ErrorStatus LL_GPIO_Init(GPIO_TypeDef *GPIOx, LL_GPIO_InitTypeDef *GPIO_InitStruct) { uint32_t pinmask; uint32_t pinpos; uint32_t currentpin; /* Check the parameters */ assert_param(IS_GPIO_ALL_INSTANCE(GPIOx)); assert_param(IS_LL_GPIO_PIN(GPIO_InitStruct->Pin)); /* ------------------------- Configure the port pins ---------------- */ /* Initialize pinpos on first pin set */ pinmask = ((GPIO_InitStruct->Pin) << GPIO_PIN_MASK_POS) >> GPIO_PIN_NB; pinpos = POSITION_VAL(pinmask); /* Configure the port pins */ while ((pinmask >> pinpos) != 0u) { /* skip if bit is not set */ if ((pinmask & (1u << pinpos)) != 0u) { /* Get current io position */ if (pinpos < GPIO_PIN_MASK_POS) { currentpin = (0x00000101uL << pinpos); } else { currentpin = ((0x00010001u << (pinpos - GPIO_PIN_MASK_POS)) | 0x04000000u); } /* Check Pin Mode and Pin Pull parameters */ assert_param(IS_LL_GPIO_MODE(GPIO_InitStruct->Mode)); assert_param(IS_LL_GPIO_PULL(GPIO_InitStruct->Pull)); if ((GPIO_InitStruct->Mode == LL_GPIO_MODE_OUTPUT) || (GPIO_InitStruct->Mode == LL_GPIO_MODE_ALTERNATE)) { /* Check speed and Output mode parameters */ assert_param(IS_LL_GPIO_SPEED(GPIO_InitStruct->Speed)); assert_param(IS_LL_GPIO_OUTPUT_TYPE(GPIO_InitStruct->OutputType)); /* Speed mode configuration */ LL_GPIO_SetPinSpeed(GPIOx, currentpin, GPIO_InitStruct->Speed); /* Output mode configuration*/ LL_GPIO_SetPinOutputType(GPIOx, currentpin, GPIO_InitStruct->OutputType); } /* Pull-up Pull-down resistor configuration*/ LL_GPIO_SetPinPull(GPIOx, currentpin, GPIO_InitStruct->Pull); /* Pin Mode configuration */ LL_GPIO_SetPinMode(GPIOx, currentpin, GPIO_InitStruct->Mode); } pinpos++; } return (SUCCESS); }
