=========================== USB Port1 =========================== Connection Status : 0x01 (Device is connected) Port Chain : 5-1 ========================== Summary ========================= Vendor ID : 0x16C0 (Van Ooijen Technische Informatica) Product ID : 0x047A USB Version : 2.00 -> wrong, Device is Full-Speed only Port maximum Speed : Full-Speed Device maximum Speed : Full-Speed Device Connection Speed : Full-Speed Self powered : yes Demanded Current : 100 mA Used Endpoints : 4 ======================== USB Device ======================== +++++++++++++++++ Device Information ++++++++++++++++++ Device Description : USB Serial Device ID : USB\VID_16C0&PID_047A\12345 Hardware IDs : USB\VID_16C0&PID_047A&REV_0100 USB\VID_16C0&PID_047A Driver KeyName : {88bae032-5a81-49f0-bc3d-a4ff138216d6}\0000 (GUID_DEVCLASS_USBDEVICE) Driver : system32\DRIVERS\WinUSB.sys (Version: 6.1.7601.17514 Date: 2010-11-21) Driver Inf : C:\Windows\inf\oem20.inf Legacy BusType : PNPBus Class : USBDevice Class GUID : {88bae032-5a81-49f0-bc3d-a4ff138216d6} (GUID_DEVCLASS_USBDEVICE) Service : WinUSB Enumerator : USB Location Info : Port_#0001.Hub_#0001 Location IDs : PCIROOT(0)#PCI(1A00)#USBROOT(0)#USB(1) Container ID : {8cde8d4d-fe20-5c03-9058-cb869ef93b22} Manufacturer Info : Van Ooijen Technische Informatica Capabilities : 0x14 (Removable, UniqueID) Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER) Problem Code : 0 HcDisableSelectiveSuspend: 0 EnableSelectiveSuspend : 0 SelectiveSuspendEnabled : 0 EnhancedPowerMgmtEnabled : 0 IdleInWorkingState : 0 WakeFromSleepState : 0 Power State : D0 (supported: D0, D3, wake from D0) +++++++++++++++++ Registry USB Flags +++++++++++++++++ HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\16C0047A0100 osvc : REG_BINARY 00 00 SkipContainerIdQuery : REG_BINARY 01 00 00 00 ---------------- Connection Information --------------- Connection Index : 0x01 (Port 1) Connection Status : 0x01 (DeviceConnected) Current Config Value : 0x01 (Configuration 1) Device Address : 0x01 (1) Is Hub : 0x00 (no) Device Bus Speed : 0x01 (Full-Speed) Number Of Open Pipes : 0x03 (3 pipes to data endpoints) Pipe[0] : EndpointID=2 Direction=IN ScheduleOffset=0 Type=Interrupt wMaxPacketSize=16 bInterval=64 Pipe[1] : EndpointID=3 Direction=OUT ScheduleOffset=0 Type=Bulk wMaxPacketSize=64 bInterval=0 Pipe[2] : EndpointID=4 Direction=IN ScheduleOffset=0 Type=Bulk wMaxPacketSize=64 bInterval=0 Data (HexDump) : 01 00 00 00 12 01 00 02 02 00 00 10 C0 16 7A 04 ..............z. 00 01 01 02 03 01 01 01 00 01 00 03 00 00 00 01 ................ 00 00 00 07 05 82 03 10 00 40 00 00 00 00 07 05 .........@...... 03 02 40 00 00 00 00 00 00 07 05 84 02 40 00 00 ..@..........@.. 00 00 00 00 .... ---------------------- Device Descriptor ---------------------- bLength : 0x12 (18 bytes) bDescriptorType : 0x01 (Device Descriptor) bcdUSB : 0x200 (USB Version 2.00) -> wrong, device is Full-Speed only bDeviceClass : 0x02 (Communications and CDC Control) bDeviceSubClass : 0x00 bDeviceProtocol : 0x00 (No class specific protocol required) bMaxPacketSize0 : 0x10 (16 bytes) idVendor : 0x16C0 (Van Ooijen Technische Informatica) idProduct : 0x047A bcdDevice : 0x0100 iManufacturer : 0x01 (String Descriptor 1) Language 0x0409 : "Your Name" iProduct : 0x02 (String Descriptor 2) Language 0x0409 : "USB Serial" iSerialNumber : 0x03 (String Descriptor 3) Language 0x0409 : "12345" bNumConfigurations : 0x01 (1 Configuration) Data (HexDump) : 12 01 00 02 02 00 00 10 C0 16 7A 04 00 01 01 02 ..........z..... 03 01 .. ------------------ Configuration Descriptor ------------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x02 (Configuration Descriptor) wTotalLength : 0x0043 (67 bytes) bNumInterfaces : 0x02 (2 Interfaces) bConfigurationValue : 0x01 (Configuration 1) iConfiguration : 0x00 (No String Descriptor) bmAttributes : 0xC0 D7: Reserved, set 1 : 0x01 D6: Self Powered : 0x01 (yes) D5: Remote Wakeup : 0x00 (no) D4..0: Reserved, set 0 : 0x00 MaxPower : 0x32 (100 mA) Data (HexDump) : 09 02 43 00 02 01 00 C0 32 09 04 00 00 01 02 02 ..C.....2....... 01 00 05 24 00 10 01 05 24 01 01 01 04 24 02 06 ...$....$....$.. 05 24 06 00 01 07 05 82 03 10 00 40 09 04 01 00 .$.........@.... 02 0A 00 00 00 07 05 03 02 40 00 00 07 05 84 02 .........@...... 