/* ATSHA204A I2C Examples Version: 1.0 Author: Alex from insideGadgets (http://www.insidegadgets.com) Created: 21/04/2017 Last Modified: 21/04/2017 Open serial monitor at 9600 to access the ATSHA204A commands such as: "wake" - Tests to see if waking up the device works "read" - Print out the configuration zone "write" - Write 4 bytes to slot config 0 & 1 in the configuration zone (0x80 0x80 0x00 0x00), slot 1 reads/writes allowed "rand" - Return a 32 byte random number, it's only random if the configuration zone is locked "lockconfig" - Lock the configuration zone. *Be careful, once locked, it can't be unlocked* "lockdata" - Lock the data and OTP zones. *Be careful, once locked, it can't be unlocked* "loadkey" - Write a 32 byte number in slot 1, this will be our secret key. *You should change the number* "printkey" - Read a 32 byte number in slot 1 "nonce" - Use the pass through mode to load a 32 byte number into TempKey "hmac" - Combines the nonce with slot 0 key to generate the HMAC result */ #include " " #include // I2C settings uint8_t I2C_DELAY_CYCLES = 2; #define I2C_READ 1 #define I2C_WRITE 0 #define NOREPEATSTART 0 #define REPEATSTART 1 #define TWI_SDA_PIN PC4 #define TWI_SCL_PIN PC5 #define cryptoauth_address 0xC8 #define PACKET_COUNT 0 #define FUNCTION_RESET 0x00 #define FUNCTION_SLEEP 0x01 #define FUNCTION_IDLE 0x02 #define FUNCTION_COMMAND 0x03 #define COMMAND_READ 0x02 #define COMMAND_WRITE 0x12 #define COMMAND_HMAC 0x11 #define COMMAND_NONCE 0x16 #define COMMAND_RANDOM 0x1B #define COMMAND_LOCK 0x17 #define ZONE_ENCODING_CONFIG 0 #define ZONE_ENCODING_OTP 1 #define ZONE_ENCODING_DATA 2 #define ZONE_LOCK_CONFIG 0 #define ZONE_LOCK_DATA_OTP 1 #define NONCE_PASS_THROUGH 0x03 #define READ_4_BYTES 0x00 #define READ_32_BYTES 0x80 #define LOCK_NO_CRC_CHECK 0x80 #define SLOT_0 0x00 #define SLOT_1 0x08 uint8_t data_out[40]; uint8_t data_in[35]; uint8_t crc[2]; uint8_t counter = 0; void setup() { Serial.begin(9600); // Initialse I2C DDRC &= ~(1< 0) { char c = Serial.read(); readInput[readCount] = c; readCount++; } readInput[readCount] = '\0'; // Test to see if the device wakes up if (strstr(readInput, "wake")) { sha204a_wakeup(); sha204a_sleep(); } // Read config zone else if (strstr(readInput, "read")) { sha204a_print_config(); } // Write slot config 0 & 1 else if (strstr(readInput, "write")) { sha204a_wakeup(); data_out[0] = FUNCTION_COMMAND; // command //0x03 data_out[1] = 9 + 2; // count (included in count + crc (add 2)) //11 data_out[2] = COMMAND_WRITE; //0x12 data_out[3] = ZONE_ENCODING_CONFIG; //0 data_out[4] = 5; //5 data_out[5] = 0; //0 data_out[6] = 0x80; data_out[7] = 0x80; data_out[8] = 0x0; data_out[9] = 0x0; sha204c_calculate_crc(9, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 10; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(50); sha204a_read_buffer(); sha204a_sleep(); } // Read random number else if (strstr(readInput, "rand")) { sha204a_wakeup(); if (soft_i2c_master_start(cryptoauth_address | I2C_WRITE)) { data_out[0] = FUNCTION_COMMAND; // command data_out[1] = 7; // count (included in count) data_out[2] = COMMAND_RANDOM; data_out[3] = 0; data_out[4] = 0; data_out[5] = 0; sha204c_calculate_crc(5, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 6; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(50); sha204a_read_buffer(); sha204a_sleep(); } } // Lock configuration else if (strstr(readInput, "lockconfig")) { sha204a_print_config(); Serial.println("\nGoing to lock configuration zone, are you sure? y/n"); // Wait for serial input while (Serial.available() <= 0) { delay(50); } // Decode input readCount = 0; while (Serial.available() > 0) { char c = Serial.read(); readInput[readCount] = c; readCount++; } readInput[readCount] = '\0'; // Yes if (strstr(readInput, "y")) { sha204a_wakeup(); if (soft_i2c_master_start(cryptoauth_address | I2C_WRITE)) { data_out[0] = FUNCTION_COMMAND; // command data_out[1] = 7; // count (included in count) data_out[2] = COMMAND_LOCK; data_out[3] = ZONE_LOCK_CONFIG | LOCK_NO_CRC_CHECK; data_out[4] = 0; data_out[5] = 0; sha204c_calculate_crc(5, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 6; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(30); sha204a_read_buffer(); sha204a_sleep(); } else { Serial.println("not ack addr"); } } else { Serial.println("Aborted"); } } // Lock data / otp else if (strstr(readInput, "lockdata")) { Serial.println("\nGoing to lock data and otp zones, are you sure? y/n"); // Wait for serial input while (Serial.available() <= 0) { delay(50); } // Decode input readCount = 0; while (Serial.available() > 0) { char c = Serial.read(); readInput[readCount] = c; readCount++; } readInput[readCount] = '\0'; // Yes if (strstr(readInput, "y")) { sha204a_wakeup(); if (soft_i2c_master_start(cryptoauth_address | I2C_WRITE)) { data_out[0] = FUNCTION_COMMAND; // command data_out[1] = 7; // count (included in count) data_out[2] = COMMAND_LOCK; data_out[3] = ZONE_LOCK_DATA_OTP | LOCK_NO_CRC_CHECK; data_out[4] = 0; data_out[5] = 0; sha204c_calculate_crc(5, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 6; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(30); sha204a_read_buffer(); sha204a_sleep(); } else { Serial.println("not ack addr"); } } else { Serial.println("Aborted"); } } // Write data key to slot 1 else if (strstr(readInput, "loadkey")) { sha204a_wakeup(); if (soft_i2c_master_start(cryptoauth_address | I2C_WRITE)) { data_out[0] = FUNCTION_COMMAND; // command data_out[1] = 7 + 32; // count (included in count) data_out[2] = COMMAND_WRITE; data_out[3] = ZONE_ENCODING_DATA | READ_32_BYTES; data_out[4] = SLOT_1; data_out[5] = 0; uint8_t privkey[32] = {0x22, 0x24, 0x25, 0xB9, 0xA3, 0x6C, 0x44, 0x53, 0x5F, 0xA1, 0x32, 0x9F, 0x37, 0xCC, 0x6E, 0x49, 0x45, 0x02, 0x20, 0x9E, 0x5D, 0xDD, 0x02, 0x32, 0xF3, 0xC5, 0x4E, 0x1A, 0x3A, 0x3E, 0x44, 0x55}; for (uint8_t x = 0; x <= 32; x++) { data_out[x+6] = privkey[x]; } sha204c_calculate_crc(5 + 32, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 6 + 32; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(50); sha204a_read_buffer(); sha204a_sleep(); } } // Read data key from slot 1 else if (strstr(readInput, "printkey")) { sha204a_wakeup(); sha204a_read_data(SLOT_1, READ_32_BYTES); sha204a_read_buffer(); sha204a_sleep(); } // Nonce to load 32 byte random number else if (strstr(readInput, "nonce")) { sha204a_wakeup(); uint8_t randomnumber[32] = {0x71, 0xE2, 0x34, 0xF3, 0xDF, 0xD4, 0x51, 0x3B, 0x6E, 0x83, 0x6D, 0xF4, 0xC7, 0xBD, 0xC2, 0x1B, 0xD6, 0xE2, 0xF5, 0xA7, 0x92, 0x2C, 0x64, 0xB0, 0x25, 0x57, 0x15, 0xC1, 0x04, 0x49, 0xA2, 0xD0}; if (soft_i2c_master_start(cryptoauth_address | I2C_WRITE)) { data_out[0] = FUNCTION_COMMAND; // command data_out[1] = 7 + 32; // count (included in count) data_out[2] = COMMAND_NONCE; data_out[3] = NONCE_PASS_THROUGH; data_out[4] = 0; data_out[5] = 0; for (uint8_t x = 0; x < 32; x++) { data_out[x+6] = randomnumber[x]; } sha204c_calculate_crc(5 + 32, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 6 + 32; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(60); sha204a_read_buffer(); sha204a_idle(); } } // HMAC