docker run -ti --rm -v $(pwd)/Tasmota:/tasmota -u $UID:$GID docker-tasmota -e tasmota >docker run -ti --rm -v $(pwd)/Tasmota:/tasmota -u $UID:$GID docker-tasmota -e tasmota Compiling Tasmota... Processing tasmota (platform: https://github.com/tasmota/platform-espressif8266/releases/download/v2.7.4.9/platform-espressif8266-2.7.4.9.zip; framework: arduino; board: esp8266_1M) ------------------------------------------------------------------------------------------------------------------------------------------------------------------------ Platform Manager: Installing https://github.com/tasmota/platform-espressif8266/releases/download/v2.7.4.9/platform-espressif8266-2.7.4.9.zip Downloading [####################################] 100% Unpacking [####################################] 100% Platform Manager: espressif8266 @ 2.7.4+9 has been installed! The platform 'https://github.com/tasmota/platform-espressif8266/releases/download/v2.7.4.9/platform-espressif8266-2.7.4.9.zip' has been successfully installed! The rest of the packages will be installed later depending on your build environment. Tool Manager: Installing platformio/toolchain-xtensa @ ~2.40802.0 Downloading [####################################] 100% Unpacking [####################################] 100% Tool Manager: toolchain-xtensa @ 2.40802.200502 has been installed! Tool Manager: Installing tasmota/framework-arduinoespressif8266 @ ~2.7.4 Downloading [####################################] 100% Unpacking [####################################] 100% Tool Manager: framework-arduinoespressif8266 @ 2.7.4+9 has been installed! Tool Manager: Installing https://github.com/tasmota/esptool/releases/download/v3.3/esptool-3.3.zip Downloading [####################################] 100% Unpacking [####################################] 100% Tool Manager: tool-esptoolpy @ 1.30300.220323 has been installed! Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp8266_1M.html PLATFORM: Espressif 8266 (2.7.4+9) > Espressif Generic ESP8266 Tasmota 1M sketch NO FS HARDWARE: ESP8266 80MHz, 80KB RAM, 972.00KB Flash PACKAGES: - framework-arduinoespressif8266 2.7.4+9 - tool-esptoolpy 1.30300.220323 (3.3.0) - toolchain-xtensa 2.40802.200502 (4.8.2) Converting tasmota.ino LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf LDF Modes: Finder ~ chain, Compatibility ~ strict Found 94 compatible libraries Scanning dependencies... Dependency Graph |-- 1.0 | |-- 1.0 | |-- 0.6 |-- 1.0.0 | |-- 1.0 |-- 1.0.1 | |-- 1.0 |-- 1.1.2 | |-- 1.0 |-- 1.2.0 | |-- 1.0 |-- 1.0.0 | |-- 1.11.0 | | |-- 1.0 | | |-- 1.0 | |-- 1.0 |-- 1.3.1 | |-- 1.0 |-- 1.9.5 | |-- 1.2 | | |-- 1.0 | |-- 0.1.0 | |-- 2.0.0 | | |-- 0.1.0 | | | |-- 1.0 | | | |-- 1.1.0 | | | | |-- 1.0 | |-- 1.0 |-- | |-- 1.0 |-- | |-- 1.0 |-- | |-- 1.0 |-- 1.1.3 |-- | |-- | | |-- 1.0 |-- 0.0.1 | |-- 1.0 |-- | |-- 1.0 |-- 0.9.0 |-- 1.0.0 |-- 1.1.0 |-- 1.0 |-- 1.0 |-- 1.0.2 | |-- 1.0 |-- 1.0.1 | |-- 1.0 |-- 1.0.0 |-- 1.0 | |-- 1.0 |-- | |-- 1.0 |-- 0.0.1 |-- 2.0.4 | |-- 3.5.0 |-- 1.5.6 | |-- 1.0 |-- 1.1.6 | |-- 1.5.6 | | |-- 1.0 | |-- 1.0 |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 | |-- 1.0 |-- 1.3.0 | |-- 1.5.6 | | |-- 1.0 | |-- 1.0 | |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 |-- 1.2.0 | |-- 1.5.6 | | |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 | |-- 1.0 |-- | |-- 1.0 |-- 0.9.5 | |-- 1.5.6 | | |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 | |-- 1.0 |-- 1.4.3 |-- 1.1.1 | |-- 1.0 |-- 1.2 | |-- 1.0 |-- 1.0.1 | |-- 1.9.5 | | |-- 1.2 | | | |-- 1.0 | | |-- 0.1.0 | | |-- 2.0.0 | | | |-- 0.1.0 | | | | |-- 1.0 | | | | |-- 1.1.0 | | | | | |-- 1.0 | | |-- 1.0 |-- 1.0 | |-- 1.0 |-- 1.0 |-- 1.3 | |-- 1.2 | | |-- 1.0 | |-- 1.0 |-- 1.2 | |-- 1.0 |-- 1.2.0 | |-- 0.1.0 | |-- 1.0 | |-- 2.0.0 | | |-- 0.1.0 | | | |-- 1.0 | | | |-- 1.1.0 | | | | |-- 1.0 |-- 1.0.0 | |-- 1.0 |-- | |-- 1.0 |-- | |-- 1.0 |-- 1.0.0 | |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 |-- 2.8.2 |-- 1.0 |-- 1.1 |-- 1.0 |-- 1.0.0 | |-- 1.0 | |-- 1.0 |-- 1.0.6 |-- |-- | |-- 1.0 |-- 0.1.0 |-- 1.4.7 | |-- 1.0 |-- | |-- 1.0 |-- | |-- 1.0 |-- 2.6.7 | |-- 1.0 |-- 1.9.1 |-- 2.3.2 |-- 2.8 |-- 1.0.2 | |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 |-- 1.0.0 |-- 1.3.3 | |-- 1.0 |-- 1.0 |-- 2.0.0 | |-- 0.1.0 | | |-- 1.0 | | |-- 1.1.0 | | | |-- 1.0 |-- 1.0 |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 | |-- 1.0 |-- 1.1.0 | |-- 1.0 |-- 1.7.0 |-- 3.4.0 | |-- 3.5.0 |-- 3.5.0 |-- 1.0 |-- 2.0.10 | |-- 1.0 |-- 1.0 |-- | |-- 1.0 |-- 1.1.1 |-- |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 |-- 1.0 | |-- 1.5.6 | | |-- 1.0 | |-- 1.0 |-- 0.5.2 | |-- 1.0 | |-- 1.0 | | |-- 1.0 | |-- 1.0 |-- 1.0.0 |-- 1.0.0 |-- 0.6 |-- 0.1 | |-- 1.5.6 | | |-- 1.0 | |-- 1.0 | |-- 1.0 | |-- 1.0 | | |-- 1.5.6 | | | |-- 1.0 | | |-- 1.0 | |-- 1.0 | | |-- 1.0 | | | |-- 1.5.6 | | | | |-- 1.0 | | | |-- 1.0 | | |-- 1.0 Building in release mode *** use provided user_config_override.h as planned *** *** use provided platformio_override.ini as planned *** *** use provided platformio_tasmota_cenv.ini as planned *** Use manually specified: COM5 Compiling .pio/build/tasmota/src/homekit.c.o Compiling .pio/build/tasmota/src/tasmota.ino.cpp.o Compiling .pio/build/tasmota/src/xsns_62_esp32_mi_homekit.c.o Generating LD script .pio/build/tasmota/ld/local.eagle.app.v6.common.ld Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/BearSSLHelpers.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/CertStoreBearSSL.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/ESP8266WiFi.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/ESP8266WiFiAP.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/ESP8266WiFiMulti.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/ESP8266WiFiSTA.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/ESP8266WiFiScan.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/WiFiClient.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/WiFiClientSecureAxTLS.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/WiFiServer.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/WiFiServerSecureAxTLS.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o Compiling .pio/build/tasmota/libbc6/ESP8266WiFi/WiFiUdp.cpp.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/aead/ccm.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/aead/eax.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/aead/gcm.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/ccopy.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/dec16be.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/dec16le.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/dec32be.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/dec32le.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/dec64be.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/dec64le.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/enc16be.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/enc16le.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/enc32be.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/enc32le.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/enc64be.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/enc64le.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/pemdec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/codec/pemenc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_all_m15.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_c25519_m15.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_curve25519.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_default.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_keygen.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_p256_m15.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_prime_i15.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_pubkey.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_secp256r1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_secp384r1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ec_secp521r1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_atr.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_default_sign_asn1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_default_sign_raw.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_default_vrfy_asn1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_default_vrfy_raw.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_i15_bits.