APP_Servomotor.elf: file format elf32-littlearm Sections: Idx Name Size VMA LMA File off Algn 0 .text 000005b4 00000400 00000400 00000400 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .relocate 00000000 20000000 20000000 000009b4 2**0 CONTENTS 2 .bss 00000014 20000000 20000000 00010000 2**2 ALLOC 3 .stack 00000404 20000014 20000014 00010000 2**0 ALLOC 4 .debug_info 000043c4 00000000 00000000 000009b4 2**0 CONTENTS, READONLY, DEBUGGING 5 .debug_abbrev 00000363 00000000 00000000 00004d78 2**0 CONTENTS, READONLY, DEBUGGING 6 .debug_loc 0000026f 00000000 00000000 000050db 2**0 CONTENTS, READONLY, DEBUGGING 7 .debug_aranges 00000060 00000000 00000000 0000534a 2**0 CONTENTS, READONLY, DEBUGGING 8 .debug_ranges 00000068 00000000 00000000 000053aa 2**0 CONTENTS, READONLY, DEBUGGING 9 .debug_macro 00009ebc 00000000 00000000 00005412 2**0 CONTENTS, READONLY, DEBUGGING 10 .debug_line 0000076c 00000000 00000000 0000f2ce 2**0 CONTENTS, READONLY, DEBUGGING 11 .debug_str 00041849 00000000 00000000 0000fa3a 2**0 CONTENTS, READONLY, DEBUGGING 12 .comment 00000059 00000000 00000000 00051283 2**0 CONTENTS, READONLY 13 .ARM.attributes 00000032 00000000 00000000 000512dc 2**0 CONTENTS, READONLY 14 .debug_frame 000000e4 00000000 00000000 00051310 2**2 CONTENTS, READONLY, DEBUGGING Disassembly of section .text: 00000400 : 400: 18 04 00 20 31 05 00 00 00 00 00 00 fd 04 00 00 ... 1........... ... 43c: c9 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ ... 474: 79 04 00 00 y... 00000478 : //systick_counter++; } //----------------------------------------------------------------------------- void tc1_ISR(void) { if (TC1->COUNT16.INTFLAG.reg & TC_INTFLAG_MC0) 478: 4b03 ldr r3, [pc, #12] ; (488 ) 47a: 7b9b ldrb r3, [r3, #14] 47c: 06db lsls r3, r3, #27 47e: d502 bpl.n 486 { TC1->COUNT16.INTFLAG.reg = TC_INTFLAG_MC0; 480: 2210 movs r2, #16 482: 4b01 ldr r3, [pc, #4] ; (488 ) 484: 739a strb r2, [r3, #14] } } 486: 4770 bx lr 488: 42001800 .word 0x42001800 0000048c : while (!(SERCOM0->USART.INTFLAG.reg & SERCOM_USART_INTFLAG_DRE)) WDT->CLEAR.reg = 0xA5; SERCOM0->USART.DATA.reg = c; } //----------------------------------------------------------------------------- static void uart_string(char *s) { 48c: b570 push {r4, r5, r6, lr} while (*s) 48e: 7806 ldrb r6, [r0, #0] 490: 2e00 cmp r6, #0 492: d011 beq.n 4b8 while (!(SERCOM0->USART.INTFLAG.reg & SERCOM_USART_INTFLAG_DRE)) WDT->CLEAR.reg = 0xA5; 494: 4a09 ldr r2, [pc, #36] ; (4bc ) 496: 2101 movs r1, #1 498: 4d09 ldr r5, [pc, #36] ; (4c0 ) 49a: 4b0a ldr r3, [pc, #40] ; (4c4 ) 49c: 781c ldrb r4, [r3, #0] uart_send(*s++); 49e: 3001 adds r0, #1 while (!