//@@ -0,0 +1,39 @@ //This example code is in the Public Domain (or CC0 licensed, at your option.) //By Evandro Copercini - 2018 // //This example creates a bridge between Serial and Classical Bluetooth (SPP) //and also demonstrate that SerialBT have the same functionalities of a normal Serial #include "BluetoothSerial.h" #if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED) #error Bluetooth is not enabled! Please run `make menuconfig` to and enable it #endif BluetoothSerial SerialBT; uint8_t address[6] = {0xAA, 0xBB, 0xCC, 0x11, 0x22, 0x33}; String MACadd = "AA:BB:CC:11:22:33"; //uint8_t address[6] = {0x10, 0x52, 0x1C, 0x5D, 0x61, 0x66}; //String MACadd = "10:52:1C:5D:61:66"; //String MACadd = "9B:D3:71:F5:E9:57"; /// String name = "OBDII"; //String name = "HC-05"; int Sekunde=0; unsigned long previousMillis = 0; // const long interval = 2000; // Intervall (milliseconds) unsigned long currentMillis=0; char *pin = "1234"; //<- standard pin would be provided by default void setup() { Serial.begin(115200); //SerialBT.setPin(pin); SerialBT.begin("ESP32WROOM_MINI", true); //z.Z. D1 MINI //SerialBT.setPin(pin);//??? Serial.println("The device started in master mode, make sure remote BT device is on!"); //delay(2000); //Das Gerät wurde im Master-Modus gestartet, stellen Sie sicher, //dass das Remote-BT-Gerät eingeschaltet ist! SerialBT.connect(address); //SerialBT.connect(name);//??? } uint8_t a =0; void loop() { currentMillis = millis(); if (currentMillis - previousMillis >= interval) { previousMillis = currentMillis; SerialBT.write(a); //jede sec Serial.println(a); a++; if (a==100){a=0;} } if (Serial.available()) { SerialBT.write(Serial.read()); } if (SerialBT.available()) { Serial.write(SerialBT.read()); } delay(20); }
