>smartctl -a /dev/sdd smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.12.4-2-default] (SUSE RPM) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Gold Device Model: WDC WD4002FYYZ-01B7CB1 Serial Number: K3H7MMTL LU WWN Device Id: 5 000cca 25cd18fd2 Firmware Version: 01.01M03 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Fri Sep 10 10:49:46 2021 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 113) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 603) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0 2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 108 3 Spin_Up_Time 0x0007 100 100 024 Pre-fail Always - 0 4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 385 5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0 7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 140 140 020 Pre-fail Offline - 15 9 Power_On_Hours 0x0012 100 100 000 Old_age Always - 2155 10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 385 192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 2363 193 Load_Cycle_Count 0x0012 099 099 000 Old_age Always - 2363 194 Temperature_Celsius 0x0002 130 130 000 Old_age Always - 46 (Min/Max 16/56) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 2154 - # 2 Extended offline Aborted by host 30% 2153 - # 3 Short offline Completed without error 00% 2147 - # 4 Extended offline Aborted by host 70% 2147 - # 5 Short offline Completed without error 00% 2143 - # 6 Short offline Completed without error 00% 2142 - # 7 Short offline Completed without error 00% 2138 - # 8 Short offline Completed without error 00% 2137 - # 9 Extended offline Aborted by host 80% 2133 - #10 Short offline Completed without error 00% 2126 - #11 Short offline Completed without error 00% 2121 - #12 Short offline Completed without error 00% 2114 - #13 Short offline Completed without error 00% 2109 - #14 Short offline Completed without error 00% 2107 - #15 Short offline Completed without error 00% 2102 - #16 Short offline Completed without error 00% 2093 - #17 Short offline Completed without error 00% 2090 - #18 Short offline Completed without error 00% 2081 - #19 Short offline Completed without error 00% 2071 - #20 Short offline Completed without error 00% 2065 - #21 Short offline Completed without error 00% 2062 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
