odroid@gnome-desktop:/data/mythtv-master/mythtv$ ./configure --compile-type=release --disable-firewire --disable-hdhomerun --disable-vbox --disable-ceton --disable-satip --dvb-path=/opt/include/frontend.h --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libvpx --enable-libxvid Qt built for OpenGL ES sed 's#@@PREFIX@@#/data/mythtv-master/mythtv/external/nv-codec-headers/install#' ffnvcodec.pc.in > ffnvcodec.pc install -m 0755 -d '/data/mythtv-master/mythtv/external/nv-codec-headers/install/include/ffnvcodec' install -m 0644 include/ffnvcodec/*.h '/data/mythtv-master/mythtv/external/nv-codec-headers/install/include/ffnvcodec' install -m 0755 -d '/data/mythtv-master/mythtv/external/nv-codec-headers/install/lib/pkgconfig' install -m 0644 ffnvcodec.pc '/data/mythtv-master/mythtv/external/nv-codec-headers/install/lib/pkgconfig' ffopts = '--arch=aarch64' '--sysinclude=/usr/include' '--cc=gcc' '--cxx=g++' '--ld=gcc' '--cpu=generic' '--target_os=linux' '--pkg_config=pkg-config' '--prefix=/usr/local' '--libdir=/usr/local/lib' '--as=gcc' '--objcc=gcc' '--dep_cc=gcc' '--host_cc=gcc' '--host_ld=gcc' '--ar=ar' '--nm=nm -g' '--ranlib=ranlib -D' --disable-cross-compile --enable-libmp3lame --enable-libx264 --enable-libx265 --enable-libvpx --enable-libxvid --disable-vdpau --enable-libxml2 --disable-libass --disable-dxva2 --enable-libbluray --disable-libfontconfig --disable-libfreetype --disable-libiec61883 --disable-crystalhd --disable-sdl2 --disable-ffplay --enable-libaom --extra-cflags=' -w' --extra-ldflags='' --extra-libs='' --enable-stripping --strip='echo skipping strip' --disable-manpages --disable-podpages --disable-doc --disable-nvenc --enable-shared --disable-static --enable-gpl --enable-pic --disable-demuxer=mpegtsraw --disable-indev=dshow #### FFmpeg CONFIGURATION #### install prefix /usr/local source path . C compiler gcc C library glibc ARCH aarch64 (generic) big-endian no runtime cpu detection yes NEON enabled yes VFP enabled yes debug symbols yes strip symbols yes optimize for size no optimizations yes static no shared yes postprocessing support yes network support yes threading support pthreads safe bitstream reader yes texi2html enabled no perl enabled yes pod2man enabled yes makeinfo enabled no makeinfo supports HTML no xmllint enabled no External libraries: iconv libbluray libvpx libx265 libxml2 zlib libaom libmp3lame libx264 libxcb libxvid External libraries providing hardware acceleration: cuda cuvid ffnvcodec nvdec v4l2_m2m Libraries: avcodec avfilter avutil swresample avdevice avformat postproc swscale Programs: ffmpeg ffprobe Enabled decoders: aac aura flv mp3adufloat pgm tmv aac_fixed aura2 fmvc mp3float pgmyuv truehd aac_latm av1 fourxm mp3on4 pgssub truemotion1 aasc avrn fraps mp3on4float pgx truemotion2 ac3 avrp frwu mpc7 phm truemotion2rt ac3_fixed avs g2m mpc8 photocd truespeech acelp_kelvin avui g723_1 mpeg1_cuvid pictor tscc adpcm_4xm ayuv g729 mpeg1_v4l2m2m pixlet tscc2 adpcm_adx bethsoftvid gdv mpeg1video pjs tta adpcm_afc bfi gem mpeg2_cuvid png twinvq adpcm_agm bink gif mpeg2_v4l2m2m ppm txd adpcm_aica binkaudio_dct gremlin_dpcm mpeg2video prores ulti adpcm_argo binkaudio_rdft gsm mpeg4 prosumer utvideo adpcm_ct bintext gsm_ms mpeg4_cuvid psd v210 adpcm_dtk bitpacked h261 mpeg4_v4l2m2m