UNIT LOAD ACTIVE SUB DESCRIPTION proc-sys-fs-binfmt_misc.automount loaded active waiting Arbitrary Executable File Formats File System Automount Point sys-devices-pci0000:00-0000:00:14.0-usb2-2\x2d9-2\x2d9:1.0-host8-target8:0:0-8:0:0:0-block-sde.device loaded active plugged SD_MMC_CRW sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda1.device loaded active plugged ST2000DM008-2FR102 _BOOT_ sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda2.device loaded active plugged ST2000DM008-2FR102 _SWAP_ sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda3.device loaded active plugged ST2000DM008-2FR102 _TMP_ sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda4.device loaded active plugged ST2000DM008-2FR102 _VAR_ sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda5.device loaded active plugged ST2000DM008-2FR102 _ROOT_ sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda6.device loaded active plugged ST2000DM008-2FR102 _OPT_ sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda-sda7.device loaded active plugged ST2000DM008-2FR102 _BCKDAT_ sys-devices-pci0000:00-0000:00:17.0-ata1-host0-target0:0:0-0:0:0:0-block-sda.device loaded active plugged ST2000DM008-2FR102 sys-devices-pci0000:00-0000:00:17.0-ata2-host1-target1:0:0-1:0:0:0-block-sdb-sdb1.device loaded active plugged ST2000DM008-2FR102 _BOOT2_ sys-devices-pci0000:00-0000:00:17.0-ata2-host1-target1:0:0-1:0:0:0-block-sdb-sdb2.device loaded active plugged ST2000DM008-2FR102 _SWAP0_ sys-devices-pci0000:00-0000:00:17.0-ata2-host1-target1:0:0-1:0:0:0-block-sdb-sdb3.device loaded active plugged ST2000DM008-2FR102 3 sys-devices-pci0000:00-0000:00:17.0-ata2-host1-target1:0:0-1:0:0:0-block-sdb.device loaded active plugged ST2000DM008-2FR102 sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc1.device loaded active plugged ST4000DM000-1F2168 BOOT sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc10.device loaded active plugged ST4000DM000-1F2168 BCKDAT sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc2.device loaded active plugged ST4000DM000-1F2168 SWAP sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc3.device loaded active plugged ST4000DM000-1F2168 VAR sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc4.device loaded active plugged ST4000DM000-1F2168 TMP sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc5.device loaded active plugged ST4000DM000-1F2168 ROOT sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc6.device loaded active plugged ST4000DM000-1F2168 USR sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc7.device loaded active plugged ST4000DM000-1F2168 OPT sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc8.device loaded active plugged ST4000DM000-1F2168 USRLOC sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc-sdc9.device loaded active plugged ST4000DM000-1F2168 USRSRC sys-devices-pci0000:00-0000:00:17.0-ata3-host2-target2:0:0-2:0:0:0-block-sdc.device loaded active plugged ST4000DM000-1F2168 sys-devices-pci0000:00-0000:00:17.0-ata4-host3-target3:0:0-3:0:0:0-block-sdd-sdd1.device loaded active plugged WDC_WD4002FYYZ-01B7CB1 SWAP2 sys-devices-pci0000:00-0000:00:17.0-ata4-host3-target3:0:0-3:0:0:0-block-sdd-sdd2.device loaded active plugged WDC_WD4002FYYZ-01B7CB1 BCKBOOT sys-devices-pci0000:00-0000:00:17.0-ata4-host3-target3:0:0-3:0:0:0-block-sdd-sdd3.device loaded active plugged WDC_WD4002FYYZ-01B7CB1 3 sys-devices-pci0000:00-0000:00:17.0-ata4-host3-target3:0:0-3:0:0:0-block-sdd-sdd4.device loaded active plugged WDC_WD4002FYYZ-01B7CB1 BCKSYS sys-devices-pci0000:00-0000:00:17.0-ata4-host3-target3:0:0-3:0:0:0-block-sdd.device loaded active plugged WDC_WD4002FYYZ-01B7CB1 sys-devices-pci0000:00-0000:00:17.0-ata7-host6-target6:0:0-6:0:0:0-block-sr0.device loaded active plugged PLDS_DVD+_-RW_DU-8A5LH sys-devices-pci0000:00-0000:00:1f.3-sound-card0-controlC0.device loaded active plugged /sys/devices/pci0000:00/0000:00:1f.3/sound/card0/controlC0 sys-devices-pci0000:64-0000:64:00.0-0000:65:00.1-sound-card1-controlC1.device loaded active plugged /sys/devices/pci0000:64/0000:64:00.0/0000:65:00.1/sound/card1/controlC1 sys-devices-platform-serial8250-tty-ttyS1.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS1 sys-devices-platform-serial8250-tty-ttyS10.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS10 sys-devices-platform-serial8250-tty-ttyS11.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS11 sys-devices-platform-serial8250-tty-ttyS12.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS12 sys-devices-platform-serial8250-tty-ttyS13.