#ifndef _OS_SERIALTFT_H__ #define _OS_SERIALTFT_H__ #include #include #define BLACK 0x0000 #define BLUE 0x001F #define RED 0xF800 #define GREEN 0x07E0 #define CYAN 0x07FF #define MAGENTA 0xF81F #define YELLOW 0xFFE0 #define WHITE 0xFFFF //////////////////////////////////// #define TEST_CMD 0X00 #define SET_READ_CURSOR 0X01 #define SET_TEXTCOLOR 0X02 #define SET_TEXTSIZE 0X03 #define SET_ROTATION 0X04 #define RESET 0X05 #define SET_BACKLIGHT 0X06 #define READ_TOUCH 0X07 #define PRINTLN 0x10 #define PRINT_CHAR_ARRAY 0X11 #define PRINT_INT_8 0X12 #define PRINT_INT_16 0X13 #define PRINT_INT_32 0X14 #define FILL_SREEN 0X20 #define DRAW_PIXEL 0X21 #define DRAW_FASTVLINE 0X22 #define DRAW_FASTHLINE 0X23 #define DRAW_LINE 0X24 #define DRAW_RECT 0X25 #define FILL_RECT 0X26 #define DRAW_CIRCLE 0X27 #define FILL_CIRCLE 0X28 #define DRAW_TRIANGLE 0X29 #define FILL_TRIANGLE 0X2A #define DRAW_ROUNDRECT 0X2B #define FILL_ROUNDRECT 0X2C #define DRAW_BMP 0X30 #define WRITE_READ_BAUD 0X40 #define READ_VERSION 0X41 #define READ_DRIVER_ID 0X42 #define READ_RESOLUTION 0X43 //////////////////////////////////////////// #define FEEDBACK_OK 0x6F #define FEEDBACK_E1 0x65 #define FEEDBACK_E2 0x66 #define SIGNED 1 #define UNSIGNED 0 class SerialTFT { public: //SerialTFT(uint8_t rxd, uint8_t txd); SerialTFT(Stream&); //void begin(long speed); uint8_t checkFeedback(); uint8_t findStartByte(); void sendCommand(char cmd[], uint8_t length); inline void sendByte(uint8_t dat); void test(); void setCursor(int16_t x, int16_t y); void readCursor(int16_t &x, int16_t &y); void setTextColor(uint16_t color); void setTextSize(uint8_t size) ; void setRotation(uint8_t rota); //rota = 0, 1, 2, 3 void reset(); void setBacklight(uint8_t bightness); void println(); void print(const char str[]); void print(int8_t c); void print(uint8_t b, uint8_t base = DEC); void print(int16_t n); void print(uint16_t n, uint8_t base = DEC); void print(int32_t n); void print(uint32_t n, uint8_t base = DEC); void println(const char str[]); void println(int8_t c); void println(uint8_t b, uint8_t base = DEC); void println(int16_t n); void println(uint16_t n, uint8_t base = DEC); void println(int32_t n); void println(uint32_t n, uint8_t base = DEC); void fillScreen(uint16_t color); void drawPixel(int16_t x, int16_t y, uint16_t color); void drawFastHLine(int16_t x0, int16_t y0, int16_t w, uint16_t color); void drawFastVLine(int16_t x0, int16_t y0, int16_t h, uint16_t color); void drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color); void drawRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color); void fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color); void drawCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color); void fillCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color); void drawTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color); void fillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color); void drawRoundRect(int16_t x0, int16_t y0, int16_t w, int16_t h, int16_t r, uint16_t color); void fillRoundRect(int16_t x0, int16_t y0, int16_t w, int16_t h, int16_t r, uint16_t color); void bmpDraw(char *filename); uint16_t color565(uint8_t r, uint8_t g, uint8_t b); uint8_t touch(); uint16_t touchX, touchY; private: //SoftwareSerial myTFT; Stream& myTFT; char feedbackBuf[6]; }; #endif