ptx v210x adpcm_ea bmp h263 mpegvideo qcelp v308 adpcm_ea_maxis_xa bmv_audio h263_v4l2m2m mpl2 qdm2 v408 adpcm_ea_r1 bmv_video h263i msa1 qdmc v410 adpcm_ea_r2 brender_pix h263p mscc qdraw vb adpcm_ea_r3 c93 h264 msmpeg4v1 qoi vble adpcm_ea_xas cavs h264_cuvid msmpeg4v2 qpeg vbn adpcm_g722 ccaption h264_v4l2m2m msmpeg4v3 qtrle vc1 adpcm_g726 cdgraphics hap msnsiren r10k vc1_cuvid adpcm_g726le cdtoons hca msp2 r210 vc1_v4l2m2m adpcm_ima_acorn cdxl hcom msrle ra_144 vc1image adpcm_ima_alp cfhd hevc mss1 ra_288 vcr1 adpcm_ima_amv cinepak hevc_cuvid mss2 ralf vmdaudio adpcm_ima_apc clearvideo hevc_v4l2m2m msvideo1 rasc vmdvideo adpcm_ima_apm cljr hnm4_video mszh rawvideo vmnc adpcm_ima_cunning cllc hq_hqa mts2 realtext vorbis adpcm_ima_dat4 comfortnoise hqx mv30 rl2 vp3 adpcm_ima_dk3 cook huffyuv mvc1 roq vp4 adpcm_ima_dk4 cpia hymt mvc2 roq_dpcm vp5 adpcm_ima_ea_eacs cri iac mvdv rpza vp6 adpcm_ima_ea_sead cscd idcin mvha rscc vp6a adpcm_ima_iss cyuv idf mwsc rv10 vp6f adpcm_ima_moflex dca iff_ilbm mxpeg rv20 vp7 adpcm_ima_mtf dds ilbc nellymoser rv30 vp8 adpcm_ima_oki derf_dpcm imc notchlc rv40 vp8_cuvid adpcm_ima_qt dfa imm4 nuv s302m vp8_v4l2m2m adpcm_ima_rad dfpwm imm5 on2avc sami vp9 adpcm_ima_smjpeg dirac indeo2 opus sanm vp9_cuvid adpcm_ima_ssi dnxhd indeo3 paf_audio sbc vp9_v4l2m2m adpcm_ima_wav dolby_e indeo4 paf_video scpr vplayer adpcm_ima_ws dpx indeo5 pam screenpresso vqa adpcm_ms dsd_lsbf interplay_acm pbm sdx2_dpcm wavpack adpcm_mtaf dsd_lsbf_planar interplay_dpcm pcm_alaw sga wcmv adpcm_psx dsd_msbf interplay_video pcm_bluray sgi webp adpcm_sbpro_2 dsd_msbf_planar ipu pcm_dvd sgirle webvtt adpcm_sbpro_3 dsicinaudio jacosub pcm_f16le sheervideo wmalossless adpcm_sbpro_4 dsicinvideo jpeg2000 pcm_f24le shorten wmapro adpcm_swf dss_sp jpegls pcm_f32be simbiosis_imx wmav1 adpcm_thp dst jv pcm_f32le sipr wmav2 adpcm_thp_le dvaudio kgv1 pcm_f64be siren wmavoice adpcm_vima dvbsub kmvc pcm_f64le smackaud wmv1 adpcm_xa dvdsub lagarith pcm_lxf smacker wmv2 adpcm_yamaha dvvideo libaom_av1 pcm_mulaw smc wmv3 adpcm_zork dxa libvpx_vp8 pcm_s16be smvjpeg wmv3image agm dxtory libvpx_vp9 pcm_s16be_planar snow wnv1 aic dxv loco pcm_s16le sol_dpcm wrapped_avframe alac eac3 lscr pcm_s16le_planar sonic ws_snd1 alias_pix eacmv m101 pcm_s24be sp5x xan_dpcm als eamad mace3 pcm_s24daud speedhq xan_wc3 amrnb eatgq mace6 pcm_s24le speex xan_wc4 amrwb eatgv magicyuv pcm_s24le_planar srgc xbin amv eatqi mdec pcm_s32be srt xbm anm eightbps metasound pcm_s32le ssa xface ansi eightsvx_exp microdvd pcm_s32le_planar stl xl ape eightsvx_fib mimic pcm_s64be subrip xma1 apng escape124 mjpeg pcm_s64le subviewer xma2 aptx escape130 mjpeg_cuvid pcm_s8 subviewer1 xpm aptx_hd evrc mjpegb pcm_s8_planar sunrast xsub arbc exr mlp pcm_sga svq1 xwd argo fastaudio mmvideo pcm_u16be svq3 y41p ass ffv1 mobiclip pcm_u16le tak ylc asv1 ffvhuff motionpixels pcm_u24be targa yop asv2 ffwavesynth movtext pcm_u24le targa_y216 yuv4 atrac1 fic mp1 pcm_u32be tdsc zero12v atrac3 fits mp1float pcm_u32le text zerocodec atrac3al flac mp2 pcm_u8 theora zlib atrac3p flashsv mp2float pcm_vidc thp zmbv atrac3pal flashsv2 mp3 pcx tiertexseqvideo atrac9 flic mp3adu pfm tiff Enabled encoders: a64multi ayuv huffyuv pcm_dvd pgm svq1 a64multi5 bitpacked jpeg2000 