?hello.world efghhhhhhhhhhhhhhhhhhhhhhhihhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhjk Jump! Orginal init value: 202072BE cde profile->manufacturer_id (first 4B):DA94D7AD profile->data_per_page:2000 profile->page_per_block:100 blk 79 starts from page 700 read page 728 error Tparam now: 20267CC4 X Tparam now: 001D6BB6 Y restored klmnopqrstu5280 wait5280 wait4K&Detect H27UBG8T2B and enable read-retrial mode... Enable Read-retrial mode... load bbt...load env to (addr 0xa0010000, size 64KB)... page_start=0xf00 page_end=0x1900 get ENV fail!! load factory to (addr 0x80100000)... load bbt...ping_no =0xff pong_no =0xff there is no data in ping ,pong buffer current_factory_start=0x1900 current_factory_start + 0x400=0x1d00 tar end,not found tar end,not found default_tv_system= new default_tv_system=PAL EPHY: 8211E check_val=0x0 [HDMI]: Set I2C Speed = 50 kHz [HDMI]: Chk_HotPlug() TV is not connected. [HDMI]: Read_EDID abort, HDMI cable plug off. [HDMI]: TV is not connected. 2nd for PAL PAL logo REALTEK ROM Monitor, Revision ICIE.0402.1067. Copyright (c) Realtek Semiconductor Corp. - All Rights Reserved. For a list of available commands, type 'help'. Compilation time /version= Feb 19 2014 10:14:08 /ICIE.0402.1067 MAC address = 00.11.22.33.44.55 Processor Company ID/options = 0x01 (MIPS Technologies, Inc.) / 0x00 Processor ID/revision = 0x93 / 0x85 Endianness = Little Flash memory size = 4 GByte SDRAM size = 512 MByte First free SDRAM address = 0x800c4000 Press 'ESC' to Monitor mode ____________________Set ethernet register: 00000044 ▒r▒▒H) error! Entering rescue linux... Rescue kernel in FLASH, total size = 0x1f52d0 seg.1 addr 0xa0a06fd3, size = 0x1f52d0 seg.2 addr 0x0, size = 0x0 copy rescue0: from a0a06fd3 to 81000000, len = 1f52d0 decompressing rescue: from 81000000 to 80100000: size = 1f52d0 lzma finished decompressing rescue done go 0x80100000 defer 625p logo Reset Ethernet Mac. Address = 0x80100000 Linux version 2.6.34-VENUS (william@rtdmpsa-05) (gcc version 4.3.6 20110218 (prerelease) (GCC) ) #21 PREEMPT Wed Dec 4 13:08:14 CST 2013 Realtek LINUX started... Venus setting: ROSs have 4194304 bytes RAM. System CPU has 1 UART. System CPU uses internal timer interrupt. Bootloader version: ICIE.0402.1067. This version string is of new format. The information of this board: Company ID:0x0 CPU ID: 0x4 Board ID: 0x402 Ethernet Mac address: 00.11.22.33.44.55 Model Config length=6 Base year of RTC is 2010. ************************************************************** You didn't specify audio image address, use default instead... ************************************************************** audio addr: 0 Config serial console: console=ttyS0,115200n8r bootconsole [early0] enabled CPU revision is: 00019385 (MIPS 24Kc) FPU revision is: 01739300 Determined physical RAM map: memory: 00020000 @ 00000000 (reserved) memory: 000e0000 @ 00020000 (ROM data) memory: 01b00000 @ 00100000 (usable) memory: 00400000 @ 01c00000 (reserved) memory: 0e000000 @ 02000000 (usable) memory: 00100000 @ 10000000 (reserved) memory: 07f00000 @ 10100000 (usable) memory: 00100000 @ 18000000 (reserved) memory: 05b00000 @ 18100000 (usable) Wasting 8192 bytes for tracking 256 unused pages Initrd not found or empty - disabling initrd Zone PFN ranges: DMA 0x00000000 -> 0x00002000 Normal 0x00002000 -> 0x0001dc00 Movable zone start PFN for each node Node 0: 64512 early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x0001dc00 zone DMA size: 2000 realsize: 2000 zone Normal size: dc00 realsize: dc00 zone Movable size: e000 realsize: e000 zonelist: Movable Normal DMA Built 1 zonelists in Zone order, mobility grouping off. Total pages: 121856 Kernel command line: console=ttyS0,115200n8r ip=192.168.0.9::192.168.0.254:255.0.0.0::: PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 64kB, 4-way, PIPT, no aliases, linesize 32 bytes Writing ErrCtl register=0000ed72 Readback ErrCtl register=0000ed72 Memory: 468824k/480256k available (3506k kernel code, 11432k reserved, 852k data, 2600k init, 0k highmem) Hierarchical RCU implementation. NR_IRQS:8 Estimated CPU frequency: 796.54 MHz Console: colour dummy device 80x25 Calibrating delay loop... 529.20 BogoMIPS (lpj=2646016) Mount-cache hash table entries: 512 devtmpfs: initialized NET: Registered protocol family 16 prom_flashsize = 0x100000000 Flash size is 0x2000000 bio: create slab at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb cfg80211: Calling CRDA to update world regulatory domain Switching to clocksource MIPS-DMP NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) Switched to NOHz mode on CPU #0 TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. ***************** se init module ********************* se init module major number = 253 ***************** md init module ********************* md init module major number = 252 size of RPC_POLL_Dev 52 and RPC_INTR_Dev 52... init_vdso successfull rtktlb: Hello, Realtek TLB Mapper... AllocBP size: 688128 order: 8 offset: 0 <<>> 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 8: 0 9: 0 10: 0 11: 0 12: 0 13: 7 Addr: 82000000, order: 13 Addr: 84000000, order: 13 Addr: 86000000, order: 13 Addr: 88000000, order: 13 Addr: 8a000000, order: 13 Addr: 8c000000, order: 13 Addr: 8e000000, order: 13 NTFS driver 2.1.29 [Flags: R/O]. msgmni has been set to 915 alg: No test for stdrng (krng) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 2 ports, IRQ sharing enabled console [ttyS0] enabled, bootconsole disabled16550A console [ttyS0] enabled, bootconsole disabled serial8250: ttyS1 at MMIO 0x0 (irq = 3) is a 16550A brd: module loaded loop: module loaded Realtek Bulid-In SATA Driver Rev:SATURN (2011-02-24 15:10) sata_rtk sata_rtk: version 0.01 sata_rtk sata_rtk: slots 32 ports 1 scsi0 : sata_rtk ata1: SATA max UDMA/133 irq 4 BGA PackageRealtek NAND Flash Driver Rev:337905 (2010-10-18) (X)Enable interrupt mechanism of NAND driver. Get parameter from register... [rtk_nand_init]Bootcode size 0x3200000 [rtk_nand_init]Factory parameter size 0x400000 [rtk_nand_init]Disable NFCP... nand_base_rtk version:0824-2011 (X)NAND_POWEROFF_CARDREADER_WITH_MULTI_READ (X)NAND_READ_SKIP_UPDATE_BBT Detect H27UBG8T2B and enable read-retrial mode... Enable Read-retrial mode... Enable Randomized mechanism READ ID:0xad 0xd7 0x94 0xda 0x74 0xc3 One H27UBG8T2B chip has 1 die(s) on board nand part=H27UBG8T2B, id=add794da, device_size=4294967296, chip_size=4294967296, num_chips=1, page_size=8192, isLastPage=1, eccBits=24 [rtk_nand_scan_bbt] have created bbt B1, just loads it !! [dump_BBT] Nand BBT Content [0] (0, 27, 0, 2047) RTK: using the whole nand as a partitoin [rtk_nand_init]Randomized enabled [rtk_nand_init]Ecc bit select 24 Realtek Nand Flash Driver is successfully installing. VenusSFC MTD init... NOR flash support list .. (X) HWSEMA support. (V) AUTO_HW_POLL support. (X) 4Bytes mode support. (V) Max erase size support. (V) Sfc_delay support. [venus_sfc_init]FLASH_BASE: 0xbdc00000 [venus_sfc_init]Flash size: 0x2000000 Read id orginal value : 0xc22015c2 --RDID Seq: 0xc2 | 0x20 | 0x15 VenusSFC MTD: MXIC MX25L1605 detected. SFC_4KB_ERASE VenusSFC MTD: Enable VenusSFC MD PP callback function. MD_READ Enable.. MD_WRITE Enable.. [venus_sfc_init]descriptor size 0x2000000 RedBoot partition parsing not available Venus SFC: using single partition Venus SFC: (for SST/SPANSION/MXIC SPI Flash) this Jupiter eth RX_OFFSET = 0x0 8139cplus: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004) MAC address = 0x00.11.22.33.44.55 eth0: RTL-8139C+ at 0xb8016000, 00:11:22:33:44:55, IRQ 2 ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [usb_param] setting for saturn #@# cfyeh-debug USBPHY_Register_Setting(861) 0xb8013808 = 0x4400a081 #@# cfyeh-debug USBPHY_Register_Setting(863) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 1 dr 7 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 2 dr 7 #@#[cfyeh-debug] USBPHY_Register_Setting(933) #@#[cfyeh-debug] USBPHY_Register_Setting(935) #@#[cfyeh-debug] USBPHY_Register_Setting(937) #@# cfyeh-debug USBPHY_SetReg_Default_39(289) tx_delay 2 [usb1_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb1_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb1_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb1_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb1_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit [usb2_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb2_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb2_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb2_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb2_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit ehci ehci: Rtk Dmp EHCI ehci ehci: new USB bus registered, assigned bus number 1 ehci ehci: irq 2, io mem 0xb8013000 cp_hotplug Hotplug got one Net Hotplug of "Add" from "eth0". It may be Realtek's wireless device. ehci ehci: USB 0.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [usb_param] setting for saturn #@# cfyeh-debug USBPHY_Register_Setting(861) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_Register_Setting(863) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 1 dr 7 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 2 dr 7 #@#[cfyeh-debug] USBPHY_Register_Setting(933) #@#[cfyeh-debug] USBPHY_Register_Setting(935) #@#[cfyeh-debug] USBPHY_Register_Setting(937) #@# cfyeh-debug USBPHY_SetReg_Default_39(289) tx_delay 2 [usb1_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb1_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb1_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb1_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb1_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit [usb2_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb2_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb2_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb2_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb2_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit ohci ohci: Rtk Dmp OHCI ohci ohci: new USB bus registered, assigned bus number 2 ohci ohci: irq 2, io mem 0xb8013400 ata1: SATA link down (SStatus 0 SControl 300) hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected #@# cfyeh-debug usb3_phy_setting_saturn(38) +++ #@# cfyeh-debug usb3_phy_setting_saturn(227) --- xhci xhci: Rtk Dmp XHCI xhci xhci: new USB bus registered, assigned bus number 3 xhci xhci: irq 2, io mem 0xb8020000 #@# cfyeh-debug xhci_irq(1747) 0x000002a0 0x002802a0 #@# cfyeh-debug handle_port_status(1096) 0x000002a0 0x002802a0 #@#[cfyeh-debug] handle_port_status(1124) NOT in U0 usb usb3: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor #######[cfyeh-debug] hub_events(3615) usb_plug_status 1 hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected #@# cfyeh-debug xhci_hub_control(287) hack for usb3 portsc #@# cfyeh-debug usb3_mac_setting_saturn(232) +++ #@# cfyeh-debug usb3_mac_setting_saturn(253) 16bit #@# cfyeh-debug usb3_mac_setting_saturn(254) *(unsigned int volatile *)0xb8028200=0x2440 #@# cfyeh-debug usb3_mac_setting_saturn(255) *(unsigned int volatile *)0xb8028200=0x2440 #@# cfyeh-debug usb3_mac_setting_saturn(257) *(unsigned int volatile *)0xb8028200=0x2400 #@# cfyeh-debug usb3_mac_setting_saturn(268) 0xb8013258 = 0x7; #@# cfyeh-debug usb3_mac_setting_saturn(270) 0xb8013258 = 0x7; #@# cfyeh-debug usb3_mac_setting_saturn(274) GTXTHRCFG #@# cfyeh-debug usb3_mac_setting_saturn(275) 0xb8028108 = 0x02400008 #@# cfyeh-debug usb3_mac_setting_saturn(280) 0xb8028108 = 0x21010000 #@# cfyeh-debug usb3_mac_setting_saturn(283) GRXTHRCFG #@# cfyeh-debug usb3_mac_setting_saturn(284) 0xb802810c = 0x02000008 #@# cfyeh-debug usb3_mac_setting_saturn(289) 0xb802810c = 0x21080000 #@# cfyeh-debug usb3_mac_setting_saturn(294) disable usb mulit request #@# cfyeh-debug usb3_mac_setting_saturn(295) *(unsigned int volatile *)0xb8013200=0x0 #@# cfyeh-debug usb3_mac_setting_saturn(297) *(unsigned int volatile *)0xb8013200=0x0 #@# cfyeh-debug usb3_mac_setting_saturn(302) GUSB3PIPECTL #@# cfyeh-debug usb3_mac_setting_saturn(303) 0xb80282c0 = 0x00060002 #@# cfyeh-debug usb3_mac_setting_saturn(306) 0xb80282c0 = 0x00060202 #@# cfyeh-debug usb3_mac_setting_saturn(309) --- Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. i2c /dev entries driver [I2C0] i2c speed changed to 100 KHz I2C0 Bus Status Check.... OK ========================= = VER : 2.1b ========================= = PHY : 0 = MODEL: Saturn = SPD : 100 = SAR : 0x024 (7 bits) = TX FIFO DEPTH : 32 = RX FIFO DEPTH : 32 = FIFO THRESHOLD: 4 = BUS JAM RECORVER 3: ON = NON STOP WRITE : ON = GPIO RW SUPPORT : ON ========================= usb 1-1: new high speed USB device using ehci and address 2 [I2C1] i2c speed changed to 100 KHz I2C1 Bus Status Check.... OK ========================= = VER : 2.1b ========================= = PHY : 1 = MODEL: Saturn = SPD : 100 = SAR : 0x024 (7 bits) = TX FIFO DEPTH : 32 = RX FIFO DEPTH : 32 = FIFO THRESHOLD: 4 = BUS JAM RECORVER 3: ON = NON STOP WRITE : ON = GPIO RW SUPPORT : ON ========================= TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver Hotplug gNET: Registered protocol family 17 ot one Net Hotplug of "Add" from "sit0". It may be Realtek's wireless device. scsi1 : usb-storage 1-1:1.0 #######[cfyeh-debug] hub_events(3619) usb_plug_status 0 #######[cfyeh-debug] usb_stor_scan_thread(841) usb_plug_status 1 cp_open alloc rings cp->rxdesc_buf =0xb0203000 , cp->ring_dma=0x10203000 init_hw eth0: Set multicast. jupiter/saturn 1g init_hw finished eth0: Set multicast. eth0: Set multicast. eth0: Set multicast. ADDRCONF(NETDEV_UP): eth0: link is not ready #######[cfyeh-debug] usb_stor_scan_thread(869) usb_plug_status 2 IP-Config: Complete: device=eth0, addr=192.168.0.9, mask=255.0.0.0, gw=192.168.0.254, host=192.168.0.9, domain=, nis-domain=(none), bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath= Freeing prom memory: 896k freed Freeing unused kernel memory: 2600k freed Welcome to Realtek Rescue Linux for PhotoViewer /etc/init.d/rcS: line 49: cannot create /sys/bus/usb/devices/usb1/bEnableHubOnBoard_woone: nonexistent directory mount: