/** @file sys_main.c * @brief Application main file * @date 11-Dec-2018 * @version 04.07.01 * * This file contains an empty main function, * which can be used for the application. */ /* * Copyright (C) 2009-2018 Texas Instruments Incorporated - www.ti.com * * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the * distribution. * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR * A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT * OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * */ /* USER CODE BEGIN (0) */ /* USER CODE END */ /* Include Files */ #include "sys_common.h" /* USER CODE BEGIN (1) */ /* Include FreeRTOS scheduler files */ #include "FreeRTOS.h" #include "os_task.h" #include "os_queue.h" /* Include HET header file - types, definitions and function declarations for system driver */ #include "het.h" #include "esm.h" #include "tcp_client.h" #include "ping.h" #include "sci.h" #include "lwftp.h" #include "includes.h" extern void EMAC_LwIP_Main (uint8 * emacAddress); uint8 emacAddress[6U] = {0xFFU, 0xFFU, 0xFFU, 0xFFU, 0xFFU, 0xFFU}; uint32 emacPhyAddress = 0U; /********************************************************************************/ int min(int num1, int num2); int min(int num1, int num2) { return (num1 > num2 ) ? num2 : num1; } static void ftp_retr_callback(void *arg, int result) { lwftp_session_t *s = (lwftp_session_t*)arg; sciSend(scilinREG, 3, " 8 "); if ( result != LWFTP_RESULT_OK ) { // ////LOG_ERROR("retr failed (%d)", result); sciSend(scilinREG, 5, " 8.1 "); // return lwftp_close(s); } sciSend(scilinREG, 5, " 8.2 "); // Test is done //lwftp_close(s); } static unsigned int data_sink(void *arg, const char* ptr, unsigned int len) { sciSend(scilinREG, 3, " 7 "); // static const unsigned int mylen = 12345; // static char * const myconfig = (char*)0x20000000; static const unsigned int mylen = 10; static char * const myconfig = (char*)0x20000000; static unsigned int offset = 0; if (ptr) { len = min( len, mylen-offset ); memcpy( myconfig+offset, ptr, len ); offset += len; } return len; } static void ftp_stor_callback(void *arg, int result) { lwftp_session_t *s = (lwftp_session_t*)arg; err_t error; sciSend(scilinREG, 3, " 6 "); // if ( result != LWFTP_RESULT_OK ) { // ////LOG_ERROR("stor failed (%d)", result); // sciSend(scilinREG, 4, " E6 "); // return lwftp_close(s); // } // Continue with RETR request s->data_sink = data_sink; s->done_fn = ftp_retr_callback; // La llama para cerrar la conexión s->remote_path = "configfile"; error = lwftp_retrieve(s); if ( error != LWFTP_RESULT_INPROGRESS ) { sciSend(scilinREG, 4, " E7"); // ////LOG_ERROR("lwftp_retrieve failed (%d)", error); } // FTP session will continue with RETR and sink callbacks } static unsigned int data_source(void *arg, const char** pptr, unsigned int maxlen) { sciSend(scilinREG, 3, " 5 "); static const unsigned int mylen = 150000; // static const char * const mydata = (char*)0x20000000; static const char * const mydata = " HOLA "; static unsigned int offset = 0; unsigned int len = 0; // Check for data request or data sent notice if (pptr) { len = mylen - offset; if ( len > maxlen ) len = maxlen; *pptr = mydata + offset; } else { offset += maxlen; if ( offset > mylen ) offset = mylen; } return len; } static void ftp_connect_callback(void *arg, int result) { lwftp_session_t *s = (lwftp_session_t*)arg; err_t error; sciSend(scilinREG, 3, " 1 "); if( result == LWFTP_RESULT_INPROGRESS ){ sciSend(scilinREG, 3, " 2 "); return; } if ( result != LWFTP_RESULT_LOGGED ) { sciSend(scilinREG, 3, " E1 "); ////LOG_ERROR("login failed (%d)", result); return lwftp_close(s); } // Continue with STOR request s->data_source = data_source; s->done_fn = ftp_stor_callback; s->remote_path = "logfile"; error = lwftp_store(s); if ( error != LWFTP_RESULT_INPROGRESS ) { sciSend(scilinREG, 4, " E2 "); ////LOG_ERROR("lwftp_store failed (%d)", error); } // FTP session will continue with STOR and source callbacks } /* Fuction to wait a time*/ void delay2 (float time){ int long c, x_time = (int long) (1.36e7 * time); for (c=0; c <= 2 * x_time; c++){ } } static void ftp_test(void) { static lwftp_session_t s; // static content for the whole FTP session err_t error; // Initialize session data memset(&s, 0, sizeof(s)); IP4_ADDR(&s.server_ip, 192,168,0,20); s.server_port = 21; s.done_fn = ftp_connect_callback; s.user = "username"; // s.pass = "UrL!V8IZs6"; // s.user = ""; s.pass = "password"; // We have no extra user data, simply use the session structure s.handle = &s; // Start the connection state machine error = lwftp_connect(&s); if ( error != LWFTP_RESULT_INPROGRESS ) { sciSend(scilinREG, 14, " error conec "); ////LOG_ERROR("lwftp_connect failed (%d)", error); } while(1) { delay2(2000); // lwftp_send_next_data(&s); // SEND(&s); } // s.done_fn = ftp_connect_callback; // FTP session will continue with the connection callback } /********************************************************************************/ int main(void) { /* USER CODE BEGIN (3) */ /* Set high end timer GIO port hetPort pin direction to all output */ gioSetDirection(hetPORT1, 0xFFFFFFFF); sciInit(); static lwftp_session_t s; EMAC_LwIP_Main (emacAddress); ftp_test(); /* Run forever */ while(1) { } /* USER CODE END */ return 0; } /* USER CODE END */