pcm_f32be pgmyuv targa aac bmp jpegls pcm_f32le phm text ac3 cfhd libaom_av1 pcm_f64be png tiff ac3_fixed cinepak libmp3lame pcm_f64le ppm truehd adpcm_adx cljr libvpx_vp8 pcm_mulaw prores tta adpcm_argo comfortnoise libvpx_vp9 pcm_s16be prores_aw ttml adpcm_g722 dca libx264 pcm_s16be_planar prores_ks utvideo adpcm_g726 dfpwm libx264rgb pcm_s16le qoi v210 adpcm_g726le dnxhd libx265 pcm_s16le_planar qtrle v308 adpcm_ima_alp dpx libxvid pcm_s24be r10k v408 adpcm_ima_amv dvbsub ljpeg pcm_s24daud r210 v410 adpcm_ima_apm dvdsub magicyuv pcm_s24le ra_144 vbn adpcm_ima_qt dvvideo mjpeg pcm_s24le_planar rawvideo vc2 adpcm_ima_ssi eac3 mlp pcm_s32be roq vorbis adpcm_ima_wav exr movtext pcm_s32le roq_dpcm vp8_v4l2m2m adpcm_ima_ws ffv1 mp2 pcm_s32le_planar rpza wavpack adpcm_ms ffvhuff mp2fixed pcm_s64be rv10 webvtt adpcm_swf fits mpeg1video pcm_s64le rv20 wmav1 adpcm_yamaha flac mpeg2video pcm_s8 s302m wmav2 alac flashsv mpeg4 pcm_s8_planar sbc wmv1 alias_pix flashsv2 mpeg4_v4l2m2m pcm_u16be sgi wmv2 amv flv msmpeg4v2 pcm_u16le smc wrapped_avframe apng g723_1 msmpeg4v3 pcm_u24be snow xbm aptx gif msvideo1 pcm_u24le sonic xface aptx_hd h261 nellymoser pcm_u32be sonic_ls xsub ass h263 opus pcm_u32le speedhq xwd asv1 h263_v4l2m2m pam pcm_u8 srt y41p asv2 h263p pbm pcm_vidc ssa yuv4 avrp h264_v4l2m2m pcm_alaw pcx subrip zlib avui hevc_v4l2m2m pcm_bluray pfm sunrast zmbv Enabled hwaccels: h264_nvdec mjpeg_nvdec mpeg2_nvdec vc1_nvdec vp9_nvdec hevc_nvdec mpeg1_nvdec mpeg4_nvdec vp8_nvdec wmv3_nvdec Enabled parsers: aac cavsvideo dvbsub h263 mpegvideo tak aac_latm cook dvd_nav h264 opus vc1 ac3 cri dvdsub hevc png vorbis adx dca flac ipu pnm vp3 amr dirac g723_1 jpeg2000 qoi vp8 av1 dnxhd g729 mjpeg rv30 vp9 avs2 dolby_e gif mlp rv40 webp avs3 dpx gsm mpeg4video sbc xbm bmp dvaudio h261 mpegaudio sipr xma Enabled demuxers: aa cine idf lmlm4 pcm_mulaw spdif aac codec2 iff loas pcm_s16be srt aax codec2raw ifv lrc pcm_s16le stl ac3 concat ilbc luodat pcm_s24be str ace dash image2 lvf pcm_s24le subviewer acm data image2_alias_pix lxf pcm_s32be subviewer1 act daud image2_brender_pix m4v pcm_s32le sup adf dcstr image2pipe matroska pcm_s8 svag adp derf image_bmp_pipe mca pcm_u16be svs ads dfa image_cri_pipe mcc pcm_u16le swf adx dfpwm image_dds_pipe mgsts pcm_u24be tak aea dhav image_dpx_pipe microdvd pcm_u24le tedcaptions afc dirac image_exr_pipe mjpeg pcm_u32be thp aiff dnxhd image_gem_pipe mjpeg_2000 pcm_u32le threedostr aix dsf image_gif_pipe mlp pcm_u8 tiertexseq alp dsicin image_j2k_pipe mlv pcm_vidc tmv amr dss image_jpeg_pipe mm pjs truehd amrnb dts image_jpegls_pipe mmf pmp tta amrwb dtshd image_jpegxl_pipe mods pp_bnk tty anm dv image_pam_pipe moflex pva txd apc dvbsub image_pbm_pipe mov pvf ty ape dvbtxt image_pcx_pipe mp3 qcp v210 apm dxa image_pfm_pipe mpc r3d v210x apng ea image_pgm_pipe mpc8 rawvideo vag aptx ea_cdata image_pgmyuv_pipe mpegps realtext vc1 aptx_hd eac3 image_pgx_pipe mpegts redspark vc1t aqtitle epaf image_phm_pipe mpegvideo rl2 vividas argo_asf ffmetadata image_photocd_pipe mpjpeg rm vivo argo_brp filmstrip image_pictor_pipe mpl2 roq vmd argo_cvg fits image_png_pipe mpsub rpl vobsub asf flac image_ppm_pipe msf rsd voc asf_o flic image_psd_pipe msnwc_tcp rso vpk ass flv image_qdraw_pipe msp rtp