#include #include "OS_SerialTFT.h" SerialTFT::SerialTFT(uint8_t rxd, uint8_t txd):myTFT(txd, rxd) { } void SerialTFT::begin(long speed) { myTFT.begin(speed); } uint8_t SerialTFT::checkFeedback() { uint16_t timeout = 318;//318*15.72=5000us = 5ms while(!myTFT.available())//one loop is about 15.72us { timeout--; if(!timeout) return 0; } char len; if(findStartByte()) { len = myTFT.read(); } else return 0;// for(uint8_t i = 0;i < len;i++) { feedbackBuf[i] = myTFT.read(); delay(2); } if(feedbackBuf[len-1] == (char)0xEF) { if((feedbackBuf[0] == 'o')&&(feedbackBuf[1] == 'k')) return FEEDBACK_OK; else if((feedbackBuf[0] == 'e')&&(feedbackBuf[1] == '1')) return FEEDBACK_E1; else if((feedbackBuf[0] == 'e')&&(feedbackBuf[1] == '2')) return FEEDBACK_E2; else return feedbackBuf[0]; } else return 0; } uint8_t SerialTFT::findStartByte() { char StartByte = 0;// while(myTFT.available()) { char dat; dat = myTFT.read(); delay(2); if(dat == 0x7E) { StartByte = dat; break;//find the Start Byte; } } if(StartByte == 0x7E) return 1; else return 0; } /**********************************************/ void SerialTFT::sendCommand(char cmd[], uint8_t length) { char dat[length+3]; dat[0] = 0x7e; dat[1] = length+1; for(uint8_t i = 0; i< length; i++) { dat[i+2] = cmd[i]; } dat[length+2] = 0xef; for(uint8_t i = 0; i< length+3; i++) { sendByte(dat[i]); } } /**************************************/ //this is the line you should modify to match you MCU system. inline void SerialTFT::sendByte(uint8_t dat) { myTFT.write(dat); } /*************************************/ //---------------------------------------- void SerialTFT::test() { char temp[1]; temp[0] = TEST_CMD; sendCommand(temp,1); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::setCursor(int16_t x, int16_t y) { char temp[5]; temp[0] = SET_READ_CURSOR; temp[1] = x>>8; temp[2] = x; temp[3] = y>>8; temp[4] = y; sendCommand(temp,5); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::readCursor(int16_t &x, int16_t &y) { char temp[1]; temp[0] = SET_READ_CURSOR; sendCommand(temp,1); while(checkFeedback()!=SET_READ_CURSOR); x = ((uint8_t)feedbackBuf[1]<<8) + (uint8_t)feedbackBuf[2]; y = ((uint8_t)feedbackBuf[3]<<8) + (uint8_t)feedbackBuf[4]; while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::setTextColor(uint16_t color) { char temp[3]; temp[0] = SET_TEXTCOLOR; temp[1] = color>>8; temp[2] = color; sendCommand(temp,3); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::setTextSize(uint8_t size) { char temp[2]; temp[0] = SET_TEXTSIZE; temp[1] = size; sendCommand(temp,2); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::setRotation(uint8_t rota) //rota = 0, 1, 2, 3 { char temp[2]; temp[0] = SET_ROTATION; temp[1] = rota; sendCommand(temp,2); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::reset() { char temp[1]; temp[0] = RESET; sendCommand(temp,1); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::setBacklight(uint8_t bightness) { char temp[2]; temp[0] = SET_BACKLIGHT; temp[1] = bightness; sendCommand(temp,2); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::println() { char temp[1]; temp[0] = PRINTLN; sendCommand(temp,1); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::print(const char str[]) { char temp[61];//can not be more than 61bytes a time uint8_t i = 0; temp[0] = PRINT_CHAR_ARRAY; while(str[i] != '\0') { temp[i+1] = str[i]; i++; } sendCommand(temp,i+1); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::print(int8_t c) { char temp[4]; temp[0] = PRINT_INT_8; temp[1] = SIGNED; temp[2] = 0;//format, char have no format temp[3] = c; sendCommand(temp,4); while(checkFeedback()!=FEEDBACK_OK); } //base: //#define DEC 10 //#define HEX 16 //#define OCT 8 //#define BIN 2 void SerialTFT::print(uint8_t b, uint8_t base) { char temp[4]; temp[0] = PRINT_INT_8; temp[1] = UNSIGNED; temp[2] = base;// temp[3] = b; sendCommand(temp,4); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::print(int16_t n) { char temp[5]; temp[0] = PRINT_INT_16; temp[1] = SIGNED; temp[2] = 0;//format, char have no format temp[3] = n>>8; temp[4] = n; sendCommand(temp,5); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::print(uint16_t n, uint8_t base) { char temp[5]; temp[0] = PRINT_INT_16; temp[1] = UNSIGNED; temp[2] = base;// temp[3] = n>>8; temp[4] = n; sendCommand(temp,5); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::print(int32_t n) { char temp[7]; temp[0] = PRINT_INT_32; temp[1] = SIGNED; temp[2] = 0;//format, char have no format temp[3] = n>>24; n <<= 8; temp[4] = n>>24; n <<= 8; temp[5] = n>>24; n <<= 8; temp[6] = n>>24; sendCommand(temp,7); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::print(uint32_t n, uint8_t base) { char temp[7]; temp[0] = PRINT_INT_32; temp[1] = UNSIGNED; temp[2] = base;// temp[3] = n>>24; temp[4] = n>>16; temp[5] = n>>8; temp[6] = n; sendCommand(temp,7); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::println(const char str[]) { print(str); println(); } void SerialTFT::println(int8_t c) { print(c); println(); } void SerialTFT::println(uint8_t b, uint8_t