/* Victron1 MPPT 12 V Victron2 MPPT 24 V Victron3 BMV 24 V D5ED V_MPPT un16 0.01 V D7ED I_MPPT un16 0.1 A BBED VPV_MPPT un16 0.01 V BCED PPV_MPPT un32 0.01 W 0102 CS_MPPT un8 D3ED H20_MPPT un16 0.01 KWH 8DED V_BMV un16 0.01 V 8CED I_BMV un32 0.001 A 8EED P_BMV un16 1 W 1003 H17_BMV un32 0.01 KWH 1103 H18_BMV un32 0.01 KWH 0603 H7_BMV un32 0.01 V 0703 H8_BMV un32 0.01 V FF0F SOC_BMV un16 0.01 % Checksum: :70010003E -> Command; checksum 0x55 – 0x7 – 0x0 – 0x10 – 0x0 = 0x3E :7001000C80076 -> Response; checksum 0x55 – 0x7 – 0x0 – 0x10 – 0x0 – 0xC8 – 0x0 = 0x76 */ #include #include #include #include LiquidCrystal_I2C lcd(0x27, 20, 4); #include #include Adafruit_BME280 bme; #include RunningMedian samples1 = RunningMedian(11); RunningMedian samples2 = RunningMedian(11); int interruptPin = 3; int counter; int Status; #include SoftwareSerial Serial_SIM900(52, 53); // RX, TX const int vicbuf = 25; const int sim900buf = 180; char vic1_ser[vicbuf]; char vic2_ser[vicbuf]; char vic3_ser[vicbuf]; char sim900_ser[sim900buf]; float vic1_v_mppt; float vic1_i_mppt; float vic1_vpv_mppt; long vic1_ppv_mppt; long vic1_cs_mppt; long vic1_h20_mppt; float vic2_v_mppt; float vic2_i_mppt; float vic2_vpv_mppt; long vic2_ppv_mppt; long vic2_cs_mppt; long vic2_h20_mppt; long vic2_v_mppt_r; float vic3_v_bmv; float vic3_i_bmv; long vic3_p_bmv; float vic3_h17_bmv; float vic3_h18_bmv; float vic3_h7_bmv; float vic3_h8_bmv; float vic3_soc_bmv; long ergebniss; float temperatur; float luftfeuchtigkeit; float luftdruck; int ina226_addr = 0x40; int shunt; int shunt_logger; int p_map; int p_ueber; volatile int regel; int schalter; int error; int error_counter; int zaehler; int messung_1; int messung_2; int mess; int status_absorption; int status_float; int up_down; int ledPin = LED_BUILTIN; int sim900_pin = 9; int K1 = 59; int K2 = 58; int K3 = 57; int K4 = 56; byte status_K1 = HIGH; byte status_K2 = HIGH; byte status_K3 = HIGH; byte status_K4 = HIGH; int p_K1 = 5; //<<<<----p AN K1 FESTLEGEN int p_K2 = 10; //<<<<----p AN K2 FESTLEGEN int p_K3 = 15; //<<<<----p AN K3 FESTLEGEN int p_K4 = 20; //<<<<----p AN K4 FESTLEGEN byte lcd_char_up_down[8] = {B00100, B01110, B10101, B00100, B10101, B01110, B00100, B00000}; byte lcd_char_up[8] = {B00100, B01110, B10101, B00100, B00100, B00100, B00100, B00000}; byte lcd_char_down[8] = {B00100, B00100, B00100, B00100, B10101, B01110, B00100, B00000}; //**************** void setup() { Serial.begin (19200); //USB Serial1.begin(19200); //Victron1_MPPT 12 Volt Serial2.begin(19200); //Victron2_MPPT 24 Volt Serial3.begin(19200); //Victron3_BMV 24 Volt Serial_SIM900.begin(19200); //SIM900 Wire.begin(); Wire.setClock(400000L); //writeRegister(0x00, 0x4E35); writeRegister(0x00, 0x4E3D); lcd.init(); lcd.backlight(); lcd.clear(); fest_display(); bme.begin(0x76); pinMode(sim900_pin, OUTPUT); digitalWrite(sim900_pin, LOW); pinMode(ledPin, OUTPUT); digitalWrite(ledPin, LOW); pinMode(K1, OUTPUT); pinMode(K2, OUTPUT); pinMode(K3, OUTPUT); pinMode(K4, OUTPUT); relais(); lcd.createChar(0, lcd_char_up_down); lcd.createChar(1, lcd_char_up); lcd.createChar(2, lcd_char_down); pinMode(interruptPin, INPUT); attachInterrupt(digitalPinToInterrupt(interruptPin), nulldurchgang, RISING); DDRA |= (1 << PA0); } //**************** void loop() { //Serial.print("Ram frei: "); Serial.println(freeRam()); //4014 vic1_serial(); vic2_serial(); vic3_serial(); sim900_error(); time1(); time2(); time3(); time4(); } //**************** int freeRam() { extern int __heap_start, *__brkval; int v; return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval); } //**************** void