git clone https://github.com/tasmota/docker-tasmota cd docker-tasmota set USE_STABLE=1 in compile.sh ./compile.sh tasmota-sensors tasmota-EN` docker build -t docker-tasmota . cd ../Tasmota git clone https://github.com/arendst/Tasmota.git docker run -ti --rm -v $(pwd)/Tasmota:/tasmota -u $UID:$GID docker-tasmota -e tasmota-EN >docker run -ti --rm -v $(pwd)/Tasmota:/tasmota -u $UID:$GID docker-tasmota -e tasmota-EN Compiling Tasmota... Error: Unknown environment names 'tasmota-EN'. Valid names are 'tasmota-RO, tasmota32s2, tasmota32_16M, tasmota-DE, tasmota32-HU, tasmota32solo1, tasmota32_8M, tasmota-PT, tasmota32-IT, tasmota-CN, tasmota-TW, tasmota32-SE, tasmota32_base, tasmota32-odroidgo, tasmota-sensors, tasmota-FR, tasmota-AF, tasmota-HE, tasmota-SE, tasmota32-bluetooth, tasmota32-AF, tasmota32-SK, tasmota-HU, tasmota32-HE, tasmota32-TR, tasmota32-BG, tasmota-FY, tasmota-KO, tasmota32-RO, tasmota-TR, tasmota32-PT, tasmota-PL, tasmota32c3, tasmota-knx, tasmota32-lvgl, tasmota-VN, tasmota32-NL, tasmota4M, tasmota32-CZ, tasmota-BG, tasmota-minimal, tasmota-RU, tasmota-zbbridge, tasmota32-ir, tasmota32-CN, tasmota-NL, tasmota-GR, tasmota32-ES, tasmota32-KO, tasmota32, tasmota-ES, tasmota-UK, tasmota32-core2, tasmota-zigbee, tasmota-lite, tasmota-display, tasmota-ir, tasmota32-BR, tasmota32-PL, tasmota32-RU, tasmota32-TW, tasmota32-FR, tasmota, tasmota32-VN, tasmota32-webcam, tasmota32-display, tasmota32-GR, tasmota-IT, tasmota32-FY, tasmota-SK, tasmota32-DE, tasmota32-UK, tasmota-BR, tasmota-CZ' All done! Find your builds in Tasmota/build_output/firmware/ docker run -ti --rm -v $(pwd)/Tasmota:/tasmota -u $UID:$GID docker-tasmota -e tasmota32-DE >docker run -ti --rm -v $(pwd)/Tasmota:/tasmota -u $UID:$GID docker-tasmota -e tasmota32-DE Compiling Tasmota... Processing tasmota32-DE (framework: arduino; platform: https://github.com/tasmota/platform-espressif32/releases/download/v2.0.3rc1/platform-espressif32-2.0.3.zip; board: esp32_4M) ------------------------------------------------------------------------------------------------------------------------------------------------------------------------ Platform Manager: Installing https://github.com/tasmota/platform-espressif32/releases/download/v2.0.3rc1/platform-espressif32-2.0.3.zip Downloading [####################################] 100% Unpacking [####################################] 100% Platform Manager: espressif32 @ 2.0.3 has been installed! The platform 'https://github.com/tasmota/platform-espressif32/releases/download/v2.0.3rc1/platform-espressif32-2.0.3.zip' has been successfully installed! The rest of the packages will be installed later depending on your build environment. Tool Manager: Installing espressif/toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3 Downloading [####################################] 100% Unpacking [####################################] 100% Tool Manager: toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3 has been installed! Tool Manager: Installing https://github.com/Jason2866/esp32-arduino-lib-builder/releases/download/803/framework-arduinoespressif32-v4.4_dev-40d126bfd1.tar.gz Downloading [####################################] 100% Unpacking [####################################] 100% Tool Manager: framework-arduinoespressif32 @ 2.0.3 has been installed! Tool Manager: Installing https://github.com/tasmota/esptool/releases/download/v3.3/esptool-3.3.zip Downloading [####################################] 100% Unpacking [####################################] 100% Tool Manager: tool-esptoolpy @ 1.30300.220323 has been installed! Tool Manager: Installing platformio/tool-mkspiffs @ ~2.230.0 Downloading [####################################] 100% Unpacking [####################################] 100% Tool Manager: tool-mkspiffs @ 2.230.0 has been installed! Tool Manager: Installing platformio/tool-mklittlefs @ ~1.203.0 Downloading [####################################] 100% Unpacking [####################################] 100% Tool Manager: tool-mklittlefs @ 1.203.210628 has been installed! Verbose mode can be enabled via `-v, --verbose` option FILESYSTEM littlefs CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32_4M.html PLATFORM: Espressif 32 (2.0.3) > Espressif Generic ESP32 4M Flash, Tasmota 1856k Code/OTA, 320k FS HARDWARE: ESP32 80MHz, 320KB RAM, 4MB Flash DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa) PACKAGES: - framework-arduinoespressif32 2.0.3 - tool-esptoolpy 1.30300.220323 (3.3.0) - tool-mklittlefs 1.203.210628 (2.3) - tool-mkspiffs 2.230.0 (2.30) - toolchain-xtensa-esp32 8.4.0+2021r2-patch3 Converting tasmota.ino LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf LDF Modes: Finder ~ chain, Compatibility ~ strict Found 116 compatible libraries Scanning dependencies... Dependency Graph |-- 1.0.0 | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 |-- 1.0 | |-- 2.0.0 | |-- 0.6 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 |-- 1.0.0 | |-- 2.0.0 |-- 2.0.0 | |-- 2.0.0 | |-- 2.0.0 | |-- 8.2.0 | | |-- 2.10.4 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 | |-- 1.0 | | |-- 7.0 | | |-- 8.2.0 | | | |-- 2.10.4 | | |-- 1.0 | | | |-- 7.0 | | | |-- 1.0 | | | | |-- 7.0 | | | |-- 1.9.5 | | | | |-- 0.0.2 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | | | |-- 2.0.0 | | | | | | | |-- 2.0.0 | | | | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 1.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- | | | |-- 8.2.0 | | | | |-- 2.10.4 | | | |-- 1.0 | | | | |-- 2.0.0 | | | | |-- 1.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 0.9 | | | |-- 2.0.0 | | | |-- 1.0 | | |-- 1.0 | | | |-- 7.0 | | |-- 7.0 | | | |-- 8.2.0 | | | | |-- 2.10.4 |-- 1.0.1 | |-- 2.0.0 |-- 1.1.2 | |-- 2.0.0 |-- 1.2.0 | |-- 2.0.0 |-- 1.0.0 | |-- 1.11.0 | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 |-- 1.3.1 | |-- 2.0.0 |-- 1.9.5 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | |-- 2.0.0 | |-- 1.0 | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 |-- | |-- 2.0.0 |-- | |-- 2.0.0 |-- 2.0.0 | |-- 2.0.0 |-- 2.0.0 |-- 1.0 | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | |-- 1.0 | | |-- 2.0.0 | | |-- 0.6 | | |-- 0.0.2 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 |-- | |-- 2.0.0 |-- 1.1.3 |-- | |-- | | |-- 2.0.0 |-- 0.0.1 | |-- 2.0.0 |-- | |-- 2.0.0 |-- 1.3.6 |-- 0.9.0 |-- 1.0.0 |-- 1.1.0 |-- 1.0 |-- 1.0 |-- 1.0.2 | |-- 2.0.0 |-- 1.0.1 | |-- 2.0.0 |-- 1.0 | |-- 2.0.0 | |-- 1.0 |-- 1.0 | |-- 7.0 | |-- 1.0 | | |-- 7.0 | |-- 1.9.5 | | |-- 0.0.2 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | |-- 1.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | |-- | |-- 8.2.0 | | |-- 2.10.4 | |-- 1.0 | | |-- 2.0.0 | | |-- 1.0 | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | |-- 0.9 | |-- 2.0.0 | |-- 1.0 |-- 7.0 |-- 1.0 | |-- 7.0 | |-- 1.0 | | |-- 7.0 |-- 1.0 | |-- 7.0 |-- 1.0.0 |-- |-- 0.0.2 | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 |-- 1.0 | |-- 7.0 | |-- 8.2.0 | | |-- 2.10.4 | |-- 1.0 | | |-- 7.0 | | |-- 1.0 | | | |-- 7.0 | | |-- 1.9.5 | | | |-- 0.0.2 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 1.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- | | |-- 8.2.0 | | | |-- 2.10.4 | | |-- 1.0 | | | |-- 2.0.0 | | | |-- 1.0 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 0.9 | | |-- 2.0.0 | | |-- 1.0 | |-- 1.0 | | |-- 7.0 | |-- 7.0 | | |-- 8.2.0 | | | |-- 2.10.4 |-- 8.2.0 | |-- 2.10.4 |-- | |-- 2.0.0 |-- 0.9 |-- 7.0 | |-- 8.2.0 | | |-- 2.10.4 |-- 0.0.1 |-- 2.0.4 | |-- 3.5.0 | | |-- 0.0.2 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 |-- 1.5.6 | |-- 2.0.0 |-- 1.1.6 | |-- 1.5.6 | | |-- 2.0.0 | |-- 2.0.0 |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 |-- 1.3.0 | |-- 1.5.6 | | |-- 2.0.0 | |-- 2.0.0 | |-- 2.0.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 |-- 1.2.0 | |-- 1.5.6 | | |-- 2.0.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 |-- | |-- 2.0.0 |-- 0.9.5 | |-- 1.5.6 | | |-- 2.0.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | |-- 2.0.0 |-- 0.1.6 | |-- 2.0.0 | |-- 1.0.0 |-- 1.4.3 |-- 2.0.0 | |-- 2.0.0 |-- 1.0.1 | |-- 1.9.5 | | |-- 0.0.2 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | |-- 1.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 |-- 1.2.0 | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 | |-- 2.0.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 | | |-- 2.0.0 |-- 2.0.0 | |-- 2.0.0 |-- 1.0.0 | |-- 2.0.0 |-- | |-- 2.0.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 |-- | |-- 2.0.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 |-- 1.0.0 | |-- 2.0.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 |-- 2.8.2 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 |-- 1.0 |-- 1.1 |-- 1.0 |-- 1.0.0 | |-- 2.0.0 | |-- 2.0.0 |-- 1.0.6 |-- |-- | |-- 2.0.0 |-- 2.0.0 | |-- 2.0.0 |-- 1.4.7 | |-- 2.0.0 |-- | |-- 2.0.0 |-- | |-- 2.0.0 |-- 2.6.7 | |-- 2.0.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 |-- 1.9.1 |-- 2.3.2 |-- 2.8 |-- 1.0.2 | |-- 2.0.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 |-- 1.0.0 |-- 1.3.3 | |-- 2.0.0 |-- 1.0 |-- 2.0.0 | |-- 2.0.0 | |-- 2.0.0 |-- 2.0.0 | |-- 2.0.0 |-- 2.0.0 |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 | |-- 2.0.0 |-- 1.7.0 |-- 3.4.0 | |-- 3.5.0 | | |-- 0.0.2 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 |-- 3.5.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 |-- 2.0.0 |-- 2.0.10 | |-- 2.0.0 |-- 2.0.0 | |-- 2.0.0 |-- 2.0.0 |-- | |-- 2.0.0 |-- 1.2.0 | |-- 2.0.0 |-- 1.1.1 |-- |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 |-- 1.0.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 |-- 1.0 | |-- 1.5.6 | | |-- 2.0.0 | |-- 2.0.0 |-- 0.5.2 | |-- 2.0.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | |-- 2.0.0 |-- 1.0.0 |-- 0.6 |-- 0.1 | |-- 1.5.6 | | |-- 2.0.0 | |-- 2.0.0 | |-- 2.0.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 2.0.0 | | |-- 2.0.0 | |-- 0.0.2 | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | |-- 2.0.0 | | | | | |-- 2.0.0 | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 | | | |-- 2.0.0 | |-- 1.0 | | |-- 1.0 | | | |-- 1.5.6 | | | | |-- 2.0.0 | | | |-- 2.0.0 | | |-- 2.0.0 |-- 2.0.0 | |-- 2.0.0 | |-- 2.0.0 Building in release mode Use manually specified: COM5 Compiling .pio/build/tasmota32-DE/src/homekit.c.o Compiling .pio/build/tasmota32-DE/src/tasmota.ino.cpp.o Compiling .pio/build/tasmota32-DE/src/xsns_62_esp32_mi_homekit.c.o Generating partitions .pio/build/tasmota32-DE/partitions.bin Compiling .pio/build/tasmota32-DE/lib496/FS/FS.cpp.o Compiling .pio/build/tasmota32-DE/lib496/FS/vfs_api.cpp.o Compiling .pio/build/tasmota32-DE/lib8ab/LittleFS/LittleFS.cpp.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/byte_convert.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_acc.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_bct.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_char.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_controllers.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_database.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_ip_services.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_keystore.c.o Archiving .pio/build/tasmota32-DE/lib496/libFS.a Indexing .pio/build/tasmota32-DE/lib496/libFS.a Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_main.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_mdns.c.o Archiving .pio/build/tasmota32-DE/lib8ab/libLittleFS.a Indexing .pio/build/tasmota32-DE/lib8ab/libLittleFS.a Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_network_io.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_pair_common.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_pair_setup.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_pair_verify.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_pairings.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_serv.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_setup_payload.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_hap_wifi.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_mfi_aes.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_mfi_base64.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_mfi_debug.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_mfi_dummy.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_mfi_rand.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/esp_mfi_sha.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hap_apple_chars.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hap_apple_servs.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hap_platform_httpd.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hap_platform_keystore.cpp.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hap_platform_memory.cpp.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hap_platform_os.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hexbin.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hexdump.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hkdf.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/hmac.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/json_generator.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/json_parser.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/mu_srp.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/port/bignum_ESP32.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/port/bignum_ESP32_C3.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/port/esp_bignum.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/sha1.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/sha224-256.