the challenge with the key else if (strstr(readInput, "hmac")) { sha204a_wakeup(); if (soft_i2c_master_start(cryptoauth_address | I2C_WRITE)) { data_out[0] = FUNCTION_COMMAND; // command data_out[1] = 7; // count (included in count) data_out[2] = COMMAND_HMAC; data_out[3] = 0x04; //mode, TempKey.SourceFlag, 1 = Input data_out[4] = SLOT_0; data_out[5] = 0; sha204c_calculate_crc(5, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 6; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(70); sha204a_read_buffer(); sha204a_idle(); } } } void sha204a_read_buffer(void) { if (soft_i2c_master_start(cryptoauth_address | I2C_READ)) { uint8_t x = 0; data_in[x] = soft_i2c_master_read(0); Serial.print("Count = 0x"); if (data_in[x] <= 0x0F) { Serial.print("0"); } Serial.print(data_in[PACKET_COUNT], HEX); Serial.print(", "); x++; Serial.print("Data = "); while (x < (data_in[PACKET_COUNT] - 2)) { data_in[x] = soft_i2c_master_read(0); Serial.print("0x"); if (data_in[x] <= 0x0F) { Serial.print("0"); } Serial.print(data_in[x], HEX); Serial.print(", "); x++; } Serial.print(", CRC = "); data_in[x] = soft_i2c_master_read(0); Serial.print("0x"); if (data_in[x] <= 0x0F) { Serial.print("0"); } Serial.print(data_in[x], HEX); Serial.print(", "); x++; data_in[x] = soft_i2c_master_read(1); Serial.print("0x"); if (data_in[x] <= 0x0F) { Serial.print("0"); } Serial.print(data_in[x], HEX); Serial.print(" "); x++; soft_i2c_master_stop(); // Check CRC matches if (sha204c_check_crc(data_in) == true) { Serial.println("CRC Ok"); } else { Serial.println("CRC Failed"); } } else { Serial.println("not ack addr"); } } void sha204a_read_data(uint8_t address, uint8_t readCount) { data_out[0] = FUNCTION_COMMAND; // command data_out[1] = 7; // count (included in count) data_out[2] = COMMAND_READ; // read data_out[3] = ZONE_ENCODING_DATA | readCount; data_out[4] = address; data_out[5] = 0; sha204c_calculate_crc(5, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 6; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(4); } void sha204a_read(uint8_t address, uint8_t readCount) { data_out[0] = FUNCTION_COMMAND; // command data_out[1] = 7; // count (included in count) data_out[2] = COMMAND_READ; // read data_out[3] = ZONE_ENCODING_CONFIG | readCount; data_out[4] = address; data_out[5] = 0; sha204c_calculate_crc(5, &data_out[1], crc); // crc starts at count soft_i2c_master_start(cryptoauth_address | I2C_WRITE); for (uint8_t x = 0; x < 6; x++) { soft_i2c_master_write(data_out[x]); } soft_i2c_master_write(crc[0]); soft_i2c_master_write(crc[1]); soft_i2c_master_stop(); delay(4); } void sha204c_calculate_crc(uint8_t length, uint8_t *data, uint8_t *crc) { uint8_t counter; uint16_t crc_register = 0; uint16_t polynom = 0x8005; uint8_t shift_register; uint8_t data_bit, crc_bit; for (counter = 0; counter < length; counter++) { for (shift_register = 0x01; shift_register > 0x00; shift_register <<= 1) { data_bit = (data[counter] & shift_register) ? 1 : 0; crc_bit = crc_register >> 15; crc_register <<= 1; if (data_bit != crc_bit) crc_register ^= polynom; } } crc[0] = (uint8_t) (crc_register & 0x00FF); crc[1] = (uint8_t) (crc_register >> 8); } uint8_t sha204c_check_crc(uint8_t *data) { uint8_t crc[2]; uint8_t count = data[PACKET_COUNT]; sha204c_calculate_crc(count - 2, data, crc); if (data[(count-2)] == crc[0] && (data[(count-1)] == crc[1])) { return true; } return false; } uint8_t sha204a_wakeup(void) { DDRC |= (1<>= 1) { // Don't change this loop unless you verify the change with a scope if (m & data) { DDRC &= ~(1<
