Auschluß einer jungfräulichen 2TB Disk (keine SSD) Aug 19 07:18:24 linux-kwm1 kernel: usb 2-1: new SuperSpeed USB device number 25 using xhci_hcd Aug 19 07:18:24 linux-kwm1 kernel: usb 2-1: New USB device found, idVendor=2109, idProduct=0711, bcdDevice= 1.44 Aug 19 07:18:24 linux-kwm1 kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Aug 19 07:18:24 linux-kwm1 kernel: usb 2-1: Product: VLI Product String Aug 19 07:18:24 linux-kwm1 kernel: usb 2-1: Manufacturer: VLI manufacture String Aug 19 07:18:24 linux-kwm1 kernel: usb 2-1: SerialNumber: 000000123AFF Aug 19 07:18:24 linux-kwm1 kernel: usb-storage 2-1:1.0: USB Mass Storage device detected Aug 19 07:18:24 linux-kwm1 kernel: usb-storage 2-1:1.0: Quirks match for vid 2109 pid 0711: 2000000 Aug 19 07:18:24 linux-kwm1 kernel: scsi host4: usb-storage 2-1:1.0 Aug 19 07:18:24 linux-kwm1 mtp-probe[20527]: checking bus 2, device 25: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1" Aug 19 07:18:24 linux-kwm1 mtp-probe[20527]: bus: 2, device: 25 was not an MTP device Aug 19 07:18:25 linux-kwm1 mtp-probe[20552]: checking bus 2, device 25: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1" Aug 19 07:18:25 linux-kwm1 mtp-probe[20552]: bus: 2, device: 25 was not an MTP device Aug 19 07:18:27 linux-kwm1 kernel: scsi 4:0:0:0: Direct-Access USB3.0 high speed 2210 PQ: 0 ANSI: 6 Aug 19 07:18:27 linux-kwm1 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0 Aug 19 07:18:27 linux-kwm1 kernel: sd 4:0:0:0: [sdc] 3907029164 512-byte logical blocks: (2.00 TB/1.82 TiB) Aug 19 07:18:27 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write Protect is off Aug 19 07:18:27 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Mode Sense: 2f 00 00 00 Aug 19 07:18:27 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Aug 19 07:18:29 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Attached SCSI disk >lsscsi [4:0:0:0] disk USB3.0 high speed 2210 /dev/sdc >lsusb Bus 002 Device 025: ID 2109:0711 VIA Labs, Inc. VL711 SATA 6Gb/s bridge >mkfs.ext4 -L USB3ADHD /dev/sdc mke2fs 1.46.3 (27-Jul-2021) Creating filesystem with 488378645 4k blocks and 122101760 inodes Filesystem UUID: 15594546-3b4b-4c1a-8dee-b27c3b5ee1a7 Superblock backups stored on blocks: 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208, 4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968, 102400000, 214990848 Allocating group tables: done Writing inode tables: done Creating journal (262144 blocks): done Writing superblocks and filesystem accounting information: done >blkid /dev/sdc /dev/sdc: LABEL="USB3ADHD" UUID="15594546-3b4b-4c1a-8dee-b27c3b5ee1a7" BLOCK_SIZE="4096" TYPE="ext4" >mount /dev/sdc /mnt/sdc (kein ERR!) >time $(dd if=/dev/shm/BIG_FILE_10GB.bin of=/mnt/sdc/IG_FILE_10GB.bin bs=1M status=progress ; sync) 