(SERCOM0->USART.INTFLAG.reg & SERCOM_USART_INTFLAG_DRE)) WDT->CLEAR.reg = 0xA5; 4a0: 7e13 ldrb r3, [r2, #24] 4a2: 420b tst r3, r1 4a4: d103 bne.n 4ae 4a6: 722c strb r4, [r5, #8] 4a8: 7e13 ldrb r3, [r2, #24] 4aa: 420b tst r3, r1 4ac: d0fb beq.n 4a6 SERCOM0->USART.DATA.reg = c; 4ae: b2b6 uxth r6, r6 4b0: 8516 strh r6, [r2, #40] ; 0x28 while (*s) 4b2: 7806 ldrb r6, [r0, #0] 4b4: 2e00 cmp r6, #0 4b6: d1f2 bne.n 49e } 4b8: bd70 pop {r4, r5, r6, pc} 4ba: 46c0 nop ; (mov r8, r8) 4bc: 42000800 .word 0x42000800 4c0: 40001000 .word 0x40001000 4c4: 00000698 .word 0x00000698 000004c8 : { 4c8: b510 push {r4, lr} if(systick_tick) { uart_string("[ARM] CPU have panic\r\n"); WDT->CTRL.reg |= WDT_CTRL_ENABLE; while(1); } 4ca: 4b08 ldr r3, [pc, #32] ; (4ec ) 4cc: 681b ldr r3, [r3, #0] 4ce: 2b00 cmp r3, #0 4d0: d103 bne.n 4da systick_tick = 1; 4d2: 2201 movs r2, #1 4d4: 4b05 ldr r3, [pc, #20] ; (4ec ) 4d6: 601a str r2, [r3, #0] } 4d8: bd10 pop {r4, pc} if(systick_tick) { uart_string("[ARM] CPU have panic\r\n"); WDT->CTRL.reg |= WDT_CTRL_ENABLE; while(1); } 4da: 4805 ldr r0, [pc, #20] ; (4f0 ) 4dc: 4b05 ldr r3, [pc, #20] ; (4f4 ) 4de: 4798 blx r3 4e0: 4a05 ldr r2, [pc, #20] ; (4f8 ) 4e2: 7813 ldrb r3, [r2, #0] 4e4: 2102 movs r1, #2 4e6: 430b orrs r3, r1 4e8: 7013 strb r3, [r2, #0] 4ea: e7fe b.n 4ea 4ec: 20000000 .word 0x20000000 4f0: 000007c4 .word 0x000007c4 4f4: 0000048d .word 0x0000048d 4f8: 40001000 .word 0x40001000 000004fc : while (!(SERCOM0->USART.INTFLAG.reg & SERCOM_USART_INTFLAG_RXC)) WDT->CLEAR.reg = 0xA5; return SERCOM0->USART.DATA.reg; } //----------------------------------------------------------------------------- void sysfault_ISR(void) { 4fc: b510 push {r4, lr} uart_string("ERZER\r\n"); 4fe: 4804 ldr r0, [pc, #16] ; (510 ) 500: 4b04 ldr r3, [pc, #16] ; (514 ) 502: 4798 blx r3 WDT->CTRL.reg |= WDT_CTRL_ENABLE; 504: 4a04 ldr r2, [pc, #16] ; (518 ) 506: 7813 ldrb r3, [r2, #0] 508: 2102 movs r1, #2 50a: 430b orrs r3, r1 50c: 7013 strb r3, [r2, #0] 50e: e7fe b.n 50e 510: 000007dc .word 0x000007dc 514: 0000048d .word 0x0000048d 518: 40001000 .word 0x40001000 0000051c : return rueck; } //----------------------------------------------------------------------------- void hint() { 51c: b510 push {r4, lr} //const char text[] = "\r\n\r\n" uart_string("\r\n\r\n" 51e: 4802 ldr r0, [pc, #8] ; (528 ) 520: 4b02 ldr r3, [pc, #8] ; (52c ) 522: 4798 blx r3 "|-h...Show.this.help.....................|\r\n" "|-t...print.test.String..................|\r\n" "|________________________________________|\r\n\r\n\r\n"); //uart_string(text); } 524: bd10 pop {r4, pc} 526: 46c0 nop ; (mov r8, r8) 528: 000007e4 .word 0x000007e4 52c: 0000048d .word 0x0000048d 00000530