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_i15_sign_asn1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_i15_sign_raw.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_i15_vrfy_asn1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_i15_vrfy_raw.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ec/ecdsa_rta.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/dig_oid.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/dig_size.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/ghash_ctmul.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/ghash_ctmul32.c.o Archiving .pio/build/tasmota/libbc6/libESP8266WiFi.a Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/ghash_ctmul64.c.o Indexing .pio/build/tasmota/libbc6/libESP8266WiFi.a Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/ghash_pclmul.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/md5.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/md5sha1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/mgf1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/multihash.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/sha1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/sha2big.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/hash/sha2small.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_add.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_bitlen.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_decmod.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_decode.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_decred.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_encode.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_fmont.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_iszero.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_moddiv.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_modpow.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_modpow2.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_montmul.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_mulacc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_muladd.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_ninv15.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_reduce.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_rshift.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_sub.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/int/i15_tmont.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/kdf/hkdf.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/kdf/shake.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/mac/hmac.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/mac/hmac_ct.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rand/aesctr_drbg.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rand/hmac_drbg.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rand/sysrng.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_keygen.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_modulus.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_oaep_decrypt.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_oaep_encrypt.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_pkcs1_sign.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_pkcs1_vrfy.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_priv.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_privexp.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_pss_sign.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_pss_vrfy.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_pub.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_default_pubexp.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_keygen.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_modulus.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_oaep_decrypt.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_oaep_encrypt.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_pkcs1_sign.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_pkcs1_vrfy.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_priv.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_privexp.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_pss_sign.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_pss_vrfy.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_pub.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_i15_pubexp.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_oaep_pad.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_oaep_unpad.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_pkcs1_sig_pad.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_pkcs1_sig_unpad.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_pss_sig_pad.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_pss_sig_unpad.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/rsa/rsa_ssl_decrypt.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/settings.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/prf.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/prf_md5sha1.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/prf_sha256.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/prf_sha384.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_ccert_single_ec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_client.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_ccert_single_rsa.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_client_default_rsapub.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_client_full.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine_default_aescbc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine_default_aesccm.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine_default_aesgcm.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine_default_chapol.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine_default_descbc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine_default_ec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine_default_ecdsa.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_engine_default_rsavrfy.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_hashes.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_hs_client.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_hs_server.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_io.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_keyexport.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_lru.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_rec_cbc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_rec_ccm.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_rec_chapol.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_rec_gcm.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_scert_single_ec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/ssl/ssl_scert_single_rsa.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_big_cbcdec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_big_cbcenc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_big_ctr.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_big_ctrcbc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_big_dec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_big_enc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_common.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct64.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct64_cbcdec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct64_cbcenc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct64_ctr.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct64_ctrcbc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct64_dec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct64_enc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct_cbcdec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct_cbcenc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct_ctr.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct_ctrcbc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct_dec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_ct_enc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_small_cbcdec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_small_cbcenc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_small_ctr.