0 @@@O11 PB1 $OSR_SYMS 7400 7200 0 0 0 @@@O12 PB2 $OSR_SYMS 7400 7100 0 0 0 @@@O13 PB6 $OSR_SYMS 7400 7000 0 0 0 @@@O14 PB7 $OSR_SYMS 7400 6900 0 0 0 @@@O15 ADC6 $OSR_SYMS 7400 6800 0 0 0 @@@O16 PH_OUT $OSR_SYMS 7400 6700 0 0 0 @@@O17 PD0 $OSR_SYMS 7400 8300 0 0 0 @@@O18 DEBUG $OSR_SYMS 7400 8200 0 0 0 @@@O19 CE $OSR_SYMS 7400 8100 0 0 0 @@@O20 PD3 $OSR_SYMS 7400 8000 0 0 0 @@@O21 RED_820 $OSR_SYMS 7400 7900 0 0 0 @@@O22 RED_1.6K $OSR_SYMS 7400 7800 0 0 0 @@@O23 AMP2_OUT $OSR_SYMS 7400 7700 0 0 0 @@@O24 VCC $PWR_SYMS 5700 8400 0 0 0 @@@O25 GND $GND_SYMS 5700 6900 0 0 0 @@@O26 GND $GND_SYMS 5000 6900 0 0 0 @@@O27 VBATT $PWR_SYMS 5000 8400 0 0 0 @@@O28 ADC6 $OSR_SYMS 4800 7600 0 0 0 @@@O29 PB2 $OSR_SYMS 2300 4300 0 0 0 @@@O30 PB1 $OSR_SYMS 2300 3900 0 0 0 @@@O31 PB0 $OSR_SYMS 2300 3500 0 0 0 @@@O32 PB7 $OSR_SYMS 2300 3100 0 0 0 @@@O33 PB6 $OSR_SYMS 2300 2700 0 0 0 @@@O34 GND $GND_SYMS 3500 2600 0 0 0 @@@O35 GND $GND_SYMS 4400 2300 0 0 0 @@@O36 VCC $PWR_SYMS 4400 4200 0 0 0 @@@O37 GND $GND_SYMS 6100 1900 0 0 0 @@@O38 VCC $PWR_SYMS 7300 4700 0 0 0 @@@O39 GND $GND_SYMS 4100 5400 0 0 0 @@@O40 GND $GND_SYMS 2700 5000 0 0 0 @@@O41 GND $GND_SYMS 3300 6300 0 0 0 @@@O42 VCC1 $PWR_SYMS 3300 7100 0 0 0 @@@O43 GND $GND_SYMS 5300 5400 0 0 0 @@@O44 SCK $OSR_SYMS 7400 6200 0 0 0 @@@O45 MISO $OSR_SYMS 7400 6300 0 0 0 @@@O46 MOSI $OSR_SYMS 7400 6400 0 0 0 @@@O47 GND $GND_SYMS 9700 3100 0 0 0 @@@O48 VCC $PWR_SYMS 9700 4600 0 0 0 @@@O49 PH_OUT $OSR_SYMS 9900 3800 0 1 0 @@@O50 RESET $OSR_SYMS 13700 4000 0 1 0 @@@O51 SCK $OSR_SYMS 13700 3900 0 1 0 @@@O52 MISO $OSR_SYMS 13700 3800 0 1 0 @@@O53 GND $GND_SYMS 12100 4400 0 0 0 @@@O54 MOSI $OSR_SYMS 12500 3900 0 0 0 @@@O55 VCC1 $PWR_SYMS 11700 4000 0 0 0 @@@O56 BLUE_1.6K $OSR_SYMS 13700 6300 0 1 0 @@@O57 BLUE_820 $OSR_SYMS 13700 6200 0 1 0 @@@O58 GRN_1.6K $OSR_SYMS 13700 5800 0 1 0 @@@O59 GRN_820 $OSR_SYMS 13700 5700 0 1 0 @@@O60 RED_1.6K $OSR_SYMS 13700 5300 0 1 0 @@@O61 RED_820 $OSR_SYMS 13700 5200 0 1 0 @@@O62 VCC1 $PWR_SYMS 11900 6000 0 0 0 *TIEDOTS* @@@D0 9200 6300 @@@D1 9200 6200 @@@D2 9200 6100 @@@D3 9200 8300 @@@D4 9200 8000 @@@D5 10600 8700 @@@D6 10800 8700 @@@D7 10600 8000 @@@D8 11300 8000 @@@D9 11300 8700 @@@D10 5700 7600 @@@D11 5000 7600 @@@D12 3000 3900 @@@D13 3000 3500 @@@D14 3000 3100 @@@D15 3000 3500 @@@D16 3500 3500 @@@D17 3500 3500 @@@D18 4400 3100 @@@D19 6100 2000 @@@D20 6800 2000 @@@D21 6800 4400 @@@D22 7300 4400 @@@D23 3500 5700 @@@D24 3300 6900 @@@D25 4100 6100 @@@D26 5300 6100 @@@D27 9700 3800 @@@D28 13000 6200 @@@D29 13000 5800 @@@D30 13000 5300 *CONNECTION* *SIGNAL* GND 2 0 U1.21 @@@D0 3 0 9100 6400 9200 6400 9200 6300 U1.5 @@@D0 2 0 9100 6300 9200 6300 @@@D0 @@@D1 2 0 9200 6300 9200 6200 U1.3 @@@D1 2 0 9100 6200 9200 6200 @@@D1 @@@D2 2 0 9200 6200 9200 6100 U1.33 @@@D2 2 0 9100 6100 9200 6100 @@@D2 @@@O0 2 0 9200 6100 9200 5900 C12.2 @@@D8 3 0 10800 8100 10800 8000 11300 8000 C15.2 @@@O1 2 0 10600 7400 10600 7400 @@@D8 C11.2 2 0 11300 8000 11300 8100 @@@D8 @@@O2 2 0 11300 8000 11300 7900 