//Initialisierung Helligkeitssensor char Helligkeitssensor1 = A0; char Helligkeitssensor2 = A1; char Helligkeitssensor3 = A2; char Helligkeitssensor4 = A3; char Helligkeitssensor5 = A4; char Helligkeitssensor6 = A5; //Initialisierung LEDs char LED1 = 9; char LED2 = 8; char LED3 = 7; char LED4 = 6; char LED5 = 5; char LED6 = 4; //Initialisierung Hilfsvariablen char x1 = 0; char x2 = 0; char x3 = 0; char x4 = 0; char x5 = 0; char x6 = 0; char Sensor_Schritt1= 0; char Sensor_Schritt2= 0; char Sensor_Schritt3= 0; char Sensor_Schritt4= 0; char Sensor_Schritt5= 0; char Sensor_Schritt6= 0; char LED_war_H = 0; char LED_war_H_2 = 0; char LED_war_H_3 = 0; char LED_war_H_4 = 0; char LED_war_H_5 = 0; char LED_war_H_6 = 0; char LED_ist_wieder_L = 0; char LED_ist_wieder_L_2 = 0; char LED_ist_wieder_L_3 = 0; char LED_ist_wieder_L_4 = 0; char LED_ist_wieder_L_5 = 0; char LED_ist_wieder_L_6 = 0; char Schritt_Reihenfolge = 0; char Erster_Durchlauf = 0; char Runde2 = 0; char Schritt1_vorgekommen = 0; char Schritt2_vorgekommen = 0; char Schritt3_vorgekommen = 0; char Schritt4_vorgekommen = 0; char Schritt5_vorgekommen = 0; char Schritt6_vorgekommen = 0; float LED_Schritt[6]= {0,0,0,0,0,0}; float pruefer_sensor[6] = {0,0,0,0,0,0}; int Sensor1_Zustand = 0; int Sensor2_Zustand = 0; int Sensor3_Zustand = 0; int Sensor4_Zustand = 0; int Sensor5_Zustand = 0; int Sensor6_Zustand = 0; char step1_immer_noch_H = 0; char step2_immer_noch_H = 0; char step3_immer_noch_H = 0; char step4_immer_noch_H = 0; char step5_immer_noch_H = 0; char step6_immer_noch_H = 0; void setup() { pinMode(Helligkeitssensor1,INPUT); pinMode(Helligkeitssensor2,INPUT); pinMode(Helligkeitssensor3,INPUT); pinMode(Helligkeitssensor4,INPUT); pinMode(Helligkeitssensor5,INPUT); pinMode(Helligkeitssensor6,INPUT); pinMode(LED1,OUTPUT); pinMode(LED2,OUTPUT); pinMode(LED3,OUTPUT); pinMode(LED4,OUTPUT); pinMode(LED5,OUTPUT); pinMode(LED6,OUTPUT); } void loop() { float LEDs[6] = {LED1,LED2,LED3,LED4,LED5,LED6}; float Sensoren[6] = {Helligkeitssensor1,Helligkeitssensor2,Helligkeitssensor3,Helligkeitssensor4,Helligkeitssensor5,Helligkeitssensor6}; float Sensoren_variable[6] = {Helligkeitssensor1,Helligkeitssensor2,Helligkeitssensor3,Helligkeitssensor4,Helligkeitssensor5,Helligkeitssensor6}; Sensoren[0] = analogRead(Helligkeitssensor1); Sensoren[1] = analogRead(Helligkeitssensor2); Sensoren[2] = analogRead(Helligkeitssensor3); Sensoren[3] = analogRead(Helligkeitssensor4); Sensoren[4] = analogRead(Helligkeitssensor5); Sensoren[5] = analogRead(Helligkeitssensor6); /*if(Sensoren[0]>= 1015){ digitalWrite(LEDs[0],HIGH); //Serial.println("2"); } */ //Schritt1------------------------------------------------------------------------------------------------------------ if(((Sensoren[0] <= 0)||(Sensoren[1] <= 0)||(Sensoren[2] <= 0)||(Sensoren[3] <= 0)||(Sensoren[4] <= 0)||(Sensoren[5] <= 0)) &&((Schritt_Reihenfolge == 0)||(Schritt_Reihenfolge == 6))){ //Wenn ein Sensor aktiviert wird und dieser Schritt an der Reihe ist Serial.println("1"); for(int x = 0; x < 6 ; x ++){ if ((LED_Schritt[0] == 