[ 104.890498] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.891674] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.891681] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.891735] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 104.891742] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.893146] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.893155] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.894039] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.894047] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.894524] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.894531] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.894736] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.894743] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.895139] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.895146] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.895352] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.895358] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.895435] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.895442] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.895891] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.895898] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.897070] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.897076] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.897208] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.897215] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 104.897763] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.897770] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.897823] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.897830] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.898379] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.898386] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.898625] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.898632] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.899784] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.899791] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.900409] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.900415] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.900435] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 104.900442] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.900462] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.900469] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.900814] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.900821] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.901642] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.901649] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.901883] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 104.901890] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.903158] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.903167] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.904488] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.904496] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.905249] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.905256] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.905736] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.905742] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.906283] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 104.906290] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.908298] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.908305] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.908736] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.908742] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.908855] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.908862] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.909420] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.909427] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.910018] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.910025] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.910330] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.910337] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 104.910786] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.910793] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.911521] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.911528] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.912481] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.912489] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.912737] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.912744] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.913388] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.913395] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.913527] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.913534] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.914179] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.914187] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.914941] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.914948] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.915375] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.915382] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.916045] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.916052] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.916072] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.916079] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.917089] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 104.917096] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.917428] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.917435] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.917627] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.917633] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.917850] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.917857] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.918445] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.918452] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.918949] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.918956] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.919317] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.919324] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.921292] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.921300] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.921347] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.921354] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.921928] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.921935] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.922300] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.922307] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.922488] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.922498] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.922824] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 104.922831] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.922886] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.922892] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.923643] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.923651] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.924418] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.924426] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.925582] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.925590] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 104.926741] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.926750] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.927058] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 104.927066] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.928575] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.928583] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.929258] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.929266] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.929576] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.929584] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.930197] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.930206] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.933729] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.933734] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.934188] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.934193] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.935008] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.935013] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.935930] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.935935] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.939741] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.939747] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.941962] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.941967] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.948982] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.948988] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.949357] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.949362] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.950659] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.950664] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.951184] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.951189] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.952817] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.952822] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.952904] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.952909] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.954034] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.954039] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.954977] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 104.954982] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.956612] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.956617] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.958733] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.958738] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.969742] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.969748] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.973891] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 104.973897] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.976170] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 104.976176] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.978313] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.978318] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.978984] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.978989] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.980537] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 104.980542] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.983703] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 104.983709] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.983784] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.983789] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.989835] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.989841] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 104.990561] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 104.990566] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.990628] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 104.990633] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 104.994548] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 104.994554] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.003145] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 105.003151] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.005243] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.005248] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.006558] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 105.006563] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.007672] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 105.007677] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.008279] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.008284] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.008951] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.008956] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.009808] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.009813] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.010492] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.010497] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.011299] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.011304] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.016149] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.016155] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.017657] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.017663] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.018304] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.018310] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.018986] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.018992] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.019043] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.019048] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.020353] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.020358] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.021829] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.021834] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.022291] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.022296] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.022502] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.022507] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.022659] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.022664] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.026730] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.026735] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.027679] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 105.027684] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.029024] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.029029] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.034360] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.034366] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.035452] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 105.035457] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.036820] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 