40 00 00 @.. ---------------- Interface Descriptor ----------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x04 (Interface Descriptor) bInterfaceNumber : 0x00 (Interface 0) bAlternateSetting : 0x00 bNumEndpoints : 0x01 (1 Endpoint) bInterfaceClass : 0x02 (Communications and CDC Control) bInterfaceSubClass : 0x02 (Abstract Control Model) bInterfaceProtocol : 0x01 (AT Commands defined by ITU-T V.250 etc) iInterface : 0x00 (No String Descriptor) Data (HexDump) : 09 04 00 00 01 02 02 01 00 ......... -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x05 (5 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x00 (Header Functional Descriptor) bcdCDC : 0x110 (CDC Version 1.10) Data (HexDump) : 05 24 00 10 01 .$... -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x05 (5 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x01 (Call Management Functional Descriptor) bmCapabilities : 0x01 D7..2 : 0x00 (Reserved) D1 : 0x00 (sends/receives call management information only over the Communication Class interface) D0 : 0x01 (handles call management itself) bDataInterface : 0x01 Data (HexDump) : 05 24 01 01 01 .$... -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x04 (4 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x02 (Abstract Control Management Functional Descriptor) bmCapabilities : 0x06 D7..4 : 0x00 (Reserved) D3 : 0x00 (not supports the notification Network_Connection) D2 : 0x01 (supports the request Send_Break) D1 : 0x01 (supports the request combination of Set_Line_Coding, Set_Control_Line_State, Get_Line_Coding, and the notification Serial_State) D0 : 0x00 (not supports the request combination of Set_Comm_Feature, Clear_Comm_Feature, and Get_Comm_Feature) Data (HexDump) : 04 24 02 06 .$.. -------------- CDC Interface Descriptor --------------- bFunctionLength : 0x05 (5 bytes) bDescriptorType : 0x24 (Interface) bDescriptorSubType : 0x06 (Union Functional Descriptor) bControlInterface : 0x00 bSubordinateInterface[0] : 0x01 Data (HexDump) : 05 24 06 00 01 .$... ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x82 (Direction=IN EndpointID=2) bmAttributes : 0x03 (TransferType=Interrupt) wMaxPacketSize : 0x0010 (16 bytes) bInterval : 0x40 (64 ms) Data (HexDump) : 07 05 82 03 10 00 40 ......@ ---------------- Interface Descriptor ----------------- bLength : 0x09 (9 bytes) bDescriptorType : 0x04 (Interface Descriptor) bInterfaceNumber : 0x01 (Interface 1) bAlternateSetting : 0x00 bNumEndpoints : 0x02 (2 Endpoints) bInterfaceClass : 0x0A (CDC-Data) bInterfaceSubClass : 0x00 bInterfaceProtocol : 0x00 iInterface : 0x00 (No String Descriptor) Data (HexDump) : 09 04 01 00 02 0A 00 00 00 ......... ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x03 (Direction=OUT EndpointID=3) bmAttributes : 0x02 (TransferType=Bulk) wMaxPacketSize : 0x0040 (64 bytes) bInterval : 0x00 (ignored) Data (HexDump) : 07 05 03 02 40 00 00 ....@.. ----------------- Endpoint Descriptor ----------------- bLength : 0x07 (7 bytes) bDescriptorType : 0x05 (Endpoint Descriptor) bEndpointAddress : 0x84 (Direction=IN EndpointID=4) bmAttributes : 0x02 (TransferType=Bulk) wMaxPacketSize : 0x0040 (64 bytes) bInterval : 0x00 (ignored) Data (HexDump) : 07 05 84 02 40 00 00 ....@.. ----------------- Device Qualifier Descriptor ----------------- Error : ERROR_GEN_FAILURE (*!*ERROR USB 2.0 devices must provide a Device Qualifier Descriptor) -------------------- String Descriptors ------------------- ------ String Descriptor 0 ------ bLength : 0x04 (4 bytes) bDescriptorType : 0x03 (String Descriptor) Language ID[0] : 0x0409 (English - United States) Data (HexDump) : 04 03 09 04 .... ------ String Descriptor 1 ------ bLength : 0x14 (20 bytes) bDescriptorType : 0x03 (String Descriptor) Language 0x0409 : "Your Name" Data (HexDump) : 14 03 59 00 6F 00 75 00 72 00 20 00 4E 00 61 00 ..Y.o.u.r. .N.a. 6D 00 65 00 m.e. ------ String Descriptor 2 ------ bLength : 0x16 (22 bytes) bDescriptorType : 0x03 (String Descriptor) Language 0x0409 : "USB Serial" Data (HexDump) : 16 03 55 00 53 00 42 00 20 00 53 00 65 00 72 00 ..U.S.B. .S.e.r. 69 00 61 00 6C 00 i.a.l. ------ String Descriptor 3 ------ bLength : 0x0C (12 bytes) bDescriptorType : 0x03 (String Descriptor) Language 0x0409 : "12345" Data (HexDump) : 0C 03 31 00 32 00 33 00 34 00 35 00 ..1.2.3.4.5.
