#include #include "RTClib.h" #include #include #define pinCS 10 // Pin 10 auf Arduino Uno RTC_DS1307 rtc; File myFile; int temperatur = 20; DateTime now, last; TimeSpan ts; void setup() { // init UART Serial.begin(9600); while (!Serial); // init RTC if (!rtc.begin()) { Serial.println("Couldn't find RTC!"); while (1); } rtc.adjust(DateTime(F(__DATE__), F(__TIME__))); Serial.println("RTC adjusted."); last = rtc.now(); // init SD card pinMode(pinCS, OUTPUT); if (SD.begin()) { Serial.println("SD card is ready to use."); } else { Serial.println("SD card initialization failed!"); while(1); } } void loop() { now = rtc.now(); ts = now - last; if (ts.totalseconds() >= 3600) { last = now; String zeit = ((String) (now.year()) + (now.month()) + (now.day()) + (now.hour())); String wetterdaten= (String) temperatur + "|Temperatur"; myFile = SD.open("test3.txt", O_WRITE | O_APPEND); if (myFile) { Serial.println("Writing to file..."); myFile.println(zeit+wetterdaten); myFile.close(); Serial.println("Done."); } else { Serial.println("error opening test3.txt"); } } delay(1000); }