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/sha384-512.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/shatest.c.o Compiling .pio/build/tasmota32-DE/lib880/ESP32-HomeKit/usha.c.o Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFi.cpp.o Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFiAP.cpp.o Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFiClient.cpp.o Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFiGeneric.cpp.o Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFiMulti.cpp.o Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFiSTA.cpp.o Archiving .pio/build/tasmota32-DE/lib880/libESP32-HomeKit.a Indexing .pio/build/tasmota32-DE/lib880/libESP32-HomeKit.a Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFiScan.cpp.o Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFiServer.cpp.o Compiling .pio/build/tasmota32-DE/liba7a/WiFi/WiFiUdp.cpp.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/aead/ccm.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/aead/eax.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/aead/gcm.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/ccopy.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/dec16be.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/dec16le.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/dec32be.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/dec32le.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/dec64be.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/dec64le.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/enc16be.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/enc16le.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/enc32be.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/enc32le.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/enc64be.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/enc64le.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/pemdec.c.o Archiving .pio/build/tasmota32-DE/liba7a/libWiFi.a Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/codec/pemenc.c.o Indexing .pio/build/tasmota32-DE/liba7a/libWiFi.a Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_all_m15.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_c25519_m15.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_curve25519.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_default.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_keygen.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_p256_m15.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_prime_i15.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_pubkey.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_secp256r1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_secp384r1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ec_secp521r1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_atr.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_default_sign_asn1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_default_sign_raw.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_default_vrfy_asn1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_default_vrfy_raw.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_i15_bits.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_i15_sign_asn1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_i15_sign_raw.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_i15_vrfy_asn1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_i15_vrfy_raw.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/dig_oid.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ec/ecdsa_rta.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/dig_size.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/ghash_ctmul.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/ghash_ctmul32.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/ghash_ctmul64.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/ghash_pclmul.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/md5.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/md5sha1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/mgf1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/multihash.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/sha1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/sha2big.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/hash/sha2small.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_add.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_bitlen.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_decmod.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_decode.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_encode.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_decred.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_fmont.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_iszero.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_moddiv.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_modpow.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_modpow2.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_montmul.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_mulacc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_muladd.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_ninv15.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_reduce.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_rshift.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_sub.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/int/i15_tmont.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/kdf/hkdf.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/kdf/shake.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/mac/hmac.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/mac/hmac_ct.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rand/aesctr_drbg.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rand/hmac_drbg.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rand/sysrng.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_keygen.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_modulus.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_oaep_decrypt.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_oaep_encrypt.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_pkcs1_sign.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_pkcs1_vrfy.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_priv.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_privexp.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_pss_sign.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_pss_vrfy.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_pub.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_default_pubexp.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_keygen.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_modulus.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_oaep_decrypt.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_oaep_encrypt.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_pkcs1_sign.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_pkcs1_vrfy.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_priv.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_privexp.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_pss_sign.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_pss_vrfy.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_pub.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_i15_pubexp.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_oaep_pad.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_oaep_unpad.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_pkcs1_sig_pad.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_pkcs1_sig_unpad.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_pss_sig_pad.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_pss_sig_unpad.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/rsa/rsa_ssl_decrypt.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/settings.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/prf.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/prf_md5sha1.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/prf_sha256.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/prf_sha384.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_ccert_single_ec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_ccert_single_rsa.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_client.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_client_default_rsapub.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_client_full.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine_default_aescbc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine_default_aesccm.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine_default_aesgcm.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine_default_chapol.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine_default_descbc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine_default_ec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine_default_ecdsa.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_engine_default_rsavrfy.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_hashes.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_hs_client.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_hs_server.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_io.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_keyexport.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_lru.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_rec_cbc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_rec_ccm.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_rec_chapol.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_rec_gcm.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_scert_single_ec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/ssl/ssl_scert_single_rsa.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_big_cbcdec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_big_cbcenc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_big_ctr.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_big_ctrcbc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_big_dec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_big_enc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_common.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct64.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct64_cbcdec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct64_cbcenc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct64_ctr.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct64_ctrcbc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct64_dec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct64_enc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct_cbcdec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct_cbcenc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct_ctr.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct_ctrcbc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct_dec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_ct_enc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_small_cbcdec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_small_cbcenc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_small_ctr.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_small_ctrcbc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_small_dec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/aes_small_enc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/chacha20_ct.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/chacha20_sse2.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/des_ct.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/des_ct_cbcdec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/des_ct_cbcenc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/des_support.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/des_tab.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/des_tab_cbcdec.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/des_tab_cbcenc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/poly1305_ctmul.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/poly1305_ctmul32.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/poly1305_ctmulq.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/symcipher/poly1305_i15.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/asn1enc.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/encode_ec_pk8der.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/encode_ec_rawder.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/encode_rsa_pk8der.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/encode_rsa_rawder.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/pkey_decoder.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/skey_decoder.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/x509_decoder.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/x509_knownkey.