: { 530: b5f8 push {r3, r4, r5, r6, r7, lr} PORT->Group[0].DIRSET.reg |= (1 << SERVO_PULSE_PIN); //Pulse Pin Servo (set as Output) 532: 4b48 ldr r3, [pc, #288] ; (654 ) 534: 689a ldr r2, [r3, #8] 536: 2180 movs r1, #128 ; 0x80 538: 0449 lsls r1, r1, #17 53a: 430a orrs r2, r1 53c: 609a str r2, [r3, #8] PORT->Group[0].OUTCLR.bit.OUTCLR = (1 << SERVO_PULSE_PIN); //Pulse Low 53e: 6159 str r1, [r3, #20] PORT->Group[0].DIRSET.reg |= (1 << TCPIN); 540: 689a ldr r2, [r3, #8] 542: 2120 movs r1, #32 544: 430a orrs r2, r1 546: 609a str r2, [r3, #8] WDT->CTRL.reg &=~ WDT_CTRL_ENABLE; 548: 4a43 ldr r2, [pc, #268] ; (658 ) 54a: 7813 ldrb r3, [r2, #0] 54c: 391e subs r1, #30 54e: 438b bics r3, r1 550: 7013 strb r3, [r2, #0] uart_string("[ARM] RUN_APP_Servo\r\n"); 552: 4842 ldr r0, [pc, #264] ; (65c ) 554: 4c42 ldr r4, [pc, #264] ; (660 ) 556: 47a0 blx r4 uart_string(__DATE__); 558: 4842 ldr r0, [pc, #264] ; (664 ) 55a: 47a0 blx r4 uart_string(" : "); 55c: 4842 ldr r0, [pc, #264] ; (668 ) 55e: 47a0 blx r4 uart_string(__TIME__); 560: 4842 ldr r0, [pc, #264] ; (66c ) 562: 47a0 blx r4 uart_string("\r\n\r\n"); 564: 4842 ldr r0, [pc, #264] ; (670 ) 566: 47a0 blx r4 hint(); 568: 4b42 ldr r3, [pc, #264] ; (674 ) 56a: 4798 blx r3 uint32_t pulse_counter = 0; //Counts Pulse from 0 to PULSEWAVE 56c: 2400 movs r4, #0 56e: e00b b.n 588 case '0': WDT->CTRL.reg |= WDT_CTRL_ENABLE; while(1); //WDT reboot automatically, saves flash! __NVIC_SystemReset(); break; 570: 4a39 ldr r2, [pc, #228] ; (658 ) 572: 7813 ldrb r3, [r2, #0] 574: 2102 movs r1, #2 576: 430b orrs r3, r1 578: 7013 strb r3, [r2, #0] 57a: e7fe b.n 57a case 'h': hint(); break; 57c: 4b3d ldr r3, [pc, #244] ; (674 ) 57e: 4798 blx r3 if(systick_tick) 580: 4b3d ldr r3, [pc, #244] ; (678 ) 582: 681b ldr r3, [r3, #0] 584: 2b00 cmp r3, #0 586: d15b bne.n 640 if((SERCOM0->USART.INTFLAG.reg & SERCOM_USART_INTFLAG_RXC)) 588: 4b3c ldr r3, [pc, #240] ; (67c ) 58a: 7e1b ldrb r3, [r3, #24] 58c: 075b lsls r3, r3, #29 58e: d5f7 bpl.n 580 rec = SERCOM0->USART.DATA.reg; 590: 4b3a ldr r3, [pc, #232] ; (67c ) 592: 8d1d ldrh r5, [r3, #40] ; 0x28 594: b2ad uxth r5, r5 switch(rec) 596: 002b movs r3, r5 598: 3b30 subs r3, #48 ; 0x30 59a: b2da uxtb r2, r3 59c: 2a49 cmp r2, #73 ; 0x49 59e: d837 bhi.n 610 5a0: 0093 lsls r3, r2, #2 5a2: 4a37 ldr r2, [pc, #220] ; (680 ) 5a4: 58d3 ldr r3, [r2, r3] 5a6: 469f mov pc, r3 case 't': uart_string("[ARM] TESTER_Servo\r\n"); break; 5a8: 4836 ldr r0, [pc, #216] ; (684 ) 5aa: 4b2d ldr r3, [pc, #180] ; (660 ) 5ac: 4798 blx r3 5ae: e7e7 b.n 580 case 'q': PORT->Group[0].OUTSET.reg |= (1 << SERVO_PULSE_PIN); PORT->Group[0].OUTSET.reg |= (1 << TCPIN); break; 5b0: 4b28 ldr r3, [pc, #160] ; (654 ) 5b2: 6999 ldr r1, [r3, #24] 5b4: 2280 movs r2, #128 ; 0x80 5b6: 0452 lsls r2, r2, #17 5b8: 430a orrs r2, r1 5ba: 619a str r2, [r3, #24] 5bc: 699a ldr r2, [r3, #24] 5be: 2120 movs r1, #32 5c0: 430a orrs r2, r1 5c2: 619a str r2, [r3, #24] 5c4: e7dc b.n 580 case 'w': PORT->Group[0].OUTCLR.bit.OUTCLR = (1 << SERVO_PULSE_PIN); PORT->Group[0].OUTCLR.bit.OUTCLR = (1 << TCPIN); break; 5c6: 4b23 ldr r3, [pc, #140] ; (654 ) 5c8: 2280 movs r2, #128 ; 0x80 5ca: 0452 lsls r2, r2, #17 5cc: 615a str r2, [r3, #20] 5ce: 2220 movs r2, #32 5d0: 615a str r2, [r3, #20] 5d2: e7d5 b.n 580 switch(rec) 5d4: 492c ldr r1, [pc, #176] ; (688 ) case 'y': for(uint32_t x = 0; x < 20000; x++) { PORT->Group[0].OUTSET.reg |= (1 << SERVO_PULSE_PIN); PORT->Group[0].OUTCLR.bit.OUTCLR = (1 << SERVO_PULSE_PIN); } break; 5d6: 4a1f ldr r2, [pc, #124] ; (654 ) 5d8: 2080 movs r0, #128 ; 0x80 5da: 0440 lsls r0, r0, #17 5dc: 0005 movs r5, r0 5de: 6993 ldr r3, [r2, #24] 5e0: 4303 orrs r3, r0 5e2: 6193 str r3, [r2, #24] 5e4: 6155 str r5, [r2, #20] 5e6: 3901 subs r1, #1 5e8: 2900 cmp r1, #0 5ea: d1f8 bne.n 5de 5ec: e7c8 b.n 580 switch(rec) 5ee: 4926 ldr r1, [pc, #152] ; (688 ) case 'x': for(uint32_t x = 0; x < 20000; x++) { PORT->Group[0].OUTSET.reg |= (1 << SERVO_PULSE_PIN); WDT->CLEAR.reg = 0xA5; PORT->Group[0].OUTCLR.bit.OUTCLR = (1 << SERVO_PULSE_PIN); } break; 5f0: 4a18 ldr r2, [pc, #96] ; (654 ) 5f2: 2080 movs r0, #128 ; 0x80 5f4: 0440 lsls r0, r0, #17 5f6: 4f18 ldr r7, [pc, #96] ; (658 ) 5f8: 4b24 ldr r3, [pc, #144] ; (68c ) 5fa: 781e ldrb r6, [r3, #0] 5fc: 0005 movs r5, r0 5fe: 6993 ldr r3, [r2, #24] 600: 4303 orrs r3, r0 602: 6193 str r3, [r2, #24] 604: 723e strb r6, [r7, #8] 606: 6155 str r5, [r2, #20] 608: 3901 subs r1, #1 60a: 2900 cmp r1, #0 60c: d1f7 bne.n 5fe 60e: e7b7 b.n 580 default: uart_string("[ARM] Empfangen: "); uart_send(rec); uart_string("\r\n"); 610: 481f ldr r0, [pc, #124] ; (690 ) 612: 4b13 ldr r3, [pc, #76] ; (660 ) 614: 4798 blx r3 while (!