0) && (Sensoren[x] <= 3)&&(pruefer_sensor[x]== 0)){ //Wenn die Nummer des x mit dem aktivierten Sensor übereinstimmt und sensor nicht bereits in Schritten vorher HIGH war Sensor_Schritt1= Sensoren_variable[x]; //aktivierter Sensor wird diesem Schritt zugewiesen LED_Schritt[0] = LEDs[x]; //dazugehörige LED des Sensors wird diesem Schritt zugewiesen pruefer_sensor[x] = 1; x1 = x; //die Nummer des Sensors wird x zugewiesen Schritt_Reihenfolge = 1; //wird um 1 erhöht dass es in den Schritt2 gehen kann Schritt1_vorgekommen = 1; //sichert ab das dieser Schritt vorkam if(Runde2 == 1){ //Wenn die erste Runde durch ist Erster_Durchlauf = 1; } } } } Sensor1_Zustand = analogRead(Sensor_Schritt1); //Zustand des Sensors wird ausgelesn if((Sensor1_Zustand <= 0)&&(((LED_ist_wieder_L_6 == 1)&&(LED_ist_wieder_L_5 == 1)&&(LED_ist_wieder_L_4 == 1)&&(LED_ist_wieder_L_3 == 1)&&(LED_ist_wieder_L_2 == 1)&&(LED_ist_wieder_L == 1))||(Erster_Durchlauf == 0))){ //wenn alle anderen LEDs Low sind oder es der erste Durchlauf ist und der Sensor von Schritt1 HIGH ist digitalWrite(LED_Schritt[0],HIGH); if(Schritt1_vorgekommen == 1){ LED_ist_wieder_L = 0; step1_immer_noch_H = 1; } } if(Sensor1_Zustand > 1){ digitalWrite(LED_Schritt[0],LOW); pruefer_sensor[x1] = 0; LED_ist_wieder_L = 1; //löschen LED_Schritt[0] = 0; Sensor_Schritt1= 0; Sensor1_Zustand = 0; Schritt1_vorgekommen = 0; step1_immer_noch_H = 0; Serial.println("2"); } //Ende Schritt 1 --------------------------------------------------------------------------------------------------------- //Schritt2 --------------------------------------------------------------------------------------------------------------- if(((Sensoren[0] <= 0)||(Sensoren[1] <= 0)||(Sensoren[2] <= 0)||(Sensoren[3] <= 0)||(Sensoren[4] <= 0)||(Sensoren[5] <= 0))&&(Schritt_Reihenfolge == 1)){ //kann direkt hier rein weil Flanke bei schritt 1 direkt auf 1 gesetzt wird muss ausschliessen dass es mit dem gleichen High hier rein kommt for(int x = 0; x < 6 ; x ++){ if ((Sensoren[x] <= 3)&&(pruefer_sensor[x] == 0)&&( LED_Schritt[1]== 0)){ LED_Schritt[1]= LEDs[x]; Sensor_Schritt2= Sensoren_variable[x]; pruefer_sensor[x] = 1; Schritt_Reihenfolge = 2; x2 = x; Schritt2_vorgekommen = 1; } } } Sensor2_Zustand = analogRead(Sensor_Schritt2); if((Sensor2_Zustand <= 0)&&(((LED_ist_wieder_L_6 == 1)&&(LED_ist_wieder_L_5 == 1)&&(LED_ist_wieder_L_4 == 1)&&(LED_ist_wieder_L_3 == 1)&&(LED_ist_wieder_L_2 == 1))||(Erster_Durchlauf == 0))&&(LED_ist_wieder_L == 1)){ digitalWrite(LED_Schritt[1],HIGH); if(Schritt2_vorgekommen == 1){ LED_ist_wieder_L_2 = 0; step2_immer_noch_H = 1; } } if(Sensor2_Zustand > 1){ digitalWrite(LED_Schritt[1],LOW); pruefer_sensor[x2] = 0; LED_ist_wieder_L_2 = 1; //löschen LED_Schritt[1] = 0; Sensor_Schritt2= 0; Sensor2_Zustand = 0; Schritt2_vorgekommen = 0; step2_immer_noch_H = 0; } //Ende Schritt 2 ------------------------------------------------------------------------------------------------------------ //Schritt3 --------------------------------------------------------------------------------------------------------------- if(((Sensoren[0] <= 