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/x509_minimal.c.o Compiling .pio/build/tasmota32-DE/lib417/bearssl-esp8266/x509/x509_minimal_full.c.o Compiling .pio/build/tasmota32-DE/lib632/WiFiClientSecure/WiFiClientSecure.cpp.o Compiling .pio/build/tasmota32-DE/lib632/WiFiClientSecure/esp_crt_bundle.c.o Archiving .pio/build/tasmota32-DE/lib417/libbearssl-esp8266.a Compiling .pio/build/tasmota32-DE/lib632/WiFiClientSecure/ssl_client.cpp.o Indexing .pio/build/tasmota32-DE/lib417/libbearssl-esp8266.a Compiling .pio/build/tasmota32-DE/liba6f/HTTPClient/HTTPClient.cpp.o Compiling .pio/build/tasmota32-DE/lib471/WebServer/Parsing.cpp.o Compiling .pio/build/tasmota32-DE/lib471/WebServer/WebServer.cpp.o Compiling .pio/build/tasmota32-DE/lib471/WebServer/detail/mimetable.cpp.o Compiling .pio/build/tasmota32-DE/libaa8/Update/HttpsOTAUpdate.cpp.o Compiling .pio/build/tasmota32-DE/libaa8/Update/Updater.cpp.o Compiling .pio/build/tasmota32-DE/lib529/HTTPUpdate/HTTPUpdate.cpp.o Archiving .pio/build/tasmota32-DE/lib632/libWiFiClientSecure.a Indexing .pio/build/tasmota32-DE/lib632/libWiFiClientSecure.a Compiling .pio/build/tasmota32-DE/lib9b8/ESPmDNS/ESPmDNS.cpp.o Compiling .pio/build/tasmota32-DE/lib97e/ESP32-to-ESP8266-compat/ESP32Wifi.cpp.o Archiving .pio/build/tasmota32-DE/lib471/libWebServer.a Archiving .pio/build/tasmota32-DE/libaa8/libUpdate.a Indexing .pio/build/tasmota32-DE/lib471/libWebServer.a Indexing .pio/build/tasmota32-DE/libaa8/libUpdate.a Archiving .pio/build/tasmota32-DE/liba6f/libHTTPClient.a Indexing .pio/build/tasmota32-DE/liba6f/libHTTPClient.a Compiling .pio/build/tasmota32-DE/lib97e/ESP32-to-ESP8266-compat/esp8266toEsp32.cpp.o Compiling .pio/build/tasmota32-DE/libd6f/tls_mini/StackThunk_light.cpp.o Compiling .pio/build/tasmota32-DE/libd6f/tls_mini/WiFiClientSecureLightBearSSL.cpp.o Compiling .pio/build/tasmota32-DE/lib6d5/Wire/Wire.cpp.o Compiling .pio/build/tasmota32-DE/lib5ed/Adafruit_CCS811-1.0.0.14/Adafruit_CCS811.cpp.o Archiving .pio/build/tasmota32-DE/lib97e/libESP32-to-ESP8266-compat.a Archiving .pio/build/tasmota32-DE/lib529/libHTTPUpdate.a Indexing .pio/build/tasmota32-DE/lib97e/libESP32-to-ESP8266-compat.a Archiving .pio/build/tasmota32-DE/lib9b8/libESPmDNS.a Indexing .pio/build/tasmota32-DE/lib529/libHTTPUpdate.a Indexing .pio/build/tasmota32-DE/lib9b8/libESPmDNS.a Compiling .pio/build/tasmota32-DE/lib709/Ticker/Ticker.cpp.o Compiling .pio/build/tasmota32-DE/libb38/freetype/base/ftbase.c.o Archiving .pio/build/tasmota32-DE/lib709/libTicker.a Indexing .pio/build/tasmota32-DE/lib709/libTicker.a Compiling .pio/build/tasmota32-DE/libb38/freetype/base/ftbbox.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/base/ftbdf.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/base/ftbitmap.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/base/ftdebug.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/base/ftglyph.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/base/ftinit.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/base/ftsystem.c.o Archiving .pio/build/tasmota32-DE/lib6d5/libWire.a Indexing .pio/build/tasmota32-DE/lib6d5/libWire.a Compiling .pio/build/tasmota32-DE/libb38/freetype/bdf/bdf.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/cache/ftcache.c.o Archiving .pio/build/tasmota32-DE/lib5ed/libAdafruit_CCS811-1.0.0.14.a Indexing .pio/build/tasmota32-DE/lib5ed/libAdafruit_CCS811-1.0.0.14.a Compiling .pio/build/tasmota32-DE/libb38/freetype/cff/cff.c.o Archiving .pio/build/tasmota32-DE/libd6f/libtls_mini.a Indexing .pio/build/tasmota32-DE/libd6f/libtls_mini.a Compiling .pio/build/tasmota32-DE/libb38/freetype/sfnt/sfnt.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/smooth/smooth.c.o Compiling .pio/build/tasmota32-DE/libb38/freetype/truetype/truetype.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_disp.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_event.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_group.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_indev.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_indev_scroll.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_obj.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_obj_class.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_obj_draw.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_obj_pos.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_obj_scroll.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_obj_style.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_obj_style_gen.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_obj_tree.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_refr.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/core/lv_theme.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_draw.c.o Archiving .pio/build/tasmota32-DE/libb38/libfreetype.a Indexing .pio/build/tasmota32-DE/libb38/libfreetype.a Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_draw_arc.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_draw_img.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_draw_label.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_draw_line.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_draw_mask.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_draw_rect.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_draw_triangle.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_img_buf.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_img_cache.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/lv_img_decoder.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/nxp_pxp/lv_gpu_nxp_pxp.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/nxp_pxp/lv_gpu_nxp_pxp_osa.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/nxp_vglite/lv_gpu_nxp_vglite.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_bg.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_arc.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_composite.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_img.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_label.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_line.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_mask.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_polygon.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_rect.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_stack_blur.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_texture_cache.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sdl/lv_draw_sdl_utils.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/stm32_dma2d/lv_gpu_stm32_dma2d.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_arc.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_blend.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_dither.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_gradient.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_img.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_letter.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_line.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_polygon.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/draw/sw/lv_draw_sw_rect.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/layouts/flex/lv_flex.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/layouts/grid/lv_grid.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/freetype/lv_freetype.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/fsdrv/lv_fs_fatfs.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/fsdrv/lv_fs_posix.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/fsdrv/lv_fs_stdio.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/fsdrv/lv_fs_win32.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/png/lodepng.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/png/lv_png.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/qrcode/lv_qrcode.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/libs/qrcode/qrcodegen.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/lv_extra.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/others/gridnav/lv_gridnav.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/others/monkey/lv_monkey.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/others/snapshot/lv_snapshot.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/themes/basic/lv_theme_basic.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/themes/default/lv_theme_default.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/themes/mono/lv_theme_mono.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/animimg/lv_animimg.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/calendar/lv_calendar.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/calendar/lv_calendar_header_arrow.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/calendar/lv_calendar_header_dropdown.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/chart/lv_chart.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/imgbtn/lv_imgbtn.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/colorwheel/lv_colorwheel.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/keyboard/lv_keyboard.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/led/lv_led.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/list/lv_list.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/menu/lv_menu.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/meter/lv_meter.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/msgbox/lv_msgbox.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/span/lv_span.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/spinbox/lv_spinbox.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/spinner/lv_spinner.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/tabview/lv_tabview.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/tileview/lv_tileview.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/extra/widgets/win/lv_win.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_dejavu_16_persian_hebrew.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_fmt_txt.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_loader.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_10.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_12.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_12_subpx.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_14.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_16.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_18.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_20.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_22.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_24.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_26.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_28.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_28_compressed.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_30.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_32.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_34.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_36.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_38.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_40.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_42.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_44.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_46.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_48.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_montserrat_8.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_simsun_16_cjk.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_unscii_16.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/font/lv_font_unscii_8.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/hal/lv_hal_disp.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/hal/lv_hal_indev.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/hal/lv_hal_tick.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_anim.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_anim_timeline.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_area.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_async.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_bidi.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_color.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_fs.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_gc.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_ll.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_log.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_lru.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_math.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_mem.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_printf.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_style.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_style_gen.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_templ.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_timer.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_tlsf.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_txt.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_txt_ap.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/misc/lv_utils.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_arc.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_bar.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_btn.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_btnmatrix.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_canvas.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_checkbox.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_dropdown.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_img.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_label.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_line.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_objx_templ.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_roller.