10655629312 bytes (11 GB, 9.9 GiB) copied, 16 s, 666 MB/s 10240+0 records in 10240+0 records out 10737418240 bytes (11 GB, 10 GiB) copied, 16.6382 s, 645 MB/s real 1m30.056s user 0m0.018s sys 0m9.394s >dstat (Seagate ST2000LM015 2TB HD) You did not select any stats, using -cdngy by default. --total-cpu-usage-- -dsk/total- -net/total- ---paging-- ---system-- usr sys idl wai stl| read writ| recv send| in out | int csw 36 9 55 0 0| 382k 66k| 0 0 | 0 0 | 704 2009 1 0 99 0 0| 0 2048k| 128B 0 | 0 0 | 415 1280 4 1 95 0 0| 0 4096k| 950B 280B| 0 0 | 876 3374 2 1 98 0 0| 0 2048k|1170B 350B| 0 0 | 494 1685 1 0 99 0 0| 0 4096k| 416B 140B| 0 0 | 327 1083 2 1 98 0 0| 0 2048k| 700k 8039B| 0 0 | 740 1458 1 12 87 1 0|4096B 2080k| 0 0 | 0 0 | 712 1322 1 12 87 0 0| 0 4096k|2606B 910B| 0 0 | 835 1485 1 13 86 0 0| 0 2048k|3186B 910B| 0 0 | 794 1407 0 13 82 4 0| 0 117M| 128B 0 | 0 0 |1088 2645 0 10 82 7 0| 0 127M| 324B 70B| 0 0 |1167 2895 1 4 80 15 0| 0 103M| 544B 140B| 0 0 | 944 2729 1 4 81 14 0| 0 124M|1248B 420B| 0 0 |1080 2890 1 4 82 13 0| 0 122M| 128B 0 | 0 0 |1005 2831 1 5 84 11 0| 0 129M| 0 0 | 0 0 | 997 2796 1 4 78 16 0| 0 115M|2514B 840B| 0 0 | 996 2758 1 5 74 20 0| 0 96M| 0 0 | 0 0 | 921 2514 1 4 81 14 0| 0 116M|3472B 1120B| 0 0 |1115 2849 1 5 78 16 0| 0 124M|1764B 630B| 0 0 |1036 2987 1 4 84 11 0| 0 128M| 128B 0 | 0 0 |1044 2945 1 3 83 13 0| 0 128M| 832B 280B| 0 0 |1011 2953 1 2 77 19 0| 0 97M| 544B 140B| 0 0 | 919 2492 1 3 85 11 0| 0 132M|2272B 840B| 0 0 |1142 3032 1 2 95 3 0| 0 130M| 128B 0 | 0 0 | 813 2796 1 1 93 5 0| 0 121M|2224B 700B| 0 0 | 839 2614 1 1 95 3 0| 0 132M| 128B 0 | 0 0 | 876 2687 1 1 90 8 0| 0 102M|2176B 770B| 0 0 | 824 2303 1 1 91 6 0| 0 121M| 128B 0 | 0 0 | 960 2750 2 1 85 12 0| 0 130M|2596B 910B| 0 0 | 982 2782 1 1 94 3 0| 0 129M| 868B 210B| 0 0 | 901 2612 1 1 94 4 0| 0 124M| 416B 140B| 0 0 | 816 2689 1 1 91 6 0| 0 114M|2606B 910B| 0 0 | 821 2654 1 1 95 4 0| 0 129M|2596B 910B| 0 0 | 835 2701 1 1 90 7 0| 0 124M| 128B 0 | 0 0 | 845 2686 1 1 96 1 0| 0 129M| 416B 140B| 0 0 | 817 2648 1 1 95 2 0| 0 121M| 544B 140B| 0 0 | 820 2618 --total-cpu-usage-- -dsk/total- -net/total- ---paging-- ---system-- usr sys idl wai stl| read writ| recv send| in out | int csw 1 1 87 11 0| 0 89M| 924B 350B| 0 0 | 931 2914 1 2 96 2 0| 0 128M| 128B 0 | 0 0 |1079 3329 1 1 94 4 0| 0 130M|3132B 974B| 0 0 |1128 3537 2 1 92 5 0| 0 123M| 128B 0 | 0 0 |1132 3749 1 2 91 6 0| 0 128M| 0 0 | 0 0 |1102 3645 2 1 88 9 0| 0 108M|3958B 1330B| 0 0 |1306 4058 2 1 93 4 0| 0 123M| 0 0 | 0 0 |1017 3169 1 2 94 4 0| 0 127M| 128B 0 | 0 0 | 998 3871 2 2 91 5 0| 0 128M|3344B 1120B| 0 0 |1219 4850 1 1 91 6 0| 0 124M| 222B 94B| 0 0 |1147 3869 2 1 92 5 0| 0 113M|3620B 1260B| 0 0 | 960 3302 1 1 94 4 0| 0 131M| 128B 0 | 0 0 |1000 3368 2 2 93 4 0| 0 126M|3274B 1050B| 0 0 | 972 2947 