/************************************************************************* * Title: I2C master library using hardware TWI interface * Author: Peter Fleury http://jump.to/fleury * File: $Id: twimaster.c,v 1.4 2015/01/17 12:16:05 peter Exp $ * Software: AVR-GCC 3.4.3 / avr-libc 1.2.3 * Target: any AVR device with hardware TWI * Usage: API compatible with I2C Software Library i2cmaster.h **************************************************************************/ #include #include #include #include "UART.h" #include "i2cmaster.h" /* define CPU frequency in hz here if not defined in Makefile */ //#ifndef F_CPU //#define F_CPU 4000000UL //#endif /* I2C clock in Hz */ #define SCL_CLOCK 1000 /************************************************************************* Initialization of the I2C bus interface. Need to be called only once *************************************************************************/ void i2c_init(void) { /* initialize TWI clock: 100 kHz clock, TWPS = 0 => prescaler = 1 */ TWSR = 0; /* no prescaler */ TWBR = ((F_CPU/SCL_CLOCK)-16)/2; /* must be > 10 for stable operation */ // PORTC |= (1 << PORTC5 | 1<< PORTC4); //internal pullop? printf("TWI initialized \n"); }/* i2c_init */ /************************************************************************* Issues a start condition and sends address and transfer direction. return 0 = device accessible, 1= failed to access device *************************************************************************/ unsigned char i2c_start(unsigned char address) { printf("Starting I2C \n"); uint8_t twst; // send START condition TWCR = (1<
