/** ****************************************************************************** * @file system_stm32f0xx.c * @author MCD Application Team * @brief CMSIS Cortex-M0 Device Peripheral Access Layer System Source File. * * 1. This file provides two functions and one global variable to be called from * user application: * - SystemInit(): This function is called at startup just after reset and * before branch to main program. This call is made inside * the "startup_stm32f0xx.s" file. * * - SystemCoreClock variable: Contains the core clock (HCLK), it can be used * by the user application to setup the SysTick * timer or configure other parameters. * * - SystemCoreClockUpdate(): Updates the variable SystemCoreClock and must * be called whenever the core clock is changed * during program execution. * * ****************************************************************************** * @attention * *
© Copyright (c) 2016 STMicroelectronics. * All rights reserved.
* * This software component is licensed by ST under BSD 3-Clause license, * the "License"; You may not use this file except in compliance with the * License. You may obtain a copy of the License at: * opensource.org/licenses/BSD-3-Clause * ****************************************************************************** */ /** @addtogroup CMSIS * @{ */ /** @addtogroup stm32f0xx_system * @{ */ /** @addtogroup STM32F0xx_System_Private_Includes * @{ */ #include "stm32f0xx.h" /** * @} */ /** @addtogroup STM32F0xx_System_Private_TypesDefinitions * @{ */ /** * @} */ /** @addtogroup STM32F0xx_System_Private_Defines * @{ */ #if !defined (HSE_VALUE) #define HSE_VALUE ((uint32_t)8000000) /*!< Default value of the External oscillator in Hz. This value can be provided and adapted by the user application. */ #endif /* HSE_VALUE */ #if !defined (HSI_VALUE) #define HSI_VALUE ((uint32_t)8000000) /*!< Default value of the Internal oscillator in Hz. This value can be provided and adapted by the user application. */ #endif /* HSI_VALUE */ #if !defined (HSI48_VALUE) #define HSI48_VALUE ((uint32_t)48000000) /*!< Default value of the HSI48 Internal oscillator in Hz. This value can be provided and adapted by the user application. */ #endif /* HSI48_VALUE */ /** * @} */ /** @addtogroup STM32F0xx_System_Private_Macros * @{ */ /** * @} */ /** @addtogroup STM32F0xx_System_Private_Variables * @{ */ /* This variable is updated in three ways: 1) by calling CMSIS function SystemCoreClockUpdate() 2) by calling HAL API function HAL_RCC_GetHCLKFreq() 3) each time HAL_RCC_ClockConfig() is called to configure the system clock frequency Note: If you use this function to configure the system clock; then there is no need to call the 2 first functions listed above, since SystemCoreClock variable is updated automatically. */ uint32_t SystemCoreClock = 8000000; const uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9}; const uint8_t APBPrescTable[8] = {0, 0, 0, 0, 1, 2, 3, 4}; /** * @} */ /** @addtogroup STM32F0xx_System_Private_FunctionPrototypes * @{ */ /** * @} */ /** @addtogroup STM32F0xx_System_Private_Functions * @{ */ /** * @brief Setup the microcontroller system * @param None * @retval None */ void SystemInit(void) { /* NOTE :SystemInit(): This function is called at startup just after reset and before branch to main program. This call is made inside the "startup_stm32f0xx.s" file. User can setups the default system clock (System clock source, PLL Multiplier and Divider factors, AHB/APBx prescalers and Flash settings). */ } /** * @brief Update SystemCoreClock variable according to Clock Register Values. * The SystemCoreClock variable contains the core clock (HCLK), it can * be used by