105.036825] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.038031] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 105.038036] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.038895] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.038900] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.043041] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.043047] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.043877] usb 1-1.1: device descriptor read/all, error -71 [ 105.044008] usb 1-1-port1: attempt power cycle [ 105.802484] usb 1-1.1: new high-speed USB device number 6 using dwc2 [ 105.833553] usb 1-1.1: New USB device found, idVendor=0403, idProduct=6011, bcdDevice= 8.00 [ 105.833572] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 105.833597] usb 1-1.1: Product: Quad RS232-HS [ 105.833613] usb 1-1.1: Manufacturer: FTDI [ 105.834680] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.834694] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.838546] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.838559] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.840516] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.840528] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.841136] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 105.841147] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.844606] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 105.844620] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.845673] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.845685] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.850867] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.850879] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.856123] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 105.856135] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.860177] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.860188] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.860611] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.860622] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.861382] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.861392] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.862792] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.862804] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.871106] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 105.871118] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.875736] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.875748] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.877737] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.877748] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.879313] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 105.879324] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.881051] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.881062] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.887866] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 105.887878] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.888249] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.888259] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.889453] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.889464] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 105.890656] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.890667] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.897467] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.897479] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 105.900239] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.900250] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.911965] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.911978] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 105.927628] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.927641] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.928727] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.928738] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.928865] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 105.928876] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.936229] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.936241] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.942444] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.942457] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.943417] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.943429] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.946374] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.946379] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.951924] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 105.951929] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.961566] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 105.961571] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.967411] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 105.967416] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.967927] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 105.967932] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.970043] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.970048] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.993649] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 105.993655] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 105.995456] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 105.995460] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 105.996813] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 105.996818] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.008098] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.008104] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.009315] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.009319] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.014982] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.014987] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.033109] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.033114] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.043300] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.043306] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.050369] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.050374] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.051626] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.051631] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.056004] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.056010] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.064950] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.064955] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.065322] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.065327] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.069804] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.069808] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.073856] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.073862] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.086857] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.086863] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.089058] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.089062] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.089408] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.089412] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.096463] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.096469] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.103505] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.103511] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.105942] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.105947] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.106308] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.106313] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.107045] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.107049] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.114627] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.114632] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.122512] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.122517] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.130799] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.130803] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.133733] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.133738] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.139120] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.139125] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.146299] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.146304] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.151771] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.151776] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.164608] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.164614] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.166351] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.166356] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.166739] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.166744] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.167290] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.167294] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.170251] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.170255] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.171031] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.171036] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.171621] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.171625] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.172477] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.172482] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.176773] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.176778] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.179690] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.179695] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.180152] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.180157] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.189796] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.189802] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.190554] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.190559] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.193763] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.193768] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.204831] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.204837] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.213648] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.213653] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.213993] ftdi_sio 1-1.1:1.0: FTDI USB Serial Device converter detected [ 106.214067] usb 1-1.1: Detected FT4232H [ 106.218576] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.218581] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.227561] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.227567] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.230980] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.230985] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.246534] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.246540] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.249915] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.249920] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.255335] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.255341] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.260173] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.260178] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.261661] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.261666] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.271798] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.271804] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.276332] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.276338] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.284418] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.284423] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.298009] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.298014] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.300746] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.300751] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.301617] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.301622] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.328463] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.328469] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.331411] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.331416] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.333175] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.333180] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.334699] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.334705] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.352139] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.352146] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.357699] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.357704] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.369781] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.369787] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.374001] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.374007] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.384337] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.384342] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.385741] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.385746] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.390335] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.390340] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.392317] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.392322] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.399865] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.399870] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.431919] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.431924] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.433565] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.433570] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.434821] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.434826] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.434922] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.434927] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.447427] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.447433] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.451796] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.451801] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.454818] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.454824] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.454843] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.454847] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.456068] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.456073] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.458311] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.458316] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.459625] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.459630] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.461535] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.461541] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.465128] ftdi_sio