INFO
Test log initialized.
INFO
User Input module initialized
INFO
Windows 7 Professional (Build 7601.24384.amd64fre.win7sp1_ldr_escrow.190220-1800)
INFO
CVApp.exe ver 4.0.1.0
INFO
BaseUtilities.dll ver 4.0.1.0
INFO
CommandVerifierLog.dll ver 4.0.1.0
INFO
GuiHelper.dll ver 4.0.1.0
INFO
TestUtilities.dll ver 4.0.1.0
INFO
TestSuiteEngine.dll ver 4.0.1.0
INFO
EhciDevIOCTL.dll ver 1.5.14.0
INFO
EhciTestServices.dll ver 1.5.14.0
INFO
USBUtilities.dll ver 1.4.5.1
INFO
StackSwitcher.dll ver 1.4.5.1
INFO
USBCommandVerifier.dll ver 1.5.14.0
INFO
BOTTests.dll ver 1.5.14.0
INFO
Host selected: PCI-Bus 0, Gerät 29, Funktion 0
INFO
DUT selected: HS Device (MSC/BOT) addr=2: VID=0951, PID=1665
INFO
Start time: Jun 27, 2021 - 14:24:59
INFO
Configuring device, set configuration = 0x1
INFO
NOTE: It is expected the device has reset the data toggles on all Bulk endpoints after the above SetConfiguration call
INFO
Re-enumerating device
WARNING
Attempt to read interfaces for current configuration (index: 0) failed.
INFO
Start time: Jun 27, 2021 - 14:25:11
INFO
INFO
INFO
INFO
No MSC interface descriptor found.
FAIL
(MSC: 5.1.5) Devices must support at least one Bulk-Only Data Interface (InterfaceClass = 0x08).
FAIL
Test did not execute all required steps.
INFO
Stop time: Jun 27, 2021 - 14:25:19
INFO
Stopping Test [ MSC Configuration Existance Test (Configuration Index 0):
Number of: Fails (2); Aborts (1); Warnings (0) ]
INFO
Device is NOT considered compliant with the Bootability specification.
FAIL
One or more functions called in this Test Suite failed to perform required tasks.
INFO
TEST SUITE SUMMARY:
[ Fails (3); Aborts (2); Warnings (1) ]
INFO
TEST RESULTS:
[ Passed (0); Failed (1) ]
