/* USER CODE BEGIN Header */
* @file : usbd_storage_if.c
* @version : v1.0_Cube
* @brief : Memory management layer.
* @attention
© Copyright (c) 2021 STMicroelectronics.
* All rights reserved.
* This software component is licensed by ST under Ultimate Liberty license
* SLA0044, the "License"; You may not use this file except in compliance with
* the License. You may obtain a copy of the License at:
* www.st.com/SLA0044
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "usbd_storage_if.h"
/* USER CODE BEGIN INCLUDE */
#include "ff.h"
#include "diskio.h"
#include "fatfs_sd.h"
/* USER CODE END INCLUDE */
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* Private variables ---------------------------------------------------------*/
/**** capacity related *****/
extern FATFS *pfs;
extern DWORD fre_clust;
/* USER CODE END PV */
/** @addtogroup STM32_USB_OTG_DEVICE_LIBRARY
* @brief Usb device.
/** @defgroup USBD_STORAGE
* @brief Usb mass storage device module
/** @defgroup USBD_STORAGE_Private_TypesDefinitions
* @brief Private types.
/* USER CODE BEGIN PRIVATE_TYPES */
/* USER CODE END PRIVATE_TYPES */
/** @defgroup USBD_STORAGE_Private_Defines
* @brief Private defines.
#define STORAGE_LUN_NBR 1
#define STORAGE_BLK_NBR 0x10000
#define STORAGE_BLK_SIZ 0x200
/* USER CODE BEGIN PRIVATE_DEFINES */
#define BLOCK_SIZE 512
/* USER CODE END PRIVATE_DEFINES */
/** @defgroup USBD_STORAGE_Private_Macros
* @brief Private macros.
/* USER CODE BEGIN PRIVATE_MACRO */
/* USER CODE END PRIVATE_MACRO */
/** @defgroup USBD_STORAGE_Private_Variables
* @brief Private variables.
/* USER CODE BEGIN INQUIRY_DATA_FS */
/** USB Mass storage Standard Inquiry Data. */
const int8_t STORAGE_Inquirydata_FS[] = {/* 36 */
/* LUN 0 */
0x00,
0x80,
0x02,
0x02,
(STANDARD_INQUIRY_DATA_LEN - 5),
0x00,
0x00,
0x00,
'S', 'T', 'M', ' ', ' ', ' ', ' ', ' ', /* Manufacturer : 8 bytes */
'P', 'r', 'o', 'd', 'u', 'c', 't', ' ', /* Product : 16 Bytes */
'0', '.', '0' ,'1' /* Version : 4 Bytes */
/* USER CODE END INQUIRY_DATA_FS */
/* USER CODE BEGIN PRIVATE_VARIABLES */
/* USER CODE END PRIVATE_VARIABLES */
/** @defgroup USBD_STORAGE_Exported_Variables
* @brief Public variables.
extern USBD_HandleTypeDef hUsbDeviceFS;
extern SPI_HandleTypeDef hspi3;
/* USER CODE BEGIN EXPORTED_VARIABLES */
/* USER CODE END EXPORTED_VARIABLES */
/** @defgroup USBD_STORAGE_Private_FunctionPrototypes
* @brief Private functions declaration.
static int8_t STORAGE_Init_FS(uint8_t lun);
static int8_t STORAGE_GetCapacity_FS(uint8_t lun, uint32_t *block_num, uint16_t *block_size);
static int8_t STORAGE_IsReady_FS(uint8_t lun);
static int8_t STORAGE_IsWriteProtected_FS(uint8_t lun);
static int8_t STORAGE_Read_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len);
static int8_t STORAGE_Write_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len);
static int8_t STORAGE_GetMaxLun_FS(void);
/* USER CODE BEGIN PRIVATE_FUNCTIONS_DECLARATION */
/* USER CODE END PRIVATE_FUNCTIONS_DECLARATION */
USBD_StorageTypeDef USBD_Storage_Interface_fops_FS =
STORAGE_Init_FS,
STORAGE_GetCapacity_FS,
STORAGE_IsReady_FS,
STORAGE_IsWriteProtected_FS,
STORAGE_Read_FS,
STORAGE_Write_FS,
STORAGE_GetMaxLun_FS,
(int8_t *)STORAGE_Inquirydata_FS
/* Private functions ---------------------------------------------------------*/
* @brief Initializes over USB FS IP
* @param lun:
* @retval USBD_OK if all operations are OK else USBD_FAIL
/* USER CODE BEGIN 2 */
return (USBD_OK);
/* USER CODE END 2 */
* @brief .
* @param lun: .
* @param block_num: .
* @param block_size: .
/* USER CODE BEGIN 3 */
f_getfree("", &fre_clust, &pfs); // FUNKTIONIERT !!
*block_num = (pfs->n_fatent - 2); // FUNKTIONIERT !!
*block_size = BLOCK_SIZE; // FUNKTIONIERT !!
return (USBD_OK);
/* USER CODE END 3 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 4 */
return (USBD_OK);
/* USER CODE END 4 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 5 */
return (USBD_OK);
/* USER CODE END 5 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 6 */
SD_disk_read(1,buf,blk_addr,blk_len);
//HAL_SPI_Receive_IT(&hspi3, *buf, 512);
return (USBD_OK);
/* USER CODE END 6 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 7 */
//SD_disk_initialize (pdrv);
SD_disk_write(1,buf,blk_addr,blk_len);
//HAL_SPI_Transmit_IT(&hspi3, *buf, 512);
return (USBD_OK);
/* USER CODE END 7 */
* @brief .
* @param None
* @retval .
/* USER CODE BEGIN 8 */
return (STORAGE_LUN_NBR - 1);
/* USER CODE END 8 */
/* USER CODE BEGIN PRIVATE_FUNCTIONS_IMPLEMENTATION */
/* USER CODE END PRIVATE_FUNCTIONS_IMPLEMENTATION */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
