#include "web_services.h"
#include "RTClib.h"
// get hours and minutes
#define gethrs(mts) ((mts) / 60)
#define getmts(mts) ((mts) % 60)
#define DEBUG 1
const char *ssid = "PM-Lüftersteuerung";
//const char *password = "220805";
const byte DNS_PORT = 53;
extern uint8_t state;
extern String config_file;
AsyncWebServer server(80);
extern uint16_t start_time[7];
extern uint16_t stop_time[7];
extern uint8_t status[7];
extern RTC_DS3231 rtc;
String file_data;
uint8_t reponded = 0;
const char header_html[] PROGMEM = R"rawliteral(
)rawliteral";
const char rem_body[] PROGMEM = R"rawliteral(
)rawliteral";
// enum STATES {STARTUP, IDLE, BTN_PRESSED, AP_ACTIVE, AP_INACTIVE};
// uint32_t uploadsize,uploadtime,start;
String get_time_str(uint16_t minu)
String time_str = "";
if (geth(minu) < 10)
time_str = "0";
time_str += String(gethrs(minu)) + ":";
if (getmts(minu) < 10)
time_str += "0";
time_str += String(getmts(minu));
return time_str;
String get_html_table()
String table;
table = "Lüfter Steuerung
return table;
String get_jsdate_fn()
String fnc;
uint8_t h, m, d,mo;
uint16_t y;
DateTime now;
now = rtc.now();
h = now.hour();
m = now.minute();
d = now.day();
mo = now.month();
y = now.year();
int th = h%12;
String hStr,mStr,dStr,moStr,yStr;
//th = h %12;
th = h %24;
if (th==0) {
// hStr = "12";
hStr = "24";
else if(th<10) hStr = "0"+String(th);
else hStr = String(th);
mStr=m<10?"0"+String(m):String(m);
dStr=d<10?"0"+String(d):String(d);
moStr=mo<10?"0"+String(mo):String(mo);
yStr = String(y);
yStr = String(y);
//String dateStr = moStr+"/"+dStr+"/"+yStr+"
"+hStr+":"+mStr;
String dateStr = dStr+"."+moStr+"."+yStr+"
"+hStr+":"+mStr;
//if(h<12) dateStr += " AM";
//else dateStr += " PM";
dateStr += " Uhr";
fnc = ""+dateStr+"
\n";
return fnc;
void handleUpload(AsyncWebServerRequest *request, String filename, size_t index, uint8_t *data, size_t len, bool final)
if (!index)
#ifdef DEBUG
Serial.printf("UploadStart: %s\n", filename.c_str());
#endif
file_data = "";
for (size_t i = 0; i < len; i++)
#ifdef DEBUG
Serial.write(data[i]);
#endif
file_data += String((char)data[i]);
if (data[i - 1] == ']' && data[i] == '}')
break;
if (final)
#ifdef DEBUG
Serial.printf("UploadEnd: %s, %u B\n", filename.c_str(), index + len);
#endif
Serial.print(file_data);
save_config_file(DEFAULT_CONFIG_FILE, file_data);
int r = load_config(start_time, stop_time, status, DEFAULT_CONFIG_FILE);
state = STARTUP;
request-> redirect("/uploadmsg");
void web_services_init()
#ifdef DEBUG
Serial.print("Setting AP (Access Point)…");
#endif
// Remove the password parameter, if you want the AP (Access Point) to be open
WiFi.softAP(ssid);
IPAddress IP = WiFi.softAPIP();
Serial.println();
Serial.print("AP IP address: ");
Serial.println(IP);
// // Print ESP8266 Local IP Address
// Serial.println(WiFi.localIP());
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
state = WAIT4RES;
String head = String(header_html);
String fn = get_jsdate_fn();
String table = get_html_table();
String rem = String(rem_body);
String foot = String(footer_html);
String resp = head + fn + table + rem+ foot;
request->send_P(200, "text/html", (resp).c_str()); });
// downloadconfig
server.on("/downloadconfig", HTTP_GET, [](AsyncWebServerRequest *request){
state = STARTUP;
request->send(SPIFFS,DEFAULT_CONFIG_FILE, String(), true);
// downloadconfig
server.on("/uploadmsg", HTTP_GET, [](AsyncWebServerRequest *request){
state = STARTUP;
delay(100);
String upload_msg = " Datei gespeichert!
\n";
String resp = head + fn + upload_msg +table + rem+ foot;
// load selected file for pump timing
server.on("/updatertc", HTTP_GET, [](AsyncWebServerRequest *request){
state = STARTUP;
uint16_t yr;
uint8_t mont, dy, hrs, minu, sec;
String thisy = request->getParam("y")->value();
String thismo = request->getParam("mo")->value();
String thisd = request->getParam("d")->value();
String thish = request->getParam("h")->value();
String thism = request->getParam("m")->value();
String thiss = request->getParam("s")->value();
yr = thisy.toInt(); mont = thismo.toInt(); dy = thisd.toInt();
hrs = thish.toInt(); minu = thism.toInt(); sec = thiss.toInt();
delay(10);
#ifdef DEBUG
Serial.printf("%d\n",yr);
#endif
rtc.adjust(DateTime(yr, mont, dy, hrs, minu, sec));
delay(10);
// server.on("/handleupload", HTTP_POST, [](AsyncWebServerRequest * request) {},
server.on("/handleupload", HTTP_POST, [](AsyncWebServerRequest *request)
{ request->send(200); },
handleUpload);
// save file
server.onRequestBody([](AsyncWebServerRequest *request, uint8_t *data, size_t len, size_t index, size_t total){
state = STARTUP;
String myjson;
if (request->url() == "/submit")
int i = 0;
while (true)
myjson = myjson + String((char)data[i]);
break;
i++;
// Serial.println(myjson);
#ifdef DEBUG
// Serial.println(fn);
#endif
save_config_file(DEFAULT_CONFIG_FILE, myjson);
String resp = head + table + rem + fn + foot;
// Set handler for '/handleupload'
// Start server
enable_ap();
void disable_ap()
server.end();
void enable_ap()
server.begin();
