#include #include #include // config options static bool print_recursion = false; static bool no_output = false; // algo parameters static const int max_num_digits = 20; static int num_digits, min_val, max_val, checksum; // working vars static int digits[max_num_digits]; // the result static int max_cs[max_num_digits], min_cs[max_num_digits]; // helper for faster pruning static long counter, rcounter; bool parseArgs(int argc,char **argv) { if (argc<5){printf("Zu wenig Parameter: 1.Anzahl Felder 2.Minwert 3.Maxwert 4.gew�nschte Quersumme\n"); return false;} num_digits=strtol(argv[1],0,10); //Anzahl Felder min_val=strtol(argv[2],0,10); // Min Wert max_val=strtol(argv[3],0,10); //Maxwert checksum=strtol(argv[4],0,10); // gew�nschte Quersumme if (num_digits > max_num_digits) {printf("Zuviele Felder\n");return false;} if(argc==6){ char *s = argv[5]; if(*s=='r') print_recursion=true; //Anzeige der Rekursivaufrufe if(*s=='o') no_output=true; //Anzeige ohne Ergebnisausgabe } return true; } void printout() { counter++; if (no_output) return; for (int i=num_digits-1; i>=0; i--) { printf(" %d,", digits[i]); } printf("\n"); } void listQCombis(int digit, int remaining_cs) { rcounter++; if (print_recursion) printf("listQCombis(digits=%d, remaining_cs=%d)\n", digit, remaining_cs); // pruning digit--; if (remaining_cs > max_cs[digit]) return; if (remaining_cs < min_cs[digit]) return; // result? if (digit==0) { digits[digit] = remaining_cs; printout(); return; } // recursion for (int i=min_val; i<=max_val; i++) { digits[digit] = i; listQCombis(digit, remaining_cs-i); } } int main(int argc,char **argv) { if (!parseArgs(argc, argv)) return 1; // prepare counter = 0; rcounter=0; for (int i = 0; i