(SERCOM0->USART.INTFLAG.reg & SERCOM_USART_INTFLAG_DRE)) WDT->CLEAR.reg = 0xA5; 616: 4b19 ldr r3, [pc, #100] ; (67c ) 618: 7e1b ldrb r3, [r3, #24] 61a: 07db lsls r3, r3, #31 61c: d408 bmi.n 630 61e: 480e ldr r0, [pc, #56] ; (658 ) 620: 4b1a ldr r3, [pc, #104] ; (68c ) 622: 7819 ldrb r1, [r3, #0] 624: 4a15 ldr r2, [pc, #84] ; (67c ) 626: 2301 movs r3, #1 628: 7201 strb r1, [r0, #8] 62a: 7e16 ldrb r6, [r2, #24] 62c: 421e tst r6, r3 62e: d0fb beq.n 628 630: 23ff movs r3, #255 ; 0xff 632: 401d ands r5, r3 SERCOM0->USART.DATA.reg = c; 634: 4b11 ldr r3, [pc, #68] ; (67c ) 636: 851d strh r5, [r3, #40] ; 0x28 default: uart_string("[ARM] Empfangen: "); uart_send(rec); uart_string("\r\n"); 638: 4816 ldr r0, [pc, #88] ; (694 ) 63a: 4b09 ldr r3, [pc, #36] ; (660 ) 63c: 4798 blx r3 63e: e79f b.n 580 if(pulse_counter == PULSEWAVE) 640: 2cc8 cmp r4, #200 ; 0xc8 642: d004 beq.n 64e pulse_counter++; 644: 3401 adds r4, #1 systick_tick = 0; 646: 2200 movs r2, #0 648: 4b0b ldr r3, [pc, #44] ; (678 ) 64a: 601a str r2, [r3, #0] 64c: e79c b.n 588 pulse_counter = 0; 64e: 2400 movs r4, #0 650: e7f8 b.n 644 652: 46c0 nop ; (mov r8, r8) 654: 41004400 .word 0x41004400 658: 40001000 .word 0x40001000 65c: 0000094c .word 0x0000094c 660: 0000048d .word 0x0000048d 664: 00000964 .word 0x00000964 668: 00000970 .word 0x00000970 66c: 00000974 .word 0x00000974 670: 00000980 .word 0x00000980 674: 0000051d .word 0x0000051d 678: 20000000 .word 0x20000000 67c: 42000800 .word 0x42000800 680: 0000069c .word 0x0000069c 684: 00000988 .word 0x00000988 688: 00004e20 .word 0x00004e20 68c: 00000698 .word 0x00000698 690: 000009a0 .word 0x000009a0 694: 000007d8 .word 0x000007d8 698: 000000a5 .word 0x000000a5 69c: 00000570 .word 0x00000570 6a0: 00000580 .word 0x00000580 6a4: 00000580 .word 0x00000580 6a8: 00000610 .word 0x00000610 6ac: 00000610 .word 0x00000610 6b0: 00000610 .word 0x00000610 6b4: 00000610 .word 0x00000610 6b8: 00000610 .word 0x00000610 6bc: 00000610 .word 0x00000610 6c0: 00000610 .word 0x00000610 6c4: 00000610 .word 0x00000610 6c8: 00000610 .word 0x00000610 6cc: 00000610 .word 0x00000610 6d0: 00000610 .word 0x00000610 6d4: 00000610 .word 0x00000610 6d8: 00000610 .word 0x00000610 6dc: 00000610 .word 0x00000610 6e0: 00000610 .word 0x00000610 6e4: 00000610 .word 0x00000610 6e8: 00000610 .word 0x00000610 6ec: 00000610 .word 0x00000610 6f0: 00000610 .word 0x00000610 6f4: 00000610 .word 0x00000610 6f8: 00000610 .word 0x00000610 6fc: 00000610 .word 0x00000610 700: 00000610 .word 0x00000610 704: 00000610 .word 0x00000610 708: 00000610 .word 0x00000610 70c: 00000610 .word 0x00000610 710: 00000610 .word 0x00000610 714: 00000610 .word 0x00000610 718: 00000610 .word 0x00000610 71c: 00000610 .word 0x00000610 720: 00000610 .word 0x00000610 724: 00000610 .word 0x00000610 728: 00000610 .word 0x00000610 72c: 00000610 .word 0x00000610 730: 00000610 .word 0x00000610 734: 00000610 .word 0x00000610 738: 00000610 .word 0x00000610 73c: 00000610 .word 0x00000610 740: 00000610 .word 0x00000610 744: 00000610 .word 0x00000610 748: 00000610 .word 0x00000610 74c: 00000610 .word 0x00000610 750: 00000610 .word 0x00000610 754: 00000610 .word 0x00000610 758: 00000610 .word 0x00000610 75c: 00000610 .word 0x00000610 760: 00000610 .word 0x00000610 764: 00000610 .word 0x00000610 768: 00000610 .word 0x00000610 76c: 00000610 .word 0x00000610 770: 00000610 .word 0x00000610 774: 00000610 .word 0x00000610 778: 00000610 .word 0x00000610 77c: 0000057c .word 0x0000057c 780: 00000610 .word 0x00000610 784: 00000610 .word 0x00000610 788: 00000610 .word 0x00000610 78c: 00000610 .word 0x00000610 790: 00000610 .word 0x00000610 794: 00000610 .word 0x00000610 798: 00000610 .word 0x00000610 79c: 00000610 .word 0x00000610 7a0: 000005b0 .word 0x000005b0 7a4: 00000610 .word 0x00000610 7a8: 00000610 .word 0x00000610 7ac: 000005a8 .word 0x000005a8 7b0: 00000610 .word 0x00000610 7b4: 00000610 .word 0x00000610 7b8: 000005c6 .word 0x000005c6 7bc: 000005ee .word 0x000005ee 7c0: 000005d4 .word 0x000005d4 7c4: 4d52415b .word 0x4d52415b 7c8: 5043205d .word 0x5043205d 7cc: 61682055 .word 0x61682055 7d0: 70206576 .word 0x70206576 7d4: 63696e61 .word 0x63696e61 7d8: 00000a0d .word 0x00000a0d 7dc: 455a5245 .word 0x455a5245 7e0: 000a0d52 .word 0x000a0d52 7e4: 0a0d0a0d .word 0x0a0d0a0d 7e8: 5f5f5f20 .word 0x5f5f5f20 7ec: 5f5f5f5f .word 0x5f5f5f5f 7f0: 5f5f5f5f .word 0x5f5f5f5f 7f4: 5f5f5f5f .word 0x5f5f5f5f 7f8: 5f5f5f5f .word 0x5f5f5f5f 7fc: 5f5f5f5f .word 0x5f5f5f5f 800: 5f5f5f5f .word 0x5f5f5f5f 804: 5f5f5f5f .word 0x5f5f5f5f 808: 5f5f5f5f .word 0x5f5f5f5f 80c: 5f5f5f5f .word 0x5f5f5f5f 810: 7c0a0d5f .word 0x7c0a0d5f 814: 5050412e .word 0x5050412e 818: 2e79622e .word 0x2e79622e 81c: 2e5a5245 .word 0x2e5a5245 820: 2e2e2e2e .word 0x2e2e2e2e 824: 2e2e2e2e .word 0x2e2e2e2e 828: 2e2e2e2e .word 0x2e2e2e2e 82c: 2e2e2e2e .word 0x2e2e2e2e 830: 2e2e2e2e .word 0x2e2e2e2e 834: 562e2e2e .word 0x562e2e2e 838: 2e302e31 .word 0x2e302e31 83c: 7c0a0d7c .word 0x7c0a0d7c 840: 5f5f5f5f .word 0x5f5f5f5f 844: 5f5f5f5f .word 0x5f5f5f5f 848: 5f5f5f5f .word 0x5f5f5f5f 84c: 5f5f5f5f .word 0x5f5f5f5f 850: 5f5f5f5f .word 0x5f5f5f5f 854: 5f5f5f5f .word 0x5f5f5f5f 858: 5f5f5f5f .word 0x5f5f5f5f 85c: 5f5f5f5f .word 0x5f5f5f5f 860: 5f5f5f5f .word 0x5f5f5f5f 864: 5f5f5f5f .word 0x5f5f5f5f 868: 7c0a0d7c .word 0x7c0a0d7c 86c: 