1 1 95 3 0| 0 131M| 222B 94B| 0 0 | 851 2733 1 2 94 4 0| 0 129M| 480B 204B| 0 0 | 904 2816 1 1 91 7 0| 0 107M| 128B 0 | 0 0 | 772 2521 1 1 94 4 0| 0 129M| 0 0 | 0 0 | 821 2638 1 2 92 5 0| 0 129M|2356B 630B| 0 0 |1165 4029 2 2 91 6 0| 0 121M| 832B 280B| 0 0 |7234 3782 2 2 86 10 0| 0 132M|2330B 700B| 0 0 |1073 2979 2 2 89 7 0| 0 121M|2084B 700B| 0 0 |1032 3251 2 1 92 5 0| 0 113M| 660B 140B| 0 0 | 992 3082 2 1 94 4 0| 0 129M|1739B 729B| 0 0 | 909 2805 2 1 94 4 0| 0 128M|1560B 560B| 0 0 | 899 2809 1 1 93 5 0| 0 126M| 0 0 | 0 0 | 886 2861 1 1 93 4 0| 0 125M| 728B 280B| 0 0 | 819 2611 1 1 92 7 0| 0 114M| 0 0 | 0 0 | 801 2735 2 2 88 9 0| 0 125M|2382B 560B| 0 0 | 864 2684 1 1 96 2 0| 0 127M| 508B 210B| 0 0 | 785 2567 1 2 94 2 0| 0 128M|5570B 1115B| 0 0 | 912 2792 1 1 92 5 0| 0 112M| 695k 6592B| 0 0 |1018 2792 2 1 91 6 0| 0 106M|3590B 1120B| 0 0 | 905 2741 2 2 93 4 0| 0 127M|2294B 770B| 0 0 | 925 2890 1 1 95 4 0| 0 119M| 128B 0 | 0 0 | 883 2508 2 2 94 3 0| 0 128M|2360B 910B| 0 0 | 955 2812 1 2 94 4 0| 0 126M| 128B 0 | 0 0 | 855 2561 --total-cpu-usage-- -dsk/total- -net/total- ---paging-- ---system-- usr sys idl wai stl| read writ| recv send| in out | int csw 1 1 90 8 0| 0 99M| 0 0 | 0 0 | 738 2407 2 1 93 4 0| 0 122M|2724B 910B| 0 0 | 890 2783 1 1 95 3 0| 0 129M| 416B 140B| 0 0 | 813 2743 1 2 95 3 0| 0 130M| 638B 210B| 0 0 | 821 2612 2 1 87 10 0| 0 120M|1666B 560B| 0 0 | 854 2650 1 1 86 12 0| 0 85M|2028B 560B| 0 0 | 832 2359 2 1 92 5 0| 0 129M|2688B 980B| 0 0 | 995 2839 1 1 93 5 0| 0 122M| 128B 0 | 0 0 | 790 2527 1 1 96 2 0| 0 127M|2316B 770B| 0 0 | 810 2769 1 1 94 3 0| 0 128M| 960B 280B| 0 0 | 821 2589 1 1 87 12 0| 0 86M| 0 0 | 0 0 | 713 2253 1 1 91 6 0| 0 131M|2724B 910B| 0 0 | 877 2784 2 1 93 4 0| 0 127M| 832B 280B| 0 0 | 971 2761 1 1 90 7 0| 0 123M| 728B 280B| 0 0 | 962 2703 2 2 90 6 0| 0 128M| 0 0 | 0 0 |1189 3105 1 1 86 11 0| 0 96M|2444B 770B| 0 0 | 819 2587 2 2 93 4 0| 0 128M|3436B 1190B| 0 0 | 995 2961 1 1 91 7 0| 0 123M| 128B 0 | 0 0 | 836 2525 1 2 87 10 0| 0 127M| 416B 140B| 0 0 | 962 2817 1 1 95 3 0| 0 127M| 544B 140B| 0 0 | 906 2724 1 1 85 13 0| 0 78M| 836B 280B| 0 0 | 736 2153 1 1 96 1 0| 0 128M|1380B 420B| 0 0 | 857 2719 1 1 93 5 0| 0 127M| 924B 350B| 0 0 | 911 2690 2 1 90 7 0| 0 87M|2396B 840B| 0 0 | 922 2848 1 0 98 1 0| 0 2084k| 0 0 | 0 0 | 430 1334 1 1 98 0 0| 0 2048k|2540B 770B| 0 0 | 535 1651 1 0 98 0 0| 0 4096k| 64B 64B| 0 0 | 474 1729 ^C Schreibgeschwindigkeit ca. 120MB/sec >> USB2.0 Speed. (umount /dev/sdc) Aug 19 07:32:05 linux-kwm1 kernel: usb 2-1: USB disconnect, device number 25 Aug 19 07:32:05 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Synchronizing SCSI cache Aug 19 07:32:05 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Synchronize Cache(10) failed: Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK (mount again /dev/sdc) Aug 19 07:32:26 linux-kwm1 kernel: usb 2-1: new SuperSpeed USB device number 26 using xhci_hcd Aug 19 07:32:26 linux-kwm1 kernel: usb 2-1: New USB device found, idVendor=2109, idProduct=0711, bcdDevice= 1.44 Aug 19 07:32:26 linux-kwm1 kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Aug 19 07:32:26 linux-kwm1 kernel: usb 2-1: Product: VLI Product String Aug 19 07:32:26 linux-kwm1 kernel: usb 2-1: Manufacturer: VLI manufacture String Aug 19 07:32:26 linux-kwm1 kernel: usb 2-1: SerialNumber: 000000123AFF Aug 19 07:32:26 linux-kwm1 kernel: usb-storage 2-1:1.0: USB Mass Storage device detected Aug 19 07:32:26 linux-kwm1 kernel: usb-storage 2-1:1.0: Quirks match for vid 2109 pid 0711: 2000000 Aug 19 07:32:26 linux-kwm1 kernel: scsi host4: usb-storage 2-1:1.0 Aug 19 07:32:26 linux-kwm1 mtp-probe[20949]: checking bus 2, device 26: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1" Aug 19 07:32:26 linux-kwm1 mtp-probe[20949]: bus: 2, device: 26 was not an MTP device Aug 19 07:32:27 linux-kwm1 mtp-probe[20974]: checking bus 2, device 26: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1" Aug 19 07:32:27 linux-kwm1 mtp-probe[20974]: bus: 2, device: 26 was not an MTP device Aug 19 07:32:30 linux-kwm1 kernel: scsi 4:0:0:0: Direct-Access USB3.0 high speed 2210 PQ: 0 ANSI: 6 Aug 19 07:32:30 linux-kwm1 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0 Aug 19 07:32:30 linux-kwm1 kernel: sd 4:0:0:0: [sdc] 3907029164 512-byte logical blocks: (2.00 TB/1.82 TiB) Aug 19 07:32:30 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write Protect is off Aug 19 07:32:30 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Mode Sense: 2f 00 00 00 Aug 19 07:32:30 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Aug 19 07:32:31 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Attached SCSI disk Aug 19 07:32:32 linux-kwm1 kernel: EXT4-fs (sdc): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none. Aug 19 07:32:32 linux-kwm1 udisksd[2266]: Mounted /dev/sdc at /run/media/mw/USB3ADHD on behalf of uid 1000 Aug 19 07:32:33 linux-kwm1 pcmanfm-qt[2113]: operation finished: 0x0 Aug 19 07:32:33 linux-kwm1 pcmanfm-qt[2113]: delete MountOperation (attached SeaGate 1TB FireCuda 120 SSD) Aug 19 07:35:46 linux-kwm1 kernel: usb 2-1: new SuperSpeed USB device number 27 using xhci_hcd Aug 19 07:35:46 linux-kwm1 kernel: usb 2-1: New USB device found, idVendor=2109, idProduct=0711, bcdDevice= 1.44 Aug 19 07:35:46 linux-kwm1 kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Aug 19 07:35:46 linux-kwm1 kernel: usb 2-1: Product: VLI Product String Aug 19 07:35:46 linux-kwm1 kernel: usb 2-1: Manufacturer: VLI manufacture String Aug 19 07:35:46 linux-kwm1 kernel: usb 2-1: SerialNumber: 000000123AFF Aug 19 07:35:46 