1TB Samsung 860Pro (SATA-USB3 Adapter err) ================== insert adapter into NB Aug 18 15:27:24 linux-kwm1 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0 Aug 18 15:27:24 linux-kwm1 kernel: sd 4:0:0:0: [sdc] 2000409260 512-byte logical blocks: (1.02 TB/954 GiB) Aug 18 15:27:24 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write Protect is off Aug 18 15:27:24 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Mode Sense: 2f 00 00 00 Aug 18 15:27:24 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Aug 18 15:27:24 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Attached SCSI disk Aug 18 15:27:25 linux-kwm1 pcmanfm-qt[2113]: operation finished: 0x55aaade03d10 Aug 18 15:27:25 linux-kwm1 kernel: EXT4-fs (sdc): bad geometry: block count 250051158 exceeds size of device (250051157 blocks) Aug 18 15:27:30 linux-kwm1 pcmanfm-qt[2113]: delete MountOperation Aug 18 15:28:50 linux-kwm1 kernel: EXT4-fs (sdc): bad geometry: block count 250051158 exceeds size of device (250051157 blocks) Aug 18 15:29:54 linux-kwm1 kernel: usb 2-5: USB disconnect, device number 9 Aug 18 15:29:54 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Synchronizing SCSI cache Aug 18 15:29:54 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK Aug 18 15:30:02 linux-kwm1 kernel: usb 2-5: new SuperSpeed USB device number 10 using xhci_hcd Aug 18 15:30:02 linux-kwm1 kernel: usb 2-5: New USB device found, idVendor=2109, idProduct=0711, bcdDevice= 1.44 Aug 18 15:30:02 linux-kwm1 kernel: usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Aug 18 15:30:02 linux-kwm1 kernel: usb 2-5: Product: VLI Product String Aug 18 15:30:02 linux-kwm1 kernel: usb 2-5: Manufacturer: VLI manufacture String Aug 18 15:30:02 linux-kwm1 kernel: usb 2-5: SerialNumber: 000000123AE7 Aug 18 15:30:02 linux-kwm1 kernel: usb-storage 2-5:1.0: USB Mass Storage device detected Aug 18 15:30:02 linux-kwm1 kernel: usb-storage 2-5:1.0: Quirks match for vid 2109 pid 0711: 2000000 Aug 18 15:30:02 linux-kwm1 kernel: scsi host4: usb-storage 2-5:1.0 Aug 18 15:30:02 linux-kwm1 mtp-probe[4965]: checking bus 2, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5" Aug 18 15:30:02 linux-kwm1 mtp-probe[4965]: bus: 2, device: 10 was not an MTP device Aug 18 15:30:02 linux-kwm1 mtp-probe[4990]: checking bus 2, device 10: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5" Aug 18 15:30:02 linux-kwm1 mtp-probe[4990]: bus: 2, device: 10 was not an MTP device Aug 18 15:30:05 linux-kwm1 kernel: scsi 4:0:0:0: Direct-Access USB3.0 high speed 2210 PQ: 0 ANSI: 6 Aug 18 15:30:05 linux-kwm1 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0 Aug 18 15:30:05 linux-kwm1 kernel: sd 4:0:0:0: [sdc] 2000409260 512-byte logical blocks: (1.02 TB/954 GiB) Aug 18 15:30:05 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write Protect is off Aug 18 15:30:05 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Mode Sense: 2f 00 00 00 Aug 18 15:30:05 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Aug 18 15:30:05 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Attached SCSI disk Aug 18 15:30:06 linux-kwm1 kernel: EXT4-fs (sdc): bad geometry: block count 250051158 exceeds size of device (250051157 blocks) ERR-MSG: Error mounting /dev/sdc at /run/media/mw/MWBACKUP: wrong fs type, bad option, bad superblock on /dev/sdc, missing codepage or helper program, or other error 512GB Samsung 860Pro (SATA-USB3 Adapter err) ==================== insert adapter into NB Aug 18 15:41:53 linux-kwm1 kernel: usb 2-5: new SuperSpeed USB device number 12 using xhci_hcd Aug 18 15:41:53 linux-kwm1 kernel: usb 2-5: New USB device found, idVendor=2109, idProduct=0711, bcdDevice= 1.44 Aug 18 15:41:53 linux-kwm1 kernel: usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Aug 18 15:41:53 linux-kwm1 kernel: usb 2-5: Product: VLI Product String Aug 18 15:41:53 linux-kwm1 kernel: usb 2-5: Manufacturer: VLI manufacture String Aug 18 15:41:53 linux-kwm1 kernel: usb 2-5: SerialNumber: 000000123AE7 Aug 18 15:41:53 linux-kwm1 kernel: usb-storage 2-5:1.0: USB Mass Storage device detected Aug 18 15:41:53 linux-kwm1 kernel: usb-storage 2-5:1.0: Quirks match for vid 2109 pid 0711: 2000000 Aug 18 15:41:53 linux-kwm1 kernel: scsi host4: usb-storage 2-5:1.0 Aug 18 15:41:53 linux-kwm1 mtp-probe[5311]: checking bus 2, device 12: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5" Aug 18 15:41:53 linux-kwm1 mtp-probe[5311]: bus: 2, device: 12 was not an MTP device Aug 18 15:41:54 linux-kwm1 mtp-probe[5336]: checking bus 2, device 12: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-5" Aug 18 15:41:54 linux-kwm1 mtp-probe[5336]: bus: 2, device: 12 was not an MTP device Aug 18 15:41:56 linux-kwm1 kernel: scsi 4:0:0:0: Direct-Access USB3.0 high speed 2210 PQ: 0 ANSI: 6 Aug 18 15:41:56 linux-kwm1 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0 Aug 18 15:41:56 linux-kwm1 kernel: sd 4:0:0:0: [sdc] 2000409260 512-byte logical blocks: (1.02 TB/954 GiB) Aug 18 15:41:56 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write Protect is off Aug 18 15:41:56 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Mode Sense: 2f 00 00 00 Aug 18 15:41:56 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Aug 18 15:41:56 linux-kwm1 kernel: sdc: sdc1 Aug 18 15:41:56 linux-kwm1 kernel: sdc: p1 size 2000407216 extends beyond EOD, enabling native capacity Aug 18 15:41:56 linux-kwm1 kernel: sdc: sdc1 Aug 18 15:41:56 linux-kwm1 kernel: sdc: p1 size 2000407216 extends beyond EOD, truncated Aug 18 15:41:56 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Attached SCSI disk Aug 18 15:41:56 linux-kwm1 kernel: BTRFS: device label BCKZBOOK17 devid 1 transid 2188 /dev/sdc1 scanned by systemd-udevd (5337) Aug 18 15:41:56 linux-kwm1 pcmanfm-qt[2113]: operation finished: 0x55aaade2a7b0 Aug 18 15:41:56 linux-kwm1 kernel: BTRFS info (device sdc1): disk space caching is enabled Aug 18 15:41:56 linux-kwm1 kernel: BTRFS info (device sdc1): has skinny extents Aug 18 15:41:56 linux-kwm1 kernel: BTRFS error (device sdc1): device total_bytes should be at most 1024208492544 but found 1024208494592 Aug 18 15:41:56 linux-kwm1 kernel: BTRFS error (device sdc1): failed to read chunk tree: -22 Aug 18 15:41:56 linux-kwm1 kernel: BTRFS error (device sdc1): open_ctree failed Aug 18 15:42:14 linux-kwm1 pcmanfm-qt[2113]: delete MountOperation ERR-MSG: Error mounting /dev/sdc1 at /run/media/mw/BCKZBOOK17: wrong fs type, bad option, bad superblock on /dev/sdc1, missing codepage or helper program, or other error