mounting /dev/cdroms/cdrom0 on /mnt/usbmounts/cdrom failed: No such device mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such file or directory mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such file or directory mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such device Please press Enter to activate this console. #@#[cfyeh-debug] check_boot_code_size(1085) nand_boot_size 0x3200000 #@#[cfyeh-debug] check_boot_code_size(1091) factory_size 0x400000 >>>>>> loader start! (Dec 4 2013:13:08:04, version=00.01.01) #@#[cfyeh-debug] check_boot_code_size(1085) nand_boot_size 0x3200000 #@#[cfyeh-debug] check_boot_code_size(1091) factory_size 0x400000 get_mtd_block_name(/dev/mtdblock0) [JH] checksignatue(), open(/dev/mtdblock0) nand_boot_size(0x3200000) factory_size(0x400000) fail 4, sig(VERO) no IMG_XXXX signature found BUS_TYPE = (null) Hotplug: device "ram2" is skipped. BUS_TYPE = (null) Hotplug: device "ram3" is skipped. BUS_TYPE = (null) Hotplug: device "ram4" is skipped. BUS_TYPE = (null) Hotplug: device "ram5" is skipped. BUS_TYPE = (null) Hotplug: device "ram8" is skipped. BUS_TYPE = (null) Hotplug: device "ram7" is skipped. BUS_TYPE = (null) Hotplug: device "ram9" is skipped. BUS_TYPE = (null) Hotplug: device "ram6" is skipped. BUS_TYPE = (null) Hotplug: device "ram11" is skipped. BUS_TYPE = (null) Hotplug: device "ram12" is skipped. BUS_TYPE = (null) Hotplug: device "ram13" is skipped. BUS_TYPE = (null) Hotplug: device "ram14" is skipped. BUS_TYPE = (null) Hotplug: device "ram15" is skipped. BUS_TYPE = (null) Hotplug: device "loop0" is skipped. BUS_TYPE = (null) Hotplug: device "ram10" is skipped. BUS_TYPE = (null) Hotplug: device "loop1" is skipped. BUS_TYPE = (null) Hotplug: device "loop2" is skipped. BUS_TYPE = (null) Hotplug: device "loop3" is skipped. BUS_TYPE = (null) Hotplug: device "loop4" is skipped. BUS_TYPE = (null) Hotplug: device "loop6" is skipped. BUS_TYPE = (null) Hotplug: device "loop7" is skipped. BUS_TYPE = (null) Hotplug: device "mtdblock0" is skipped. BUS_TYPE = (null) Hotplug: device "mtdblock1" is skipped. BUS_TYPE = (null) Hotplug: device "ram0" is skipped. BUS_TYPE = (null) Hotplug: device "ram1" is skipped. BUS_TYPE = (null) Hotplug: device "loop5" is skipped. scsi 1:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 4 #@#[cfyeh-debug] sd_probe(2278) sd_flag 1 #@#[cfyeh-debug] sd_probe(2344) sd_flag 0 #@#[cfyeh-debug] sd_probe_async(2186) sd_flag 1 #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 2 #######[cfyeh-debug] usb_stor_scan_thread(872) usb_plug_status 1 #######[cfyeh-debug] usb_stor_scan_thread(879) usb_plug_status 0 modprobe: module sd_mod not found modprobe: failed to load module sd_mod sd 1:0:0:0: [sda] 31129600 512-byte logical blocks: (15.9 GB/14.8 GiB) sd 1:0:0:0: [sda] Write Protect is off sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 1 #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 2 sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 1 sda: sda1 data[0] 0x0 signature[0] 0xbabeface data[1] 0x0 signature[1] 0xdeadbeef #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 2 rmdir: '/var/lock/hotplug/mount_tmp/.sda1': No such file or directory mount: mounting /dev/sda1 on /var/lock/hotplug/mount_tmp/.sda1 failed: No such device mount: mounting /dev/sda1 on /var/lock/hotplug/mount_tmp/.sda1 failed: No such device sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 1 sd 1:0:0:0: [sda] Attached SCSI removable disk #@#[cfyeh-debug] sd_probe_async(2245) sd_flag 0 mount: mounting /dev/sda1 on /var/lock/hotplug/mount_tmp/.sda1 failed: No such deNTFS-fs warning (device sda1): parse_options(): Option iocharset is deprecated. Please use option nls= in the future. vice mount: mounting /dev/sda1 on /var/lock/hotplug/mount_tmp/.sda1 failed: Invalid arguFAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! ment BUS_TYPE = usb Hotplug: mount -t ufsd -o force,ro,nls=utf8,umask=0,noatime /dev/sda1 /var/lock/hotplug/mount_tmp/.sda1 ret: 255 Hotplug: mount -t ntfs -o ro,iocharset=utf8,umask=0 /dev/sda1 /var/lock/hotplug/mount_tmp/.sda1 ret: 255 Hotplug: mount -t vfat -o ro,shortname=winnt,iocharset=utf8,umask=0 /dev/sda1 /var/lock/hotplug/mount_tmp/.sda1 ret: 0 Hotplug: Mount "sda1" successfully. build_imgfile_list: namelist[n]->d_name: . build_imgfile_list: namelist[n]->d_name: .. build_imgfile_list: namelist[n]->d_name: 3DFHDL_3DS4600_Forced_Update_Manual.pdf build_imgfile_list: namelist[n]->d_name: System Volume Information build_imgfile_list: namelist[n]->d_name: install.img (pattern_byte ==pattern_comparing11 [loader_a.c][verona_load_func][1679]Debug USB Install(path:/mnt/usbmounts/sda1) totallistcount: 1 img_list[first_big_useful_index].filename: /mnt/usbmounts/sda1/install.img tar: UI: not found in archive command: tar -xOf /mnt/usbmounts/sda1/install.img install_a > /install_a ************************************************************************** Saturn install_a (JH version), date:Dec 24 2013, time:10:25:37 REV:612471 ************************************************************************** argc:2, argv[0]=/install_a, argv[1]=/mnt/usbmounts/sda1/install.img opt_str=(null) , tgt_dev=(null), compress_srting=(null) package_file_path:/mnt/usbmounts/sda1/install.img [INSTALL INFO][./src/rtk_mtd.cpp][44] Open MTD_CHAR /dev/mtd0 [INSTALL LOG][./src/rtk_imgdesc.cpp][66] support MEMDISABLESCRAMBLE [INSTALL INFO][./src/rtk_mtd.cpp][62] Open MTD_BLOCK /dev/mtdblock0 [INSTALL LOG][./src/rtk_fwdesc.cpp][767] nand_boot_size 0x3200000 [INSTALL LOG][./src/rtk_fwdesc.cpp][773] factory_size 0x400000 [INSTALL LOG][./src/rtk_imgdesc.cpp][101] MEMINFO flash_type:4 flash_size:0x100000000(4194304 KB = 4096 MB) mtd_erasesize:0x00200000 (2048 KB), page_size:0x00002000 [INSTALL INFO][./src/rtk_main.cpp][136] prtkimgdesc->tarinfo.tarfile_path:/mnt/usbmounts/sda1/install.img(0x3fbb71c0) [INSTALL LOG][./src/rtk_tar.cpp][108] NULL:0 ZERO:0, prtkimg->tarinfo.tarfile_path=/mnt/usbmounts/sda1/install.img(0x3fbb71c0) tarfile_path:/mnt/usbmounts/sda1/install.img, tarfile_size: 203931648 Bytes (199152 KB) [INSTALL LOG][./src/rtk_tar.cpp][50] hash_value : 0xFF82 0x34 0xFFEF 0x52 0x03 0x09 0xFF87 0xFFAD 0x4C 0x4E 0x24 0x74 0x58 0x04 0x2C 0xFF8E current tarfile_offset:0 filename=arial.ttf, filezie=143300 (139KB), ustarin=ustar Tarfile parsing offset:0 (0x00000000) current tarfile_offset:143872 filename=configuration.xml, filezie=2315 (2KB), ustarin=ustar Tarfile parsing offset:143872 (0x00023200) [INSTALL LOG][./src/rtk_imgdesc.cpp][579] Got configuration.xml current tarfile_offset:146944 filename=flash_erase, filezie=47504 (46KB), ustarin=ustar Tarfile parsing offset:146944 (0x00023e00) current tarfile_offset:195072 filename=image/, filezie=0 (0KB), ustarin=ustar Tarfile parsing offset:195072 (0x0002fa00) current tarfile_offset:195584 filename=image/update_bg_ok.png, filezie=53749 (52KB), ustarin=ustar Tarfile parsing offset:195584 (0x0002fc00) current tarfile_offset:249856 filename=image/update_focus.png, filezie=2871 (2KB), ustarin=ustar Tarfile parsing offset:249856 (0x0003d000) current tarfile_offset:253440 filename=image/update_bg.png, filezie=52790 (51KB), ustarin=ustar Tarfile parsing offset:253440 (0x0003de00) current tarfile_offset:307200 filename=image/update_unfocus.png, filezie=2871 (2KB), ustarin=ustar Tarfile parsing offset:307200 (0x0004b000) current tarfile_offset:310784 filename=image/update_bg_fail.png, filezie=51773 (50KB), ustarin=ustar Tarfile parsing offset:310784 (0x0004be00) current tarfile_offset:363520 filename=install_a, filezie=3033700 (2962KB), ustarin=ustar Tarfile parsing offset:363520 (0x00058c00) current tarfile_offset:3398144 filename=mkfs.jffs2, filezie=163948 (160KB), ustarin=ustar Tarfile parsing offset:3398144 (0x0033da00) current tarfile_offset:3563008 filename=mkyaffs2image, filezie=48052 (46KB), ustarin=ustar Tarfile parsing offset:3563008 (0x00365e00) current tarfile_offset:3611648 filename=nandwrite, filezie=61668 (60KB), ustarin=ustar Tarfile parsing offset:3611648 (0x00371c00) current tarfile_offset:3674112 filename=package5/, filezie=0 (0KB), ustarin=ustar Tarfile parsing offset:3674112 (0x00381000) [INSTALL INFO][./src/rtk_imgdesc.cpp][616] package5/ can't be figured current tarfile_offset:3674624 filename=package5/vmlinux.develop.android.saturn.nand.bin, filezie=7483204 (7307KB), ustarin=ustar Tarfile parsing offset:3674624 (0x00381200) current tarfile_offset:11158528 filename=package5/bootloader.tar, filezie=2467840 (2410KB), ustarin=ustar Tarfile parsing offset:11158528 (0x00aa4400) current tarfile_offset:13626880 filename=package5/yaffs2_2.img, filezie=1480512 (1445KB), ustarin=ustar Tarfile parsing offset:13626880 (0x00cfee00) current tarfile_offset:15108096 filename=package5/video_firmware.bin, filezie=2298336 (2244KB), ustarin=ustar Tarfile parsing offset:15108096 (0x00e68800) current tarfile_offset:17406976 filename=package5/squashfs1.img, filezie=181489664 (177236KB), ustarin=ustar Tarfile parsing offset:17406976 (0x01099c00) current tarfile_offset:198897152 filename=package5/bluecore.audio, filezie=1883184 (1839KB), ustarin=ustar Tarfile parsing offset:198897152 (0x0bdaee00) current tarfile_offset:200781312 filename=uEGBK.mbf, filezie=747522 (730KB), ustarin=ustar Tarfile parsing offset:200781312 (0x0bf7ae00) current tarfile_offset:201529856 filename=video_firmware.install.bin, filezie=2391176 (2335KB), ustarin=ustar Tarfile parsing offset:201529856 (0x0c031a00) current tarfile_offset:203921920 [INSTALL DEBUG][./src/rtk_tar.cpp][152] tar magic error command:tar xv -f /mnt/usbmounts/sda1/install.img en_kh.txt, (139) [./src/rtk_main.cpp] tar: en_kh.txt: not found in archive [INSTALL DEBUG][./src/rtk_common.cpp][190] Can't exec command:tar xv -f /mnt/usbmounts/sda1/install.img en_kh.txt, (139) [./src/rtk_main.cpp] command:tar xv -f /mnt/usbmounts/sda1/install.img rsa_key_tmp.pub, (141) [./src/rtk_main.cpp] tar: rsa_key_tmp.pub: not found in archive [INSTALL DEBUG][./src/rtk_common.cpp][190] Can't exec command:tar xv -f /mnt/usbmounts/sda1/install.img rsa_key_tmp.pub, (141) [./src/rtk_main.cpp] [INSTALL INFO][./src/rtk_mtd.cpp][101] Open MTD_BLOCK /dev/mtdblock0 with 56623104(0x3600000) offset fw_table: 68 f2 1b 90 90 36 52 80 00 00 10 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 80 00 00 00 00 [INSTALL DEBUG][./src/rtk_fwdesc.cpp][74] Wrong boottable version:0x00 [INSTALL DEBUG][./src/rtk_imgdesc.cpp][130] load_fwdesc() fail Extract configuration.xml file... tarfile_offset:0x00023200 (2315 Bytes = 2 KB) extract configuration.xml from /mnt/usbmounts/sda1/install.img 100 |******************************| 2 KB total_time:0 secands extract ok Realtek Semiconductor Corp. This image file contains 3 Jupiter packages. The first one is for AVHDD on NOR, the second one is for AVHDD on NAND, and the third one is for AVHDD on ISO image. v10.1.11.r11498 05/26/14 12:04 Saturn image files install_a 4c7fd58c048cde1ecfa1a34c47d1a092 y This is Android on NAND of Saturn N/A cache 52428800 package5/vmlinux.develop.android.saturn.nand.bin 0x80100000 SVN:11498 package5/bluecore.audio 0x81b00000 N/A package5/video_firmware.bin 0x81d80000 N/A package5/bootloader.tar N/A package5/squashfs1.img / package5/yaffs2_2.img /usr/local/etc 1073741824 [INSTALL DEBUG][./src/rtk_imgdesc.cpp][201] (Audio Bootfile) target address not found!! skip [INSTALL DEBUG][./src/rtk_imgdesc.cpp][201] (Video Bootfile) target address not found!! skip [INSTALL INFO][./src/rtk_imgdesc.cpp][253] prtkimg->option(0x3)etc_partition_size(0x40000000) preserve_partition_size(0x3200000) [INSTALL DEBUG][./src/rtk_imgdesc.cpp][271] The size of FW_TYPE:3 is zero!! flash_type=0x00000004, flash_size=0x0100000000 (4194304 KB), mtd_erasesize=0x00200000, page_size=0x00002000, total_sector=2048 [INSTALL LOG][./src/rtk_imgdesc.cpp][410] Kernel flash_ofs:0x0003800000 allo_size:0x00800000 end:0x0004000000 img_size:0x00722f44( 7307 KBytes)(004 sectors) Audio kernel flash_ofs:0x0004000000 allo_size:0x00200000 end:0x0004200000 img_size:0x001cbc30( 1839 KBytes)(001 sectors) Video kernel flash_ofs:0x0004200000 allo_size:0x00400000 end:0x0004600000 img_size:0x002311e0( 2244 KBytes)(002 sectors) Audio Bootfile flash_ofs:0x0004600000 allo_size:0x00000000 end:0x0004600000 img_size:0x00000000( 0 KBytes)(000 sectors) Video Bootfile flash_ofs:0x0004600000 allo_size:0x00000000 end:0x0004600000 img_size:0x00000000( 0 KBytes)(000 sectors) RootFS flash_ofs:0x00a5000000 allo_size:0x0ae00000 end:0x00afe00000 img_size:0x0ad15000(177236 KBytes)(087 sectors) Resource flash_ofs:0x00afe00000 allo_size:0x00000000 end:0x00afe00000 img_size:0x00000000( 0 KBytes)(000 sectors) Preserve flash_ofs:0x00afe00000 allo_size:0x03200000 end:0x00b3000000 img_size:0x00000000( 0 KBytes)(025 sectors) Usr.local.etc flash_ofs:0x00b3000000 allo_size:0x40000000 end:0x00f3000000 img_size:0x00169740( 1445 KBytes)(512 sectors) bootcode flash_ofs:0x0000000000 allo_size:0x00000000 end:0x0000000000 img_size:0x0025a800( 2410 KBytes)(000 sectors) ROOTFS:/, USR_LOCAL_ETC:/usr/local/etc Kernel target_offset:0x80100000 tarfile_offset:0x00381200 Audio kernel target_offset:0x81b00000 tarfile_offset:0x0bdaee00 Video kernel target_offset:0x81d80000 tarfile_offset:0x00e68800 Audio Bootfile target_offset:0xffffffff tarfile_offset:0x00000000 Video Bootfile target_offset:0xffffffff tarfile_offset:0x00000000 RootFS target_offset:0x00000000 tarfile_offset:0x01099c00 Resource target_offset:0x00000000 tarfile_offset:0x00000000 Preserve target_offset:0x00000000 tarfile_offset:0x00000000 Usr.local.etc target_offset:0x00000000 tarfile_offset:0x00cfee00 bootcode target_offset:0x00000000 tarfile_offset:0x00aa4400 Extract video_firmware.install.bin file... tarfile_offset:0x0c031a00 (2391176 Bytes = 2335 KB) extract video_firmware.install.bin from /mnt/usbmounts/sda1/install.img 100 |******************************| 2335 KB total_time:0 secands extract ok Extract uEGBK.mbf file... tarfile_offset:0x0bf7ae00 (747522 Bytes = 730 KB) extract uEGBK.mbf from /mnt/usbmounts/sda1/install.img 100 |******************************| 730 KB total_time:0 secands extract ok Extract image/update_bg_ok.png file... tarfile_offset:0x0002fc00 (53749 Bytes = 52 KB) extract image/update_bg_ok.png from /mnt/usbmounts/sda1/install.img 100 |******************************| 52 KB total_time:0 secands extract ok Extract image/update_focus.png file... tarfile_offset:0x0003d000 (2871 Bytes = 2 KB) extract image/update_focus.png from /mnt/usbmounts/sda1/install.img 100 |******************************| 2 KB total_time:0 secands extract ok Extract image/update_bg.png file... tarfil*** 476MB version... e_offset:0x0003de00 (52790 Bytes = 51 KB) auth: memory address 0x40000000... extract ***************** se open: queue = 0 ********************* i ***************** se open: initialized = 0 ********************* magarch/mips/rtk_dmp/drivers/se.c, 714: offset = 0, se_devices = 90188000 e/arch/mips/rtk_dmp/drivers/se.c, 724: offset = 0 uparch/mips/rtk_dmp/drivers/se.c, 768: length = 20480 daarch/mips/rtk_dmp/drivers/se.c, 769: offset = 270041088 tearch/mips/rtk_dmp/drivers/se.c, 776: offset = 270041088 _barch/mips/rtk_dmp/drivers/se.c, 714: offset = 98316, se_devices = 90188000 g.arch/mips/rtk_dmp/drivers/se.c, 724: offset = 402702336 pnarch/mips/rtk_dmp/drivers/se.c, 768: length = 4096 g arch/mips/rtk_dmp/drivers/se.c, 769: offset = 402702336 frarch/mips/rtk_dmp/drivers/se.c, 776: offset = 402702336 om /mnt/usbmounts/sda1/install.img 100 |******************************| 51 KB total_time:1 secands extract ok Extract image/update_unfocus.png file... tarfile_offset:0x0004b000 (2871 Bytes = 2 KB) extract image/update_unfocus.png from /mnt/usbmounts/sda1/install.img 100 |******************************| 2 KB === GET HWSEM... total_time:0 secands extract ok Extract image/update_bg_fail.png file... tarfile_offset:0x0004be00 (51773 Bytes = 50 KB) extract image/update_bg_fail.png from /mnt/usbmounts/sda1/install.img === GET HWSEM... 