/*************************************************************************** This is a library for the BME280 humidity, temperature & pressure sensor Designed specifically to work with the BME280 Breakout board – --> http://www.adafruit.com/products/2650 This sketch only supports the I2C bus for connection. ***************************************************************************/ #include #include "cactus_io_BME280_I2C.h" BME280_I2C bme(0x76); // I2C using address 0x76 void setup() { Serial.begin(9600); Serial.println("BME280 Luftdruck, Luftfeuchtigkeit, Temperatur Sensor | cactus.io"); Serial.println("-----------------------------------------------------------------"); Serial.println(""); if (!bme.begin()) { Serial.println("Es konnte kein BME280 Sensor gefunden werden!"); Serial.println("Bitte überprüfen Sie die Verkabelung!"); while (1); } bme.setTempCal(-1); Serial.println("Luftdruck\tLuftfeuchtigkeit\t\tTemperatur(Celsius)\t\tTemperatur(Fahrenheit)"); } void loop() { bme.readSensor(); Serial.print(bme.getPressure_MB()); Serial.print("\t\t"); // Pressure in millibars Serial.print(bme.getHumidity()); Serial.print("%\t\t\t\t"); Serial.print(bme.getTemperature_C()); Serial.print(" °C\t\t\t"); Serial.print(bme.getTemperature_F()); Serial.println(" °F"); delay(2000); }
