#include #include enum qoi_op { QOI_OP_INDEX, QOI_OP_DIFF, QOI_OP_LUMA, QOI_OP_RUN, QOI_OP_RGB, QOI_OP_RGBA, }; static inline enum qoi_op qoi_get_op(const unsigned char symbol){ if(symbol == 0xFE){ return QOI_OP_RGB; }else if(symbol == 0xFF){ return QOI_OP_RGBA; } return symbol >> 6; } static inline unsigned char qoi_color_to_index(const struct qoi_color_rgba c){ return (c.color[0] * 3 + c.color[1] * 5 + c.color[2] * 7 + c.color[3] * 11) % 64; } static inline int qoi_output_store(unsigned char*restrict out, struct qoi_color_rgba c){ // Feel free to change this as needed out[0] = c.color[2]; out[1] = c.color[1]; out[2] = c.color[0]; out[3] = c.color[3]; return 4; } void qoi_decode(struct qoi_decoder*restrict state, size_t count, unsigned char*restrict output){ if(!count || !state->input) return; if(state->run) goto skip_store; do { state->run = 1; { const unsigned char ch = *state->input++; switch(qoi_get_op(ch)){ case QOI_OP_INDEX: { if(!ch && !*state->input){ // Failsafe to prevent buffer overflows state->input = 0; count = 1; } state->current_color = state->table[ch]; } goto skip_store; case QOI_OP_DIFF: { state->current_color.color[0] += ((ch>>4) & 3) - 2; state->current_color.color[1] += ((ch>>2) & 3) - 2; state->current_color.color[2] += ( ch & 3) - 2; } break; case QOI_OP_LUMA: { const unsigned char rb = *state->input++; int8_t dg = (ch & 0x3F) - 32; state->current_color.color[0] += (rb >> 4) - 8 + dg; state->current_color.color[1] += dg; state->current_color.color[2] += (rb & 0x0F) - 8 + dg; } break; case QOI_OP_RUN: { state->run = (ch & 0x3F) + 1; } goto skip_store; case QOI_OP_RGB: { state->current_color.color[0] = *state->input++; state->current_color.color[1] = *state->input++; state->current_color.color[2] = *state->input++; } break; case QOI_OP_RGBA: { state->current_color.color[0] = *state->input++; state->current_color.color[1] = *state->input++; state->current_color.color[2] = *state->input++; state->current_color.color[3] = *state->input++; } break; } } state->table[qoi_color_to_index(state->current_color)] = state->current_color; skip_store: { if(!output){ if(state->run > count){ state->run -= count; count = 0; }else{ count -= state->run; } if(!count) break; }else{ for(; count && state->run--; count--){ output += qoi_output_store(output, state->current_color); } } } } while(count); }