100 |******************************| 50 KB total_time:0 secands extract ok pli initialization... call pli_init, return 0 pli_getStattAddress() return 0x40000000 start[0-3] = {7ff1a500} end[0-3] = {7ff1a504} **chip_id = 1186 chip_id&0xF =0x6 SB2 DEBUG CONTROL(0)= 0x0 --> 0x0 SB2 DEBUG CONTROL(1)= 0x0 --> 0x0 SB2 DEBUG CONTROL(2)= 0x0 --> 0x0 SB2 DEBUG CONTROL(3)= 0x0 --> 0x0 SB2 DEBUG CONTROL(4)= 0x0 --> 0x0 SB2 DEBUG CONTROL(5)= 0x0 --> 0x0 SB2 DEBUG CONTROL(6)= 0x0 --> 0x0 SB2 DEBUG CONTROL(7)= 0x0 --> 0x0 SB2 INT = 0x0 --> 0x0 SB2 start addr(0)= 0x38a03b21 --> 0x0 SB2 end addr(0)= 0xade74bba --> 0x0 SB2 start addr(1)= 0x60d5d673 --> 0x0 SB2 end addr(1)= 0x9ee88de3 --> 0x0 SB2 start addr(2)= 0xe4567833 --> 0x0 SB2 end addr(2)= 0x8221267 --> 0x0 SB2 start addr(3)= 0x4aa1fb6 --> 0x0 SB2 end addr(3)= 0xda69d1e0 --> 0x0 SB2 start addr(4)= 0xa41a23dc --> 0x0 SB2 end addr(4)= 0x338fac --> 0x0 SB2 start addr(5)= 0xb201a803 --> 0x0 SB2 end addr(5)= 0x2e57f686 --> 0x0 SB2 start addr(6)= 0xbcbaeba --> 0x0 SB2 end addr(6)= 0x87213189 --> 0x0 SB2 start addr(7)= 0xd18802ed --> 0x0 SB2 end addr(7)= 0x6336e02f --> 0x0 IS_CHIP(SATURN) Saturn... got //video_firmware.install.bin video start addr, ptr=0x41d80000 video image size, cnt=2391176 audio_addr = 0xb081 video_addr = 0xd881 sleep for 3 seconds... C[RPC]open for RPC ioctl... al[RPC]start reset... li[RPC]done... n pli_resetRPC()... Release SW Semaphore. command:rm -rf /video_firmware.install.bin /tmp/video_firmware.install.bin, (1556) [./src/rtk_ui.cpp] Got encoding system: 7 (PAL) call initRPCProxy... done. call getTVE... done. call prepareCLNT... done. [Video Firmware Version] 399810 [Video Binary Built on] Jan 12 2012 22:38:13 pli malloc order: 12 +++ ALLOC index: 0 order: 12 zone: 80849000 page: 80849000(82000000) count: 4096 start remap DVR zone 82000000(80849000) 4096... total migrated: done: 0 fail: 0 pli malloc order: 10 +++ ALLOC index: 4096 order: 10 zone: 80849000 page: 80869000(83000000) count: 1024 start remap DVR zone 83000000(80869000) 1024... total migrated: done: 0 fail: 0 pli malloc order: 10 +++ ALLOC index: 5120 order: 10 zone: 80849000 page: 80871000(83400000) count: 1024 start remap DVR zone 83400000(80871000) 1024... total migrated: done: 0 fail: 0 pli malloc order: 3 +++ ALLOC index: 6144 order: 3 zone: 80849000 page: 80879000(83800000) count: 8 start remap DVR zone 83800000(80879000) 8... total migrated: done: 0 fail: 0 pli malloc order: 12 +++ ALLOC index: 8192 order: 12 zone: 80849000 page: 80889000(84000000) count: 4096 start remap DVR zone 84000000(80889000) 4096... total migrated: done: 0 fail: 0 pli malloc order: 12 +++ ALLOC index: 12288 order: 12 zone: 80849000 page: 808a9000(85000000) count: 4096 start remap DVR zone 85000000(808a9000) 4096... total migrated: done: 0 fail: 0 pli malloc order: 12 +++ ALLOC index: 16384 order: 12 zone: 80849000 page: 808c9000(86000000) count: 4096 start remap DVR zone 86000000(808c9000) 4096... total migrated: done: 0 fail: 0 pli malloc order: 12 +++ ALLOC index: 20480 order: 12 zone: 80849000 page: 808e9000(87000000) count: 4096 start remap DVR zone 87000000(808e9000) 4096... total migrated: done: 0 fail: 0 VBM: configured to SD! call VIDEVBM: deleting GOB id=0 ... OVBM: deleting GOB id=1 ... _VBM: deleting GOB id=2 ... RVBM: deleting GOB id=3 ... PVBM: deleting GOB id=4 ... CVBM: deleting GOB id=5 ... _VBM: deleting GOB id=6 ... TVBM: deleting GOB id=7 ... oVBM: deleting GOB id=8 ... AVBM: deleting GOB id=9 ... VBM: deleting GOB id=10 ... gVBM: deleting GOB id=11 ... eVBM: deleting GOB id=12 ... nVBM: deleting GOB id=13 ... tVBM: deleting GOB id=14 ... VBM: deleting GOB id=15 ... _VBM: deleting GOB id=16 ... VVBM: deleting GOB id=17 ... iVBM: deleting GOB id=18 ... dVBM: deleting GOB id=19 ... eoCreate_0...--- FREE index: 20480 order: 12 done. call pl--- FREE index: 16384 order: 12 i_allVBM: configured to HD! ocContinuousMemory... done. call pli_IPCWriteULONG... done. call prepareCLNT... done. call setDebugFlag... done. call VIDEO_RPC_ToAgent_VideoChunkConfig_0... done. -=- create MBF engine for //uEGBK.mbf get_os (TVE) TVE_DAC_mode 0!! ~~comp 0, ch2 0, mode_3D 0!! ~~TVE standard# d_language(0) call SetVO() start. [RPCTest] VIDEO_RPC_VOUT_ToAgent_SetVideoStandard [RPCTest] VIDEO_RPC_VOUT_ToAgent_SetVideoStandard = S_OK vo.SetBackground() vo.ConfigureOSD() vo.SetDeintMode() vo.SetRescaleMode() vo.ConfigureDisplayWindow() vo.ConfigGraphicCanvas() call SetVO() end. call SetHDMI() start. [HDMI]: Turn off HDMI [HDMI]: Set AVMute [HDMI]: TURN OFF HDMI PHY for Jupiter/Saturn ----------------------------------------- [I2C0] Xfer fail - TXABORT (1/2), Reason=0001 msg->addr = 50 msg->flags = 0001 msg->len = 4 msg->buf = 9836a380 ----------------------------------------- [HDMI (VO_ConfigHDMI_InfoFrame) L:219, is_hdmi_plugin 1, hdmiMode 1!! (HDMI_3D) mode 1, HDMI_gen 0, En_3D 0, Format_3D 0!! go back SET_HDMI!!]: Readpli malloc order: 12 E+++ ALLOC index: 16384 order: 12 DI zone: 80849000 page: 808c9000(86000000) count: 4096 D start remap DVR zone 86000000(808c9000) 4096... failstotal migrated: doIne[: :TVE0 - fdaifl:w 0 ne 313 WARNING[3]:TVE p-underflow @ line 1 WARNING[3]:TVE h-underflow @ line 1 , i=0 [HDMI]: Turn on HDMI mode................... [RPCTest] VIDEO_RPC_VOUT_ToAgent_ConfigHdmiInfoFrame_0 = S_OK [HDMI]: Turn on HDMI [HDMI]: Clear AVMute [HDMI]: TURN ON HDMI PHY for Jupiter/Saturn call SetHDMI() end. call EnableUI() DG_CreateSurface() DG_GetDisplayHandle() DG_DisplayArea() start. DG_DisplayArea() end. call EnableUI() end. ---------- g_totalSize(188627)KB Extract bootloader.tar file... tarfile_offset:0x00aa4400 (2467840 Bytes = 2410 KB) extract bootloader.tar from /mnt/usbmounts/sda1/install.img 100 |******************************| 2410 KB total_time:0 secands extract ok command:mkdir -p /tmp/tar_file_tmp;tar -xf /tmp/bootfw -C /tmp/tar_file_tmp, (55) [./src/rtk_burn.cpp] /tmp/tar_file_tmp/logo10.bin not exist. /tmp/tar_file_tmp/logo11.bin not exist. /tmp/tar_file_tmp/logo12.bin not exist. /tmp/tar_file_tmp/logo13.bin not exist. /tmp/tar_file_tmp/logo14.bin not exist. /tmp/tar_file_tmp/logo15.bin not exist. /tmp/tar_file_tmp/logo16.bin not exist. /tmp/tar_file_tmp/logo17.bin not exist. /tmp/tar_file_tmp/logo18.bin not exist. /tmp/tar_file_tmp/logo19.bin not exist. /tmp/tar_file_tmp/logo20.bin not exist. flapli malloc order: 9 sh+++ ALLOC index: 6656 order: 9 t zone: 80849000 page: 8087d000(83a00000) count: 512 yp start remap DVR zone 83a00000(8087d000) 512... e: nand total migrated: done: 512 fail: 0 pli malloc order: 4 +++ ALLOC index: 6160 order: 4 zone: 80849000 page: 80879200(83810000) count: 16 start remap DVR zone 83810000(80879200) 16... total migrated: done: 16 fail: 0 pli malloc order: 7 +++ ALLOC index: 6272 order: 7 zone: 80849000 page: 8087a000(83880000) count: 128 start remap DVR zone 83880000(8087a000) 128... total migrated: done: 128 fail: 0 pli malloc order: 10 +++ ALLOC index: 7168 order: 10 zone: 80849000 page: 80881000(83c00000) count: 1024 start remap DVR zone 83c00000(80881000) 1024... total migrated: done: 1024 fail: 0 Begin:[H27UBG8T2B][20202020 20 20] [20202020 20 20] [20202020 20 20] blk_state_len =0x19 get original param in block b, size 0x520 ............/...............--- FREE index: 6656 order: 9 ..--- FREE index: 6160 order: 4 ....--- FREE index: 7168 order: 10 ..--- FREE index: 6272 order: 7 ................../..............................................................................................................................................................................................................................................................././........................................./..............................................................................................................................................................................................................................................................././........................................./..............................................................................................................................................................................................................................................................././........................................./...............................................................................................................................................................................................................................................................do_exit_n blk_state: d0 bb bb 23 23 23 23 79 79 79 79 80 80 80 80 ff ff ff ff ff ff ff ff ff ff Finish write bootcode success [INSTALL LOG][./src/rtk_burn.cpp][58] boot_main:ret:0 [INSTALL LOG][./src/rtk_main.cpp][44] In NAND FLASH command:echo -n RESCUE__ | dd of=/dev/mtdblock0 bs=1 seek=56623104, (103) [./src/rtk_burn.cpp] .8+0 records in 8+0 records out Extract mkyaffs2image file... tarfile_offset:0x00365e00 (48052 Bytes = 46 KB) extract mkyaffs2image from /mnt/usbmounts/sda1/install.img 100 |******************************| 46 KB total_time:0 secands extract ok Extract nandwrite file... tarfile_offset:0x00371c00 (61668 Bytes = 60 KB) extract nandwrite from /mnt/usbmounts/sda1/install.img 100 |******************************| 60 KB total_time:0 secands extract ok Extract flash_erase file... tarfile_offset:0x00023e00 (47504 Bytes = 46 KB) extract flash_erase from /mnt/usbmounts/sda1/install.img 100 |******************************| 46 KB total_time:0 secands extract ok command:chmod 777 /usr/sbin/mkyaffs2image;chmod 777 /usr/sbin/nandwrite;chmod 777 /usr/sbin/flash_erase, (202) [./src/rtk_burn.cpp] Burning Kernel efwtype(0) image with mem_offset(0x80100000) ... flash_offset:0x0003800000 flash_allo_size:0x00800000 bytes(4 sector) tarfile_offset:0x00381200 image_size:0x00722f44 bytes(7307 KB) command:/usr/sbin/flash_erase /dev/mtd0 58720256 4, (572) [./src/rtk.burn.cpp] Erase Total 4 Units Performing Flash Erase of length 2097152 at offset 0x3e00000 done popen(cmd):/usr/sbin/nandwrite -c -x -X -s 58720256 -l 7483204 /dev/mtd0 - start burning progress_callback---------- totalLen(7483204) g_burnSize(0) nandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c ....checksum:0x215994C5 total_time:2 secands Writing data finishes !! Complete!! Burning Audio kernel efwtype(1) image with mem_offset(0x81b00000) ... flash_offset:0x0004000000 flash_allo_size:0x00200000 bytes(1 sector) tarfile_offset:0x0bdaee00 image_size:0x001cbc30 bytes(1839 KB) command:/usr/sbin/flash_erase /dev/mtd0 67108864 1, (572) [./src/rtk_burn.cpp] Erase Total 1 Units Performing Flash Erase of length 2097152 at offset 0x4000000 done popen(cmd):/usr/sbin/nandwrite -c -x -X -s 67108864 -l 1883184 /dev/mtd0 - start burning progress_callback---------- totalLen(1883184) g_burnSize(7483204) nandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c .checksum:0x0877547B total_time:0 secands Writing data finishes !! Complete!! Burning Video kernel efwtype(2) image with mem_offset(0x81d80000) ... flash_offset:0x0004200000 flash_allo_size:0x00400000 bytes(2 sector) tarfile_offset:0x00e68800 image_size:0x002311e0 bytes(2244 KB) command:/usr/sbin/flash_erase /dev/mtd0 69206016 2, (572) [./src/rtk_burn.cpp] Erase Total 2 Units Performing Flash Erase of length 2097152 at offset 0x4400000 done popen(cmd):/usr/sbin/nandwrite -c -x -X -s 69206016 -l 2298336 /dev/mtd0 - start burning progress_callback---------- totalLen(2298336) g_burnSize(9366388) nandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c .checksum:0x06F0B3BC total_time:1 secands Writing data finishes !! Complete!! Burning Audio Bootfile efwtype(3) image with mem_offset(0xffffffff) ... flash_offset:0x0004600000 flash_allo_size:0x00000000 bytes(0 sector) tarfile_offset:0x00000000 image_size:0x00000000 bytes(0 KB) [INSTALL DEBUG][./src/rtk_burn.cpp][562] Audio Bootfile don't exist [INSTALL DEBUG][./src/rtk_main.cpp][78] Audio bootfile none Burning Video Bootfile efwtype(4) image with mem_offset(0xffffffff) ... flash_offset:0x0004600000 flash_allo_size:0x00000000 bytes(0 sector) tarfile_offset:0x00000000 image_size:0x00000000 bytes(0 KB) [INSTALL DEBUG][./src/rtk_burn.cpp][562] Video Bootfile don't exist [INSTALL DEBUG][./src/rtk_main.cpp][83] Video bootfile none Burning RootFS efwtype(5) image with mem_offset(0x00000000) ... flash_offset:0x00a5000000 flash_allo_size:0x0ae00000 bytes(87 sector) tarfile_offset:0x01099c00 image_size:0x0ad15000 bytes(177236 KB) command:/usr/sbin/flash_erase /dev/mtd0 2768240640 87, (572) [./src/rtk_burn.cpp] Erase Total 87 Units Performing Flash Erase of length 2097152 at offset 0xafc00000 donese of length 2097152 at offset 0xab800000 popen(cmd):/usr/sbin/nandwrite -c -x -X -s 2768240640 -l 181489664 /dev/mtd0 - start burning progress_callback---------- totalLen(181489664) g_burnSize(11664724) nandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c ............................................ ........................................................checksum:0x8F8A6A61 total_time:62 secands Writing data finishes !! Complete!! Burning Resource efwtype(6) image with mem_offset(0x00000000) ... flash_offset:0x00afe00000 flash_allo_size:0x00000000 bytes(0 sector) tarfile_offset:0x00000000 image_size:0x00000000 bytes(0 KB) [INSTALL DEBUG][./src/rtk_burn.cpp][562] Resource don't exist [INSTALL DEBUG][./src/rtk_main.cpp][94] burn Resource fail Burning Preserve efwtype(7) image with mem_offset(0x00000000) ... flash_offset:0x00afe00000 flash_allo_size:0x03200000 bytes(25 sector) tarfile_offset:0x00000000 image_size:0x00000000 bytes(0 KB) command:/usr/sbin/flash_erase /dev/mtd0 2950692864 25, (491) [./src/rtk_burn.cpp] Erase Total 25 Units Performing Flash Erase of length 2097152 at offset 0xb2e00000 done preserve partition Complete!! Burning Usr.local.etc efwtype(8) image with mem_offset(0x00000000) ... flash_offset:0x00b3000000 flash_allo_size:0x40000000 bytes(512 sector) tarfile_offset:0x00cfee00 image_size:0x00169740 bytes(1445 KB) Burning Usr.local.etc efwtype(8) image with mem_offset(0x00000000) ... flash_offset:0x00b3000000 flash_allo_size:0x40000000 bytes(512 sector) tarfile_offset:0x00cfee00 image_size:0x00169740 bytes(1445 KB) command:/usr/sbin/flash_erase /dev/mtd0 3003121664 512, (572) [./src/rtk_burn.cpp] Erase Total 512 Units Performing Flash Erase of length 2097152 at offset 0xf1800000.Performing Flash Erase of length 2097152 at offset 0xf1a00Performing Flash Erase of length 2097152 at offset 0xf2e00000 done popen(cmd):/usr/sbin/nandwrite -c -y -n -o -X -s 3003121664 -l 1480512 /dev/mtd0 - start burning 0 | | 8 KBnandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c 100 |******************************| 1445 KB checksum:0x05C4FD60 total_time:1 secands Data buf File I/O error on input file: Unknown error 0 ERR readlen is 8192, cnt is 3072 Complete!! [INSTALL INFO][./src/rtk_burn.cpp][1010] RootFS offset(0xa5000000) [INSTALL INFO][./src/rtk_burn.cpp][1041] Preserve offset(0xafe00000) [INSTALL INFO][./src/rtk_burn.cpp][1054] Usr.local.etc offset(0xb3000000) [INSTALL INFO][./src/rtk_burn.cpp][1066] remapping offset(0xf3000000) [INSTALL INFO][./src/rtk_burn.cpp][1099] partition(0) length(0xa5000000) [INSTALL LOG][./src/rtk_burn.cpp][1128] BOOTTABLE PRESERVE[INSTALL INFO][./src/rtk_burn.cpp][1158] rtk_fw_head.part_count:5 [INSTALL LOG][./src/rtk_fwdesc.cpp][351] veraion:0x01 fw_count:7, part_count:5 checksum:0x00001e08 [INSTALL INFO][./src/rtk_mtd.cpp][101] Open MTD_BLOCK /dev/mtdblock0 with 56623104(0x3600000) offset .56 45 52 4f 4e 41 5f 5f 00 00 1e 08 01 00 00 00 00 00 00 00 00 20 00 00 00 00 00 f0 00 00 00 e0 01 80 a5 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 0a e0 00 00 01 06 00 00 00 00 00 00 00 00 2f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 20 00 00 01 09 00 00 00 00 00 00 00 00 63 61 63 68 65 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 40 00 00 00 01 09 00 00 00 00 00 00 00 00 2f 75 73 72 2f 6c 6f 63 61 6c 2f 65 74 63 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 80 0d 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 80 00 00 00 00 80 10 00 00 03 80 00 00 00 72 2f 44 00 80 00 00 00 00 00 00 00 00 00 00 00 00 03 80 00 00 00 00 81 b0 00 00 04 00 00 00 00 1c bc 30 00 20 00 00 00 00 00 00 00 00 00 00 00 00 04 80 00 00 00 00 81 d8 00 00 04 20 00 00 00 23 11 e0 00 40 00 00 00 00 00 00 00 00 00 00 00 00 06 80 00 00 00 00 00 00 00 00 a5 00 00 00 0a d1 50 00 0a e0 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 af e0 00 00 00 00 00 00 03 20 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 b3 00 00 00 00 16 97 40 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 f3 00 00 00 0d 00 00 00 0d 00 00 00 00 00 00 00 00 00 00 00 00 00 . rtk_burn_rtkimg_from_usb():0 install time:88 secands command:pci stop, (138) [install_a.cpp] sh: pci: not found [INSTALL DEBUG][./src/rtk_common.cpp][190] Can't exec command:pci stop, (138) [install_a.cpp] command:reboot, (139) [install_a.cpp] The system is going down NOW! Sending SIGTERM to all processes clear pli setting.... se release, count = 0 Sending SIGKILL to all processes Requesting system reboot Restarting system. ?hello.world efghhhhhhhhhhhhhhhhhhhhhhihhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhjk Jump! Orginal init value: 202072BE cde profile->manufacturer_id (first 4B):DA94D7AD profile->data_per_page:2000 profile->page_per_block:100 blk 79 starts from page 700 klmnopqrstu5280 wait5280 wait4K&Detect H27UBG8T2B and enable read-retrial mode... Enable Read-retrial mode... load bbt...load env to (addr 0xa0010000, size 64KB)... page_start=0xf00 page_end=0x1900 get ENV fail!! load factory to (addr 0x80100000)... load bbt...ping_no =0xff pong_no =0xff there is no data in ping ,pong buffer current_factory_start=0x1900 current_factory_start + 0x400=0x1d00 tar end,not found tar end,not found default_tv_system= new default_tv_system=PAL EPHY: 8211E check_val=0x0 [HDMI]: Set I2C Speed = 50 kHz [HDMI]: Chk_HotPlug() TV is not connected. [HDMI]: Read_EDID abort, HDMI cable plug off. [HDMI]: TV is not connected. 2nd for PAL PAL logo REALTEK ROM Monitor, Revision ICIE.0402.1067. Copyright (c) Realtek Semiconductor Corp. - All Rights Reserved. For a list of available commands, type 'help'. Compilation time /version= Feb 19 2014 10:14:08 /ICIE.0402.1067 MAC address = 00.11.22.33.44.55 Processor Company ID/options = 0x01 (MIPS Technologies, Inc.) / 0x00 Processor ID/revision = 0x93 / 0x85 Endianness = Little Flash memory size = 4 GByte SDRAM size = 512 MByte First free SDRAM address = 0x800c4000 Press 'ESC' to Monitor mode ____________________Set ethernet register: 00000044 ▒r▒▒H) error! Entering rescue linux... Rescue kernel in FLASH, total size = 0x1f52d0 seg.1 addr 0xa0a06fd3, size = 0x1f52d0 seg.2 addr 0x0, size = 0x0 copy rescue0: from a0a06fd3 to 81000000, len = 1f52d0 decompressing rescue: from 81000000 to 80100000: size = 1f52d0 lzma finished decompressing rescue done go 0x80100000 defer 625p logo Reset Ethernet Mac. Address = 0x80100000 Linux version 2.6.34-VENUS (william@rtdmpsa-05) (gcc version 4.3.6 20110218 (prerelease) (GCC) ) #21 PREEMPT Wed Dec 4 13:08:14 CST 2013 Realtek LINUX started... Venus setting: ROSs have 4194304 bytes RAM. System CPU has 1 UART. System CPU uses internal timer interrupt. Bootloader version: ICIE.0402.1067. This version string is of new format. The information of this board: Company ID:0x0 CPU ID: 0x4 Board ID: 0x402 Ethernet Mac address: 00.11.22.33.44.55 Model Config length=6 Base year of RTC is 2010. ************************************************************** You didn't specify audio image address, use default instead... ************************************************************** audio addr: 0 Config serial console: console=ttyS0,115200n8r bootconsole [early0] enabled CPU revision is: 00019385 (MIPS 24Kc) FPU revision is: 01739300 Determined physical RAM map: memory: 00020000 @ 00000000 (reserved) memory: 000e0000 @ 00020000 (ROM data) memory: 01b00000 @ 00100000 (usable) memory: 00400000 @ 01c00000 (reserved) memory: 0e000000 @ 02000000 (usable) memory: 00100000 @ 10000000 (reserved) memory: 07f00000 @ 10100000 (usable) memory: 00100000 @ 18000000 (reserved) memory: 05b00000 @ 18100000 (usable) Wasting 8192 bytes for tracking 256 unused pages Initrd not found or empty - disabling initrd Zone PFN ranges: DMA 0x00000000 -> 0x00002000 Normal 0x00002000 -> 0x0001dc00 Movable zone start PFN for each node Node 0: 64512 early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x0001dc00 zone DMA size: 2000 realsize: 2000 zone Normal size: dc00 realsize: dc00 zone Movable size: e000 realsize: e000 zonelist: Movable Normal DMA Built 1 zonelists in Zone order, mobility grouping off. Total pages: 121856 Kernel command line: console=ttyS0,115200n8r ip=192.168.0.9::192.168.0.254:255.0.0.0::: PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 64kB, 4-way, PIPT, no aliases, linesize 32 bytes Writing ErrCtl register=0000ed70 Readback ErrCtl register=0000ed70 Memory: 468824k/480256k available (3506k kernel code, 11432k reserved, 852k data, 2600k init, 0k highmem) Hierarchical RCU implementation. NR_IRQS:8 Estimated CPU frequency: 796.55 MHz Console: colour dummy device 80x25 Calibrating delay loop... 529.20 BogoMIPS (lpj=2646016) Mount-cache hash table entries: 512 devtmpfs: initialized NET: Registered protocol family 16 prom_flashsize = 0x100000000 Flash size is 0x2000000 bio: create slab at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb cfg80211: Calling CRDA to update world regulatory domain Switching to clocksource MIPS-DMP NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) Switched to NOHz mode on CPU #0 TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. ***************** se init module ********************* se init module major number = 253 ***************** md init module ********************* md init module major number = 252 size of RPC_POLL_Dev 52 and RPC_INTR_Dev 52... init_vdso successfull rtktlb: Hello, Realtek TLB Mapper... AllocBP size: 688128 order: 8 offset: 0 <<>> 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 8: 0 9: 0 10: 0 11: 0 12: 0 13: 7 Addr: 82000000, order: 13 Addr: 84000000, order: 13 Addr: 86000000, order: 13 Addr: 88000000, order: 13 Addr: 8a000000, order: 13 Addr: 8c000000, order: 13 Addr: 8e000000, order: 13 NTFS driver 2.1.29 [Flags: R/O]. msgmni has been set to 915 alg: No test for stdrng (krng) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 2 ports, IRQ sharing enabled console [ttyS0] enabled, bootconsole disabled16550A console [ttyS0] enabled, bootconsole disabled serial8250: ttyS1 at MMIO 0x0 (irq = 3) is a 16550A brd: module loaded loop: module loaded Realtek Bulid-In SATA Driver Rev:SATURN (2011-02-24 15:10) sata_rtk sata_rtk: version 0.01 sata_rtk sata_rtk: slots 32 ports 1 scsi0 : sata_rtk ata1: SATA max UDMA/133 irq 4 BGA PackageRealtek NAND Flash Driver Rev:337905 (2010-10-18) (X)Enable interrupt mechanism of NAND driver. Get parameter from register... [rtk_nand_init]Bootcode size 0x3200000 [rtk_nand_init]Factory parameter size 0x400000 [rtk_nand_init]Disable NFCP... nand_base_rtk version:0824-2011 (X)NAND_POWEROFF_CARDREADER_WITH_MULTI_READ (X)NAND_READ_SKIP_UPDATE_BBT Detect H27UBG8T2B and enable read-retrial mode... Enable Read-retrial mode... Enable Randomized mechanism READ ID:0xad 0xd7 0x94 0xda 0x74 0xc3 One H27UBG8T2B chip has 1 die(s) on board nand part=H27UBG8T2B, id=add794da, device_size=4294967296, chip_size=4294967296, num_chips=1, page_size=8192, isLastPage=1, eccBits=24 [rtk_nand_scan_bbt] have created bbt B1, just loads it !! [dump_BBT] Nand BBT Content [0] (0, 27, 0, 2047) RTK: using the whole nand as a partitoin [rtk_nand_init]Randomized enabled [rtk_nand_init]Ecc bit select 24 Realtek Nand Flash Driver is successfully installing. VenusSFC MTD init... NOR flash support list .. (X) HWSEMA support. (V) AUTO_HW_POLL support. (X) 4Bytes mode support. (V) Max erase size support. (V) Sfc_delay support. [venus_sfc_init]FLASH_BASE: 0xbdc00000 [venus_sfc_init]Flash size: 0x2000000 Read id orginal value : 0xc22015c2 --RDID Seq: 0xc2 | 0x20 | 0x15 VenusSFC MTD: MXIC MX25L1605 detected. SFC_4KB_ERASE VenusSFC MTD: Enable VenusSFC MD PP callback function. MD_READ Enable.. MD_WRITE Enable.. [venus_sfc_init]descriptor size 0x2000000 RedBoot partition parsing not available Venus SFC: using single partition Venus SFC: (for SST/SPANSION/MXIC SPI Flash) this Jupiter eth RX_OFFSET = 0x0 8139cplus: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004) MAC address = 0x00.11.22.33.44.55 Hotplug got one Neteth0: RTL-8139C+ at 0xb8016000, 00:11:22:33:44:55, IRQ 2 Hoehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver tplug of "Add" from "eth0". It may be Realtek's wireless device. [usb_param] setting for saturn #@# cfyeh-debug USBPHY_Register_Setting(861) 0xb8013808 = 0x4400a081 #@# cfyeh-debug USBPHY_Register_Setting(863) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 1 dr 7 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 2 dr 7 #@#[cfyeh-debug] USBPHY_Register_Setting(933) #@#[cfyeh-debug] USBPHY_Register_Setting(935) #@#[cfyeh-debug] USBPHY_Register_Setting(937) #@# cfyeh-debug USBPHY_SetReg_Default_39(289) tx_delay 2 [usb1_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb1_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb1_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb1_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb1_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit [usb2_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb2_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb2_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb2_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb2_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit ehci ehci: Rtk Dmp EHCI ehci ehci: new USB bus registered, assigned bus number 1 ehci ehci: irq 2, io mem 0xb8013000 cp_hotplug ehci ehci: USB 0.