library IEEE; use IEEE.STD_LOGIC_1164.all; entity top is port (clk_i : in std_logic; --VGA led_o : out std_logic_vector(47 downto 0); bcd_i : in std_logic_vector(23 downto 0); end top; architecture Behavioral of top is component seg_coder is port ( a, b, c, d, e, f, g : out std_logic; bcd_i : in std_logic ); end component seg_coder; signal s_led : std_logic_vector(47 downto 0); begin G_7seg : for idx in 0 to 5 Generate seg_coder_1 : entity work.seg_coder port map ( a => s_led(8*idx + 0), b => s_led(8*idx + 1), c => s_led(8*idx + 2), d => s_led(8*idx + 3), e => s_led(8*idx + 4), f => s_led(8*idx + 5), g => s_led(8*idx + 6), bcd_i => bcd_i(4*idx+3 downto 4*idx)); S_LED(8*IDX + 7) <= '0' -- DECIMAL POINT end generate; P_output_buffer : process(clk_i) begin if rising_edge(clk_i) then led_o <= s_led; end if; end process P_output_buffer; end Behavioral; --- library IEEE; use IEEE.STD_LOGIC_1164.all; entity seg_coder is port ( a, b, c, d, e, f, g : out std_logic; bcd_i : in std_logic); end entity seg_coder; architecture rtl of seg_coder is begin process (bcd_i) begin case bcd_i is when "0000" => a <= '1'; b <= '1'; c <= '1'; d <= '1'; e <= '1'; f <= '1'; g <= '0'; when "0001" => a <= '0'; b <= '1'; c <= '1'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; when "0010" => a <= '1'; b <= '1'; c <= '0'; d <= '1'; e <= '1'; f <= '0'; g <= '1'; when "0011" => a <= '1'; b <= '1'; c <= '1'; d <= '1'; e <= '0'; f <= '0'; g <= '1'; when "0100" => a <= '0'; b <= '1'; c <= '1'; d <= '0'; e <= '0'; f <= '1'; g <= '1'; when "0101" => a <= '1'; b <= '0'; c <= '1'; d <= '1'; e <= '0'; f <= '1'; g <= '1'; when "0110" => a <= '1'; b <= '0'; c <= '1'; d <= '1'; e <= '1'; f <= '1'; g <= '1'; when "0111" => a <= '1'; b <= '1'; c <= '1'; d <= '0'; e <= '0'; f <= '0'; g <= '0'; when "1000" => a <= '1'; b <= '1'; c <= '1'; d <= '1'; e <= '1'; f <= '1'; g <= '1'; when "1001" => a <= '1'; b <= '1'; c <= '1'; d <= '1'; e <= '0'; f <= '1'; g <= '1'; when others => a <= '0'; b <= '0'; c <= '0'; d <= '0'; e <= '0'; f <= '0'; g <= '1'; end case; end process; end architecture;