R22.1 @@@O25 2 0 5700 6900 5700 6900 R31.1 @@@O26 2 0 5000 6900 5000 6900 R15.1 @@@O34 2 0 3500 2700 3500 2600 R19.1 @@@O35 2 0 4400 2400 4400 2300 R38.1 @@@D19 2 0 6100 2100 6100 2000 @@@D19 @@@O37 2 0 6100 2000 6100 1900 @@@D19 @@@D20 2 0 6100 2000 6800 2000 C9.2 @@@D20 3 0 7300 3500 7300 2000 6800 2000 @@@D20 C8.2 2 0 6800 2000 6800 3500 T1.E @@@O39 2 0 4100 5400 4100 5400 R23.1 @@@O40 2 0 2700 5000 2700 5000 C20.2 @@@O41 2 0 3300 6300 3300 6300 C4.2 @@@O43 2 0 5300 5400 5300 5400 R35.1 @@@O47 2 0 9700 3100 9700 3100 J6.2 @@@O53 5 0 12500 4000 12300 4000 12300 4500 12100 4500 12100 4400 *SIGNAL* DEBUG 0 0 U1.31 @@@O18 2 0 7400 8200 7400 8200 *SIGNAL* VBATT 0 0 R32.2 @@@O27 2 0 5000 8300 5000 8400 *SIGNAL* PD0 0 0 U1.30 @@@O17 2 0 7400 8300 7400 8300 *SIGNAL* VCC1 0 0 U1.6 @@@D3 3 0 9100 8200 9200 8200 9200 8300 @@@D3 U1.4 2 0 9200 8300 9100 8300 @@@D3 @@@D5 3 0 9200 8300 9200 8700 10600 8700 C12.1 @@@D6 2 0 10800 8600 10800 8700 @@@D5 L1.2 2 0 10600 8700 10600 8600 C11.1 @@@D9 2 0 11300 8600 11300 8700 @@@D6 @@@D5 2 0 10800 8700 10600 8700 @@@D9 @@@D6 2 0 11300 8700 10800 8700 @@@D9 @@@O3 2 0 11300 8700 11300 8800 R1.2 @@@D24 3 0 4100 6800 4100 6900 3300 6900 @@@D24 C20.1 2 0 3300 6900 3300 6800 @@@D24 @@@O42 2 0 3300 6900 3300 7100 J6.6 @@@O55 3 0 12500 3800 11700 3800 11700 4000 LED1.4 @@@O62 2 0 12100 6000 11900 6000 *SIGNAL* CE 0 0 U1.32 @@@O19 2 0 7400 8100 7400 8100 *SIGNAL* VCC 2 0 R21.2 @@@O24 2 0 5700 8300 5700 8400 T2.C @@@O36 2 0 4400 3800 4400 4200 TX1.1 @@@D21 3 0 6100 4300 6100 4400 6800 4400 C9.1 @@@D22 2 0 7300 4000 7300 4400 @@@D21 C8.1 2 0 6800 4400 6800 4000 @@@D22 @@@D21 2 0 7300 4400 6800 4400 @@@D22 @@@O38 2 0 7300 4400 7300 4700 T4.1 @@@O48 2 0 9700 4500 9700 4600 *SIGNAL* $$$955 64 0 R26.1 @@@D28 2 0 13100 6200 13000 6200 LED1.3 @@@D28 2 0 12600 6200 13000 6200 @@@D28 R25.1 3 0 13000 6200 13000 6300 13100 6300 *SIGNAL* $$$1173 64 0 R28.1 @@@D29 3 0 13100 5700 13000 5700 13000 5800 LED1.2 @@@D29 3 0 12600 6000 13000 6000 13000 5800 @@@D29 R27.1 2 0 13000 5800 13100 5800 *SIGNAL* PD3 0 0 U1.1 @@@O20 2 0 7400 8000 7400 8000 *SIGNAL* BLUE_1.6K 0 0 U1.28 @@@O9 2 0 9100 7100 9100 7100 R25.2 @@@O56 2 0 13700 6300 13700 6300 *SIGNAL* BLUE_820 0 0 U1.27 @@@O8 2 0 9100 7200 9100 7200 R26.2 @@@O57 2 0 13700 6200 13700 6200 *SIGNAL* GRN_1.6K 0 0 U1.26 @@@O7 2 0 9100 7300 9100 7300 R27.2 @@@O58 2 0 13700 5800 13700 5800 *SIGNAL* GRN_820 0 0 U1.25 @@@O6 2 0 9100 7400 9100 7400 R28.2 @@@O59 2 0 13700 5700 13700 5700 *SIGNAL* RED_1.6K 0 0 U1.9 @@@O22 2 0 7400 7800 7400 7800 R29.2 @@@O60 2 0 13700 5300 13700 5300 *SIGNAL* RED_820 0 0 U1.2 @@@O21 2 0 7400 7900 7400 7900 R30.2 @@@O61 2 0 13700 5200 13700 5200 *SIGNAL* $$$1177 64 0 R30.1 @@@D30 3 0 13100 5200 13000 5200 13000 5300 LED1.1 @@@D30 4 0 12600 5800 12800 5800 12800 5300 13000 5300 @@@D30 R29.1 2 0 13000 5300 13100 5300 *SIGNAL* AMP1_OUT 0 0 U1.24 @@@O5 2 0 9100 7500 9100 7500 *SIGNAL* $$$349 64 0 R21.1 @@@D10 2 0 5700 7700 5700 7600 U1.11 @@@D10 2 0 7400 7600 5700 7600 @@@D10 R22.2 2 0 5700 7600 5700 7500 *SIGNAL* $$$17816 64 0 R16.2 T3.B 2 0 5400 3100 5700 3100 *SIGNAL* $$$17740 64 0 R19.2 @@@D18 2 0 4400 3000 4400 3100 R16.1 @@@D18 2 0 4800 3100 4400 3100 @@@D18 T2.E 2 0 4400 3100 4400 3200 *SIGNAL* $$$17828 64 0 T3.C TX1.2 2 0 6100 3400 6100 3800 *SIGNAL* AMP2_OUT 0 0 U1.23 @@@O4 2 0 9100 7600 9100 7600 U1.10 @@@O23 2 0 7400 7700 7400 7700 *SIGNAL* $$$17834 64 0 R38.2 T3.E 2 0 6100 2700 6100 2800 *SIGNAL* RESET 0 0 R3.2 @@@D26 2 0 5000 6100 5300 6100 @@@D26 C4.1 2 0 5300 6100 5300 5900 @@@D26 U1.29 2 0 5300 6100 7400 6100 J6.1 @@@O50 2 0 13700 4000 13700 4000 *SIGNAL* $$$32240 64 0 U1.18 @@@D4 3 0 9100 8100 9200 8100 9200 8000 L1.1 @@@D7 2 0 10600 8100 10600 8000 @@@D4 U1.20 2 0 9200 8000 9100 8000 C15.1 @@@D7 2 0 10600 7900 10600 8000 @@@D7 @@@D4 2 0 10600 8000 9200 8000 *SIGNAL* PB0 0 0 U1.12 @@@O10 2 0 7400 7300 7400 7300 R14.1 @@@O31 2 0 2300 3500 2300 3500 *SIGNAL* PB1 0 0 U1.13 @@@O11 2 0 7400 7200 7400 7200 R13.1 @@@O30 2 0 2300 3900 2300 3900 *SIGNAL* PB2 0 0 U1.14 @@@O12 2 0 7400 7100 7400 7100 R11.1 @@@O29 2 0 2300 4300 2300 4300 *SIGNAL* PB6 0 0 U1.7 @@@O13 2 0 7400 7000 7400 7000 R20.1 @@@O33 2 0 2300 2700 2300 2700 *SIGNAL* PB7 0 0 U1.8 @@@O14 2 0 7400 6900 7400 6900 R18.1 @@@O32 2 0 2300 3100 2300 3100 *SIGNAL* ADC6 0 0 U1.19 @@@O15 2 0 7400 6800 7400 6800 R32.1 @@@D11 2 0 5000 7700 5000 7600 @@@D11 R31.2 2 0 5000 7600 5000 7500 @@@D11 @@@O28 2 0 5000 7600 4800 7600 *SIGNAL* PH_OUT 0 0 U1.22 @@@O16 2 0 7400 6700 7400 6700 T4.2 @@@D27 2 0 9700 3900 9700 3800 @@@D27 R35.2 2 0 9700 3800 9700 3700 @@@D27 @@@O49 2 0 9700 3800 9900 3800 *SIGNAL* $$$17602 64 0 R11.2 @@@D12 3 0 2900 4300 3000 4300 3000 3900 R14.2 @@@D13 2 0 2900 3500 3000 3500 @@@D12 R13.2 2 0 3000 3900 2900 3900 R20.2 @@@D14 3 0 2900 2700 3000 2700 3000 3100 @@@D13 @@@D12 2 0 3000 3500 3000 3900 R18.2 @@@D14 2 0 2900 3100 3000 3100 @@@D14 @@@D15 2 0 3000 3100 3000 3500 @@@D15 @@@D13 2 0 3000 3500 3000 3500 @@@D15 @@@D16 2 0 3000 3500 3500 3500 R15.2 @@@D17 2 0 3500 3300 3500 3500 @@@D16 R12.1 2 0 3500 3500 3500 3700 @@@D17 @@@D16 2 0 3500 3500 3500 3500 @@@D17 T2.B 2 0 3500 3500 4000 3500 *SIGNAL* $$$17989 64 0 T1.B @@@D23 2 0 3700 5700 3500 5700 @@@D23 R12.2 2 0 3500 5700 3500 4300 @@@D23 R23.2 3 0 3500 5700 2700 5700 2700 5600 *SIGNAL* SCK 0 0 U1.17 @@@O44 2 0 7400 6200 7400 6200 J6.3 @@@O51 2 0 13700 3900 13700 3900 *SIGNAL* $$$18034 64 0 T1.C @@@D25 2 0 4100 6000 4100 6100 @@@D25 R1.1 2 0 4100 6100 4100 6200 @@@D25 R3.1 2 0 4100 6100 4400 6100 *SIGNAL* MISO 0 0 U1.16 @@@O45 2 0 7400 6300 7400 6300 J6.5 @@@O52 2 0 13700 3800 13700 3800 *SIGNAL* MOSI 0 0 U1.15 @@@O46 2 0 7400 6400 7400 6400 J6.4 @@@O54 2 0 12500 3900 12500 3900 *NETNAMES* VCC1 @@@O3 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" AMP2_OUT @@@O4 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" AMP1_OUT @@@O5 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" GRN_820 @@@O6 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" GRN_1.6K @@@O7 