INFO
Test log initialized.
INFO
User Input module initialized
INFO
Windows 10 Home (Build 17134.1.amd64fre.rs4_release.180410-1804)
INFO
CVApp.exe ver 4.0.0.0
INFO
BaseUtilities.dll ver 4.0.0.0
INFO
CommandVerifierLog.dll ver 4.0.0.0
INFO
GuiHelper.dll ver 4.0.0.0
INFO
TestUtilities.dll ver 4.0.0.0
INFO
TestSuiteEngine.dll ver 4.0.0.0
INFO
EhciDevIOCTL.dll ver 1.15.13.1
INFO
EhciTestServices.dll ver 1.15.13.1
INFO
USBUtilities.dll ver 1.4.5.1
INFO
StackSwitcher.dll ver 1.4.5.1
INFO
USBCommandVerifier.dll ver 1.15.13.1
INFO
Host selected: PCI-Bus 0, Gerät 29, Funktion 0
INFO
DUT selected: FS Device (MSC/BOT) addr=2: VID=dead, PID=beef
INFO
Start time: Feb 22, 2021 - 15:02:54
INFO
Device descriptor length : 12
INFO
Device descriptor type : 1
INFO
Each interface specifies its own device class type
INFO
Device MaxPacketSize0 : 8
WARNING
Couldn't open vendor name file usbif.json.
WARNING
Failed to get vendor information for VendorID : dead
INFO
Device ProductID : beef
INFO
ENGLISH_US language string descriptor is : usbman
INFO
ENGLISH_US language string descriptor is : device0
INFO
ENGLISH_US language string descriptor is : 055AA3540000
INFO
Number of configurations device supports : 1
INFO
Stop time: Feb 22, 2021 - 15:02:55
INFO
Stopping Test [ Device Descriptor Test (Configuration Index 0):
Number of: Fails (0); Aborts (0); Warnings (2) ]
INFO
Start time: Feb 22, 2021 - 15:02:56
INFO
INFO
INFO
INFO
WARNING
WARNING
INFO
INFO
INFO
INFO
INFO
INFO
Stop time: Feb 22, 2021 - 15:02:57
INFO
INFO
Start time: Feb 22, 2021 - 15:02:57
INFO
Device has 2 functions, of which 1 has an Interface Association descriptor.
INFO
Function #1 does not have an Interface Association Descriptor.
INFO
Interface Association Descriptor :
INFO
bDescriptorType = 0x0b
INFO
bFunctionClass = 0x02
INFO
bFunctionSubClass = 0x02
INFO
bFunctionProtocol = 0x01
INFO
Running TD 9.8 : String Descriptor Test for iFunction : 0x00
INFO
Found Interface Descriptor with number : 1
INFO
Found Interface Descriptor with number : 2
INFO
Stop time: Feb 22, 2021 - 15:02:58
INFO
Stopping Test [ TD 9.3 Interface Association Descriptor Test (Config 0):
Number of: Fails (0); Aborts (0); Warnings (0) ]
INFO
Start time: Feb 22, 2021 - 15:02:59
INFO
Configuration descriptor contains descriptor of type : b
INFO
Configuration descriptor contains descriptor of type : 24
INFO
INFO
INFO
INFO
Number of interface descriptors found 3
INFO
Number of alternate interface descriptors found : 0
INFO
Number of endpoint descriptors found : 5
INFO
Configuration descriptor length : 9
INFO
Configuration descriptor type : 2
INFO
Configuration descriptor TotalLength : 62
INFO
Configuration descriptor NumInterfaces : 3
INFO
Configuration descriptor ConfigurationValue: 1
INFO
Configuration descriptor string descriptor index : 0
INFO
Configuration descriptor bmAttributes : 80
INFO
Device does not support remote wake up
INFO
Maximum power device requires : 100mA
INFO
Device is BUS POWERED
INFO
Device is currently BUS POWERED
INFO
Currently remote wakeup is DISABLED
INFO
Stop time: Feb 22, 2021 - 15:03:00
INFO
Stopping Test [ Configuration Descriptor Test (Configuration Index 0):
INFO
Start time: Feb 22, 2021 - 15:03:00
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
Stop time: Feb 22, 2021 - 15:03:01
INFO
INFO
Start time: Feb 22, 2021 - 15:03:01
INFO
Bandwidth check passed
INFO
Testing Interface number : 0 Alternate setting : 0
INFO
Interface descriptor length : 9