0)||(Sensoren[1] <= 0)||(Sensoren[2] <= 0)||(Sensoren[3] <= 0)||(Sensoren[4] <= 0)||(Sensoren[5] <= 0)) &&(Schritt_Reihenfolge == 2)){ //kann direkt hier rein weil Flanke bei schritt 1 direkt auf 1 gesetzt wird muss ausschliessen dass es mit dem gleichen High hier rein kommt for(int x = 0; x < 6 ; x ++){ if ((Sensoren[x] <= 3)&&(pruefer_sensor[x] == 0)&&(LED_Schritt[2] == 0)){ LED_Schritt[2] = LEDs[x]; Sensor_Schritt3= Sensoren_variable[x]; pruefer_sensor[x] = 1; Schritt_Reihenfolge = 3; x3 = x; Schritt3_vorgekommen = 1; } } } Sensor3_Zustand = analogRead(Sensor_Schritt3); if((Sensor3_Zustand <= 0)&&(((LED_ist_wieder_L_6 == 1)&&(LED_ist_wieder_L_5 == 1)&&(LED_ist_wieder_L_4 == 1)&&(LED_ist_wieder_L_3 == 1))||(Erster_Durchlauf == 0))&&(LED_ist_wieder_L == 1)&&(LED_ist_wieder_L_2 == 1)){ digitalWrite(LED_Schritt[2],HIGH); if(Schritt3_vorgekommen == 1){ LED_ist_wieder_L_3 = 0; step3_immer_noch_H = 1; } } if(Sensor3_Zustand > 1){ digitalWrite(LED_Schritt[2],LOW); pruefer_sensor[x3] = 0; LED_ist_wieder_L_3 = 1; //löschen LED_Schritt[2] = 0; Sensor_Schritt3= 0; Sensor3_Zustand = 0; Schritt3_vorgekommen = 0; step3_immer_noch_H = 0; } //Ende Schritt 3 ------------------------------------------------------------------------------------------------------------ //Schritt4 --------------------------------------------------------------------------------------------------------------- if(((Sensoren[0] <= 0)||(Sensoren[1] <= 0)||(Sensoren[2] <= 0)||(Sensoren[3] <= 0)||(Sensoren[4] <= 0)||(Sensoren[5] <= 0)) &&(Schritt_Reihenfolge == 3)){ //kann direkt hier rein weil Flanke bei schritt 1 direkt auf 1 gesetzt wird muss ausschliessen dass es mit dem gleichen High hier rein kommt for(int x = 0; x < 6 ; x ++){ if ((Sensoren[x] <= 3)&&(pruefer_sensor[x] == 0)&&(LED_Schritt[3] == 0)){ //zb 1 LED_Schritt[3] = LEDs[x]; Sensor_Schritt4= Sensoren_variable[x]; pruefer_sensor[x] = 1; Schritt_Reihenfolge = 4; x4 = x; Schritt4_vorgekommen = 1; } } } Sensor4_Zustand = analogRead(Sensor_Schritt4); if((Sensor4_Zustand <= 0)&&(((LED_ist_wieder_L_6 == 1)&&(LED_ist_wieder_L_5 == 1)&&(LED_ist_wieder_L_4 == 1))||(Erster_Durchlauf == 0))&&(LED_ist_wieder_L == 1)&&(LED_ist_wieder_L_2 == 1)&&(LED_ist_wieder_L_3 == 1)){ digitalWrite(LED_Schritt[3],HIGH); if(Schritt4_vorgekommen == 1){ LED_ist_wieder_L_4 = 0; step4_immer_noch_H = 1; } } if(Sensor4_Zustand > 1){ digitalWrite(LED_Schritt[3],LOW); pruefer_sensor[x4] = 0; LED_ist_wieder_L_4 = 1; //löschen LED_Schritt[3] = 0; Sensor_Schritt4= 0; Sensor4_Zustand = 0; Schritt4_vorgekommen = 0; step4_immer_noch_H = 0; } //Ende Schritt 4 ------------------------------------------------------------------------------------------------------------ //Schritt5 --------------------------------------------------------------------------------------------------------------- if(((Sensoren[0] <= 0)||(Sensoren[1] <= 0)||(Sensoren[2] <= 0)||(Sensoren[3] <= 0)||(Sensoren[4] <= 0)||(Sensoren[5] <= 0))&&(Schritt_Reihenfolge == 4)){ //kann direkt hier rein weil Flanke bei schritt 1 direkt