// timer grundlage für 7,8 hz 'schumann frequenz' // OCR1A = ((CPU frequ/Prescaler * ISR frequ)) -1 isr frqu = gewünschte frequenz void setup() { pinMode(11,OUTPUT); // led pin 50 hz ausgang // start timer setup // timer setup for highly preceised timed measurements cli(); // stop all interrupts // turn on CTC mode TCCR1A = 0; // set entire TCCR1A register to 0 TCCR1B = 0; // same for TCCR1B TCCR1B |= (1 << WGM12); // set CS11 bit for prescaler 8 TCCR1B |= (1 << CS11); // initialize counter value to 0 TCNT1 = 0; // set timer count for 50 hz increments OCR1A = 39999; // = (16*10^6) / (50*8) -1 // enable timer compare interrupt TIMSK1 |= (1 << OCIE1A); sei(); // allow interrupts // end timer setup } ISR(TIMER1_COMPA_vect) { digitalWrite(11,HIGH); delay(15); digitalWrite(11,LOW); } void loop() { // put your main code here, to run repeatedly: }