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [usb_param] setting for saturn #@# cfyeh-debug USBPHY_Register_Setting(861) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_Register_Setting(863) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 1 dr 7 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 2 dr 7 #@#[cfyeh-debug] USBPHY_Register_Setting(933) #@#[cfyeh-debug] USBPHY_Register_Setting(935) #@#[cfyeh-debug] USBPHY_Register_Setting(937) #@# cfyeh-debug USBPHY_SetReg_Default_39(289) tx_delay 2 [usb1_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb1_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb1_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb1_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb1_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit [usb2_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb2_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb2_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb2_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb2_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit ohci ohci: Rtk Dmp OHCI ohci ohci: new USB bus registered, assigned bus number 2 ohci ohci: irq 2, io mem 0xb8013400 ata1: SATA link down (SStatus 0 SControl 300) hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected #@# cfyeh-debug usb3_phy_setting_saturn(38) +++ #@# cfyeh-debug usb3_phy_setting_saturn(227) --- xhci xhci: Rtk Dmp XHCI xhci xhci: new USB bus registered, assigned bus number 3 xhci xhci: irq 2, io mem 0xb8020000 #@# cfyeh-debug xhci_irq(1747) 0x000002a0 0x002802a0 #@# cfyeh-debug handle_port_status(1096) 0x000002a0 0x002802a0 #@#[cfyeh-debug] handle_port_status(1124) NOT in U0 usb usb3: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor #######[cfyeh-debug] hub_events(3615) usb_plug_status 1 hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected #@# cfyeh-debug xhci_hub_control(287) hack for usb3 portsc #@# cfyeh-debug usb3_mac_setting_saturn(232) +++ #@# cfyeh-debug usb3_mac_setting_saturn(253) 16bit #@# cfyeh-debug usb3_mac_setting_saturn(254) *(unsigned int volatile *)0xb8028200=0x2440 #@# cfyeh-debug usb3_mac_setting_saturn(255) *(unsigned int volatile *)0xb8028200=0x2440 #@# cfyeh-debug usb3_mac_setting_saturn(257) *(unsigned int volatile *)0xb8028200=0x2400 #@# cfyeh-debug usb3_mac_setting_saturn(268) 0xb8013258 = 0x7; #@# cfyeh-debug usb3_mac_setting_saturn(270) 0xb8013258 = 0x7; #@# cfyeh-debug usb3_mac_setting_saturn(274) GTXTHRCFG #@# cfyeh-debug usb3_mac_setting_saturn(275) 0xb8028108 = 0x02400008 #@# cfyeh-debug usb3_mac_setting_saturn(280) 0xb8028108 = 0x21010000 #@# cfyeh-debug usb3_mac_setting_saturn(283) GRXTHRCFG #@# cfyeh-debug usb3_mac_setting_saturn(284) 0xb802810c = 0x02000008 #@# cfyeh-debug usb3_mac_setting_saturn(289) 0xb802810c = 0x21080000 #@# cfyeh-debug usb3_mac_setting_saturn(294) disable usb mulit request #@# cfyeh-debug usb3_mac_setting_saturn(295) *(unsigned int volatile *)0xb8013200=0x0 #@# cfyeh-debug usb3_mac_setting_saturn(297) *(unsigned int volatile *)0xb8013200=0x0 #@# cfyeh-debug usb3_mac_setting_saturn(302) GUSB3PIPECTL #@# cfyeh-debug usb3_mac_setting_saturn(303) 0xb80282c0 = 0x00060002 #@# cfyeh-debug usb3_mac_setting_saturn(306) 0xb80282c0 = 0x00060202 #@# cfyeh-debug usb3_mac_setting_saturn(309) --- Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. i2c /dev entries driver [I2C0] i2c speed changed to 100 KHz I2C0 Bus Status Check.... OK ========================= = VER : 2.1b ========================= = PHY : 0 = MODEL: Saturn = SPD : 100 = SAR : 0x024 (7 bits) = TX FIFO DEPTH : 32 = RX FIFO DEPTH : 32 = FIFO THRESHOLD: 4 = BUS JAM RECORVER 3: ON = NON STOP WRITE : ON = GPIO RW SUPPORT : ON ========================= usb 1-1: new high speed USB device using ehci and address 2 [I2C1] i2c speed changed to 100 KHz I2C1 Bus Status Check.... OK ========================= = VER : 2.1b ========================= = PHY : 1 = MODEL: Saturn = SPD : 100 = SAR : 0x024 (7 bits) = TX FIFO DEPTH : 32 = RX FIFO DEPTH : 32 = FIFO THRESHOLD: 4 = BUS JAM RECORVER 3: ON = NON STOP WRITE : ON = GPIO RW SUPPORT : ON ========================= TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver Hotplug gNET: Registered protocol family 17 ot one Net Hotplug of "Add" from "sit0". It may be Realtek's wireless device. scsi1 : usb-storage 1-1:1.0 #######[cfyeh-debug] hub_events(3619) usb_plug_status 0 #######[cfyeh-debug] usb_stor_scan_thread(841) usb_plug_status 1 cp_open alloc rings cp->rxdesc_buf =0xb021e000 , cp->ring_dma=0x1021e000 init_hw eth0: Set multicast. jupiter/saturn 1g init_hw finished eth0: Set multicast. eth0: Set multicast. eth0: Set multicast. ADDRCONF(NETDEV_UP): eth0: link is not ready #######[cfyeh-debug] usb_stor_scan_thread(869) usb_plug_status 2 scsi 1:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 4 #@#[cfyeh-debug] sd_probe(2278) sd_flag 1 #@#[cfyeh-debug] sd_probe_async(2186) sd_flag 2 #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 3 #@#[cfyeh-debug] sd_probe(2344) sd_flag 2 #######[cfyeh-debug] usb_stor_scan_thread(872) usb_plug_status 1 #######[cfyeh-debug] usb_stor_scan_thread(879) usb_plug_status 0 modprobe: module sd_mod not found modprobe: failed to load module sd_mod IP-Config: Complete: device=eth0, addr=192.168.0.9, mask=255.0.0.0, gw=192.168.0.254, host=192.168.0.9, domain=, nis-domain=(none), bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath= sd 1:0:0:0: [sda] 31129600 512-byte logical blocks: (15.9 GB/14.8 GiB) sd 1:0:0:0: [sda] Write Protect is off sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 1 #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 2 sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 1 sda: sda1 data[0] 0x0 signature[0] 0xbabeface data[1] 0x0 signature[1] 0xdeadbeef #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 2 sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 1 sd 1:0:0:0: [sda] Attached SCSI removable disk #@#[cfyeh-debug] sd_probe_async(2245) sd_flag 0 Freeing prom memory: 896k freed Freeing unused kernel memory: 2600k freed Welcome to Realtek Rescue Linux for PhotoViewer /etc/init.d/rcS: line 49: cannot create /sys/bus/usb/devices/usb1/bEnableHubOnBoard_woone: nonexistent directory mount: mounting /dev/cdroms/cdrom0 on /mnt/usbmounts/cdrom failed: No such device mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such file or directory mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such file or directory mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such device Please press Enter to activate this console. #@#[cfyeh-debug] check_boot_code_size(1085) nand_boot_size 0x3200000 #@#[cfyeh-debug] check_boot_code_size(1091) factory_size 0x400000 >>>>>> loader start! (Dec 4 2013:13:08:04, version=00.01.01) #@#[cfyeh-debug] check_boot_code_size(1085) nand_boot_size 0x3200000 #@#[cfyeh-debug] check_boot_code_size(1091) factory_size 0x400000 get_mtd_block_name(/dev/mtdblock0) [JH] checksignatue(), open(/dev/mtdblock0) nand_boot_size(0x3200000) factory_size(0x400000) fail 4, sig(VERO) no IMG_XXXX signature found BUS_TYPE = (null) Hotplug: device "ram1" is skipped. BUS_TYPE = (null) Hotplug: device "ram2" is skipped. BUS_TYPE = (null) Hotplug: device "ram3" is skipped. BUS_TYPE = (null) Hotplug: device "ram4" is skipped. BUS_TYPE = (null) Hotplug: device "ram5" is skipped. BUS_TYPE = (null) Hotplug: device "ram8" is skipped. BUS_TYPE = (null) Hotplug: device "ram9" is skipped. BUS_TYPE = (null) Hotplug: device "ram6" is skipped. BUS_TYPE = (null) Hotplug: device "ram10" is skipped. BUS_TYPE = (null) Hotplug: device "ram11" is skipped. BUS_TYPE = (null) Hotplug: device "ram12" is skipped. BUS_TYPE = (null) Hotplug: device "ram14" is skipped. BUS_TYPE = (null) Hotplug: device "ram13" is skipped. BUS_TYPE = (null) Hotplug: device "loop0" is skipped. BUS_TYPE = (null) Hotplug: device "loop1" is skipped. BUS_TYPE = (null) Hotplug: device "loop2" is skipped. BUS_TYPE = (null) Hotplug: device "ram15" is skipped. BUS_TYPE = (null) Hotplug: device "loop4" is skipped. BUS_TYPE = (null) Hotplug: device "loop5" is skipped. BUS_TYPE = (null) Hotplug: device "loop3" is skipped. BUS_TYPE = (null) Hotplug: device "loop7" is skipped. BUS_TYPE = (null) Hotplug: device "mtdblock0" is skipped. BUS_TYPE = (null) Hotplug: device "ram0" is skipped. BUS_TYPE = (null) Hotplug: device "mtdblock1" is skipped. BUS_TYPE = (null) Hotplug: device "ram7" is skipped. BUS_TYPE = (null) Hotplug: device "loop6" is skipped. rmdir: '/var/lock/hotplug/mount_tmp/.sda1': No such file or directory mount: mounting /dev/sda1 on /var/lock/hotplug/mount_tmp/.sda1 failed: No such device mount: mounting /dev/sda1 on /var/lock/hotplug/mount_tmp/.sda1 failed: No such device mount: mounting /dev/sda1 on /var/lock/hotplug/mount_tmp/.sda1 failed: No such deNTFS-fs warning (device sda1): parse_options(): Option iocharset is deprecated. Please use option nls= in the future. vice mount: mounting /dev/sda1 on /var/lock/hotplug/mount_tmp/.sda1 failed: Invalid argFAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! ument BUS_TYPE = usb Hotplug: mount -t ufsd -o force,ro,nls=utf8,umask=0,noatime /dev/sda1 /var/lock/hotplug/mount_tmp/.sda1 ret: 255 Hotplug: mount -t ntfs -o ro,iocharset=utf8,umask=0 /dev/sda1 /var/lock/hotplug/mount_tmp/.sda1 ret: 255 Hotplug: mount -t vfat -o ro,shortname=winnt,iocharset=utf8,umask=0 /dev/sda1 /var/lock/hotplug/mount_tmp/.sda1 ret: 0 Hotplug: Mount "sda1" successfully. build_imgfile_list: namelist[n]->d_name: . build_imgfile_list: namelist[n]->d_name: .. build_imgfile_list: namelist[n]->d_name: 3DFHDL_3DS4600_Forced_Update_Manual.pdf build_imgfile_list: namelist[n]->d_name: System Volume Information build_imgfile_list: namelist[n]->d_name: install.img (pattern_byte ==pattern_comparing11 [loader_a.c][verona_load_func][1679]Debug USB Install(path:/mnt/usbmounts/sda1) totallistcount: 1 img_list[first_big_useful_index].filename: /mnt/usbmounts/sda1/install.img tar: UI: not found in archive command: tar -xOf /mnt/usbmounts/sda1/install.img install_a > /install_a ************************************************************************** Saturn install_a (JH version), date:Dec 24 2013, time:10:25:37 REV:612471 ************************************************************************** argc:2, argv[0]=/install_a, argv[1]=/mnt/usbmounts/sda1/install.img opt_str=(null) , tgt_dev=(null), compress_srting=(null) package_file_path:/mnt/usbmounts/sda1/install.img [INSTALL INFO][./src/rtk_mtd.cpp][44] Open MTD_CHAR /dev/mtd0 [INSTALL LOG][./src/rtk_imgdesc.cpp][66] support MEMDISABLESCRAMBLE [INSTALL INFO][./src/rtk_mtd.cpp][62] Open MTD_BLOCK /dev/mtdblock0 [INSTALL LOG][./src/rtk_fwdesc.cpp][767] nand_boot_size 0x3200000 [INSTALL LOG][./src/rtk_fwdesc.cpp][773] factory_size 0x400000 [INSTALL LOG][./src/rtk_imgdesc.cpp][101] MEMINFO flash_type:4 flash_size:0x100000000(4194304 KB = 4096 MB) mtd_erasesize:0x00200000 (2048 KB), page_size:0x00002000 [INSTALL INFO][./src/rtk_main.cpp][136] prtkimgdesc->tarinfo.tarfile_path:/mnt/usbmounts/sda1/install.img(0x3fe78650) [INSTALL LOG][./src/rtk_tar.cpp][108] NULL:0 ZERO:0, prtkimg->tarinfo.tarfile_path=/mnt/usbmounts/sda1/install.img(0x3fe78650) tarfile_path:/mnt/usbmounts/sda1/install.img, tarfile_size: 203931648 Bytes (199152 KB) [INSTALL LOG][./src/rtk_tar.cpp][50] hash_value : 0xFF82 0x34 0xFFEF 0x52 0x03 0x09 0xFF87 0xFFAD 0x4C 0x4E 0x24 0x74 0x58 0x04 0x2C 0xFF8E current tarfile_offset:0 filename=arial.ttf, filezie=143300 (139KB), ustarin=ustar Tarfile parsing offset:0 (0x00000000) current tarfile_offset:143872 filename=configuration.xml, filezie=2315 (2KB), ustarin=ustar Tarfile parsing offset:143872 (0x00023200) [INSTALL LOG][./src/rtk_imgdesc.cpp][579] Got configuration.xml current tarfile_offset:146944 filename=flash_erase, filezie=47504 (46KB), ustarin=ustar Tarfile parsing offset:146944 (0x00023e00) current tarfile_offset:195072 filename=image/, filezie=0 (0KB), ustarin=ustar Tarfile parsing offset:195072 (0x0002fa00) current tarfile_offset:195584 filename=image/update_bg_ok.png, filezie=53749 (52KB), ustarin=ustar Tarfile parsing offset:195584 (0x0002fc00) current tarfile_offset:249856 filename=image/update_focus.png, filezie=2871 (2KB), ustarin=ustar Tarfile parsing offset:249856 (0x0003d000) current tarfile_offset:253440 filename=image/update_bg.png, filezie=52790 (51KB), ustarin=ustar Tarfile parsing offset:253440 (0x0003de00) current tarfile_offset:307200 filename=image/update_unfocus.png, filezie=2871 (2KB), ustarin=ustar Tarfile parsing offset:307200 (0x0004b000) current tarfile_offset:310784 filename=image/update_bg_fail.png, filezie=51773 (50KB), ustarin=ustar Tarfile parsing offset:310784 (0x0004be00) current tarfile_offset:363520 filename=install_a, filezie=3033700 (2962KB), ustarin=ustar Tarfile parsing offset:363520 (0x00058c00) current tarfile_offset:3398144 filename=mkfs.jffs2, filezie=163948 (160KB), ustarin=ustar Tarfile parsing offset:3398144 (0x0033da00) current tarfile_offset:3563008 filename=mkyaffs2image, filezie=48052 (46KB), ustarin=ustar Tarfile parsing offset:3563008 (0x00365e00) current tarfile_offset:3611648 filename=nandwrite, filezie=61668 (60KB), ustarin=ustar Tarfile parsing offset:3611648 (0x00371c00) current tarfile_offset:3674112 filename=package5/, filezie=0 (0KB), ustarin=ustar Tarfile parsing offset:3674112 (0x00381000) [INSTALL INFO][./src/rtk_imgdesc.cpp][616] package5/ can't be figured current tarfile_offset:3674624 filename=package5/vmlinux.develop.android.saturn.nand.bin, filezie=7483204 (7307KB), ustarin=ustar Tarfile parsing offset:3674624 (0x00381200) current tarfile_offset:11158528 filename=package5/bootloader.tar, filezie=2467840 (2410KB), ustarin=ustar Tarfile parsing offset:11158528 (0x00aa4400) current tarfile_offset:13626880 filename=package5/yaffs2_2.img, filezie=1480512 (1445KB), ustarin=ustar Tarfile parsing offset:13626880 (0x00cfee00) current tarfile_offset:15108096 filename=package5/video_firmware.bin, filezie=2298336 (2244KB), ustarin=ustar Tarfile parsing offset:15108096 (0x00e68800) current tarfile_offset:17406976 filename=package5/squashfs1.img, filezie=181489664 (177236KB), ustarin=ustar Tarfile parsing offset:17406976 (0x01099c00) current tarfile_offset:198897152 filename=package5/bluecore.audio, filezie=1883184 (1839KB), ustarin=ustar Tarfile parsing offset:198897152 (0x0bdaee00) current tarfile_offset:200781312 