------------------------------------------------------------------------------- -- Title : Polynom division -- Project : ------------------------------------------------------------------------------- -- File : poly_mult.vhd -- Author : -- Company : -- Created : 2023-01-03 -- Last update: 2023-01-03 -- Platform : -- Standard : VHDL'93/02 ------------------------------------------------------------------------------- -- Description: Hausaufgabe ------------------------------------------------------------------------------- -- Copyright (c) 2023, educational purposes only ------------------------------------------------------------------------------- -- Revisions : -- Date Version Author Description -- 2023-01-03 0.04 Xaver Xanthus based on gustl work, transformed from testbench, adopted to industry naming and style conventions -- expect functionale changes from poor documentation, sub-optimal identifiernaming and vector direction reversal ------------------------------------------------------------------------------- library ieee; use ieee.std_logic_1164.all; entity e_polymult is port ( clk_i : in std_logic; arst_i : in std_logic; -- inp_i : in std_logic; res_o : out std_logic_vector(11 downto 0)); end entity e_polymult; architecture behave of e_polymult is --signal s_inp_q : std_logic_vector(11 downto 0); signal reg_q : std_logic_vector(7 downto 0); signal s_inp : std_logic; -- consider 'alias' during refactoring signal s_out_2 : std_logic; signal s_out_q : std_logic_vector(11 downto 0); begin --s_inp <= s_inp_q(0); process(clk_i, arst_i) begin if arst_i = '1' then reg_q <= "110100000000"; --s_out_q <= (others => '0'); --s_inp_q <= (others => '0'); else if rising_edge(clk_i) then --s_inp_q <= '0' & s_inp_q(11 downto 1); reg_q(0) <= inp_i; reg_q(1) <= reg_q(0) xor inp_i; reg_q(2) <= reg_q(1) xor inp_i; reg_q(3) <= reg_q(2); reg_q(4) <= reg_q(3) xor inp_i; reg_q(5) <= reg_q(4); reg_q(6) <= reg_q(5); reg_q(7) <= reg_q(6) xor inp_i; --s_out_q <= s_out_2 & s_out_q(11 downto 1); end if; end if; end process; res_o <= reg_q(7) xor inp_i; end;