2e2e2e2e .word 0x2e2e2e2e 870: 2e2e2e2e .word 0x2e2e2e2e 874: 2e2e2e2e .word 0x2e2e2e2e 878: 2e2e2e2e .word 0x2e2e2e2e 87c: 2e2e2e2e .word 0x2e2e2e2e 880: 2e2e2e2e .word 0x2e2e2e2e 884: 2e2e2e2e .word 0x2e2e2e2e 888: 2e2e2e2e .word 0x2e2e2e2e 88c: 2e2e2e2e .word 0x2e2e2e2e 890: 2e2e2e2e .word 0x2e2e2e2e 894: 7c0a0d7c .word 0x7c0a0d7c 898: 2e2e302d .word 0x2e2e302d 89c: 7365522e .word 0x7365522e 8a0: 74726174 .word 0x74726174 8a4: 6f6f422f .word 0x6f6f422f 8a8: 616f6c74 .word 0x616f6c74 8ac: 2e726564 .word 0x2e726564 8b0: 2e2e2e2e .word 0x2e2e2e2e 8b4: 2e2e2e2e .word 0x2e2e2e2e 8b8: 2e2e2e2e .word 0x2e2e2e2e 8bc: 2e2e2e2e .word 0x2e2e2e2e 8c0: 7c0a0d7c .word 0x7c0a0d7c 8c4: 2e2e682d .word 0x2e2e682d 8c8: 6f68532e .word 0x6f68532e 8cc: 68742e77 .word 0x68742e77 8d0: 682e7369 .word 0x682e7369 8d4: 2e706c65 .word 0x2e706c65 8d8: 2e2e2e2e .word 0x2e2e2e2e 8dc: 2e2e2e2e .word 0x2e2e2e2e 8e0: 2e2e2e2e .word 0x2e2e2e2e 8e4: 2e2e2e2e .word 0x2e2e2e2e 8e8: 2e2e2e2e .word 0x2e2e2e2e 8ec: 7c0a0d7c .word 0x7c0a0d7c 8f0: 2e2e742d .word 0x2e2e742d 8f4: 6972702e .word 0x6972702e 8f8: 742e746e .word 0x742e746e 8fc: 2e747365 .word 0x2e747365 900: 69727453 .word 0x69727453 904: 2e2e676e .word 0x2e2e676e 908: 2e2e2e2e .word 0x2e2e2e2e 90c: 2e2e2e2e .word 0x2e2e2e2e 910: 2e2e2e2e .word 0x2e2e2e2e 914: 2e2e2e2e .word 0x2e2e2e2e 918: 7c0a0d7c .word 0x7c0a0d7c 91c: 5f5f5f5f .word 0x5f5f5f5f 920: 5f5f5f5f .word 0x5f5f5f5f 924: 5f5f5f5f .word 0x5f5f5f5f 928: 5f5f5f5f .word 0x5f5f5f5f 92c: 5f5f5f5f .word 0x5f5f5f5f 930: 5f5f5f5f .word 0x5f5f5f5f 934: 5f5f5f5f .word 0x5f5f5f5f 938: 5f5f5f5f .word 0x5f5f5f5f 93c: 5f5f5f5f .word 0x5f5f5f5f 940: 5f5f5f5f .word 0x5f5f5f5f 944: 0d0a0d7c .word 0x0d0a0d7c 948: 000a0d0a .word 0x000a0d0a 94c: 4d52415b .word 0x4d52415b 950: 5552205d .word 0x5552205d 954: 50415f4e .word 0x50415f4e 958: 65535f50 .word 0x65535f50 95c: 0d6f7672 .word 0x0d6f7672 960: 0000000a .word 0x0000000a 964: 20727041 .word 0x20727041 968: 32203131 .word 0x32203131 96c: 00323230 .word 0x00323230 970: 00203a20 .word 0x00203a20 974: 313a3132 .word 0x313a3132 978: 33313a38 .word 0x33313a38 97c: 00000000 .word 0x00000000 980: 0a0d0a0d .word 0x0a0d0a0d 984: 00000000 .word 0x00000000 988: 4d52415b .word 0x4d52415b 98c: 4554205d .word 0x4554205d 990: 52455453 .word 0x52455453 994: 7265535f .word 0x7265535f 998: 0a0d6f76 .word 0x0a0d6f76 99c: 00000000 .word 0x00000000 9a0: 4d52415b .word 0x4d52415b 9a4: 6d45205d .word 0x6d45205d 9a8: 6e616670 .word 0x6e616670 9ac: 3a6e6567 .word 0x3a6e6567 9b0: 00000020 .word 0x00000020