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_slider.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_switch.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_table.c.o Compiling .pio/build/tasmota32-DE/libd0a/lvgl/widgets/lv_textarea.c.o Compiling .pio/build/tasmota32-DE/lib422/SPI/SPI.cpp.o Compiling .pio/build/tasmota32-DE/lib13e/Adafruit-GFX-Library-1.5.6-gemu-1.0/Adafruit_GFX.cpp.o Archiving .pio/build/tasmota32-DE/lib422/libSPI.a Indexing .pio/build/tasmota32-DE/lib422/libSPI.a Compiling .pio/build/tasmota32-DE/lib13e/Adafruit-GFX-Library-1.5.6-gemu-1.0/Adafruit_SPITFT.cpp.o Compiling .pio/build/tasmota32-DE/lib13e/Adafruit-GFX-Library-1.5.6-gemu-1.0/glcdfont.c.o Archiving .pio/build/tasmota32-DE/libd0a/liblvgl.a Indexing .pio/build/tasmota32-DE/libd0a/liblvgl.a Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/epdif.cpp.o Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/epdpaint.cpp.o Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/font12.c.o Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/font16.c.o Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/font20.c.o Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/font24.c.o Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/font24_7seg.c.o Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/font8.c.o Compiling .pio/build/tasmota32-DE/libe2a/Display_Renderer-gemu-1.0/renderer.cpp.o Compiling .pio/build/tasmota32-DE/libdaf/default/be_modtab.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_api.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_baselib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_bytecode.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_byteslib.c.o Archiving .pio/build/tasmota32-DE/lib13e/libAdafruit-GFX-Library-1.5.6-gemu-1.0.a Indexing .pio/build/tasmota32-DE/lib13e/libAdafruit-GFX-Library-1.5.6-gemu-1.0.a Compiling .pio/build/tasmota32-DE/libdaf/berry/be_class.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_code.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_debug.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_debuglib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_exec.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_filelib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_func.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_gc.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_gclib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_globallib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_introspectlib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_jsonlib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_lexer.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_libs.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_list.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_listlib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_map.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_maplib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_mathlib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_mem.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_module.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_object.c.o Archiving .pio/build/tasmota32-DE/libe2a/libDisplay_Renderer-gemu-1.0.a Indexing .pio/build/tasmota32-DE/libe2a/libDisplay_Renderer-gemu-1.0.a Compiling .pio/build/tasmota32-DE/libdaf/berry/be_oslib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_parser.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_rangelib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_repl.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_solidifylib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_strictlib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_string.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_strlib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_syslib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_timelib.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_var.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_vector.c.o Compiling .pio/build/tasmota32-DE/libdaf/berry/be_vm.c.o Compiling .pio/build/tasmota32-DE/liba77/berry_mapping/be_cb_module.c.o Compiling .pio/build/tasmota32-DE/liba77/berry_mapping/be_class_wrapper.c.o Compiling .pio/build/tasmota32-DE/liba77/berry_mapping/be_const_members.c.o Compiling .pio/build/tasmota32-DE/liba77/berry_mapping/be_mapping_utils.c.o Compiling .pio/build/tasmota32-DE/liba77/berry_mapping/be_raisef.c.o Compiling .pio/build/tasmota32-DE/libfa6/I2S/I2S.cpp.o Archiving .pio/build/tasmota32-DE/libdaf/libberry.a Archiving .pio/build/tasmota32-DE/liba77/libberry_mapping.a Indexing .pio/build/tasmota32-DE/liba77/libberry_mapping.a Indexing .pio/build/tasmota32-DE/libdaf/libberry.a Compiling .pio/build/tasmota32-DE/lib8a3/FFat/FFat.cpp.o Compiling .pio/build/tasmota32-DE/libf75/SD/SD.cpp.o Compiling .pio/build/tasmota32-DE/libf75/SD/sd_diskio.cpp.o Compiling .pio/build/tasmota32-DE/libf75/SD/sd_diskio_crc.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceBuffer.cpp.o Archiving .pio/build/tasmota32-DE/libfa6/libI2S.a Indexing .pio/build/tasmota32-DE/libfa6/libI2S.a Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceFS.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceFunction.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceHTTPStream.cpp.o Archiving .pio/build/tasmota32-DE/lib8a3/libFFat.a Indexing .pio/build/tasmota32-DE/lib8a3/libFFat.a Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceICYStream.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceID3.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourcePROGMEM.cpp.o Archiving .pio/build/tasmota32-DE/libf75/libSD.a Indexing .pio/build/tasmota32-DE/libf75/libSD.a Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceSD.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceSPIRAMBuffer.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileSourceSTDIO.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioFileStream.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorAAC.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorFLAC.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorMIDI.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorMOD.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorMP3.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorMP3a.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorOpus.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorRTTTL.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorTalkie.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioGeneratorWAV.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioLogger.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputBuffer.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputFilterBiquad.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputFilterDecimate.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputI2S.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputI2SNoDAC.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputMixer.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputSPDIF.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputSTDIO.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputSerialWAV.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/AudioOutputULP.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/driver/SinglePinI2SDriver.cpp.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/bitmath.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/bitreader.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/cpu.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/crc.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/fixed.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/float.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/format.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/lpc.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/md5.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/memory.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/stream_decoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libflac/window.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/aacdec.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/aactabs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/bitstream.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/buffers.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/dct4.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/decelmnt.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/dequant.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/fft.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/filefmt.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/huffman.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/hufftabs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/imdct.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/noiseless.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/pns.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbr.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrfft.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrfreq.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrhfadj.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrhfgen.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrhuff.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrimdct.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrmath.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrqmf.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrside.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/sbrtabs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/stproc.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/tns.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-aac/trigtabs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/bitstream.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/buffers.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/dct32.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/dequant.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/dqchan.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/huffman.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/hufftabs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/imdct.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/mp3dec.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/mp3tabs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/polyphase.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/scalfact.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/stproc.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/subband.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libhelix-mp3/trigtabs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/bit.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/decoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/fixed.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/frame.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/huffman.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/layer3.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/stream.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/synth.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/timer.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libmad/version.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libogg/bitwise.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libogg/framing.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/bands.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/celt.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/celt_decoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/celt_encoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/celt_lpc.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/cwrs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/entcode.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/entdec.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/entenc.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/kiss_fft.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/laplace.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/mathops.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/mdct.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/modes.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/pitch.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/quant_bands.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/rate.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/celt/vq.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/mapping_matrix.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/opus.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/opus_decoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/opus_encoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/opus_multistream.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/opus_multistream_decoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/opus_multistream_encoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/opus_projection_decoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/opus_projection_encoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/repacketizer.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/A2NLSF.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/CNG.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/HP_variable_cutoff.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/LPC_analysis_filter.