filename=uEGBK.mbf, filezie=747522 (730KB), ustarin=ustar Tarfile parsing offset:200781312 (0x0bf7ae00) current tarfile_offset:201529856 filename=video_firmware.install.bin, filezie=2391176 (2335KB), ustarin=ustar Tarfile parsing offset:201529856 (0x0c031a00) current tarfile_offset:203921920 [INSTALL DEBUG][./src/rtk_tar.cpp][152] tar magic error command:tar xv -f /mnt/usbmounts/sda1/install.img en_kh.txt, (139) [./src/rtk_main.cpp] tar: en_kh.txt: not found in archive [INSTALL DEBUG][./src/rtk_common.cpp][190] Can't exec command:tar xv -f /mnt/usbmounts/sda1/install.img en_kh.txt, (139) [./src/rtk_main.cpp] command:tar xv -f /mnt/usbmounts/sda1/install.img rsa_key_tmp.pub, (141) [./src/rtk_main.cpp] tar: rsa_key_tmp.pub: not found in archive [INSTALL DEBUG][./src/rtk_common.cpp][190] Can't exec command:tar xv -f /mnt/usbmounts/sda1/install.img rsa_key_tmp.pub, (141) [./src/rtk_main.cpp] [INSTALL INFO][./src/rtk_mtd.cpp][101] Open MTD_BLOCK /dev/mtdblock0 with 56623104(0x3600000) offset fw_table: a0 ac 1a 90 90 36 52 80 00 00 10 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 80 00 00 00 00 [INSTALL DEBUG][./src/rtk_fwdesc.cpp][74] Wrong boottable version:0x00 [INSTALL DEBUG][./src/rtk_imgdesc.cpp][130] load_fwdesc() fail Extract configuration.xml file... tarfile_offset:0x00023200 (2315 Bytes = 2 KB) extract configuration.xml from /mnt/usbmounts/sda1/install.img 100 |******************************| 2 KB total_time:0 secands extract ok Realtek Semiconductor Corp. This image file contains 3 Jupiter packages. The first one is for AVHDD on NOR, the second one is for AVHDD on NAND, and the third one is for AVHDD on ISO image. v10.1.11.r11498 05/26/14 12:04 Saturn image files install_a 4c7fd58c048cde1ecfa1a34c47d1a092 y This is Android on NAND of Saturn N/A cache 52428800 package5/vmlinux.develop.android.saturn.nand.bin 0x80100000 SVN:11498 package5/bluecore.audio 0x81b00000 N/A package5/video_firmware.bin 0x81d80000 N/A package5/bootloader.tar N/A package5/squashfs1.img / package5/yaffs2_2.img /usr/local/etc 1073741824 [INSTALL DEBUG][./src/rtk_imgdesc.cpp][201] (Audio Bootfile) target address not found!! skip [INSTALL DEBUG][./src/rtk_imgdesc.cpp][201] (Video Bootfile) target address not found!! skip [INSTALL INFO][./src/rtk_imgdesc.cpp][253] prtkimg->option(0x3)etc_partition_size(0x40000000) preserve_partition_size(0x3200000) [INSTALL DEBUG][./src/rtk_imgdesc.cpp][271] The size of FW_TYPE:3 is zero!! flash_type=0x00000004, flash_size=0x0100000000 (4194304 KB), mtd_erasesize=0x00200000, page_size=0x00002000, total_sector=2048 [INSTALL LOG][./src/rtk_imgdesc.cpp][410] Kernel flash_ofs:0x0003800000 allo_size:0x00800000 end:0x0004000000 img_size:0x00722f44( 7307 KBytes)(004 sectors) Audio kernel flash_ofs:0x0004000000 allo_size:0x00200000 end:0x0004200000 img_size:0x001cbc30( 1839 KBytes)(001 sectors) Video kernel flash_ofs:0x0004200000 allo_size:0x00400000 end:0x0004600000 img_size:0x002311e0( 2244 KBytes)(002 sectors) Audio Bootfile flash_ofs:0x0004600000 allo_size:0x00000000 end:0x0004600000 img_size:0x00000000( 0 KBytes)(000 sectors) Video Bootfile flash_ofs:0x0004600000 allo_size:0x00000000 end:0x0004600000 img_size:0x00000000( 0 KBytes)(000 sectors) RootFS flash_ofs:0x00a5000000 allo_size:0x0ae00000 end:0x00afe00000 img_size:0x0ad15000(177236 KBytes)(087 sectors) Resource flash_ofs:0x00afe00000 allo_size:0x00000000 end:0x00afe00000 img_size:0x00000000( 0 KBytes)(000 sectors) Preserve flash_ofs:0x00afe00000 allo_size:0x03200000 end:0x00b3000000 img_size:0x00000000( 0 KBytes)(025 sectors) Usr.local.etc flash_ofs:0x00b3000000 allo_size:0x40000000 end:0x00f3000000 img_size:0x00169740( 1445 KBytes)(512 sectors) bootcode flash_ofs:0x0000000000 allo_size:0x00000000 end:0x0000000000 img_size:0x0025a800( 2410 KBytes)(000 sectors) ROOTFS:/, USR_LOCAL_ETC:/usr/local/etc Kernel target_offset:0x80100000 tarfile_offset:0x00381200 Audio kernel target_offset:0x81b00000 tarfile_offset:0x0bdaee00 Video kernel target_offset:0x81d80000 tarfile_offset:0x00e68800 Audio Bootfile target_offset:0xffffffff tarfile_offset:0x00000000 Video Bootfile target_offset:0xffffffff tarfile_offset:0x00000000 RootFS target_offset:0x00000000 tarfile_offset:0x01099c00 Resource target_offset:0x00000000 tarfile_offset:0x00000000 Preserve target_offset:0x00000000 tarfile_offset:0x00000000 Usr.local.etc target_offset:0x00000000 tarfile_offset:0x00cfee00 bootcode target_offset:0x00000000 tarfile_offset:0x00aa4400 Extract video_firmware.install.bin file... tarfile_offset:0x0c031a00 (2391176 Bytes = 2335 KB) extract video_firmware.install.bin from /mnt/usbmounts/sda1/install.img 100 |******************************| 2335 KB total_time:0 secands extract ok Extract uEGBK.mbf file... tarfile_offset:0x0bf7ae00 (747522 Bytes = 730 KB) extract uEGBK.mbf from /mnt/usbmounts/sda1/install.img 100 |******************************| 730 KB total_time:0 secands extract ok Extract image/update_bg_ok.png file... tarfile_offset:0x0002fc00 (53749 Bytes = 52 KB) extract image/update_bg_ok.png from /mnt/usbmounts/sda1/install.img 100 |******************************| 52 KB total_time:0 secands extract ok Extract image/update_focus.png file... tarfile_offset:0x0003d000 (2871 Bytes = 2 KB) extract image/update_focus.png from /mnt/usbmounts/sda1/install.img 100 |******************************| 2 KB total_time:0 secands extract ok Extract image/update_bg.png file... tarfile_o*** 476MB version... ffset:0x0003de00 (52790 Bytes = 51 KB) extauth: memory address 0x40000000... ract im ***************** se open: queue = 0 ********************* ag ***************** se open: initialized = 0 ********************* e/uarch/mips/rtk_dmp/drivers/se.c, 714: offset = 0, se_devices = 90188000 pdarch/mips/rtk_dmp/drivers/se.c, 724: offset = 0 atarch/mips/rtk_dmp/drivers/se.c, 768: length = 20480 e_arch/mips/rtk_dmp/drivers/se.c, 769: offset = 270041088 bgarch/mips/rtk_dmp/drivers/se.c, 776: offset = 270041088 .parch/mips/rtk_dmp/drivers/se.c, 714: offset = 98316, se_devices = 90188000 ngarch/mips/rtk_dmp/drivers/se.c, 724: offset = 402702336 farch/mips/rtk_dmp/drivers/se.c, 768: length = 4096 roarch/mips/rtk_dmp/drivers/se.c, 769: offset = 402702336 m arch/mips/rtk_dmp/drivers/se.c, 776: offset = 402702336 /mnt/usbmounts/sda1/install.img 100 |******************************| 51 KB total_time:0 secands extract ok Extract image/update_unfocus.png file... tarfile_offset:0x0004b000 (2871 Bytes = 2 KB) extract image/update_unfocus.png from /mnt/usbmounts/sda1/install.img 100 |******************************| 2 KB === GET HWSEM... total_time:0 secands extract ok Extract image/update_bg_fail.png file... tarfile_offset:0x0004be00 (51773 Bytes = 50 KB) extract image/update_bg_fail.png from /mnt/usbmounts/sda1/install.img === GET HWSEM... 100 |******************************| 50 KB total_time:0 secands extract ok pli initialization... call pli_init, return 0 pli_getStattAddress() return 0x40000000 start[0-3] = {7ff1a500} end[0-3] = {7ff1a504} **chip_id = 1186 chip_id&0xF =0x6 SB2 DEBUG CONTROL(0)= 0x0 --> 0x0 SB2 DEBUG CONTROL(1)= 0x0 --> 0x0 SB2 DEBUG CONTROL(2)= 0x0 --> 0x0 SB2 DEBUG CONTROL(3)= 0x0 --> 0x0 SB2 DEBUG CONTROL(4)= 0x0 --> 0x0 SB2 DEBUG CONTROL(5)= 0x0 --> 0x0 SB2 DEBUG CONTROL(6)= 0x0 --> 0x0 SB2 DEBUG CONTROL(7)= 0x0 --> 0x0 SB2 INT = 0x0 --> 0x0 SB2 start addr(0)= 0x0 --> 0x0 SB2 end addr(0)= 0x0 --> 0x0 SB2 start addr(1)= 0x0 --> 0x0 SB2 end addr(1)= 0x0 --> 0x0 SB2 start addr(2)= 0x1d80000 --> 0x0 SB2 end addr(2)= 0x1ffdfff --> 0x0 SB2 start addr(3)= 0x1d80410 --> 0x0 SB2 end addr(3)= 0x1ed3a10 --> 0x0 SB2 start addr(4)= 0x2000000 --> 0x0 SB2 end addr(4)= 0x24ef7ff --> 0x0 SB2 start addr(5)= 0x0 --> 0x0 SB2 end addr(5)= 0x0 --> 0x0 SB2 start addr(6)= 0x0 --> 0x0 SB2 end addr(6)= 0x0 --> 0x0 SB2 start addr(7)= 0x0 --> 0x0 SB2 end addr(7)= 0x0 --> 0x0 IS_CHIP(SATURN) Saturn... got //video_firmware.install.bin video start addr, ptr=0x41d80000 video image size, cnt=2391176 audio_addr = 0xb081 video_addr = 0xd881 sleep for 3 seconds... C[RPC]open for RPC ioctl... al[RPC]start reset... li[RPC]done... n pli_resetRPC()... Release SW Semaphore. command:rm -rf /video_firmware.install.bin /tmp/video_firmware.install.bin, (1556) [./src/rtk_ui.cpp] Got encoding system: 7 (PAL) call initRPCProxy... done. call getTVE... done. call prepareCLNT... done. [Video Firmware Version] 399810 [Video Binary Built on] Jan 12 2012 22:38:13 pli malloc order: 12 +++ ALLOC index: 0 order: 12 zone: 80849000 page: 80849000(82000000) count: 4096 start remap DVR zone 82000000(80849000) 4096... total migrated: done: 0 fail: 0 pli malloc order: 10 +++ ALLOC index: 4096 order: 10 zone: 80849000 page: 80869000(83000000) count: 1024 start remap DVR zone 83000000(80869000) 1024... total migrated: done: 0 fail: 0 pli malloc order: 10 +++ ALLOC index: 5120 order: 10 zone: 80849000 page: 80871000(83400000) count: 1024 start remap DVR zone 83400000(80871000) 1024... total migrated: done: 0 fail: 0 pli malloc order: 3 +++ ALLOC index: 6144 order: 3 zone: 80849000 page: 80879000(83800000) count: 8 start remap DVR zone 83800000(80879000) 8... total migrated: done: 0 fail: 0 pli malloc order: 12 +++ ALLOC index: 8192 order: 12 zone: 80849000 page: 80889000(84000000) count: 4096 start remap DVR zone 84000000(80889000) 4096... total migrated: done: 0 fail: 0 pli malloc order: 12 +++ ALLOC index: 12288 order: 12 zone: 80849000 page: 808a9000(85000000) count: 4096 start remap DVR zone 85000000(808a9000) 4096... total migrated: done: 0 fail: 0 pli malloc order: 12 +++ ALLOC index: 16384 order: 12 zone: 80849000 page: 808c9000(86000000) count: 4096 start remap DVR zone 86000000(808c9000) 4096... total migrated: done: 0 fail: 0 pli malloc order: 12 +++ ALLOC index: 20480 order: 12 zone: 80849000 page: 808e9000(87000000) count: 4096 start remap DVR zone 87000000(808e9000) 4096... total migrated: done: 0 fail: 0 VBM: configured to SD! call VIDEVBM: deleting GOB id=0 ... OVBM: deleting GOB id=1 ... _VBM: deleting GOB id=2 ... RVBM: deleting GOB id=3 ... PVBM: deleting GOB id=4 ... CVBM: deleting GOB id=5 ... _VBM: deleting GOB id=6 ... TVBM: deleting GOB id=7 ... oVBM: deleting GOB id=8 ... AVBM: deleting GOB id=9 ... VBM: deleting GOB id=10 ... gVBM: deleting GOB id=11 ... eVBM: deleting GOB id=12 ... nVBM: deleting GOB id=13 ... tVBM: deleting GOB id=14 ... VBM: deleting GOB id=15 ... _VBM: deleting GOB id=16 ... VVBM: deleting GOB id=17 ... iVBM: deleting GOB id=18 ... dVBM: deleting GOB id=19 ... eoCreate_0...--- FREE index: 20480 order: 12 done. call pl--- FREE index: 16384 order: 12 i_alloBM: configured to HD! cContinuousMemory... done. call pli_IPCWriteULONG... done. call prepareCLNT... done. call setDebugFlag... done. call VIDEO_RPC_ToAgent_VideoChunkConfig_0... done. -=- create MBF engine for //uEGBK.mbf get_os (TVE) TVE_DAC_mode 0!! ~~comp 0, ch2 0, mode_3D 0!! ~~TVE standard# d_language(0) call SetVO() start. [RPCTest] VIDEO_RPC_VOUT_ToAgent_SetVideoStandard [RPCTest] VIDEO_RPC_VOUT_ToAgent_SetVideoStandard = S_OK vo.SetBackground() vo.ConfigureOSD() vo.SetDeintMode() vo.SetRescaleMode() vo.ConfigureDisplayWindow() vo.ConfigGraphicCanvas() call SetVO() end. call SetHDMI() start. [HDMI]: Turn off HDMI [HDMI]: Set AVMute [HDMI]: TURN OFF HDMI PHY for Jupiter/Saturn ----------------------------------------- [I2C0] Xfer fail - TXABORT (1/2), Reason=0001 msg->addr = 50 msg->flags = 0001 msg->len = 4 msg->buf = 981d9980 ----------------------------------------- [HDMI (VO_ConfigHDMI_InfoFra]me) L:219, is_hdmi_plugin 1, hdmiMode 1!! (HDMI_3D) mode 1, HDMI_gen 0, En_3D 0, Format_3D 0!! go back SET_HDMI!!: Read pli malloc order: 12 ED+++ ALLOC index: 16384 order: 12 ID zone: 80849000 page: 808c9000(86000000) count: 4096 f start remap DVR zone 86000000(808c9000) 4096... ails,total migrated: done: 0 fail: 0 i=0 [HDMI]: Turn on HDMI mode................... [RPCTest] VIDEO_RPC_VOUT_ToAgent_ConfigHdmiInfoFrame_0 = S_OK [HDMI]: Turn on HDMI [HDMI]: Clear AVMute [HDMI]: TURN ON HDMI PHY for Jupiter/Saturn WARNING[4]:TVE i-underflow @ line 0 WARNING[4]:TVE p-underflow @ line 0 WARNING[4]:TVE h-underflow @ line 0 call SetHDMI() end. call EnableUI() DG_CreateSurface() DG_GetDisplayHandle() DG_DisplayArea() start. DG_DisplayArea() end. call EnableUI() end. ---------- g_totalSize(188627)KB Extract bootloader.tar file... tarfile_offset:0x00aa4400 (2467840 Bytes = 2410 KB) extract bootloader.tar from /mnt/usbmounts/sda1/install.img 100 |******************************| 2410 KB total_time:0 secands extract ok command:mkdir -p /tmp/tar_file_tmp;tar -xf /tmp/bootfw -C /tmp/tar_file_tmp, (55) [./src/rtk_burn.cpp] /tmp/tar_file_tmp/logo10.bin not exist. /tmp/tar_file_tmp/logo11.bin not exist. /tmp/tar_file_tmp/logo12.bin not exist. /tmp/tar_file_tmp/logo13.bin not exist. /tmp/tar_file_tmp/logo14.bin not exist. /tmp/tar_file_tmp/logo15.bin not exist. /tmp/tar_file_tmp/logo16.bin not exist. /tmp/tar_file_tmp/logo17.bin not exist. /tmp/tar_file_tmp/logo18.bin not exist. /tmp/tar_file_tmp/logo19.bin not exist. /tmp/tar_file_tmp/logo20.bin not exist. flapli malloc order: 9 sh+++ ALLOC index: 6656 order: 9 t zone: 80849000 page: 8087d000(83a00000) count: 512 yp start remap DVR zone 83a00000(8087d000) 512... e: nand total migrated: done: 512 fail: 0 pli malloc order: 4 +++ ALLOC index: 6160 order: 4 zone: 80849000 page: 80879200(83810000) count: 16 start remap DVR zone 83810000(80879200) 16... total migrated: done: 16 fail: 0 pli malloc order: 7 +++ ALLOC index: 6272 order: 7 zone: 80849000 page: 8087a000(83880000) count: 128 start remap DVR zone 83880000(8087a000) 128... total migrated: done: 128 fail: 0 pli malloc order: 10 +++ ALLOC index: 7168 order: 10 zone: 80849000 page: 80881000(83c00000) count: 1024 start remap DVR zone 83c00000(80881000) 1024... total migrated: done: 1024 fail: 0 Begin:[H27UBG8T2B][20202020 20 20] [20202020 20 20] [20202020 20 20] blk_state_len =0x19 get original param in block b, size 0x520 ............/...............--- FREE index: 6656 order: 9 ..--- FREE index: 6160 order: 4 ......--- FREE index: 7168 order: 10 ..--- FREE index: 6272 order: 7 ................