#include #include #include "bits.h" #include #include #include #include #include "bits.h" // All of port B is address. // All of port D is data. #define PORTC_ICONT 2 #define PORTC_nDBE 4 #define PORTC_POLL 5 #define PORTC_nASR 6 #define PORTC_ADV 7 #define EP0_SIZE 64 void setup_delay() { for (volatile uint16_t i = 0; i < 9; ++i) { asm volatile("nop"); } } void write_reg(uint8_t addr, uint8_t data) { // Take control of instrument bus and enable data bus drivers. // This also drives ADV low at the same time. PORTC = 0x00; DDRC = _BV(PORTC_ICONT) | _BV(PORTC_nDBE) | _BV(PORTC_ADV); // Set up address. This will cause the data buffer to drive into the instrument. DDRB = 0xff; PORTB = addr & 0x7f; // Set up data. DDRD = 0xff; PORTD = data; setup_delay(); // Assert ADV set(PORTC, PORTC_ADV); // 800ns asm volatile("nop"); asm volatile("nop"); asm volatile("nop"); asm volatile("nop"); asm volatile("nop"); // Deassert ADV. clear(PORTC, PORTC_ADV); setup_delay(); // Stop driving the data lines. // This will cause the address buffer to drive out of the instrument because AD7 will be pulled high. PORTD = 0xff; DDRD = 0x00; // Stop driving the address lines. PORTB = 0xff; DDRB = 0x00; // Return control to the instrument computer. DDRC = _BV(PORTC_ICONT) | _BV(PORTC_nDBE); PORTC = _BV(PORTC_ICONT) | _BV(PORTC_nDBE); } uint8_t read_reg(uint8_t addr) { // Take control of instrument bus and enable data bus drivers. // This also drives ADV low at the same time. PORTC = 0x00; DDRC = _BV(PORTC_ICONT) | _BV(PORTC_nDBE) | _BV(PORTC_ADV); // Set up address. This will cause the data buffer to drive out of the instrument. DDRB = 0xff; PORTB = addr | 0x80; setup_delay(); // Assert ADV set(PORTC, PORTC_ADV); //FIXME - 15.40us setup_delay(); uint8_t value = PIND; // Deassert ADV. clear(PORTC, PORTC_ADV); setup_delay(); // Stop driving the address lines. PORTB = 0xff; DDRB = 0x00; // Return control to the instrument computer. DDRC = _BV(PORTC_ICONT) | _BV(PORTC_nDBE); PORTC = _BV(PORTC_ICONT) | _BV(PORTC_nDBE); return value; } typedef struct { uint8_t bmRequestType; uint8_t bRequest; uint16_t wValue; uint16_t wIndex; uint16_t wLength; } USB_Setup_Request; // Used for putting words in descriptor byte arrays #define WORD(x) ((x) & 0xff), (((x) >> 8) & 0xff) const uint8_t device_desc[] PROGMEM = { 18, // bLength 1, // bDescriptorType WORD(0x200), // bcdUSB 0xff, // bDeviceClass 0, // bDeviceSubclass 0, // bDeviceProtocol EP0_SIZE, // bMaxPacketSize0 WORD(0x3141), // idVendor WORD(0x0005), // idProduct WORD(0), // bcdDevice 0, // iManufacturer 0, // iProduct 0, // iSerialNumber 1 // bNumConfigurations }; #define CONFIG_SIZE 9 #define INTF_SIZE 9 #define EP_SIZE 7 const uint8_t config_desc[] PROGMEM = { // Configuration CONFIG_SIZE, // bLength 2, // bDescriptorType WORD( // wTotalLength CONFIG_SIZE + INTF_SIZE), 1, // bNumInterfaces 1, // bConfigurationValue 0, // iConfiguration 0xc0, // bmAttributes 0, // MaxPower // Interface 0 INTF_SIZE, // bLength 4, // bDescriptorType 0, // bInterfaceNumber 0, // bAlternateSetting 0, // bNumEndpoints (not counting endpoint 0) 0xff, // bInterfaceClass 0xff, // bInterfaceSubclass 0, // bInterfaceProtocol 0 // iInterface }; // Read n bytes from the current endpoint void usb_read(void *buf, uint8_t n) { while (n--) { *(uint8_t *)buf++ = UEDATX; } } // Sends the data currently in the FIFO (typically used to send a zero-length packet) void usb_write_packet() { clear(UEINTX, TXINI); loop_until_bit_is_set(UEINTX, TXINI); } // Send data from program memory void usb_write_P(PGM_VOID_P buf, uint8_t len, uint16_t requested) { // Only send up to the requested amount of data. // Otherwise we will be waiting forever for another IN token from the host. uint8_t n = len; if (n > requested) { n = requested; } uint8_t sent = 0; while (n--) { UEDATX = pgm_read_byte(buf++); ++sent; if (n == 0 || sent == 64) //FIXME - Endpoint size { sent = 0; clear(UEINTX, TXINI); while (!(UEINTX & ((1 << TXINI) | (1 << RXOUTI)))) ; if (bit_is_set(UEINTX, RXOUTI)) { // Aborted by host return; } } } // Wait for status loop_until_bit_is_set(UEINTX, RXOUTI); clear(UEINTX, RXOUTI); } // Send data from RAM void usb_write(void *buf, uint8_t len, uint16_t requested) { // Only send up to the requested amount of data. // Otherwise we will be waiting forever for another IN token from the host. uint8_t n = len; if (n > requested) { n = requested; } uint8_t sent = 0; while (n--) { UEDATX = *(uint8_t *)buf++; ++sent; if (n == 0 || sent == 64) //FIXME - Endpoint size { sent = 0; clear(UEINTX, TXINI); while (!