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/LPC_fit.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/LPC_inv_pred_gain.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/LP_variable_cutoff.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NLSF2A.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NLSF_VQ.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NLSF_VQ_weights_laroia.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NLSF_decode.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NLSF_del_dec_quant.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NLSF_stabilize.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NLSF_encode.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NLSF_unpack.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NSQ.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/NSQ_del_dec.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/PLC.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/VAD.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/VQ_WMat_EC.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/ana_filt_bank_1.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/bwexpander.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/biquad_alt.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/bwexpander_32.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/check_control_input.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/code_signs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/control_SNR.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/control_audio_bandwidth.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/control_codec.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/debug.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/dec_API.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/decode_core.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/decode_frame.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/decode_indices.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/decode_parameters.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/decode_pitch.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/decode_pulses.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/decoder_set_fs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/enc_API.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/encode_indices.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/encode_pulses.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/LTP_analysis_filter_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/LTP_scale_ctrl_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/apply_sine_window_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/autocorr_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/burg_modified_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/corrMatrix_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/encode_frame_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/find_LPC_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/find_LTP_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/find_pitch_lags_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/find_pred_coefs_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/k2a_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/k2a_Q16_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/noise_shape_analysis_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/pitch_analysis_core_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/process_gains_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/regularize_correlations_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/residual_energy16_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/residual_energy_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/schur64_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/schur_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/vector_ops_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/fixed/warped_autocorrelation_FIX.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/gain_quant.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/init_decoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/init_encoder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/inner_prod_aligned.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/interpolate.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/lin2log.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/log2lin.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/pitch_est_tables.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/process_NLSFs.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/quant_LTP_gains.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/resampler.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/resampler_down2.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/resampler_down2_3.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/resampler_private_AR2.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/resampler_private_IIR_FIR.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/resampler_private_down_FIR.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/resampler_private_up2_HQ.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/resampler_rom.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/shell_coder.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/sigm_Q15.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/sort.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/stereo_LR_to_MS.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/stereo_MS_to_LR.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/stereo_decode_pred.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/stereo_encode_pred.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/stereo_find_predictor.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/stereo_quant_pred.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/sum_sqr_shift.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/table_LSF_cos.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/tables_LTP.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/tables_NLSF_CB_NB_MB.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/tables_pitch_lag.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/tables_gain.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/tables_NLSF_CB_WB.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/tables_other.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/libopus/silk/tables_pulses_per_block.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/opusfile/info.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/opusfile/internal.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/opusfile/opusfile.c.o Compiling .pio/build/tasmota32-DE/lib034/ESP8266Audio/opusfile/stream.c.o Compiling .pio/build/tasmota32-DE/lib974/ccronexpr/ccronexpr.c.o Compiling .pio/build/tasmota32-DE/lib974/ccronexpr/ccronexpr_test.c.o Compiling .pio/build/tasmota32-DE/libdcd/Zip-readonly-FS/ZipReadFS.cpp.o Compiling .pio/build/tasmota32-DE/libc8a/re1.5/backtrack.c.o Archiving .pio/build/tasmota32-DE/lib974/libccronexpr.a Compiling .pio/build/tasmota32-DE/libc8a/re1.5/charclass.c.o Indexing .pio/build/tasmota32-DE/lib974/libccronexpr.a Compiling .pio/build/tasmota32-DE/libc8a/re1.5/cleanmarks.c.o Compiling .pio/build/tasmota32-DE/libc8a/re1.5/compile.c.o Compiling .pio/build/tasmota32-DE/libc8a/re1.5/compilecode.c.o Archiving .pio/build/tasmota32-DE/lib034/libESP8266Audio.a Compiling .pio/build/tasmota32-DE/libc8a/re1.5/dumpcode.c.o Indexing .pio/build/tasmota32-DE/lib034/libESP8266Audio.a Compiling .pio/build/tasmota32-DE/libc8a/re1.5/pike.c.o Compiling .pio/build/tasmota32-DE/libc8a/re1.5/recursive.c.o Compiling .pio/build/tasmota32-DE/libc8a/re1.5/recursiveloop.c.o Compiling .pio/build/tasmota32-DE/libc8a/re1.5/sub.c.o Compiling .pio/build/tasmota32-DE/libc8a/re1.5/thompson.c.o Compiling .pio/build/tasmota32-DE/libc8a/re1.5/util.c.o Compiling .pio/build/tasmota32-DE/lib213/Unishox-1.0-shadinger/UnishoxStrings.cpp.o Compiling .pio/build/tasmota32-DE/lib213/Unishox-1.0-shadinger/unishox.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_MI32_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_animate_lib.c.o Archiving .pio/build/tasmota32-DE/libc8a/libre1.5.a Indexing .pio/build/tasmota32-DE/libc8a/libre1.5.a Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_audio_opus_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_autoconf_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_cron_class.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_crypto_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_ctypes.c.o Archiving .pio/build/tasmota32-DE/lib213/libUnishox-1.0-shadinger Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_display_lib.cpp.o Indexing .pio/build/tasmota32-DE/lib213/libUnishox-1.0-shadinger Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_driverlib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_energy_ctypes_definitions.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_energylib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_flash_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_gpio_lib.c.o Archiving .pio/build/tasmota32-DE/libdcd/libZip-readonly-FS.a Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_hue_bridge_lib.c.o Indexing .pio/build/tasmota32-DE/libdcd/libZip-readonly-FS.a Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_hue_lib.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_i2c_axp192_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_i2c_driverlib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_leds_animator_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_i2s_audio_lib.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_leds_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_leds_ntv_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_light_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_light_state_class.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lv_openhasp.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lv_tasmota_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lvgl_clock_icon_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lvgl_clock_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lvgl_signal_arcs_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lvgl_signal_bars_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lvgl_wifi_arcs_icon_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lvgl_wifi_arcs_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lvgl_wifi_bars_icon_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_lvgl_wifi_bars_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_md5_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_modtab_tasmota.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_mqtt_lib.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_onewire_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_path_tasmota_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_persist_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_port.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_python_compat.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_re_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_serial_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_tapp_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_tasmota_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_tasmota_log_reader_class.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_tcpclient_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_trigger_class.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_udp_lib.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_unishox_lib.cpp.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_uuid_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_webclient_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_webserver_lib.c.o Compiling .pio/build/tasmota32-DE/libb62/berry_tasmota/be_wire_lib.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_12_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_14_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_16_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_20_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_22_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_24_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_26_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_28_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_32_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_36_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_38_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_40_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_44_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/roboto-latin1/robotocondensed_regular_48_latin1.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_10.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_12.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_14.c.o Archiving .pio/build/tasmota32-DE/libb62/libberry_tasmota.a Indexing .pio/build/tasmota32-DE/libb62/libberry_tasmota.a Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_16.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_18.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_20.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_24.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_28.