/..............................................................................................................................................................................................................................................................././........................................./..............................................................................................................................................................................................................................................................././........................................./..............................................................................................................................................................................................................................................................././........................................./...............................................................................................................................................................................................................................................................do_exit_n blk_state: d0 bb bb 23 23 23 23 79 79 79 79 80 80 80 80 ff ff ff ff ff ff ff ff ff ff Finish write bootcode success [INSTALL LOG][./src/rtk_burn.cpp][58] boot_main:ret:0 [INSTALL LOG][./src/rtk_main.cpp][44] In NAND FLASH command:echo -n RESCUE__ | dd of=/dev/mtdblock0 bs=1 seek=56623104, (103) [./src/rtk_burn.cpp] .8+0 records in 8+0 records out Extract mkyaffs2image file... tarfile_offset:0x00365e00 (48052 Bytes = 46 KB) extract mkyaffs2image from /mnt/usbmounts/sda1/install.img 100 |******************************| 46 KB total_time:0 secands extract ok Extract nandwrite file... tarfile_offset:0x00371c00 (61668 Bytes = 60 KB) extract nandwrite from /mnt/usbmounts/sda1/install.img 100 |******************************| 60 KB total_time:0 secands extract ok Extract flash_erase file... tarfile_offset:0x00023e00 (47504 Bytes = 46 KB) extract flash_erase from /mnt/usbmounts/sda1/install.img 100 |******************************| 46 KB total_time:0 secands extract ok command:chmod 777 /usr/sbin/mkyaffs2image;chmod 777 /usr/sbin/nandwrite;chmod 777 /usr/sbin/flash_erase, (202) [./src/rtk_burn.cpp] Burning Kernel efwtype(0) image with mem_offset(0x80100000) ... flash_offset:0x0003800000 flash_allo_size:0x00800000 bytes(4 sector) tarfile_offset:0x00381200 image_size:0x00722f44 bytes(7307 KB) command:/usr/sbin/flash_erase /dev/mtd0 58720256 4, (572) [./src/rtk_burn.cpp] Erase Total 4 Units Performing Flash Erase of length 2097152 at offset 0x3e00000 done popen(cmd):/usr/sbin/nandwrite -c -x -X -s 58720256 -l 7483204 /dev/mtd0 - start burning progress_callback---------- totalLen(7483204) g_burnSize(0) nandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c ....checksum:0x215994C5 total_time:2 secands Writing data finishes !! Complete!! Burning Audio kernel efwtype(1) image with mem_offset(0x81b00000) ... flash_offset:0x0004000000 flash_allo_size:0x00200000 bytes(1 sector) tarfile_offset:0x0bdaee00 image_size:0x001cbc30 bytes(1839 KB) command:/usr/sbin/flash_erase /dev/mtd0 67108864 1, (572) [./src/rtk_burn.cpp] Erase Total 1 Units Performing Flash Erase of length 2097152 at offset 0x4000000 done popen(cmd):/usr/sbin/nandwrite -c -x -X -s 67108864 -l 1883184 /dev/mtd0 - start burning progress_callback---------- totalLen(1883184) g_burnSize(7483204) nandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c .checksum:0x0877547B total_time:1 secands Writing data finishes !! Complete!! Burning Video kernel efwtype(2) image with mem_offset(0x81d80000) ... flash_offset:0x0004200000 flash_allo_size:0x00400000 bytes(2 sector) tarfile_offset:0x00e68800 image_size:0x002311e0 bytes(2244 KB) command:/usr/sbin/flash_erase /dev/mtd0 69206016 2, (572) [./src/rtk_burn.cpp] Erase Total 2 Units Performing Flash Erase of length 2097152 at offset 0x4400000 done popen(cmd):/usr/sbin/nandwrite -c -x -X -s 69206016 -l 2298336 /dev/mtd0 - start burning progress_callback---------- totalLen(2298336) g_burnSize(9366388) nandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c ..checksum:0x06F0B3BC total_time:1 secands Writing data finishes !! Complete!! Burning Audio Bootfile efwtype(3) image with mem_offset(0xffffffff) ... flash_offset:0x0004600000 flash_allo_size:0x00000000 bytes(0 sector) tarfile_offset:0x00000000 image_size:0x00000000 bytes(0 KB) [INSTALL DEBUG][./src/rtk_burn.cpp][562] Audio Bootfile don't exist [INSTALL DEBUG][./src/rtk_main.cpp][78] Audio bootfile none Burning Video Bootfile efwtype(4) image with mem_offset(0xffffffff) ... flash_offset:0x0004600000 flash_allo_size:0x00000000 bytes(0 sector) tarfile_offset:0x00000000 image_size:0x00000000 bytes(0 KB) [INSTALL DEBUG][./src/rtk_burn.cpp][562] Video Bootfile don't exist [INSTALL DEBUG][./src/rtk_main.cpp][83] Video bootfile none Burning RootFS efwtype(5) image with mem_offset(0x00000000) ... flash_offset:0x00a5000000 flash_allo_size:0x0ae00000 bytes(87 sector) tarfile_offset:0x01099c00 image_size:0x0ad15000 bytes(177236 KB) command:/usr/sbin/flash_erase /dev/mtd0 2768240640 87, (572) [./src/rtk_burn.cpp] Erase Total 87 Units Performing Flash Erase of length 2097152 at offset 0xafc00000 done popen(cmd):/usr/sbin/nandwrite -c -x -X -s 2768240640 -l 181489664 /dev/mtd0 - start burning progress_callback---------- totalLen(181489664) g_burnSize(11664724) nandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c .............................................. .......................................................checksum:0x8F8A6A61 total_time:62 secands Writing data finishes !! Complete!! Burning Resource efwtype(6) image with mem_offset(0x00000000) ... flash_offset:0x00afe00000 flash_allo_size:0x00000000 bytes(0 sector) tarfile_offset:0x00000000 image_size:0x00000000 bytes(0 KB) [INSTALL DEBUG][./src/rtk_burn.cpp][562] Resource don't exist [INSTALL DEBUG][./src/rtk_main.cpp][94] burn Resource fail Burning Preserve efwtype(7) image with mem_offset(0x00000000) ... flash_offset:0x00afe00000 flash_allo_size:0x03200000 bytes(25 sector) tarfile_offset:0x00000000 image_size:0x00000000 bytes(0 KB) command:/usr/sbin/flash_erase /dev/mtd0 2950692864 25, (491) [./src/rtk_burn.cpp] Erase Total 25 Units Performing Flash Erase of length 2097152 at offset 0xb2e00000 done preserve partition Complete!! Burning Usr.local.etc efwtype(8) image with mem_offset(0x00000000) ... flash_offset:0x00b3000000 flash_allo_size:0x40000000 bytes(512 sector) tarfile_offset:0x00cfee00 image_size:0x00169740 bytes(1445 KB) Burning Usr.local.etc efwtype(8) image with mem_offset(0x00000000) ... flash_offset:0x00b3000000 flash_allo_size:0x40000000 bytes(512 sector) tarfile_offset:0x00cfee00 image_size:0x00169740 bytes(1445 KB) command:/usr/sbin/flash_erase /dev/mtd0 3003121664 512, (572) [./src/rtk_burn.cpp] Erase Total 512 Units Performing Flash Erase of length 2097152 at offset 0xf2e00000 done popen(cmd):/usr/sbin/nandwrite -c -y -n -o -X -s 3003121664 -l 1480512 /dev/mtd0 - start burning 0 | | 8 KBnandwrite $ Revision: 1.63 release Version.$ struct64... Linux version 0x2060c 100 |******************************| 1445 KB checksum:0x05C4FD60 total_time:1 secands Data buf File I/O error on input file: Unknown error 0 ERR readlen is 8192, cnt is 3072 Complete!! [INSTALL INFO][./src/rtk_burn.cpp][1010] RootFS offset(0xa5000000) [INSTALL INFO][./src/rtk_burn.cpp][1041] Preserve offset(0xafe00000) [INSTALL INFO][./src/rtk_burn.cpp][1054] Usr.local.etc offset(0xb3000000) [INSTALL INFO][./src/rtk_burn.cpp][1066] remapping offset(0xf3000000) [INSTALL INFO][./src/rtk_burn.cpp][1099] partition(0) length(0xa5000000) [INSTALL LOG][./src/rtk_burn.cpp][1128] BOOTTABLE PRESERVE[INSTALL INFO][./src/rtk_burn.cpp][1158] rtk_fw_head.part_count:5 [INSTALL LOG][./src/rtk_fwdesc.cpp][351] veraion:0x01 fw_count:7, part_count:5 checksum:0x00001e08 [INSTALL INFO][./src/rtk_mtd.cpp][101] Open MTD_BLOCK /dev/mtdblock0 with 56623104(0x3600000) offset 56 45 52 4f 4e 41 5f 5f 00 00 1e 08 01 00 00 00 00 00 00 00 00 20 00 00 00 00 00 f0 00 00 00 e0 01 80 a5 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 0a e0 00 00 01 06 00 00 00 00 00 00 00 00 2f 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 03 20 00 00 01 09 00 00 00 00 00 00 00 00 63 61 63 68 65 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 40 00 00 00 01 09 00 00 00 00 00 00 00 00 2f 75 73 72 2f 6c 6f 63 61 6c 2f 65 74 63 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 80 0d 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 80 00 00 00 00 80 10 00 00 03 80 00 00 00 72 2f 44 00 80 00 00 00 00 00 00 00 00 00 00 00 00 03 80 00 00 00 00 81 b0 00 00 04 00 00 00 00 1c bc 30 00 20 00 00 00 00 00 00 00 00 00 00 00 00 04 80 00 00 00 00 81 d8 00 00 04 20 00 00 00 23 11 e0 00 40 00 00 00 00 00 00 00 00 00 00 00 00 06 80 00 00 00 00 00 00 00 00 a5 00 00 00 0a d1 50 00 0a e0 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 af e0 00 00 00 00 00 00 03 20 00 00 00 00 00 00 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00 b3 00 00 00 00 16 97 40 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 f3 00 00 00 0d 00 00 00 0d 00 00 00 00 00 00 00 00 00 00 00 00 00 .. rtk_burn_rtkimg_from_usb():0 install time:88 secands command:pci stop, (138) [install_a.cpp] sh: pci: not found [INSTALL DEBUG][./src/rtk_common.cpp][190] Can't exec command:pci stop, (138) [install_a.cpp] command:reboot, (139) [install_a.cpp] The system is going down NOW! Sending SIGTERM to all processes clear pli setting.... se release, count = 0 Sending SIGKILL to all processes Requesting system reboot Restarting system. ?hello.world efghhhhhhhhhhhhhhhhhhhhhhhhhihhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhjk Jump! Orginal init value: 202072BE cde profile->manufacturer_id (first 4B):DA94D7AD profile->data_per_page:2000 profile->page_per_block:100 blk 79 starts from page 700 klmnopqrstu5280 wait5280 wait4K&Detect H27UBG8T2B and enable read-retrial mode... Enable Read-retrial mode... load bbt...load env to (addr 0xa0010000, size 64KB)... page_start=0xf00 page_end=0x1900 get ENV fail!! load factory to (addr 0x80100000)... load bbt...ping_no =0xff pong_no =0xff there is no data in ping ,pong buffer current_factory_start=0x1900 current_factory_start + 0x400=0x1d00 tar end,not found tar end,not found default_tv_system= new default_tv_system=PAL EPHY: 8211E check_val=0x0 [HDMI]: Set I2C Speed = 50 kHz [HDMI]: Chk_HotPlug() TV is not connected. [HDMI]: Read_EDID abort, HDMI cable plug off. [HDMI]: TV is not connected. 2nd for PAL PAL logo REALTEK ROM Monitor, Revision ICIE.0402.1067. Copyright (c) Realtek Semiconductor Corp. - All Rights Reserved. For a list of available commands, type 'help'. Compilation time /version= Feb 19 2014 10:14:08 /ICIE.0402.1067 MAC address = 00.11.22.33.44.55 Processor Company ID/options = 0x01 (MIPS Technologies, Inc.) / 0x00 Processor ID/revision = 0x93 / 0x85 Endianness = Little Flash memory size = 4 GByte SDRAM size = 512 MByte First free SDRAM address = 0x800c4000 Press 'ESC' to Monitor mode ____________________Set ethernet register: 00000044 ▒r▒▒H) error! Entering rescue linux... Rescue kernel in FLASH, total size = 0x1f52d0 seg.1 addr 0xa0a06fd3, size = 0x1f52d0 seg.2 addr 0x0, size = 0x0 copy rescue0: from a0a06fd3 to 81000000, len = 1f52d0 decompressing rescue: from 81000000 to 80100000: size = 1f52d0 lzma finished decompressing rescue done go 0x80100000 defer 625p logo Reset Ethernet Mac. Address = 0x80100000 Linux version 2.6.34-VENUS (william@rtdmpsa-05) (gcc version 4.3.6 20110218 (prerelease) (GCC) ) #21 PREEMPT Wed Dec 4 13:08:14 CST 2013 Realtek LINUX started... Venus setting: ROSs have 4194304 bytes RAM. System CPU has 1 UART. System CPU uses internal timer interrupt. Bootloader version: ICIE.0402.1067. This version string is of new format. The information of this board: Company ID:0x0 CPU ID: 0x4 Board ID: 0x402 Ethernet Mac address: 00.11.22.33.44.55 Model Config length=6 Base year of RTC is 2010. ************************************************************** You didn't specify audio image address, use default instead... ************************************************************** audio addr: 0 Config serial console: console=ttyS0,115200n8r bootconsole [early0] enabled CPU revision is: 00019385 (MIPS 24Kc) FPU revision is: 01739300 Determined physical RAM map: memory: 00020000 @ 00000000 (reserved) memory: 000e0000 @ 00020000 (ROM data) memory: 01b00000 @ 00100000 (usable) memory: 00400000 @ 01c00000 (reserved) memory: 0e000000 @ 02000000 (usable) memory: 00100000 @ 10000000 (reserved) memory: 07f00000 @ 10100000 (usable) memory: 00100000 @ 18000000 (reserved) memory: 05b00000 @ 18100000 (usable) Wasting 8192 bytes for tracking 256 unused pages Initrd not found or empty - disabling initrd Zone PFN ranges: DMA 0x00000000 -> 0x00002000 Normal 0x00002000 -> 0x0001dc00 Movable zone start PFN for each node Node 0: 64512 early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x0001dc00 zone DMA size: 2000 realsize: 2000 zone Normal size: dc00 realsize: dc00 zone Movable size: e000 realsize: e000 zonelist: Movable Normal DMA Built 1 zonelists in Zone order, mobility grouping off. Total pages: 121856 Kernel command line: console=ttyS0,115200n8r ip=192.168.0.9::192.168.0.254:255.0.0.0::: PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes. Primary data cache 64kB, 4-way, PIPT, no aliases, linesize 32 bytes Writing ErrCtl register=0000ed70 Readback ErrCtl register=0000ed70 Memory: 468824k/480256k available (3506k kernel code, 11432k reserved, 852k data, 2600k init, 0k highmem) Hierarchical RCU implementation. NR_IRQS:8 Estimated CPU frequency: 796.55 MHz Console: colour dummy device 80x25 Calibrating delay loop... 529.20 BogoMIPS (lpj=2646016) Mount-cache hash table entries: 512 devtmpfs: initialized NET: Registered protocol family 16 prom_flashsize = 0x100000000 Flash size is 0x2000000 bio: create slab at 0 SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb cfg80211: Calling CRDA to update world regulatory