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_small_ctrcbc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_small_dec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/aes_small_enc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/chacha20_ct.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/chacha20_sse2.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/des_ct.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/des_ct_cbcdec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/des_ct_cbcenc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/des_support.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/des_tab.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/des_tab_cbcdec.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/des_tab_cbcenc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/poly1305_ctmul.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/poly1305_ctmul32.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/poly1305_ctmulq.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/symcipher/poly1305_i15.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/asn1enc.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/encode_ec_pk8der.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/encode_ec_rawder.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/encode_rsa_pk8der.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/encode_rsa_rawder.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/pkey_decoder.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/skey_decoder.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/x509_decoder.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/x509_knownkey.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/x509_minimal.c.o Compiling .pio/build/tasmota/lib417/bearssl-esp8266/x509/x509_minimal_full.c.o Compiling .pio/build/tasmota/libd6f/tls_mini/StackThunk_light.cpp.o Compiling .pio/build/tasmota/libd6f/tls_mini/WiFiClientSecureLightBearSSL.cpp.o Compiling .pio/build/tasmota/libef1/Wire/Wire.cpp.o Compiling .pio/build/tasmota/lib5ed/Adafruit_CCS811-1.0.0.14/Adafruit_CCS811.cpp.o Compiling .pio/build/tasmota/lib748/SPI/SPI.cpp.o Archiving .pio/build/tasmota/libd6f/libtls_mini.a Indexing .pio/build/tasmota/libd6f/libtls_mini.a Compiling .pio/build/tasmota/lib11b/Adafruit_MAX31865-1.1.0-custom/Adafruit_MAX31865.cpp.o Compiling .pio/build/tasmota/libf55/Adafruit_MCP9808_Tasmota/Adafruit_MCP9808.cpp.o Compiling .pio/build/tasmota/lib76e/Adafruit_SGP30-1.2.0/Adafruit_SGP30.cpp.o Archiving .pio/build/tasmota/lib417/libbearssl-esp8266.a Indexing .pio/build/tasmota/lib417/libbearssl-esp8266.a Compiling .pio/build/tasmota/lib1cf/Adafruit_BusIO/Adafruit_BusIO_Register.cpp.o Archiving .pio/build/tasmota/lib5ed/libAdafruit_CCS811-1.0.0.14.a Indexing .pio/build/tasmota/lib5ed/libAdafruit_CCS811-1.0.0.14.a Compiling .pio/build/tasmota/lib1cf/Adafruit_BusIO/Adafruit_I2CDevice.cpp.o Archiving .pio/build/tasmota/libef1/libWire.a Indexing .pio/build/tasmota/libef1/libWire.a Compiling .pio/build/tasmota/lib1cf/Adafruit_BusIO/Adafruit_SPIDevice.cpp.o Archiving .pio/build/tasmota/lib76e/libAdafruit_SGP30-1.2.0.a Archiving .pio/build/tasmota/libf55/libAdafruit_MCP9808_Tasmota.a Indexing .pio/build/tasmota/lib76e/libAdafruit_SGP30-1.2.0.a Indexing .pio/build/tasmota/libf55/libAdafruit_MCP9808_Tasmota.a Archiving .pio/build/tasmota/lib11b/libAdafruit_MAX31865-1.1.0-custom Indexing .pio/build/tasmota/lib11b/libAdafruit_MAX31865-1.1.0-custom Compiling .pio/build/tasmota/lib13a/Adafruit_VEML7700/Adafruit_VEML7700.cpp.o Compiling .pio/build/tasmota/lib509/Adafruit_seesaw_soilsensor_1.3.1/Adafruit_seesaw.cpp.o Compiling .pio/build/tasmota/lib4e3/ESP8266HTTPClient/ESP8266HTTPClient.cpp.o Archiving .pio/build/tasmota/lib748/libSPI.a Indexing .pio/build/tasmota/lib748/libSPI.a Compiling .pio/build/tasmota/lib5b0/LittleFS/LittleFS.cpp.o Compiling .pio/build/tasmota/lib5b0/LittleFS/lfs.c.o Compiling .pio/build/tasmota/lib5b0/LittleFS/lfs_util.c.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/FatFile.cpp.o Archiving .pio/build/tasmota/lib1cf/libAdafruit_BusIO.a Indexing .pio/build/tasmota/lib1cf/libAdafruit_BusIO.a Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/FatFileLFN.cpp.o Archiving .pio/build/tasmota/lib13a/libAdafruit_VEML7700.a Indexing .pio/build/tasmota/lib13a/libAdafruit_VEML7700.a Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/FatFilePrint.cpp.o Archiving .pio/build/tasmota/lib509/libAdafruit_seesaw_soilsensor_1.3.1.a Indexing .pio/build/tasmota/lib509/libAdafruit_seesaw_soilsensor_1.3.1.a Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/FatFileSFN.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/FatVolume.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/FmtNumber.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/StdioStream.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/fstream.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/istream.cpp.o Archiving .pio/build/tasmota/lib4e3/libESP8266HTTPClient.a Indexing .pio/build/tasmota/lib4e3/libESP8266HTTPClient.a Archiving .pio/build/tasmota/lib5b0/libLittleFS.a Indexing .pio/build/tasmota/lib5b0/libLittleFS.a Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/FatLib/ostream.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/MinimumSerial.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SdCard/SdSpiCard.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SdCard/SdSpiCardEX.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SdCard/SdioCardEX.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SdCard/SdioTeensy.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SpiDriver/SdSpiESP8266.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SpiDriver/SdSpiParticle.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SpiDriver/SdSpiSAM3X.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SpiDriver/SdSpiSTM32.cpp.o Compiling .pio/build/tasmota/lib0f3/ESP8266SdFat/SpiDriver/SdSpiTeensy3.cpp.o Compiling .pio/build/tasmota/lib5c3/SDFS/SDFS.cpp.o Compiling .pio/build/tasmota/lib227/SD/SD.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceBuffer.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceFS.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceFunction.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceHTTPStream.cpp.o Archiving .pio/build/tasmota/lib0f3/libESP8266SdFat.a Indexing .pio/build/tasmota/lib0f3/libESP8266SdFat.a Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceICYStream.cpp.o Archiving .pio/build/tasmota/lib227/libSD.a Indexing .pio/build/tasmota/lib227/libSD.a Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceID3.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourcePROGMEM.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceSD.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceSPIRAMBuffer.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileSourceSTDIO.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioFileStream.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorAAC.cpp.o Archiving .pio/build/tasmota/lib5c3/libSDFS.a Indexing .pio/build/tasmota/lib5c3/libSDFS.a Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorFLAC.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorMIDI.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorMOD.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorMP3.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorMP3a.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorOpus.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorRTTTL.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorTalkie.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioGeneratorWAV.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioLogger.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputBuffer.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputFilterBiquad.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputFilterDecimate.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputI2S.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputI2SNoDAC.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputMixer.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputSPDIF.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputSTDIO.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputSerialWAV.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/AudioOutputULP.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/driver/SinglePinI2SDriver.cpp.