(UEINTX & ((1 << TXINI) | (1 << RXOUTI)))) ; if (bit_is_set(UEINTX, RXOUTI)) { // Aborted by host return; } } } // Wait for status loop_until_bit_is_set(UEINTX, RXOUTI); clear(UEINTX, RXOUTI); } // Starts the bootloader void bootloader() { cli(); set(UDCON, DETACH); ((void (*)(void))0x1800)(); } // Disables and frees memory for all endpoints except 0. void usb_free_endpoints() { uint8_t old_ep = UENUM; uint8_t i; for (i = 1; i <= 4; ++i) { UENUM = i; clear(UECONX, EPEN); clear(UECFG1X, ALLOC); } UENUM = old_ep; } // Called when a SETUP packet is received on endpoint 0. void usb_handle_setup() { // Read the packet USB_Setup_Request req; usb_read(&req, 8); // Clear the FIFO //FIXME - Do this later if this is an OUT transfer (host will be sending in the DATA stage)? clear(UEINTX, RXSTPI); // Every request must end with either an IN packet (usb_write_packet or similar) or // a STALL, which is sent if valid == 0. uint8_t valid = 1; if ((req.bmRequestType & 0x60) == 0) { // Device request switch (req.bRequest) { case 0x05: // Set address UDADDR = (UDADDR & (1 << ADDEN)) | (req.wValue & 0x7f); usb_write_packet(); set(UDADDR, ADDEN); break; case 0x06: // Get descriptor if (req.wValue == 0x0100) { // Get device descriptor usb_write_P(device_desc, sizeof(device_desc), req.wLength); } else if (req.wValue == 0x0200) { // Get configuration descriptor usb_write_P(config_desc, sizeof(config_desc), req.wLength); } else { valid = 0; } break; case 0x09: // Set configuration usb_write_packet(); break; default: valid = 0; break; } } else if ((req.bmRequestType & 0x7f) == 0x40) { // Vendor request switch (req.bRequest) { case 0: write_reg(req.wIndex, req.wValue); usb_write_packet(); break; case 1: { // This is a copy of usb_write which doesn't require an intermediate buffer. uint8_t sent = 0; uint16_t n = req.wLength; while (n--) { UEDATX = read_reg(req.wIndex); ++sent; if (n == 0 || sent == EP0_SIZE) { sent = 0; clear(UEINTX, TXINI); while (!(UEINTX & ((1 << TXINI) | (1 << RXOUTI)))) ; if (bit_is_set(UEINTX, RXOUTI)) { // Aborted by host return; } } } // Wait for status loop_until_bit_is_set(UEINTX, RXOUTI); clear(UEINTX, RXOUTI); break; } case 0xff: // Bootloader usb_write_packet(); bootloader(); break; default: valid = 0; break; } } else { valid = 0; } if (!valid) { // Unsupported request: stall EP0 set(UECONX, STALLRQ); } } ISR(USB_GEN_vect) { if (bit_is_set(UDINT, WAKEUPI)) { // Wakeup (USB bus activity is detected) // We have to turn off the interrupt or it will trigger frequently when // the device is active. This causes all sorts of weird problems. clear(UDIEN, WAKEUPE); // Start the 48MHz PLL set(PLLCSR, PLLE); loop_until_bit_is_set(PLLCSR, PLOCK); // Enable the USB clock clear(USBCON, FRZCLK); // Clear the interrupt flag after starting the clock clear(UDINT, WAKEUPI); // The USB controller will indicate end-of-reset soon. // The end-of-reset handler will set up endpoints. } if (bit_is_set(UDINT, EORSTI)) { // USB reset clear(UDINT, EORSTI); usb_free_endpoints(); // Endpoint 0: control // 64-byte packets (so we can send the device and config descriptors in one packet) // Single buffer UENUM = 0; clear(UECONX, EPEN); clear(UECFG1X, ALLOC); UECONX = (1 << EPEN); // Do this before other configuration UEIENX = (1 << RXSTPE); UECFG0X = 0; UECFG1X = (3 << EPSIZE0); set(UECFG1X, ALLOC); } } ISR(USB_COM_vect) { UENUM = 0; if (bit_is_set(UEINTX, RXSTPI)) { usb_handle_setup(); } } int main() { // Disable the watchdog timer. // This must be done in case we are started from the clear_bit, // which uses the WDT to reset. wdt_reset(); clear(MCUSR, WDRF); WDTCSR |= (1 << WDCE) | (1 << WDE); WDTCSR = 0; // Run at full clock speed CLKPR = 1 << CLKPCE; CLKPR = 0; // Set up I/O ports DDRB = 0x00; PORTB = 0xff; DDRC = _BV(PORTC_ICONT) | _BV(PORTC_nDBE); PORTC = _BV(PORTC_ICONT) | _BV(PORTC_nDBE); DDRD = 0x00; PORTD = 0xff; // Reset the USB controller. // This will disable all interrupts and endpoints too. USBCON = (1 << FRZCLK); UDCON = (1 << DETACH); // Enable the USB controller set(USBCON, USBE); // Attach device clear(UDCON, DETACH); // Enable interrupts UDIEN = (1 << WAKEUPE) | (1 << EORSTE); sei(); while (1) { } }