vplayer ast fourxm image_qoi_pipe mtaf rtsp vqf au frm image_sgi_pipe mtv s337m w64 av1 fsb image_sunrast_pipe musx sami wav avi fwse image_svg_pipe mv sap wc3 avr g722 image_tiff_pipe mvi sbc webm_dash_manifest avs g723_1 image_vbn_pipe mxf sbg webvtt avs2 g726 image_webp_pipe mxg scc wsaud avs3 g726le image_xbm_pipe mythtv_mpegts scd wsd bethsoftvid g729 image_xpm_pipe mythtv_mpegtsraw sdp wsvqa bfi gdv image_xwd_pipe nc sdr2 wtv bfstm genh imf nistsphere sds wv bink gif ingenient nsp sdx wve binka gsm ipmovie nsv segafilm xa bintext gxf ipu nut ser xbin bit h261 ircam nuv sga xmv bitpacked h263 iss obu shorten xvag bmv h264 iv8 ogg siff xwma boa hca ivf oma simbiosis_imx yop brstm hcom ivr paf sln yuv4mpegpipe c93 hevc jacosub pcm_alaw smacker caf hls jv pcm_f32be smjpeg cavsvideo hnm kux pcm_f32le smush cdg ico kvag pcm_f64be sol cdxl idcin live_flv pcm_f64le sox Enabled muxers: a64 crc h263 mp3 pcm_s16le sox ac3 dash h264 mp4 pcm_s24be spdif adts data hash mpeg1system pcm_s24le spx adx daud hds mpeg1vcd pcm_s32be srt aiff dfpwm hevc mpeg1video pcm_s32le stream_segment alp dirac hls mpeg2dvd pcm_s8 streamhash amr dnxhd ico mpeg2svcd pcm_u16be sup amv dts ilbc mpeg2video pcm_u16le swf apm dv image2 mpeg2vob pcm_u24be tee apng eac3 image2pipe mpegts pcm_u24le tg2 aptx f4v ipod mpjpeg pcm_u32be tgp aptx_hd ffmetadata ircam mxf pcm_u32le truehd argo_asf fifo ismv mxf_d10 pcm_u8 tta argo_cvg fifo_test ivf mxf_opatom pcm_vidc ttml asf filmstrip jacosub null psp uncodedframecrc asf_stream fits kvag nut rawvideo vc1 ass flac latm obu rm vc1t ast flv lrc oga roq voc au framecrc m4v ogg rso w64 avi framehash matroska ogv rtp wav avif framemd5 matroska_audio oma rtp_mpegts webm avm2 g722 md5 opus rtsp webm_chunk avs2 g723_1 microdvd pcm_alaw sap webm_dash_manifest avs3 g726 mjpeg pcm_f32be sbc webp bit g726le mkvtimestamp_v2 pcm_f32le scc webvtt caf gif mlp pcm_f64be segafilm wsaud cavsvideo gsm mmf pcm_f64le segment wtv codec2 gxf mov pcm_mulaw smjpeg wv codec2raw h261 mp2 pcm_s16be smoothstreaming yuv4mpegpipe Enabled protocols: async crypto gopher md5 rtmp tcp bluray data hls mmsh rtmpt tee cache ffrtmphttp http mmst rtp udp concat file httpproxy pipe srtp udplite concatf ftp icecast prompeg subfile unix Enabled filters: abench asetpts curves hdcd oscilloscope silenceremove abitscope asetrate datascope headphone overlay sinc acompressor asettb dblur hflip owdenoise sine acontrast ashowinfo dcshift highpass pad siti acopy asidedata dctdnoiz highshelf pal100bars smartblur acrossfade asoftclip deband hilbert pal75bars smptebars acrossover aspectralstats deblock histeq palettegen smptehdbars acrusher asplit decimate histogram paletteuse sobel acue astats deconvolve hqdn3d pan spectrumsynth addroi astreamselect dedot hqx perms speechnorm adeclick asubboost deesser hstack perspective split adeclip asubcut deflate hsvhold phase spp adecorrelate asupercut deflicker hsvkey photosensitivity sr adelay asuperpass dejudder hue pixdesctest ssim adenorm asuperstop delogo huesaturation pixelize stereo3d aderivative atadenoise derain hwdownload pixscope stereotools adrawgraph atempo deshake hwmap pp stereowiden adynamicequalizer atilt despill hwupload pp7 streamselect adynamicsmooth atrim detelecine hwupload_cuda premultiply