library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.NUMERIC_STD.all; entity PWM_MODULE_CLK_EN is generic ( P : integer := 1666667 ); port ( CLK_100MHZ_PIN : in std_logic; ARESETN_PIN : in std_logic; CLK_EN_OUT : out std_logic ); end PWM_MODULE_CLK_EN; architecture Behavioral of PWM_MODULE_CLK_EN is signal COUNTER : integer range 0 to P-1 := 0; begin process(CLK_100MHZ_PIN) begin if CLK_100MHZ_PIN = '1' and CLK_100MHZ_PIN'event then CLK_EN_OUT <= '0'; if ARESETN_PIN = '0' then COUNTER <= 0; else if COUNTER = P-1 then COUNTER <= 0; CLK_EN_OUT <= '1'; else COUNTER <= COUNTER +1; end if; end if; end if; end process; end Behavioral;