ttyUSB4: Unable to read latency timer: -71 [ 106.466478] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.466483] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.469373] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.469378] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.474798] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.474803] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.483645] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.483651] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.487048] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.487053] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.487118] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.487122] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.489361] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.489365] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.507595] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.507601] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.512373] ftdi_sio ttyUSB4: Unable to write latency timer: -71 [ 106.512532] usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB4 [ 106.515118] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.515123] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.519896] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.519902] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.532380] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.532385] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.541645] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.541651] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.546854] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.546859] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.549193] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.549197] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.552985] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.552990] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.558567] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.558572] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.572185] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.572190] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.577893] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.577898] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.589317] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.589322] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.595895] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.595901] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.600645] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.600650] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.600664] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.600668] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.609869] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.609875] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.619666] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.619672] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.621381] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.621385] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.624719] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.624724] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.631797] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.631801] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.631816] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.631820] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.642188] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.642194] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.642993] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.642999] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.649032] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.649040] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.649648] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.649656] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.649831] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.649838] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.650562] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.650569] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.653099] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.653108] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.654001] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.654010] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.654120] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.654127] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.654737] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.654745] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.654941] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.654949] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.655237] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.655245] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.657881] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.657890] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.657941] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.657949] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.658258] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.658266] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.659364] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.659372] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.659671] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.659679] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.659925] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.659934] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.660740] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.660748] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.661374] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.661382] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.661738] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.661746] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.663800] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.663809] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.667318] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.667327] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.668153] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.668161] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.671497] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.671506] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.672258] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.672266] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.672495] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.672503] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.674489] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.674498] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.677514] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.677522] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.679655] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.679664] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.680775] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.680784] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.683497] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.683506] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.683804] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.683812] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.686040] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.686049] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.686545] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.686553] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.687495] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.687503] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.687550] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.687558] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.687775] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.687782] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.688577] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.688585] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.688957] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.688964] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.689253] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.689261] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.689540] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.689548] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.691486] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.691494] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.691551] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.691558] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.692439] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.692450] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.693436] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.693445] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.695185] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.695194] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.695366] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.695375] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.696712] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.696721] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.698896] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.698904] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.698953] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.698960] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.699163] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.699171] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.699860] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.699868] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.700280] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.700289] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.700328] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.700336] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.701159] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.701168] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.702256] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.702264] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.702554] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.702563] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.704618] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.704627] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.705047] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.705055] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.705413] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.705421] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.706145] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.706153] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.706841] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.706849] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.708057] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.708065] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.708309] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.708317] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.709047] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.709056] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.709401] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.709410] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.710765] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.710774] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.710862] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.710870] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.710996] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.711004] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.712650] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.712659] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.713211] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.713220] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.714257] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.714265] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.714516] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.714524] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.715925] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.715933] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.717385] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.717393] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.718006] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.718015] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.718456] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.718464] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.719665] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.719673] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.721336] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.721345] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.721822] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.721830] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.723463] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.723472] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.723531] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.723539] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.724502] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.724510] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.724740] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.724748] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.724922] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.724930] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.725135] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.725143] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.725382] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.725390] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.725626] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.725634] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.726704] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.726712] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.726899] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.726907] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.730420] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.730428] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.732453] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.732461] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.733916] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.733925] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.733959] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.733966] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.736320] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.736329] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.737874] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.737882] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.738215] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.738223] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.739715] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.739724] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.740018] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.740026] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.740130] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.740138] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.740215] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.740222] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.740896] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.740904] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.742734] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.742742] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.743265] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.743273] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.743659] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.743667] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.744385] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.744394] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.746390] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.746398] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.746986] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.746994] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.747049] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.747056] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.747697] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.747705] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.748673] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.748681] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.762518] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.762524] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.762981] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.762986] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.768524] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.768529] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.771857] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.771862] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.777140] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.777146] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.784356] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.784362] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.786188] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.786193] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.786736] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.786741] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.802179] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.802185] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.804073] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.804079] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.815112] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.815118] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.815527] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.815533] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.821825] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.821831] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.827855] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.827861] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.839835] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.839842] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.851497] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.851503] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.855857] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.855863] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.860780] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.860786] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.863780] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.863786] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.864973] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.864979] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.877778] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.877784] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.909575] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 106.909581] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.916297] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.916303] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.917827] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.917831] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.924305] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.924311] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.925884] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.925889] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.927859] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.927864] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.943066] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.943072] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.950532] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 106.950537] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.959555] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 106.959561] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.960101] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 106.960106] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.966000] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 106.966006] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.970436] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 106.970440] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.970851] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.970855] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 106.980705] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 106.980711] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 106.999550] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 106.999556] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.009456] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 107.009461] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000029 [ 107.012420] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 107.012424] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.030539] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 107.030545] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.035423] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 107.035428] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.035916] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 107.035920] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.045610] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 107.045615] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.048622] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 107.048626] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.057742] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 107.057746] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.066601] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 107.066606] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.092893] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 107.092897] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.102970] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 107.102974] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.103198] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 107.103202] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.109528] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 107.109532] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.125141] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 107.125145] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.127440] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 107.127445] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.139053] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 107.139057] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.140099] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 107.140103] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.148497] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 107.148501] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.148554] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 4 - ChHltd set, but reason is unknown [ 107.148559] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.152454] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 107.152458] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.159325] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 107.159329] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.177374] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 107.177379] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.179307] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 107.179311] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.181780] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 107.181785] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.195093] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 107.195097] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.207408] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 107.207412] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.211448] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 107.211453] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.211927] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 107.211931] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.213352] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 107.213356] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.219227] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 6 - ChHltd set, but reason is unknown [ 107.219232] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.220322] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 107.220327] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.232843] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 7 - ChHltd set, but reason is unknown [ 107.232848] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.234885] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 1 - ChHltd set, but reason is unknown [ 107.234889] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.239539] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 107.239544] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.239560] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 107.239565] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.240117] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 3 - ChHltd set, but reason is unknown [ 107.240121] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.244968] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 2 - ChHltd set, but reason is unknown [ 107.244973] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.247123] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 0 - ChHltd set, but reason is unknown [ 107.247128] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.252217] dwc2 fe980000.usb: dwc2_hc_chhltd_intr_dma: Channel 5 - ChHltd set, but reason is unknown [ 107.252222] dwc2 fe980000.usb: hcint 0x00000002, intsts 0x04000021 [ 107.260631] ftdi_sio 1-1.1:1.1: FTDI USB Serial Device converter detected [ 107.260718] usb 1-1.1: Detected FT4232H [ 107.260885] ftdi_sio ttyUSB5: Unable to read latency timer: -71 [ 107.261005] ftdi_sio ttyUSB5: Unable to write latency timer: -71 [ 107.261118] usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB5 [ 107.261572] ftdi_sio 1-1.1:1.2: FTDI USB Serial Device converter detected [ 107.261643] usb 1-1.1: Detected FT4232H [ 107.261757] ftdi_sio ttyUSB6: Unable to read latency timer: -71 [ 107.261881] ftdi_sio ttyUSB6: Unable to write latency timer: -71 [ 107.261967] usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB6 [ 107.262478] ftdi_sio 1-1.1:1.3: FTDI USB Serial Device converter detected [ 107.262554] usb 1-1.1: Detected FT4232H [ 107.262633] ftdi_sio ttyUSB7: Unable to read latency timer: -71 [ 107.262756] ftdi_sio ttyUSB7: Unable to write latency timer: -71 [ 107.262864] usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB7 [ 107.263375] usb 1-1.1: USB disconnect, device number 6 [ 107.263839] ftdi_sio ttyUSB4: FTDI USB Serial Device converter now disconnected from ttyUSB4 [ 107.263892] ftdi_sio 1-1.1:1.0: device disconnected [ 107.264346] ftdi_sio ttyUSB5: FTDI USB Serial Device converter now disconnected from ttyUSB5 [ 107.264394] ftdi_sio 1-1.1:1.1: device disconnected [ 107.264813] ftdi_sio ttyUSB6: FTDI USB Serial Device converter now disconnected from ttyUSB6 [ 107.264867] ftdi_sio 1-1.1:1.2: device disconnected [ 107.265274] ftdi_sio ttyUSB7: FTDI USB Serial Device converter now disconnected from ttyUSB7 [ 107.265319] ftdi_sio 1-1.1:1.3: device disconnected