time1() { static unsigned long prev_millis; if (millis() - prev_millis > 500) { vic2_anfragen(); vic2_display(); ina_226(); ueberschuss(); ueberschuss_display(); prev_millis = millis(); } } void time2() { static unsigned long prev_millis; if (millis() - prev_millis > 750) { vic1_anfragen(); vic1_display(); vic3_anfragen(); vic3_display(); prev_millis = millis(); } } void time3() { static unsigned long prev_millis; if (millis() - prev_millis > 1000) { thingspeak(); bme280(); bme280_display(); prev_millis = millis(); } } void time4() { static unsigned long prev_millis; if (millis() - prev_millis > 300000) { lcd.clear(); fest_display(); prev_millis = millis(); } } //**************** void vic1_anfragen() { Serial1.println(F(":7D3ED008E")); } //**************** void vic2_anfragen() { Serial2.println(F(":7D3ED008E")); } //**************** void vic3_anfragen() { Serial3.println(F(":78DED00D4")); Serial3.println(F(":78CED00D5")); Serial3.println(F(":78EED00D3")); Serial3.println(F(":71003003B")); Serial3.println(F(":71103003A")); Serial3.println(F(":706030045")); Serial3.println(F(":707030044")); Serial3.println(F(":7FF0F0040")); } //**************** void vic1_serial() { static byte index; while (Serial1.available()) { char c = Serial1.read(); if (c == '\n' && index > 0) { vic1_ser[index] = '\0'; index = 0; if (((strncmp(vic1_ser, ":7", 2) == 0) || (strncmp(vic1_ser, ":A", 2) == 0)) && (strncmp(vic1_ser, "Checksum", 8) != 0)) { vic1_auswerten(); } } else if (index < vicbuf - 1) { vic1_ser[index++] = c; } } } //**************** void vic2_serial() { static byte index; while (Serial2.available()) { char c = Serial2.read(); if (c == '\n' && index > 0) { vic2_ser[index] = '\0'; index = 0; //Serial.println(vic2_ser); if (((strncmp(vic2_ser, ":7", 2) == 0) || (strncmp(vic2_ser, ":A", 2) == 0)) && (strncmp(vic2_ser, "Checksum", 8) != 0)) { vic2_auswerten(); } } else if (index < vicbuf - 1) { vic2_ser[index++] = c; } } } //**************** void vic3_serial() { static byte index; while (Serial3.available()) { char c = Serial3.read(); if (c == '\n' && index > 0) { vic3_ser[index] = '\0'; index = 0; vic3_auswerten(); } else if (index < vicbuf - 1) { vic3_ser[index++] = c; } } } //******************** void sim900_error() { static byte index; while (Serial_SIM900.available()) { char c = Serial_SIM900.read(); if (c == '\r' && index > 0) { sim900_ser[index] = '\0'; index = 0; if (strncmp(sim900_ser, "\nERROR", 6) == 0) { error++; error_counter++; } } else if (index < sim900buf - 1) { sim900_ser[index++] = c; } } } //******************** void vic1_auswerten() { if (strncmp(vic1_ser, ":AD5ED00", 8) == 0) { char str[5] = ""; char sub3[3] = ""; strncpy(sub3, &vic1_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic1_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic1_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -375 - a - b; if (xxx == checksum) { hextodec(str); vic1_v_mppt = ergebniss / 100.0; } return; } if (strncmp(vic1_ser, ":AD7ED00", 8) == 0) { char str[5] = ""; char sub3[3] = ""; strncpy(sub3, &vic1_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic1_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic1_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -377 - a - b; if (xxx == checksum) { hextodec(str); vic1_i_mppt = ergebniss / 10.0; } return; } if (strncmp(vic1_ser, ":ABBED00", 8) == 0) { char str[5] = ""; char sub3[3] = ""; strncpy(sub3, &vic1_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic1_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic1_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -349 - a - b; if (xxx == checksum) { hextodec(str); vic1_vpv_mppt = ergebniss / 100.0; } return; } if (strncmp(vic1_ser, ":ABCED00", 8) == 0) { char str[9] = ""; char sub5[3] = ""; strncpy(sub5, &vic1_ser[16], 2); sub5[2] = '\0'; hextodec(sub5); int checksum = ergebniss; char sub4[3] = ""; strncpy(sub4, &vic1_ser[14], 2); sub4[2] = '\0'; hextodec(sub4); int d = ergebniss; strcpy (str, sub4); char sub3[3] = ""; strncpy(sub3, &vic1_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int c = ergebniss; strcat (str, sub3); char sub2[3] = ""; strncpy(sub2, &vic1_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcat (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic1_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -350 - a - b - c - d; if (xxx == checksum) { hextodec(str); vic1_ppv_mppt = ergebniss / 100; } return; } if (strncmp(vic1_ser, ":A010200", 8) == 0) { char sub2[3] = ""; strncpy(sub2, &vic1_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int checksum = ergebniss; char sub1[3] = ""; strncpy(sub1, &vic1_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; byte xxx = 72 - a; if (xxx == checksum) { vic1_cs_mppt = ergebniss; } return; } if (strncmp(vic1_ser, ":7D3ED00", 8) == 0) { char str[5] = ""; char sub3[3] = ""; strncpy(sub3, &vic1_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic1_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic1_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -370 - a - b; if (xxx == checksum) { hextodec(str); vic1_h20_mppt = ergebniss * 10; } return; } } //**************** void vic2_auswerten() { if (strncmp(vic2_ser, ":AD5ED00", 8) == 0) { char str[5]; char sub3[3] = ""; strncpy(sub3, &vic2_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic2_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic2_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -375 - a - b; if (xxx == checksum) { hextodec(str); vic2_v_mppt_r = ergebniss; vic2_v_mppt = ergebniss / 100.0; } return; } if (strncmp(vic2_ser, ":AD7ED00", 8) == 0) { char str[5]; char sub3[3] = ""; strncpy(sub3, &vic2_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic2_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic2_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -377 - a - b; if (xxx == checksum) { hextodec(str); vic2_i_mppt = ergebniss / 10.0; } return; } if (strncmp(vic2_ser, ":ABBED00", 8) == 0) { char str[5]; char sub3[3] = ""; strncpy(sub3, &vic2_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic2_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic2_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -349 - a - b; if (xxx == checksum) { hextodec(str); vic2_vpv_mppt = ergebniss / 100.0; } return; } if (strncmp(vic2_ser, ":ABCED00", 8) == 0) { digitalWrite(ledPin, HIGH); char str[9]; char sub5[3] = ""; strncpy(sub5, &vic2_ser[16], 2); sub5[2] = '\0'; hextodec(sub5); int checksum = ergebniss; char sub4[3] = ""; strncpy(sub4, &vic2_ser[14], 2); sub4[2] = '\0'; hextodec(sub4); int d = ergebniss; strcpy (str, sub4); char sub3[3] = ""; strncpy(sub3, &vic2_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int c = ergebniss; strcat (str, sub3); char sub2[3] = ""; strncpy(sub2, &vic2_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcat (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic2_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -350 - a - b - c - d; if (xxx == checksum) { hextodec(str); vic2_ppv_mppt = ergebniss / 100; } digitalWrite(ledPin, LOW); return; } if (strncmp(vic2_ser, ":A010200", 8) == 0) { char sub2[3] = ""; strncpy(sub2, &vic2_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int checksum = ergebniss; char sub1[3] = ""; strncpy(sub1, &vic2_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; byte xxx = 72 - a; if (xxx == checksum) { vic2_cs_mppt = ergebniss; } return; } if (strncmp(vic2_ser, ":7D3ED00", 8) == 0) { char str[5]; char sub3[3] = ""; strncpy(sub3, &vic2_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic2_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic2_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -370 - a - b; if (xxx == checksum) { hextodec(str); vic2_h20_mppt = ergebniss * 10; } return; } } //**************** void vic3_auswerten() { if (strncmp(vic3_ser, ":78DED00", 8) == 0) { char str[5]; char sub3[3] = ""; strncpy(sub3, &vic3_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic3_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic3_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -300 - a - b; if (xxx == checksum) { hextodec(str); vic3_v_bmv = ergebniss / 100.0; } return; } if (strncmp(vic3_ser, ":78CED00", 8) == 0) { char str[9]; char sub5[3] = ""; strncpy(sub5, &vic3_ser[16], 2); sub5[2] = '\0'; hextodec(sub5); int checksum = ergebniss; char sub4[3] = ""; strncpy(sub4, &vic3_ser[14], 2); sub4[2] = '\0'; hextodec(sub4); int d = ergebniss; strcpy (str, sub4); char sub3[3] = ""; strncpy(sub3, &vic3_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int c = ergebniss; strcat (str, sub3); char sub2[3] = ""; strncpy(sub2, &vic3_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcat (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic3_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -299 - a - b - c - d; if (xxx == checksum) { hextodec(str); vic3_i_bmv = ergebniss / 1000.0; } return; } if (strncmp(vic3_ser, ":78EED00", 8) == 0) { char str[5]; char sub3[3] = ""; strncpy(sub3, &vic3_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic3_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic3_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -301 - a - b; if (xxx == checksum) { hextodec(str); vic3_p_bmv = ergebniss; } return; } if (strncmp(vic3_ser, ":7100300", 8) == 0) { char str[9]; char sub5[3] = ""; strncpy(sub5, &vic3_ser[16], 2); sub5[2] = '\0'; hextodec(sub5); int checksum = ergebniss; char sub4[3] = ""; strncpy(sub4, &vic3_ser[14], 2); sub4[2] = '\0'; hextodec(sub4); int d = ergebniss; strcpy (str, sub4); char sub3[3] = ""; strncpy(sub3, &vic3_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int c = ergebniss; strcat (str, sub3); char sub2[3] = ""; strncpy(sub2, &vic3_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcat (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic3_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = 59 - a - b - c - d; if (xxx == checksum) { hextodec(str); vic3_h17_bmv = ergebniss / 100.0; } return; } if (strncmp(vic3_ser, ":7110300", 8) == 0) { char str[9]; char sub5[3] = ""; strncpy(sub5, &vic3_ser[16], 2); sub5[2] = '\0'; hextodec(sub5); int checksum = ergebniss; char sub4[3] = ""; strncpy(sub4, &vic3_ser[14], 2); sub4[2] = '\0'; hextodec(sub4); int d = ergebniss; strcpy (str, sub4); char sub3[3] = ""; strncpy(sub3, &vic3_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int c = ergebniss; strcat (str, sub3); char sub2[3] = ""; strncpy(sub2, &vic3_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcat (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic3_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = 58 - a - b - c - d; if (xxx == checksum) { hextodec(str); vic3_h18_bmv = ergebniss / 100.0; } return; } if (strncmp(vic3_ser, ":7060300", 8) == 0) { char str[9]; char sub5[3] = ""; strncpy(sub5, &vic3_ser[16], 2); sub5[2] = '\0'; hextodec(sub5); int checksum = ergebniss; char sub4[3] = ""; strncpy(sub4, &vic3_ser[14], 2); sub4[2] = '\0'; hextodec(sub4); int d = ergebniss; strcpy (str, sub4); char sub3[3] = ""; strncpy(sub3, &vic3_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int c = ergebniss; strcat (str, sub3); char sub2[3] = ""; strncpy(sub2, &vic3_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcat (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic3_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = 69 - a - b - c - d; if (xxx == checksum) { hextodec(str); vic3_h7_bmv = ergebniss / 100.0; } return; } if (strncmp(vic3_ser, ":7070300", 8) == 0) { char str[9]; char sub5[3] = ""; strncpy(sub5, &vic3_ser[16], 2); sub5[2] = '\0'; hextodec(sub5); int checksum = ergebniss; char sub4[3] = ""; strncpy(sub4, &vic3_ser[14], 2); sub4[2] = '\0'; hextodec(sub4); int d = ergebniss; strcpy (str, sub4); char sub3[3] = ""; strncpy(sub3, &vic3_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int c = ergebniss; strcat (str, sub3); char sub2[3] = ""; strncpy(sub2, &vic3_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcat (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic3_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = 68 - a - b - c - d; if (xxx == checksum) { hextodec(str); vic3_h8_bmv = ergebniss / 100.0; } return; } if (strncmp(vic3_ser, ":7FF0F00", 8) == 0) { char str[5]; char sub3[3] = ""; strncpy(sub3, &vic3_ser[12], 2); sub3[2] = '\0'; hextodec(sub3); int checksum = ergebniss; char sub2[3] = ""; strncpy(sub2, &vic3_ser[10], 2); sub2[2] = '\0'; hextodec(sub2); int b = ergebniss; strcpy (str, sub2); char sub1[3] = ""; strncpy(sub1, &vic3_ser[8], 2); sub1[2] = '\0'; hextodec(sub1); int a = ergebniss; strcat (str, sub1); byte xxx = -192 - a - b; if (xxx == checksum) { hextodec(str); vic3_soc_bmv = ergebniss / 100.0; } return; } } //**************** long hextodec(char*hdec) { ergebniss = 0; while (*hdec) { long onebyte = *hdec++; if (onebyte >= '0' && onebyte <= '9') { onebyte = onebyte - '0'; } else if (onebyte >= 'a' && onebyte <= 'f') { onebyte = onebyte - 'a' + 10; } else if (onebyte >= 'A' && onebyte <= 'F') { onebyte = onebyte - 'A' + 10; } ergebniss = (ergebniss << 4) | (onebyte & 0xF); } return ergebniss; } //******************** void ina_226() { shunt = readRegister(0x01); if (shunt && 0x8000) { shunt = ~shunt; shunt += 1; shunt *= -1 ; } shunt_logger = shunt; shunt = constrain(shunt, 3000, 17500); p_map = (map(shunt, 3000, 17500, 0, 13000 )) / 10; p_ueber = (p_map - vic2_ppv_mppt); //p_ueber = constrain(p_ueber, 0, 1300); } //******************** void ueberschuss() { if (vic2_cs_mppt != 4 && vic2_cs_mppt != 5) { reset(); relais(); return; } if (vic2_cs_mppt == 4 && status_float == 0) { status_absorption = 0; status_float = 1; reset(); relais(); } if (vic2_cs_mppt == 5 && status_absorption == 0) { status_absorption = 1; status_float = 0; reset(); relais(); } if (zaehler < 120) { if (zaehler < 60) { messung_1 = samples1.getMedian(); mess = 1; } if (zaehler >= 60) { messung_2 = samples2.getMedian(); mess = 2; } samples1.add(vic2_v_mppt_r); samples2.add(vic2_v_mppt_r); zaehler++; } if (zaehler == 120) { mess = 3; if (abs(messung_1 - messung_2) <= 3) //<<<<<----- 0.03 Volt { if (vic2_v_mppt_r > (min(messung_1, messung_2)) - 20) //<<<<<-----0.2 Volt { if (p_ueber > p_K1 && status_K2 == HIGH && status_K3 == HIGH && status_K4 == HIGH) { status_K1 = LOW; } if (p_ueber <= 0 && status_K2 == HIGH && status_K3 == HIGH && status_K4 == HIGH) { status_K1 = HIGH; } if (p_ueber > p_K2 && status_K1 == LOW && status_K3 == HIGH && status_K4 == HIGH) { status_K2 = LOW; } if (p_ueber <= 0 && status_K1 == LOW && status_K3 == HIGH && status_K4 == HIGH) { status_K2 = HIGH; } if (p_ueber > p_K3 && status_K1 == LOW && status_K2 == LOW && status_K4 == HIGH) { status_K3 = LOW; } if (p_ueber <= 0 && status_K1 == LOW && status_K2 == LOW && status_K4 == HIGH) { status_K3 = HIGH; } if (p_ueber > p_K4 && status_K1 == LOW && status_K2 == LOW && status_K3 == LOW) { status_K4 = LOW; } if (p_ueber <= 0 && regel == 0 && status_K1 == LOW && status_K2 == LOW && status_K3 == LOW) { status_K4 = HIGH; up_down = 0; } if (p_ueber > 100 && status_K1 == LOW && status_K2 == LOW && status_K3 == LOW && status_K4 == LOW) { static unsigned long prev_millis; if (millis() - prev_millis > 2000) { prev_millis = millis(); } regel++; up_down = 1; } if (p_ueber <= 20 && status_K1 == LOW && status_K2 == LOW && status_K3 == LOW && status_K4 == LOW) { regel--; up_down = 2; } } else { regel = regel - 2; up_down = 2; } } else { reset(); } } relais(); regel = constrain(regel, 0, 20); } //**************** void nulldurchgang() { //regel = 8; if (counter == 20) counter = 0; if (counter == 0) Status = 1; if (counter == regel) Status = 0; PORTA = (Status << PA0); counter++; } //******************** void reset() { zaehler = 0; messung_1 = 0; messung_2 = 0; mess = 0; regel = 0; up_down = 0; status_K1 = HIGH; status_K2 = HIGH; status_K3 = HIGH; status_K4 = HIGH; } //******************** void relais() { digitalWrite(K1, status_K1); digitalWrite(K2, status_K2); digitalWrite(K3, status_K3); digitalWrite(K4, status_K4); } //******************** void thingspeak() { schalter++; switch (schalter) { case 1: digitalWrite(sim900_pin, HIGH); break; case 2: digitalWrite(sim900_pin, LOW); break; case 22: Serial_SIM900.println(F("AT+CIPSHUT")); break; case 24: Serial_SIM900.println(F("ATE0")); break; case 26: Serial_SIM900.println(F("AT+CIPMUX=0")); break; case 28: Serial_SIM900.println(F("AT+CSTT=\"internet\"")); break; case 30: Serial_SIM900.println(F("AT+CIICR")); break; case 32: Serial_SIM900.println(F("AT+CIFSR")); break; case 34: Serial_SIM900.println(F("AT+CIPSPRT=0")); break; case 36: Serial_SIM900.println(F("AT+CSQ")); break; case 38: Serial_SIM900.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"")); break; case 41: Serial_SIM900.println(F("AT+CIPSEND")); break; case 43: daten1(); break; case 45: Serial_SIM900.println((char)26); break; case 53: Serial_SIM900.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"")); break; case 56: Serial_SIM900.println(F("AT+CIPSEND")); break; case 58: daten2(); break; case 60: Serial_SIM900.println((char)26); break; case 68: Serial_SIM900.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"")); break; case 71: Serial_SIM900.println(F("AT+CIPSEND")); break; case 73: daten3(); break; case 75: Serial_SIM900.println((char)26); break; case 83: Serial_SIM900.println(F("AT+CIPSTART=\"TCP\",\"api.thingspeak.com\",\"80\"")); break; case 86: Serial_SIM900.println(F("AT+CIPSEND")); break; case 88: daten4(); break; case 90: Serial_SIM900.println((char)26); break; case 98: schalter = 37; if (error >= 1) { schalter = 21; error = 0; } break; } } //................ void daten1() //MPPT 100/50 12 Volt { char v[10]; char i[10]; char vpv[10]; char ppv[10]; char h20[10]; char cs[10]; dtostrf(vic1_v_mppt, 1, 2, v ); dtostrf(vic1_i_mppt, 1, 2, i ); dtostrf(vic1_vpv_mppt, 1, 2, vpv ); itoa(vic1_ppv_mppt, ppv, 10 ); itoa(vic1_h20_mppt, h20, 10 ); itoa(vic1_cs_mppt, cs, 10 ); char daten1[180] = "GET http://api.thingspeak.com/update?api_key=MC6V8698TB8GXDS3&field1="; strcat (daten1, v); //MPPT Spannung strcat (daten1, "&field2="); strcat (daten1, i); //MPPT Strom strcat (daten1, "&field3="); strcat (daten1, vpv); //PV Spannung strcat (daten1, "&field4="); strcat (daten1, ppv); //PV Leistung strcat (daten1, "&field5="); strcat (daten1, h20); //Wh/Tag strcat (daten1, "&field6="); strcat (daten1, cs); //Status Serial_SIM900.println(daten1); } //................ void daten2() //MPPT 100/50 24 Volt { char v[10]; char i[10]; char vpv[10]; char ppv[10]; char h20[10]; char cs[10]; char p_ueber_[10]; char regel_[10]; dtostrf(vic2_v_mppt, 1, 2, v ); dtostrf(vic2_i_mppt, 1, 2, i ); dtostrf(vic2_vpv_mppt, 1, 2, vpv ); itoa(vic2_ppv_mppt, ppv, 10 ); itoa(vic2_h20_mppt, h20, 10 ); itoa(vic2_cs_mppt, cs, 10 ); itoa(p_ueber, p_ueber_, 10 ); itoa(regel, regel_, 10 ); char daten2[180] = "GET http://api.thingspeak.com/update?api_key=5Y645SG09QQZ3NA8&field1="; strcat (daten2, v); //MPPT Spannung strcat (daten2, "&field2="); strcat (daten2, i); //MPPT Strom strcat (daten2, "&field3="); strcat (daten2, vpv); //PV Spannung strcat (daten2, "&field4="); strcat (daten2, ppv); //PV Leistung strcat (daten2, "&field5="); strcat (daten2, h20); //Wh/Tag strcat (daten2, "&field6="); strcat (daten2, cs); //Status strcat (daten2, "&field7="); strcat (daten2, p_ueber_); // Überschuss Leistung strcat (daten2, "&field8="); strcat (daten2, regel_); // Last 0 - 255 Serial_SIM900.println(daten2); } //................ void daten3() //BMV 702 24 Volt { char v[10]; char i[10]; char p[10]; char h18[10]; char h17[10]; char h8[10]; char h7[10]; char soc[10]; dtostrf(vic3_v_bmv, 1, 2, v ); dtostrf(vic3_i_bmv, 1, 2, i ); itoa(vic3_p_bmv, p , 10 ); dtostrf(vic3_h18_bmv, 1, 2, h18 ); dtostrf(vic3_h17_bmv, 1, 2, h17 ); dtostrf(vic3_h8_bmv, 1, 2, h8 ); dtostrf(vic3_h7_bmv, 1, 2, h7 ); dtostrf(vic3_soc_bmv, 1, 2, soc ); char daten3[180] = "GET http://api.thingspeak.com/update?api_key=XDJ604T15I5ZNIWS&field1="; strcat (daten3, v); //BMV Spannung strcat (daten3, "&field2="); strcat (daten3, i); //BMV Strom strcat (daten3, "&field3="); strcat (daten3, p); //BMV Leistung strcat (daten3, "&field4="); strcat (daten3, h18); //KWH geladen strcat (daten3, "&field5="); strcat (daten3, h17); //KWH entladen strcat (daten3, "&field6="); strcat (daten3, h8); //höchste Spannung strcat (daten3, "&field7="); strcat (daten3, h7); //niedrigste Spannung strcat (daten3, "&field8="); strcat (daten3, soc); //SOC Serial_SIM900.println(daten3); } //................ void daten4() //BME 280 / SIM 900 { char temperatur_[10]; char luftfeuchtigkeit_[10]; char luftdruck_[10]; char error_counter_[10]; char shunt_logger_[10]; dtostrf(temperatur, 1, 2, temperatur_); dtostrf(luftfeuchtigkeit, 1, 2, luftfeuchtigkeit_); dtostrf(luftdruck, 1, 2, luftdruck_); itoa(error_counter, error_counter_ , 10 ); itoa(shunt_logger, shunt_logger_ , 10 ); char daten4[180] = "GET http://api.thingspeak.com/update?api_key=YNYKLGS425SLZ828&field1="; strcat (daten4, temperatur_); //Temperatur strcat (daten4, "&field2="); strcat (daten4, luftfeuchtigkeit_); //Luftfeuchtigkeit strcat (daten4, "&field3="); strcat (daten4, luftdruck_); //Luftdruck strcat (daten4, "&field4="); strcat (daten4, error_counter_); //SIM 900 Error strcat (daten4, "&field5="); strcat (daten4, shunt_logger_); //Einstrahlung Serial_SIM900.println(daten4); } //******************** void