/* SD card datalogger This example shows how to log data from three analog sensors to an SD card using the SD library. The circuit: analog sensors on analog ins 0, 1, and 2 SD card attached to SPI bus as follows: ** MOSI - pin 11 ** MISO - pin 12 ** CLK - pin 13 ** CS - pin 4 (for MKRZero SD: SDCARD_SS_PIN) created 24 Nov 2010 modified 9 Apr 2012 by Tom Igoe This example code is in the public domain. */ #include #include #include // eingefügt #include"cactus_io_BME280_I2C.h" // "" BME280_I2C bme(0x76); // "" I2C adr 0x76 const int chipSelect = 5; void setup() { // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for native USB port only } // see if the card is present and can be initialized: if (!SD.begin(chipSelect)) { Serial.println("Card failed, or not present"); // don't do anything more: if (!bme.begin()) // funktioniert nicht { Serial.println("Es konnte kein Sensor gefunden werden .."); } while (1); } Serial.println("card initialized."); } void loop() { bme.readSensor(); // eingefügt Serial.println("Luftdruck "); Serial.print(bme.getPressure_MB()); //Serial.print(bme.readPressure_MB()); delay(1000); // eingefügt }