linux-kwm1 kernel: usb-storage 2-1:1.0: USB Mass Storage device detected Aug 19 07:35:46 linux-kwm1 kernel: usb-storage 2-1:1.0: Quirks match for vid 2109 pid 0711: 2000000 Aug 19 07:35:46 linux-kwm1 kernel: scsi host4: usb-storage 2-1:1.0 Aug 19 07:35:46 linux-kwm1 mtp-probe[21130]: checking bus 2, device 27: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1" Aug 19 07:35:46 linux-kwm1 mtp-probe[21130]: bus: 2, device: 27 was not an MTP device Aug 19 07:35:47 linux-kwm1 mtp-probe[21156]: checking bus 2, device 27: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-1" Aug 19 07:35:47 linux-kwm1 mtp-probe[21156]: bus: 2, device: 27 was not an MTP device Aug 19 07:35:48 linux-kwm1 kernel: scsi 4:0:0:0: Direct-Access USB3.0 high speed 2210 PQ: 0 ANSI: 6 Aug 19 07:35:48 linux-kwm1 kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0 Aug 19 07:35:48 linux-kwm1 kernel: sd 4:0:0:0: [sdc] 1953525164 512-byte logical blocks: (1.00 TB/932 GiB) Aug 19 07:35:48 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write Protect is off Aug 19 07:35:48 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Mode Sense: 2f 00 00 00 Aug 19 07:35:48 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Aug 19 07:35:48 linux-kwm1 kernel: sdc: sdc1 sdc2 sdc3 sdc4 < sdc5 sdc6 > Aug 19 07:35:48 linux-kwm1 kernel: sdc: p6 size 1667241392 extends beyond EOD, enabling native capacity Aug 19 07:35:48 linux-kwm1 kernel: sdc: sdc1 sdc2 sdc3 sdc4 < sdc5 sdc6 > Aug 19 07:35:48 linux-kwm1 kernel: sdc: p6 size 1667241392 extends beyond EOD, truncated Aug 19 07:35:48 linux-kwm1 kernel: sd 4:0:0:0: [sdc] Attached SCSI disk >fdisk -l /dev/sdc Disk /dev/sdc: 931.51 GiB, 1000204883968 bytes, 1953525164 sectors Disk model: high speed Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xc1bd9c1e Device Boot Start End Sectors Size Id Type /dev/sdc1 2048 18431 16384 8M ef EFI (FAT-12/16/32) /dev/sdc2 18432 1067007 1048576 512M 83 Linux /dev/sdc3 1067008 17844223 16777216 8G 82 Linux swap / Solaris /dev/sdc4 17844224 1953525167 1935680944 923G 5 Extended /dev/sdc5 17846272 286281727 268435456 128G 83 Linux /dev/sdc6 286283776 1953525167 1667241392 795G 83 Linux mount /dev/sdc5 /mnt/sdc5 /dev/sdc5 on /mnt/sdc5 type ext4 (rw,relatime) (Kein ERR!) >mount /dev/sdc6 /mnt/sdc6 mount: /mnt/sdc6: wrong fs type, bad option, bad superblock on /dev/sdc6, missing codepage or helper program, or other error. (ERR tritt wieder auf!) root@linux-kwm1:~ >time $(dd if=/dev/shm/BIG_FILE_10GB.bin of=/mnt/sdc5/IG_FILE_10GB.bin bs=1M status=progress ; sync) 10450108416 bytes (10 GB, 9.7 GiB) copied, 11 s, 950 MB/s 10240+0 records in 10240+0 records out 10737418240 bytes (11 GB, 10 GiB) copied, 11.9037 s, 902 MB/s real 0m45.936s user 0m0.010s sys 0m7.990s >dstat You did not select any stats, using -cdngy by default. --total-cpu-usage-- -dsk/total- -net/total- ---paging-- ---system-- usr sys idl wai stl| read writ| recv send| in out | int csw 30 8 62 0 0| 369k 47k| 0 0 | 0 0 | 696 1994 1 0 99 0 0| 0 4096B| 128B 0 | 0 0 | 445 1389 3 1 96 0 0| 0 0 |3322B 1190B| 0 0 | 832 3341 1 1 98 0 0| 0 0 |2514B 840B| 0 0 | 605 2254 1 2 97 0 0|4096B 0 | 0 0 | 0 0 | 481 1302 1 12 87 0 0| 0 0 | 544B 140B| 0 0 | 842 1253 1 13 87 0 0| 0 0 |2176B 770B| 0 0 | 863 1365 0 13 86 0 0| 0 45M| 541B 471B| 0 0 |1074 1974 0 14 83 3 0| 0 248M|1340B 490B| 0 0 |1879 4660 1 9 82 8 0| 0 248M| 128B 0 | 0 0 |1800 4633 1 6 80 13 0| 0 246M| 0 0 | 0 0 |1598 4530 2 7 81 9 0| 0 244M|3656B 1260B| 0 0 |1859 4511 1 5 84 9 0| 0 248M| 0 0 | 0 0 |1443 4425 1 8 77 14 0| 0 237M| 636B 210B| 0 0 |1627 4198 1 6 84 10 0| 0 246M| 0 0 | 0 0 |1520 4332 1 5 84 10 0| 0 248M| 128B 0 | 0 0 |1420 4587 1 5 86 8 0| 0 232M|1528B 630B| 0 0 |1480 4185 1 2 94 2 0| 0 237M| 544B 140B| 0 0 |1240 3961 1 2 94 3 0| 0 240M| 0 0 | 0 0 |1312 4152 1 2 94 3 0| 0 241M|2606B 910B| 0 0 |1336 4080 1 2 96 1 0| 0 236M| 0 0 | 0 0 |1264 4085 2 3 93 2 0| 0 239M|3472B 1120B| 0 0 |1374 4240 2 3 93 2 0| 0 236M|6458B 1535B| 0 0 |1481 4184 2 2 93 3 0| 0 241M| 694k 7374B| 0 0 |1579 4351 1 2 95 2 0| 0 235M| 896B 628B| 0 0 |1350 4111 1 2 90 6 0| 0 233M|1144B 420B| 0 0 |1315 3852 1 3 90 7 0| 0 235M| 0 0 | 0 0 |1295 4022 2 2 95 2 0| 0 232M|2356B 630B| 0 0 |1391 4065 1 2 96 1 0| 0 231M| 0 0 | 0 0 |1268 3868 2 2 93 4 0| 0 236M| 636B 210B| 0 0 |1361 4146 1 2 93 4 0| 0 243M| 679B 315B| 0 0 |1347 4131 1 2 95 2 0| 0 241M| 128B 0 | 0 0 |1277 3951 2 2 91 4 0| 0 234M|3042B 980B| 0 0 |1389 4271 1 3 94 2 0| 0 232M| 128B 0 | 0 0 |1265 3825 1 2 95 1 0| 0 234M| 0 0 | 0 0 |1282 4010 2 3 91 4 0| 0 241M|3314B 910B| 0 0 |1433 4211 --total-cpu-usage-- -dsk/total- -net/total- ---paging-- ---system-- usr sys idl wai stl| read writ| recv send| in out | int csw 1 2 96 1 0| 0 242M| 179B 109B| 0 0 |1323 4053 1 2 95 2 0| 0 237M| 237B 152B| 0 0 |1240 3924 2 2 95 2 0| 0 243M|3528B 1260B| 0 0 |1299 4243 1 2 95 2 0| 0 241M| 128B 0 | 0 0 |1199 4016 2 2 94 3 0| 0 240M|2950B 910B| 0 0 |1304 4185 2 2 94 2 0| 0 244M|3380B 1050B| 0 0 |1334 4275 1 2 96 1 0| 0 240M| 64B 64B| 0 0 |1296 4058 2 3 91 4 0| 0 239M|2304B 770B| 0 0 |1399 4396 3 4 90 3 0| 0 240M| 416B 140B| 0 0 |1534 4768 2 3 94 2 0| 0 231M| 128B 0 | 0 0 |1559 4482 2 3 94 2 0| 0 232M|2320B 700B| 0 0 |1317 4016 2 2 94 3 0| 0 239M| 336B 70B| 0 0 |1293 4195 1 2 95 2 0| 0 239M| 716B 280B| 0 0 |1201 3956 1 2 95 2 0| 0 239M| 636B 210B| 0 0 |1234 4047 1 2 93 4 0| 0 162M| 0 0 | 0 0 |1422 4070 2 0 98 0 0| 0 0 |3012B 770B| 0 0 | 359 1223 1 0 99 0 0| 0 0 | 0 0 | 0 0 | 291 1078 1 0 99 0 0| 0 0 | 128B 0 | 0 0 | 342 1196 1 0 99 0 0| 0 0 | 924B 350B| 0 0 | 310 1088 1 0 99 0 0| 0 0 | 128B 0 | 0 0 | 289 1024 ^C
