>smartctl -a /dev/sda smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.12.4-2-default] (SUSE RPM) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate BarraCuda 3.5 Device Model: ST2000DM008-2FR102 Serial Number: ZFL0YWR3 LU WWN Device Id: 5 000c50 0c2c65c10 Firmware Version: 0001 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches TRIM Command: Available Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 5 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Sep 10 10:47:34 2021 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 0) seconds. Offline data collection capabilities: (0x73) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 195) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x30a5) SCT Status supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 076 064 006 Pre-fail Always - 44619320 3 Spin_Up_Time 0x0003 098 098 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 296 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 079 060 045 Pre-fail Always - 84113146 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 1207 (105 105 0) 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 295 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 059 057 040 Old_age Always - 41 (Min/Max 31/41) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 62 193 Load_Cycle_Count 0x0032 091 091 000 Old_age Always - 18684 194 Temperature_Celsius 0x0022 041 043 000 Old_age Always - 41 (0 17 0 0 0) 195 Hardware_ECC_Recovered 0x001a 076 064 000 Old_age Always - 44619320 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 998h+24m+32.308s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 4521920811 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 3398764078 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 1207 - # 2 Extended offline Completed without error 00% 1204 - # 3 Short offline Completed without error 00% 1199 - # 4 Extended offline Interrupted (host reset) 00% 1198 - # 5 Short offline Completed without error 00% 1195 - # 6 Short offline Completed without error 00% 1193 - # 7 Short offline Completed without error 00% 1189 - # 8 Short offline Completed without error 00% 1188 - # 9 Extended offline Interrupted (host reset) 00% 1183 - #10 Short offline Completed without error 00% 1176 - #11 Short offline Completed without error 00% 1171 - #12 Short offline Completed without error 00% 1163 - #13 Short offline Completed without error 00% 1158 - #14 Short offline Completed without error 00% 1156 - #15 Short offline Completed without error 00% 1151 - #16 Short offline Completed without error 00% 1142 - #17 Short offline Completed without error 00% 1139 - #18 Short offline Completed without error 00% 1129 - #19 Short offline Completed without error 00% 1119 - #20 Short offline Completed without error 00% 1114 - #21 Short offline Completed without error 00% 1110 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