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS13 sys-devices-platform-serial8250-tty-ttyS14.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS14 sys-devices-platform-serial8250-tty-ttyS15.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS15 sys-devices-platform-serial8250-tty-ttyS16.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS16 sys-devices-platform-serial8250-tty-ttyS17.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS17 sys-devices-platform-serial8250-tty-ttyS18.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS18 sys-devices-platform-serial8250-tty-ttyS19.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS19 sys-devices-platform-serial8250-tty-ttyS2.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS2 sys-devices-platform-serial8250-tty-ttyS20.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS20 sys-devices-platform-serial8250-tty-ttyS21.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS21 sys-devices-platform-serial8250-tty-ttyS22.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS22 sys-devices-platform-serial8250-tty-ttyS23.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS23 sys-devices-platform-serial8250-tty-ttyS24.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS24 sys-devices-platform-serial8250-tty-ttyS25.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS25 sys-devices-platform-serial8250-tty-ttyS26.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS26 sys-devices-platform-serial8250-tty-ttyS27.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS27 sys-devices-platform-serial8250-tty-ttyS28.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS28 sys-devices-platform-serial8250-tty-ttyS29.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS29 sys-devices-platform-serial8250-tty-ttyS3.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS3 sys-devices-platform-serial8250-tty-ttyS30.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS30 sys-devices-platform-serial8250-tty-ttyS31.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS31 sys-devices-platform-serial8250-tty-ttyS4.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS4 sys-devices-platform-serial8250-tty-ttyS5.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS5 sys-devices-platform-serial8250-tty-ttyS6.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS6 sys-devices-platform-serial8250-tty-ttyS7.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS7 sys-devices-platform-serial8250-tty-ttyS8.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS8 sys-devices-platform-serial8250-tty-ttyS9.device loaded active plugged /sys/devices/platform/serial8250/tty/ttyS9 sys-devices-pnp0-00:04-tty-ttyS0.device loaded active plugged /sys/devices/pnp0/00:04/tty/ttyS0 sys-devices-virtual-block-dm\x2d0.device loaded active plugged /sys/devices/virtual/block/dm-0 sys-devices-virtual-mem-random.device loaded active plugged /sys/devices/virtual/mem/random sys-devices-virtual-misc-rfkill.device loaded active plugged /sys/devices/virtual/misc/rfkill sys-module-configfs.device loaded active plugged /sys/module/configfs sys-module-fuse.device loaded active plugged /sys/module/fuse -.mount loaded active mounted Root Mount boot.mount loaded active mounted /boot dev-hugepages.mount loaded active mounted Huge Pages File System dev-mqueue.mount loaded active mounted POSIX Message Queue File System home.mount loaded active mounted /home opt.mount loaded active mounted /opt run-user-1000-gvfs.mount loaded active mounted /run/user/1000/gvfs run-user-1000.mount loaded active mounted /run/user/1000 sys-fs-fuse-connections.mount loaded active mounted FUSE Control File System sys-kernel-config.mount loaded active mounted Kernel Configuration File System sys-kernel-debug-tracing.mount loaded active mounted /sys/kernel/debug/tracing sys-kernel-debug.mount loaded active mounted Kernel Debug File System sys-kernel-tracing.mount loaded active mounted Kernel Trace File System tmp.mount loaded active mounted /tmp var.mount loaded active mounted /var btrfsmaintenance-refresh.path loaded active waiting Watch /etc/sysconfig/btrfsmaintenance ca-certificates.path loaded active waiting Watch for changes in CA certificates cups.path loaded active running CUPS Scheduler issue-generator.path loaded active waiting Watch for changes in issue snippets smartd_generate_opts.path loaded active waiting Watch for changes in smartmontools sysconfig file systemd-ask-password-console.path loaded active running Dispatch Password Requests to Console