1TB Samsung 860Pro (SATA-USB3 Adapter ok) ================== insert adapter into NB Aug 18 15:34:21 linux-kwm1 kernel: usb 2-5: new SuperSpeed USB device number 11 using xhci_hcd Aug 18 15:34:21 linux-kwm1 kernel: usb 2-5: New USB device found, idVendor=174c, idProduct=1153, bcdDevice= 0.01 Aug 18 15:34:21 linux-kwm1 kernel: usb 2-5: New USB device strings: Mfr=2, Product=3, SerialNumber=1 Aug 18 15:34:21 linux-kwm1 kernel: usb 2-5: Product: AS2115 Aug 18 15:34:21 linux-kwm1 kernel: usb 2-5: Manufacturer: ASMedia Aug 18 15:34:21 linux-kwm1 kernel: usb 2-5: SerialNumber: 00000000000000000000 Aug 18 15:34:21 linux-kwm1 kernel: usb-storage 2-5:1.0: USB Mass Storage device detected Aug 18 15:34:21 linux-kwm1 kernel: scsi host4: usb-storage 2-5:1.0 Aug 18 15:34:21 linux-kwm1 mtp-probe[5101]: checking bus 2, device 11: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5" Aug 18 15:34:21 linux-kwm1 mtp-probe[5101]: bus: 2, device: 11 was not an MTP device Aug 18 15:34:21 linux-kwm1 mtp-probe[5126]: checking bus 2, device 11: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5" Aug 18 15:34:21 linux-kwm1 mtp-probe[5126]: bus: 2, device: 11 was not an MTP device Aug 18 15:34:22 linux-kwm1 kernel: scsi 4:0:0:0: Direct-Access ASMT 2115 0 PQ: 0 ANSI: 6 Aug 18 15:34:22 linux-kwm1 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0 Aug 18 15:34:22 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Spinning up disk... Aug 18 15:34:25 linux-kwm1 kernel: ...ready Aug 18 15:34:25 linux-kwm1 kernel: sd 4:0:0:0: [sdc] 2000409264 512-byte logical blocks: (1.02 TB/954 GiB) Aug 18 15:34:25 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write Protect is off Aug 18 15:34:25 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Mode Sense: 43 00 00 00 Aug 18 15:34:25 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Aug 18 15:34:25 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Attached SCSI disk Aug 18 15:34:25 linux-kwm1 kernel: EXT4-fs (sdc): warning: mounting unchecked fs, running e2fsck is recommended Aug 18 15:34:25 linux-kwm1 udisksd[2266]: Mounted /dev/sdc at /run/media/mw/MWBACKUP on behalf of uid 1000 Aug 18 15:34:25 linux-kwm1 kernel: EXT4-fs (sdc): mounted filesystem without journal. Opts: (null). Quota mode: none. Aug 18 15:34:25 linux-kwm1 pcmanfm-qt[2113]: operation finished: 0x0 Aug 18 15:34:25 linux-kwm1 pcmanfm-qt[2113]: delete MountOperation Aug 18 15:34:36 linux-kwm1 pcmanfm-qt[2113]: delete MountOperation umount via file browser: Aug 18 15:34:50 linux-kwm1 pcmanfm-qt[2113]: PlacesView::onEjectButtonClicked Aug 18 15:34:50 linux-kwm1 pcmanfm-qt[2113]: folder unmount Aug 18 15:34:50 linux-kwm1 pcmanfm-qt[2113]: delete MountOperation Aug 18 15:34:50 linux-kwm1 systemd[1]: run-media-mw-MWBACKUP.mount: Deactivated successfully. Aug 18 15:34:50 linux-kwm1 udisksd[2266]: Cleaning up mount point /run/media/mw/MWBACKUP (device 8:32 is not mounted) Aug 18 15:34:50 linux-kwm1 udisksd[2266]: Unmounted /dev/sdc on behalf of uid 1000 512GB Samsung 860Pro (SATA-USB3 Adapter err) ==================== insert adapter into NB Aug 18 15:49:37 linux-kwm1 kernel: usb 2-5: new SuperSpeed USB device number 15 using xhci_hcd Aug 18 15:49:37 linux-kwm1 kernel: usb 2-5: New USB device found, idVendor=174c, idProduct=1153, bcdDevice= 0.01 Aug 18 15:49:37 linux-kwm1 kernel: usb 2-5: New USB device strings: Mfr=2, Product=3, SerialNumber=1 Aug 18 15:49:37 linux-kwm1 kernel: usb 2-5: Product: AS2115 Aug 18 15:49:37 linux-kwm1 kernel: usb 2-5: Manufacturer: ASMedia Aug 18 15:49:37 linux-kwm1 kernel: usb 2-5: SerialNumber: 00000000000000000000 Aug 18 15:49:37 linux-kwm1 kernel: usb-storage 2-5:1.0: USB Mass Storage device detected Aug 18 15:49:37 linux-kwm1 kernel: scsi host4: usb-storage 2-5:1.0 Aug 18 15:49:37 linux-kwm1 mtp-probe[5734]: checking bus 2, device 15: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5" Aug 18 15:49:37 linux-kwm1 mtp-probe[5734]: bus: 2, device: 15 was not an MTP device Aug 18 15:49:38 linux-kwm1 mtp-probe[5759]: checking bus 2, device 15: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5" Aug 18 15:49:38 linux-kwm1 mtp-probe[5759]: bus: 2, device: 15 was not an MTP device Aug 18 15:49:38 linux-kwm1 kernel: scsi 4:0:0:0: Direct-Access ASMT 2115 0 PQ: 0 ANSI: 6 Aug 18 15:49:38 linux-kwm1 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0 Aug 18 15:49:38 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Spinning up disk... Aug 18 15:49:41 linux-kwm1 kernel: ...ready Aug 18 15:49:41 linux-kwm1 kernel: sd 4:0:0:0: [sdc] 2000409264 512-byte logical blocks: (1.02 TB/954 GiB) Aug 18 15:49:41 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write Protect is off Aug 18 15:49:41 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Mode Sense: 43 00 00 00 Aug 18 15:49:41 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Aug 18 15:49:41 linux-kwm1 kernel: sdc: sdc1 Aug 18 15:49:41 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Attached SCSI disk Aug 18 15:49:42 linux-kwm1 kernel: BTRFS info (device sdc1): disk space caching is enabled Aug 18 15:49:42 linux-kwm1 kernel: BTRFS info (device sdc1): has skinny extents Aug 18 15:49:42 linux-kwm1 udisksd[2266]: Mounted /dev/sdc1 at /run/media/mw/BCKZBOOK17 on behalf of uid 1000 Aug 18 15:49:42 linux-kwm1 pcmanfm-qt[2113]: operation finished: 0x0 Aug 18 15:49:42 linux-kwm1 pcmanfm-qt[2113]: delete MountOperation umount via cli: Aug 18 15:51:51 linux-kwm1 udisksd[2266]: Cleaning up mount point /run/media/mw/BCKZBOOK17 (device 8:33 is not mounted) Aug 18 15:51:51 linux-kwm1 sudo[5842]: mw : TTY=pts/0 ; PWD=/home/mw ; USER=root ; COMMAND=/usr/bin/umount /run/media/mw/BCKZBOOK17 Aug 18 15:51:51 linux-kwm1 systemd[1]: run-media-mw-BCKZBOOK17.mount: Deactivated successfully.
