library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity tb_hysterese is end tb_hysterese; architecture tb of tb_hysterese is component hysterese is port( Spannungslimit : in std_logic_vector(7 downto 0); HysVariable : in std_logic_vector(7 downto 0); ADC_WERT : in std_logic_vector(7 downto 0); Portpin : out std_logic); end component; signal Spannungslimit: std_logic_vector(7 downto 0):=std_logic_vector(to_unsigned(200,8)); signal HysVariable : std_logic_vector(7 downto 0):=std_logic_vector(to_unsigned(40,8)); signal ADC_WERT : std_logic_vector(7 downto 0):=(others => '0'); signal Portpin : std_logic:='0'; signal dir : std_logic:='0'; begin process begin wait for 10 ns; if dir = '0' then ADC_WERT <= std_logic_vector(unsigned(ADC_WERT) +1); if unsigned(ADC_WERT) = 254 then dir <= '1'; end if; else ADC_WERT <= std_logic_vector(unsigned(ADC_WERT) -1); if unsigned(ADC_WERT) = 1 then dir <= '0'; end if; end if; end process; UUT: hysterese port map( Spannungslimit => Spannungslimit, HysVariable => HysVariable, ADC_WERT => ADC_WERT, Portpin => Portpin); end;