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" BLUE_820 @@@O8 360 0 0 0 0 0 0 3 -1 10 97 "Default Font" BLUE_1.6K @@@O9 360 0 0 0 0 0 0 3 -1 10 97 "Default Font" PB0 @@@O10 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB1 @@@O11 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB2 @@@O12 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB6 @@@O13 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB7 @@@O14 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" ADC6 @@@O15 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PH_OUT @@@O16 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PD0 @@@O17 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" DEBUG @@@O18 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" CE @@@O19 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PD3 @@@O20 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" RED_820 @@@O21 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" RED_1.6K @@@O22 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" AMP2_OUT @@@O23 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" VCC @@@O24 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VBATT @@@O27 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" ADC6 @@@O28 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB2 @@@O29 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB1 @@@O30 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB0 @@@O31 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB7 @@@O32 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" PB6 @@@O33 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" VCC @@@O36 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC @@@O38 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" VCC1 @@@O42 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" RESET U1.29 -350 10 0 1 0 0 0 0 -1 10 100 "Default Font" SCK @@@O44 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" MISO @@@O45 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" MOSI @@@O46 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" VCC @@@O48 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" PH_OUT @@@O49 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" RESET @@@O50 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" SCK @@@O51 360 0 0 0 0 0 0 3 -1 10 97 "Default Font" MISO @@@O52 360 0 0 0 0 0 0 3 -1 10 97 "Default Font" MOSI @@@O54 -360 0 0 1 0 0 0 3 -1 10 100 "Default Font" VCC1 @@@O55 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" BLUE_1.6K @@@O56 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" BLUE_820 @@@O57 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" GRN_1.6K @@@O58 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" GRN_820 @@@O59 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" RED_1.6K @@@O60 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" RED_820 @@@O61 360 0 0 0 0 0 0 3 -1 10 100 "Default Font" VCC1 @@@O62 0 250 0 4 0 0 0 0 -1 10 100 "Default Font" *END* OF ASCII OUTPUT FILE