domain Switching to clocksource MIPS-DMP NET: Registered protocol family 2 IP route cache hash table entries: 4096 (order: 2, 16384 bytes) Switched to NOHz mode on CPU #0 TCP established hash table entries: 16384 (order: 5, 131072 bytes) TCP bind hash table entries: 16384 (order: 4, 65536 bytes) TCP: Hash tables configured (established 16384 bind 16384) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. ***************** se init module ********************* se init module major number = 253 ***************** md init module ********************* md init module major number = 252 size of RPC_POLL_Dev 52 and RPC_INTR_Dev 52... init_vdso successfull rtktlb: Hello, Realtek TLB Mapper... AllocBP size: 688128 order: 8 offset: 0 <<>> 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 8: 0 9: 0 10: 0 11: 0 12: 0 13: 7 Addr: 82000000, order: 13 Addr: 84000000, order: 13 Addr: 86000000, order: 13 Addr: 88000000, order: 13 Addr: 8a000000, order: 13 Addr: 8c000000, order: 13 Addr: 8e000000, order: 13 NTFS driver 2.1.29 [Flags: R/O]. msgmni has been set to 915 alg: No test for stdrng (krng) io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) Serial: 8250/16550 driver, 2 ports, IRQ sharing enabled console [ttyS0] enabled, bootconsole disabled16550A console [ttyS0] enabled, bootconsole disabled serial8250: ttyS1 at MMIO 0x0 (irq = 3) is a 16550A brd: module loaded loop: module loaded Realtek Bulid-In SATA Driver Rev:SATURN (2011-02-24 15:10) sata_rtk sata_rtk: version 0.01 sata_rtk sata_rtk: slots 32 ports 1 scsi0 : sata_rtk ata1: SATA max UDMA/133 irq 4 Realtek NAND Flash Driver Rev:337905 (2010-10-18) (X)Enable interrupt mechanism of NAND driver. Get parameter from register... [rtk_nand_init]Bootcode size 0x3200000 [rtk_nand_init]Factory parameter size 0x400000 [rtk_nand_init]Disable NFCP... nand_base_rtk version:0824-2011 (X)NAND_POWEROFF_CARDREADER_WITH_MULTI_READ (X)NAND_READ_SKIP_UPDATE_BBT Detect H27UBG8T2B and enable read-retrial mode... Enable Read-retrial mode... Enable Randomized mechanism READ ID:0xad 0xd7 0x94 0xda 0x74 0xc3 One H27UBG8T2B chip has 1 die(s) on board nand part=H27UBG8T2B, id=add794da, device_size=4294967296, chip_size=4294967296, num_chips=1, page_size=8192, isLastPage=1, eccBits=24 [rtk_nand_scan_bbt] have created bbt B1, just loads it !! [dump_BBT] Nand BBT Content [0] (0, 27, 0, 2047) RTK: using the whole nand as a partitoin BGA Package[rtk_nand_init]Randomized enabled [rtk_nand_init]Ecc bit select 24 Realtek Nand Flash Driver is successfully installing. VenusSFC MTD init... NOR flash support list .. (X) HWSEMA support. (V) AUTO_HW_POLL support. (X) 4Bytes mode support. (V) Max erase size support. (V) Sfc_delay support. [venus_sfc_init]FLASH_BASE: 0xbdc00000 [venus_sfc_init]Flash size: 0x2000000 Read id orginal value : 0xc22015c2 --RDID Seq: 0xc2 | 0x20 | 0x15 VenusSFC MTD: MXIC MX25L1605 detected. SFC_4KB_ERASE VenusSFC MTD: Enable VenusSFC MD PP callback function. MD_READ Enable.. MD_WRITE Enable.. [venus_sfc_init]descriptor size 0x2000000 RedBoot partition parsing not available Venus SFC: using single partition Venus SFC: (for SST/SPANSION/MXIC SPI Flash) this Jupiter eth RX_OFFSET = 0x0 8139cplus: 10/100 PCI Ethernet driver v1.2 (Mar 22, 2004) MAC address = 0x00.11.22.33.44.55 Hotplug got one Neteth0: RTL-8139C+ at 0xb8016000, 00:11:22:33:44:55, IRQ 2 Hoehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver tplug of "Add" from "eth0". It may be Realtek's wireless device. [usb_param] setting for saturn #@# cfyeh-debug USBPHY_Register_Setting(861) 0xb8013808 = 0x4400a081 #@# cfyeh-debug USBPHY_Register_Setting(863) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 1 dr 7 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 2 dr 7 #@#[cfyeh-debug] USBPHY_Register_Setting(933) #@#[cfyeh-debug] USBPHY_Register_Setting(935) #@#[cfyeh-debug] USBPHY_Register_Setting(937) #@# cfyeh-debug USBPHY_SetReg_Default_39(289) tx_delay 2 [usb1_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb1_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb1_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb1_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb1_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit [usb2_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb2_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb2_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb2_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb2_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit ehci ehci: Rtk Dmp EHCI ehci ehci: new USB bus registered, assigned bus number 1 ehci ehci: irq 2, io mem 0xb8013000 cp_hotplug ehci ehci: USB 0.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [usb_param] setting for saturn #@# cfyeh-debug USBPHY_Register_Setting(861) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_Register_Setting(863) 0xb8013808 = 0x4400a080 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 1 dr 7 #@# cfyeh-debug USBPHY_SetReg_Default_33_port(210) port 2 dr 7 #@#[cfyeh-debug] USBPHY_Register_Setting(933) #@#[cfyeh-debug] USBPHY_Register_Setting(935) #@#[cfyeh-debug] USBPHY_Register_Setting(937) #@# cfyeh-debug USBPHY_SetReg_Default_39(289) tx_delay 2 [usb1_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb1_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb1_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb1_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb1_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit [usb2_param] usbphy reg 32, set sh = 0xa, get sh = 0xa, 4bit [usb2_param] usbphy reg 35, set src = 0x7, get src = 0x7, 3bit [usb2_param] usbphy reg 36, set senh = 0xa, get senh = 0xa, 4bit [usb2_param] usbphy reg 32, set sen = 0x9, get sen = 0x9, 4bit [usb2_param] usbphy reg 33, set dr = 0x7, get dr = 0x7, 3bit ohci ohci: Rtk Dmp OHCI ohci ohci: new USB bus registered, assigned bus number 2 ohci ohci: irq 2, io mem 0xb8013400 ata1: SATA link down (SStatus 0 SControl 300) hub 2-0:1.0: USB hub found hub 2-0:1.0: 2 ports detected #@# cfyeh-debug usb3_phy_setting_saturn(38) +++ #@# cfyeh-debug usb3_phy_setting_saturn(227) --- xhci xhci: Rtk Dmp XHCI xhci xhci: new USB bus registered, assigned bus number 3 xhci xhci: irq 2, io mem 0xb8020000 #@# cfyeh-debug xhci_irq(1747) 0x000002a0 0x002802a0 #@# cfyeh-debug handle_port_status(1096) 0x000002a0 0x002802a0 #@#[cfyeh-debug] handle_port_status(1124) NOT in U0 usb usb3: config 1 interface 0 altsetting 0 endpoint 0x81 has no SuperSpeed companion descriptor #######[cfyeh-debug] hub_events(3615) usb_plug_status 1 hub 3-0:1.0: USB hub found hub 3-0:1.0: 2 ports detected #@# cfyeh-debug xhci_hub_control(287) hack for usb3 portsc #@# cfyeh-debug usb3_mac_setting_saturn(232) +++ #@# cfyeh-debug usb3_mac_setting_saturn(253) 16bit #@# cfyeh-debug usb3_mac_setting_saturn(254) *(unsigned int volatile *)0xb8028200=0x2440 #@# cfyeh-debug usb3_mac_setting_saturn(255) *(unsigned int volatile *)0xb8028200=0x2440 #@# cfyeh-debug usb3_mac_setting_saturn(257) *(unsigned int volatile *)0xb8028200=0x2400 #@# cfyeh-debug usb3_mac_setting_saturn(268) 0xb8013258 = 0x7; #@# cfyeh-debug usb3_mac_setting_saturn(270) 0xb8013258 = 0x7; #@# cfyeh-debug usb3_mac_setting_saturn(274) GTXTHRCFG #@# cfyeh-debug usb3_mac_setting_saturn(275) 0xb8028108 = 0x02400008 #@# cfyeh-debug usb3_mac_setting_saturn(280) 0xb8028108 = 0x21010000 #@# cfyeh-debug usb3_mac_setting_saturn(283) GRXTHRCFG #@# cfyeh-debug usb3_mac_setting_saturn(284) 0xb802810c = 0x02000008 #@# cfyeh-debug usb3_mac_setting_saturn(289) 0xb802810c = 0x21080000 #@# cfyeh-debug usb3_mac_setting_saturn(294) disable usb mulit request #@# cfyeh-debug usb3_mac_setting_saturn(295) *(unsigned int volatile *)0xb8013200=0x0 #@# cfyeh-debug usb3_mac_setting_saturn(297) *(unsigned int volatile *)0xb8013200=0x0 #@# cfyeh-debug usb3_mac_setting_saturn(302) GUSB3PIPECTL #@# cfyeh-debug usb3_mac_setting_saturn(303) 0xb80282c0 = 0x00060002 #@# cfyeh-debug usb3_mac_setting_saturn(306) 0xb80282c0 = 0x00060202 #@# cfyeh-debug usb3_mac_setting_saturn(309) --- Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. i2c /dev entries driver [I2C0] i2c speed changed to 100 KHz I2C0 Bus Status Check.... OK ========================= = VER : 2.1b ========================= = PHY : 0 = MODEL: Saturn = SPD : 100 = SAR : 0x024 (7 bits) = TX FIFO DEPTH : 32 = RX FIFO DEPTH : 32 = FIFO THRESHOLD: 4 = BUS JAM RECORVER 3: ON = NON STOP WRITE : ON = GPIO RW SUPPORT : ON ========================= usb 1-1: new high speed USB device using ehci and address 2 [I2C1] i2c speed changed to 100 KHz I2C1 Bus Status Check.... OK ========================= = VER : 2.1b ========================= = PHY : 1 = MODEL: Saturn = SPD : 100 = SAR : 0x024 (7 bits) = TX FIFO DEPTH : 32 = RX FIFO DEPTH : 32 = FIFO THRESHOLD: 4 = BUS JAM RECORVER 3: ON = NON STOP WRITE : ON = GPIO RW SUPPORT : ON ========================= TCP cubic registered NET: Registered protocol family 10 IPv6 over IPv4 tunneling driver Hotplug gNET: Registered protocol family 17 ot one Net Hotplug of "Add" from "sit0". It may be Realtek's wireless device. scsi1 : usb-storage 1-1:1.0 #######[cfyeh-debug] hub_events(3619) usb_plug_status 0 #######[cfyeh-debug] usb_stor_scan_thread(841) usb_plug_status 1 cp_open alloc rings cp->rxdesc_buf =0xb022d000 , cp->ring_dma=0x1022d000 init_hw eth0: Set multicast. jupiter/saturn 1g init_hw finished eth0: Set multicast. eth0: Set multicast. eth0: Set multicast. ADDRCONF(NETDEV_UP): eth0: link is not ready #######[cfyeh-debug] usb_stor_scan_thread(869) usb_plug_status 2 scsi 1:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 4 #@#[cfyeh-debug] sd_probe(2278) sd_flag 1 #@#[cfyeh-debug] sd_probe_async(2186) sd_flag 2 #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 3 #@#[cfyeh-debug] sd_probe(2344) sd_flag 2 #######[cfyeh-debug] usb_stor_scan_thread(872) usb_plug_status 1 #######[cfyeh-debug] usb_stor_scan_thread(879) usb_plug_status 0 modprobe: module sd_mod not found modprobe: failed to load module sd_mod IP-Config: Complete: device=eth0, addr=192.168.0.9, mask=255.0.0.0, gw=192.168.0.254, host=192.168.0.9, domain=, nis-domain=(none), bootserver=255.255.255.255, rootserver=255.255.255.255, rootpath= sd 1:0:0:0: [sda] 31129600 512-byte logical blocks: (15.9 GB/14.8 GiB) sd 1:0:0:0: [sda] Write Protect is off sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 1 #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 2 #######[cfyeh-debug] hub_events(3615) usb_plug_status 1 usb 1-1: USB disconnect, address 2 #######[cfyeh-debug] usb_stor_disconnect(1021) usb_plug_status 2 #@#[cfyeh-debug] sd_remove(2385) sd_flag 3 sd 1:0:0:0: [sda] READ CAPACITY failed sd 1:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00 sd 1:0:0:0: [sda] Sense not available. sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 2 sda: detected capacity change from 15938355200 to 0 #@#[cfyeh-debug] sd_revalidate_disk(2061) sd_flag 3 sd 1:0:0:0: [sda] READ CAPACITY failed sd 1:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00 sd 1:0:0:0: [sda] Sense not available. sd 1:0:0:0: [sda] Assuming drive cache: write through #@#[cfyeh-debug] sd_revalidate_disk(2120) sd_flag 2 sd 1:0:0:0: [sda] Attached SCSI removable disk #@#[cfyeh-debug] sd_probe_async(2245) sd_flag 1 Freeing prom memory: 896k freed Freeing unused kernel memory: 2600k freed testcl#@#[cfyeh-debug] sd_remove(2403) sd_flag 0 ear_lockdata_once open lock file er#######[cfyeh-debug] usb_stor_disconnect(1025) usb_plug_status 1 ror. Hotplug: Cannot find "/tmp/usbmounts/sda". Welcome to Realtek Rescue Linux for PhotoViewer /etc/init.d/rcS: line 49: cannot create /sys/bus/usb/devices/usb1/bEnableHubOnBoard_woone: nonexistent directory mount: mounting /dev/cdroms/cdrom0 on /mnt/usbmounts/cdrom failed: No such device mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such file or directory mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such file or directory mount: mounting /dev/hda1 on /mnt/usbmounts/hda1 failed: No such device BUS_TYPE = (null) Hotplug: device "ram1" is skipped. BUS_TYPE = (null) Hotplug: device "ram2" is skipped. BUS_TYPE = (null) Hotplug: device "ram3" is skipped. BUS_TYPE = (null) Hotplug: device "ram4" is skipped. BUS_TYPE = (null) Hotplug: device "ram5" is skipped. BUS_TYPE = (null) Hotplug: device "ram6" is skipped. BUS_TYPE = (null) Hotplug: device "ram7" is skipped. BUS_TYPE = (null) Hotplug: device "ram9" is skipped. BUS_TYPE = (null) Hotplug: device "ram10" is skipped. BUS_TYPE = (null) Hotplug: device "ram11" is skipped. BUS_TYPE = (null) Hotplug: device "ram8" is skipped. BUS_TYPE = (null) Hotplug: device "ram13" is skipped. BUS_TYPE = (null) Hotplug: device "ram12" is skipped. BUS_TYPE = (null) Hotplug: device "loop0" is skipped. BUS_TYPE = (null) Hotplug: device "ram15" is skipped. BUS_TYPE = (null) Hotplug: device "loop1" is skipped. BUS_TYPE = (null) Hotplug: device "loop2" is skipped. BUS_TYPE = (nu#######[cfyeh-debug] hub_events(3619) usb_plug_status 0 ll) Hotplug: device "loop4" is skipped. BUS_TYPE = (null) Hotplug: device "loop5" is skipped. BUS_TYPE = (null) Hotplug: device "loop7" is skipped. BUS_TYPE = (null) Hotplug: device "ram14" is skipped. BUS_TYPE = (null) Hotplug: device "loop3" is skipped. BUS_TYPE = (null) Hotplug: device "mtdblock0" is skipped. BUS_TYPE = (null) Hotplug: device "ram0" is skipped. BUS_TYPE = (null) Hotplug: device "mtdblock1" is skipped. #@#[cfyeh-debug] check_boot_code_size(1085) nand_boot_size 0x3200000 #@#[cfyeh-debug] check_boot_code_size(1091) factory_size 0x400000 >>>>>> loader start! (Dec 4 2013:13:08:04, version=00.01.01) #@#[cfyeh-debug] check_boot_code_size(1085) nand_boot_size 0x3200000 #@#[cfyeh-debug] check_boot_code_size(1091) factory_size 0x400000 get_mtd_block_name(/dev/mtdblock0) [JH] checksignatue(), open(/dev/mtdblock0) nand_boot_size(0x3200000) factory_size(0x400000) fail 4, sig(VERO) no IMG_XXXX signature found Please press Enter to activate this console. BUS_TYPE = (null) Hotplug: device "loop6" is skipped. rmdir: '/var/lock/hotplug/mount_tmp/.sda': No such file or directory BUS_TYPE = usb