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_36.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_48.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/fonts/seg7_8.c.o Compiling .pio/build/tasmota32-DE/lib059/LVGL_assets/lv_theme_openhasp.c.o Compiling .pio/build/tasmota32-DE/lib181/generate/be_lvgl_module.c.o Compiling .pio/build/tasmota32-DE/lib181/generate/be_lvgl_widgets_lib.c.o Compiling .pio/build/tasmota32-DE/lib181/lv_binding_berry/be_lv_extra.c.o Compiling .pio/build/tasmota32-DE/lib181/lv_binding_berry/be_lvgl_ctypes_definitions.c.o Archiving .pio/build/tasmota32-DE/lib059/libLVGL_assets.a Indexing .pio/build/tasmota32-DE/lib059/libLVGL_assets.a Compiling .pio/build/tasmota32-DE/lib181/lv_binding_berry/be_lvgl_glob_lib.c.o Compiling .pio/build/tasmota32-DE/lib181/lv_binding_berry/lv_berry.c.o Compiling .pio/build/tasmota32-DE/lib771/Adafruit_LvGL_Glue-shadinger/Adafruit_LvGL_Glue.cpp.o Archiving .pio/build/tasmota32-DE/lib181/liblv_binding_berry.a Indexing .pio/build/tasmota32-DE/lib181/liblv_binding_berry.a Compiling .pio/build/tasmota32-DE/lib11b/Adafruit_MAX31865-1.1.0-custom/Adafruit_MAX31865.cpp.o Compiling .pio/build/tasmota32-DE/libf55/Adafruit_MCP9808_Tasmota/Adafruit_MCP9808.cpp.o Compiling .pio/build/tasmota32-DE/lib76e/Adafruit_SGP30-1.2.0/Adafruit_SGP30.cpp.o Compiling .pio/build/tasmota32-DE/lib1cf/Adafruit_BusIO/Adafruit_I2CDevice.cpp.o Compiling .pio/build/tasmota32-DE/lib1cf/Adafruit_BusIO/Adafruit_BusIO_Register.cpp.o Compiling .pio/build/tasmota32-DE/lib1cf/Adafruit_BusIO/Adafruit_SPIDevice.cpp.o Archiving .pio/build/tasmota32-DE/lib11b/libAdafruit_MAX31865-1.1.0-custom Archiving .pio/build/tasmota32-DE/lib771/libAdafruit_LvGL_Glue-shadinger.a Indexing .pio/build/tasmota32-DE/lib11b/libAdafruit_MAX31865-1.1.0-custom Indexing .pio/build/tasmota32-DE/lib771/libAdafruit_LvGL_Glue-shadinger.a Compiling .pio/build/tasmota32-DE/lib13a/Adafruit_VEML7700/Adafruit_VEML7700.cpp.o Archiving .pio/build/tasmota32-DE/lib76e/libAdafruit_SGP30-1.2.0.a Archiving .pio/build/tasmota32-DE/libf55/libAdafruit_MCP9808_Tasmota.a Indexing .pio/build/tasmota32-DE/lib76e/libAdafruit_SGP30-1.2.0.a Indexing .pio/build/tasmota32-DE/libf55/libAdafruit_MCP9808_Tasmota.a Compiling .pio/build/tasmota32-DE/lib509/Adafruit_seesaw_soilsensor_1.3.1/Adafruit_seesaw.cpp.o Compiling .pio/build/tasmota32-DE/libf56/BM8563_RTC/BM8563.cpp.o Archiving .pio/build/tasmota32-DE/lib1cf/libAdafruit_BusIO.a Indexing .pio/build/tasmota32-DE/lib1cf/libAdafruit_BusIO.a Compiling .pio/build/tasmota32-DE/libe29/AT24C256_512/Eeprom24C128_256.cpp.o Compiling .pio/build/tasmota32-DE/libe29/AT24C256_512/Eeprom24C512.cpp.o Compiling .pio/build/tasmota32-DE/lib766/Berry-HttpClientLight/HTTPUpdateLight.cpp.o Compiling .pio/build/tasmota32-DE/lib766/Berry-HttpClientLight/HttpClientLight.cpp.o Archiving .pio/build/tasmota32-DE/lib509/libAdafruit_seesaw_soilsensor_1.3.1.a Archiving .pio/build/tasmota32-DE/libf56/libBM8563_RTC.a Indexing .pio/build/tasmota32-DE/lib509/libAdafruit_seesaw_soilsensor_1.3.1.a Archiving .pio/build/tasmota32-DE/lib13a/libAdafruit_VEML7700.a Indexing .pio/build/tasmota32-DE/libf56/libBM8563_RTC.a Indexing .pio/build/tasmota32-DE/lib13a/libAdafruit_VEML7700.a Compiling .pio/build/tasmota32-DE/lib618/I2Cdevlib-Core/I2Cdev.cpp.o Archiving .pio/build/tasmota32-DE/libe29/libAT24C256_512.a Indexing .pio/build/tasmota32-DE/libe29/libAT24C256_512.a Compiling .pio/build/tasmota32-DE/libcfa/LibTeleinfo/LibTeleinfo.cpp.o Compiling .pio/build/tasmota32-DE/libcd3/I2Cdevlib-MPU6050/MPU6050.cpp.o Compiling .pio/build/tasmota32-DE/lib5d4/Mutichannel_Gas_Sensor/MutichannelGasSensor.cpp.o Compiling .pio/build/tasmota32-DE/lib9aa/ArduinoNTPd/NTPPacket.cpp.o Archiving .pio/build/tasmota32-DE/libcfa/libLibTeleinfo.a Archiving .pio/build/tasmota32-DE/lib766/libBerry-HttpClientLight.a Indexing .pio/build/tasmota32-DE/libcfa/libLibTeleinfo.a Indexing .pio/build/tasmota32-DE/lib766/libBerry-HttpClientLight.a Archiving .pio/build/tasmota32-DE/lib618/libI2Cdevlib-Core.a Compiling .pio/build/tasmota32-DE/lib9aa/ArduinoNTPd/NTPServer.cpp.o Indexing .pio/build/tasmota32-DE/lib618/libI2Cdevlib-Core.a Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLE2904.cpp.o Archiving .pio/build/tasmota32-DE/libcd3/libI2Cdevlib-MPU6050.a Indexing .pio/build/tasmota32-DE/libcd3/libI2Cdevlib-MPU6050.a Archiving .pio/build/tasmota32-DE/lib5d4/libMutichannel_Gas_Sensor.a Indexing .pio/build/tasmota32-DE/lib5d4/libMutichannel_Gas_Sensor.a Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEAddress.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEAdvertisedDevice.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEAdvertising.cpp.o Archiving .pio/build/tasmota32-DE/lib9aa/libArduinoNTPd.a Indexing .pio/build/tasmota32-DE/lib9aa/libArduinoNTPd.a Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEBeacon.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLECharacteristic.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEClient.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEDescriptor.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEDevice.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEEddystoneTLM.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEEddystoneURL.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEHIDDevice.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLERemoteCharacteristic.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLERemoteDescriptor.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLERemoteService.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEScan.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLESecurity.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEServer.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEService.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEUUID.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/NimBLEUtils.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/esp_port/esp-hci/src/esp_nimble_hci.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/esp_port/port/src/esp_nimble_mem.cpp.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/aes_decrypt.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/aes_encrypt.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/cbc_mode.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/ccm_mode.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/cmac_mode.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/ctr_mode.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/ctr_prng.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/ecc.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/ecc_dh.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/ecc_dsa.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/ecc_platform_specific.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/hmac.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/hmac_prng.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/sha256.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/ext/tinycrypt/src/utils.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_adv.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_conn.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_conn_hci.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_ctrl.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_dtm.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_hci.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_hci_ev.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_rand.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_resolv.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_rfmgmt.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_scan.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_sched.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_supp_cmd.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_sync.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_trace.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_utils.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/controller/src/ble_ll_whitelist.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/drivers/nrf51/src/ble_hw.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/drivers/nrf51/src/ble_phy.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/drivers/nrf52/src/ble_hw.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/drivers/nrf52/src/ble_phy.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/drivers/nrf52/src/ble_phy_trace.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/access.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/adv.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/beacon.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/cfg_cli.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/cfg_srv.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/crypto.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/friend.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/glue.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/health_cli.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/health_srv.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/light_model.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/lpn.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/mesh.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/model_cli.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/model_srv.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/net.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/nodes.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/prov.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/proxy.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/settings.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/shell.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/mesh/src/transport.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/services/ans/src/ble_svc_ans.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/services/bas/src/ble_svc_bas.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/services/dis/src/ble_svc_dis.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/services/gap/src/ble_svc_gap.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/services/gatt/src/ble_svc_gatt.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/services/ias/src/ble_svc_ias.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/services/ipss/src/ble_svc_ipss.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/services/lls/src/ble_svc_lls.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_att.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_att_clt.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_att_cmd.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_att_svr.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_eddystone.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_gap.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_gattc.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_gatts.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_gatts_lcl.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_adv.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_atomic.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_cfg.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_conn.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_flow.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_hci.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_hci_cmd.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_hci_evt.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_hci_util.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_id.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_log.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_mbuf.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_misc.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_mqueue.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_periodic_sync.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_pvcy.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_resolv.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_shutdown.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_startup.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_hs_stop.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_ibeacon.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_l2cap.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_l2cap_coc.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_l2cap_sig.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_l2cap_sig_cmd.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_monitor.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_sm.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_sm_alg.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_sm_cmd.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_sm_lgcy.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_sm_sc.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_store.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_store_util.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/src/ble_uuid.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/store/config/src/ble_store_config.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/store/config/src/ble_store_config_conf.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/store/config/src/ble_store_nvs.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/host/util/src/addr.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/nimble/transport/ram/src/ble_hci_ram.