fest_display() { lcd.clear(); lcd.setCursor (5, 0); lcd.print(F("V")); lcd.setCursor (13, 0); lcd.print(F("A")); lcd.setCursor (5, 1); lcd.print(F("V")); lcd.setCursor (13, 1); lcd.print(F("A")); lcd.setCursor (5, 2); lcd.print(F("V")); lcd.setCursor (13, 2); lcd.print(F("A")); lcd.setCursor (5, 3); lcd.print(F("W")); lcd.setCursor (18, 3); lcd.write(0xdf); //Grad Zeichen lcd.setCursor (19, 3); lcd.print(F("C")); } //******************** void vic1_display() { lcd.setCursor (0, 0); lcd.print(vic1_v_mppt); lcd.setCursor (9, 0); if (vic1_i_mppt < 9.995) lcd.print(F(" ")); lcd.print(vic1_i_mppt, 1); lcd.setCursor (15, 0); if (vic1_cs_mppt == 0) lcd.print(F("AUS ")); if (vic1_cs_mppt == 2) lcd.print(F("FAULT")); if (vic1_cs_mppt == 3) lcd.print(F("BULK ")); if (vic1_cs_mppt == 4) lcd.print(F("ABS ")); if (vic1_cs_mppt == 5) lcd.print(F("FLOAT")); if (vic1_cs_mppt == 7) lcd.print(F("EQU M")); if (vic1_cs_mppt == 245) lcd.print(F("START")); if (vic1_cs_mppt == 247) lcd.print(F("EQU A")); if (vic1_cs_mppt == 252) lcd.print(F("EXT ")); } //******************** void vic2_display() { lcd.setCursor (0, 1); lcd.print(vic2_v_mppt); lcd.setCursor (9, 1); if (vic2_i_mppt < 9.995) lcd.print(F(" ")); lcd.print(vic2_i_mppt, 1); lcd.setCursor (15, 1); if (vic2_cs_mppt == 0) lcd.print(F("AUS ")); if (vic2_cs_mppt == 2) lcd.print(F("FAULT")); if (vic2_cs_mppt == 3) lcd.print(F("BULK ")); if (vic2_cs_mppt == 4) lcd.print(F("ABS ")); if (vic2_cs_mppt == 5) lcd.print(F("FLOAT")); if (vic2_cs_mppt == 7) lcd.print(F("EQU M")); if (vic2_cs_mppt == 245) lcd.print(F("START")); if (vic2_cs_mppt == 247) lcd.print(F("EQU A")); if (vic2_cs_mppt == 252) lcd.print(F("EXT ")); } //******************** void vic3_display() { lcd.setCursor (0, 2); lcd.print(vic3_v_bmv); lcd.setCursor (7, 2); if (abs(vic3_i_bmv) < 99.995) lcd.print(F(" ")); if (abs(vic3_i_bmv) < 9.995) lcd.print(F(" ")); if (vic3_i_bmv >= 0) lcd.print(F(" ")); lcd.print(vic3_i_bmv, 1); } //******************** void ueberschuss_display() { lcd.setCursor (15, 2); if (mess == 0) lcd.print(F(" ")); if (mess == 1) lcd.print(F("MESS1")); if (mess == 2) lcd.print(F("MESS2")); if (mess == 3) lcd.print(F("UEBER")); lcd.setCursor (0, 3); if (abs(p_ueber) < 1000) lcd.print(F(" ")); if (abs(p_ueber) < 100) lcd.print(F(" ")); if (abs(p_ueber) < 10) lcd.print(F(" ")); if (p_ueber >= 0) lcd.print(F(" ")); lcd.print(p_ueber); lcd.setCursor (7, 3); if (regel < 100) lcd.print(F(" ")); if (regel < 10) lcd.print(F(" ")); lcd.print(regel); lcd.setCursor (10, 3); if (up_down == 0) lcd.write(byte(0)); if (up_down == 1) lcd.write(byte(1)); if (up_down == 2) lcd.write(byte(2)); } //******************** void bme280_display() { lcd.setCursor (12, 3); if (abs(temperatur < 9.995)) lcd.print(F(" ")); if (temperatur >= 0) lcd.print(F(" ")); lcd.print(temperatur); } //******************** static void writeRegister(byte reg, word value) { Wire.beginTransmission(ina226_addr); Wire.write(reg); Wire.write((value >> 8) & 0xFF); Wire.write(value & 0xFF); Wire.endTransmission(); } //******************** static word readRegister(byte reg) { word res = 0x0000; Wire.beginTransmission(ina226_addr); Wire.write(reg); if (Wire.endTransmission() == 0) { if (Wire.requestFrom(ina226_addr, 2) >= 2) { res = Wire.read() * 256; res += Wire.read(); } } return res; } //******************** void bme280() { temperatur = (bme.readTemperature()); luftfeuchtigkeit = (bme.readHumidity()); luftdruck = ((bme.readPressure() / 100.0F) + 12.8); //Luftdruck umgerechnet von 103m ueber Meereshoehe auf Meereshoehe }