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/bitmath.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/bitreader.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/cpu.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/crc.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/fixed.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/float.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/format.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/lpc.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/md5.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/memory.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/stream_decoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libflac/window.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/aacdec.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/aactabs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/bitstream.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/buffers.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/dct4.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/decelmnt.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/dequant.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/fft.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/filefmt.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/huffman.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/hufftabs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/imdct.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/noiseless.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/pns.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbr.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrfft.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrfreq.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrhfadj.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrhfgen.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrhuff.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrimdct.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrmath.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrqmf.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrside.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/sbrtabs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/stproc.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/tns.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-aac/trigtabs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/bitstream.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/buffers.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/dct32.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/dequant.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/dqchan.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/huffman.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/hufftabs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/imdct.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/mp3dec.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/mp3tabs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/polyphase.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/scalfact.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/stproc.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/subband.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libhelix-mp3/trigtabs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/bit.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/decoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/fixed.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/frame.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/huffman.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/layer3.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/stream.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/synth.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/timer.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libmad/version.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libogg/bitwise.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libogg/framing.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/bands.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/celt.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/celt_decoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/celt_encoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/celt_lpc.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/cwrs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/entcode.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/entdec.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/entenc.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/kiss_fft.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/laplace.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/mathops.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/mdct.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/modes.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/pitch.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/quant_bands.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/rate.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/celt/vq.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/mapping_matrix.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/opus.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/opus_decoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/opus_encoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/opus_multistream.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/opus_multistream_decoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/opus_multistream_encoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/opus_projection_decoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/opus_projection_encoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/repacketizer.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/A2NLSF.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/CNG.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/HP_variable_cutoff.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/LPC_analysis_filter.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/LPC_fit.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/LPC_inv_pred_gain.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/LP_variable_cutoff.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NLSF2A.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NLSF_VQ.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NLSF_VQ_weights_laroia.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NLSF_decode.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NLSF_del_dec_quant.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NLSF_encode.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NLSF_stabilize.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NLSF_unpack.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NSQ.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/NSQ_del_dec.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/PLC.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/VAD.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/VQ_WMat_EC.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/ana_filt_bank_1.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/biquad_alt.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/bwexpander.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/bwexpander_32.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/check_control_input.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/code_signs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/control_SNR.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/control_audio_bandwidth.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/control_codec.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/debug.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/dec_API.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/decode_core.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/decode_frame.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/decode_indices.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/decode_parameters.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/decode_pitch.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/decode_pulses.