/* lvglDriver for Mbed * Copyright (c) 2019 Johannes Stratmann * * Permission is hereby granted, free of charge, to any person obtaining a copy * of this software and associated documentation files (the "Software"), to deal * in the Software without restriction, including without limitation the rights * to use, copy, modify, merge, publish, distribute, sublicense, and/or sell * copies of the Software, and to permit persons to whom the Software is * furnished to do so, subject to the following conditions: * * The above copyright notice and this permission notice shall be included in * all copies or substantial portions of the Software. * * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE * SOFTWARE. */ #include "LVGLDispDriver_DISCO_F769NI.h" #include "systool.h" #define BUFFERLINES (20) #define USE_STATIC_BUFFER (0) #define USE_DMA (1) #define USE_DOUBLE_BUFFER (1) static Timer t; static int t0; static int t1; #if (USE_STATIC_BUFFER == 1) static lv_color_t xbuf1[LV_HOR_RES_MAX * BUFFERLINES]; # if (USE_DOUBLE_BUFFER == 1) static lv_color_t xbuf2[LV_HOR_RES_MAX * BUFFERLINES]; # endif #endif #if (USE_DMA == 1) extern "C" void dmaXFerComplete(DMA2D_HandleTypeDef *hdma2d) { lv_disp_flush_ready(LVGLDispDriver::get_target_default_instance()->getLVDispDrv()); t1 = t.elapsed_time().count(); // get µs timestamp } #else LCD_DISCO_F769NI* pLcd; #endif LVGLDispDISCO_F769NI::LVGLDispDISCO_F769NI(uint32_t nBufferRows) : LVGLDispDriver(LV_HOR_RES_MAX, LV_VER_RES_MAX), _nBufferRows(nBufferRows) { // init display and show message using BSP draw functions (not lvgl) _lcd.Clear(LCD_COLOR_BLUE); _lcd.SetBackColor(LCD_COLOR_BLUE); _lcd.SetTextColor(LCD_COLOR_WHITE); _lcd.DisplayStringAt(0, LINE(5), (uint8_t *)"DISCOVERY STM32F769NI", CENTER_MODE); init(); } void LVGLDispDISCO_F769NI::init() { size_t bufferSize = LV_HOR_RES_MAX * _nBufferRows; #if (USE_STATIC_BUFFER == 0) // allocate memory for display buffer // lv_color_t* xbuf1 = new lv_color_t[bufferSize]; // buffer on heap // lv_color_t* xbuf1 = (lv_color_t*)0x20000800; // buffer in DTCM lv_color_t* xbuf1 = (lv_color_t*)0x20060000; // buffer in SRAM1 MBED_ASSERT(xbuf1 != nullptr); memset(xbuf1, 0, bufferSize*sizeof(lv_color_t)); debug("init display, using heap buffer, addr: %p %s\n", xbuf1, get_RAM_name(xbuf1)); # if (USE_DOUBLE_BUFFER == 1) // lv_color_t* xbuf2 = new lv_color_t[bufferSize]; // buffer on heap // lv_color_t* xbuf2 = (lv_color_t*)0x20010400; // buffer in DTCM lv_color_t* xbuf2 = (lv_color_t*)0x20070000; // buffer in SRAM1 MBED_ASSERT(xbuf2 != nullptr); memset(xbuf2, 0, bufferSize*sizeof(lv_color_t)); debug("init display, using double buffer, addr: %p %s\n", xbuf2, get_RAM_name(xbuf2)); # endif #else debug("init display, using static buffer, addr: %p %s\n", xbuf1, get_RAM_name(xbuf1)); # if (USE_DOUBLE_BUFFER == 1) debug("init display, using double buffer, addr: %p %s\n", xbuf2, get_RAM_name(xbuf2)); # endif #endif /*Used to copy the buffer's content to the display*/ _disp_drv.flush_cb = disp_flush; /*Set a display buffer*/ _disp_drv.buffer = &_disp_buf_1; #if (USE_DOUBLE_BUFFER == 1) lv_disp_buf_init(&_disp_buf_1, xbuf1, xbuf2, bufferSize); /* Initialize the display buffer */ #else lv_disp_buf_init(&_disp_buf_1, xbuf1, nullptr, bufferSize); /* Initialize the display buffer */ #endif /*Finally register the driver*/ _disp = lv_disp_drv_register(&_disp_drv); #if (USE_DMA == 1) debug("display using DMA\n"); BSP_LCD_SetDMACpltCallback(dmaXFerComplete); #if 1 // configure buffer as write-through { /* Disable the MPU */ HAL_MPU_Disable(); ARM_MPU_SetRegion( ARM_MPU_RBAR( 4, // Region 4: not (yet) used by Mbed (uint32_t)xbuf1), // Base, must be aligned ARM_MPU_RASR( 1, // DisableExec ARM_MPU_AP_FULL, // AccessPermission 0, // TypeExtField 1, // IsShareable 1, // IsCacheable 0, // IsBufferable 0, // subregions ARM_MPU_REGION_SIZE_128KB) // Size ); /* Enable the MPU */ HAL_MPU_Enable(MPU_HFNMI_PRIVDEF); } #endif #else pLcd = &_lcd; debug("display using DrawPixel, addr LVGLDispDISCO_F769NI: %p %s\n", pLcd, get_RAM_name(pLcd)); #endif t.start(); // start performance measurement timer } void LVGLDispDISCO_F769NI::disp_flush(lv_disp_drv_t *disp_drv, const lv_area_t *area, lv_color_t *color_p) { #if (USE_DMA == 1) uint32_t width = area->x2 - area->x1 + 1; uint32_t height = area->y2 - area->y1 + 1; // t0 = t.elapsed_time().count(); // SCB_CleanDCache(); // ok, works //SCB_CleanDCache_by_Addr((uint32_t*)color_p, height * LV_HOR_RES_MAX * sizeof(lv_color_t)); // ok, works, but maybe slower than CleanDCache() printf("transfer cache: %d us\n", t1-t0); // print previous transfer time t0 = t.elapsed_time().count(); // get start time in µs BSP_LCD_TransferBitmap(area->x1, area->y1, width, height, (uint32_t*)color_p); #else // use DrawPixel to buffer write to screen int32_t x; int32_t y; for (y = area->y1; y <= area->y2; y++) { for (x = area->x1; x <= area->x2; x++) { pLcd->DrawPixel(x, y, *((uint32_t *)color_p)); color_p++; } } /* IMPORTANT!!! * Inform the graphics library that you are ready with the flushing*/ lv_disp_flush_ready(disp_drv); #endif } MBED_WEAK LVGLDispDriver *LVGLDispDriver::get_target_default_instance() { static LVGLDispDISCO_F769NI drv(BUFFERLINES); return &drv; }
