>smartctl -a /dev/sdc smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.12.4-2-default] (SUSE RPM) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Desktop HDD.15 Device Model: ST4000DM000-1F2168 Serial Number: S30044YE LU WWN Device Id: 5 000c50 06cdf296d Firmware Version: CC52 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5900 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Sep 10 10:49:10 2021 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x00) Offline data collection activity was never started. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 602) seconds. Offline data collection capabilities: (0x73) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 513) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x1085) SCT Status supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 115 099 006 Pre-fail Always - 84607000 3 Spin_Up_Time 0x0003 093 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 853 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 080 060 030 Pre-fail Always - 109214125 9 Power_On_Hours 0x0032 076 076 000 Old_age Always - 21579 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 853 183 Runtime_Bad_Block 0x0032 099 099 000 Old_age Always - 1 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 096 096 000 Old_age Always - 4 190 Airflow_Temperature_Cel 0x0022 062 051 045 Old_age Always - 38 (Min/Max 26/38) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 611 193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 377251 194 Temperature_Celsius 0x0022 038 049 000 Old_age Always - 38 (0 14 0 0 0) 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 20384h+34m+46.567s 241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 22620230051 242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 37235101909 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 21579 - # 2 Extended offline Interrupted (host reset) 00% 21578 - # 3 Short offline Completed without error 00% 21571 - # 4 Extended offline Interrupted (host reset) 00% 21571 - # 5 Short offline Completed without error 00% 21567 - # 6 Short offline Completed without error 00% 21566 - # 7 Short offline Completed without error 00% 21562 - # 8 Short offline Completed without error 00% 21561 - # 9 Extended offline Interrupted (host reset) 00% 21556 - #10 Short offline Completed without error 00% 21549 - #11 Short offline Completed without error 00% 21545 - #12 Short offline Completed without error 00% 21536 - #13 Short offline Completed without error 00% 21532 - #14 Short offline Completed without error 00% 21529 - #15 Short offline Completed without error 00% 21524 - #16 Short offline Completed without error 00% 21515 - #17 Short offline Completed without error 00% 21512 - #18 Short offline Completed without error 00% 21503 - #19 Short offline Completed without error 00% 21493 - #20 Short offline Completed without error 00% 21488 - #21 Short offline Completed without error 00% 21484 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