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/decoder_set_fs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/enc_API.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/encode_indices.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/encode_pulses.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/LTP_analysis_filter_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/LTP_scale_ctrl_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/apply_sine_window_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/autocorr_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/burg_modified_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/corrMatrix_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/encode_frame_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/find_LPC_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/find_LTP_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/find_pitch_lags_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/find_pred_coefs_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/k2a_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/k2a_Q16_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/noise_shape_analysis_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/pitch_analysis_core_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/process_gains_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/regularize_correlations_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/residual_energy16_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/residual_energy_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/schur64_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/schur_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/vector_ops_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/fixed/warped_autocorrelation_FIX.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/gain_quant.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/init_decoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/init_encoder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/inner_prod_aligned.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/interpolate.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/lin2log.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/log2lin.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/pitch_est_tables.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/process_NLSFs.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/quant_LTP_gains.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/resampler.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/resampler_down2.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/resampler_down2_3.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/resampler_private_AR2.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/resampler_private_IIR_FIR.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/resampler_private_down_FIR.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/resampler_private_up2_HQ.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/resampler_rom.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/shell_coder.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/sigm_Q15.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/sort.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/stereo_LR_to_MS.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/stereo_MS_to_LR.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/stereo_decode_pred.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/stereo_encode_pred.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/stereo_find_predictor.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/stereo_quant_pred.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/sum_sqr_shift.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/table_LSF_cos.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/tables_LTP.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/tables_NLSF_CB_NB_MB.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/tables_NLSF_CB_WB.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/tables_gain.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/tables_other.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/tables_pitch_lag.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/libopus/silk/tables_pulses_per_block.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/opusfile/info.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/opusfile/internal.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/opusfile/opusfile.c.o Compiling .pio/build/tasmota/lib034/ESP8266Audio/opusfile/stream.c.o Compiling .pio/build/tasmota/libf56/BM8563_RTC/BM8563.cpp.o Compiling .pio/build/tasmota/libe29/AT24C256_512/Eeprom24C128_256.cpp.o Compiling .pio/build/tasmota/libe29/AT24C256_512/Eeprom24C512.cpp.o Compiling .pio/build/tasmota/lib618/I2Cdevlib-Core/I2Cdev.cpp.o Compiling .pio/build/tasmota/libcfa/LibTeleinfo/LibTeleinfo.cpp.o Archiving .pio/build/tasmota/libf56/libBM8563_RTC.a Indexing .pio/build/tasmota/libf56/libBM8563_RTC.a Compiling .pio/build/tasmota/libcd3/I2Cdevlib-MPU6050/MPU6050.cpp.o Compiling .pio/build/tasmota/lib5d4/Mutichannel_Gas_Sensor/MutichannelGasSensor.cpp.o Compiling .pio/build/tasmota/lib9aa/ArduinoNTPd/NTPPacket.cpp.o Archiving .pio/build/tasmota/libe29/libAT24C256_512.a Indexing .pio/build/tasmota/libe29/libAT24C256_512.a Compiling .pio/build/tasmota/lib9aa/ArduinoNTPd/NTPServer.cpp.o Archiving .pio/build/tasmota/lib618/libI2Cdevlib-Core.a Indexing .pio/build/tasmota/lib618/libI2Cdevlib-Core.a Compiling .pio/build/tasmota/lib0f2/OpenTherm-0.9.0/OpenTherm.cpp.o Archiving .pio/build/tasmota/libcfa/libLibTeleinfo.a Indexing .pio/build/tasmota/libcfa/libLibTeleinfo.a Compiling .pio/build/tasmota/libfd6/ProcessControl/PID.cpp.o Compiling .pio/build/tasmota/libfd6/ProcessControl/Timeprop.cpp.o Archiving .pio/build/tasmota/lib5d4/libMutichannel_Gas_Sensor.a Indexing .pio/build/tasmota/lib5d4/libMutichannel_Gas_Sensor.a Compiling .pio/build/tasmota/lib2c1/arduino-tm1637/SevenSegmentAsciiMap.cpp.o Archiving .pio/build/tasmota/libfd6/libProcessControl.a Indexing .pio/build/tasmota/libfd6/libProcessControl.a Archiving .pio/build/tasmota/lib034/libESP8266Audio.a Compiling .pio/build/tasmota/lib2c1/arduino-tm1637/SevenSegmentExtended.cpp.o Compiling .pio/build/tasmota/lib2c1/arduino-tm1637/SevenSegmentFun.cpp.o Archiving .pio/build/tasmota/lib9aa/libArduinoNTPd.a Indexing .pio/build/tasmota/lib9aa/libArduinoNTPd.a Compiling .pio/build/tasmota/lib2c1/arduino-tm1637/SevenSegmentTM1637.cpp.o Indexing .pio/build/tasmota/lib034/libESP8266Audio.a Compiling .pio/build/tasmota/lib213/Unishox-1.0-shadinger/UnishoxStrings.cpp.o Compiling .pio/build/tasmota/lib213/Unishox-1.0-shadinger/unishox.cpp.o Archiving .pio/build/tasmota/lib0f2/libOpenTherm-0.9.0.a Indexing .pio/build/tasmota/lib0f2/libOpenTherm-0.9.0.a Compiling .pio/build/tasmota/libbfe/vl53l0x-arduino-1.02/VL53L0X.cpp.o Compiling .pio/build/tasmota/libea1/vl53l1x-arduino-1.01/VL53L1X.cpp.o Archiving .pio/build/tasmota/lib213/libUnishox-1.0-shadinger Indexing .pio/build/tasmota/lib213/libUnishox-1.0-shadinger Compiling .pio/build/tasmota/lib90d/C2Programmer-1.0.0/c2.cpp.o Archiving .pio/build/tasmota/libcd3/libI2Cdevlib-MPU6050.a Indexing .pio/build/tasmota/libcd3/libI2Cdevlib-MPU6050.a Compiling .pio/build/tasmota/lib90d/C2Programmer-1.0.0/ihx.cpp.o Compiling .pio/build/tasmota/libde0/cc1101/cc1101.cpp.o Compiling .pio/build/tasmota/libaf3/arduino-mcp2515-1.0.1/mcp2515.cpp.o Archiving .pio/build/tasmota/lib2c1/libarduino-tm1637.a Indexing .pio/build/tasmota/lib2c1/libarduino-tm1637.a Compiling .pio/build/tasmota/libc38/A4988_Stepper/A4988_Stepper.cpp.o Archiving .pio/build/tasmota/libbfe/libvl53l0x-arduino-1.02.a Indexing .pio/build/tasmota/libbfe/libvl53l0x-arduino-1.02.a Compiling .pio/build/tasmota/libba0/TasmotaSerial-3.5.0/TasmotaSerial.cpp.o Archiving .pio/build/tasmota/libea1/libvl53l1x-arduino-1.01.a Indexing .pio/build/tasmota/libea1/libvl53l1x-arduino-1.01.a Compiling .pio/build/tasmota/lib455/Adafruit-Fingerprint-Sensor-Library-2.0.4-Tasmota/Adafruit_Fingerprint.cpp.o Compiling .pio/build/tasmota/lib13e/Adafruit-GFX-Library-1.5.6-gemu-1.0/Adafruit_GFX.cpp.o Archiving .pio/build/tasmota/libde0/libcc1101.a Indexing .pio/build/tasmota/libde0/libcc1101.a Compiling .pio/build/tasmota/lib13e/Adafruit-GFX-Library-1.5.6-gemu-1.0/Adafruit_SPITFT.cpp.o Archiving .pio/build/tasmota/libc38/libA4988_Stepper.a Indexing .pio/build/tasmota/libc38/libA4988_Stepper.a Archiving .pio/build/tasmota/lib90d/libC2Programmer-1.0.0.a Compiling .pio/build/tasmota/lib13e/Adafruit-GFX-Library-1.5.6-gemu-1.0/glcdfont.c.o Indexing .pio/build/tasmota/lib90d/libC2Programmer-1.0.0.a Archiving .pio/build/tasmota/libaf3/libarduino-mcp2515-1.0.1.a Indexing .pio/build/tasmota/libaf3/libarduino-mcp2515-1.0.1.a Compiling .pio/build/tasmota/libf72/Adafruit_LED_Backpack-1.1.6/Adafruit_LEDBackpack.cpp.o Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/epdif.cpp.o Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/epdpaint.cpp.o Archiving .pio/build/tasmota/libba0/libTasmotaSerial-3.5.0.a Indexing .pio/build/tasmota/libba0/libTasmotaSerial-3.5.0.a Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/font12.c.o Archiving .pio/build/tasmota/lib455/libAdafruit-Fingerprint-Sensor-Library-2.0.4-Tasmota Indexing .pio/build/tasmota/lib455/libAdafruit-Fingerprint-Sensor-Library-2.0.4-Tasmota Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/font16.c.o Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/font20.c.o Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/font24.c.o Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/font24_7seg.c.o Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/font8.c.o Compiling .pio/build/tasmota/libe2a/Display_Renderer-gemu-1.0/renderer.cpp.o Compiling .pio/build/tasmota/lib802/Adafruit_SH1106-gemu-1.0/Adafruit_SH1106.cpp.o Compiling .pio/build/tasmota/lib64b/Adafruit_SSD1306-1.3.0-gemu-1.1/Adafruit_SSD1306.cpp.o Compiling .pio/build/tasmota/lib443/Adafruit_SSD1331-1.2.0/Adafruit_SPITFT_Renderer.cpp.o Compiling .pio/build/tasmota/lib443/Adafruit_SSD1331-1.2.0/Adafruit_SSD1331.cpp.o Archiving .pio/build/tasmota/libf72/libAdafruit_LED_Backpack-1.1.6.a Indexing .pio/build/tasmota/libf72/libAdafruit_LED_Backpack-1.1.6.a Compiling .pio/build/tasmota/lib054/Adafruit_TSL2591_Library/Adafruit_TSL2591.cpp.o Archiving .pio/build/tasmota/lib13e/libAdafruit-GFX-Library-1.5.6-gemu-1.0.a Indexing .pio/build/tasmota/lib13e/libAdafruit-GFX-Library-1.5.6-gemu-1.0.a Compiling .pio/build/tasmota/lib964/Arduino_ST7789-gemu-1.0/Arduino_ST7789.cpp.o Archiving .pio/build/tasmota/lib802/libAdafruit_SH1106-gemu-1.0.a Indexing .pio/build/tasmota/lib802/libAdafruit_SH1106-gemu-1.0.a Compiling .pio/build/tasmota/lib31a/DHT-sensor-library/DHT.cpp.o Compiling .pio/build/tasmota/lib954/DNSServer/DNSServer.cpp.o Archiving .pio/build/tasmota/lib054/libAdafruit_TSL2591_Library.a Indexing .pio/build/tasmota/lib054/libAdafruit_TSL2591_Library.a Compiling .pio/build/tasmota/lib4fa/ESP8266SAM/ESP8266SAM.cpp.o Archiving .pio/build/tasmota/libe2a/libDisplay_Renderer-gemu-1.0.a Indexing .pio/build/tasmota/libe2a/libDisplay_Renderer-gemu-1.0.a Compiling .pio/build/tasmota/lib4fa/ESP8266SAM/esp8266sam_debug.c.o Archiving .pio/build/tasmota/lib64b/libAdafruit_SSD1306-1.3.0-gemu-1.1.a Indexing .pio/build/tasmota/lib64b/libAdafruit_SSD1306-1.3.0-gemu-1.1.a Archiving .pio/build/tasmota/lib443/libAdafruit_SSD1331-1.2.0.a Compiling .pio/build/tasmota/lib4fa/ESP8266SAM/reciter.c.o Indexing .pio/build/tasmota/lib443/libAdafruit_SSD1331-1.2.0.a Compiling .pio/build/tasmota/lib4fa/ESP8266SAM/render.c.o Compiling .pio/build/tasmota/lib4fa/ESP8266SAM/sam.c.o Compiling .pio/build/tasmota/libd66/ESP8266WebServer/detail/mimetable.cpp.o Archiving .pio/build/tasmota/lib964/libArduino_ST7789-gemu-1.0.a Indexing .pio/build/tasmota/lib964/libArduino_ST7789-gemu-1.0.a Compiling .pio/build/tasmota/libbdd/ESP8266httpUpdate/ESP8266httpUpdate.cpp.o Archiving .pio/build/tasmota/libd66/libESP8266WebServer.a Indexing .pio/build/tasmota/libd66/libESP8266WebServer.a Compiling .pio/build/tasmota/lib911/ESP8266mDNS/ESP8266mDNS.cpp.o Archiving .pio/build/tasmota/lib31a/libDHT-sensor-library.a Compiling .pio/build/tasmota/lib911/ESP8266mDNS/ESP8266mDNS_Legacy.cpp.o Indexing .pio/build/tasmota/lib31a/libDHT-sensor-library.a Compiling .pio/build/tasmota/lib911/ESP8266mDNS/LEAmDNS.cpp.o Compiling .pio/build/tasmota/lib911/ESP8266mDNS/LEAmDNS_Control.cpp.o Archiving .pio/build/tasmota/lib4fa/libESP8266SAM.a Indexing .pio/build/tasmota/lib4fa/libESP8266SAM.a Compiling .pio/build/tasmota/lib911/ESP8266mDNS/LEAmDNS_Helpers.cpp.o Archiving .pio/build/tasmota/lib954/libDNSServer.a Indexing .pio/build/tasmota/lib954/libDNSServer.a Compiling .pio/build/tasmota/lib911/ESP8266mDNS/LEAmDNS_Structs.cpp.o Compiling .pio/build/tasmota/lib911/ESP8266mDNS/LEAmDNS_Transfer.cpp.o Archiving .pio/build/tasmota/libbdd/libESP8266httpUpdate.a Indexing .pio/build/tasmota/libbdd/libESP8266httpUpdate.a Compiling .pio/build/tasmota/libca6/lib_mail/ESP_Mail_Client.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/extras/ESPTimeHelper.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/extras/RFC2047.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/wcs/esp32/ESP_Mail_HTTPClient32.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/wcs/esp32/ESP_Mail_WCS32.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/wcs/esp32/esp_mail_ssl_client32.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/wcs/esp8266/ESP_Mail_BearSSLHelpers.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/wcs/esp8266/ESP_Mail_CertStoreBearSSL.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/wcs/esp8266/ESP_Mail_HTTPClient.cpp.o Compiling .pio/build/tasmota/libca6/lib_mail/wcs/esp8266/ESP_Mail_WCS.cpp.o Compiling .pio/build/tasmota/libe10/FT5206_Library/FT5206.cpp.o Archiving .pio/build/tasmota/lib911/libESP8266mDNS.a Indexing .pio/build/tasmota/lib911/libESP8266mDNS.a Compiling .pio/build/tasmota/lib104/FrogmoreScd30/FrogmoreScd30.cpp.o Compiling .pio/build/tasmota/lib40a/FrogmoreScd40/FrogmoreScd40.cpp.o Archiving .pio/build/tasmota/libe10/libFT5206_Library.a Indexing .pio/build/tasmota/libe10/libFT5206_Library.a Compiling .pio/build/tasmota/libde0/ILI9341-gemu-1.0/ILI9341_2.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/IRac.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/IRrecv.cpp.o Archiving .pio/build/tasmota/lib104/libFrogmoreScd30.a Indexing .pio/build/tasmota/lib104/libFrogmoreScd30.a Compiling .pio/build/tasmota/lib351/IRremoteESP8266/IRsend.cpp.o Archiving .pio/build/tasmota/lib40a/libFrogmoreScd40.a Indexing .pio/build/tasmota/lib40a/libFrogmoreScd40.a Compiling .pio/build/tasmota/lib351/IRremoteESP8266/IRtext.cpp.o Archiving .pio/build/tasmota/libde0/libILI9341-gemu-1.0.a Indexing .pio/build/tasmota/libde0/libILI9341-gemu-1.0.a Compiling .pio/build/tasmota/lib351/IRremoteESP8266/IRtimer.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/IRutils.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Airton.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Airwell.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Aiwa.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Amcor.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Argo.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Arris.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Bose.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Carrier.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Coolix.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Corona.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Daikin.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Delonghi.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Denon.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Dish.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Doshisha.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Ecoclim.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Electra.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_EliteScreens.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Epson.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Fujitsu.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_GICable.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_GlobalCache.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Goodweather.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Gree.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Haier.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Hitachi.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Inax.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_JVC.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Kelon.