smartctl 6.6 2016-05-31 r4324 [x86_64-linux-5.3.0-050300-generic] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: Intenso SSD SATAIII Serial Number: AA000000000000051472 Firmware Version: T1201A0 User Capacity: 128.035.676.160 bytes [128 GB] Sector Size: 512 bytes logical/physical Rotation Rate: Solid State Device Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ACS-3 T13/2161-D revision 4 SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Jul 28 02:27:58 2021 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is: Unavailable APM level is: 254 (maximum performance) Rd look-ahead is: Enabled Write cache is: Enabled ATA Security is: Disabled, NOT FROZEN [SEC1] === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: FAILED! Drive failure expected in less than 24 hours. SAVE ALL DATA. No failed Attributes found. General SMART Values: Offline data collection status: (0x02) Offline data collection activity was completed without error. Auto Offline Data Collection: Disabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x11) SMART execute Offline immediate. No Auto Offline data collection support. Suspend Offline collection upon new command. No Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. No Selective Self-test supported. SMART capabilities: (0x0002) Does not save SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 10) minutes. SMART Attributes Data Structure revision number: 1 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate -O--CK 100 100 050 - 0 5 Reallocated_Sector_Ct -O--CK 100 100 050 - 0 9 Power_On_Hours -O--CK 100 100 050 - 32 12 Power_Cycle_Count -O--CK 100 100 050 - 209 160 Unknown_Attribute -O--CK 100 100 050 - 0 161 Unknown_Attribute PO--CK 100 100 050 - 100 163 Unknown_Attribute -O--CK 100 100 050 - 38 164 Unknown_Attribute -O--CK 100 100 050 - 0 165 Unknown_Attribute -O--CK 100 100 050 - 0 166 Unknown_Attribute -O--CK 100 100 050 - 0 167 Unknown_Attribute -O--CK 100 100 050 - 0 168 Unknown_Attribute -O--CK 100 100 050 - 2000 169 Unknown_Attribute -O--CK 100 100 050 - 100 175 Program_Fail_Count_Chip -O--CK 100 100 050 - 0 176 Erase_Fail_Count_Chip -O--CK 100 100 050 - 0 177 Wear_Leveling_Count -O--CK 100 100 050 - 0 178 Used_Rsvd_Blk_Cnt_Chip -O--CK 100 100 050 - 0 181 Program_Fail_Cnt_Total -O--CK 100 100 050 - 0 182 Erase_Fail_Count_Total -O--CK 100 100 050 - 0 192 Power-Off_Retract_Count -O--CK 100 100 050 - 192 194 Temperature_Celsius -O---K 100 100 050 - 40 195 Hardware_ECC_Recovered -O--CK 100 100 050 - 0 196 Reallocated_Event_Count -O--CK 100 100 050 - 0 197 Current_Pending_Sector -O--CK 100 100 050 - 0 198 Offline_Uncorrectable -O--CK 100 100 050 - 0 199 UDMA_CRC_Error_Count -O--CK 100 100 050 - 193 232 Available_Reservd_Space -O--CK 100 100 050 - 100 241 Total_LBAs_Written ----CK 100 100 050 - 5133 242 Total_LBAs_Read ----CK 100 100 050 - 5485 245 Unknown_Attribute -O--CK 100 100 050 - 0 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 1 Comprehensive SMART error log 0x03 GPL R/O 1 Ext. Comprehensive SMART error log 0x04 GPL,SL R/O 8 Device Statistics log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x10 GPL R/O 1 SATA NCQ Queued Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x24 GPL R/O 88 Current Device Internal Status Data log 0x25 GPL R/O 32 Saved Device Internal Status Data log 0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log SMART Extended Comprehensive Error Log Version: 1 (1 sectors) Device Error Count: 193 (device log contains only the most recent 4 errors) CR = Command Register FEATR = Features Register COUNT = Count (was: Sector Count) Register LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8 LH = LBA High (was: Cylinder High) Register ] LBA LM = LBA Mid (was: Cylinder Low) Register ] Register LL = LBA Low (was: Sector Number) Register ] DV = Device (was: Device/Head) Register DC = Device Control Register ER = Error register ST = Status register Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 193 [0] log entry is empty Error 192 [3] log entry is empty Error 191 [2] log entry is empty Error 190 [1] occurred at disk power-on lifetime: 0 hours (0 days + 0 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 00 -- 00 00 00 00 00 00 00 00 00 00 00 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- b0 00 d1 01 01 00 00 4f 00 c2 01 00 08 00:00:00.000 SMART READ ATTRIBUTE THRESHOLDS [OBS-4] b0 00 d0 01 01 00 00 4f 00 c2 00 00 08 00:00:00.000 SMART READ DATA ec 00 00 01 01 00 00 00 00 00 00 00 08 00:00:00.000 IDENTIFY DEVICE ec 00 00 01 01 00 00 00 00 00 00 00 08 00:00:00.000 IDENTIFY DEVICE b0 00 da 00 00 00 00 4f 00 c2 00 00 08 00:00:00.000 SMART RETURN STATUS SMART Extended Self-test Log Version: 1 (1 sectors) No self-tests have been logged. [To run self-tests, use: smartctl -t] Selective Self-tests/Logging not supported SCT Commands not supported Device Statistics (GP Log 0x04) Page Offset Size Value Flags Description 0x01 ===== = = === == General Statistics (rev 1) == 0x01 0x008 4 209 --- Lifetime Power-On Resets 0x01 0x010 4 32 --- Power-on Hours 0x01 0x018 6 336405004 --- Logical Sectors Written 0x01 0x020 6 709495 --- Number of Write Commands 0x01 0x028 6 359504813 --- Logical Sectors Read 0x01 0x030 6 2926974 --- Number of Read Commands 0x07 ===== = = === == Solid State Device Statistics (rev 1) == 0x07 0x008 1 0 --- Percentage Used Endurance Indicator |||_ C monitored condition met ||__ D supports DSN |___ N normalized value SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 4 0 Command failed due to ICRC error 0x0002 4 0 R_ERR response for data FIS 0x0005 4 0 R_ERR response for non-data FIS 0x000a 4 3 Device-to-host register FISes sent due to a COMRESET