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/endian.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/hal_timer.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/mem.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/nimble_port.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/os_cputime.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/os_cputime_pwr2.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/os_mbuf.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/os_mempool.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/nimble/src/os_msys_init.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/npl/freertos/src/nimble_port_freertos.c.o Compiling .pio/build/tasmota32-DE/lib012/NimBLE-Arduino/nimble/porting/npl/freertos/src/npl_os_freertos.c.o Compiling .pio/build/tasmota32-DE/lib0f2/OpenTherm-0.9.0/OpenTherm.cpp.o Compiling .pio/build/tasmota32-DE/libfd6/ProcessControl/PID.cpp.o Compiling .pio/build/tasmota32-DE/libfd6/ProcessControl/Timeprop.cpp.o Compiling .pio/build/tasmota32-DE/lib2c1/arduino-tm1637/SevenSegmentAsciiMap.cpp.o Compiling .pio/build/tasmota32-DE/lib2c1/arduino-tm1637/SevenSegmentExtended.cpp.o Compiling .pio/build/tasmota32-DE/lib2c1/arduino-tm1637/SevenSegmentFun.cpp.o Compiling .pio/build/tasmota32-DE/lib2c1/arduino-tm1637/SevenSegmentTM1637.cpp.o Archiving .pio/build/tasmota32-DE/lib012/libNimBLE-Arduino.a Archiving .pio/build/tasmota32-DE/libfd6/libProcessControl.a Indexing .pio/build/tasmota32-DE/libfd6/libProcessControl.a Indexing .pio/build/tasmota32-DE/lib012/libNimBLE-Arduino.a Compiling .pio/build/tasmota32-DE/libbfe/vl53l0x-arduino-1.02/VL53L0X.cpp.o Compiling .pio/build/tasmota32-DE/libea1/vl53l1x-arduino-1.01/VL53L1X.cpp.o Compiling .pio/build/tasmota32-DE/lib3ac/berry_int64/be_int64_class.c.o Archiving .pio/build/tasmota32-DE/lib0f2/libOpenTherm-0.9.0.a Indexing .pio/build/tasmota32-DE/lib0f2/libOpenTherm-0.9.0.a Compiling .pio/build/tasmota32-DE/libaf3/arduino-mcp2515-1.0.1/mcp2515.cpp.o Compiling .pio/build/tasmota32-DE/libc38/A4988_Stepper/A4988_Stepper.cpp.o Archiving .pio/build/tasmota32-DE/libbfe/libvl53l0x-arduino-1.02.a Archiving .pio/build/tasmota32-DE/lib2c1/libarduino-tm1637.a Indexing .pio/build/tasmota32-DE/libbfe/libvl53l0x-arduino-1.02.a Archiving .pio/build/tasmota32-DE/lib3ac/libberry_int64.a Indexing .pio/build/tasmota32-DE/lib2c1/libarduino-tm1637.a Indexing .pio/build/tasmota32-DE/lib3ac/libberry_int64.a Compiling .pio/build/tasmota32-DE/libba0/TasmotaSerial-3.5.0/TasmotaSerial.cpp.o Compiling .pio/build/tasmota32-DE/lib455/Adafruit-Fingerprint-Sensor-Library-2.0.4-Tasmota/Adafruit_Fingerprint.cpp.o Archiving .pio/build/tasmota32-DE/libaf3/libarduino-mcp2515-1.0.1.a Archiving .pio/build/tasmota32-DE/libea1/libvl53l1x-arduino-1.01.a Indexing .pio/build/tasmota32-DE/libaf3/libarduino-mcp2515-1.0.1.a Indexing .pio/build/tasmota32-DE/libea1/libvl53l1x-arduino-1.01.a Compiling .pio/build/tasmota32-DE/libf72/Adafruit_LED_Backpack-1.1.6/Adafruit_LEDBackpack.cpp.o Compiling .pio/build/tasmota32-DE/lib802/Adafruit_SH1106-gemu-1.0/Adafruit_SH1106.cpp.o Compiling .pio/build/tasmota32-DE/lib64b/Adafruit_SSD1306-1.3.0-gemu-1.1/Adafruit_SSD1306.cpp.o Archiving .pio/build/tasmota32-DE/libba0/libTasmotaSerial-3.5.0.a Archiving .pio/build/tasmota32-DE/lib455/libAdafruit-Fingerprint-Sensor-Library-2.0.4-Tasmota Archiving .pio/build/tasmota32-DE/libc38/libA4988_Stepper.a Indexing .pio/build/tasmota32-DE/lib455/libAdafruit-Fingerprint-Sensor-Library-2.0.4-Tasmota Indexing .pio/build/tasmota32-DE/libba0/libTasmotaSerial-3.5.0.a Indexing .pio/build/tasmota32-DE/libc38/libA4988_Stepper.a Compiling .pio/build/tasmota32-DE/lib443/Adafruit_SSD1331-1.2.0/Adafruit_SPITFT_Renderer.cpp.o Compiling .pio/build/tasmota32-DE/lib443/Adafruit_SSD1331-1.2.0/Adafruit_SSD1331.cpp.o Compiling .pio/build/tasmota32-DE/lib054/Adafruit_TSL2591_Library/Adafruit_TSL2591.cpp.o Compiling .pio/build/tasmota32-DE/lib964/Arduino_ST7789-gemu-1.0/Arduino_ST7789.cpp.o Compiling .pio/build/tasmota32-DE/lib66e/rtsp/CRtspSession.cpp.o Archiving .pio/build/tasmota32-DE/lib054/libAdafruit_TSL2591_Library.a Archiving .pio/build/tasmota32-DE/lib443/libAdafruit_SSD1331-1.2.0.a Indexing .pio/build/tasmota32-DE/lib054/libAdafruit_TSL2591_Library.a Archiving .pio/build/tasmota32-DE/lib64b/libAdafruit_SSD1306-1.3.0-gemu-1.1.a Indexing .pio/build/tasmota32-DE/lib443/libAdafruit_SSD1331-1.2.0.a Archiving .pio/build/tasmota32-DE/lib802/libAdafruit_SH1106-gemu-1.0.a Indexing .pio/build/tasmota32-DE/lib64b/libAdafruit_SSD1306-1.3.0-gemu-1.1.a Indexing .pio/build/tasmota32-DE/lib802/libAdafruit_SH1106-gemu-1.0.a Archiving .pio/build/tasmota32-DE/libf72/libAdafruit_LED_Backpack-1.1.6.a Compiling .pio/build/tasmota32-DE/lib66e/rtsp/CStreamer.cpp.o Indexing .pio/build/tasmota32-DE/libf72/libAdafruit_LED_Backpack-1.1.6.a Compiling .pio/build/tasmota32-DE/lib66e/rtsp/JPEGSamples.cpp.o Compiling .pio/build/tasmota32-DE/lib66e/rtsp/OV2640.cpp.o Compiling .pio/build/tasmota32-DE/lib66e/rtsp/OV2640Streamer.cpp.o Compiling .pio/build/tasmota32-DE/lib66e/rtsp/SimStreamer.cpp.o Compiling .pio/build/tasmota32-DE/lib31a/DHT-sensor-library/DHT.cpp.o Compiling .pio/build/tasmota32-DE/libd5a/DNSServer/DNSServer.cpp.o Archiving .pio/build/tasmota32-DE/lib964/libArduino_ST7789-gemu-1.0.a Indexing .pio/build/tasmota32-DE/lib964/libArduino_ST7789-gemu-1.0.a Compiling .pio/build/tasmota32-DE/lib4fa/ESP8266SAM/ESP8266SAM.cpp.o Archiving .pio/build/tasmota32-DE/lib31a/libDHT-sensor-library.a Indexing .pio/build/tasmota32-DE/lib31a/libDHT-sensor-library.a Archiving .pio/build/tasmota32-DE/lib66e/librtsp.a Indexing .pio/build/tasmota32-DE/lib66e/librtsp.a Compiling .pio/build/tasmota32-DE/lib4fa/ESP8266SAM/esp8266sam_debug.c.o Compiling .pio/build/tasmota32-DE/lib4fa/ESP8266SAM/reciter.c.o Compiling .pio/build/tasmota32-DE/lib4fa/ESP8266SAM/render.c.o Compiling .pio/build/tasmota32-DE/lib4fa/ESP8266SAM/sam.c.o Compiling .pio/build/tasmota32-DE/lib51a/SD_MMC/SD_MMC.cpp.o Compiling .pio/build/tasmota32-DE/lib037/Ethernet/ETH.cpp.o Archiving .pio/build/tasmota32-DE/libd5a/libDNSServer.a Indexing .pio/build/tasmota32-DE/libd5a/libDNSServer.a Compiling .pio/build/tasmota32-DE/libca6/lib_mail/extras/ESPTimeHelper.cpp.o Compiling .pio/build/tasmota32-DE/libca6/lib_mail/ESP_Mail_Client.cpp.o Compiling .pio/build/tasmota32-DE/libca6/lib_mail/extras/RFC2047.cpp.o Compiling .pio/build/tasmota32-DE/libca6/lib_mail/wcs/esp32/ESP_Mail_HTTPClient32.cpp.o Archiving .pio/build/tasmota32-DE/lib4fa/libESP8266SAM.a Indexing .pio/build/tasmota32-DE/lib4fa/libESP8266SAM.a Compiling .pio/build/tasmota32-DE/libca6/lib_mail/wcs/esp32/ESP_Mail_WCS32.cpp.o Compiling .pio/build/tasmota32-DE/libca6/lib_mail/wcs/esp32/esp_mail_ssl_client32.cpp.o Archiving .pio/build/tasmota32-DE/lib51a/libSD_MMC.a Indexing .pio/build/tasmota32-DE/lib51a/libSD_MMC.a Compiling .pio/build/tasmota32-DE/libca6/lib_mail/wcs/esp8266/ESP_Mail_BearSSLHelpers.cpp.o Compiling .pio/build/tasmota32-DE/libca6/lib_mail/wcs/esp8266/ESP_Mail_CertStoreBearSSL.cpp.o Compiling .pio/build/tasmota32-DE/libca6/lib_mail/wcs/esp8266/ESP_Mail_HTTPClient.cpp.o Compiling .pio/build/tasmota32-DE/libca6/lib_mail/wcs/esp8266/ESP_Mail_WCS.cpp.o Archiving .pio/build/tasmota32-DE/lib037/libEthernet.a Indexing .pio/build/tasmota32-DE/lib037/libEthernet.a Compiling .pio/build/tasmota32-DE/libe10/FT5206_Library/FT5206.cpp.o Compiling .pio/build/tasmota32-DE/lib104/FrogmoreScd30/FrogmoreScd30.cpp.o Compiling .pio/build/tasmota32-DE/lib40a/FrogmoreScd40/FrogmoreScd40.cpp.o Compiling .pio/build/tasmota32-DE/libde0/ILI9341-gemu-1.0/ILI9341_2.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/IRac.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/IRrecv.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/IRsend.cpp.o Archiving .pio/build/tasmota32-DE/lib104/libFrogmoreScd30.a Archiving .pio/build/tasmota32-DE/libe10/libFT5206_Library.a Indexing .pio/build/tasmota32-DE/lib104/libFrogmoreScd30.a Indexing .pio/build/tasmota32-DE/libe10/libFT5206_Library.a Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/IRtext.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/IRtimer.cpp.o Archiving .pio/build/tasmota32-DE/lib40a/libFrogmoreScd40.a Indexing .pio/build/tasmota32-DE/lib40a/libFrogmoreScd40.a Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/IRutils.cpp.o Archiving .pio/build/tasmota32-DE/libde0/libILI9341-gemu-1.0.a Indexing .pio/build/tasmota32-DE/libde0/libILI9341-gemu-1.0.a Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Airton.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Airwell.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Aiwa.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Amcor.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Argo.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Arris.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Bose.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Carrier.cpp.o Archiving .pio/build/tasmota32-DE/libca6/lib_mail.a Indexing .pio/build/tasmota32-DE/libca6/lib_mail.a Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Coolix.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Corona.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Daikin.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Delonghi.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Denon.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Dish.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Doshisha.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Ecoclim.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Electra.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_EliteScreens.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Epson.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Fujitsu.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_GICable.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_GlobalCache.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Goodweather.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Gree.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Haier.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Hitachi.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Inax.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_JVC.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Kelon.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Kelvinator.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_LG.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Lasertag.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Lego.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Lutron.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_MWM.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Magiquest.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Metz.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Midea.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_MilesTag2.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Mirage.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Mitsubishi.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_MitsubishiHeavy.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Multibrackets.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_NEC.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Neoclima.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Nikai.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Panasonic.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Pioneer.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Pronto.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_RC5_RC6.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_RCMM.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Rhoss.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Samsung.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Sanyo.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Sharp.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Sherwood.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Sony.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Symphony.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Tcl.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Technibel.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Teco.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Teknopoint.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Toshiba.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Transcold.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Trotec.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Truma.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Vestel.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Voltas.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Whirlpool.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Whynter.