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Kelvinator.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_LG.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Lasertag.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Lego.cpp.o Archiving .pio/build/tasmota/libca6/lib_mail.a Indexing .pio/build/tasmota/libca6/lib_mail.a Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Lutron.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_MWM.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Magiquest.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Metz.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Midea.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_MilesTag2.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Mirage.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Mitsubishi.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_MitsubishiHeavy.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Multibrackets.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_NEC.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Neoclima.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Nikai.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Panasonic.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Pioneer.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Pronto.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_RC5_RC6.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_RCMM.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Rhoss.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Samsung.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Sanyo.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Sharp.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Sherwood.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Sony.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Symphony.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Tcl.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Technibel.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Teco.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Teknopoint.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Toshiba.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Transcold.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Trotec.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Truma.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Vestel.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Voltas.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Whirlpool.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Whynter.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Xmp.cpp.o Compiling .pio/build/tasmota/lib351/IRremoteESP8266/ir_Zepeal.cpp.o Compiling .pio/build/tasmota/lib336/jsmn-shadinger-1.0/JsonGenerator.cpp.o Compiling .pio/build/tasmota/lib336/jsmn-shadinger-1.0/JsonParser.cpp.o Compiling .pio/build/tasmota/lib336/jsmn-shadinger-1.0/jsmn.cpp.o Compiling .pio/build/tasmota/lib526/KeeloqLib/KeeloqLib.cpp.o Compiling .pio/build/tasmota/libe5d/LOLIN_HP303B/LOLIN_HP303B.cpp.o Compiling .pio/build/tasmota/lib93a/LedControl/LedControl.cpp.o Compiling .pio/build/tasmota/lib93a/LedControl/LedMatrix.cpp.o Compiling .pio/build/tasmota/libb2e/LiquidCrystal_I2C-1.1.3/LiquidCrystal_I2C.cpp.o Archiving .pio/build/tasmota/lib351/libIRremoteESP8266.a Indexing .pio/build/tasmota/lib351/libIRremoteESP8266.a Compiling .pio/build/tasmota/lib124/rfid-1.4.7/MFRC522.cpp.o Compiling .pio/build/tasmota/lib124/rfid-1.4.7/MFRC522Extended.cpp.o Archiving .pio/build/tasmota/lib336/libjsmn-shadinger-1.0.a Indexing .pio/build/tasmota/lib336/libjsmn-shadinger-1.0.a Compiling .pio/build/tasmota/lib410/mlx90640-library/MLX90640_API.cpp.o Archiving .pio/build/tasmota/lib526/libKeeloqLib.a Indexing .pio/build/tasmota/lib526/libKeeloqLib.a Compiling .pio/build/tasmota/libb66/MPU_accel/MPU_accel.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/Esp32_i2s.c.o Archiving .pio/build/tasmota/lib93a/libLedControl.a Indexing .pio/build/tasmota/lib93a/libLedControl.a Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/HsbColor.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/HslColor.cpp.o Archiving .pio/build/tasmota/libb2e/libLiquidCrystal_I2C-1.1.3.a Indexing .pio/build/tasmota/libb2e/libLiquidCrystal_I2C-1.1.3.a Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/HtmlColor.cpp.o Archiving .pio/build/tasmota/libe5d/libLOLIN_HP303B.a Indexing .pio/build/tasmota/libe5d/libLOLIN_HP303B.a Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/HtmlColorNameStrings.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/HtmlColorNames.cpp.o Archiving .pio/build/tasmota/libb66/libMPU_accel.a Indexing .pio/build/tasmota/libb66/libMPU_accel.a Archiving .pio/build/tasmota/lib410/libmlx90640-library.a Indexing .pio/build/tasmota/lib410/libmlx90640-library.a Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/HtmlColorShortNames.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/NeoEsp32RmtMethod.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/NeoEsp8266DmaMethod.cpp.o Archiving .pio/build/tasmota/lib124/librfid-1.4.7.a Indexing .pio/build/tasmota/lib124/librfid-1.4.7.a Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/NeoEsp8266UartMethod.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/NeoEspBitBangMethod.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/NeoGamma.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/NeoPixelAnimator.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/NeoPixelAvr.c.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/Rgb48Color.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/RgbColor.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/RgbColorBase.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/RgbwColor.cpp.o Compiling .pio/build/tasmota/libd3f/NeoPixelBus/internal/SegmentDigit.cpp.o Compiling .pio/build/tasmota/libc83/NewPing-1.9.1/NewPing.cpp.o Compiling .pio/build/tasmota/libc2b/OneWire-Stickbreaker/OneWire.cpp.o Compiling .pio/build/tasmota/lib462/pubsubclient-2.8.13/PubSubClient.cpp.o Compiling .pio/build/tasmota/libe60/Xlatb_RA8876-gemu-1.0/RA8876.cpp.o Compiling .pio/build/tasmota/lib404/rc-switch/RCSwitch.cpp.o Compiling .pio/build/tasmota/liba21/RF24/RF24.cpp.o Compiling .pio/build/tasmota/libd18/Ext-printf/ext_printf.cpp.o Archiving .pio/build/tasmota/libd3f/libNeoPixelBus.a Archiving .pio/build/tasmota/libc83/libNewPing-1.9.1.a Indexing .pio/build/tasmota/libd3f/libNeoPixelBus.a Indexing .pio/build/tasmota/libc83/libNewPing-1.9.1.a Compiling .pio/build/tasmota/lib73d/Adafruit_SSD1351-gemu-1.0/SSD1351.cpp.o Compiling .pio/build/tasmota/lib73d/Adafruit_SSD1351-gemu-1.0/Tiger.c.o Compiling .pio/build/tasmota/lib34b/TM1638plus/TM1638plus.cpp.o Archiving .pio/build/tasmota/libc2b/libOneWire-Stickbreaker.a Indexing .pio/build/tasmota/libc2b/libOneWire-Stickbreaker.a Compiling .pio/build/tasmota/lib34b/TM1638plus/TM1638plus_common.cpp.o Archiving .pio/build/tasmota/lib404/librc-switch.a Indexing .pio/build/tasmota/lib404/librc-switch.a Compiling .pio/build/tasmota/libc06/TasmotaModbus-3.4.0/TasmotaModbus.cpp.o Archiving .pio/build/tasmota/libd18/libExt-printf.a Indexing .pio/build/tasmota/libd18/libExt-printf.a Compiling .pio/build/tasmota/lib426/Ticker/Ticker.cpp.o Archiving .pio/build/tasmota/liba21/libRF24.a Archiving .pio/build/tasmota/lib462/libpubsubclient-2.8.13.a Indexing .pio/build/tasmota/liba21/libRF24.a Indexing .pio/build/tasmota/lib462/libpubsubclient-2.8.13.a Archiving .pio/build/tasmota/libe60/libXlatb_RA8876-gemu-1.0.a Indexing .pio/build/tasmota/libe60/libXlatb_RA8876-gemu-1.0.a Compiling .pio/build/tasmota/lib62d/Joba_Tsl2561-2.0.10/Tsl2561.cpp.o Compiling .pio/build/tasmota/lib62d/Joba_Tsl2561-2.0.10/Tsl2561Util.cpp.o Compiling .pio/build/tasmota/lib48e/XPT2046_Touchscreen/XPT2046_Touchscreen.cpp.o Archiving .pio/build/tasmota/lib73d/libAdafruit_SSD1351-gemu-1.0.a Indexing .pio/build/tasmota/lib73d/libAdafruit_SSD1351-gemu-1.0.a Compiling .pio/build/tasmota/lib2b5/BME68x-Sensor-API/bme68x.c.o Archiving .pio/build/tasmota/lib34b/libTM1638plus.a Compiling .pio/build/tasmota/libf9a/Epaper_29-gemu-1.0/epd2in9.cpp.o Indexing .pio/build/tasmota/lib34b/libTM1638plus.a Compiling .pio/build/tasmota/lib963/Epaper_42-gemu-1.0/epd4in2.cpp.o Archiving .pio/build/tasmota/lib426/libTicker.a Indexing .pio/build/tasmota/lib426/libTicker.a Compiling .pio/build/tasmota/lib42e/EEPROM/EEPROM.cpp.o