auf 1 gesetzt wird muss ausschliessen dass es mit dem gleichen High hier rein kommt for(int x = 0; x < 6 ; x ++){ if ((Sensoren[x] <= 3)&&(pruefer_sensor[x] == 0)&&(LED_Schritt[4] == 0)){ //zb 1 LED_Schritt[4] = LEDs[x]; Sensor_Schritt5= Sensoren_variable[x]; pruefer_sensor[x] = 1; Schritt_Reihenfolge = 5; x5 = x; Schritt5_vorgekommen = 1; } } } Sensor5_Zustand = analogRead(Sensor_Schritt5); if((Sensor5_Zustand <= 0)&&(((LED_ist_wieder_L_6 == 1)&&(LED_ist_wieder_L_5 == 1))||(Erster_Durchlauf == 0))&&(LED_ist_wieder_L == 1)&&(LED_ist_wieder_L_2 == 1)&&(LED_ist_wieder_L_3 == 1)&&(LED_ist_wieder_L_4 == 1)){ digitalWrite(LED_Schritt[4],HIGH); if(Schritt5_vorgekommen == 1){ LED_ist_wieder_L_5 = 0; step5_immer_noch_H = 1; } } if(Sensor5_Zustand > 1){ digitalWrite(LED_Schritt[4],LOW); pruefer_sensor[x5] = 0; LED_ist_wieder_L_5 = 1; step5_immer_noch_H = 0; //löschen LED_Schritt[4] = 0; Sensor_Schritt5= 0; Sensor5_Zustand = 0; Schritt5_vorgekommen = 0; } //Ende Schritt 5 ------------------------------------------------------------------------------------------------------------ //Schritt6 --------------------------------------------------------------------------------------------------------------- if(((Sensoren[0] <= 0)||(Sensoren[1] <= 0)||(Sensoren[2] <= 0)||(Sensoren[3] <= 0)||(Sensoren[4] <= 0)||(Sensoren[5] <= 0)) &&(Schritt_Reihenfolge == 5)){ //kann direkt hier rein weil Flanke bei schritt 1 direkt auf 1 gesetzt wird muss ausschliessen dass es mit dem gleichen High hier rein kommt for(int x = 0; x < 6 ; x ++){ if ((Sensoren[x] <= 3)&&(pruefer_sensor[x] == 0)&&(LED_Schritt[5] == 0)){ //zb 1 LED_Schritt[5] = LEDs[x]; Sensor_Schritt6= Sensoren_variable[x]; pruefer_sensor[x] = 1; Schritt_Reihenfolge = 6; Runde2 = 1; x6 = x; Schritt6_vorgekommen = 1; } } } Sensor6_Zustand = analogRead(Sensor_Schritt6); if((Sensor6_Zustand <= 0)&&(LED_ist_wieder_L == 1)&&(LED_ist_wieder_L_2 == 1)&&(LED_ist_wieder_L_3 == 1)&&(LED_ist_wieder_L_4 == 1)&&(LED_ist_wieder_L_5 == 1)){ digitalWrite(LED_Schritt[5],HIGH); if(Schritt6_vorgekommen == 1){ LED_ist_wieder_L_6 = 0; step6_immer_noch_H = 1; } } if(Sensor6_Zustand > 1){ digitalWrite(LED_Schritt[5],LOW); pruefer_sensor[x6] = 0; LED_ist_wieder_L_6 = 1; step6_immer_noch_H = 0; //löschen LED_Schritt[5] = 0; Sensor_Schritt6= 0; Sensor6_Zustand = 0; Schritt6_vorgekommen = 0; } //Ende Schritt 6 ------------------------------------------------------------------------------------------------------------ //Überspringt Schritt falls dieser Sensor in nächster Runde immer noch High ist if((Schritt_Reihenfolge == 5)&&(step6_immer_noch_H == 1)){ Schritt_Reihenfolge = 6; } if((Schritt_Reihenfolge == 4)&&(step5_immer_noch_H == 1)){ Schritt_Reihenfolge = 5; } if((Schritt_Reihenfolge == 3)&&(step4_immer_noch_H == 1)){ Schritt_Reihenfolge = 4; } if((Schritt_Reihenfolge == 2)&&(step3_immer_noch_H == 1)){ Schritt_Reihenfolge = 3; } if((Schritt_Reihenfolge == 1)&&(step2_immer_noch_H == 1)){ Schritt_Reihenfolge = 2; } if((Schritt_Reihenfolge == 6)&&(step1_immer_noch_H == 1)){ Schritt_Reihenfolge = 1; } }
