library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.NUMERIC_STD.all; entity TB_PWM_MODULE_CLK_EN is end TB_PWM_MODULE_CLK_EN; architecture tb of TB_PWM_MODULE_CLK_EN is component PWM_MODULE_CLK_EN is generic ( P : integer ); port ( CLK_100MHZ_PIN : in std_logic; ARESETN_PIN : in std_logic; CLK_EN_OUT : out std_logic ); end component; signal CLK_100MHZ_PIN : std_logic := '1'; signal ARESETN_PIN : std_logic := '1'; signal CLK_EN_OUT : std_logic := '0'; begin CLK_100MHZ_PIN <= not CLK_100MHZ_PIN after 5 ns; process begin wait for 500 ns; ARESETN_PIN <= '0'; wait for 500 ns; ARESETN_PIN <= '1'; wait; end process; inst_PWM_MODULE_CLK_EN : PWM_MODULE_CLK_EN generic map ( P => 20 ) port map ( CLK_100MHZ_PIN => CLK_100MHZ_PIN, ARESETN_PIN => ARESETN_PIN, CLK_EN_OUT => CLK_EN_OUT ); end;