Directory Watch systemd-ask-password-plymouth.path loaded active running Forward Password Requests to Plymouth Directory Watch init.scope loaded active running System and Service Manager session-2.scope loaded active abandoned Session 2 of User markus session-4.scope loaded active running Session 4 of User markus accounts-daemon.service loaded active running Accounts Service alsa-restore.service loaded active exited Save/Restore Sound Card State auditd.service loaded active running Security Auditing Service avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack colord.service loaded active running Manage, Install and Generate Color Profiles cron.service loaded active running Command Scheduler cups.service loaded active running CUPS Scheduler dbus.service loaded active running D-Bus System Message Bus display-manager.service loaded active running X Display Manager dracut-shutdown.service loaded active exited Restore /run/initramfs on shutdown firewalld.service loaded active running firewalld - dynamic firewall daemon getty@tty1.service loaded active running Getty on tty1 haveged.service loaded active running Entropy Daemon based on the HAVEGE algorithm irqbalance.service loaded active running irqbalance daemon kbdsettings.service loaded active exited Apply settings from /etc/sysconfig/keyboard kernel-sysctl.service loaded active exited Apply Kernel Variables for 5.14.0-1-default klog.service loaded active exited Early Kernel Boot Messages kmod-static-nodes.service loaded active exited Create List of Static Device Nodes mcelog.service loaded active running Machine Check Exception Logging Daemon nscd.service loaded active running Name Service Cache Daemon plymouth-quit-wait.service loaded active exited Hold until boot process finishes up plymouth-read-write.service loaded active exited Tell Plymouth To Write Out Runtime Data plymouth-start.service loaded active exited Show Plymouth Boot Screen polkit.service loaded active running Authorization Manager ● postfix.service loaded failed failed Postfix Mail Transport Agent rsyslog.service loaded active running System Logging Service rtkit-daemon.service loaded active running RealtimeKit Scheduling Policy Service smartd.service loaded active running Self Monitoring and Reporting Technology (SMART) Daemon systemd-ask-password-console.service loaded active running Dispatch Password Requests to Console systemd-ask-password-plymouth.service loaded active running Forward Password Requests to Plymouth systemd-cryptsetup@cr_ata\x2dST2000DM008\x2d2FR102_ZFL0YHCY\x2dpart3.service loaded active exited Cryptography Setup for cr_ata-ST2000DM008-2FR102_ZFL0YHCY-part3 systemd-fsck-root.service loaded active exited File System Check on Root Device systemd-fsck@dev-disk-by\x2dlabel-_BOOT_.service loaded active exited File System Check on /dev/disk/by-label/_BOOT_ systemd-fsck@dev-disk-by\x2dlabel-_HOME_.service loaded active exited File System Check on /dev/disk/by-label/_HOME_ systemd-fsck@dev-disk-by\x2dlabel-_OPT_.service loaded active exited File System Check on /dev/disk/by-label/_OPT_ systemd-fsck@dev-disk-by\x2dlabel-_TMP_.service loaded active exited File System Check on /dev/disk/by-label/_TMP_ systemd-fsck@dev-disk-by\x2dlabel-_VAR_.service loaded active exited File System Check on /dev/disk/by-label/_VAR_ systemd-journal-flush.service loaded active exited Flush Journal to Persistent Storage systemd-journald.service loaded active running Journal Service systemd-logind.service loaded active running User Login Management systemd-modules-load.service loaded active exited Load Kernel Modules systemd-random-seed.service loaded active exited Load/Save Random Seed systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems systemd-sysctl.service loaded active exited Apply Kernel Variables systemd-tmpfiles-setup-dev.service loaded active exited Create Static Device Nodes in /dev systemd-tmpfiles-setup.service loaded active exited Create Volatile Files and Directories systemd-udev-settle.service loaded active exited Wait for udev To Complete Device Initialization systemd-udev-trigger.service loaded active exited Coldplug All udev Devices systemd-udevd.service loaded active running Rule-based Manager for Device Events and Files systemd-update-utmp.service loaded active exited Record System Boot/Shutdown in UTMP systemd-user-sessions.service loaded active exited Permit User Sessions systemd-vconsole-setup.service loaded active exited Setup Virtual Console udisks2.service loaded active running Disk Manager upower.service loaded