#include #include bool digitalRead(int); void digitalWrite(int, bool); #define KEY_COUNT 6 #define KEY_EMPTY 0xff uint8_t key_pins[KEY_COUNT] = { 1, 2, 3, 4, 5, 6 }; uint8_t led_pins[KEY_COUNT] = { 7, 8, 9, 10, 11, 12 }; bool key_input[KEY_COUNT]; uint8_t key_order[KEY_COUNT]; void setup(void) { for (uint8_t i = 0; i < KEY_COUNT; i++) key_order[i] = KEY_EMPTY; } static void input_keys(void) { for (uint8_t i = 0; i < KEY_COUNT; i++) key_input[i] = digitalRead( key_pins[i] ); } static void remove_first_key(uint8_t key) { if (key_order[0] != key) // not at first return; for (uint8_t i = 0; i < KEY_COUNT-1; i++) // copy down key_order[i] = key_order[i+1]; key_order[KEY_COUNT-1] = KEY_EMPTY; } static void insert_next_key(uint8_t key) { for (uint8_t i = 0; i < KEY_COUNT; i++) { if (key_order[i] == key) // already in list break; if (key_order[i] == KEY_EMPTY) // insert here { key_order[i] = key; break; } } } static void handle_keys(void) { for (uint8_t i = 0; i < KEY_COUNT; i++) if (key_input[i] == true) insert_next_key(i); else remove_first_key(i); } static void first_led_on(void) { for (uint8_t i = 0; i < KEY_COUNT; i++) digitalWrite(led_pins[i], i == key_order[0]); // only first LED on } void loop(void) { input_keys(); handle_keys(); first_led_on(); }