base) { print(b, base); println(); } void SerialTFT::println(int16_t n) { print(n); println(); } void SerialTFT::println(uint16_t n, uint8_t base) { print(n,base); println(); } void SerialTFT::println(int32_t n) { print(n); println(); } void SerialTFT::println(uint32_t n, uint8_t base) { print(n,base); println(); } void SerialTFT::fillScreen(uint16_t color) { char temp[3]; temp[0] = FILL_SREEN; temp[1] = color>>8; temp[2] = color; sendCommand(temp,3); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::drawPixel(int16_t x, int16_t y, uint16_t color) { char temp[7]; temp[0] = DRAW_PIXEL; temp[1] = x>>8; temp[2] = x; temp[3] = y>>8; temp[4] = y; temp[5] = color>>8; temp[6] = color; sendCommand(temp,7); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::drawFastHLine(int16_t x0, int16_t y0, int16_t w, uint16_t color) { char temp[9]; temp[0] = DRAW_FASTHLINE; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = w>>8; temp[6] = w; temp[7] = color>>8; temp[8] = color; sendCommand(temp,9); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::drawFastVLine(int16_t x0, int16_t y0, int16_t h, uint16_t color) { char temp[9]; temp[0] = DRAW_FASTVLINE; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = h>>8; temp[6] = h; temp[7] = color>>8; temp[8] = color; sendCommand(temp,9); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color) { char temp[11]; temp[0] = DRAW_LINE; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = x1>>8; temp[6] = x1; temp[7] = y1>>8; temp[8] = y1; temp[9] = color>>8; temp[10] = color; sendCommand(temp,11); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::drawRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color) { char temp[11]; temp[0] = DRAW_RECT; temp[1] = x>>8; temp[2] = x; temp[3] = y>>8; temp[4] = y; temp[5] = w>>8; temp[6] = w; temp[7] = h>>8; temp[8] = h; temp[9] = color>>8; temp[10] = color; sendCommand(temp,11); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color) { char temp[11]; temp[0] = FILL_RECT; temp[1] = x>>8; temp[2] = x; temp[3] = y>>8; temp[4] = y; temp[5] = w>>8; temp[6] = w; temp[7] = h>>8; temp[8] = h; temp[9] = color>>8; temp[10] = color; sendCommand(temp,11); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::drawCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color) { char temp[9]; temp[0] = DRAW_CIRCLE; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = r>>8; temp[6] = r; temp[7] = color>>8; temp[8] = color; sendCommand(temp,9); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::fillCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color) { char temp[9]; temp[0] = FILL_CIRCLE; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = r>>8; temp[6] = r; temp[7] = color>>8; temp[8] = color; sendCommand(temp,9); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::drawTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color) { char temp[15]; temp[0] = DRAW_TRIANGLE; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = x1>>8; temp[6] = x1; temp[7] = y1>>8; temp[8] = y1; temp[9] = x2>>8; temp[10] = x2; temp[11] = y2>>8; temp[12] = y2; temp[13] = color>>8; temp[14] = color; sendCommand(temp,15); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::fillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color) { char temp[15]; temp[0] = FILL_TRIANGLE; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = x1>>8; temp[6] = x1; temp[7] = y1>>8; temp[8] = y1; temp[9] = x2>>8; temp[10] = x2; temp[11] = y2>>8; temp[12] = y2; temp[13] = color>>8; temp[14] = color; sendCommand(temp,15); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::drawRoundRect(int16_t x0, int16_t y0, int16_t w, int16_t h, int16_t r, uint16_t color) { char temp[13]; temp[0] = DRAW_ROUNDRECT; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = w>>8; temp[6] = w; temp[7] = h>>8; temp[8] = h; temp[9] = r>>8; temp[10] = r; temp[11] = color>>8; temp[12] = color; sendCommand(temp,13); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::fillRoundRect(int16_t x0, int16_t y0, int16_t w, int16_t h, int16_t r, uint16_t color) { char temp[13]; temp[0] = FILL_ROUNDRECT; temp[1] = x0>>8; temp[2] = x0; temp[3] = y0>>8; temp[4] = y0; temp[5] = w>>8; temp[6] = w; temp[7] = h>>8; temp[8] = h; temp[9] = r>>8; temp[10] = r; temp[11] = color>>8; temp[12] = color; sendCommand(temp,13); while(checkFeedback()!=FEEDBACK_OK); } void SerialTFT::bmpDraw(char *filename) { char temp[9];//can not be more than 8 byte file name uint8_t i = 0; temp[0] = DRAW_BMP; while(*(filename+i)!='\0') { temp[i+1] = *(filename+i); i++; } sendCommand(temp,i+1); while(checkFeedback()!=FEEDBACK_OK); } uint16_t SerialTFT::color565(uint8_t r, uint8_t g, uint8_t b) { return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3); } /**************************/ //if someone touch, it will return 1. otherwise return 0; uint8_t SerialTFT::touch() { if(checkFeedback() == READ_TOUCH) { touchX = ((uint8_t)feedbackBuf[1]<<8) + (uint8_t)feedbackBuf[2]; touchY = ((uint8_t)feedbackBuf[3]<<8) + (uint8_t)feedbackBuf[4]; return 1; } else return 0; }