active running Daemon for power management user-runtime-dir@1000.service loaded active exited User Runtime Directory /run/user/1000 user@1000.service loaded active running User Manager for UID 1000 wicked.service loaded active exited wicked managed network interfaces wickedd-auto4.service loaded active running wicked AutoIPv4 supplicant service wickedd-dhcp4.service loaded active running wicked DHCPv4 supplicant service wickedd-dhcp6.service loaded active running wicked DHCPv6 supplicant service wickedd-nanny.service loaded active running wicked network nanny service wickedd.service loaded active running wicked network management service daemon -.slice loaded active active Root Slice system-getty.slice loaded active active Slice /system/getty system-modprobe.slice loaded active active Slice /system/modprobe system-systemd\x2dcryptsetup.slice loaded active active Cryptsetup Units Slice system-systemd\x2dfsck.slice loaded active active Slice /system/systemd-fsck system-systemd\x2dhibernate\x2dresume.slice loaded active active Slice /system/systemd-hibernate-resume system.slice loaded active active System Slice user-1000.slice loaded active active User Slice of UID 1000 user.slice loaded active active User and Session Slice avahi-daemon.socket loaded active running Avahi mDNS/DNS-SD Stack Activation Socket cups.socket loaded active running CUPS Scheduler dbus.socket loaded active running D-Bus System Message Bus Socket dm-event.socket loaded active listening Device-mapper event daemon FIFOs pcscd.socket loaded active listening PC/SC Smart Card Daemon Activation Socket syslog.socket loaded active running Syslog Socket systemd-initctl.socket loaded active listening initctl Compatibility Named Pipe systemd-journald-dev-log.socket loaded active running Journal Socket (/dev/log) systemd-journald.socket loaded active running Journal Socket systemd-rfkill.socket loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch systemd-udevd-control.socket loaded active running udev Control Socket systemd-udevd-kernel.socket loaded active running udev Kernel Socket dev-disk-by\x2dlabel-_SWAP_.swap loaded active active /dev/disk/by-label/_SWAP_ basic.target loaded active active Basic System blockdev@dev-mapper-cr_ata\x2dST2000DM008\x2d2FR102_ZFL0YHCY\x2dpart3.target loaded active active Block Device Preparation for /dev/mapper/cr_ata-ST2000DM008-2FR102_ZFL0YHCY-part3 cryptsetup.target loaded active active Local Encrypted Volumes getty.target loaded active active Login Prompts graphical.target loaded active active Graphical Interface local-fs-pre.target loaded active active Preparation for Local File Systems local-fs.target loaded active active Local File Systems multi-user.target loaded active active Multi-User System network-pre.target loaded active active Preparation for Network network.target loaded active active Network nss-lookup.target loaded active active Host and Network Name Lookups nss-user-lookup.target loaded active active User and Group Name Lookups paths.target loaded active active Path Units remote-fs.target loaded active active Remote File Systems slices.target loaded active active Slice Units sockets.target loaded active active Socket Units sound.target loaded active active Sound Card swap.target loaded active active Swaps sysinit.target loaded active active System Initialization timers.target loaded active active Timer Units veritysetup.target loaded active active Local Verity Integrity Protected Volumes backup-rpmdb.timer loaded active waiting Backup of RPM database backup-sysconfig.timer loaded active waiting Backup of /etc/sysconfig btrfs-balance.timer loaded active waiting Balance block groups on a btrfs filesystem btrfs-scrub.timer loaded active waiting Scrub btrfs filesystem, verify block checksums check-battery.timer loaded active waiting Check if mainboard battery is Ok fstrim.timer loaded active waiting Discard unused blocks once a week logrotate.timer loaded active waiting Daily rotation of log files man-db.timer loaded active waiting Daily man-db regeneration mlocate.timer loaded active waiting Daily locate database update snapper-cleanup.timer loaded active waiting Daily Cleanup of Snapper Snapshots systemd-tmpfiles-clean.timer loaded active waiting Daily Cleanup of Temporary Directories yast-timesync.timer loaded active waiting yast-timesync.timer LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 212 loaded units listed. Pass --all to see loaded but inactive units, too. To show all installed unit files use 'systemctl list-unit-files'.