super2xsai aecho avectorscope dialoguenhance hysteresis prewitt superequalizer aemphasis avgblur dilation identity pseudocolor surround aeval avsynctest displace idet psnr swaprect aevalsrc axcorrelate dnn_classify il pullup swapuv aexciter bandpass dnn_detect inflate qp tblend afade bandreject dnn_processing interlace random telecine afftdn bass doubleweave interleave readeia608 testsrc afftfilt bbox drawbox join readvitc testsrc2 afifo bench drawgraph kerndeint realtime thistogram afir bilateral drawgrid kirsch remap threshold afirsrc biquad drmeter lagfun removegrain thumbnail aformat bitplanenoise dynaudnorm latency removelogo tile afreqshift blackdetect earwax lenscorrection repeatfields tiltshelf afwtdn blackframe ebur128 life replaygain tinterlace agate blend edgedetect limitdiff reverse tlut2 agraphmonitor blockdetect elbg limiter rgbashift tmedian ahistogram blurdetect entropy loop rgbtestsrc tmidequalizer aiir bm3d epx loudnorm roberts tmix aintegral boxblur eq lowpass rotate tonemap ainterleave bwdif equalizer lowshelf sab tpad alatency cas erosion lumakey scale transpose alimiter cellauto estdif lut scale2ref treble allpass channelmap exposure lut1d scdet tremolo allrgb channelsplit extractplanes lut2 scharr trim allyuv chorus extrastereo lut3d scroll unpremultiply aloop chromahold fade lutrgb segment unsharp alphaextract chromakey feedback lutyuv select untile alphamerge chromanr fftdnoiz mandelbrot selectivecolor v360 amerge chromashift fftfilt maskedclamp sendcmd vaguedenoiser ametadata ciescope field maskedmax separatefields varblur amix codecview fieldhint maskedmerge setdar vectorscope amovie color fieldmatch maskedmin setfield vflip amplify colorbalance fieldorder maskedthreshold setparams vfrdet amultiply colorchannelmixer fifo maskfun setpts vibrance anequalizer colorchart fillborders mcompand setrange vibrato anlmdn colorcontrast find_rect median setsar vif anlmf colorcorrect firequalizer mergeplanes settb vignette anlms colorhold flanger mestimate shear virtualbass anoisesrc colorize floodfill metadata showcqt vmafmotion anull colorkey format midequalizer showfreqs volume anullsink colorlevels fps minterpolate showinfo volumedetect anullsrc colormap framepack mix showpalette vstack apad colormatrix framerate monochrome showspatial w3fdif aperms colorspace framestep morpho showspectrum waveform aphasemeter colorspectrum freezedetect movie showspectrumpic weave aphaser colortemperature freezeframes mpdecimate showvolume xbr aphaseshift compand fspp mptestsrc showwaves xcorrelate apsyclip compensationdelay gblur msad showwavespic xfade apulsator concat geq multiply shuffleframes xmedian arealtime convolution gradfun negate shufflepixels xstack aresample convolve gradients nlmeans shuffleplanes yadif areverse copy graphmonitor nnedi sidechaincompress yaepblur arnndn cover_rect grayworld noformat sidechaingate yuvtestsrc asdr crop greyedge noise sidedata zoompan asegment cropdetect guided normalize sierpinski aselect crossfeed haas null signalstats asendcmd crystalizer haldclut nullsink signature asetnsamples cue haldclutsrc nullsrc silencedetect Enabled bsfs: aac_adtstoasc dv_error_marker hapqa_extract mp3_header_decompress pgs_frame_merge vp9_metadata av1_frame_merge eac3_core hevc_metadata