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Xmp.cpp.o Compiling .pio/build/tasmota32-DE/lib351/IRremoteESP8266/ir_Zepeal.cpp.o Compiling .pio/build/tasmota32-DE/lib336/jsmn-shadinger-1.0/JsonGenerator.cpp.o Compiling .pio/build/tasmota32-DE/lib336/jsmn-shadinger-1.0/JsonParser.cpp.o Compiling .pio/build/tasmota32-DE/lib336/jsmn-shadinger-1.0/jsmn.cpp.o Compiling .pio/build/tasmota32-DE/lib526/KeeloqLib/KeeloqLib.cpp.o Compiling .pio/build/tasmota32-DE/libe5d/LOLIN_HP303B/LOLIN_HP303B.cpp.o Archiving .pio/build/tasmota32-DE/lib351/libIRremoteESP8266.a Compiling .pio/build/tasmota32-DE/lib93a/LedControl/LedControl.cpp.o Indexing .pio/build/tasmota32-DE/lib351/libIRremoteESP8266.a Compiling .pio/build/tasmota32-DE/lib93a/LedControl/LedMatrix.cpp.o Compiling .pio/build/tasmota32-DE/libb2e/LiquidCrystal_I2C-1.1.3/LiquidCrystal_I2C.cpp.o Compiling .pio/build/tasmota32-DE/lib124/rfid-1.4.7/MFRC522.cpp.o Archiving .pio/build/tasmota32-DE/libe5d/libLOLIN_HP303B.a Archiving .pio/build/tasmota32-DE/lib526/libKeeloqLib.a Archiving .pio/build/tasmota32-DE/lib336/libjsmn-shadinger-1.0.a Indexing .pio/build/tasmota32-DE/libe5d/libLOLIN_HP303B.a Indexing .pio/build/tasmota32-DE/lib336/libjsmn-shadinger-1.0.a Indexing .pio/build/tasmota32-DE/lib526/libKeeloqLib.a Compiling .pio/build/tasmota32-DE/lib124/rfid-1.4.7/MFRC522Extended.cpp.o Compiling .pio/build/tasmota32-DE/lib410/mlx90640-library/MLX90640_API.cpp.o Compiling .pio/build/tasmota32-DE/libb66/MPU_accel/MPU_accel.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/Esp32_i2s.c.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/HsbColor.cpp.o Archiving .pio/build/tasmota32-DE/lib124/librfid-1.4.7.a Archiving .pio/build/tasmota32-DE/lib410/libmlx90640-library.a Indexing .pio/build/tasmota32-DE/lib124/librfid-1.4.7.a Archiving .pio/build/tasmota32-DE/libb2e/libLiquidCrystal_I2C-1.1.3.a Indexing .pio/build/tasmota32-DE/lib410/libmlx90640-library.a Indexing .pio/build/tasmota32-DE/libb2e/libLiquidCrystal_I2C-1.1.3.a Archiving .pio/build/tasmota32-DE/lib93a/libLedControl.a Indexing .pio/build/tasmota32-DE/lib93a/libLedControl.a Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/HslColor.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/HtmlColor.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/HtmlColorNameStrings.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/HtmlColorNames.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/HtmlColorShortNames.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/NeoEsp32RmtMethod.cpp.o Archiving .pio/build/tasmota32-DE/libb66/libMPU_accel.a Indexing .pio/build/tasmota32-DE/libb66/libMPU_accel.a Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/NeoEsp8266DmaMethod.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/NeoEsp8266UartMethod.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/NeoEspBitBangMethod.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/NeoGamma.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/NeoPixelAnimator.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/NeoPixelAvr.c.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/Rgb48Color.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/RgbColor.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/RgbColorBase.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/RgbwColor.cpp.o Compiling .pio/build/tasmota32-DE/libd3f/NeoPixelBus/internal/SegmentDigit.cpp.o Compiling .pio/build/tasmota32-DE/libc83/NewPing-1.9.1/NewPing.cpp.o Compiling .pio/build/tasmota32-DE/libc2b/OneWire-Stickbreaker/OneWire.cpp.o Compiling .pio/build/tasmota32-DE/lib462/pubsubclient-2.8.13/PubSubClient.cpp.o Archiving .pio/build/tasmota32-DE/libd3f/libNeoPixelBus.a Indexing .pio/build/tasmota32-DE/libd3f/libNeoPixelBus.a Compiling .pio/build/tasmota32-DE/libe60/Xlatb_RA8876-gemu-1.0/RA8876.cpp.o Compiling .pio/build/tasmota32-DE/lib404/rc-switch/RCSwitch.cpp.o Compiling .pio/build/tasmota32-DE/liba21/RF24/RF24.cpp.o Compiling .pio/build/tasmota32-DE/libd18/Ext-printf/ext_printf.cpp.o Archiving .pio/build/tasmota32-DE/lib462/libpubsubclient-2.8.13.a Archiving .pio/build/tasmota32-DE/libc2b/libOneWire-Stickbreaker.a Archiving .pio/build/tasmota32-DE/libc83/libNewPing-1.9.1.a Indexing .pio/build/tasmota32-DE/lib462/libpubsubclient-2.8.13.a Indexing .pio/build/tasmota32-DE/libc2b/libOneWire-Stickbreaker.a Indexing .pio/build/tasmota32-DE/libc83/libNewPing-1.9.1.a Compiling .pio/build/tasmota32-DE/lib73d/Adafruit_SSD1351-gemu-1.0/SSD1351.cpp.o Archiving .pio/build/tasmota32-DE/libe60/libXlatb_RA8876-gemu-1.0.a Archiving .pio/build/tasmota32-DE/lib404/librc-switch.a Compiling .pio/build/tasmota32-DE/lib73d/Adafruit_SSD1351-gemu-1.0/Tiger.c.o Indexing .pio/build/tasmota32-DE/libe60/libXlatb_RA8876-gemu-1.0.a Indexing .pio/build/tasmota32-DE/lib404/librc-switch.a Compiling .pio/build/tasmota32-DE/lib34b/TM1638plus/TM1638plus.cpp.o Compiling .pio/build/tasmota32-DE/lib34b/TM1638plus/TM1638plus_common.cpp.o Archiving .pio/build/tasmota32-DE/liba21/libRF24.a Indexing .pio/build/tasmota32-DE/liba21/libRF24.a Compiling .pio/build/tasmota32-DE/libc06/TasmotaModbus-3.4.0/TasmotaModbus.cpp.o Compiling .pio/build/tasmota32-DE/lib62d/Joba_Tsl2561-2.0.10/Tsl2561.cpp.o Compiling .pio/build/tasmota32-DE/lib62d/Joba_Tsl2561-2.0.10/Tsl2561Util.cpp.o Archiving .pio/build/tasmota32-DE/lib34b/libTM1638plus.a Archiving .pio/build/tasmota32-DE/lib73d/libAdafruit_SSD1351-gemu-1.0.a Indexing .pio/build/tasmota32-DE/lib34b/libTM1638plus.a Archiving .pio/build/tasmota32-DE/libd18/libExt-printf.a Indexing .pio/build/tasmota32-DE/lib73d/libAdafruit_SSD1351-gemu-1.0.a Indexing .pio/build/tasmota32-DE/libd18/libExt-printf.a Compiling .pio/build/tasmota32-DE/lib48e/XPT2046_Touchscreen/XPT2046_Touchscreen.cpp.o Compiling .pio/build/tasmota32-DE/lib675/TTGO_TWatch_Library/axp20x.cpp.o Archiving .pio/build/tasmota32-DE/libc06/libTasmotaModbus-3.4.0.a Indexing .pio/build/tasmota32-DE/libc06/libTasmotaModbus-3.4.0.a Compiling .pio/build/tasmota32-DE/lib675/TTGO_TWatch_Library/bma.cpp.o Compiling .pio/build/tasmota32-DE/lib675/TTGO_TWatch_Library/bma4.c.o Compiling .pio/build/tasmota32-DE/lib675/TTGO_TWatch_Library/bma423.c.o Archiving .pio/build/tasmota32-DE/lib62d/libJoba_Tsl2561-2.0.10.a Indexing .pio/build/tasmota32-DE/lib62d/libJoba_Tsl2561-2.0.10.a Compiling .pio/build/tasmota32-DE/lib675/TTGO_TWatch_Library/i2c_bus.cpp.o Compiling .pio/build/tasmota32-DE/lib2b5/BME68x-Sensor-API/bme68x.c.o Compiling .pio/build/tasmota32-DE/libf9a/Epaper_29-gemu-1.0/epd2in9.cpp.o Archiving .pio/build/tasmota32-DE/lib48e/libXPT2046_Touchscreen.a Archiving .pio/build/tasmota32-DE/lib2b5/libBME68x-Sensor-API.a Indexing .pio/build/tasmota32-DE/lib48e/libXPT2046_Touchscreen.a Indexing .pio/build/tasmota32-DE/lib2b5/libBME68x-Sensor-API.a Compiling .pio/build/tasmota32-DE/lib963/Epaper_42-gemu-1.0/epd4in2.cpp.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd4in7.cpp.o Archiving .pio/build/tasmota32-DE/lib675/libTTGO_TWatch_Library.a Indexing .pio/build/tasmota32-DE/lib675/libTTGO_TWatch_Library.a Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/builtin_waveforms.c.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/display_ops.c.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/epd_driver.c.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/epd_temperature.c.o Archiving .pio/build/tasmota32-DE/libf9a/libEpaper_29-gemu-1.0.a Indexing .pio/build/tasmota32-DE/libf9a/libEpaper_29-gemu-1.0.a Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/font.c.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/highlevel.c.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/i2s_data_bus.c.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/lut.c.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/render.c.o Compiling .pio/build/tasmota32-DE/lib68f/epdiy/epd_driver/rmt_pulse.c.o Compiling .pio/build/tasmota32-DE/lib854/EEPROM/EEPROM.cpp.o Archiving .pio/build/tasmota32-DE/lib963/libEpaper_42-gemu-1.0.a Indexing .pio/build/tasmota32-DE/lib963/libEpaper_42-gemu-1.0.a Compiling .pio/build/tasmota32-DE/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip-config.cpp.o Compiling .pio/build/tasmota32-DE/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip-conversion.cpp.o Compiling .pio/build/tasmota32-DE/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip-send.cpp.o Compiling .pio/build/tasmota32-DE/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip-webserver.cpp.o Compiling .pio/build/tasmota32-DE/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip.cpp.o Archiving .pio/build/tasmota32-DE/lib68f/libepdiy.a Indexing .pio/build/tasmota32-DE/lib68f/libepdiy.a Compiling .pio/build/tasmota32-DE/lib669/HPMA115S0/hpma115S0.cpp.o Compiling .pio/build/tasmota32-DE/libeb1/UDisplay/uDisplay.cpp.o Archiving .pio/build/tasmota32-DE/lib854/libEEPROM.a Indexing .pio/build/tasmota32-DE/lib854/libEEPROM.a Archiving .pio/build/tasmota32-DE/libFrameworkArduinoVariant.a Indexing .pio/build/tasmota32-DE/libFrameworkArduinoVariant.a Compiling .pio/build/tasmota32-DE/FrameworkArduino/Esp.cpp.o Archiving .pio/build/tasmota32-DE/lib669/libHPMA115S0.a Indexing .pio/build/tasmota32-DE/lib669/libHPMA115S0.a Compiling .pio/build/tasmota32-DE/FrameworkArduino/FirmwareMSC.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/FunctionalInterrupt.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/HWCDC.cpp.o Archiving .pio/build/tasmota32-DE/lib6a9/libesp-knx-ip-0.5.2.a Indexing .pio/build/tasmota32-DE/lib6a9/libesp-knx-ip-0.5.2.a Compiling .pio/build/tasmota32-DE/FrameworkArduino/HardwareSerial.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/IPAddress.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/IPv6Address.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/MD5Builder.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/Print.cpp.o Archiving .pio/build/tasmota32-DE/libeb1/libUDisplay.a Indexing .pio/build/tasmota32-DE/libeb1/libUDisplay.a Compiling .pio/build/tasmota32-DE/FrameworkArduino/Stream.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/StreamString.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/Tone.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/USB.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/USBCDC.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/USBMSC.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/WMath.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/WString.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/base64.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/cbuf.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-adc.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-bt.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-cpu.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-dac.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-gpio.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-i2c-slave.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-i2c.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-ledc.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-matrix.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-misc.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-psram.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-rmt.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-sigmadelta.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-spi.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-time.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-timer.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-tinyusb.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-touch.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/esp32-hal-uart.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/firmware_msc_fat.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/libb64/cdecode.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/libb64/cencode.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/main.cpp.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/stdlib_noniso.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/wiring_pulse.c.o Compiling .pio/build/tasmota32-DE/FrameworkArduino/wiring_shift.c.o Archiving .pio/build/tasmota32-DE/libFrameworkArduino.a Indexing .pio/build/tasmota32-DE/libFrameworkArduino.a Linking .pio/build/tasmota32-DE/firmware.elf Retrieving maximum program size .pio/build/tasmota32-DE/firmware.elf Checking size .pio/build/tasmota32-DE/firmware.elf Advanced Memory Usage is available via "PlatformIO Home > Project Inspect" RAM: [== ] 19.7% (used 64564 bytes from 327680 bytes) Flash: [======== ] 76.0% (used 1444753 bytes from 1900544 bytes) Building .pio/build/tasmota32-DE/firmware.bin esptool.py v3.3 Creating esp32 image... Merged 25 ELF sections Successfully created esp32 image. esp32_create_combined_bin([".pio/build/tasmota32-DE/firmware.bin"], [".pio/build/tasmota32-DE/firmware.elf"]) Offset | File - 0x1000 | /.platformio/packages/framework-arduinoespressif32/tools/sdk/esp32/bin/bootloader_dout_40m.bin - 0x8000 | /tasmota/.pio/build/tasmota32-DE/partitions.bin - 0xe000 | /.platformio/packages/framework-arduinoespressif32/tools/partitions/boot_app0.bin - 0x10000 | /tasmota/.pio/build/tasmota32-DE/firmware.bin esptool.py v3.3 Wrote 0x172290 bytes to file /tasmota/.pio/build/tasmota32-DE/firmware.factory.bin, ready to flash to offset 0x0 bin_map_copy([".pio/build/tasmota32-DE/firmware.bin"], [".pio/build/tasmota32-DE/firmware.elf"]) map_gzip([".pio/build/tasmota32-DE/firmware.bin"], [".pio/build/tasmota32-DE/firmware.elf"]) ==================================================================== [SUCCESS] Took 153.06 seconds ==================================================================== Environment Status Duration ------------- -------- ------------ tasmota32-DE SUCCESS 00:02:33.063 ===================================================================== 1 succeeded in 00:02:33.063 ===================================================================== All done! Find your builds in Tasmota/build_output/firmware/ >ls -l Tasmota/build_output/firmware/ total 2904 -rw-r--r-- 1 mw root 1450640 Apr 21 14:44 tasmota32-DE.bin -rw-r--r-- 1 mw root 1516176 Apr 21 14:44 tasmota32-DE.factory.bin