Archiving .pio/build/tasmota/libc06/libTasmotaModbus-3.4.0.a Indexing .pio/build/tasmota/libc06/libTasmotaModbus-3.4.0.a Compiling .pio/build/tasmota/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip-config.cpp.o Archiving .pio/build/tasmota/lib2b5/libBME68x-Sensor-API.a Indexing .pio/build/tasmota/lib2b5/libBME68x-Sensor-API.a Compiling .pio/build/tasmota/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip-conversion.cpp.o Compiling .pio/build/tasmota/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip-send.cpp.o Archiving .pio/build/tasmota/lib62d/libJoba_Tsl2561-2.0.10.a Indexing .pio/build/tasmota/lib62d/libJoba_Tsl2561-2.0.10.a Archiving .pio/build/tasmota/lib48e/libXPT2046_Touchscreen.a Indexing .pio/build/tasmota/lib48e/libXPT2046_Touchscreen.a Compiling .pio/build/tasmota/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip-webserver.cpp.o Compiling .pio/build/tasmota/lib6a9/esp-knx-ip-0.5.2/esp-knx-ip.cpp.o Archiving .pio/build/tasmota/libf9a/libEpaper_29-gemu-1.0.a Indexing .pio/build/tasmota/libf9a/libEpaper_29-gemu-1.0.a Compiling .pio/build/tasmota/lib669/HPMA115S0/hpma115S0.cpp.o Archiving .pio/build/tasmota/lib42e/libEEPROM.a Archiving .pio/build/tasmota/lib963/libEpaper_42-gemu-1.0.a Indexing .pio/build/tasmota/lib42e/libEEPROM.a Indexing .pio/build/tasmota/lib963/libEpaper_42-gemu-1.0.a Compiling .pio/build/tasmota/libe8a/stm32flash-1.0-tasmota/stm32flash.cpp.o Compiling .pio/build/tasmota/libeb1/UDisplay/uDisplay.cpp.o Archiving .pio/build/tasmota/lib669/libHPMA115S0.a Indexing .pio/build/tasmota/lib669/libHPMA115S0.a Archiving .pio/build/tasmota/libFrameworkArduinoVariant.a Indexing .pio/build/tasmota/libFrameworkArduinoVariant.a Compiling .pio/build/tasmota/FrameworkArduino/Crypto.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/Esp-frag.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/Esp-version.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/Esp.cpp.o Archiving .pio/build/tasmota/libe8a/libstm32flash-1.0-tasmota Indexing .pio/build/tasmota/libe8a/libstm32flash-1.0-tasmota Compiling .pio/build/tasmota/FrameworkArduino/FS.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/FSnoop.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/FunctionalInterrupt.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/HardwareSerial.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/IPAddress.cpp.o Archiving .pio/build/tasmota/libeb1/libUDisplay.a Indexing .pio/build/tasmota/libeb1/libUDisplay.a Compiling .pio/build/tasmota/FrameworkArduino/MD5Builder.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/Print.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/Schedule.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/StackThunk.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/Stream.cpp.o Archiving .pio/build/tasmota/lib6a9/libesp-knx-ip-0.5.2.a Indexing .pio/build/tasmota/lib6a9/libesp-knx-ip-0.5.2.a Compiling .pio/build/tasmota/FrameworkArduino/StreamString.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/Tone.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/TypeConversion.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/Updater.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/WMath.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/WString.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/abi.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/base64.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/cbuf.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/cont.S.o Compiling .pio/build/tasmota/FrameworkArduino/cont_util.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_app_entry_noextra4k.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_eboot_command.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_features.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_flash_quirks.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_flash_utils.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_i2s.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_main.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_noniso.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_phy.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_postmortem.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_si2c.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_sigma_delta.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_spi_utils.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_timer.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_waveform_phase.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_waveform_pwm.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_wiring.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_wiring_analog.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_wiring_digital.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_wiring_pulse.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_wiring_pwm.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/core_esp8266_wiring_shift.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/crc32.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/debug.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/flash_hal.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/gdb_hooks.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/heap.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/libb64/cdecode.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/libb64/cencode.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/libc_replacements.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/sntp-lwip2.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/spiffs/spiffs_cache.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/spiffs/spiffs_check.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/spiffs/spiffs_gc.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/spiffs/spiffs_hydrogen.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/spiffs/spiffs_nucleus.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/spiffs_api.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/sqrt32.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/time.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/uart.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/umm_malloc/umm_info.c.o Compiling .pio/build/tasmota/FrameworkArduino/umm_malloc/umm_integrity.c.o Compiling .pio/build/tasmota/FrameworkArduino/umm_malloc/umm_local.c.o Compiling .pio/build/tasmota/FrameworkArduino/umm_malloc/umm_malloc.cpp.o Compiling .pio/build/tasmota/FrameworkArduino/umm_malloc/umm_poison.c.o Archiving .pio/build/tasmota/libFrameworkArduino.a Indexing .pio/build/tasmota/libFrameworkArduino.a Linking .pio/build/tasmota/firmware.elf Retrieving maximum program size .pio/build/tasmota/firmware.elf Checking size .pio/build/tasmota/firmware.elf Advanced Memory Usage is available via "PlatformIO Home > Project Inspect" RAM: [===== ] 50.2% (used 41120 bytes from 81920 bytes) Flash: [====== ] 62.2% (used 637260 bytes from 1023984 bytes) Building .pio/build/tasmota/firmware.bin Creating BIN file ".pio/build/tasmota/firmware.bin" using "/.platformio/packages/framework-arduinoespressif8266@2.7.4+9/bootloaders/eboot/eboot.elf" and ".pio/build/tasmota/firmware.elf" bin_map_copy([".pio/build/tasmota/firmware.bin"], [".pio/build/tasmota/firmware.elf"]) map_gzip([".pio/build/tasmota/firmware.bin"], [".pio/build/tasmota/firmware.elf"]) bin_gzip([".pio/build/tasmota/firmware.bin"], [".pio/build/tasmota/firmware.elf"]) Compression reduced firmware size by 71% (was 641408 bytes, now 456955 bytes) ===================================================================== [SUCCESS] Took 69.08 seconds ===================================================================== Environment Status Duration ------------- -------- ------------ tasmota SUCCESS 00:01:09.084 ===================================================================== 1 succeeded in 00:01:09.084 ===================================================================== All done! Find your builds in Tasmota/build_output/firmware/ mw@linux-kwm1:/dev/shm/Tasmota >ls -l Tasmota/build_output/firmware/ total 3980 -rw-r--r-- 1 mw root 1450640 Apr 21 14:44 tasmota32-DE.bin -rw-r--r-- 1 mw root 1516176 Apr 21 14:44 tasmota32-DE.factory.bin -rw-r--r-- 1 mw root 641408 Apr 21 15:10 tasmota.bin -rw-r--r-- 1 mw root 456955 Apr 21 15:10 tasmota.bin.gz