the user application to setup the SysTick timer or configure * other parameters. * * @note Each time the core clock (HCLK) changes, this function must be called * to update SystemCoreClock variable value. Otherwise, any configuration * based on this variable will be incorrect. * * @note - The system frequency computed by this function is not the real * frequency in the chip. It is calculated based on the predefined * constant and the selected clock source: * * - If SYSCLK source is HSI, SystemCoreClock will contain the HSI_VALUE(*) * * - If SYSCLK source is HSE, SystemCoreClock will contain the HSE_VALUE(**) * * - If SYSCLK source is PLL, SystemCoreClock will contain the HSE_VALUE(**) * or HSI_VALUE(*) multiplied/divided by the PLL factors. * * (*) HSI_VALUE is a constant defined in stm32f0xx_hal_conf.h file (default value * 8 MHz) but the real value may vary depending on the variations * in voltage and temperature. * * (**) HSE_VALUE is a constant defined in stm32f0xx_hal_conf.h file (its value * depends on the application requirements), user has to ensure that HSE_VALUE * is same as the real frequency of the crystal used. Otherwise, this function * may have wrong result. * * - The result of this function could be not correct when using fractional * value for HSE crystal. * * @param None * @retval None */ void SystemCoreClockUpdate (void) { uint32_t tmp = 0, pllmull = 0, pllsource = 0, predivfactor = 0; /* Get SYSCLK source -------------------------------------------------------*/ tmp = RCC->CFGR & RCC_CFGR_SWS; switch (tmp) { case RCC_CFGR_SWS_HSI: /* HSI used as system clock */ SystemCoreClock = HSI_VALUE; break; case RCC_CFGR_SWS_HSE: /* HSE used as system clock */ SystemCoreClock = HSE_VALUE; break; case RCC_CFGR_SWS_PLL: /* PLL used as system clock */ /* Get PLL clock source and multiplication factor ----------------------*/ pllmull = RCC->CFGR & RCC_CFGR_PLLMUL; pllsource = RCC->CFGR & RCC_CFGR_PLLSRC; pllmull = ( pllmull >> 18) + 2; predivfactor = (RCC->CFGR2 & RCC_CFGR2_PREDIV) + 1; if (pllsource == RCC_CFGR_PLLSRC_HSE_PREDIV) { /* HSE used as PLL clock source : SystemCoreClock = HSE/PREDIV * PLLMUL */ SystemCoreClock = (HSE_VALUE/predivfactor) * pllmull; } #if defined(STM32F042x6) || defined(STM32F048xx) || defined(STM32F072xB) || defined(STM32F078xx) || defined(STM32F091xC) || defined(STM32F098xx) else if (pllsource == RCC_CFGR_PLLSRC_HSI48_PREDIV) { /* HSI48 used as PLL clock source : SystemCoreClock = HSI48/PREDIV * PLLMUL */ SystemCoreClock = (HSI48_VALUE/predivfactor) * pllmull; } #endif /* STM32F042x6 || STM32F048xx || STM32F072xB || STM32F078xx || STM32F091xC || STM32F098xx */ else { #if defined(STM32F042x6) || defined(STM32F048xx) || defined(STM32F070x6) \ || defined(STM32F078xx) || defined(STM32F071xB) || defined(STM32F072xB) \ || defined(STM32F070xB) || defined(STM32F091xC) || defined(STM32F098xx) || defined(STM32F030xC) /* HSI used as PLL clock source : SystemCoreClock = HSI/PREDIV * PLLMUL */ SystemCoreClock = (HSI_VALUE/predivfactor) * pllmull; #else /* HSI used as PLL clock source : SystemCoreClock = HSI/2 * PLLMUL */ SystemCoreClock = (HSI_VALUE >> 1) * pllmull; #endif /* STM32F042x6 || STM32F048xx || STM32F070x6 || STM32F071xB || STM32F072xB || STM32F078xx || STM32F070xB || STM32F091xC || STM32F098xx || STM32F030xC */ } break; default: /* HSI used as system clock */ SystemCoreClock = HSI_VALUE; break; } /* Compute HCLK clock frequency ----------------*/ /* Get HCLK prescaler */ tmp = AHBPrescTable[((RCC->CFGR & RCC_CFGR_HPRE) >> 4)]; /* HCLK clock frequency */ SystemCoreClock >>= tmp; } /** * @} */ /** * @} */ /** * @} */ /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