INFO
Interface descriptor bDescriptorType : 4
INFO
Interface descriptor bAlternateSetting : 0
INFO
Interface descriptor bNumEndPoints: 2
INFO
Interface descriptor bInterfaceClass reserved for assignment by the USB-IF : 8
INFO
Interface class code indicates [Mass-Storage] Interface
INFO
Interface sub class : 6 <not defined>
INFO
Interface protocol : 80 <not defined>
INFO
Interface descriptor bInterfaceSubClass : 6
INFO
Interface descriptor bInterfaceProtocol assigned by the USB-IF : 50
INFO
Interface descriptor iInterface : 0x0
INFO
Calling SetInterface(), InterfaceNumber=0, AlternateSetting=0
INFO
Calling GetInterface(), InterfaceNumber=0, AlternateSetting=0
INFO
Testing Interface number : 1 Alternate setting : 0
INFO
INFO
INFO
INFO
Interface descriptor bNumEndPoints: 1
INFO
Interface descriptor bInterfaceClass reserved for assignment by the USB-IF : 2
INFO
Interface class code indicates [CDC-Control] Interface
INFO
Interface sub class : 2 <not defined>
INFO
Interface protocol : 1 <not defined>
INFO
Interface descriptor bInterfaceSubClass : 2
INFO
Interface descriptor bInterfaceProtocol assigned by the USB-IF : 1
INFO
INFO
Calling SetInterface(), InterfaceNumber=1, AlternateSetting=0
INFO
Calling GetInterface(), InterfaceNumber=1, AlternateSetting=0
INFO
Testing Interface number : 2 Alternate setting : 0
INFO
INFO
INFO
INFO
INFO
Interface descriptor bInterfaceClass reserved for assignment by the USB-IF : a
INFO
Interface class code indicates [CDC-Data] Interface
INFO
Interface sub class : 0 <not defined>
INFO
Interface protocol : 0 <not defined>
INFO
Interface descriptor bInterfaceSubClass : 0
INFO
Device does not use a class-specific protocol on this interface
INFO
INFO
Calling SetInterface(), InterfaceNumber=2, AlternateSetting=0
INFO
Calling GetInterface(), InterfaceNumber=2, AlternateSetting=0
INFO
Stop time: Feb 22, 2021 - 15:03:02
INFO
Stopping Test [ Interface Descriptor Test (Configuration Index 0):
INFO
Start time: Feb 22, 2021 - 15:03:02
INFO
INFO
Endpoint descriptor length : 7
INFO
Endpoint descriptor type : 5
INFO
Endpoint Type : Bulk, Number : 2, Direction : OUT
INFO
Endpoint descriptor bmAttributes : 2
INFO
Endpoint descriptor raw MaxPacketSize : 40
INFO
Endpoint descriptor interval : 0
INFO
INFO
INFO
Endpoint Type : Bulk, Number : 2, Direction : IN
INFO
INFO
INFO
INFO
INFO
INFO
INFO
Endpoint Type : Interrupt, Number : 1, Direction : IN
INFO
Endpoint descriptor bmAttributes : 3
INFO
Endpoint descriptor raw MaxPacketSize : 8
INFO
Endpoint descriptor interval : ff
INFO
INFO
INFO
INFO
Endpoint Type : Bulk, Number : 3, Direction : OUT
INFO
INFO
INFO
INFO
INFO
INFO
Endpoint Type : Bulk, Number : 3, Direction : IN
INFO
INFO
INFO
INFO
Stop time: Feb 22, 2021 - 15:03:03
INFO
Stopping Test [ Endpoint Descriptor Test (Configuration Index 0):
INFO
Start time: Feb 22, 2021 - 15:03:03
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
INFO
Stop time: Feb 22, 2021 - 15:03:04
INFO
INFO
Start time: Feb 22, 2021 - 15:03:04
INFO
INFO
Testing EndPoint type : Bulk, Address : 2
INFO
Endpoint is currently not halted
INFO
Cleared endpoint halt
INFO
Testing EndPoint type : Bulk, Address : 82
INFO
INFO
INFO
INFO
Testing EndPoint type : Interrupt, Address : 81
INFO
INFO
INFO
INFO
Testing EndPoint type : Bulk, Address : 3
INFO
INFO
INFO
Testing EndPoint type : Bulk, Address : 83
INFO
INFO
INFO
Stop time: Feb 22, 2021 - 15:03:05
INFO
Stopping Test [ Halt Endpoint Test (Configuration Index 0):