mpeg2_metadata prores_metadata vp9_raw_reorder av1_frame_split extract_extradata hevc_mp4toannexb mpeg4_unpack_bframes remove_extradata vp9_superframe av1_metadata filter_units imx_dump_header noise setts vp9_superframe_split chomp h264_metadata mjpeg2jpeg null text2movsub dca_core h264_mp4toannexb mjpega_dump_header opus_metadata trace_headers dump_extradata h264_redundant_pps mov2textsub pcm_rechunk truehd_core Enabled indevs: fbdev lavfi oss v4l2 xcbgrab Enabled outdevs: fbdev oss License: GPL version 2 or later libavutil/avconfig.h is unchanged libavfilter/filter_list.c is unchanged libavcodec/parser_list.c is unchanged libavcodec/bsf_list.c is unchanged libavformat/demuxer_list.c is unchanged libavformat/muxer_list.c is unchanged libavdevice/indev_list.c is unchanged libavdevice/outdev_list.c is unchanged libavformat/protocol_list.c is unchanged CONFIG_NVDEC=yes #### MythTV CONFIGURATION #### # Basic Settings Qt minimum version 5.12 Qt installed version 5.12.8 Compile type release Compiler cache no DistCC no qmake /usr/bin/qmake install prefix /usr/local runtime prefix /usr/local CPU aarch64 NEON enabled yes (Intrinsics yes) VFP enabled yes Creating configuration files ... # Input Support Joystick menu yes lirc support yes libCEC device support no [/usr/include] Video4Linux support yes FireWire support no DVB support yes [/usr/include] DVB-S2 support yes HDHomeRun support no Sat>IP support no V@Box TV Gateway support no Ceton support no DVEO ASI support no # Sound Output Support PulseAudio support no OSS support yes ALSA support no JACK support default # Video Output Support x11/xrandr support yes VDPAU support no NVDEC support yes VAAPI support no DRM support no Video4Linux codecs yes (DRM no) MMAL decoder support no OpenGL yes (OpenGLES yes) EGL support yes Vulkan no (libglslang no) MHEG support yes libass subtitle support no # Misc Features Frontend yes Backend yes Qt private headers no Wayland extras no multi threaded libavcodec yes libxml2 support yes [/usr/include/libxml2] libdns_sd (Bonjour) no libcrypto no gnutls no exiv2 support yes (internal) udfread support yes (internal) bluray support yes (system) systemd_notify no systemd_journal no # Bindings bindings_perl yes bindings_python yes bindings_php yes # External Codec Options mp3lame yes xvid yes x264 yes x265 (HEVC) yes vpx yes libaom (AV1) yes libdav1d (AV1) no # Compilation Options C++ standard supported c++17 Enforce c++11 nullptr yes Enforce shadowed vars yes Creating libs/libmythbase/mythconfig.h and libs/libmythbase/mythconfig.mak Created libs/libmythbase/mythconfig.h Created libs/libmythbase/mythconfig.mak Creating settings2.pro settings2.pro is unchanged Creating libs/libmythbase/mythversion.h libs/libmythbase/mythversion.h is unchanged Creating bindings/perl/Makefile.PL bindings/perl/Makefile.PL is unchanged Creating bindings/python/setup.cfg bindings/python/setup.cfg is unchanged Creating bindings/python/MythTV/static.py bindings/python/MythTV/static.py is unchanged Creating bindings/python/MythTV/services_api/mythversions.py bindings/python/MythTV/services_api/mythversions.py is unchanged Configuring libudfread... Configuring libexiv2... Configuring libmythdvdnav... WARNING: QtWebkit disabled. WARNING: QtScript disabled.
